13-Layer 3—IP Services Command Reference
HomeSupportSecurityH3C SecPath F100-C-A FirewallReference GuidesCommand ReferencesH3C SecPath F100[F1000] Firewalls Series Command Reference(V7)-6W90013-Layer 3—IP Services Command Reference
11-Multi-CPU packet distribution commands
11-Multi-CPU packet distribution commands 45.55 KB
The following compatibility matrixes show the support of hardware platforms for multi-CPU packet distribution:
F1000 series
Models
Multi-CPU packet distribution compatibility
F1000-X-G5 series
F1000-A-G5, F1000-S-G5
Yes
F1000-C-G5, F1000-C-G5-LI
No
F1000-E-G5, F1000-H-G5
Yes
F1000-X-XI series
F1000-E-X
No
F100 series
Models
F100-X-G5 series
F100-A-G5
Yes
F100-E-G5
No
F100-C-G5, F100-M-G5, F100-S-G5
Yes
F100-C-A series
F100-C-A2, F100-C-A1
No
F100-X-XI series
F100-A-XI
No
F100-C-XI, F100-S-XI
Yes
forwarding policy
Use forwarding policy to specify a multi-CPU packet distribution policy.
Use undo forwarding policy to restore the default.
forwarding policy { per-flow [ three-tuple | mode { source-ip | destination-ip | source-port | destination-port } ] | per-packet }
The device uses the flow-based policy that identifies a flow by source IP address, destination IP address, source port number, destination port number, and protocol number.
context-admin
per-flow: Specifies the flow-based forwarding. The device identifies a data flow by the five-tuple, and forwards packets of the same flow to one CPU. The CPU processes flow packets by following the first-in first-out rule.
three-tuple: Identifies a data flow by the three-tuple (source IP address, destination IP address, and protocol number). If you do not specify this keyword, the device identifies a data flow by the five-tuple.
mode: Specifies a flow-based forwarding mode.
source-ip: Identifies a flow by source IP address.
destination-ip: Identifies a flow by destination IP address.
source-port: Identifies a flow by source port.
destination-port: Identifies a flow by destination port.
per-packet: Specifies the packet-based forwarding. The device forwards packets in sequence to different CPUs, even though they are the same flow. This policy does not ensure packet order.
If you do not specify any keyword for flow identification, the device identifies a flow by source IP address, destination IP address, source port number, destination port number, and protocol number.
# Specify the flow-based policy.
[Sysname] forwarding policy per-flow
