| 02-FRUs and Compatibility Matrixes | 331.57 KB |
2 FRUs and compatibility matrixes
Fabric module slot filler panels
Chassis component ordering information
FRUs compatibility
S12500R
Table 2-1 S12500R modules compatibility
Device model |
MPU |
Fabric module |
Service module |
S12516R |
LSXM1SUPER1 LSXM1SUPEAR1 |
· LSXM2SFH16CR1 · LSXM1SFH16ER1 · LSXM1SFK16ER1 · LSXM1SFK16GR1 |
Type H service modules (LSXM1TGS48HFR1 for example) and Type K service modules (LSXM1CGQ48KBR1 for example). For more information, see Table 2-10. |
S12508R |
· LSXM1SFH08CR1 · LSXM1SFH08DR1 · LSXM1SFK08ER1 · LSXM1SFK08GR1 |
S12504R |
LSXM1SUP04TR1 |
· LSXM1SFH04DR1 · LSXM1SFK04FR1 |
S12500R-2L |
LSXM1SUP02LR1 LSXM1SUP02TR1 LSXM2SUP02LR1 |
N/A |
S12500R-2XL |
LSXM1SUP04TR1 |
N/A |
LSXM1CGQ72KCR1 |
S12500CR
The S12516CR and S12508CR can be installed with Type K and Type S modules. To avoid module damage or operation anomalies, do not install both types of modules on the same device.
· Type K MPUs (LSXM1SUPKR1 for example) can be used only with Type K service modules (LSXM1CGQ48KBR1 for example), LSXM1CMUR1 environment management module, and Type K fabric modules (LSXM1SFK08GR1 for example).
· Type S MPUs (LSXM1SUPRS2 for example) can be used only with Type S service modules (LSXM3TGS48SF2 for example), Type S environment management module (LSXM1CMURS2 for example), and Type S fabric modules (LSXM3SFS08F2 for example).
Table 2-2 S12500CR Type K modules compatibility
Device model |
MPU |
Environment management module |
Fabric module |
Service module |
S12516CR |
LSXM1SUPKR1 LSXM1SUPKAR1 |
LSXM1CMUR1 |
S12508CR |
· LSXM1SFK08ER1 · LSXM1SFK08FR1 · LSXM1SFK08GR1 |
Table 2-3 S12500CR Type S modules compatibility
Device model |
MPU |
Fabric module |
Service module |
S12516CR |
LSXM1SUPRS2 |
LSXM1CMURS2 |
· LSXM3SFS16F2 · LSXM3SFS16G2 |
Type S service modules (LSXM3TGS48SF2 for example). For more information, see Table 2-10. |
S12508CR |
· LSXM3SFS08G2 · LSXM3SFS08F2 |
MPUs
Table 2-4 MPUs available for the device
Device model |
Available MPUs |
· S12516R · S12508R |
· S12504R · S12500R-2XL |
LSXM1SUP04TR1 |
· S12516CR · S12508CR |
LSXM1SUPKR1 LSXM1SUPKAR1 LSXM1SUPRS2 |
S12500R-2L |
Table 2-5 MPU specifications (1)
Item |
LSXM1SUP04TR1 |
Processor |
Intel Processor (Quad Core) @ 2.2 GHz |
SDRAM |
32GB DDR4 SDRAM (two DIMM slots) |
16GB DDR4 SDRAM (two DIMM slots) |
Flash |
4GB EMMC |
8GB EMMC |
4GB EMMC |
NVRAM |
512 KB |
Port connector type |
· RJ-45 · LC · USB (Type A) · Mini-USB (Type AB) |
· RJ-45 · LC · USB (Type A) |
Ports |
· One console port (RJ-45 connector) · One console port (Mini-USB connector) · Two 10/100/1000BASE-T ports for management and upgrade · Two Gigabit SFP ports for management and upgrade · One USB port (USB3.0, host port) · Two 1PPS/TOD ports for time synchronization · Two SMB clock input ports · Two SMB clock output ports |
· One console port · One 10/100/1000BASE-T port for management and upgrade · One Gigabit SFP port for management and upgrade · One USB port (USB2.0, host port) · Two 1PPS/TOD ports for time synchronization · Two SMB clock input ports · Two SMB clock output ports |
Port transmission rate |
· Console port: ≤ 115200 bps (default: 9600 bps) · SFP port: 1000 Mbps · 10/100/1000BASE-T port: 10/100/1000 Mbps |
NOTE: The two console ports on the LSXM1SUPKR1, LSXM1SUPKAR1, or LSXM1SUPRS2 MPU cannot be used simultaneously. |
Table 2-6 MPU specifications (2)
Item |
LSXM1SUP02LR1 |
LSXM1SUP02TR1 |
LSXM2SUP02LR1 |
Processor |
SDRAM |
Flash |
8GB EMMC |
8GB EMMC |
8GB EMMC |
NVRAM |
512 KB |
512 KB |
512 KB |
· RJ-45 · LC · USB (Type A) · Coaxial RF connector |
Ports |
· One console port · One 10/100/1000BASE-T port for management and upgrade · One Gigabit SFP port for management and upgrade · One USB port (USB2.0, host port) |
· One console port · One 10/100/1000BASE-T port for management and upgrade · One Gigabit SFP port for management and upgrade · One USB port (USB2.0, host port) · One SMB clock input port · One SMB clock output port · One 1PPS/TOD port for time synchronization |
The environment management module is the system monitoring module of the device. It can collect system running information and interact with the management system of the equipment room in real time to deliver highly reliable device monitoring and management.
