- 21-Network Management and Monitoring
- 01-DISMAN-EVENT-MIB
- 02-DISMAN-PING-MIB
- 03-DISMAN-TRACEROUTE-MIB
- 04-HH3C-NQA-MIB
- 05-HH3C-NTP-MIB
- 06-HH3C-RMON-EXT2-MIB
- 07-HH3C-SNMP-EXT-MIB
- 08-RMON-MIB
- 09-RMON2-MIB
- 10-SFLOW-MIB
- 11-SNMP-FRAMEWORK-MIB
- 12-SNMP-MPD-MIB
- 13-SNMP-NOTIFICATION-MIB
- 14-SNMP-TARGET-MIB
- 15-SNMP-USER-BASED-SM-MIB
- 16-SNMP-VIEW-BASED-ACM-MIB
- 17-SNMPv2-MIB
| 14-SNMP-TARGET-MIB | 84.90 KB |
SNMP-TARGET-MIB
About this MIB
Use this MIB to configure parameters used by an SNMP entity for generation of SNMP messages.
Use snmpTargetAddrTable and snmpTargetParamsTable together for creating a target host and follow these rules.
· To create a target host, you must create an instance in both snmpTargetAddrTable and snmpTargetParamsTable.
· Set the same value for snmpTargetAddrName and snmpTargetAddrParams.
· Set the same value for snmpTargetAddrParams and snmpTargetParamsName.
· Set snmpTargetAddrName in the traphost+snmpTargetParamsSecurityName+IpAddress+VPNInstancename format, where IpAddress is the IP address in the snmpTargetAddrTAddress value. You do not need to specify VPNInstancename if the device does not support VPN.
· Set snmpTargetAddrTagList to TrapHost or InformHost.
· Set snmpTargetAddrStorageType to nonVolatile.
· Set snmpTargetParamsSecurityName to a value with a length of 1 to 32 octets in snmpTargetAddrParams.
· Set VPNInstancename to a value with a length of 1 to 31 octets in snmpTargetAddrParams.
***** SNMP QUERY STARTED *****
1:[Loaded:SNMPv2-TM] snmpTargetAddrTDomain.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (object identifier) snmpUDPDomain
2:snmpTargetAddrTAddress.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (octet string) A9.FE.4C.4C.00.A2 (hex)
3:snmpTargetAddrTimeout.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (integer) 1500
4:snmpTargetAddrRetryCount.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (integer) 3
5:snmpTargetAddrTagList.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (octet string) TrapHost [54.72.61.70.48.6F.73.74 (hex)]
6:snmpTargetAddrParams.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (octet string) traphost.gl.169.254.76.76 [74.72.61.70.68.6F.73.74.2E.67.6C.2E.31.36.39.2E.32.35.34.2E.37.36.2E.37.36 (hex)]
7:snmpTargetAddrStorageType.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (integer) nonVolatile(3)
8:snmpTargetAddrRowStatus.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (integer) active(1)
9:snmpTargetParamsMPModel.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (integer) 0
10:snmpTargetParamsSecurityModel.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (integer) 1
11:snmpTargetParamsSecurityName.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (octet string) gl [67.6C (hex)]
12:snmpTargetParamsSecurityLevel.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (integer) noAuthNoPriv(1)
13:snmpTargetParamsStorageType.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (integer) nonVolatile(3)
14:snmpTargetParamsRowStatus.116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54 (integer) active(1)
15:snmpUnavailableContexts.0 (counter) 0
16:snmpUnknownContexts.0 (counter) 0
***** SNMP QUERY FINISHED *****
The preceding information is an SNMP query result for a target host instance. The index of the instance is 116.114.97.112.104.111.115.116.46.103.108.46.49.54.57.46.50.53.52.46.55.54.46.55.54, which can be converted to traphost.gl.169.254.76.76.
· With 116.114.97.112.104.111.115.116.46 converted to traphost.
· With 103.108.46 converted to gl.
· With 46.49.54.57.46.50.53.52.46.55.54.46.55.54 converted to 169.254.76.76.
