13-Layer 3—IP Services Command Reference
HomeSupportSecurityH3C SecPath F100-C-A FirewallReference GuidesCommand ReferencesH3C SecPath F100[F1000] Firewalls Series Command Reference(V7)-6W90013-Layer 3—IP Services Command Reference
12-Adjacency table commands
12-Adjacency table commands 139.88 KB
IPv4 adjacency table commands
display adjacent-table
Use display adjacent-table to display IPv4 adjacency entries.
display adjacent-table { all | physical-interface interface-type interface-number | routing-interface interface-type interface-number | slot slot-number } [ count | verbose ]
View
context-admin
context-operator
all: Displays all IPv4 adjacency entries.
physical-interface interface-type interface-number: Displays IPv4 adjacency entries about the specified physical interface.
routing-interface interface-type interface-number: Displays IPv4 adjacency entries about the specified routing interface.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv4 adjacency entries for all member devices.
count: Displays the number of IPv4 adjacency entries.
verbose: Displays detailed information about IPv4 adjacency entries.
# Display detailed information about all IPv4 adjacency entries.
<Sysname> display adjacent-table all verbose
   IP address                        : 0.0.0.0
   Routing interface                : Tunnel1
   Physical interface               : Tunnel1
   Logical interface                : N/A
   Service type                      : Tunnel
   Action type                       : Forwarding
   Link media type                  : P2P
   Slot                               : 0
   Cpu                                : 0
   VPN index                         : 0
   Virtual circuit information   : N/A
   Link head information(IP)      : 4500000000000000ff2f000002020201020202020000
                                   0800
   Link head information(MPLS)   : 4500000000000000ff2f000002020201020202020000
                                   0800
# Display IPv4 adjacency entries for the specified slot.
<Sysname> display adjacent-table slot 1
IP address        Routing interface         Physical interface      Type
0.0.0.0           Tun1                         Tun1                       Tunnel
# Display the number of IPv4 adjacency entries for the specified slot.
<Sysname> display adjacent-table slot 1 count
 Total entries on slot 1: 1
IP address
IP address of the next hop.
·     For a P2P link, the IP address of the next hop is not needed. This field displays 0.0.0.0.
·     For an NBMA link, the value 0.0.0.0 indicates the default adjacency entry. Packets are forwarded through the default virtual circuit.
Routing interface
Output interface of the matching route entry.
Physical interface
Physical interface of which the outgoing packets are sent out.
Logical interface
Logical interface for sending the packets. If the entry has no logical interface, this field displays N/A.
Service type/Type
Link layer protocol type.
Action type
Packet processing type, Forwarding or Drop.
Link media type
Link media type:
·     P2P—Point-to-point link.
·     NBMA—Non-broadcast multi-access link.
Cpu
Number of the CPU.
VPN index
Index of the VPN.
Information about the virtual circuit, such as PVC or DLCI. If the entry has no virtual circuit, this field displays N/A.
Link layer header for IPv4.
Link layer header for MPLS.
display adjacent-table log
Use display adjacent-table log to display brief log information for the IPv4 adjacency table.
display adjacent-table log [ interface interface-type interface-number | ip ip-address ] [ slot slot-number ]
View
context-admin
context-operator
interface: Displays brief log information for the specified interface.
ip: Displays brief log information for the specified IP address.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays brief log information on the master device.
# Display brief log information for the IPv4 adjacency table.
<Sysname> display adjacent-table log
Operate  : ADD                 Reason   : ADDBYMSG
Mac      : 0000-0000-0000    Interface: GE2/0/1
SVLAN    : 65535               IP        : 1.1.1.2
CVLAN    : 65535               Time      : Oct 28 22:22:02 2022
SVLAN    : 65535               IP        : 1.1.1.1
Operate
Adjacency entry operation type.
·     ADD—Add an entry to the table.
·     MOD—Modify an existing entry in the table.
·     DEL—Delete an entry from the table.
Reason
Source of the adjacency log entry.
·     M-LAGMSG—Added in response to an ARP entry update message from the M-LAG module.
·     STATICFIX—Added in response to conversion of a dynamic ARP entry to a static one.
·     PKTLEARN—Added by learning from an ARP packet.
·     STATICMSG—Added through static configuration.
·     ADDBYRULE—Added by the IPoE or portal feature.
