03-Typical Configuration Example
HomeSupportRoutersCR16000-F SeriesConfigure & DeployConfiguration ExamplesH3C CR16000-F Routers Configuration Examples All-In-One-R838x-6W10103-Typical Configuration Example
Table of Contents
Related Documents
38-H3C_OSPFv3_Configuration_Examples
38-H3C_OSPFv3_Configuration_Examples 125.60 KB
Introduction
This document provides OSPFv3 route filtering configuration examples.
This document assumes that you have basic knowledge of OSPFv3 route filtering.
Example: Configuring OSPFv3 route filtering
As shown in Figure 1, the devices of an enterprise reside in OSPFv3 and RIPng domains.
Configure route redistribution between OSPFv3 and RIPng to interconnect the devices.
Configure route filtering on Device E, Device C, and Device D to meet the following requirements:
·     The route destined for R&D department 2 is not redistributed to OSPFv3.
·     Marketing department 1 cannot reach R&D department 1.
·     R&D department 1 and the After-sale service department cannot reach Marketing department 2.
Figure 1 Network diagram
Device
IP address
Device
IP address
Device A
XGE3/1/1
1::1/64
Device B
XGE3/1/1
1::2/64
XGE3/1/2
2::1/64
XGE3/1/2
3::1/64
XGE3/1/3
4::1/64
Device C
XGE3/1/1
2::2/64
Device D
XGE3/1/1
3::2/64
Loop0
13::1/64
Loop0
11::1/64
Loop1
12::1/64
Device E
XGE3/1/1
4::2/64
Device F
XGE3/1/1
5::2/64
XGE3/1/2
5::1/64
Loop0
14::1/64
Loop1
15::1/64
When you configure OSPFv3 route filtering, follow these restrictions and guidelines:
·     The filter-policy export command that filters redistributed routes takes effect only on an ASBR.
·     OSPFv3 filters routes calculated using received LSAs. It does not filter LSAs.
·     IP communication is bidirectional. If a router filters a route destined for Network A, the subnets attached to the router cannot reach Network A, and Network A cannot reach the subnets.
·     When you configure route filtering by referencing an ACL, configure the rule permit source any item following multiple rule deny source items to allow unmatched routes to pass.
·     Specify a Router ID when you configure OSPFv3.
