- 21-Network Management and Monitoring
- 01-DISMAN-EVENT-MIB
- 02-DISMAN-PING-MIB
- 03-DISMAN-TRACEROUTE-MIB
- 04-HH3C-NQA-MIB
- 05-HH3C-NTP-MIB
- 06-HH3C-RMON-EXT2-MIB
- 07-HH3C-SNMP-EXT-MIB
- 08-RMON-MIB
- 09-RMON2-MIB
- 10-SFLOW-MIB
- 11-SNMP-FRAMEWORK-MIB
- 12-SNMP-MPD-MIB
- 13-SNMP-NOTIFICATION-MIB
- 14-SNMP-TARGET-MIB
- 15-SNMP-USER-BASED-SM-MIB
- 16-SNMP-VIEW-BASED-ACM-MIB
- 17-SNMPv2-MIB
| 03-DISMAN-TRACEROUTE-MIB | 166.87 KB |
About this MIB
This MIB contains information about the traceroute (tracert) utility defined by RFC 4560 and the traceroute notifications. The traceroute utility is implemented by NQA UDP traceroute operations.
MIB file name
rfc4560-disman-traceroute.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).traceRouteMIB(81)
Scalar objects
traceRouteMaxConcurrentRequests (1.3.6.1.2.1.81.1.1)
Access |
Syntax |
Value range |
Implementation |
traceRouteMaxConcurrentRequests (1.3.6.1.2.1.81.1.1) |
read-write |
Unsigned32 |
Standard MIB values. |
Maximum number of concurrent active traceroute requests that are allowed within an agent implementation. |
Only read is supported. |
Tabular objects
traceRouteCtlTable
About this table
Use this table to define probe parameters for a traceroute operation.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
· When create a traceroute operation entry, the default value of traceRouteCtlType is traceRouteUsingUdpProbes. At present, the traceRouteCtlType object supports only traceRouteUsingUdpProbes. · When create a traceroute operation entry, the values of the traceRouteCtlOwnerIndex and traceRouteCtlTestName objects must be different than the pingCtlOwnerIndex and pingCtlTestName objects. |
· Modifying any object in the traceRouteCtlTable except the following objects will clear the corresponding probe results, history records, and statistics information: ¡ traceRouteCtlTrapGeneration. ¡ traceRouteCtlDescr. ¡ traceRouteCtlMaxRows. If the new value for this object is lower than the previous value, the system deletes the excessive history records. · You must specify traceRouteCtlTargetAddressType and traceRouteCtlTargetAddress in pairs in an SNMP request. · You must specify traceRouteCtlSourceAddressType and traceRouteCtlSourceAddress in pairs in an SNMP request. · When traceRouteCtlAdminStatus is enabled, you cannot change the configuration in the traceRouteCtlTable. |
Supported |
Supported |
Columns
The table indexes are traceRouteCtlOwnerIndex and traceRouteCtlTestName.
Access |
Syntax |
Value range |
Implementation |
traceRouteCtlOwnerIndex (1.3.6.1.2.1.81.1.2.1.1) |
not-accessible |
SnmpAdminString |
OCTET STRING (0..32) |
Administrator name. |
For the set operation, the uppercase letters in the value will be converted to lowercase letters. The value cannot contain a minus sign (-) or question mark (?). |
traceRouteCtlTestName (1.3.6.1.2.1.81.1.2.1.2) |
not-accessible |
SnmpAdminString |
Operation tag. |
traceRouteCtlTargetAddressType (1.3.6.1.2.1.81.1.2.1.3) |
read-create |
InetAddressType |
Destination address type. |
Supports only ipv4(1), dns(16), and unknown(0). |
traceRouteCtlTargetAddress (1.3.6.1.2.1.81.1.2.1.4) |
read-create |
InetAddress |
Destination address. |
If the value for the traceRouteCtlTargetAddressType object is ipv4(1), the value for this object must be an IPv4 address. If the value for the traceRouteCtlTargetAddressType object is dns(16), the value for this object can be a host name. If the value for the traceRouteCtlTargetAddressType object is unknown(0), the value for this object must be a zero-length string. |
traceRouteCtlByPassRouteTable(1.3.6.1.2.1.81.1.2.1.5) |
read-create |
TruthValue |
Whether to bypass the routing table. |
As per the MIB. |
traceRouteCtlDataSize (1.3.6.1.2.1.81.1.2.1.6) |
read-create |
Unsigned32 |
Unsigned32 (0..65507) |
Size of the data portion of a traceroute request, in octets. |
Value range: 20 to 65507 octets. Default: 100 octets. |
traceRouteCtlTimeOut (1.3.6.1.2.1.81.1.2.1.7) |
read-create |
Unsigned32 |
Unsigned32 (1-60) |
Timeout time for waiting for a response to a probe request.. |
Same as the standard MIB file. |
traceRouteCtlProbesPerHop (1.3.6.1.2.1.81.1.2.1.8) |
read-create |
Unsigned32 |
Unsigned32 (1-10) |
