06-Radio Resources Management
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Web-Based Configuration Examples-6W10006-Radio Resources Management
02-Load Balancing Group-Based Session-Mode Load Balancing Configuration Example
Comware 7 Load Balancing Group-Based Session-Mode Load Balancing
Overview
The following information provides an example for configuring load balancing group-based session-mode load balancing.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of load balancing group-based session-mode load balancing.
Example: Configuring load balancing group-based session-mode load balancing
As shown in Figure 1, AP 1, AP 2, and AP 3 are managed by the AC and the clients can discover the APs. Client 1 associates with radio 2 of AP 1. Client 2 through Client 4 associate with radio 2 of AP 2.
Configure the AC to perform session-mode load balancing on radio 2 of AP 1 and radio 2 of AP 2 when the following conditions are met:
·     The number of sessions on one radio reaches 3.
·     The session gap between the radios reaches 2.
Figure 1 Network diagram
Procedures
Configuring basic features on the AC
Configure AP access, wireless service, and radio settings. (Details not shown.)
Adding a load balancing group
1.     Click the Network View tab at the bottom of the page.
2.     From the navigation pane, select Wireless Configuration > Radio Management.
3.     Click the Load Balancing tab and click the More button  in the Loadbalancing groups area.
a.     Click the Add button .
b.     On the page that opens, enter 1 in the Group ID field.
c.     Click the Add radios to group link.
d.     In the window that opens, select radio 2 of AP 1 and radio 2 of AP 2, and then click Apply.
e.     On the Add Group page, click Apply.
Figure 2 Adding a load balancing group
3.     Click the Load Balancing tab and click the More button  in the Global settings area.
a.     On the page that opens, select on and Session.
b.     Enter 3 and 2 in the Session threshold and Session gap threshold fields, respectively.
Use the default values in the Max denials and RSSI threshold fields.
c.     Click Apply.
Figure 3 Configuring load balancing
1.     Configure Client 5 to access the WLAN in the nearby area of AP 2.
2.     Click the Network View tab at the bottom of the page.
3.     From the navigation pane, select Monitoring > Clients.
4.     Verify that the number of clients associated with AP 1 has increased by 1.
Related documentation
H3C Access Controllers Web-Based Configuration Guide