Table 2-7 Module functionalities
Functionalities |
Smart monitoring and management |
· The module exchanges data with the management system of the equipment room in real time, improving energy management resiliency in the data center. ¡ The module monitors the device temperature in real time, and adjusts the fan speed intelligently to avoid overtemperature. ¡ The module reports the power requirements of the device in real time to the management system of the equipment room which will then adjust power supply accordingly to avoid power distribution system overload or underload or energy waste. · The module monitors the power consumption and power usage of the device in real time and automatically powers on or off interface modules accordingly. · The module provides asset management and fault diagnosis. |
High availability |
The module is used in 1+1 redundancy with another one. When the active module fails, the standby module takes over the services immediately. |
Maintainability |
The module reserves a COM port and two 10/100/1000BASE-T management ports (ETH) for future service expansion. |
Table 2-8 Environment management modules available for the device
Device model |
Available environment management modules |
S12516CR S12508CR |
LSXM1CMUR1 LSXM1CMURS2 |
Table 2-9 Environment management module specifications
Item |
Specifications |
Processor |
Intel processor (Quad Core) @ 2.2 GHz |
SDRAM |
8 GB DDR4 SDRAM (two DIMM slots) |
Flash |
8 GB EMMC |
Ports |
· 1 × COM port (reserved) · 2 × 10/100/1000BASE-T management ports (reserved) |
Interface module adapter
To install an S12500R interface module with dimensions of 50.0 × 432.6 × 519.8 mm (1.97 × 17.03 × 20.46 in) on an S12508CR or S12516CR, you must first install an LSXM1IMAA interface module adapter in the interface module slot. To install an LSXM1CGQ72KCR1 interface module, you must first install two LSXM1IMAA interface module adapters in the interface module slot.
An LSXM1IMAA interface module adapter is required for each S12500R interface module.
Service modules
Table 2-10 describes the service modules available for the device. The service modules provide different types and numbers of ports.
IMPORTANT: To use the LSXM1CGQ36HBR1 or LSXM1CGQ36HFR1 service modules on the device, choose high-performance fan trays for the device. See Table 2-3 for information about the available high-performance fan trays. |
For the transceiver modules or cables available for modules, see H3C S12500R Switch Series Cards and Transceiver Modules Compatibility Matrixes and H3C S12500R Switch Router Series Port Splitting and Compatibility With Transceivers and Cables.