Number of times to reissue a traceroute request with the same time-to-live (TTL) value. |
Same as the standard MIB file.. |
traceRouteCtlPort (1.3.6.1.2.1.81.1.2.1.9) |
read-create |
Unsigned32 |
Unsigned32 (1-65535) |
Destination port number. |
traceRouteCtlMaxTtl (1.3.6.1.2.1.81.1.2.1.10) |
read-create |
Unsigned32 |
Unsigned32 (1-255) |
Maximum TTL value. |
traceRouteCtlDSField (1.3.6.1.2.1.81.1.2.1.11) |
read-create |
Unsigned32 |
Unsigned32 (0-255) |
Service type. |
As per the MIB. |
traceRouteCtlSourceAddressType (1.3.6.1.2.1.81.1.2.1.12) |
read-create |
InetAddressType |
Source address type. |
Supports only ipv4(1) and unknown(0). Default: unknown(0). |
traceRouteCtlSourceAddress (1.3.6.1.2.1.81.1.2.1.13) |
read-create |
InetAddress |
Source address. |
If the value for the traceRouteCtlSourceAddressType object is ipv4(1), the value for this object must be an IPV4 address. If the value for the traceRouteCtlSourceAddressType object is unknown(0), the value for this object must be a zero-length string. |
traceRouteCtlIfIndex (1.3.6.1.2.1.81.1.2.1.14) |
read-create |
InterfaceIndexOrZero |
Output interface index. |
traceRouteCtlMaxFailures (1.3.6.1.2.1.81.1.2.1.16) |
read-create |
Unsigned32 |
Maximum number of consecutive timeouts allowed before a remote traceroute request is terminated. |
traceRouteCtlDontFragment (1.3.6.1.2.1.81.1.2.1.17) |
read-create |
TruthValue |
Whether to enable setting of the don't fragment flag (DF) in the IP header. |
traceRouteCtlInitialTtl (1.3.6.1.2.1.81.1.2.1.18) |
read-create |
Unsigned32 |
Unsigned32 (1..255) |
Initial TTL value. |
traceRouteCtlFrequency (1.3.6.1.2.1.81.1.2.1.19) |
read-create |
Unsigned32 |
Interval between two consecutive traceroute probes. |
Value range: 0 to 604800 seconds. The return value for the read operation is not accurate if the value is not set to integer seconds at the CLI. For example, if the value configured at the CLI is 1050 milliseconds, the return value for the read operation will be 2 seconds. Default: 0 seconds. |
traceRouteCtlAdminStatus (1.3.6.1.2.1.81.1.2.1.21) |
read-create |
INTEGER |
enabled(1) disabled(2) |
Operation status. |
As per the MIB. |
traceRouteCtlDescr (1.3.6.1.2.1.81.1.2.1.22) |
read-create |
SnmpAdminString |
OCTET STRING (0..255) |
Description string for the remote traceroute operation. |
Value range: 0 to 200 characters. The value cannot start with a space. |
traceRouteCtlMaxRows (1.3.6.1.2.1.81.1.2.1.23) |
read-create |
Unsigned32 |
Maximum number of history records. |
Value range: 0 to 50. |
traceRouteCtlTrapGeneration (1.3.6.1.2.1.81.1.2.1.24) |
read-create |
BITS |
BITS { pathChange(0), testFailure(1), testCompletion(2) } |
Conditions to generate notifications. |
As per the MIB. |
traceRouteCtlCreateHopsEntries(1.3.6.1.2.1.81.1.2.1.25) |
read-create |
TruthValue |
Whether to generate the hop table. |
As per the MIB. |
traceRouteCtlType (1.3.6.1.2.1.81.1.2.1.26) |
read-create |
OBJECT IDENTIFIER |
Traceroute operation type. |
This object cannot be edited after creation. |
traceRouteCtlRowStatus (1.3.6.1.2.1.81.1.2.1.27) |
read-create |
RowStatus |
Row status. |
Supports only active(1), createAndgo(4), and destroy(6). |
traceRouteResultsTable
About this table
This table contains information about traceroute probe results.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Access |
Syntax |
Value range |
Implementation |
traceRouteResultsOperStatus (1.3.6.1.2.1.81.1.3.1.1) |
read-only |
INTEGER |
enabled(1) , disabled(2), completed(3) |
Operation status of a remote traceroute operation. |
As per the MIB. |
traceRouteResultsCurHopCount (1.3.6.1.2.1.81.1.3.1.2) |
read-only |
Gauge32 |
Current TTL value for the traceroute request. |
As per the MIB. |
traceRouteResultsCurProbeCount (1.3.6.1.2.1.81.1.3.1.3) |
read-only |
Gauge32 |
Current probe count for the remote traceroute operation. |
As per the MIB. |
traceRouteResultsIpTgtAddrType (1.3.6.1.2.1.81.1.3.1.4) |
read-only |
InetAddressType |
Type of address stored in the corresponding traceRouteResultsIpTgtAddr object. |
As per the MIB. |
traceRouteResultsIpTgtAddr (1.3.6.1.2.1.81.1.3.1.5) |
read-only |
InetAddress |
IP address associated with a traceRouteCtlTargetAddress value when the destination address is specified as a DNS name. |
