| 01-MER Routers and MSR Routers License Installation Examples (Web) | 707.11 KB |
Obtaining the serial number (SN) and device ID (DID) on the device
Applying for an activation file on H3C License Management Platform
Installing an activation file the Web on the device
Introduction
The following information provides an example for installing a license at the Web interface.
This example is applicable to the MSR26, MSR36, and MSR56 series and MER series routers of the Comware 7 platform.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of licensing.
Configuration example
As shown in Figure 1, a router is deployed at the network egress. Install a license on the router.
Software versions used
This configuration example was created and verified on Release 6749P14.
Identifying the license key
Identify the license key in the purchased software license certificate. The authorization serial number in the software license certificate is the license key. The license key will be used later.
1. From the left navigation pane, select System Tool > License Management.
Figure 2 License configuration page
2. Click the Obtain DID tab to access the Obtain DID page. You can view the serial number (SN) and device ID (DID) of the device. Save them for later use.
Figure 3 Obtain DID page
Adding license keys
1. Access H3C License Management Platform at http://www.h3c.com/en/License.
2. Click License Activation Requests, as shown in Figure 4.
Figure 4 Accessing the License Activation Requests page
3. Add license keys.
Copy and paste a license key in the empty License Key box that opens, and then click Search & Add, as shown in Figure 4. Repeat this step to add multiple license keys.
4. Select the license keys to be activated, and then click Next, as shown in Figure 5.
Figure 5 Finishing adding license keys
Binding license keys to a hardware device
1. Verify that the license keys to be activated are all added.
2. Enter device information. To bind a single
license key to a single device, click the <
> icon next to the Custom device ID
box in the license key entry, as shown in Figure 5. In the
dialog box that opens, enter the required device information, and then click
Yes, as shown in Figure 6. Repeat
this step until all license keys are bound.
Figure 6 Entering device information
3. Review the bindings carefully. Each license key will be locked to the device to which each of them is bound. Make sure you understand the impact of the binding operation, and then select the option that explicitly states so, as shown Figure 7. Click Next.
Figure 7 Finishing binding license keys to devices
Entering user information
As shown in Figure 8, enter user information, and then click Next. Table 1 describes the parameters.
If the entered email address is used for the first time on the platform, the platform displays the email address validation page, as shown in Table 1Figure 9. Click Get verification code, and the platform will send a test mail to the specified email address. Enter the verification code in the test mail in the Verification Code field, and click Yes to complete the verification. Click Next to verify the settings.
Figure 8 Entering user information
Parameter |
End Customer Company/Organization |
(Required.) Company or organization that uses the licenses. |
Your Company/Organization |
(Required.) Company or organization with which the license applicant works. |
Contact Person |
(Required.) Name of the contact person. |
Phone Number |
(Required.) Contact phone number. |
Email Address |
(Required.) Contact email address. H3C License Management Platform will send the generated activation files to this email address. Make sure the email address is correct and available. |
Zip/Postal Code |
(Optional.) Zip code or postal code for the contact address. |
Address |
(Optional.) Contact address. |
Project Name |
(Optional.) Project name. |
Verification Code |
(Required.) The verification code is case insensitive. |
Figure 9 Email address validation page
Reviewing information and activating the licenses
1. Review the license key and device information, and then select I accept all terms and conditions of H3C License Service Portal Legal Statement, as shown in Figure 10. Click Confirm & Activate.
Figure 10 Reviewing information and activating the licenses
2. Double-check the license key and device information, and then click OK in the dialog box as shown in Figure 11.
Figure 11 Double-checking the license key and device information
The platform automatically generates an activation file for each binding and send them to the specified email address. To download the activation file, click Get Activation Info in the Get Activation Info column for the license key, as shown in Figure 12.
Figure 12 Activating the license succeeded
To download an activation file to the PC, click Get Activation Info in the Get Activation Info column for the license key, as shown in Figure 12.
Access the email box at the specified address to obtain the activation files.
From the left navigation pane, select System Tool > License Management. On the License configuration tab, click Add to install a license. Click Select file, select the license file, and click Apply.
Figure 13 Installing a license
From the left navigation pane, select System Tool > License Management. On the License configuration tab, click Refresh to identify the status of activation files.
Figure 14 License configuration page
· Save and back up the activation file.
· To prevent an activation file from becoming invalid, do not open it.
· Do not modify the name of an activation file.
