05-Layer 2—LAN Switching
HomeSupportReference GuidesMIB CompanionH3C SR6600[SR6600-X] Routers MIB Reference-R6749-6W10005-Layer 2—LAN Switching
06-IEEE8023-LAG-MIB
06-IEEE8023-LAG-MIB 130.21 KB
IEEE8023-LAG-MIB
About this MIB
This MIB defines MIB objects for the following information:
·     Aggregate interface configuration.
·     Aggregation member port list.
·     Aggregation member port configuration.
·     Traffic statistics.
·     State machine information about aggregation member ports.
MIB file name
ieee8023-lag.mib
Root object
iso(1).member-body(2).us(840).802dot3(10006).snmpmibs(300).lagMIB(43)
Tabular objects
dot3adAggTable
About this table
Use this table to configure aggregate interfaces.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is dot3adAggIndex.
Object (OID)
Access
Value range
Implementation
dot3adAggIndex (1.2.840.10006.300.43.1.1.1.1.1)
not-accessible
InterfaceIndex
Integer32 (1..2147483647)
Unique identifier allocated to an aggregate interface by the local system, table index.
N/A
dot3adAggMACAddress (1.2.840.10006.300.43.1.1.1.1.2)
read-only
MacAddress
OCTET STRING (6)
MAC address of the aggregate interface.
Default: 0.
dot3adAggActorSystemPriority (1.2.840.10006.300.43.1.1.1.1.3)
read-write
INTEGER
INTEGER (0..65535)
Local system priority.
N/A
dot3adAggActorSystemID (1.2.840.10006.300.43.1.1.1.1.4)
read-only
MacAddress
OCTET STRING (6)
Local system ID.
Default: 0.
dot3adAggAggregateOrIndividual (1.2.840.10006.300.43.1.1.1.1.5)
read-only
TruthValue
true(1)
false(2)
Aggregation flag.
The value is fixed at true.
dot3adAggActorAdminKey (1.2.840.10006.300.43.1.1.1.1.6)
read-write
LacpKey
INTEGER (0..65535)
Administrative key.
Only the read operation is supported.
dot3adAggActorOperKey (1.2.840.10006.300.43.1.1.1.1.7)
read-only
LacpKey
INTEGER (0..65535)
Operational key.
N/A
dot3adAggPartnerSystemID (1.2.840.10006.300.43.1.1.1.1.8)
read-only
MacAddress
OCTET STRING (6)
Peer system ID.
Default: 0.
dot3adAggPartnerSystemPriority (1.2.840.10006.300.43.1.1.1.1.9)
read-only
INTEGER
INTEGER (0..65535)
Peer system priority.
N/A
dot3adAggPartnerOperKey (1.2.840.10006.300.43.1.1.1.1.10)
read-only
LacpKey
INTEGER (0..65535)
Peer operational key.
N/A
dot3adAggCollectorMaxDelay (1.2.840.10006.300.43.1.1.1.1.11)
read-write
INTEGER (
INTEGER (0..65535)
Maximum delay.
A value of 0 is returned for read operations. Only the read operation is supported.
dot3adAggPortListTable
About this table
Use this table to obtain the member port list for an aggregate interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
dot3adAggPortListPorts (1.2.840.10006.300.43.1.1.2.1.1)
read-only
PortList
OCTET STRING (0..255)
Member port list.
Each bit set in this list represents a member port.
dot3adAggPortTable
About this table
Use this table to configure an aggregation member port.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is dot3adAggPortIndex.
Object (OID)
Access
Value range
Implementation
dot3adAggPortIndex (1.2.840.10006.300.43.1.2.1.1.1)
not-accessible
InterfaceIndex
Member port index.
As per the MIB.
dot3adAggPortActorSystemPriority (1.2.840.10006.300.43.1.2.1.1.2)
read-write
INTEGER
INTEGER (0..65535)
As per the MIB.
dot3adAggPortActorSystemID (1.2.840.10006.300.43.1.2.1.1.3)
read-only
MacAddress
OCTET STRING (6)
Local system ID.
As per the MIB.
dot3adAggPortActorAdminKey (1.2.840.10006.300.43.1.2.1.1.4)
read-write
LacpKey
INTEGER (0..65535)
Administrative key.
