05-NAT Configuration Guide
HomeSupportSecurityH3C SecPath F100-C-A FirewallConfigure & DeployConfiguration GuidesH3C SecPath F100[F1000] Firewalls Series Configuration Guides(V7)-6W90005-NAT Configuration Guide
03-AFT configuration
03-AFT configuration 410.97 KB
Content
Configuring AFT· 1
About AFT· 1
AFT translation methods· 1
Static AFT· 1
Dynamic AFT· 1
Prefix translation· 2
IPv6 internal server 4
IPv4 internal server 4
Static port block mapping-based IPv6-to-IPv4 source address translation· 4
AFT translation process· 4
IPv6-initiated communication· 4
IPv4-initiated communication· 5
AFT ALG·· 6
AFT support for hot backup in collaboration with virtual IP addresses· 6
Restrictions and guidelines· 7
AFT tasks at a glance· 7
Enabling AFT· 7
Configuring an IPv6-to-IPv4 destination address translation policy· 8
About IPv6-to-IPv4 destination address translation policies· 8
Configuring an AFT mapping for an IPv4 internal server 8
Configuring an IPv4-to-IPv6 source address static mapping· 8
Configuring a general prefix· 9
Configuring a NAT64 prefix· 9
Configuring an IPv6-to-IPv4 source address translation policy· 9
About IPv6-to-IPv4 source address translation policies· 9
Configuring an IPv6-to-IPv4 source address static mapping· 10
Configuring a general prefix· 10
Configuring an IVI prefix· 10
Configuring an IPv6-to-IPv4 source address dynamic translation policy· 10
Configuring a port block group-based IPv6-to-IPv4 source address static translation policy· 11
Configuring an IPv4-to-IPv6 destination address translation policy· 12
About IPv4-to-IPv6 destination address translation policies· 12
Restrictions and guidelines for configuring an IPv4-to-IPv6 destination address translation policy· 13
Configuring an AFT mapping for an IPv6 internal server 13
Configuring an IPv6-to-IPv4 source address static mapping· 13
Configuring an IPv4-to-IPv6 destination address translation policy based on IVI or general prefix· 14
Configuring an IPv4-to-IPv6 source address translation policy· 14
About IPv4-to-IPv6 source address translation policies· 14
Restrictions and guidelines for configuring an IPv4-to-IPv6 source address translation policy· 14
Configuring an IPv4-to-IPv6 source address static mapping· 14
Configuring an IPv4-to-IPv6 source address translation policy based on NAT64 or general prefix· 15
Configuring a NAT64 prefix· 15
Setting the ToS field to 0 for translated IPv4 packets· 15
Setting the Traffic Class field to 0 for translated IPv6 packets· 16
Configuring AFT ALG·· 16
Configuring AFT high availability· 16
About AFT high availability· 16
Enabling AFT port halving for IRF hot backup· 17
Associating an AFT address group with a VRRP group on a hot backup system·· 17
Enable dynamic port block mapping synchronization· 18
Enabling AFT logging· 19
Configuring AFT logging· 19
Configuring threshold violation logging· 20
Display and maintenance commands for AFT· 20
AFT configuration examples· 21
Example: Allowing IPv4 Internet access from an IPv6 network· 21
Example: Providing FTP service from an IPv6 network to the IPv4 Internet 24
Example: Allowing mutual access between IPv4 and IPv6 networks· 27
Example: Allowing IPv6 Internet access from an IPv4 network· 31
Example: Providing FTP service from an IPv4 network to the IPv6 Internet 34
Configuring AFT
About AFT
Address Family Translation (AFT) translates an IP address of one address family into an IP address of the other address family. It enables an IPv4 network and an IPv6 network to communicate with each other, as shown in Figure 1. The IPv4 host and the IPv6 host can communicate with each other without changing the existing configuration.
Figure 1 AFT application scenario
Static AFT
Static AFT creates a fixed mapping between an IPv4 address and an IPv6 address.
An IPv4-to-IPv6 source address static mapping can be applied to the following scenarios:
·     For an IPv4-initiated session packet, if the source IPv4 address in the packet matches the mapping, AFT translates the source IPv4 address to the mapped IPv6 address.
·     For an IPv6-initiated session packet, if the destination IPv6 address in the packet matches the mapping, AFT translates the destination IPv6 address to the mapped IPv4 address.
An IPv6-to-IPv4 source address static mapping can be applied to the following scenarios:
·     For an IPv6-initiated session packet, if the source IPv6 address in the packet matches the mapping, AFT translates the source IPv6 address to the mapped IPv4 address.
·     For an IPv4-initiated session packet, if the destination IPv4 address in the packet matches the mapping, AFT translates the destination IPv4 address to the mapped IPv6 address.
Dynamic AFT
Dynamic AFT creates a dynamic mapping between an IPv4 address and an IPv6 address.
When dynamic AFT performs IPv6-to-IPv4 source address translation, the Not Port Address Translation (NO-PAT) and Port Address Translation (PAT) modes are available.
NO-PAT
NO-PAT translates one IPv6 address to one IPv4 address. An IPv4 address assigned to one IPv6 host cannot be used by any other IPv6 host until it is released.
NO-PAT supports all IP packets.
PAT
PAT translates multiple IPv6 addresses to a single IPv4 address by mapping each IPv6 address and port to the IPv4 address and a unique port. PAT supports the following packet types:
·     TCP packets.
·     UDP packets.
·     ICMPv6 echo request and echo reply messages.
PAT supports port blocks for connection limit and user tracing. Port blocks are generated by dividing the port range (1024 to 65535) by the port block size. Port block based PAT maps multiple IPv6 addresses to one IPv4 address and uses a port block for each IPv6 address.
Port block based PAT functions as follows:
1.     When an IPv6 host first initiates a connection to the IPv4 network, it creates a mapping from the host's IPv6 address to an IPv4 address and a port block.
2.     It translates the IPv6 address to the IPv4 address, and the source ports to ports in the port block for subsequent connections from the IPv6 host until the ports in the port block are exhausted.
If the port range cannot be divided by the port block size exactly, the remaining ports are not used for translation.
Prefix translation
NAT64 prefix translation
A NAT64 prefix is an IPv6 address prefix used to construct an IPv6 address representing an IPv4 node in an IPv6 network. The IPv6 hosts do not use a constructed IPv6 address as their real IP address. The length of a NAT64 prefix can be 32, 40, 48, 56, 64, or 96. A NAT64 prefix can be a network-specific prefix (NSP) or well-known prefix (WKP). An NSP is assigned by an organization and is usually a subnet from the organization’s IPv6 prefix. The WKP for NAT64 is 64:ff9b::/96. If no NSP is configured, NAT64 uses the WKP to preform address translation.
As shown in Figure 2, the construction methods vary depending on the NAT64 prefix length. Bits 64 through 71 in the constructed IPv6 address are reserved bits, which must be set to 0.
·     If the prefix length is 32, 64, or 96 bits, the IPv4 address contained in the IPv6 address will be intact.