Table 2-10 Service modules available for the device
Service module type |
Service module model |
Port quantity |
Compatible device models |
Type K |
LSXM1CDMS36KCR1 |
36-port 400G QSFP-DD MACsec Ethernet optical interface module |
36 |
LSXM1CDQ24KBR1 |
24-port 400G QSFP-DD Ethernet optical interface module |
24 |
· S12516R · S12508R · S12504R · S12516CR · S12508CR |
LSXM1CDQ36KBR1 |
36-port 400G QSFP-DD Ethernet optical interface module |
36 |
LSXM1CDQ18KCR1 |
18-port 400G QSFP-DD Ethernet optical interface module |
18 |
· S12516R · S12508R · S12504R · S12500R-2XL · S12516CR · S12508CR |
LSXM1CCQ48KBR1 |
48-port 200G QSFP56 Ethernet optical interface module |
48 |
LSXM1CGQ72KCR1 |
36-port 200G QSFP56 Ethernet optical interface/72-port 100G QSFP28 Ethernet optical interface module |
72 |
· S12516R · S12508R · S12504R · S12500R-2XL · S12500R-2L · S12516CR · S12508CR |
LSXM1CGMS48KBR1 |
48-port 100GBASE MACsec Ethernet optical interface module |
48 |
· S12516R · S12508R · S12504R · S12500R-2L · S12516CR · S12508CR |
LSXM1CGQ48KBR1 |
48-port 100G QSFP28 Ethernet optical interface module |
48 |
LSXM1CGQFX16KBR1 |
16-port 100GBASE FlexE Ethernet optical interface module |
16 |
LSXM1MOD24KBR1 |
24KBR flexible line processing platform module, with two interface module slots |
Depends on the interface modules installed. For more information about the available interface modules, see "Interface modules." |
Type H |
LSXM1CGQ36HBR1 |
36-port 100GBASE QSFP28 Ethernet optical interface module |
36 |
· S12516R · S12508R · S12504R |
LSXM1CGQ36HFR1 |
36 |
LSXM1CGQ18QGHBR1 |
18-port 100G QSFP28 Ethernet optical interface/36-port 40G QSFP+ Ethernet optical interface module |
36 |
LSXM1CGQ18QGHFR1 |
36 |
LSXM1CGQ6QGHFR1 |
6-port 100G QSFP28 Ethernet optical interface/12-port 40G QSFP+ Ethernet optical interface module |
12 |
LSXM1TGS48HBR1 |
48-port 10GBASE SFP+ Ethernet optical interface module |
48 |
LSXM1TGS48HFR1 |
48 |
Type S |
LSXM3CDQ16SF2 |
16-port 400G QSFP-DD Ethernet optical interface module |
16 |
LSXM3CDQ8SF2 |
8 |
LSXM3CGQ36SF2 |
36-port 100G QSFP28 Ethernet optical interface module |
36 |
LSXM3CGQ18SF2 |
18-port 100G QSFP28 Ethernet optical interface module |
18 |
LSXM3QGS36SF2 |
36 |
LSXM3YGS48SF2 |
48-port 25G SFP28 Ethernet optical interface module |
48 |
LSXM3TGS48SF2 |
48-port 10G SFP+ Ethernet optical interface module |
48 |
Interface modules
The LSXM1MOD24KBR1 supports installation of interface modules. Table 2-11 describes the interface modules available for the LSXM1MOD24KBR1.
Table 2-11 Interface modules available for the LSXM1MOD24KBR1
Model |
Port quantity and type |
LSXM1CGQ18C1 |
18-port 100GBASE Ethernet optical interface module |
18 QSFP28 ports |
LSXM1CGQ8C1 |
8 QSFP28 ports |
LSXM1TGS24C1 |
24-port 100GBASE Ethernet optical interface module |
24 SFP+ ports |
Fabric modules
Table 2-12 describes the fabric modules available for the device.
Do not install fabric module of different models on the same device.
Table 2-12 Fabric modules available for the device
Device model |
Available fabric modules |
Quantity per chassis |
S12516R |
2 to 6 |
S12508R |
2 to 6 |
S12504R |
2 to 6 |
S12516CR |
· LSXM1SFK16ER1 · LSXM1SFK16GR1 · LSXM3SFS16F2 · LSXM3SFS16G2 |
2 to 9 |
S12508CR |
· LSXM1SFK08ER1 · LSXM1SFK08FR1 · LSXM1SFK08GR1 · LSXM3SFS08F2 · LSXM3SFS08G2 |
2 to 9 |
NOTE: You can install a maximum of six Type S fabric modules (LSXM3SFS08F2 for example) on an S12516CR or S12508CR. For an S12508CR, install Type S fabric modules in slots 14 to 19. For an S12516CR, install Type S fabric modules in slots 22 to 27. |
The device comes with empty fabric module slots. For good ventilation, purchase and install filler panels in the empty fabric module slots.
Table 2-13 Fabric module slot filler panels
Item |
S12516R fabric module slot filler panel |
0 to 4 |
S12508R fabric module slot filler panel |
0 to 4 |
S12504R fabric module slot filler panel |
0 to 4 |
S12516CR fabric module slot filler panel |
0 to 6 |
S12508CR fabric module slot filler panel |
0 to 6 |
Slide rails
No slide rails are provided with the device. Purchase slide rails for the device as needed.
