05-Layer 2—LAN Switching
HomeSupportReference GuidesMIB CompanionH3C SR6600[SR6600-X] Routers MIB Reference-R6749-6W10005-Layer 2—LAN Switching
09-LLDP-EXT-DOT1-V2-MIB
09-LLDP-EXT-DOT1-V2-MIB 131.90 KB
About this MIB
LLDP facilitates network management to discover and use network physical topology in a standard way, and enables network management to discover configuration inconsistencies or errors that affect the upper-layer applications. Although H3C products already support the LLDP 2009 version, they still use the MIBs of the LLDP 2005 version.
The MIB of the LLDP 2009 version is also referred to as LLDP-V2-MIB. This MIB is a standard public MIB, which contains LLDP configuration, LLDP statistics, local LLDP information, neighboring LLDP information, and IEEE 802.1 extended configuration, DCBX extended configuration, IEEE 802.3 extended configuration. The CNP extended configuration is not supported in Comware V700R001.
MIB file name
lldp-ext-dot1-v2.mib
Root object
iso(1).org(3).ieee(111).standards-association-numbers-series-standards(2).lan-man-stds(802).ieee802dot1(1).ieee802dot1mibs(1).lldpV2MIB(13).lldpV2Objects(1).lldpV2Extensions(5).lldpV2Xdot1MIB(32962)
Tabular objects
lldpV2Xdot1ConfigPortVlanTable
About this table
This table controls selection of LLDP port VLAN TLVs to be transmitted on individual ports.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are lldpV2PortConfigIfIndex and lldpV2PortConfigDestAddressIndex.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1ConfigPortVlanTxEnable (1.3.111.2.802.1.1.13.1.5.32962.1.1.1.1.1)
read-write
TruthValue
true(1),
false(2)
Indicates whether the port VLAN TLV transmission is enabled on a given LLDP transmission capable port.
The default is true for the following agents: Nearest bridge agents and nearest customer bridge agents on the Layer 2 Ethernet interfaces. Nearest customer bridge agents on Layer 2 aggregate interfaces.
lldpV2Xdot1ConfigVlanNameTable
About this table
This table controls selection of LLDP VLAN name TLV instances to be transmitted on individual ports.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are lldpV2LocPortIfIndex and lldpV2Xdot1LocVlanId.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1ConfigVlanNameTxEnable (1.3.111.2.802.1.1.13.1.5.32962.1.1.2.1.1)
read-write
TruthValue
true(1),
false(2)
Indicates whether the agents on the ports of the device can send VLAN name TLVs.
By default, the value is 0 and the status is FALSE. If this object is set to TRUE, the VLAN with the minimum VLAN ID is enabled. To delete an enabled VLAN, set the VLAN status to FALSE. Only one VLAN name TLV is supported in an LLDP packet.
As a best practice, do not perform the walk operation from the MIB browser, because it takes a long time to walk through all ports and VLANs.
lldpV2Xdot1ConfigProtoVlanTable
About this table
This table controls selection of LLDP port and protocol VLAN ID TLV instances to be transmitted on individual ports.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are lldpV2LocPortIfIndex and lldpV2Xdot1LocProtoVlanId.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1ConfigProtoVlanTxEnable (1.3.111.2.802.1.1.13.1.5.32962.1.1.3.1.1)
read-write
TruthValue
true(1),
false(2)
Indicates whether the transmission of port and protocol VLAN ID TLVs is enabled on a given LLDP transmission capable port.
By default, the value is 0 and the status is FALSE. If this object is set to TRUE, the VLAN with the minimum VLAN ID is enabled. To delete an enabled VLAN, set the VLAN status to FALSE. Only one protocol VLAN TLV is supported in an LLDP packet.
As a best practice, do not perform the walk operation from the MIB browser, because it takes a long time to scan all ports and VLANs.
lldpV2Xdot1ConfigManVidTable
About this table
This table controls selection of management VID TLVs to be transmitted on individual ports.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is lldpV2LocPortIfIndex.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1ConfigManVidTxEnable (1.3.111.2.802.1.1.13.1.5.32962.1.1.6.1.1)
read-write
TruthValue
true(1),
false(2)
Indicates whether the management VID TLV transmission is enabled on a given LLDP transmission capable port.
As per the MIB.
lldpV2Xdot1LocTable
About this table
This table contains local VLAN ID information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1LocPortVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.2.1.1.1)
read-only
Unsigned32
Unsigned32(0|1..4094)
Local VLAN ID.
As per the MIB.
lldpV2Xdot1LocProtoVlanTable
About this table
This table contains information about local port and protocol VLANs.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1LocProtoVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.2.2.1.1)
not-accessible
Unsigned32
Unsigned320|1..4094
Port and protocol VLAN ID.
As per the MIB.
lldpV2Xdot1LocProtoVlanSupported (1.3.111.2.802.1.1.13.1.5.32962.1.2.2.1.2)
read-only
TruthValue
true(1),
false(2)
Indicates whether the given local port supports port and protocol VLANs.
As per the MIB.
lldpV2Xdot1LocProtoVlanEnabled (1.3.111.2.802.1.1.13.1.5.32962.1.2.2.1.3)
read-only
TruthValue
true(1),
false(2)
Indicates whether the port and protocol VLANs are enabled on the given local port.