·     If the prefix length is 40, 48, or 56 bits, the IPv4 address contained in the IPv6 address will be divided into two parts by bits 64 through 71.
Figure 2 IPv6 address construction with NAT 64 prefix and IPv4 address
Table 1 Examples of IPv6 address construction with NAT64 prefix and IPv4 address
IPv6 prefix
IPv4 address
Constructed IPv6 address
2001:db8::/32
192.0.2.33
2001:db8:c000:221::
2001:db8:100::/40
192.0.2.33
2001:db8:1c0:2:21::
2001:db8:122::/48
192.0.2.33
2001:db8:122:c000:2:2100::
2001:db8:122:300::/56
192.0.2.33
2001:db8:122:3c0:0:221::
2001:db8:122:344::/64
192.0.2.33
2001:db8:122:344:c0:2:2100::
2001:db8:122:344::/96
192.0.2.33
2001:db8:122:344::192.0.2.33
AFT uses a NAT64 prefix to perform the following translation:
·     IPv4-to-IPv6 source address translation. AFT translates a source IPv4 address to an IPv6 address that is created by using the NAT64 prefix and the IPv4 address.
·     IPv6-to-IPv4 destination address translation. AFT uses the NAT64 prefix to match destination IPv6 addresses and extracts the embedded IPv4 address from the matching IPv6 addresses.
A NAT64 prefix cannot be on the same subnet as any interface on the device.
IVI prefix translation
An IVI prefix is a 32-bit IPv6 address prefix. An IVI address is the IPv6 address that an IPv6 node uses. As shown in Figure 3, the IVI address includes an IVI prefix and an IPv4 address.
Figure 3 IVI address format
AFT uses an IVI prefix for IPv6-to-IPv4 source address translation. If a source IPv6 address matches the IVI prefix, AFT translates it to the embedded IPv4 address.
General prefix translation
A general prefix is an IPv6 address prefix used to construct an IPv6 address representing an IPv4 node in an IPv6 network. The length of a general prefix can be 32, 40, 48, 56, 64, or 96.
As shown in Figure 4, a general prefix based IPv6 address does not have bits 64 through 71 reserved as a NAT64 prefix based IPv6 address does. An IPv4 address is embedded as a whole into an IPv6 address.
Figure 4 General prefix based IPv6 address format
AFT uses a general prefix for IPv6-to-IPv4 source and destination address translation. If a source or destination IPv6 address matches the general prefix, AFT translates it to the embedded IPv4 address.
A general prefix cannot be on the same subnet as any interface on the device.
IPv6 internal server maps the IPv6 address and port number of an IPv6 internal server to an IPv4 address and port number. It allows the IPv6 internal server to provide services to IPv4 hosts.
IPv4 internal server maps the IPv4 address and port number of an IPv4 internal server to an IPv6 address and port number. It allows the IPv4 internal server to provide services to IPv6 hosts.
AFT algorithmically creates static port block mappings based on the port block group configuration in a port block group-based IPv6-to-IPv4 source address static translation policy. A static port block mapping maps an IPv6 prefix to a unique IPv4 address and port block pair. When an IPv6-initiated session packet matches an IPv6 prefix in the policy, AFT translates the source IPv6 address of the packet into the IPv4 address and a TCP or UDP port number in the port block of the matching entry.
The address translation differs for IPv6-initiated communication and IPv4-initiated communication.
As shown in Figure 5, when the IPv6 host initiates access to the IPv4 host, AFT operates as follows:
1.     Upon receiving a packet from the IPv6 host, AFT compares the packet with IPv6-to-IPv4 destination address translation policies.
¡     If a matching policy is found, AFT translates the destination IPv6 address according to the policy.
¡     If no matching policy is found, AFT does not process the packet.
2.     AFT performs pre-lookup to determine the output interface for the translated packet. PBR is not used for the pre-lookup.
¡     If a matching route is found, the process goes to step 3.
¡     If no matching route is found, AFT discards the packet.
3.     AFT compares the source IPv6 address of the packet with IPv6-to-IPv4 source address translation policies.
¡     If a matching policy is found, AFT translates the source IPv6 address according to the policy.
¡     If no matching policy is found, AFT discards the packet.
4.     AFT forwards the translated packet and records the mappings between IPv6 addresses and IPv4 addresses.
5.     AFT translates the IPv4 addresses in the response packet header to IPv6 addresses based on the address mappings before packet forwarding.
For more information about IPv6-to-IPv4 destination address translation policies, see "Configuring an IPv6-to-IPv4 destination address translation policy."
For more information about IPv6-to-IPv4 source address translation policies, see "Configuring an IPv6-to-IPv4 source address translation policy."
Figure 5 AFT process for IPv6-initiated communication
As shown in Figure 6, when the IPv4 host initiates access to the IPv6 host, AFT operates as follows:
1.     Upon receiving a packet from the IPv4 host, AFT compares the packet with IPv4-to-IPv6 destination address translation policies.
¡     If a matching policy is found, AFT translates the destination IPv4 address according to the policy.
¡     If no matching policy is found, AFT does not perform address translation.
2.     AFT performs the pre-lookup to determine output interface for the translated packet. PBR is not used for the pre-lookup.
3.     AFT compares the source IPv4 address with IPv4-to-IPv6 source address translation policies.
¡     If a matching policy is found, AFT translates the source IPv4 address according to the policy.
4.     AFT forwards the translated packet and records the mappings between IPv4 addresses and IPv6 addresses.
5.     AFT translates the IPv6 addresses in the response packet header to IPv4 addresses based on the address mappings before packet forwarding.
For more information about IPv4-to-IPv6 destination address translation policies, see "Configuring an IPv4-to-IPv6 destination address translation policy."
For more information about IPv4-to-IPv6 source address translation policies, see "Configuring an IPv4-to-IPv6 source address translation policy."
Figure 6 AFT process for IPv4-initiated communication
AFT ALG
AFT ALG translates address or port information in the application layer payloads.
For example, an FTP application includes a data connection and a control connection. The IP address and port number for the data connection depend on the payload information of the control connection. This requires AFT ALG to translate the address and port information.
You enable AFT on a hot backup system in collaboration with virtual IP addresses (also known as floating addresses) and configure address translation for IPv6-initiated or IPv4-initiated sessions. Both the hot backup active and standby devices advertise the mappings between the IP addresses after translation and MAC addresses of their own physical interfaces to all nodes in the same LAN. As a result, the upstream Layer 3 device directly connected to the hot backup system might incorrectly send downlink packets to the hot backup standby device, causing service anomalies.
To avoid such an issue, configure only the hot backup active device to advertise the mappings between the IP addresses after translation and virtual MAC address corresponding to the virtual IP address.
Upon receiving an ARP reply from the hot backup active device, the upstream Layer 3 device updates the IP-MAC mapping. Then, it encapsulates downlink packets in which the destination IP address is a translated IP address with the virtual MAC address. The device sends the packets to the hot backup active device to ensure normal services.