Table 2-14 Slide rails available for the device
Device model |
Chassis weight (fully configured) |
Applicable slide rails |
Slide rail model |
Adjustment range |
Occupied space |
S12516R |
400 kg (881.83 lb) |
LSXM1BSR |
630 mm to 900 mm (24.80 in to 35.43 in) |
1 RU |
S12508R |
220 kg (485.01 lb) |
LSXM1BSR |
1 RU |
LSTM2KSGD0 |
500 mm to 800 mm (19.69 in to 31.50 in) |
2 RU |
S12504R S12500R-2XL |
120 kg (264.55 lb) |
LSVM1BSR10 |
630 mm to 850 mm (24.80 in to 33.46 in) |
N/A |
S12500R-2L |
70 kg (154.32 lb) |
S12516CR |
620 kg (1366.84 lb) |
LSXM1BSR |
1 RU |
S12508CR |
LSXM1BSR |
1 RU |
Power trays and power modules
CAUTION: You must install power modules of the same model for the device. |
The device supports N+N (dual power input lines) or N+1 (single power input line) power module redundancy. Determine the number of power modules based on the power supply mode and system power consumption. Make sure the maximum total output power of the device power modules is greater than the system power consumption. Reserve a 20% power surplus as a best practice.
Table 2-15 describes the power trays and power modules available for the device.
Table 2-15 Power trays and power modules available for the device
Device model |
Available power trays |
Available power modules |
S12516R S12508R S12504R S12500R-2XL |
N/A |
PSR2400-54A PSR2400-54D PSR3000-54A PSR3000-54AHD |
S12516CR S12508CR |
CR-PEM-DC2000 |
PSR2000B-54D |
CR-PEM-AC3000 |
PSR3000B-54AHD |
CR-PEM-HVDC3000 |
PSR3000B-54AHD |
S12500R-2L |
N/A |
PSR1800-56A PSR1800-56D |
The PSR2000B-54D is a DC input and DC output removable power supply. The PSR3000B-54AHD is an AC/high-voltage DC input and DC output removable power supply.
Table 2-16 PSR2400-54A power module specifications
Item |
Specifications |
Rated input voltage |
100 to 240 VAC @ 50 or 60 Hz |
Rated output voltage |
54 VDC |
Maximum input current |
16 A |
Maximum output current |
44.5 A |
Maximum output power |
· 1200 W @ 110 VAC · 2400 W @ 220 VAC |
Dimensions (H × W × D) |
41 × 100 × 332 mm (1.61 × 3.94 × 13.07 in) |
Ambient temperature |
Operating temperature |
–10°C to +50°C (–14°F to +122°F) |
Storage temperature |
–40°C to +70°C (–40°F to +158°F) |
Table 2-17 PSR3000-54A power module specifications
Item |
Specifications |
54 VDC |
16 A |
55.6 A |
· 1200 W @ 100 to 175 VAC · 3000 W @ 175 to 240 VAC |
Table 2-18 PSR2400-54D power module specifications
Item |
Specifications |
–48 to –60 VDC |
54 VDC |
80 A |
44.5 A |
2400 W |
Table 2-19 PSR3000-54AHD power module specifications
Item |
Specifications |
AC input |
Rate input voltage |
20 A |
High-voltage DC input |
240 to 380 VDC |
20 A |
54 V |
27.8 A (100 to 175 VAC) 55.6 A (175 to 240 VAC or 240 to 380 VDC) |
1500 W (100 to 175 VAC) 3000 W (175 to 240 VAC or 240 to 380 VDC) |
Table 2-20 PSR2000B-54D/PSR3000B-54AHD power supply specifications
Item |
PSR2000B-54D |
PSR3000B-54AHD |
–48 to –60 VDC |
· 100 to 130 VAC @ 50 or 60 Hz · 200 to 240 VAC @ 50 or 60 Hz · 240 VDC · 336 VDC |
Input voltage range |
–39 to –72 VDC |
· 90 to 150 VAC @ 47 to 63 Hz · 176 to 290 VAC @ 47 to 63 Hz · 180 to 290 VDC · 260 to 400 VDC |
Input current |
60 A (max) |
16 A (rated) |
54 VDC |
54 VDC |
Max. output current |
37 A |
55.6 A |
Max. output power |
2000 W |
· 100 to 130 VAC @ 60 Hz: 1500 W · 200 to 240 VAC @ 50 Hz: 3000 W · 240 VDC: 3000 W · 336 VDC: 3000 W |
· Operating: –10°C to +50°C (14°F to 122°F) · Storage: –40°C to +70°C (–40°F to +158°F) |
