- 04-DPI Command Reference
- 01-DPI engine commands
- 02-IPS commands
- 03-URL filtering commands
- 04-Data filtering commands
- 05-File filtering commands
- 06-Anti-virus commands
- 07-Data analysis center commands
- 08-Proxy policy commands
- 09-WAF commands
- 10-IP reputation commands
- 11-APT defense commands
- 12-Domain reputation commands
- 13-DLP commands
- 14-Network asset scan commands
- 15-Intelligent service platform commands
- 16-DGA detection commands
| 15-Intelligent service platform commands | 51.93 KB |
The following compatibility matrixes show the support of hardware platforms for intelligent service platform:
F1000 series |
Models |
Intelligent service platform compatibility |
F1000-X-G5 series |
F1000-A-G5, F1000-C-G5, F1000-C-G5-LI, F1000-E-G5, F1000-H-G5, F1000-S-G5 |
Yes |
F100 series |
Models |
F100-X-G5 series |
F100-E-G5 |
Yes |
F100-A-G5, F100-C-G5, F100-M-G5, F100-S-G5 |
No |
F100-C-A series |
F100-C-A2, F100-C-A1 |
No |
display intelligent-inspect status
Use display intelligent-inspect status to display the connection status of the intelligent service platform.
# Display the connection status of the intelligent service platform.
<Sysname> display intelligent-inspect status
State: Connected.
State |
Connection status of the intelligent service platform: · Connected—The device is connected to the intelligent service platform. · Disconnected—The device is disconnected from the intelligent service platform. |
intelligent-inspect ip
Use intelligent-inspect ip to assign an IP address to the intelligent service platform.
Use undo intelligent-inspect ip to restore the default.
intelligent-inspect ip ip-address
The intelligent service platform does not have an IP address.
ip-address: Specifies an IP address.
This address acts as the IP address of the internal Ethernet interface. The device communicates with the intelligent service platform through this IP address.
Only IPv4 addresses can be configured for the intelligent service platform.
# Assign IP address 192.22.1.30 to the intelligent service platform.
[Sysname] intelligent-inspect ip 192.22.1.30
enhanced-inspect anti-virus enable
service enable
