04-A-MPDU and A-MSDU Configuration Example | 176.17 KB |
H3C Access Controllers |
Comware 7 A-MSDU and A-MPDU Aggregation |
Overview
The following information provides an example for configuring A-MSDU and A-MPDU aggregation.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of A-MSDU and A-MPDU.
Example: Configuring A-MSDU and A-MPDU aggregation
As shown in Figure 1, configure the 802.11an radio mode and configure A-MPDU aggregation and A-MSDU aggregation to reduce AP traffic and improve network throughput efficiency.
Procedures
1. Click the Network View tab at the bottom of the page.
2. From the navigation pane, select Wireless Configuration > Radio Management.
3. Click the More icon on
the Radios for all AP models tab.
4. Click the Edit icon for
radio 2.4GHz(2) of AP ap1.
Figure 2 Radio list
5. On the Basic tab, configure the radio as follows in the Basic Configuration area:
¡ Select On from the Status field.
¡ Select the 802.11n(2.4GHz) radio mode.
Figure 3 Configuring basic radio settings
6. On the Basic tab, configure the radio as follows in the 802.11n/802.11ac configuration area:
¡ Select On from the A-MSDU field.
¡ Select On from the A-MPDU field.
Figure 4 Configuring basic radio settings
# Verify that network throughput efficiency is improved. (Details not shown.)
Related documentation
H3C Access Controllers Web-Based Configuration Guide