As per the MIB.
lldpV2Xdot1LocVlanNameTable
About this table
This table contains information about VLAN names on the local system.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1LocVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.2.3.1.1)
not-accessible
VlanId
Standard MIB values.
ID of the VLAN to which the port belongs.
As per the MIB.
lldpV2Xdot1LocVlanName (1.3.111.2.802.1.1.13.1.5.32962.1.2.3.1.2)
read-only
SnmpAdminString
OCTET STRING (1..32)
VLAN name identified by the VLAN ID associated with the given local port.
As per the MIB.
lldpV2Xdot1LocManVidTable
About this table
This table contains management TLV information on the local system.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1LocManVid (1.3.111.2.802.1.1.13.1.5.32962.1.2.6.1.1)
read-only
Unsigned32
Local management TLV information.
As per the MIB.
lldpV2Xdot1LocLinkAggTable
About this table
This table contains link aggregation information on the local system.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1LocLinkAggStatus (1.3.111.2.802.1.1.13.1.5.32962.1.2.7.1.1)
read-only
LldpV2LinkAggStatusMap
The link aggregation capabilities and the current aggregation status of the system.
As per the MIB.
lldpV2Xdot1LocLinkAggPortId (1.3.111.2.802.1.1.13.1.5.32962.1.2.7.1.2)
read-only
Unsigned32
Unsigned32(0|1..2147483647)
Aggregate interface ID.
As per the MIB.
lldpV2Xdot1RemTable
About this table
This table contains information about physical network connections.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, and lldpV2RemIndex.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1RemPortVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.3.1.1.1)
read-only
Unsigned32
PVID of the given port on a neighboring device.
As per the MIB.
lldpV2Xdot1RemProtoVlanTable
About this table
This table contains port and protocol VLAN information about the neighboring devices, received on the given port.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, and lldpV2Xdot1RemProtoVlanId.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1RemProtoVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.3.2.1.1)
not-accessible
Unsigned32
Port and protocol VLAN ID of a neighboring device.
As per the MIB.
lldpV2Xdot1RemProtoVlanSupported (1.3.111.2.802.1.1.13.1.5.32962.1.3.2.1.2)
read-only
TruthValue
true(1),
false(2)
Indicates whether the given port of the neighboring device supports port and protocol VLANs.
As per the MIB.
lldpV2Xdot1RemProtoVlanEnabled (1.3.111.2.802.1.1.13.1.5.32962.1.3.2.1.3)
read-only
TruthValue
true(1),
false(2)
Indicates whether port and protocol VLANs are enabled on the given port of the neighboring device.
As per the MIB.
lldpV2Xdot1RemVlanNameTable
About this table
This table contains information about VLAN names on the ports of the neighboring devices.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex,a nd lldpV2Xdot1RemVlanId.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1RemVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.3.3.1.1)
not-accessible
VlanId
ID of the VLAN to which a port on a neighboring device belongs.
As per the MIB.
lldpV2Xdot1RemVlanName (1.3.111.2.802.1.1.13.1.5.32962.1.3.3.1.2)
read-only
SnmpAdminString
VLAN name identified by the VLAN ID associated with the neighboring device.
As per the MIB.
lldpV2Xdot1RemProtocolTable
About this table
This table contains neighboring protocol information received on the given port.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddres, lldpV2RemIndex, and lldpV2Xdot1RemProtocolIndex.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1RemProtocolIndex (1.3.111.2.802.1.1.13.1.5.32962.1.3.4.1.1)
not-accessible
Unsigned32
Unsigned32(1..2147483647)
Protocol index.
As per the MIB.
lldpV2Xdot1RemProtocolId (1.3.111.2.802.1.1.13.1.5.32962.1.3.4.1.2)
read-only
OCTET STRING
OCTET STRING (1..255)
IDs of the protocols associated with the ports of the neighboring devices.
As per the MIB.
lldpV2Xdot1RemVidUsageDigestTable
About this table
This table contains VID usage information of the agents on the ports of the neighboring devices.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, and lldpV2RemLocalDestMACAddress.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1RemVidUsageDigest (1.3.111.2.802.1.1.13.1.5.32962.1.3.5.1.1)
read-only
Unsigned32
VID usage information on the given port of a neighboring device.
As per the MIB.
lldpV2Xdot1RemManVidTable
About this table
This table contains management VLAN information received from the neighbors.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1RemManVid (1.3.111.2.802.1.1.13.1.5.32962.1.3.6.1.1)
read-only
Unsigned32
Management VLAN information on the given port of a neighboring device.
As per the MIB.
lldpV2Xdot1RemLinkAggTable
About this table
This table contains port link aggregation information of the agents on the ports of the neighboring devices.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex. lldpV2RemLocalDestMACAddress, and lldpV2RemIndex.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1RemLinkAggStatus (1.3.111.2.802.1.1.13.1.5.32962.1.3.7.1.1)
read-only
Link aggregation capabilities and current aggregation status of a neighboring device.
As per the MIB.
lldpV2Xdot1RemLinkAggPortId (1.3.111.2.802.1.1.13.1.5.32962.1.3.7.1.2)
read-only
Unsigned32
As per the MIB.