MIB file name
rfc2573-snmp-target.mib
Root object
iso(1).org(3).dod(6).internet(1).snmpV2(6).snmpModules(3).snmpTargetMIB(12)
Scalar objects
snmpTargetSpinLock
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpTargetSpinLock (1.3.6.1.6.3.12.1.1) |
read-write |
TestAndIncr |
Standard MIB values. |
This object is used to facilitate modification of table entries. In particular, it is useful when modifying the value of the snmpTargetAddrTagList object. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpUnavailableContexts (1.3.6.1.6.3.12.1.4) |
read-only |
Counter32 |
Standard MIB values |
Total number of messages received but dropped by the SNMP engine because the context contained in the message was unavailable. |
As per the MIB. |
snmpUnknownContexts
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpUnknownContexts (1.3.6.1.6.3.12.1.5) |
read-only |
Counter32 |
Total number of messages received but dropped by the SNMP engine because the context contained in the message was unknown. |
As per the MIB. |
Tabular objects
snmpTargetAddrTable
About this table
Use this table to configure target addresses for SNMP messages
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is IMPLIED snmpTargetAddrName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpTargetAddrName (1.3.6.1.6.3.12.1.2.1.1) |
not-accessible |
SnmpAdminString |
OCTET STRING (1..32) |
Identifier for an snmpTargetAddrEntry. |
The value must be in a length of 1 to 255 octets. It can contain only displayable characters except for question marks. |
snmpTargetAddrTDomain (1.3.6.1.6.3.12.1.2.1.2) |
read-create |
TDomain |
Transport type of the address contained in the snmpTargetAddrTAddress object. |
The value is snmpUDPDomain. |
snmpTargetAddrTAddress (1.3.6.1.6.3.12.1.2.1.3) |
read-create |
TAddress |
OCTET STRING (1..255) |
Target address, the format of which depends on the value of the snmpTargetAddrTDomain object. |
As per the MIB. |
snmpTargetAddrTimeout (1.3.6.1.6.3.12.1.2.1.4) |
read-create |
TimeInterval |
Integer32 (0..2147483647) |
Expected maximum round trip time for communicating with the target address defined by this row. |
As per the MIB. |
snmpTargetAddrRetryCount (1.3.6.1.6.3.12.1.2.1.5) |
read-create |
Integer32 |
Integer32 (0..255) |
Default number of retries when a response is not received for a generated message. |
As per the MIB. |
snmpTargetAddrTagList (1.3.6.1.6.3.12.1.2.1.6) |
read-create |
SnmpTagList |
OCTET STRING (0..255) |
List of tag values which are used to select target addresses for a particular operation. |
The value can be TrapHost or InformHost only. It can contain only displayable characters except for question marks. |
snmpTargetAddrParams (1.3.6.1.6.3.12.1.2.1.7) |
read-create |
SnmpAdminString |
The value of this object identifies an entry in the snmpTargetParamsTable. |
snmpTargetAddrStorageType (1.3.6.1.6.3.12.1.2.1.8) |
read-create |
StorageType |
other(1), volatile(2), nonVolatile(3), permanent(4), readOnly(5) |
Storage type for this conceptual row. |
This object takes effect only when the value is nonVolatile. You can set the object to other values, but they do not take effect. |
snmpTargetAddrRowStatus (1.3.6.1.6.3.12.1.2.1.9) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
As per the MIB. |
About this table
Use this table to configure SNMP parameters to be used for generation of SNMP messages to be sent to a target.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is snmpTargetParamsName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpTargetParamsName (1.3.6.1.6.3.12.1.3.1.1) |
not-accessible |
SnmpAdminString |
Identifier for an snmpTargetParamsEntry. |
snmpTargetParamsMPModel (1.3.6.1.6.3.12.1.3.1.2) |
read-create |
SnmpMessageProcessingModel |
Message processing model to be used for generation of SNMP messages using this entry. |
As per the MIB. |
snmpTargetParamsSecurityModel (1.3.6.1.6.3.12.1.3.1.3) |
read-create |
SnmpSecurityModel |
Integer32 (1..2147483647) |
Security model to be used for generation of SNMP messages using this entry. An implementation might choose to return an inconsistent value error if an attempt is made to set this variable to a value for a security model which the implementation does not support. |
As per the MIB. |
snmpTargetParamsSecurityName (1.3.6.1.6.3.12.1.3.1.4) |
read-create |
SnmpAdminString |
Security name which identifies the principal on whose behalf SNMP messages will be generated. |
As per the MIB. |
snmpTargetParamsSecurityLevel (1.3.6.1.6.3.12.1.3.1.5) |
read-create |
SnmpSecurityLevel |
noAuthNoPriv(1), authNoPriv(2), authPriv(3) |
Security level to be used for generation of SNMP messages. |
As per the MIB. |
snmpTargetParamsStorageType (1.3.6.1.6.3.12.1.3.1.6) |
read-create |
StorageType |
snmpTargetParamsRowStatus (1.3.6.1.6.3.12.1.3.1.7) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