An AFTed packet will not be NATed.
To configure AFT, perform the following tasks:
1.     Enabling AFT
2.     Configuring address translation for IPv6-initiated communication
You can perform the following tasks or configure global NAT policies to configure address translation for IPv6-initiated communication. For more information about global NAT policies, see "Configuring NAT."
¡     Configuring an IPv6-to-IPv4 destination address translation policy
¡     Configuring an IPv6-to-IPv4 source address translation
¡     (Optional.) Setting the ToS field to 0 for translated IPv4 packets
3.     Configuring address translation for IPv4-initiated communication
You can perform the following tasks or configure global NAT policies to configure address translation for IPv4-initiated communication. For more information about global NAT policies, see "Configuring NAT."
¡     Configuring an IPv4-to-IPv6 destination address translation policy
¡     Configuring an IPv4-to-IPv6 source address translation policy
¡     (Optional.) Setting the Traffic Class field to 0 for translated IPv6 packets
4.     (Optional.) Configuring AFT ALG
5.     (Optional.) Configuring AFT high availability
¡     Enabling AFT port halving for IRF hot backup
¡     Associating an AFT address group with a VRRP group on a hot backup system
¡     Enable dynamic port block mapping synchronization
6.     (Optional.) Enabling AFT logging
¡     Configuring AFT logging
¡     Configuring threshold violation logging
Enabling AFT
To implement address translation between IPv4 and IPv6 networks, you must enable AFT on interfaces connected to the IPv4 network and interfaces connected to the IPv6 network.
2.     Enter interface view.
3.     Enable AFT.
aft enable
By default, AFT is disabled.
AFT compares an IPv6 packet with IPv6-to-IPv4 destination address translation policies in the following order:
1.     AFT mappings for IPv4 internal servers.
2.     IPv4-to-IPv6 source address static mappings.
3.     General prefixes.
4.     NAT64 prefixes.
For this feature to operate correctly, make sure the security policy on the device permits packets that are sent from security zone Local to the IPv4 network-side security zone.
The AFT mappings for different IPv4 internal servers cannot be the same.
When an IPv4 server moves from a VPN to the public network or another VPN, and its IPv4 address and port number do not change, do not edit the public network or VPN information by repeating this command. To edit the public network or VPN information, first execute the undo aft v4server command to delete the AFT mapping for the IPv4 server, and then execute the aft v4server command.
2.     Configure an AFT mapping for an IPv4 internal server.
aft v4server protocol protocol-type ipv6-destination-address ipv6-port-number [ vpn-instance ipv6-vpn-instance-name ] ipv4-destination-address ipv4-port-number [ vpn-instance ipv4-vpn-instance-name ] [ vrrp virtual-router-id ]
By default, no AFT mapping for an IPv4 internal server is configured.
An IPv4 server can be bound to only one VRRP group. You can execute this command multiple times to change the bound VRRP group for the IPv4 server.
An IPv4-to-IPv6 source address static mapping creates a one-to-one mapping between an IPv4 address and an IPv6 address, and can be applied to the following scenarios:
2.     Configure an IPv4-to-IPv6 source address static mapping.
aft v4tov6 source ipv4-address [ vpn-instance ipv4-vpn-instance-name ] ipv6-address [ vpn-instance ipv6-vpn-instance-name ] [ vrrp virtual-router-id ]
By default, no IPv4-to-IPv6 source address static mapping is configured.
2.     Configure a general prefix.
aft prefix-general prefix-general prefix-length
By default, no general prefix is configured.
2.     Configure a NAT64 prefix.
aft prefix-nat64 prefix-nat64 prefix-length
By default, no NAT64 prefix is configured.
AFT compares an IPv6 packet with IPv6-to-IPv4 source address translation settings in the following order:
1.     IPv6-to-IPv4 source address static mappings.
2.     General prefixes.
3.     IVI prefixes.
4.     Port block group-based IPv6-to-IPv4 source address static translation policies.
5.     IPv6-to-IPv4 source address dynamic translation policies.
For this feature to operate correctly, make sure the security policy on the device permits packets that are from security zone Local to the IPv4 network-side security zone.
An IPv6-to-IPv4 source address static mapping creates a one-to-one mapping between an IPv6 address and an IPv4 address, and can be applied to the following scenarios:
2.     Configure an IPv6-to-IPv4 source address static mapping.
aft v6tov4 source ipv6-address [ vpn-instance ipv6-vpn-instance-name ] ipv4-address [ vpn-instance ipv4-vpn-instance-name ] [ vrrp virtual-router-id ]
2.     Configure an IVI prefix for IPv6-to-IPv4 source address translation.
aft prefix-ivi prefix-ivi
An IPv6-to-IPv4 source address dynamic translation policy uses dynamic IPv6-to-IPv4 mappings for IPv6-to-IPv4 source address translation. In PAT mode, AFT translates multiple IPv6 addresses to a single IPv4 address by mapping each IPv6 address and port to the IPv4 address and a unique port. PAT supports the following packet types:
·     TCP packets.
·     UDP packets.
2.     (Optional.) Configure an AFT address group.
a.     Create an AFT address group and enter AFT address group view.
aft address-group group-id
This step is required if you decide to use an address group in an IPv6-to-IPv4 source address dynamic translation policy.
b.     Add an address range to the address group.
address start-address end-address
You can add multiple address ranges to an address group, but the address ranges must not overlap.
c.     Return to system view.
This configuration is supported only for the IPv6-to-IPv4 source address dynamic translation policies.
3.     Configure an IPv6-to-IPv4 source address dynamic translation policy.
aft v6tov4 source { acl ipv6 { name ipv6-acl-name | number ipv6-acl-number } | prefix-nat64 prefix-nat64 prefix-length [ vpn-instance ipv6--vpn-instance-name ] } { address-group group-id [ no-pat | port-block-size blocksize [ extended-block-number extended-block-number ] [ port-range start-port-number end-port-number ] ] | interface interface-type interface-number } [ vpn-instance ipv4-vpn-instance-name ]
To create a port block group-based IPv6-to-IPv4 source address static translation policy, you must create a port block group for the policy first. A port block group contains the following settings:
·     Address ranges:
¡     IPv4 address ranges used for IPv6-to-IPv4 source address static translation.
¡     IPv6 prefix ranges used to match the IPv6 addresses to be translated.
·     Port range, which will be divided into port blocks of the user-defined port block size. Each port block is paired with an IPv4 address to match an IPv6 prefix for IPv6-to-IPv4 source address translation.
·     Port block size.
After the policy is created, the device algorithmically maps each IPv6 prefix to a unique IPv4 address and port block pair according to the policy's port block group configuration. If not enough unique IPv4 address and port block pairs are available, excessive IPv6 prefixes will be ignored and IPv6 addresses matching those IPv6 prefixes cannot be translated.