·     ADDBYMSG—Added through ARP entry synchronization.
·     ADDWADJ—Added in response to an IPv4 adjacency entry refresh message sent by the WAN link adjacency table module.
·     ADDWADJSYN—Added in response to an inter-card IPv4 adjacency entry synchronization message sent by the WAN link adjacency table module.
·     DRVRELOAD—Added in response to the ARP entry update operation done in the hardware.
·     STATICEVENT—Added through ARP entry update in response to a long static entry event.
·     SYNCWITHDRV—Added in synchronization with the hardware.
·     RELOADBYPW—Added in response to the PW reload operation.
·     RELOADBYMMAC—Added through ARP entry refresh triggered by the MultiMac module.
·     RELOADBYRB—Added through ARP entry refresh triggered by the RB module.
·     DELBYCFG—Manually deleted.
·     DELBYIPVRF—Deleted in bulk.
·     DELBYVSRP—Deleted by VSRP.
·     DELBYNODUMMY—Deleted due to lack of a DUMMY entry.
·     DELBYSMOOTH—Deleted upon ARP entry smoothing.
·     DELBYSMOOTHFILTER—Deleted through filtering in an ARP entry smooth operation.
·     DELCONFIGIPIF—Deleted upon an IPv6 address, interface IP, or interface conflict.
·     DELARPSYN—Deleted upon an inter-card ARP entry synchronization.
·     DELWADJMSG—Deleted upon deletion of the corresponding IPv4 adjacency entry from the WAN link adjacency table.
·     DELWADJIFMSG—Deleted by interface upon deletion of the corresponding IPv4 adjacency entry from the WAN link adjacency table.
·     DELWADJBI—Deleted upon reception of the entry deletion message sent from the WAN link adjacency table module to the link layer in the kernel.
·     DELWADJDUMMY—Deleted upon deletion of the corresponding DUMMY entry by the WAN link adjacency table module.
·     DELWADJIFEVENT—Deleted upon deletion of the corresponding IPv4 adjacency entry done by the WAN link adjacency table module in response to an interface event.
·     DELWADJALL—Deleted upon deletion of all IPv4 adjacency entries from the WAN link adjacency table.
·     DELWADJ—Deleted upon deletion of the corresponding IPv4 adjacency entry from the WAN link adjacency table.
·     DELWADJSAGE—Deleted upon deletion of the corresponding IPv4 adjacency entry that had aged out from the WAN link adjacency table.
·     DELWADJIFSYN—Deleted upon deletion of the corresponding IPv4 adjacency entry from the WAN link adjacency table in response to interface entry synchronization.
·     DELWADJSYNMSG—Deleted upon deletion of the corresponding IPv4 adjacency entry from the WAN link adjacency table in response to inter-card entry synchronization.
·     DELWADJSMOOTH—Deleted upon deletion of the corresponding IPv4 adjacency entry because of entry smoothing done by the WAN link adjacency table module.
·     DELWADJPULLFINISH—Deleted upon deletion of the corresponding IPv4 adjacency entry after the WAN link adjacency table module successfully obtained entries in bulk.
·     DELPORTLVLAN—Deleted upon removal of the port from the VLAN.
·     DELVLANMODCHG—Deleted upon VLAN mode change.
·     DELLIMIT—Deleted because the number of ARP entries has reached the limit.
·     DELARPBYOPIF—Deleted upon deletion of the interface.
·     DELARPVLANEVENT—Deleted upon a VLAN event.
·     DELARPSTATUS—Deleted upon ARP entry status change.
·     DELARPBYIPIF—Deleted by specifying the IPv4 address, interface IP, or interface.
·     DELARPBYIFMAP—Deleted upon an interface mapping operation.
·     DELARPBYIFDOWN—Deleted because the interface went down.
·     DELARPBYIFAGG—Deleted because the interface was added to a link aggregation group.
·     DELARPBYNODE—Deleted upon deletion of ARP entries by slot.
·     DELARPBYALL—Deleted upon deletion of all ARP entries.
·     DELARPBYALLEM—Deleted upon deletion of all ARP entries from non-management interfaces.
·     DELARPBYPW—Deleted upon deletion of ARP entries from a PW.
·     DELARPBYPWVSI—Deleted upon deletion of ARP entries done by PWVSI.