41 × 68 × 440 mm (1.61 × 2.68 × 17.32 in) |
Weight |
2.0 kg (4.41 lb) |
2.0 kg (4.41 lb) |
Compatible power trays |
CR-PEM-DC2000 |
· AC power input: CR-PEM-AC3000 and CR-PEM-HVDC3000 · 240 VDC power input: CR-PEM-AC3000 and CR-PEM-HVDC3000 · 336 VDC power input: CR-PEM-HVDC3000 |
Table 2-1 PSR1800-56A power supply specifications
Item |
Specifications |
56 VDC |
· 13 A @ 110 VAC · 9 A @ 220 VAC |
32.2 A |
· 1100 W @ 100 VAC to 200 VAC · 1800 W @ 201 VAC to 240 VAC · 1800 W @ 240 VDC |
40.1 × 82.6 × 297.7 mm (1.58 × 3.25 × 11.72 in) |
–40°C to + 70°C (–40°F to +158°F) |
Table 2-2 PSR1800-56D power supply specifications
Item |
Specifications |
–48 to –60 VDC |
56 VDC |
45 A |
32.2 A |
1800 W |
NOTE: The power module shuts down automatically when its temperature exceeds the acceptable range. When the temperature returns to the acceptable range, the power module automatically restarts. |
Fan trays
Table 2-3 Fan trays available for the device
Model |
Available fan trays |
Number of fans |
Fan diameter |
Maximum air flow rate |
S12516R |
LSXM116XFAN |
6 |
120 mm (4.72 in) |
1020 CFM (28.88 m3/min) |
LSXM116XFANH (high-performance) |
6 |
134 mm (5.28 in) |
1860 CFM (52.67 m3/min) |
S12508R |
LSXM108XFAN |
3 |
120 mm (4.72 in) |
510 CFM (14.44 m3/min) |
LSXM108XFANH (high-performance) |
3 |
134 mm (5.28 in) |
930 CFM (26.33 m3/min) |
S12504R |
LSXM104XFAN |
2 |
120 mm (4.72 in) |
340 CFM (9.63 m3/min) |
LSXM104XFANH (high-performance) |
2 |
120 mm (4.72 in) |
560 CFM (15.86 m3/min) |
S12516CR |
FAN-80-9-A |
9 |
80 mm (3.15 in) |
900 CFM (25.49 m3/min) |
S12508CR |
FAN-80-5-A |
5 |
80 mm (3.15 in) |
500 CFM (14.16 m3/min) |
S12500R-2L |
FAN-120-1-A |
2 |
120 mm (4.72 in) |
1240 CFM (35.11 m3/min) |
S12500R-2XL |
2 |
120 mm (4.72 in) |
NOTE: You can install a maximum of three fan trays on an S12516CR or S12508CR installed with Type S modules. The fan trays can be installed only in slots FAN 2 to FAN 4. Do not remove the filler panels in slots FAN 1 and FAN 5. |
DC power cords
A DC power cord is used for connecting a DC power module on the device to an external DC power supply system.
Table 2-4 DC power cords
Power module/power tray model |
Power cord length |
PSR2400-54D |
3 m (9.84 ft) |
Connects the DC power module to an external DC power supply system. |
15 m (49.21 ft) |
PSR3000-54AHD |
3 m (9.84 ft) |
Connects the 3000W AC & 240 to 380 HVDC power module to an external DC power supply system. |
CR-PEM-DC2000 |
5 m (16.40 ft) |
Connects the power tray to an external DC power supply system. |
25 m (82.02 ft) |
35 m (114.83 ft) |
CR-PEM-HVDC3000 |
1 m (3.28 ft) |
3 m (9.84 ft) |
PSR1800-56D |
3 m (9.84 ft) |
Connects the DC power supply to an external DC power source. |
15 m (49.21 ft) |
AC power cords
An AC power cord is used for connecting an AC power module on the device to an external AC power supply system.
· Select an AC power cord with a current-carrying capacity that meets the power module requirement.
· The connector type varies by country or region. Select a compliant connector type as needed.
· Select 16A AC power cords for the device. For the connector types of different countries or regions, see http://www.h3c.com/en/Support/Resource_Center/EN/Home/Switches/00-Public/Install/Installation_Guides/H3C_Power_Cords_Cables_UG-6W100/.
To purchase chassis components, contact the sales agent or H3C sales personnel.