The total number of IPv6 prefixes that can be mapped equals to the total number of unique IPv4 address and port block pairs in the policy, which is calculated as follows:
Total number of IPv6 prefixes that can be mapped = N × M, where:
·     N is the total number of port blocks in the port block group, which is result of dividing the port range by the port block size.
·     M is the total number of IPv4 addresses in the policy available for IPv6-to-IPv4 translation.
For example, assuming that a policy contains two IPv4 addresses (x1 and y1) and n port blocks. The device takes n IPv6 prefixes in the port block group, maps them to the same IPv4 address paired in turn with the first to nth port blocks. The created static port block mappings are as follows:
·     IPv6 prefix x1<-->IPv4 address X1 + Port block 1
·     IPv6 prefix x2<-->IPv4 address X1 + Port block 2
·     IPv6 prefix xn<-->IPv4 address X1 + Port block n
·     IPv6 prefix y1<-->IPv4 address Y1 + Port block 1
·     IPv6 prefix y2<-->IPv4 address Y1 + Port block 2
·     IPv6 prefix yn<-->IPv4 address Y1 + Port block n.
2.     Create an AFT port block group and enter its view.
aft port-block-group block-group-id
3.     Add an IPv6 prefix range to the port block group.
ipv6-prefix ipv6-start-prefix ipv6-end-prefix prefix-length [ vpn-instance vpn-name ]
By default, an AFT port block group does not contain any IPv6 prefix ranges.
4.     Add an IPv4 address range to the port block group.
ip-address start-address end-address [ vpn-instance vpn-name ]
By default, an AFT port block group does not contain any IPv4 address ranges.
5.     Specify the port range for the port block group.
By default, an AFT port block group uses port range 1 to 65535.
6.     Set the port block size for the port block group.
block-size block-size-value
The default port block size is 256.
7.     Return to system view.
8.     Create an IPv6-to-IPv4 source address static translation policy based on the port block group.
aft v6tov4 source port-block-group group-id
By default, no port block group-based IPv6-to-IPv4 source address static translation policies exist.
AFT compares an IPv4 packet with IPv4-to-IPv6 destination address translation policies in the following order:
1.     AFT mappings for IPv6 internal servers.
2.     IPv6-to-IPv4 source address static mappings.
3.     IPv4-to-IPv6 destination address translation policies that use IVI prefixes or general prefixes.
For this feature to operate correctly, make sure the security policy on the device permits packets that are sent from security zone Local to the IPv6 network-side security zone.
The AFT mappings for different IPv6 internal servers cannot be the same.
If an IPv6 server moves from a VPN to the public network or another VPN, and its IPv6 address and port number do not change, do not edit the public network or VPN information by repeating this command. To edit the public network or VPN information, first execute the undo aft v6server command to delete the AFT mapping for the IPv6 server, and then execute the aft v6server command.
2.     Configure an AFT mapping for an IPv6 internal server.
aft v6server protocol protocol-type ipv4-destination-address ipv4-port-number [ vpn-instance ipv4-vpn-instance-name ] ipv6-destination-address ipv6-port-number [ vpn-instance ipv6-vpn-instance-name ] [ vrrp virtual-router-id ]
By default, no AFT mapping for an IPv6 internal server is configured.
An IPv6 server can be bound to only one VRRP group. You can execute this command multiple times to change the bound VRRP group for the IPv6 server.
2.     Configure an IVI prefix or general prefix. Choose one option as needed:
¡     Configure an IVI prefix.
¡     Configure a general prefix.
3.     Configure an IPv4-to-IPv6 destination address translation policy that uses an IVI prefix or a general prefix.
aft v4tov6 destination acl { name ipv4-acl-name prefix-ivi prefix-ivi [ vpn-instance ipv6-vpn-instance-name ] | number ipv4-acl-number { prefix-general prefix-general prefix-length | prefix-ivi prefix-ivi [ vpn-instance ipv6-vpn-instance-name ] } }
You can use a nonexistent IVI prefix or general prefix in a policy, but the policy takes effect only after you configure the prefix.
AFT compares an IPv4 packet with IPv4-to-IPv6 source address translation policies in the following order:
1.     IPv4-to-IPv6 source address static mappings.
2.     IPv4-to-IPv6 source address translation policies that use NAT64 prefixes or general prefixes.
3.     The first NAT64 prefix.
2.     Configure a NAT64 prefix or general prefix. Choose one option as needed:
¡     Configure a NAT64 prefix.
3.     Configure an IPv4-to-IPv6 source address translation policy that uses a NAT64 prefix or general prefixes.
aft v4tov6 source acl { name ipv4-acl-name prefix-nat64 prefix-nat64 prefix-length [ vpn-instance ipv6-vpn-instance-name ] | number ipv4-acl-number { prefix-general prefix-general prefix-length | prefix-nat64 prefix-nat64 prefix-length [ vpn-instance ipv6-vpn-instance-name ] } }
You can use a nonexistent NAT64 prefix or general prefix in a policy, but the policy takes effect only after you configure the prefix.
You can set the ToS field value for IPv4 packets translated from IPv6 packets:
·     If the value is set to 0, the priority of the IPv4 packets is set to the lowest.
·     If the value is kept the same as the Traffic Class field value of original IPv6 packets, the priority is not changed.
2.     Set the ToS field to 0 for IPv4 packets translated from IPv6 packets.
aft turn-off tos
By default, the ToS field value of translated IPv4 packets is the same as the Traffic Class field value of original IPv6 packets.
You can set the Traffic Class field value for IPv6 packets translated from IPv4 packets:
·     If the value is set to 0, the priority of the IPv6 packets is set to the lowest.
·     If the value is kept the same as the ToS field value of original IPv4 packets, the priority is not changed.
2.     Set the Traffic Class field to 0 for IPv6 packets translated from IPv4 packets.
aft turn-off traffic-class
By default, the Traffic Class field value of translated IPv6 packets is the same as the ToS field value of original IPv4 packets.
Configuring AFT ALG
In an IRF fabric, AFT configured on physical interfaces does not support ALG.
For this feature to operate correctly, make sure the security policy on the device permits packets that are sent from the initiator security zone to security zone Local.
2.     Enable AFT ALG for a protocol or all protocols.
aft alg { all | dns | ftp | h323 | http | icmp-error | rtsp | sip }
By default, AFT ALG is enabled for DNS, FTP, H.323, HTTP, ICMP error messages, RSTP, and SIP.
If only one AFT device is deployed in the internal network, internal users cannot access the external network when the AFT device fails. To avoid this situation, configure dual-device hot backup for AFT. The dual-device hot backup supports the IRF hot backup and hot backup system schemes. In the two schemes, the two IRF/hot backup member devices in dual-active or active/standby mode are capable of processing AFT services. Session entries, session relation entries, AFT port block entries, and AFT settings are synchronized through the backup channel. When one device fails, the other device takes over.
For more information about IRF, see Virtual Technologies Configuration Guide.
For more information about the hot backup system, see RBM-based hot backup configuration in High Availability Configuration Guide.
AFT supports IRF hot backup in active/standby and dual-active mode. The AFT configuration for IRF hot backup depends on the deployment mode.