As per the MIB.
dot3adAggPortActorOperKey (1.2.840.10006.300.43.1.2.1.1.5)
read-write
LacpKey
INTEGER (0..65535)
Operational key.
dot3adAggPortPartnerAdminSystemPriority (1.2.840.10006.300.43.1.2.1.1.6)
read-write
INTEGER
INTEGER (0..65535)
Administrative priority of the peer port.
dot3adAggPortPartnerOperSystemPriority (1.2.840.10006.300.43.1.2.1.1.7)
read-only
INTEGER
INTEGER (0..65535)
Peer operational priority.
As per the MIB.
dot3adAggPortPartnerAdminSystemID (1.2.840.10006.300.43.1.2.1.1.8)
read-write
MacAddress
OCTET STRING (6)
Peer administrative system ID.
dot3adAggPortPartnerOperSystemID (1.2.840.10006.300.43.1.2.1.1.9)
read-only
MacAddress
OCTET STRING (6)
Peer operational system ID.
Default: 0.
dot3adAggPortPartnerAdminKey (1.2.840.10006.300.43.1.2.1.1.10)
read-write
LacpKey
INTEGER (0..65535)
Peer administrative key.
dot3adAggPortPartnerOperKey (1.2.840.10006.300.43.1.2.1.1.11)
read-only
LacpKey
INTEGER (0..65535)
As per the MIB.
dot3adAggPortSelectedAggID (1.2.840.10006.300.43.1.2.1.1.12)
read-only
InterfaceIndexOrZero
Integer32 (0..2147483647)
Selected aggregate interface index.
As per the MIB.
dot3adAggPortAttachedAggID (1.2.840.10006.300.43.1.2.1.1.13)
read-only
Joined aggregate interface index.
As per the MIB.
dot3adAggPortActorPort (1.2.840.10006.300.43.1.2.1.1.14)
read-only
INTEGER
INTEGER (0..65535)
Local port index.
As per the MIB.
dot3adAggPortActorPortPriority (1.2.840.10006.300.43.1.2.1.1.15)
read-write
INTEGER
INTEGER (0..65535)
Local port priority.
As per the MIB.
dot3adAggPortPartnerAdminPort (1.2.840.10006.300.43.1.2.1.1.16)
read-write
INTEGER
INTEGER (0..65535)
Peer administrative port number.
dot3adAggPortPartnerOperPort (1.2.840.10006.300.43.1.2.1.1.17)
read-only
INTEGER
INTEGER (0..65535)
Peer operational port number.
As per the MIB.
dot3adAggPortPartnerAdminPortPriority (1.2.840.10006.300.43.1.2.1.1.18)
read-write
INTEGER
INTEGER (0..65535)
Peer administrative port priority.
dot3adAggPortPartnerOperPortPriority (1.2.840.10006.300.43.1.2.1.1.19)
read-only
INTEGER
INTEGER (0..65535)
Peer operational port priority.
As per the MIB.
dot3adAggPortActorAdminState (1.2.840.10006.300.43.1.2.1.1.20)
read-write
LacpState
BITS {
lacpActivity(0)
lacpTimeout(1)
aggregation(2)
synchronization(3)
collecting(4)
distributing(5)
defaulted(6)
expired(7)
Local administrative status.
The write operation processes only bit 1.
dot3adAggPortActorOperState (1.2.840.10006.300.43.1.2.1.1.21)
read-only
LacpState
BITS {
lacpActivity(0)
lacpTimeout(1)
aggregation(2)
synchronization(3)
collecting(4)
distributing(5)
defaulted(6)
expired(7)
Local operational status.
As per the MIB.
dot3adAggPortPartnerAdminState (1.2.840.10006.300.43.1.2.1.1.22)
read-write
LacpState
BITS {
lacpActivity(0)
lacpTimeout(1)
aggregation(2)
synchronization(3)
collecting(4)
distributing(5)
defaulted(6)
expired(7)
Peer administrative status.
dot3adAggPortPartnerOperState (1.2.840.10006.300.43.1.2.1.1.23)
read-only
LacpState
BITS {
lacpActivity(0)
lacpTimeout(1)
aggregation(2)
synchronization(3)
collecting(4)
distributing(5)
defaulted(6)
expired(7)
Peer operational status.
As per the MIB.
dot3adAggPortAggregateOrIndividual (1.2.840.10006.300.43.1.2.1.1.24)
read-only
TruthValue
true(1)
false(2)
Aggregation status.