Table 2-5 Chassis component ordering information
Product code |
Product name |
MPUs |
0231AE3C |
LSXM1SUPER1 |
H3C S12500R supervisor engine unit |
0231ADRF |
LSXM1SUP04TR1 |
H3C S12504R supervisor engine unit |
0231ADUD |
LSXM1SUPKR1 |
H3C S12500CR supervisor engine unit |
0231ABV3 |
LSXM1SUP02LR1 |
H3C S12500R-2L supervisor engine unit |
0231AG2Q |
LSXM1SUP02TR1 |
0231AKY6 |
LSXM2SUP02LR1 |
0231AH9W |
LSXM1SUPEAR1 |
H3C S12500R AI supervisor engine unit |
0231AH9X |
LSXM1SUPKAR1 |
H3C S12500CR AI supervisor engine unit |
0231AJC1 |
LSXM1SUPRS2 |
0231AE47 |
LSXM1CMUR1 |
H3C S12500CR switch environment management module |
0231AJC0 |
LSXM1CMURS2 |
Fabric modules |
0231AD26 |
LSXM2SFH16CR1 |
H3C S12516R fabric module, Type H (Class C) |
0231AD2A |
LSXM1SFH16ER1 |
H3C S12516R fabric module, Type H (Class E) |
0231AD28 |
LSXM1SFH08CR1 |
H3C S12508R fabric module, Type H (Class C) |
0231AD27 |
LSXM1SFH08DR1 |
H3C S12508R fabric module, Type H(Class D) |
0231AD29 |
LSXM1SFH04DR1 |
H3C S12504R fabric module, Type H(Class D) |
0231AFCT |
LSXM1SFK16ER1 |
H3C S12516R fabric module, Type K(Class E) |
0231AE48 |
LSXM1SFK16GR1 |
H3C S12516R fabric module, Type K(Class G) |
0231AFCU |
LSXM1SFK08ER1 |
H3C S12508R fabric module, Type K(Class E) |
0231AE3A |
LSXM1SFK08FR1 |
H3C S12508R fabric module, Type K(Class F) |
0231AETV |
LSXM1SFK08GR1 |
H3C S12508R fabric module, Type K(Class G) |
0231AETW |
LSXM1SFK04FR1 |
H3C S12504R fabric module, Type K(Class F) |
0231AGJ7 |
LSXM3SFS16F2 |
H3C S12516 fabric module,Type S(Class F) |
0231AGHK |
LSXM3SFS16G2 |
H3C S12516 fabric module,Type S (Class G) |
0231AGJ3 |
LSXM3SFS08F2 |
H3C S12508 fabric module,Type S(Class F) |
0231AGHR |
LSXM3SFS08G2 |
H3C S12508 fabric module,Type S (Class G) |
Service modules |
0231AD2D |
LSXM1CGQ36HBR1 |
H3C S12500R 36-Port 100GBASE Ethernet optical interface module (QSFP28) (HB) |
0231AD2E |
LSXM1CGQ36HFR1 |
H3C S12500R 36-Port 100GBASE Ethernet optical interface module (QSFP28) (HF) |
0231AEM6 |
LSXM1TGS48HFR1 |
H3C S12500R 48-port 10GBASE Ethernet optical interface module (SFP+,LC)(HF) |
0231AEM8 |
LSXM1CGQ18QGHFR1 |
H3C S12500R 18-port 100GBASE Ethernet optical interface (QSFP28)/36-port 40GBASE Ethernet optical interface module (QSFP+)(HF) |
0231AEM7 |
LSXM1CGQ6QGHFR1 |
H3C S12500R 6-port 100GBASE Ethernet optical interface (QSFP28)/12-port 40GBASE Ethernet optical interface module (QSFP+)(HF) |
0231AE03 |
LSXM1TGS48HBR1 |
H3C S12500R 48-port 10GBASE Ethernet optical interface module (SFP+,LC)(HB) |
0231AE04 |
LSXM1CGQ18QGHBR1 |
H3C S12500R 18-port 100GBASE Ethernet optical interface (QSFP28)/36-port 40GBASE Ethernet Optical interface module (QSFP+)(HB) |
0231AE39 |
LSXM1CDQ24KBR1 |
H3C S12500R 24-port 400GBASE Ethernet optical interface module (QSFP-DD) (KB) |
0231AE3B |
LSXM1CGQ48KBR1 |
H3C S12500R 48-port 100GBASE Ethernet optical interface module (QSFP28) (KB) |
