H3C Access Controllers Application Security Web-Based Configuration Examples-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Application Security Web-Based Configuration Examples-6W100
03-H3C Access Controllers Comware 7 Anti-Virus Configuration Example
Introduction
The following information provides an example for configuring anti-virus.
Application scenarios
This configuration example is used in networks with security threats.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
This feature is supported only in E5568P01 and later.
Example: Configuring anti-virus
As shown in Figure 1, the AC is connected to the Internet. The client uses a Web server and a mail server on the Internet to transfer files and emails. Configure the AC to use an anti-virus policy to detect and prevent viruses in the files and emails uploaded and downloaded by the client.
Figure 1 Network diagram
Configuring the switch
Configure the switch as follows (details not shown):
·     Configure VLAN interfaces and DHCP. Assign IP address 192.1.1.2/24 to VLAN interface 100. Create a DHCP address pool named vlan100, specify subnet 192.1.1.0/24 for dynamic allocation, and specify gateway address 192.1.1.1.
·     Assign IP address 192.2.1.2/24 to VLAN interface 200. Create a DHCP address pool named vlan200, specify subnet 192.2.1.0/24 for dynamic allocation, and specify gateway address 192.2.1.1.
·     Configure the interface connecting to the AC as a trunk port, and configure the interface connecting to the AP as an access port.
Configuring the AC
Configuring basic AC functions
Configure VLAN interfaces. (Details not shown.)
Adding an object group
1.     From the navigation pane, select Application Security > Object Groups > IPv4 Address Object Groups.
Figure 2 IPv4 address object group configuration page
2.     Click  to add an IPv4 address object group named sobj_ipv4.
Figure 3 Configuring an object group name
3.     Click  to add an object for the object group:
a.     Select Network segment from the Object list.
b.     Configure the network segment as 192.2.1.0/255.255.255.0.
c.     Click Apply.
d.     Click Apply to complete the configuration.
Figure 4 Adding an object
Configuring an anti-virus profile
1.     From the navigation pane, select Application Security > Anti-Virus > Profile.
Figure 5 Anti-virus profile configuration page
2.     Click  to add an anti-virus profile:
a.     Enter av in the Name field.
b.     In the File transfer protocols area, set the action to Block in both the upload and download directions for the HTTP and FTP protocols.
c.     In the Mail protocols area, set the action to Block for the SMTP and POP3 mail protocols.
Figure 6 Adding an anti-virus profile
3.     In the Application exceptions area, click  to add an application exception:
a.     Enter Alibaba in the Name field.
b.     Set the action to Alarm.
c.     Click Apply.
Figure 7 Adding an application exception
Configuring a security policy
1.     From the navigation pane, select Application Security > Security Policies > Security Policies.
Figure 8 Security policy configuration page
2.     Click  to add a security policy:
¡     Enter AV in the Security policy name field.
¡     Select SSID service.
¡     Select APs ap1 and ap2.
¡     Select AP group default-group.
¡     Select type IPv4.
¡     Set the action to Permit.
¡     Select source IP address sobj_ipv4.
¡     Select anti-virus profile av.
¡     Select Enable in the Policy field to enable the security policy.
¡     Click Apply.
Figure 9 Adding a security policy
# Verify that the AC can use the anti-virus policy to detect and prevent viruses.
Related documentation
·     H3C Access Controllers Web-Based Configuration Guide