·     DELARPBYMACNOTIFY—Deleted upon reception of ARP entries from MAC.
·     DELARPBYRB—Deleted upon an RB action.
·     DELARPBYTCPKEEP—Deleted because of the topology change notification (TCN) flag.
·     DELARPBYSTATICFIX—Deleted upon conversion of a dynamic entry to a static entry.
·     DELBYPULLFINISH—Deleted upon a successful batch data pull.
·     DELSTATICCONFLICT—Deleted upon a static configuration conflict.
IP
·     For an NBMA link, value 0.0.0.0 represents the default adjacency entry. Packets are forwarded through the default virtual circuit.
Mac
MAC address of the next hop.
Output interface of the next hop.
SVLAN
Service VLAN.
CVLAN
Customer VLAN.
Time
Time when the log was generated.
IPv6 adjacency table commands
display ipv6 adjacent-table
Use display ipv6 adjacent-table to display IPv6 adjacency entries.
display ipv6 adjacent-table { all | physical-interface interface-type interface-number | routing-interface interface-type interface-number | slot slot-number } [ count | verbose ]
context-admin
context-operator
all: Displays all IPv6 adjacency entries.
physical-interface interface-type interface-number: Displays IPv6 adjacency entries about the specified physical interface.
routing-interface interface-type interface-number: Displays IPv6 adjacency entries about the specified routing interface.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 adjacency entries for all member devices.
count: Displays the number of IPv6 adjacency entries.
verbose: Displays detailed information about IPv6 adjacency entries.
# Display detailed information about all IPv6 adjacency entries.
<Sysname> display ipv6 adjacent-table all verbose
   IPv6 address                    : N/A
   Slot                              : 1
   Cpu                                : 0
   VPN index                         : 0
   Link head information(IPv6)   : 4500000000000000ff2f000002020201020202020000
                                   86dd
                                   86dd
# Display IPv6 adjacency entries for the specified slot.
<Sysname> display ipv6 adjacent-table slot 1
IPv6 address          Routing interface     Physical interface    Type
N/A                     Tun1                     Tun1                    Tunnel
# Display the number of IPv6 adjacency entries for the specified slot.
<Sysname> display ipv6 adjacent-table slot 1 count
IPv6 address
IPv6 address of the next hop.
·     For a P2P link, the IPv6 address of the next hop is not needed. This field has the value 0::0, and displays N/A.
·     For an NBMA link, the value 0.0.0.0 indicates a default adjacency table. Packets are forwarded through the default virtual circuit.
Routing interface
Physical interface
Logical interface
Logical interface that sends the packets. If the entry has no logical interface, this field displays N/A.
Service type/Type
Action type
Link media type
Link media type:
Cpu
Number of the CPU.
VPN index
Index of the VPN.
Link layer header for IPv6.
display ipv6 adjacent-table log
Use display ipv6 adjacent-table log to display brief log information for the IPv6 adjacency table.
isplay ipv6 adjacent-table log [ interface interface-type interface-number | ip ip-address ] [ slot slot-number ]
View
context-admin
context-operator
# Display brief log information for the IPv6 adjacency table.
[Sysname] probe
[System-probe] display ipv6 adjacent-table log
SVLAN    : 65535               IP        : 1::2
SVLAN    : 65535               IP        : 1::1
Operate
Reason
·     MLAGMSG—Added in response to an ND entry update message from the M-LAG module.
·     PKTLEARN—Added by learning from an IPv6 packet.
·     ADDBYMSG—Added through ND entry synchronization.
·     ADDWADJ—Added in response to an IPv6 adjacency entry refresh message sent by the WAN link adjacency table module.
·     ADDWADJSYN—Added in response to an inter-card IPv6 adjacency entry synchronization message sent by the WAN link adjacency table module.
·     DRVRELOAD—Added in response to the ND update operation done in the driver.
·     ADDBYVSRP—Added through ND entry adding on the VSRP module.
·     STATICEVENT—Added through ND entry update in response to a long static entry event.
·     SYNCWITHDRV—Added in synchronization with the driver.
·     DELBYLINKLOCAL—Added because an unassociated link-local address was removed from the driver and the corresponding ND entry was deleted.
·     DELBYVSRP—Added through ND entry deletion by VSRP.