0231AM6Y |
LSXM1CDQ18KCR1 |
H3C S12500R 18-port 400GBASE Ethernet optical interface module (QSFP-DD)(KC) |
0231AE4A |
LSXM1CDQ36KBR1 |
H3C S12500CR 36-port 400GBASE Ethernet optical interface module (QSFP-DD) (KB) |
0231AFPW |
LSXM1CCQ48KBR1 |
H3C S12500R 48-port 200GBASE Ethernet optical interface module (QSFP56) (KB) |
0231AG0A |
LSXM1MOD24KBR1 |
H3C S12500R 24KBR flexible line processing platform module |
0231AG2P |
LSXM1CGQFX16KBR1 |
H3C S12500R 16-port 100GBASE FlexE Ethernet optical interface module(QSFP28) |
0231AH8C |
LSXM1CGMS48KBR1 |
H3C S12500R 48-port 100GBASE MACsec Ethernet optical interface module (QSFP28) |
0231AJ2B |
LSXM1CDMS36KCR1 |
H3C S12500CR 36-port 400GBASE MACsec Ethernet optical interface module (QSFP-DD)(KC) |
0231AGX6 |
LSXM1CGQ72KCR1 |
H3C S12500R 36-port 200GBASE Ethernet optical interface (QSFP56)/72-port 100GBASE Ethernet optical interface module (QSFP28)(KC) |
0231AGJ5 |
LSXM3CDQ16SF2 |
H3C S12500 16-port 400G Ethernet optical interface module (QSFP-DD)(SF) |
0231AGJ6 |
LSXM3CDQ8SF2 |
H3C S12500 8-port 400G Ethernet optical interface module (QSFP-DD)(SF) |
0231AGHL |
LSXM3CGQ36SF2 |
H3C S12500 36-port 100G Ethernet optical interface module (QSFP28)(SF) |
0231AGJ4 |
LSXM3CGQ18SF2 |
H3C S12500 18-port 100G Ethernet optical interface module (QSFP28)(SF) |
0231AGJ2 |
LSXM3QGS36SF2 |
H3C S12500 36-port 40G Ethernet optical interface module (QSFP+)(SF) |
0231AGHP |
LSXM3YGS48SF2 |
H3C S12500 48-port 25G Ethernet optical interface module (SFP28,LC) (SF) |
0231AGHN |
LSXM3TGS48SF2 |
H3C S12500 48-port 10G Ethernet optical interface module (SFP+,LC)(SF) |
Interface module |
0231AFVG |
LSXM1CGQ18C1 |
18-port 100GBASE Ethernet optical interface module (QSFP28) |
0231AG38 |
LSXM1CGQ8C1 |
0231AG2N |
LSXM1TGS24C1 |
24-port 100GBASE Ethernet optical interface module (SFP+,LC) |
Fan trays |
0231A2T1 |
LSXM116XFAN |
Fan module for the H3C S12516R |
0231A2UH |
LSXM108XFAN |
Fan module for the H3C S12508R |
0231A2X9 |
LSXM104XFAN |
Fan module for the H3C S12504R |
0231A4WX |
LSXM116XFANH |
High speed fan module for the H3C S12516R |
0231A4X0 |
LSXM108XFANH |
High speed fan module for the H3C S12508R |
0231A4X1 |
LSXM104XFANH |
High speed fan module for the H3C S12504R |
0231AE49 |
FAN-80-9-A |
Fan tray module (9 fans, port to power airflow) |
0231AE4B |
FAN-80-5-A |
Fan tray module (5 fans, port to power airflow) |
0231ABVR |
LSXM102LFAN |
H3C S12500R-2L Ethernet switch router fan module |
Power trays |
0231A5UX |
CR-PEM-DC2000 |
DC 2000W power tray |
0231A5UW |
CR-PEM-AC3000 |
AC 3000W power tray |
0231A5UY |
CR-PEM-HVDC3000 |
HVDC 3000W power tray |
Power modules |
0231A2KX |
LSVM3PSRA |
AC power supply, 1800W |
0231A2KY |
PSR1800-56D |
DC power supply, 1800W |
0231A2SN |
PSR2400-54A |
AC power module, 2400W |
0231A2X7 |
PSR2400-54D |
