H3C Access Controllers Application Security Web-Based Configuration Examples-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Application Security Web-Based Configuration Examples-6W100
01-H3C Access Controllers Comware 7 IPS Configuration Example
Introduction
The following information provides an example for configuring IPS.
Application scenarios
This configuration example is used to protect enterprise information systems and networks from attacks .
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
This feature is supported only in E5568P01 and later.
Example: Configuring IPS
As shown in Figure 1, the switch acts as a DHCP server to assign IP addresses to the AP and the clients. The AP and the AC use VLAN 100 to establish a tunnel, and the clients access the wireless network through VLAN 200. Configure IPS to protect internal users in enterprises from vulnerability attacks from the Internet.
Figure 1 Network diagram
Procedures
Configuring basic AC functions
Configure wireless service, IP address, AP access, and radio settings on the AC. (Details not shown.)
Configuring an address object group
1.     From the left navigation pane, select Application Security > Object Groups > IPv4 Address Object Groups.
2.     Click  to add an IPv4 address object group:
a.     Enter object group name ipsfilter.
b.     Click  to specify the network segment object, specify the content as 192.2.1.0/24, and click Apply.
c.     Click Apply.
Figure 2 Adding an IPv4 address object group
Configuring an IPS profile
1.     From the left navigation pane, select Application Security > IPS > Profiles.
2.     Click  to add an IPS profile, and configure the following parameters:
¡     Enter IPS profile name ips.
¡     Select all protected objects.
¡     Select Vulnerability as the attack type.
¡     Select Server and Client as objects.
¡     Select Deny, Permit, Reset, and Block-source as default actions.
¡     Select all severity levels, including Critical, High, Medium, and Low.
Figure 3 Configuring filtering criteria
3.     In the Set profile rule area, configure the following parameters:
¡     Select the Deny action.
¡     Use the default settings for other parameters.
Figure 4 Configuration profile rules
4.     Click Apply.
5.     Activate the IPS profile settings.
<AC> system-view
[AC] inspect activate
Configuring a security policy
1.     From the left navigation pane, select Application Security > Security Policies > Security Policies.
2.     Click  to add a security policy:
¡     Enter security policy name name.
¡     Select Permit as the action.
¡     Enter ipsfilter in the Destination IP address field.
¡     Select IPS profile ips.
3.     Click OK.
Figure 5 Adding a security policy
Verify that the AC can use the IPS profile to protect internal users from vulnerability attacks.
Related documentation
H3C Access Controllers Web-Based Configuration Guide
