05-Layer 2—LAN Switching
HomeSupportReference GuidesMIB CompanionH3C SR6600[SR6600-X] Routers MIB Reference-R6749-6W10005-Layer 2—LAN Switching
05-HH3C-LswVLAN-MIB
05-HH3C-LswVLAN-MIB 86.53 KB
HH3C-LswVLAN-MIB
About this MIB
Use this MIB to configure basic VLAN settings and obtain basic VLAN information.
MIB file name
hh3c-splat-vlan.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswVlan(2)
Tabular objects
hh3cdot1qVlanMIBTable
About this table
Use this table to manage and monitor VLANs, create and delete VLANs, and configure and obtain the proprietary VLAN data.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cdot1qVlanIndex, which specifies a VLAN ID. Use this table to create and delete VLANs, configure VLAN attributes, and obtain VLAN data.
Object (OID)
Access
Value range
Implementation
hh3cdot1qVlanIndex (1.3.6.1.4.1.25506.8.35.2.1.1.1.1)
read-only
Hh3cVlanIndex
Integer32 (0..2147483647)
VLAN index.
As per the MIB.
hh3cdot1qVlanName (1.3.6.1.4.1.25506.8.35.2.1.1.1.2)
read-write
SnmpAdminString
OCTET STRING (0..80)
VLAN name.
If the VLAN name input starts or ends with spaces, the spaces will be automatically trimmed. The string cannot contain only spaces. If you enter an empty string, the default VLAN description is used.
hh3cdot1qVlanPorts (1.3.6.1.4.1.25506.8.35.2.1.1.1.3)
read-write
PortList
OCTET STRING (0..65535)
List of ports in a VLAN.
This object can only assign access ports to and remove access ports from VLANs.
hh3cdot1qVlanType (1.3.6.1.4.1.25506.8.35.2.1.1.1.4)
read-write
Integer
superVlan(1)
common-vlan(2)
sub-vlan(3)
isolate-user-vlan(4)
secondary-vlan(5)
primaryVlan(6)
VLAN type.
Not supported
hh3cExistInterface (1.3.6.1.4.1.25506.8.35.2.1.1.1.7)
read-only
TruthValue
true(1),
false(2)
Whether the VLAN has a VLAN interface.
As per the MIB.
hh3cVlanInterfaceIndex (1.3.6.1.4.1.25506.8.35.2.1.1.1.8)
read-only
Integer
Integer
(1..4094)
Index of the VLAN interface.
As per the MIB.
hh3cdot1qVlanStatus (1.3.6.1.4.1.25506.8.35.2.1.1.1.10)
read-only
Integer
other(1),
static(2),
dynamic(3)
VLAN state.
As per the MIB.
hh3cdot1qVlanCreationTime (1.3.6.1.4.1.25506.8.35.2.1.1.1.11)
read-only
TimeTicks
TimeTicks (0..4294967295)
Time when the VLAN was created.
As per the MIB.
hh3cdot1qVlanPriority (1.3.6.1.4.1.25506.8.35.2.1.1.1.12)
read-write
Integer
Integer(0..7)
VLAN priority.
Fixed at 0.
hh3cdot1qVlanRowStatus (1.3.6.1.4.1.25506.8.35.2.1.1.1.13)
read-create
Row-Status
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
VLAN row state.
Only the following operations are supported: active(1), createAndGo(4), and destroy(6)
hh3cdot1qVlanBroadcastSuppression (1.3.6.1.4.1.25506.8.35.2.1.1.1.14)
read-write
Integer
Integer
(0..100)
VLAN broadcast suppression.
The object can only be read.
hh3cdot1qVlanTaggedPorts (1.3.6.1.4.1.25506.8.35.2.1.1.1.17)
read-only
PortList
Tagged ports of a VLAN.
As per the MIB.
hh3cdot1qVlanUntaggedPorts (1.3.6.1.4.1.25506.8.35.2.1.1.1.18)
read-only
PortList
Untagged ports of a VLAN.