·     DELBYNODUMMY—Added because an ND entry without a DUMMY entry was deleted.
·     DELBYSMOOTH—Added because ND entries were deleted upon ND entry smoothing.
·     DELBYRULE—Added because of ND entry deletion through the IPoE or portal feature.
·     DELBYSTATIC—Added because of ND entry deletion through static configuration.
·     DELBYBEFORESMOOTH—Added because invalid ND entries were deleted before smoothing.
·     DELCONFIGIPIF—Added because ND entries were deleted upon an IPv6 address or interface conflict.
·     DELNDSYN—Added because ND entries were deleted upon an inter-card ND entry synchronization.
·     DELWADJMSG—Added because an IPv6 adjacency entry was deleted from the WAN link adjacency table.
·     DELWADJIFMSG—Added because IPv6 adjacency entries were deleted from the WAN link adjacency table by interface.
·     DELWADJBI—Added because IPv6 adjacency entries were deleted upon reception of the entry deletion message sent from the WAN link adjacency table module to the link layer in the kernel.
·     DELWADJDUMMY—Added because DUMMY entries were deleted by the WAN link adjacency table module.
·     DELWADJIFEVENT—Added because IPv6 adjacency entries were deleted by the WAN link adjacency table module in response to an interface event.
·     DELWADJALL—Added because all IPv6 adjacency entries were deleted from the WAN link adjacency table.
·     DELWADJ—Added because an IPv6 adjacency entry was deleted from the WAN link adjacency table.
·     DELWADJSAGE—Added because IPv6 adjacency entries that aged out were deleted from the WAN link adjacency table.
·     DELWADJIFSYN—Added because IPv6 adjacency entries were deleted from the WAN link adjacency table in response to interface entry synchronization.
·     DELWADJSYNMSG—Added because IPv6 adjacency entries were deleted from the WAN link adjacency table in response to inter-card entry synchronization.
·     DELWADJSMOOTH—Added because IPv6 adjacency entries were deleted upon entry smoothing done by the WAN link adjacency table module.
·     DELWADJPULLFINISH—Added because IPv6 adjacency entries were deleted after the WAN link adjacency table module successfully obtained entries in bulk.
·     DELPORTLVLANAdded because ND entries were deleted upon removal of the port from the VLAN.
·     DELVLANMODCHG—Added because ND entries were deleted upon VLAN mode change.
·     DELLIMIT—Added because ND entries were deleted when the number of ND entries had reached the limit.
·     DELNDBYIPIF—Added because ND entries were deleted from the specified IPv6 address or interface.
·     DELNDBYIFAGG—Added because ND entries were deleted after the interface was added to a link aggregation group.
·     DELNDBYNODE—Added upon deletion of ND entries by slot.
·     DELNDBYALL—Added upon deletion of all ND entries.
·     DELNDBYALLEM—Added upon deletion of all ND entries from non-management interfaces.
·     DELNDBYPWAdded upon deletion of ND entries from a PW.
·     DELNDBYTCPKEEP—Added upon deletion of ND entries through the topology change notification (TCN) flag.
·     DELBYPULLFINISH—Added because of deletion of ND entries upon a successful batch data pull.
·     DELSTATICCONFLICT—Added because of deletion of ND entries upon a static configuration conflict.
·     DELBYSPANSEG—Added upon deletion of cross-subnet ND entries.
·     DELBYSPANSEGBYIPIF—Added upon deletion of cross-subnet ND entries from the specified IPv6 address or interface.
·     DELINCOMBYALL—Added upon deletion of all ND entries in Incomplete state.
·     DELINCOMBYIF—Added upon deletion of ND entries in Incomplete state from the specified interface.
·     DELINCOMBYNODE—Added upon deletion of ND entries in Incomplete state from the specified card.
·     DELNDBYNETDOWN—Added because ND entries were deleted upon a down event in the network layer.
·     DELNDBYLINKDOWN—Added because ND entries were deleted upon a down event in the link layer.
IP
·     For a P2P link, the IPv6 address of the next hop is not needed. The value for this field is 0::0 and the field displays N/A.
·     For an NBMA link, value 0::0 represents the default adjacency entry. Packets are forwarded through the default virtual circuit.
Mac
SVLAN
Service VLAN.
CVLAN
Customer VLAN.
Time
