- 04-DPI Command Reference
- 01-DPI engine commands
- 02-IPS commands
- 03-URL filtering commands
- 04-Data filtering commands
- 05-File filtering commands
- 06-Anti-virus commands
- 07-Data analysis center commands
- 08-Proxy policy commands
- 09-WAF commands
- 10-IP reputation commands
- 11-APT defense commands
- 12-Domain reputation commands
- 13-DLP commands
- 14-Network asset scan commands
- 15-Intelligent service platform commands
- 16-DGA detection commands
| 00-Preface | 110.64 KB |
Preface
This command reference describes the commands for configuring DPI features, including DPI engine, IPS, URL filtering, data filtering, file filtering, anti-virus, data analysis center, proxy policy, •WAF, APT defense, IP reputation, and domain reputation.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
