04-Layer 3—IP Services Command Reference
HomeSupportReference GuidesCommand ReferencesH3C IE4300[IE4300-M][IE4320] Switch Series Command References-R63xx-6W10204-Layer 3—IP Services Command Reference
05-IP forwarding basics commands
05-IP forwarding basics commands 57.49 KB
Basic IP forwarding commands
display fib
Use display fib to display FIB entries.
display fib  [ ip-address [ mask | mask-length ] ]
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display the FIB entries for the public network, do not specify any VPN.
ip-address: Displays the FIB entry that matches the specified destination IP address.
mask: Specifies the mask for the IP address.
mask-length: Specifies the mask length for the IP address. The value range is 0 to 32.
If you specify an IP address without a mask or mask length, this command displays the longest matching FIB entry.
If you specify an IP address and a mask or mask length, this command displays the exactly matching FIB entry.
# Display all FIB entries of the public network.
<Sysname> display fib
Destination count: 5 FIB entry count: 5
Flag:
  R:Relay     F:FRR
Destination/Mask   Nexthop         Flag     OutInterface/Token       Label
0.0.0.0/32         127.0.0.1       UH       InLoop0                  Null
1.1.1.0/24         192.168.126.1   USGF     M-GE0/0/0                Null
127.0.0.0/8        127.0.0.1       U        InLoop0                  Null
127.0.0.0/32       127.0.0.1       UH       InLoop0                  Null
127.0.0.1/32       127.0.0.1       UH       InLoop0                  Null
# Display the FIB entries for VPN vpn1.
<Sysname> display fib vpn-instance vpn1
Destination count: 6 FIB entry count: 6
Flag:
  R:Relay     F:FRR
20.20.20.0/24      20.20.20.25     U        M-GE0/0/0                Null
20.20.20.0/32      20.20.20.25     UBH      M-GE0/0/0                Null
20.20.20.25/32     127.0.0.1       UH       InLoop0                  Null
20.20.20.25/32     20.20.20.25     H        M-GE0/0/0                Null
20.20.20.255/32    20.20.20.25     UBH      M-GE0/0/0                Null
# Display the FIB entries matching the destination IP address 10.2.1.1.
<Sysname> display fib 10.2.1.1
Flag:
  R:Relay     F:FRR
10.2.1.1/32        127.0.0.1       UH       InLoop0                  Null
Destination count
Total number of destination addresses.
FIB entry count
Total number of FIB entries.
Destination/Mask
Destination address and the mask length.
Nexthop
Next hop address.
Flag
Flags of routes:
·     U—Usable route.
·     G—Gateway route.
·     H—Host route.
·     B—Blackhole route.
·     D—Dynamic route.
·     S—Static route.
·     R—Relay route.
·     F—Fast reroute.
OutInterface/Token
Output interface/LSP index number.
Label
Inner label.
ip forwarding-table save
Use ip forwarding-table save to save the IP forwarding entries to a file.
ip forwarding-table save filename filename
filename filename: Specifies the name of a file, a string of 1 to 255 characters. For information about the filename argument, see file system management in Fundamentals Configuration Guide.
The command automatically creates the file if you specify a nonexistent file. If the file already exists, this command overwrites the file content.
To automatically save the IP forwarding entries periodically, configure a schedule for the device to automatically run the ip forwarding-table save command. For information about scheduling a task, see Fundamentals Configuration Guide.
# Save the IP forwarding entries to the fib.txt file.
<Sysname> ip forwarding-table save filename fib.txt