As per the MIB. |
traceRouteResultsTestAttempts (1.3.6.1.2.1.81.1.3.1.6) |
read-only |
Gauge32 |
Current number of probe attempts. |
As per the MIB. |
traceRouteResultsTestSuccesses (1.3.6.1.2.1.81.1.3.1.7) |
read-only |
Gauge32 |
Current number of succeeded probe attempts. |
As per the MIB. |
traceRouteResultsLastGoodPath (1.3.6.1.2.1.81.1.3.1.8) |
read-only |
DateAndTime |
Date and time when the last complete path was determined. |
As per the MIB. |
traceRouteProbeHistoryTable
About this table
Use this table to obtain history information about each probe in a traceroute operation.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are traceRouteCtlOwnerIndex, traceRouteCtlTestName, traceRouteProbeHistoryIndex, traceRouteProbeHistoryHopIndex, and traceRouteProbeHistoryProbeIndex.
Access |
Syntax |
Value range |
Implementation |
traceRouteProbeHistoryIndex (1.3.6.1.2.1.81.1.4.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (1..'ffffffff'h) |
History record index of a traceroute operation. |
As per the MIB. |
traceRouteProbeHistoryHopIndex (1.3.6.1.2.1.81.1.4.1.2) |
not-accessible |
Unsigned32 |
Index of a hop in the record. |
As per the MIB. |
traceRouteProbeHistoryProbeIndex (1.3.6.1.2.1.81.1.4.1.3) |
not-accessible |
Unsigned32 |
Unsigned (1-10) |
Index of a probe for the hop in the traceroute path. |
As per the MIB. |
traceRouteProbeHistoryHAddrType(1.3.6.1.2.1.81.1.4.1.4) |
read-only |
InetAddressType |
Type of address for the hop in the traceroute path. |
As per the MIB. |
traceRouteProbeHistoryHAddr (1.3.6.1.2.1.81.1.4.1.5) |
read-only |
InetAddress |
Address of the hop in the traceroute path. |
As per the MIB. |
traceRouteProbeHistoryResponse (1.3.6.1.2.1.81.1.4.1.6) |
read-only |
Unsigned32 |
Amount of time measured in milliseconds from when the probe was sent to when its response was received or when it timed out. |
As per the MIB. |
traceRouteProbeHistoryStatus (1.3.6.1.2.1.81.1.4.1.7) |
read-only |
OperationResponseStatus |
Probe result. |
As per the MIB. |
traceRouteProbeHistoryLastRC (1.3.6.1.2.1.81.1.4.1.8) |
read-only |
Integer32 |
The last implementation-method-specific reply code received. |
As per the MIB. |
traceRouteProbeHistoryTime (1.3.6.1.2.1.81.1.4.1.9) |
read-only |
DateAndTime |
Time when the probe result was determined. |
As per the MIB. |
traceRouteHopsTable
About this table
This table contains information about each hop in a traceroute path.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are traceRouteCtlOwnerIndex, traceRouteCtlTestName, and traceRouteHopsHopIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
traceRouteHopsHopIndex (1.3.6.1.2.1.81.1.5.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (1..4294967295) |
Hop index. |
As per the MIB. |
traceRouteHopsIpTgtAddressType (1.3.6.1.2.1.81.1.5.1.2) |
read-only |
InetAddressType |
As per the MIB. |
traceRouteHopsIpTgtAddress (1.3.6.1.2.1.81.1.5.1.3) |
read-only |
InetAddress |
As per the MIB. |
traceRouteHopsMinRtt (1.3.6.1.2.1.81.1.5.1.4) |
read-only |
Unsigned32 |
Minimum bidirectional delay. |
As per the MIB. |
traceRouteHopsMaxRtt (1.3.6.1.2.1.81.1.5.1.5) |
read-only |
Unsigned32 |
Maximum bidirectional delay. |
As per the MIB. |
traceRouteHopsAverageRtt (1.3.6.1.2.1.81.1.5.1.6) |
read-only |
Unsigned32 |
Average bidirectional delay |
As per the MIB. |
traceRouteHopsRttSumOfSquares (1.3.6.1.2.1.81.1.5.1.7) |
read-only |
Unsigned32 |
Sum of squares for delay. |
As per the MIB. |
traceRouteHopsSentProbes (1.3.6.1.2.1.81.1.5.1.8) |
read-only |
Unsigned32 |
Number of sent probe packets. |
As per the MIB. |
traceRouteHopsProbeResponses (1.3.6.1.2.1.81.1.5.1.9) |
read-only |
Unsigned32 |
Number of received probe reply packets. |
As per the MIB. |
traceRouteHopsLastGoodProbe (1.3.6.1.2.1.81.1.5.1.10) |
read-only |
DateAndTime |
Date and time when the last probe reply packet was received. |
As per the MIB. |
Notifications
traceRoutePathChange
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.81.0.1 |
The traceroute path changed. |
Informational |
Warning |
N/A |
OFF |
Notification triggers
This notification is generated if the path obtained by the current traceroute operation is different from the path obtained by the last traceroute operation.