·     In dual-active mode, if the two IRF member devices in an IRF fabric use the same AFT address group, the devices might map different IPv6 addresses and ports to the same IPv4 address and port. To avoid this situation, enable AFT port halving on the devices. After you enable AFT port halving, each port block will be equally divided between the two devices. The two devices will use different ports to translate packets from different IP addresses, avoiding port assignment conflicts.
·     In active/standby mode, you do not need to enable AFT port halving on the IRF member devices.
2.     Enable AFT port halving.
aft port-load-balance enable slot slot-number
By default, AFT port halving is disabled.
You enable AFT on a hot backup system in collaboration with VRRP and configure an IPv6-to-IPv4 source address dynamic translation policy or port block group-based IPv6-to-IPv4 source address static translation policy. Both the hot backup active and standby devices send gratuitous ARP packets to all nodes in the same LAN. This enables them to advertise the mappings between the IPv4 addresses in the translation policy and MAC addresses of their own physical interfaces. As a result, the upstream Layer 3 device directly connected to the hot backup system might incorrectly send downlink packets to the hot backup standby device, causing service anomalies.
To avoid such an issue, bind the AFT address group or AFT port block group to the VRRP group. Then, the hot backup active and standby devices no longer send gratuitous ARP packets. Upon receiving an ARP request in which the target IP address is an IPv4 address after translation, only the VRRP master device returns an ARP reply with the virtual MAC address of the VRRP group.
This mechanism enables the uplink Layer 3 device directly connected to the hot backup system to send downlink packets only to the hot backup active device, which ensures normal services. For more information about configuring the hot backup system, see RBM-based hot backup configuration in High Availability Configuration Guide. For more information about VRRP, see High Availability Configuration Guide.
As a best practice, do not use an AFT port block group for address translation in a dual-active hot backup system. If you use an AFT port block group for address translation, AFT service anomalies might occur when one device is faulty.
Procedure (dual-active mode)
2.     Enter AFT address group view.
3.     Bind the AFT address group to a VRRP group.
vrrp vrid virtual-router-id
By default, an AFT address group is not bound to any VRRP group.
4.     Return to system view.
5.     Specify AFT port ranges for the two devices in the hot backup system.
aft remote-backup port-alloc { primary | secondary }
By default, the two devices in the hot backup system share AFT port resources.
When the two devices in the hot backup system use the same AFT address group, execute this command on the primary device.
Procedure (active/standby mode)
2.     Enter AFT address group view or AFT port block group view.
¡     Enter AFT address group view.
¡     Enter AFT port block group view.
3.     Bind the AFT address group or AFT port block group to a VRRP group.
By default, an AFT address group or an AFT port block group is not bound to any VRRP group.
Execute this command on the primary device in the hot backup system.
In a service hot backup scenario, dynamic AFT port block mapping synchronization enables the active and the standby to synchronize dynamic port block mappings, which ensures smooth switchover without service interruption.
On a hot backup system, dynamic port block mapping synchronization takes effect only after you enable service entry hot backup by using the hot-backup enable command.
In an IRF hot backup network, dynamic port block mapping synchronization takes effect only after you enable session synchronization for stateful failover by using the session synchronization enable command.
2.     Enable dynamic port block mapping synchronization..
aft port-block synchronization enable
By default, dynamic port block mapping synchronization is enabled.
For security auditing, you can configure AFT logging to record AFT session information. AFT sessions refer to sessions whose source and destination addresses have been translated by AFT.
AFT can log the following events:
·     An AFT port block is assigned.
·     An AFT port block is withdrawn.
·     An AFT port block has assigned all its ports.
·     An AFT session is established.
·     An AFT session is removed.
The logs are sent to the information center of the device. For the logs to be output correctly, you must also configure the information center on the device. For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
2.     Enable AFT logging.
aft log enable
By default, AFT logging is disabled.
After you configure this command, AFT logs the creation and deletion events of AFT port blocks.
3.     (Optional.) Enabling AFT port block logging.
aft log port-block { alarm | assign | withdraw }
By default, AFT port block logging is disabled.
After you configure this command, AFT generates logs when an AFT port block is assigned or withdrawn, and an AFT port block has assigned all its ports.
AFT port block logging takes effect only after you execute the aft log enable command to enable AFT logging.
4.     (Optional.) Enabling AFT session establishment and removal logging.
¡     Enable AFT session establishment logging.
aft log flow-begin
By default, AFT session establishment logging is disabled.
AFT session establishment logging takes effect only after you execute the aft log enable command to enable AFT logging.
¡     Enable AFT session removal logging.
aft log flow-end
By default, AFT session removal logging is disabled.
AFT session removal logging takes effect only after you execute the aft log enable command to enable AFT logging.
In a port block group-based IPv6-to-IPv4 source address dynamic translation policy, if no available AFT resources can be assigned to users for address translation, the corresponding packets will be discarded. Use this feature to output logs when the AFT resources run out. AFT resources include IPv4 addresses and port blocks. A log is generated when the port block usage exceeds the threshold.
The logs are sent to the information center of the device. You can configure the information center to output these messages to certain destinations, such as the console and the log buffer. For more information about the information center, see information center configuration in Network Management and Configuring Configuration Guide.
This command takes effect only after you use the aft log enable command to enable AFT logging.
aft log enable
3.     Set the AFT port block usage threshold.
aft log port-block usage threshold threshold-value
By default, the AFT port block usage threshold is 90%.
Display AFT configuration.
display aft configuration
Display AFT address group information.
display aft address-group [ group-id ]
Display AFT mappings.
display aft address-mapping [ slot slot-number ]
Display information about AFT NO-PAT entries.
display aft no-pat [ slot slot-number ]
Display AFT port block mappings.
display aft port-block { dynamic | static } [ slot slot-number ]
Display information about AFT sessions.
display aft session ipv4 [ { source-ip source-ip-address | destination-ip destination-ip-address } * [ vpn-instance ipv4-vpn-instance-name ] ] [ slot slot-number ] [ verbose ]
display aft session ipv6 [ { source-ip source-ipv6-address | destination-ip destination-ipv6-address } * [ vpn-instance ipv6-vpn-instance-name ] ] [ slot slot-number ] [ verbose ]
Display AFT statistics.
display aft statistics [ slot slot-number ]
Clear AFT sessions.
reset aft session [ slot slot-number ]
Clear AFT statistics.
reset aft statistics [ slot slot-number ]
As shown in Figure 7, a company upgrades the network to IPv6 and has IPv4 addresses from 10.1.1.1 to 10.1.1.3.
To allow IPv6 hosts on subnet 2013::/96 to access the IPv4 Internet, configure the following AFT policies on the device:
·     Configure a NAT64 prefix to translate IPv4 addresses of IPv4 servers to IPv6 addresses.
·     Configure an IPv6-to-IPv4 source address dynamic translation policy to translate source IPv6 addresses of IPv6-initiated packets to IPv4 addresses in the range of 10.1.1.1 to 10.1.1.3.
