06-Radio Resources Management
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Web-Based Configuration Examples-6W10006-Radio Resources Management
01-Radio Management Configuration Example
01-Radio Management Configuration Example 121.73 KB
Comware 7 Radio Management
Overview
The following information provides an example for configuring radio management.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of radio management.
Example: Configuring radio management
As shown in Figure 1, create a manual AP and set the radio mode, working channel, and maximum transmit power to 802.11gn, channel 11, and 19 dBm, respectively.
Figure 1 Network diagram
Procedures
1.     Click the Network View tab at the bottom of the page.
2.     From the navigation pane, select Wireless Configuration > Radio Management.
3.     Click the More icon  in the upper right corner of the Radios for all APs area.
4.     Click the Edit icon  for radio 2.4GHz(2) of AP ap1 and configure the radio as follows:
¡     Set the radio mode to 802.11n(2.4GHz).
¡     Set the working channel to 11.
¡     Set the maximum power to 19 dBm.
¡     Select On from the Status field.
Figure 2 Configuring basic radio settings
3.     Verify that the radio is configured correctly.
Figure 3 Verifying the configuration
Related documentation
H3C Access Controllers Web-Based Configuration Guide