Procedures
Configuring IPv6 addresses
# Configure an IPv6 address for Ten-GigabitEthernet3/1/1.
[DeviceA] interface Ten-GigabitEthernet 3/1/1
[DeviceA-Ten-GigabitEthernet3/1/1] ipv6 address 1::1 64
# Configure IPv6 addresses for other interfaces, as shown in Figure 1. (Details not shown.)
Configuring OSPFv3
# Enable OSPFv3 on Device A.
[DeviceA] ospfv3
[DeviceA-ospfv3-1] router-id 6.6.6.6
[DeviceA-ospfv3-1] quit
[DeviceA-Ten-GigabitEthernet3/1/1] ospfv3 1 area 0
[DeviceA-Ten-GigabitEthernet3/1/1]quit
[DeviceA] interface Ten-GigabitEthernet 3/1/2
[DeviceA-Ten-GigabitEthernet3/1/2] ospfv3 1 area 2
[DeviceA-Ten-GigabitEthernet3/1/2]quit
[DeviceA] interface Ten-GigabitEthernet 3/1/3
[DeviceA-Ten-GigabitEthernet3/1/3] ospfv3 1 area 1
[DeviceA-Ten-GigabitEthernet3/1/3]quit
# Enable OSPFv3 on Device B.
[DeviceB] ospfv3
[DeviceB-ospfv3-1] router-id 5.5.5.5
[DeviceB-ospfv3-1] quit
[DeviceB] interface Ten-GigabitEthernet 3/1/1
[DeviceB-Ten-GigabitEthernet3/1/1] ospfv3 1 area 0
[DeviceB-Ten-GigabitEthernet3/1/1]quit
[DeviceB] interface Ten-GigabitEthernet 3/1/2
[DeviceB-Ten-GigabitEthernet3/1/2] ospfv3 1 area 3
[DeviceB-Ten-GigabitEthernet3/1/2]quit
# Enable OSPFv3 on Device C.
<DeviceC> system-view
[DeviceC] ospfv3
[DeviceC-ospfv3-1] router-id 4.4.4.4
[DeviceC-ospfv3-1] quit
[DeviceC] interface Ten-GigabitEthernet 3/1/1
[DeviceC-Ten-GigabitEthernet3/1/1] ospfv3 1 area 2
[DeviceC-Ten-GigabitEthernet3/1/1]quit
[DeviceC]interface LoopBack 0
[DeviceC-LoopBack0] ospfv3 1 area 2
[DeviceC-LoopBack0] quit
# Enable OSPFv3 on Device D.
<DeviceD> system-view
[DeviceD] ospfv3
[DeviceD-ospfv3-1] router-id 3.3.3.3
[DeviceD-ospfv3-1] quit
[DeviceD] interface Ten-GigabitEthernet 3/1/1
[DeviceD-Ten-GigabitEthernet3/1/1] ospfv3 1 area 3
[DeviceD-Ten-GigabitEthernet3/1/1]quit
[DeviceD]interface LoopBack 0
[DeviceD-LoopBack0] ospfv3 1 area 3
[DeviceD-LoopBack0] quit
[DeviceD]interface LoopBack 1
[DeviceD-LoopBack1] ospfv3 1 area 3
[DeviceD-LoopBack1] quit
# Enable OSPFv3 on Device E.
<DeviceE> system-view
[DeviceE] ospfv3
[DeviceE-ospfv3-1] router-id 2.2.2.2
[DeviceE-ospfv3-1] quit
[DeviceE] interface Ten-GigabitEthernet 3/1/1
[DeviceE-Ten-GigabitEthernet3/1/1] ospfv3 1 area 1
[DeviceE-Ten-GigabitEthernet3/1/1]quit
Configure RIPng
# Enable RIPng on Device E.
[DeviceE] ripng
[DeviceE-ripng-1] quit
[DeviceE] interface Ten-GigabitEthernet 3/1/2
[DeviceE-Ten-GigabitEthernet3/1/2] ripng 1 enable
[DeviceE-Ten-GigabitEthernet3/1/2] quit
# Enable RIPng on Device F.
<DeviceF> system-view
[DeviceF] ripng
[DeviceF-ripng-1] quit
[DeviceF] interface Ten-GigabitEthernet 3/1/1
[DeviceF-Ten-GigabitEthernet3/1/1] ripng 1 enable
[DeviceF-Ten-GigabitEthernet3/1/1] quit
[DeviceF]interface LoopBack 0
[DeviceF-LoopBack0] ripng 1 enable
[DeviceF-LoopBack0] quit
[DeviceF]interface LoopBack 1
[DeviceF-LoopBack1] ripng 1 enable
[DeviceF-LoopBack1] quit
Configuring route redistribution
# Configure Device E to redistribute OSPFv3 and direct routes to RIPng.
[DeviceE] ripng
[DeviceE-ripng-1] import-route direct
[DeviceE-ripng-1] import-route ospfv3
# Configure Device E to redistribute RIPng and direct routes to OSPFv3.
[DeviceE] ospfv3
[DeviceE-ospfv3-1] import-route direct
[DeviceE-ospfv3-1] import-route ripng
# Verify that Device E has routes to all networks.
[Device E]display ipv6 routing-table
Destinations : 15        Routes : 15
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Interface  : InLoop0                                     Cost      : 0