As per the MIB.
hh3cdot1qVlanPortIndexs (1.3.6.1.4.1.25506.8.35.2.1.1.1.19)
read-write
OCTET STRING
Port index list.
As per the MIB.
hh3cVlanInterfaceTable
About this table
Use this table to configure and obtain VLAN interface information.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cdot1qVlanID.
Object (OID)
Access
Value range
Implementation
hh3cVlanInterfaceID (1.3.6.1.4.1.25506.8.35.2.1.2.1.1)
read-only
Integer
Standard MIB values.
Index.
As per the MIB.
hh3cdot1qVlanID (1.3.6.1.4.1.25506.8.35.2.1.2.1.2)
read-only
Hh3cVlanIndex
VLAN ID
As per the MIB.
hh3cdot1qVlanIpAddress (1.3.6.1.4.1.25506.8.35.2.1.2.1.3)
read-write
IpAddress
IP address.
As per the MIB.
hh3cdot1qVlanIpAddressMask (1.3.6.1.4.1.25506.8.35.2.1.2.1.4)
read-write
IpAddress
IP address and its mask.
As per the MIB.
hh3cVlanInterfaceAdminStatus (1.3.6.1.4.1.25506.8.35.2.1.2.1.5)
read-write
Integer
up(1),
down(2)
VLAN interface state.
As per the MIB.
hh3cVlanInterfaceFrameType (1.3.6.1.4.1.25506.8.35.2.1.2.1.6)
read-only
Integer
ethernet-ii(1),
ethernet-snap(2),
ethernet-8022(3),
ethernet-8023(4)
Frame type.
As per the MIB.
hh3cInterfaceRowStatus (1.3.6.1.4.1.25506.8.35.2.1.2.1.7)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Interface row state.
Available values are active(1), createAndgo(4), and destroy(6).
When the row is created together with configuring other attribute objects, the VLAN interface is first created, and then other attribute objects are configured.
If an object fails to be configured, this operation fails.
As a best practice, use the hh3cInterfaceRowStatus (createAndGo(4)) to create a VLAN interface and configure other attribute objects separately.
When the row state is active, the createAndGo operation succeeds.
hh3cVlanInterfaceIpMethod (1.3.6.1.4.1.25506.8.35.2.1.2.1.8)
read-write
Integer
assigned-ip(1),
dhcp-ip(2),
bootp-ip(3)
VLAN interface IP address assignment method.
hh3cVlanInterfaceIfIndex (1.3.6.1.4.1.25506.8.35.2.1.2.1.9)
read-only
Integer
As per the MIB.
hh3cVlanInterfaceAddrTable
About this table
Use this table to configure and obtain VLAN interface IP addresses.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are hh3cVlanInterfaceIpIfIndex and hh3cVlanInterfaceIpAddr.
Object (OID)
Access
Value range
Implementation
hh3cVlanInterfaceIpIfIndex (1.3.6.1.4.1.25506.8.35.2.1.5.1.1)
read-only
Integer
As per the MIB.
hh3cVlanInterfaceIpAddr (1.3.6.1.4.1.25506.8.35.2.1.5.1.2)
read-only
IpAddress
OCTET STRING (4)
VLAN interface IP address.
As per the MIB.
hh3cVlanInterfaceIpMask (1.3.6.1.4.1.25506.8.35.2.1.5.1.3)
read-create
IpAddress
OCTET STRING (4)
VLAN Interface IP address mask.
As per the MIB.
hh3cVlanInterfaceIpType (1.3.6.1.4.1.25506.8.35.2.1.5.1.4)
read-create
Integer
primary(1),
sub(2),
cluster(3),
vrrp(4)
VLAN interface IP type.
As per the MIB.
Available values are primary(1) and sub(2).
hh3cVlanInterfaceIpRowStatus (1.3.6.1.4.1.25506.8.35.2.1.5.1.5)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Interface IP address row state.
Available values are active(1), createAndGo(4), and destroy(6).