Figure 7 Network diagram
1.     Assign IP addresses to interfaces:
# Assign an IP address to interface GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] ipv6 address 2013::1 96
2.     Add interfaces to security zones.
[Device] security-zone name trust
[Device-security-zone-Trust] import interface gigabitethernet 1/0/1
[Device] security-zone name untrust
[Device-security-zone-Untrust] import interface gigabitethernet 1/0/2
[Device-security-zone-Untrust] quit
3.     Configure settings for routing.
This example configures a static route with next hop address 10.1.1.100.
[Device] ip route-static 20.1.1.0 24 10.1.1.100
4.     Configure security policies:
# In the IPv6 security policy, configure a rule named aftlocalin to allow the device to perform AFT on the IPv6 host traffic destined for the IPv4 servers.
[Device] security-policy ipv6
[Device-security-policy-ipv6] rule name aftlocalin
[Device-security-policy-ipv6-1-aftlocalin] source-zone trust
[Device-security-policy-ipv6-1-aftlocalin] destination-zone local
[Device-security-policy-ipv6-1-aftlocalin] source-ip-subnet 2013:: 96
[Device-security-policy-ipv6-1-aftlocalin] destination-ip-host 2012::20.1.1.1
[Device-security-policy-ipv6-1-aftlocalin] destination-ip-host 2012::20.1.1.2
[Device-security-policy-ipv6-1-aftlocalin] action pass
[Device-security-policy-ipv6-1-aftlocalin] quit
[Device-security-policy-ipv6] quit
# In the IPv6 security policy, configure a rule named aftlocalout to allow the device to forward the AFT-translated packets to the IPv4 servers.
[Device-security-policy-ip] rule name aftlocalout
[Device-security-policy-ip-1-aftlocalout] source-zone local
[Device-security-policy-ip-1-aftlocalout] destination-zone untrust
[Device-security-policy-ip-1-aftlocalout] source-ip-host 10.1.1.1
[Device-security-policy-ip-1-aftlocalout] source-ip-host 10.1.1.2
[Device-security-policy-ip-1-aftlocalout] source-ip-host 10.1.1.3
[Device-security-policy-ip-1-aftlocalout] destination-ip-host 20.1.1.1
[Device-security-policy-ip-1-aftlocalout] destination-ip-host 20.1.1.2
[Device-security-policy-ip-1-aftlocalout] action pass
[Device-security-policy-ip-1-aftlocalout] quit
[Device-security-policy-ip] quit
5.     Configure AFT settings:
# Create AFT address group 0, and add the address range from 10.1.1.1 to 10.1.1.3 to the group.
[Device] aft address-group 0
[Device-aft-address-group-0] address 10.1.1.1 10.1.1.3
[Device-aft-address-group-0] quit
# Configure IPv6 ACL 2000 to permit IPv6 packets only from subnet 2013::/96 to pass through.
[Device] acl ipv6 basic 2000
[Device-acl-ipv6-basic-2000] rule permit source 2013:: 96
[Device-acl-ipv6-basic-2000] rule deny
[Device-acl-ipv6-basic-2000] quit
# Configure the device to translate source IPv6 addresses of packets permitted by IPv6 ACL 2000 to IPv4 addresses in address group 0.
[Device] aft v6tov4 source acl ipv6 number 2000 address-group 0
# Configure the device to use NAT64 prefix 2012::/96 to translate destination IPv6 addresses of IPv6 packets.
[Device] aft prefix-nat64 2012:: 96
# Enable AFT on the interfaces connected to the IPv6 network and IPv4 Internet, respectively.
[Device-GigabitEthernet1/0/1] aft enable
[Device-GigabitEthernet1/0/2] aft enable
# Configure routes to make sure IPv6 hosts can reach IPv6 addresses that are translated by using the NAT64 prefix, and IPv4 servers can reach translated IPv4 addresses. (Details not shown.)
# Verify the connectivity between IPv6 hosts and IPv4 servers. This example pings IPv4 server A from IPv6 host A.
D:\>ping 2012::20.1.1.1
Pinging 2012::20.1.1.1 with 32 bytes of data:
Reply from 2012::20.1.1.1: time=3ms
# Display detailed information about IPv6 AFT sessions on the device.
[Device] display aft session ipv6 verbose
Initiator:
  Source      IP/port: 2013::100/0
  Destination IP/port: 2012::1401:0101/32768
  Protocol: IPV6-ICMP(58)
  Inbound interface: GigabitEthernet1/0/1
  Source security zone: Trust
Responder:
  Source      IP/port: 2012::1401:0101/0
  Destination IP/port: 2013::100/33024
  Inbound interface: GigabitEthernet1/0/2
  Source security zone: Local
State: ICMPV6_REPLY
Application: ICMP
Rule ID: -/-/-
Rule name:
Start time: 2014-03-13 08:52:59  TTL: 23s
Initiator->Responder:            4 packets        320 bytes
Responder->Initiator:            4 packets        320 bytes
Total sessions found: 1
# Display detailed information about IPv4 AFT sessions on the device.
[Device] display aft session ipv4 verbose
Initiator:
  Source      IP/port: 10.1.1.1/1025
  Destination IP/port: 20.1.1.1/2048
  DS-Lite tunnel peer: -
  Protocol: ICMP(1)
Responder:
  Source      IP/port: 20.1.1.1/1025
  Destination IP/port: 10.1.1.1/0
  Protocol: ICMP(1)
  Source security zone: Untrust
State: ICMP_REPLY
Application: ICMP
Rule ID: 0
Rule name: aftlocalout
Start time: 2014-03-13 08:52:59  TTL: 27s
Initiator->Responder:            4 packets        240 bytes
Responder->Initiator:            4 packets        240 bytes
As shown in Figure 8, a company upgrades the network to IPv6, and it has an IPv4 address 10.1.1.1.
To allow the IPv6 FTP server to provide FTP services to IPv4 hosts, configure the following AFT policies on the device:
·     Map the IPv6 FTP server's IPv6 address and TCP port number to the company's IPv4 address and TCP port number.
·     Configure a NAT64 prefix to translate source IPv4 addresses of IPv4 packets to source IPv6 addresses.
Figure 8 Network diagram
[Device-GigabitEthernet1/0/1] ip address 10.1.1.2 24
[Device-security-zone-Trust] import interface gigabitethernet 1/0/2
[Device-security-zone-Untrust] import interface gigabitethernet 1/0/1
3.     Configure security policies:
# In the IPv4 security policy, configure a rule named aftlocalin to allow the device to perform AFT on the IPv4 traffic destined for the IPv6 FTP server.
[Device-security-policy-ip] rule name aftlocalin
[Device-security-policy-ip-1-aftlocalin] source-zone untrust
[Device-security-policy-ip-1-aftlocalin] destination-zone local
[Device-security-policy-ip-1-aftlocalin] destination-ip-host 10.1.1.1
[Device-security-policy-ip-1-aftlocalin] action pass
[Device-security-policy-ip-1-aftlocalin] quit
# In the IPv6 security policy, configure a rule named aftlocalout to allow the device to forward the AFT-translated packets to the IPv6 server.