Destination: 1::/64                                      Protocol  : O_INTER
NextHop    : FE80::2E0:FCFF:FE58:124D                    Preference: 10
Interface  : XGE3/1/1                                    Cost      : 2
Destination: 2::/64                                      Protocol  : O_INTER
Destination: 3::/64                                      Protocol  : O_INTER
Interface  : XGE3/1/1                                    Cost      : 3
Destination: 4::/64                                      Protocol  : Direct
NextHop    : ::                                          Preference: 0
Interface  : XGE3/1/1                                    Cost      : 0
Destination: 4::2/128                                    Protocol  : Direct
Destination: 5::/64                                      Protocol  : Direct
Interface  : XGE3/1/2                                    Cost      : 0
Destination: 5::1/128                                    Protocol  : Direct
Destination: 11::1/128                                   Protocol  : O_INTER
Destination: 12::1/128                                   Protocol  : O_INTER
Destination: 13::1/128                                   Protocol  : O_INTER
Destination: 14::/64                                     Protocol  : RIPng
NextHop    : FE80::2E0:FCFF:FE11:19B5                    Preference: 100
Interface  : XGE3/1/2                                    Cost      : 1
Destination: 15::/64                                     Protocol  : RIPng
Destination: FE80::/10                                   Protocol  : Direct
Destination: FF00::/8                                    Protocol  : Direct
Interface  : NULL0
# Verify that other devices have routes to all networks. (Details not shown.)
# On Device C, configure IPv6 basic ACL 2000 to deny 12::1/64.
[DeviceC] acl ipv6 basic 2000
[DeviceC-acl-ipv6-basic-2000] rule 0 deny source 12::1 64
[DeviceC-acl-ipv6-basic-2000] rule permit source any
[DeviceC-acl-ipv6-basic-2000] quit
# On Device C, use IPv6 ACL 2000 to filter received routes.
[DeviceC] ospfv3
[DeviceC-ospfv3-1] filter-policy 2000 import
# On Device D, configure IPv6 basic ACL 2000 to deny 15::1/64.
[DeviceD] acl ipv6 basic 2000
[DeviceD-acl-ipv6-basic-2000] rule 0 deny source 15::1 64
[DeviceD-acl-ipv6-basic-2000] rule permit source any
[DeviceD-acl-ipv6-basic-2000] quit
# On Device D, use IPv6 ACL 2000 to filter received routes.
[DeviceD] ospfv3
[DeviceD-ospfv3-1] filter-policy 2000 import
# On Device E, configure IPv6 basic ACL 2000 to deny 14::1/64.
[DeviceE] acl ipv6 basic 2000
[DeviceE-acl-ipv6-basic-2000] rule 0 deny source 14::1 64
[DeviceE-acl-ipv6-basic-2000] rule permit source any
[DeviceE-acl-ipv6-basic-2000] quit
# On Device E, use IPv6 ACL 2000 to filter routes redistributed from RIPng.
[DeviceE] ospfv3
[DeviceE-ospfv3-1] filter-policy 2000 export ripng 1
# Verify that Device C does not have a route to 12::/64.
[DeviceC]display ipv6 routing-table
Destinations : 13        Routes : 13
NextHop    : FE80::2E0:FCFF:FE58:1245                    Preference: 10
Destination: 2::/64                                      Protocol  : Direct
Destination: 2::2/128                                    Protocol  : Direct
Destination: 4::/64                                      Protocol  : O_INTER
Destination: 5::/64                                      Protocol  : O_ASE2
NextHop    : FE80::2E0:FCFF:FE58:1245                    Preference: 150
Interface  : XGE3/1/1                                    Cost      : 1
Destination: 13::/64                                     Protocol  : Direct
Interface  : Loop0                                       Cost      : 0
Destination: 13::1/128                                   Protocol  : Direct
Destination: 15::/64                                     Protocol  : O_ASE2
Interface  : NULL0
# Verify that Marketing department 1 cannot reach R&D department 1.
[DeviceC] ping ipv6 -a 13::1 12::1
Ping6(56 data bytes) 13::1 --> 12::1, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
--- Ping6 statistics for 12::1 ---
5 packet(s) transmitted, 0 packet(s) received, 100.0% packet loss
# Verify that Device D does not have a route to 15::/64.
[DeviceD]display ipv6 routing-table
Destinations : 14        Routes : 14
NextHop    : FE80::2A0:FCFF:FE00:5815                    Preference: 10
Destination: 3::/64                                      Protocol  : Direct
Destination: 3::2/128                                    Protocol  : Direct
NextHop    : FE80::2A0:FCFF:FE00:5815                    Preference: 150
Destination: 11::/64                                     Protocol  : Direct
Destination: 11::1/128                                   Protocol  : Direct
Destination: 12::/64                                     Protocol  : Direct
Interface  : Loop1                                       Cost      : 0
Destination: 12::1/128                                   Protocol  : Direct
Interface  : NULL0                                       Cost      : 0
Interface  : NULL0
# Verify that the After-sale service department cannot reach Marketing department 2.
[DeviceD] ping ipv6 -a 11::1 15::1
Ping6(56 data bytes) 11::1 --> 15::1, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
--- Ping6 statistics for 15::1 ---
# Verify that R&D department 1 cannot reach Marketing department 2.
[DeviceD] ping ipv6 -a 12::1 15::1
Ping6(56 data bytes) 12::1 --> 15::1, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
The output on Device C and Device D shows that Device E has filtered the route destined for R&D development 2.
Configuration files
·     Device A:
ospfv3 1
 router-id 6.6.6.6
 area 0.0.0.0
 area 0.0.0.1
 area 0.0.0.2
interface Ten-GigabitEthernet3/1/1
 ospfv3 1 area 0.0.0.0
 ipv6 address 1::1/64
interface Ten-GigabitEthernet3/1/2
 ospfv3 1 area 0.0.0.2
 ipv6 address 2::1/64
interface Ten-GigabitEthernet3/1/3
 ospfv3 1 area 0.0.0.1
 ipv6 address 4::1/64
·     Device B:
ospfv3 1
 router-id 5.5.5.5
 area 0.0.0.0
 area 0.0.0.3
 ipv6 address 1::2/64
 ospfv3 1 area 0.0.0.3
 ipv6 address 3::1/64
·     Device C:
ospfv3 1
 router-id 4.4.4.4
 area 0.0.0.2
interface LoopBack0
 ipv6 address 13::1/64
 ipv6 address 2::2/64
acl ipv6 basic 2000
 rule 0 deny source 12::/64
 rule 5 permit
·     Device D:
ospfv3 1
 router-id 3.3.3.3
 area 0.0.0.3
interface LoopBack0
 ipv6 address 11::1/64
interface LoopBack1
 ipv6 address 12::1/64
 ipv6 address 3::2/64
acl ipv6 basic 2000
 rule 0 deny source 15::/64
 rule 5 permit
·     Device E:
ospfv3 1
 router-id 2.2.2.2
 import-route direct
import-route ripng 1
 area 0.0.0.1
ripng 1
 import-route direct
 import-route ospfv3 1
 ipv6 address 4::2/64
 ipv6 address 5::1/64
 ripng 1 enable
acl ipv6 basic 2000
 rule 0 deny source 14::/64
 rule 5 permit
·     Device F:
ripng 1
interface LoopBack0
 ipv6 address 14::1/64
 ripng 1 enable
interface LoopBack1
 ipv6 address 15::1/64
 ripng 1 enable
 ipv6 address 5::2/64
 ripng 1 enable
Related documentation
·     H3C CR16000-F Routers Layer—3 IP Routing Configuration Guide-R8385P09
·     H3C CR16000-F Routers Layer—3 IP Routing Command Reference-R8385P09