The return value is fixed at true.
dot3adAggPortStatsTable
About this table
Use this table to obtain traffic statistics about aggregate interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
dot3adAggPortStatsLACPDUsRx (1.2.840.10006.300.43.1.2.2.1.1)
read-only
Counter32
Standard MIB values.
Valid incoming LACPDU count.
As per the MIB.
dot3adAggPortStatsMarkerPDUsRx (1.2.840.10006.300.43.1.2.2.1.2)
read-only
Counter32
Valid incoming Maker PDU count.
As per the MIB.
dot3adAggPortStatsMarkerResponsePDUsRx (1.2.840.10006.300.43.1.2.2.1.3)
read-only
Counter32
Valid incoming Maker response PDU count.
As per the MIB.
dot3adAggPortStatsUnknownRx (1.2.840.10006.300.43.1.2.2.1.4)
read-only
Counter32
Unknown incoming packet count.
As per the MIB.
dot3adAggPortStatsIllegalRx (1.2.840.10006.300.43.1.2.2.1.5)
read-only
Counter32
Invalid incoming packet count.
As per the MIB.
dot3adAggPortStatsLACPDUsTx (1.2.840.10006.300.43.1.2.2.1.6)
read-only
Counter32
Outgoing LACPDU count.
As per the MIB.
dot3adAggPortStatsMarkerPDUsTx (1.2.840.10006.300.43.1.2.2.1.7)
read-only
Counter32
Outgoing Maker PDU count.
As per the MIB.
dot3adAggPortStatsMarkerResponsePDUsTx (1.2.840.10006.300.43.1.2.2.1.8)
read-only
Counter32
Outgoing Maker response PDU count.
As per the MIB.
dot3adAggPortDebugTable
About this table
Use this table to obtain state machine information about aggregation member ports.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is dot3adAggPortDebugRxState.
Object (OID)
Access
Value range
Implementation
dot3adAggPortDebugRxState (1.2.840.10006.300.43.1.2.3.1.1)
read-only
INTEGER
currentRx(1)
expired(2)
defaulted(3)
initialize(4)
lacpDisabled(5)
portDisabled(6)
Receive state machine.
As per the MIB.
dot3adAggPortDebugLastRxTime (1.2.840.10006.300.43.1.2.3.1.2)
read-only
TimeTicks
Time when the last LACPDU was received.
As per the MIB.
dot3adAggPortDebugMuxState (1.2.840.10006.300.43.1.2.3.1.3)
read-only
INTEGER
detached(1)
waiting(2)
attached(3)
collecting(4)
distributing(5)
collectingDistributing(6)
Mux state machine.
As per the MIB.
dot3adAggPortDebugMuxReason (1.2.840.10006.300.43.1.2.3.1.4)
read-only
DisplayString
Cause for the last Mux state machine change.
As per the MIB.
dot3adAggPortDebugActorChurnState (1.2.840.10006.300.43.1.2.3.1.5)
read-only
ChurnState
INTEGER {
noChurn(1)
churn(2)
churnMonitor(3)
Actor Churn state machine.
As per the MIB.
dot3adAggPortDebugPartnerChurnState (1.2.840.10006.300.43.1.2.3.1.6)
read-only
ChurnState
INTEGER {
noChurn(1)
churn(2)
churnMonitor(3)
Partner Churn state machine.
As per the MIB.
dot3adAggPortDebugActorChurnCount (1.2.840.10006.300.43.1.2.3.1.7)
read-only
Counter32
Number of times the Actor Churn state machine has entered the ACTOR_CHURN state.
As per the MIB.
dot3adAggPortDebugPartnerChurnCount (1.2.840.10006.300.43.1.2.3.1.8)
read-only
Counter32
Number of times the Partner Churn state machine has entered the PARTNER_CHURN state.
As per the MIB.
dot3adAggPortDebugActorChangeCount (1.2.840.10006.300.43.1.2.3.1.11)
read-only
Counter32
Number of times the Actor Churn state machine has changed status.
As per the MIB.
dot3adAggPortDebugPartnerChangeCount (1.2.840.10006.300.43.1.2.3.1.12)
read-only
Counter32
Number of times the Partner Churn state machine has changed status.
As per the MIB.