[Device-security-policy-ipv6] rule name aftlocalout
[Device-security-policy-ipv6-1-aftlocalout] source-zone local
[Device-security-policy-ipv6-1-aftlocalout] destination-zone trust
[Device-security-policy-ipv6-1-aftlocalout] source-ip-subnet 2012:: 96
[Device-security-policy-ipv6-1-aftlocalout] destination-ip-host 2013::102
[Device-security-policy-ipv6-1-aftlocalout] action pass
[Device-security-policy-ipv6-1-aftlocalout] quit
4.     Configure AFT settings:
# Map IPv4 address 10.1.1.1 with TCP port 21 to IPv6 address 2013::102 with TCP port 21 for the IPv6 internal FTP server.
[Device] aft v6server protocol tcp 10.1.1.1 21 2013::102 21
# Configure the device to use NAT64 prefix 2012:: 96 to translate source addresses of IPv4 packets.
# Enable AFT on the interfaces connected to the IPv4 Internet and IPv6 network, respectively.
# Verify that IPv4 hosts can use FTP to access the IPv6 FTP server. (Details not shown.)
Initiator:
  Source      IP/port: 20.1.1.1/11025
  Destination IP/port: 10.1.1.1/21
  Protocol: TCP(6)
Responder:
  Source      IP/port: 10.1.1.1/21
  Destination IP/port: 20.1.1.1/11025
  Protocol: TCP(6)
State: TCP_ESTABLISHED
Application: FTP
Rule ID: -/-/-
Rule name:
Start time: 2014-03-13 09:07:30  TTL: 3577s
Initiator->Responder:            3 packets        124 bytes
Responder->Initiator:            2 packets        108 bytes
Initiator:
  Source      IP/port: 2012::1401:0101/1029
  Destination IP/port: 2013::102/21
  Protocol: TCP(6)
Responder:
  Source      IP/port: 2013::102/21
  Destination IP/port: 2012::1401:0101/1029
  Protocol: TCP(6)
Application: FTP
Rule ID: 0
Start time: 2014-03-13 09:07:30  TTL: 3582s
Initiator->Responder:            3 packets        184 bytes
Responder->Initiator:            2 packets        148 bytes
As shown in Figure 9, a company deploys both an IPv4 network and an IPv6 network.
To allow mutual access between the IPv4 network and the IPv6 network, configure the following AFT policies on the device:
·     Assign an IVI prefix and an IPv4 subnet to the IPv6 network. Each IPv6 host uses the IPv6 addresses formed by the IVI prefix and an IPv4 address on the IPv4 subnet.
·     Configure a NAT64 prefix to translate source IPv4 addresses of packets initiated by the IPv4 network to IPv6 addresses.
Figure 9 Network diagram
[Device-GigabitEthernet1/0/1] ip address 20.1.1.1 24
This example configures an IPv6 static route (with next hop address 2014::100) and an IPv4 static route (with next hop address 20.1.1.2).
[Device] ipv6 route-static 2013:: 32 2014::100
[Device] ip route-static 10.1.1.0 24 20.1.1.2
4.     Configure security policies to allow the device to permit IPv4-to-IPv6 traffic:
# In the IPv4 security policy, configure a rule named aftlocalin4 to allow the device to perform AFT on the IPv4 traffic destined for the IPv6 hosts.
[Device-security-policy-ip] rule name aftlocalin4
[Device-security-policy-ip-1-aftlocalin4] source-zone trust
[Device-security-policy-ip-1-aftlocalin4] destination-zone local
[Device-security-policy-ip-1-aftlocalin4] source-ip-subnet 10.1.1.0 24
[Device-security-policy-ip-1-aftlocalin4] destination-ip-subnet 20.1.1.0 24
[Device-security-policy-ip-1-aftlocalin4] action pass
[Device-security-policy-ip-1-aftlocalin4] quit
# In the IPv6 security policy, configure a rule named aftlocalout6 to allow the device to forward the AFT-translated packets to the IPv6 hosts.
[Device-security-policy-ipv6] rule name aftlocalout6
[Device-security-policy-ipv6-1-aftlocalout6] source-zone local
[Device-security-policy-ipv6-1-aftlocalout6] destination-zone trust
[Device-security-policy-ipv6-1-aftlocalout6] source-ip-subnet 2012:: 96
[Device-security-policy-ipv6-1-aftlocalout6] destination-ip-subnet 2013:: 32
[Device-security-policy-ipv6-1-aftlocalout6] action pass
[Device-security-policy-ipv6-1-local-ipv6] quit
5.     Configure security policies to allow the device to permit IPv6-to-IPv4 traffic:
# In the IPv6 security policy, configure a rule named aftlocalin6 to allow the device to perform AFT on the IPv6 traffic destined for the IPv4 hosts.
[Device-security-policy-ipv6] rule name aftlocalin6
[Device-security-policy-ipv6-2-aftlocalin6] source-zone trust
[Device-security-policy-ipv6-2-aftlocalin6] destination-zone local
[Device-security-policy-ipv6-2-aftlocalin6] source-ip-subnet 2013:: 32
[Device-security-policy-ipv6-2-aftlocalin6] destination-ip-subnet 2012:: 96
[Device-security-policy-ipv6-2-aftlocalin6] action pass
[Device-security-policy-ipv6-2-aftlocalin6] quit
# In the IPv4 security policy, configure a rule named aftlocalout4 to allow the device to forward the AFT-translated packets to the IPv4 hosts.
[Device-security-policy-ip] rule 2 name aftlocalout4
[Device-security-policy-ip-2-aftlocalout4] source-zone local
[Device-security-policy-ip-2-aftlocalout4] destination-zone trust
[Device-security-policy-ip-2-aftlocalout4] source-ip-subnet 20.1.1.0 24
[Device-security-policy-ip-2-aftlocalout4] destination-ip-subnet 10.1.1.0 24
[Device-security-policy-ip-2-aftlocalout4] action pass
[Device-security-policy-ip-2-aftlocalout4] quit
6.     Configure AFT settings:
# Configure IPv4 ACL 2000 to permits all IPv4 packets to pass through.
[Device] acl basic 2000
[Device-acl-ipv4-basic-2000] rule permit
# Configure the device to use NAT64 prefix 2012:: 96 to translate source addresses of IPv4 packets. The device also uses the prefix to translate destination addresses of IPv6 packets.
# Configure the device to use IVI prefix 2013:: to translate source addresses of IPv6 packets.
[Device] aft prefix-ivi 2013::
# Configure the device to use IVI prefix 2013:: to translate destination addresses of packets permitted by IPv4 ACL 2000.