System impact
No impact on the system.
Status control
ON
CLI: Use the reaction trap path-change command.
OFF
CLI: Use the undo reaction trap path-change command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.2.1.81.1.2.1.3 (traceRouteCtlTargetAddressType) |
traceRouteCtlOwnerIndex traceRouteCtlTestName |
InetAddressType |
1.3.6.1.2.1.81.1.2.1.4 (traceRouteCtlTargetAddress) |
InetAddress |
1.3.6.1.2.1.81.1.3.1.4 (traceRouteResultsIpTgtAddrType) |
Destination address type in the probe result. |
InetAddressType |
1.3.6.1.2.1.81.1.3.1.5 (traceRouteResultsIpTgtAddr) |
Destination address in the probe result. |
InetAddress |
Recommended action
No action is required.
traceRouteTestFailed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.81.0.2 |
A traceroute operation failed. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when a traceroute operation fails. The following might be operation failure reasons:
· The destination address does not exist.
· The destination address exists but is unreachable.
· The destination address exists and is reachable. However, the number of hops for probe packets of the traceroute operation to reach the destination address exceeds the maximum number of hops that the probe packets can traverse.
· The network latency is large and the round-trip time of packets is larger than the specified timeout time.
System impact
Status control
ON
CLI: Use the reaction trap test-failure [ accumulate-probe-failures ] command.
OFF
CLI: Use the undo reaction trap test-failure [ accumulate-probe-failures ] command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
InetAddressType |
InetAddress |
InetAddressType |
InetAddress |
Recommended action
1. In NQA operation view, execute the display this command to identify whether the destination address is configured correctly.
¡ If the destination address is correct, go to step 2.
¡ If the destination address is incorrect, execute the destination ip command to change the destination address, and then perform the traceroute operation again.
- If no notification is generated, the issue is cleared.
- If the notification is generated, go to step 2.
2. In NQA operation view, execute the ping command to identify whether the destination address is reachable.
¡ If the destination address is reachable, go to step 3.
¡ If the destination address is unreachable, locate routing issues. For example, execute the display ip routing-table command to verify routing table information.
3. In NQA operation view, execute the display this command to display the maximum number of hops that the probe packets can traverse. You can execute the ttl command to change the maximum number as needed. Then, perform the traceroute operation again.
¡ If no notification is generated, the issue is cleared.
¡ If the notification is generated, go to step 4.
4. In NQA operation view, execute the probe timeout command to set the probe timeout time, and then perform the traceroute operation again.
¡ If the notification is generated, go to step 5.
5. Verify that the settings are correct on the destination device and the intermediate devices between the source and destination devices.
¡ IPv4:
- Enable sending ICMP time exceeded messages on the intermediate devices between the source and destination devices. If the intermediate devices are H3C devices, use the ip ttl-expires enable command.
- Enable sending ICMP destination unreachable messages on the destination device. If the destination device is an H3C device, use the ip unreachables enable command.
¡ IPv6:
- Enable sending ICMPv6 time exceeded messages on the intermediate devices between the source and destination devices. If the intermediate devices are H3C devices, use the ipv6 hoplimit-expires enable command.
- Enable sending ICMPv6 destination unreachable messages on the destination device. If the destination device is an H3C device, use the ipv6 unreachables enable command.
6. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
traceRouteTestCompleted
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.81.0.3 |
A traceroute operation completed. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when a traceroute operation completes successfully.
System impact
Status control
ON
CLI: Use the reaction trap test-complete command.
OFF
CLI: Use the undo reaction trap test-complete command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
InetAddressType |
InetAddress |
InetAddressType |
InetAddress |
Recommended action