DC power module, 2400W |
0231A5CH |
PSR3000-54A |
3000W AC power supply module |
0231A6PS |
PSR3000-54AHD |
3000W AC & 240V-380V HVDC power supply |
0231A5V1 |
PSR2000B-54D |
DC 2000W power supply |
0231A5V0 |
PSR3000B-54AHD |
AC 3000W power supply (support HVDC) |
Power cords |
0404A0E1 |
CAB-DC Pwr-3m-2 |
External DC power cable, 3m, 13mm^2, PWR63A-B-2, 6UL10455BL+6UL10455B, 2*(T16-12G)+2*OT(16-6-0)!+2*OT(16-8-0)! |
0404A0E2 |
CAB-DC Pwr-15m-2 |
External DC power cable, 15m, 13mm^2, PWR63A-B-2, 6UL10455BL+6UL10455B, 2*(T16-12G)+2*OT(16-6-0)!+2*OT(16-8-0)! |
0404A0H4 |
CAB-AC-CHI-C19RA-3m |
Chinese AC power cable (C19 right angle), 3.0m, 1.5mm^2, black, PI250V16AAM, 227 IEC 53(RVV)3*1.5mm^2B, C19-250V16ARAF |
04043396 |
CAB-AC Pwr CHI-3m |
Chinese AC power cable 220V16A, 3m, 3*1.5mm^2, black, I-Type angle plug, 227IEC53-1.5^2(3C), C19 straight connector |
0404A0C2 |
CAB-AC Pwr 3C-3m-PDU |
External power cable, Chinese AC power cable 220V16A, 3m, 3*1.5mm^2, black, C20 straight plug, 227IEC53-1.5^2(3C), C19 straight connector, PDU |
0404A0GE |
CAB-HVDC-16A-PDU-3m-Y |
High voltage DC power cable (yellow), 3m, 1.5mm^2, pantone yellow 121C, C20-250V16A, 227IEC53(RVV)3*1.5mm^2 pantone yellow 121C, C19-250V16A |
0404A0GK |
CAB-HVDC-250V16A-3m-Y |
High voltage DC power cable (yellow), 3m, 1.5mm^2, pantone yellow 121C, PI angle plug, 227IEC53(RVV)3*1.5mm^2PANTONE YELLOW 121C, C19-250V16A |
0404A0HS |
CAB-AC-PWR-3m-C20-C19RA |
External AC power cable, 3m, 3*1.5mm^2, black, C20-250V16A, 227IEC53(RVV)3*1.5mm^2B, C19RA-250V16A |
0404A0LH |
CAB-HVDC-16A-PDU-5m-Y |
High voltage DC power cable (yellow), 5m, 1.5mm^2, pantone yellow 121C, C20-250V16A, 227IEC53(RVV)3*1.5mm^2 pantone yellow 121C, C19-250V16A |
0404A0NH |
CAB-PDU PWR-3m-C19A-C20 |
Chinese PDU power cable (C19A-C20) yellow, 3.0m, 3*1.5mm^2, pantone yellow 121C, C20-250V16ASM, 227 IEC 53(RVV)3*1.5mm^2 pantone yellow 121C,C19-250V16AAF |
0404A0RQ |
CAB-AC-Pwr-3m-PW3C450V |
External AC power cable, 3m, 3*1.5mm^2, black, PW3C-16A450V, 227IEC53(RVV)3*1.5mm^2B, PI-16A250V-SM |
0404A0RP |
CAB-PDU Pwr-3m-PW3C450V |
External AC PDU power cable, 3m, 3*1.5mm^2, black, PW3C-16A450V, 227IEC 53(RVV)3*1.5mm^2B, C20-16A250V |
0404A0RL |
CAB-HVDC Pwr-3m-336V |
336V high voltage DC power cable, 3m, 3*1.5mm^2, black, PW3C-16A450V, 227IEC53(RVV)3*1.5mm^2B, 3*T1.5mm^2-8R+3*OT(2.5-6-0)! |
Fabric module slot filler panels |
0231A3RK |
LSXM1BFP16A |
16 fabric blank filler panel |
0231A3RL |
LSXM1BFP08A |
08 fabric blank filler panel |
0231A3RM |
LSXM1BFP04A |
04 fabric blank filler panel |
Slide rails |
0231A4EK |
LSXM1BSR |
1U bottom-support rails, 630mm-900mm |
0231A0PL |
LSTM2KSGD0 |
Slide rail accessories, 500mm-800mm |
0231A2VL |
LSVM1BSR10 |
H3C S9810 bottom support rails, 630mm-900mm |
Interface module adapter |
0231AE4C |
LSXM1IMAA |
H3C S12500CR interface module adapter |