[Device] aft v4tov6 destination acl number 2000 prefix-ivi 2013::
# Enable AFT on the interfaces connected to the IPv4 and IPv6 networks, respectively.
# Verify the connectivity between IPv6 hosts and IPv4 hosts. This example pings IPv4 host A from IPv6 host A.
D:\>ping 2012::a01:0101
Pinging 2012::a01:0101 with 32 bytes of data:
Reply from 2012::a01:0101: time=3ms
# Display information about IPv6 AFT sessions on the device.
Initiator:
  Source      IP/port: 2013:0:FF14:0101:0100::/0
  Destination IP/port: 2012::0a01:0101/32768
Responder:
  Source      IP/port: 2012::0a01:0101/0
  Destination IP/port: 2013:0:FF14:0101:0100::/33024
State: ICMPV6_REPLY
Application: ICMP
Rule ID: -/-/-
Rule name:
# Display information about IPv4 AFT sessions on the device.
Initiator:
  Destination IP/port: 10.1.1.1/2048
  Protocol: ICMP(1)
Responder:
  Destination IP/port: 20.1.1.1/0
  Protocol: ICMP(1)
State: ICMP_REPLY
Application: ICMP
Rule ID: 2
Rule name: aftlocalout4
As shown in Figure 10, a company deploys an IPv4 network, and the Internet migrates to IPv6.
To allow IPv4 hosts to access the IPv6 server in the IPv6 Internet, configure the following AFT policies on the device:
·     Configure an IPv4-to-IPv6 source address dynamic translation policy.
·     Configure an IPv6-to-IPv4 source address static mapping for the IPv6 server.
Figure 10 Network diagram
[Device-GigabitEthernet1/0/1] ip address 10.1.1.3 24
This example configures a static route with next hop address 2014::100.
[Device] ipv6 route-static 2013:0:ff14:0101:100:: 64 2014::100
# In the IPv4 security policy, configure a rule named aftlocalin to allow the device to perform AFT on the IPv4 host traffic destined for the IPv6 server.
[Device-security-policy-ip-1-aftlocalin] source-zone trust
[Device-security-policy-ip-1-aftlocalin] source-ip-subnet 10.1.1.0 24
[Device-security-policy-ip-1-aftlocalin] destination-ip-host 20.1.1.1
[Device-security-policy-ipv6-1-aftlocalout] destination-zone untrust
[Device-security-policy-ipv6-1-aftlocalout] destination-ip-host 2013:0:ff14:0101:100::1
# Configure IPv4 ACL 2000 to permit IPv4 packets only from subnet 10.1.1.0/24 to pass through.
[Device-acl-ipv4-basic-2000] rule permit source 10.1.1.0 0.0.0.255
[Device-acl-ipv4-basic-2000] rule deny
# Configure NAT64 prefix 2012:: 96.
# Configure the device to use NAT64 prefix 2012:: 96 to translate source addresses of packets permitted by IPv4 ACL 2000.
[Device] aft v4tov6 source acl number 2000 prefix-nat64 2012:: 96
# Map source IPv6 address 2013:0:ff14:0101:100:: to source IPv4 address 20.1.1.1.
[Device] aft v6tov4 source 2013:0:ff14:0101:100::1 20.1.1.1
# Verify the connectivity between the IPv4 hosts and the IPv6 server. This example uses the ping utility on an IPv4 host.
D:\>ping 20.1.1.1
Pinging 20.1.1.1 with 32 bytes of data:
Reply from 20.1.1.1: bytes=32 time=14ms TTL=63
Reply from 20.1.1.1: bytes=32 time=1ms TTL=63
Initiator:
  Protocol: ICMP(1)
Responder:
  Protocol: ICMP(1)
State: ICMP_REPLY
Application: ICMP
Rule ID: -/-/-
Rule name:
Initiator:
  Source      IP/port: 2012::0A01:0101/0
  Destination IP/port: 2013:0:FF14:0101:0100::/32768
Responder:
  Destination IP/port: 2012::0A01:0101/33024
State: ICMPV6_REPLY
Application: ICMP
Rule ID: 0
As shown in Figure 11, a company deploys an IPv4 network, and it has an IPv6 address 2012::1. The Internet migrates to IPv6.
To allow the IPv4 FTP server to provide FTP services to IPv6 hosts, configure the following AFT policies on the device:
·     Configure an IPv4-to-IPv6 source address static mapping for the IPv4 FTP server. The device uses the mapping to translate the destination IPv6 address of IPv6-initiated addresses to the IPv4 address.
·     Configure an IPv6-to-IPv4 source address dynamic translation policy. The device translates source IPv6 addresses of IPv6-initiated packets to source IPv4 addresses 30.1.1.1 and 30.1.1.2.
Figure 11 Network diagram
[Device-GigabitEthernet1/0/1] ip address 10.1.1.4 24
# In the IPv6 security policy, configure a rule named aftlocalin to allow the device to perform AFT on the IPv6 host traffic destined for the IPv4 server.
[Device-security-policy-ipv6-1-aftlocalin] source-zone untrust
[Device-security-policy-ipv6-1-aftlocalin] destination-ip-host 2012::1
# In the IPv4 security policy, configure a rule named aftlocalout to allow the device to forward the AFT-translated packets to the IPv4 server.
[Device-security-policy-ip-1-aftlocalout] destination-zone trust
[Device-security-policy-ip-1-aftlocalout] source-ip-host 30.1.1.1
[Device-security-policy-ip-1-aftlocalout] source-ip-host 30.1.1.2
# Map source IPv4 address 20.1.1.1 to source IPv6 address 2012::1.
[Device] aft v4tov6 source 20.1.1.1 2012::1
# Configure address group 0, and add the address range from 30.1.1.1 to 30.1.1.2 to the group.
[Device-aft-address-group-0] address 30.1.1.1 30.1.1.2
# Configure IPv6 ACL 2000 to permit all IPv6 packets to pass through.
# Configure the device to translate source addresses of IPv6 packets permitted by IPv6 ACL 2000 to IPv4 addresses in address group 0.
# Enable AFT on the interfaces connected to the IPv6 Internet and IPv4 network, respectively.
# Verify the connectivity between the IPv6 hosts and the IPv4 FTP server. For example, ping the IPv4 FTP server from IPv6 host A.
D:\>ping 2012::1
Pinging 2012::1 with 32 bytes of data:
Reply from 2012::1: time=3ms
Initiator:
  Source      IP/port: 2013:0:FF0A:0101:0100::/1029
  Destination IP/port: 2012::1/21
Responder:
  Source      IP/port: 2012::1/21
  Destination IP/port: 2013:0:FF0A:0101:0100::/1029
State: ICMPV6_REPLY
Application: ICMP
Rule ID: -/-/-
Rule name:
Initiator:
  Source      IP/port: 30.1.1.1/11025
  Destination IP/port: 20.1.1.1/21
  Protocol: ICMP(1)
Responder:
  Source      IP/port: 20.1.1.1/21
  Destination IP/port: 30.1.1.1/11025
  Protocol: ICMP(1)
State: ICMP_REPLY
Application: ICMP
Rule ID: 0
