02-Appendix B Sensor Name and Description | 52.75 KB |
Appendix A
Table 1 Sensor name and description
Sensor type |
Sensor name |
Sensor description |
Temperature |
Inlet_Temp |
Air inlet temperature (only one available) |
Outlet_Temp |
Air outlet temperature (only one available) |
CPUx_Temp |
CPUx core temperature |
CPUx_DTS |
Remaining temperature before CPU throttling |
CPUx_DIMM_Temp |
Max. temperature of common DIMMs for CPUx (x represents the CPU number starting from 1, such as 1 and 2) |
Front_HD_Max |
Max. temperature of front drives |
Mid_HD_Max |
Max. temperature of middle drives |
Rear_HD_Max |
Max. temperature of rear drives |
Front_NVMe_Max |
Max. temperature of front NVMe drives |
Mid_NVMe_Max |
Max. temperature of middle NVMe drives |
Rear_NVMe_Max |
Max. temperature of rear NVMe drives |
M.2_Max |
Max. temperature of M.2 drives |
M.2_Zone |
M.2 zone temperature |
PCH_Temp |
PCH temperature |
PSUx_Temp |
Power supply x air inlet temperature |
CPUx_VR_Temp |
Max. CPU VR value |
PCIex_Temp |
PCIe x temperature |
OCPx_Temp |
OCP card temperature |
Busbarx_Zone |
BusBar temperature |
DSFP_Max |
Max. transceiver module temperature |
Voltage |
CPUx_VCORE |
CPUx core voltage |
PSUx_VIN |
Power supply N input voltage |
PSUx_VOUT |
Power supply N output voltage |
SYS_12V |
System 12V voltage (system HSC output voltage) |
SYS_5V |
System 5V voltage |
SYS_3V3_Standby |
System 3.3V voltage |
SYS_3V_BAT |
Voltage of the RTC battery on the system board |
CPUx_DDR_VDDQ1 |
Memory voltage sensor (VDDQ1) |
CPUx_DDR_VDDQ2 |
Memory voltage sensor (VDDQ2) |
Current |
PSUN_IIN |
Power supply N input current |
PSUN_IOUT |
Power supply N output current |
Power |
Total_Power |
Total chassis power |
FAN_Power |
Total fan power |
CPU_Power |
Total CPU power |
MEM_Power |
Total memory power |
DISK_Power |
Total drive power |
GPU_Power |
Total GPU power |
PSUx_PIN |
Power supply x input power |
PSUx_POUT |
Power supply x output power |
Rotation speed |
FANx_Speed or FANx_F_Speed or FANx_R_Speed |
Rotation speed of fan module x in RPM or rotation speed of the front fan in fan module x in RPM or rotation speed of the rear fan in fan module x in RPM |
Status |
CPUx_Status |
CPU x status (x: 0 to n) |
CPUx_Chy_Dz |
Memory status, including status in the BIOS and MCA error parsing status The sensor is displayed in the following modes: · Mode 1: ¡ x represents the CPU number, starting from 1, such as 1 and 2. ¡ y represents the DIMM channel number (channel ID), starting from 1, such as 1 to 8. ¡ z represents the DIMM ID in each channel, starting from 0, such as 0 and 1. · Mode 2: x represents the CPU number, A#, B#, C#... A pound sign (#) represents the DIMM ID in each channel, starting from 0, such as 0 and 1. A=Channel1 B=Channel2 … |
Watchdog2 |
System watchdog overflow and action |
Sys_Restart |
System startup/startup reason |
SysShutdown |
System shutdown reason |
Boards |
Exceptional host power outage |
Sys_FW_Progress |
System firmware (BIOS) and POST status |
ACPI_State |
ACPI power status |
PSUx_Status |
System power supply x status (x: 0 to n) |
PSU_Mismatch |
Overall power status |
PSU_Redundant |
System power redundancy status |
FANx_Status or FANx_F_Speed or FANx_R_Speed |
Fan x status Status of front/rear fan in fan module x (x: 0 to n) A centrifugal fan module includes front and rear fans. The status sensors for upper and down fans are named in different formats, such as FANx_U_Status and FANx_D_Status, or FANx_U_F_Status, FANx_U_R_Status, FANx_D_F_Status, and FANx_D_R_Status |
Front: Disk_Fx_Status Rear: Disk_Rx_Status Middle: Disk_Mx_Status |
Drive status (x: 0 to n) |
Front: M2_SSD_Fx_Status M2_NVMe_Fx_Sts Rear: M2_SSD_Rx_Status M2_NVMe_Rx_Sts |
Drive status (x: 0 to 2) |
LAN_Leash_Lost |
Link status of network adapter ports |
PCIe_Status |
Overall PCIe alarm status |
PCIex_PM_LNK |
PCIe link status of port M in standard PCIe slot x |
Px_PCIe_Status |
PCIe status of the module in standard PCIe slot x This status indicates the fault status of the PCIe bus and slot with x representing the PCIe slot number, in the range of 0 to n. The status information is obtained by PCIe faults from the BIOS or is interpreted from the MCA register |
BMC_Boot_Up |
BMC startup |
UID_Button |
Long press on the UID button on the panel for BMC reset |
SEL_Status |
SEL status |
PCIe_Riserx_PG |
Riser card PG status |
F_BPx_Status |
Status of front drive backplane x (x: 0 to n, depending on product marks) |
M_BPx_Status |
Status of middle drive backplane x (x: 0 to n, depending on product marks) |
R_BPx_Status |
Status of rear drive backplane x (x: 0 to n, depending on product marks) |
AreaIntrusion |
Chassis status |
Liquid_Cooler |
Liquid-cooled leak sensor |
BMC_Boot_Up |
BMC startup |
