14-Layer 3—IP Services Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath F1000[F5000] Firewalls Series Configuration Guides(V7)-6W90114-Layer 3—IP Services Configuration Guide
06-IPv6 fast forwarding configuration
06-IPv6 fast forwarding configuration 67.07 KB
Configuring IPv6 fast forwarding
About IPv6 fast forwarding
Fast forwarding reduces route lookup time and improves packet forwarding efficiency by using a high-speed cache and data-flow-based technology. It identifies a data flow by using the following fields:
·     Source IPv6 address.
·     Destination IPv6 address.
·     Source port number.
·     Destination port number.
·     Protocol number.
After a flow's first packet is forwarded through the routing table, fast forwarding creates an entry and uses the entry to forward subsequent packets of the flow.
vSystem support for features
Non-default vSystems do not support the following features:
·     Configuring the aging time for IPv6 fast forwarding entries.
·     Configuring IPv6 fast forwarding load sharing.
For information about the support of non-default vSystems for the commands, see IPv6 fast forwarding command reference. For information about vSystem, see Virtual Technologies Configuration Guide.
The IPv6 fast forwarding feature will create fast forwarding entries for the device to speed up packet forwarding. When the traffic volume is high, the device will generate a large number of fast forwarding entries. These entries will cause high memory usage, which eventually leads to memory allocation failure for other services. In this case, you can disable this feature temporarily to free up device memory.
2.     Configure IPv6 fast forwarding.
¡     Enable IPv6 fast forwarding.
ipv6 fast-forwarding enable
¡     Disable IPv6 fast forwarding.
undo ipv6 fast-forwarding enable
By default, IPv6 fast forwarding is enabled.
The IPv6 fast forwarding table uses an aging timer for each forwarding entry. If an entry is not updated before the timer expires, the device deletes the entry. If an entry has a hit within the aging time, the aging timer restarts.
2.     Set the aging time for IPv6 fast forwarding entries.
ipv6 fast-forwarding aging-time aging-time
By default, the aging time is 30 seconds.
IPv6 fast forwarding load sharing enables the device to identify a data flow by using the packet information.
If IPv6 fast forwarding load sharing is disabled, the device identifies a data flow by the packet information and the input interface.
2.     Configure IPv6 fast forwarding load sharing. Choose one option as needed:
¡     Enable IPv6 fast forwarding load sharing.
Ipv6 fast-forwarding load-sharing
¡     Disable IPv6 fast forwarding load sharing.
undo ipv6 fast-forwarding load-sharing
By default, IPv6 fast forwarding load sharing is enabled.
Display and maintenance commands for IPv6 fast forwarding
Display the aging time of the IPv6 fast forwarding entries.
display ipv6 fast-forwarding aging-time
Display IPv6 fast forwarding entries.
display ipv6 fast-forwarding cache [ ipv6-address ] [ slot slot-number ]
Display IPv6 fast forwarding entries for fragmented datagrams.
display ipv6 fast-forwarding fragcache [ ipv6-address ] [ slot slot-number ]
Clear the IPv6 fast forwarding table.
reset ipv6 fast-forwarding cache [ slot slot-number ]
