- 04-DPI Command Reference
- 01-DPI engine commands
- 02-IPS commands
- 03-URL filtering commands
- 04-Data filtering commands
- 05-File filtering commands
- 06-Anti-virus commands
- 07-Data analysis center commands
- 08-Proxy policy commands
- 09-WAF commands
- 10-IP reputation commands
- 11-APT defense commands
- 12-Domain reputation commands
- 13-DLP commands
- 14-Network asset scan commands
- 15-Intelligent service platform commands
- 16-DGA detection commands
| 14-Network asset scan commands | 102.33 KB |
The following compatibility matrixes show the support of hardware platforms for network asset scan:
F1000 series |
Models |
Network asset scan compatibility |
F1000-X-G5 series |
F1000-A-G5, F1000-C-G5, F1000-C-G5-LI, F1000-E-G5, F1000-H-G5, F1000-S-G5 |
Yes |
F1000-X-XI series |
F1000-E-XI |
Yes |
F100 series |
Models |
F100-X-G5 series |
F100-A-G5, F100-C-G5, F100-E-G5, F100-M-G5, F100-S-G5 |
Yes |
F100-C-A series |
F100-C-A2, F100-C-A1 |
No |
F100-X-XI series |
F100-C-XI, F100-S-XI |
Yes |
F100-A-XI |
No |
Network asset scan configuration commands
asset-scan
Use asset-scan to enter asset scan view.
Use undo asset-scan to delete all configurations in asset scan view.
asset-scan
undo asset-scan
context-admin
# Enter asset scan view.
[Sysname] asset-scan
[Sysname-asset-scan]
auto-scan enable
Use auto-scan enable to enable automatic asset scan.
Use undo auto-scan enable to disable automatic asset scan.
auto-scan enable
Automatic asset scan is disabled.
Asset scan view
context-admin
Use this command to scan and analyze the hosts, servers and devices at the specified IP addresses or in the specified IP address ranges to detect risks such as open ports and weak passwords. You can harden the security configuration of devices according to the scanning results. For example, close ports that do not need to be opened, and enhance the security strength of passwords.
When automatic asset scan is enabled, the device automatically scans the network assets at the specified IP addresses or in the specified IP address ranges according to the network asset scan schedule.
# Enable automatic asset scan.
[Sysname-asset-scan] auto-scan enable
ip
ipv6
schedule every
tcp-port
udp-port
weak-password-scan enable
ip
Use ip to specify a target IPv4 address range for network asset scan.
Use undo ip to delete a target IPv4 address range for network asset scan.
ip { subnet ip-address mask-length | range start-address end-address }
undo ip { subnet ip-address mask-length | range start-address end-address }
No target IPv4 address range for network asset scan exists.
Asset scan view
context-admin
subnet ip-address mask-length: Specifies an IPv4 subnet. The ip-address argument specifies an IPv4 network address. The mask-length argument specifies the subnet mask length, in the range of 1 to 32.
range start-address end-address: Specifies an IPv4 address range. The start-address argument specifies the start IPv4 address. The end-address argument specifies the end IPv4 address. The end address must be higher than the start address. If they are the same, the address range has only one IP address.
A target IPv4 address range is a set of IPv4 addresses. When network asset scan is enabled, the device performs network asset scans on all addresses in the target IPv4 address ranges.
You can specify multiple target IPv4 address ranges. Make sure the address ranges do not overlap.
For network asset scan to take effect, you must specify the target IPv4 or IPv6 address ranges.
# Specify a target IPv4 address range for network asset scan.
[Sysname-asset-scan] ip subnet 192.168.1.1 24
auto-scan enable
ipv6
ipv6
Use ipv6 to specify a target IPv6 address range for network asset scan.
Use undo ipv6 to delete a target IPv6 address range for network asset scan.
ipv6 { subnet ipv6-address prefix-length | range start-address end-address }
undo ipv6 { subnet ipv6-address prefix-length | range start-address end-address }
No target IPv6 address range for network asset scan exists.
Asset scan view
context-admin
subnet ipv6-address prefix-length: Specifies an IPv6 subnet. The ipv6-address argument specifies an IPv6 address prefix. The prefix-length argument specifies the prefix length, in the range of 112 to 128.
range start-address end-address: Specifies an IPv6 address range. The start-address argument specifies the start IPv6 address. The end-address argument specifies the end IPv6 address. The first 112 bits of the start IPv6 address and the end IPv6 address must be the same. The end address must be higher than the start address. If they are the same, the address range has only one IP address.
A target IPv6 address range is a set of IPv6 addresses. When network asset scan is enabled, the device performs network asset scans on all addresses in the target IPv6 address ranges.
You can specify multiple target IPv6 address ranges. Make sure the address ranges do not overlap.
# Specify a target IPv6 address range for network asset scan.
[Sysname-asset-scan] ipv6 subnet 192:168::1:1 120
schedule every
Use schedule every to configure an automatic asset scan schedule.
Use undo schedule every to restore the default.
schedule every { day start-time | hour start-hour | week week-days start-time }
undo schedule every
The device performs automatic asset scans every 12 hours.
Asset scan view
context-admin
day start-time: Performs a scan every day. The start-time argument specifies the scan start time, in the format of HH:MM.
hour start-hour: Performs a scan every specific hours starting from the configuration time. The value range for the start-hour argument is 1 to 12.
week week-days start-time: Performs a scan every week on a specific day and time. The week-days argument specifies the start day of the scan, which can be Mon, Tue, Wed, Thu, Fri, Sat, and Sun. The start-time argument specifies the start time of the scan in the format of HH:MM.
When automatic asset scan is enabled, the device automatically initiates network asset scans to the addresses in the target IP address ranges according to the scan schedule.
# Configure the device to start asset scans at 12:30 every Friday.
[Sysname-asset-scan] schedule every week Fri 12:30
auto-scan enable
ip
ipv6
tcp-port
udp-port
tcp-port
Use tcp-port to configure a target TCP port for network asset scan.
Use undo tcp-port to delete a target TCP port for network asset scan.
tcp-port port-number
undo tcp-port [ port-number ]
The target TCP ports are 23, 80, 139, 443, 445, 554, 631, 3389, 3872, 5800, 7080, 8000, 8080, 8088, 8180 and 8443.
Asset scan view
context-admin
port-number: Specifies a TCP port for network asset scan, in the range of 1 to 65535.
You can configure multiple target TCP ports. When automatic asset scan is enabled, the device scans the target TCP ports.
Executing the undo tcp-port command without specifying the port-number argument deletes all the configured target TCP ports.
If you configure neither target TCP ports nor target UDP ports for network asset scan, the device scans the default target TCP ports and target UDP port. If you configure target ports for network asset scan, the device scans only the configured target ports.
# Configure a target TCP port for network asset scan.
[Sysname-asset-scan] tcp-port 80
auto-scan enable
udp-port
udp-port
Use udp-port to configure a target UDP port for network asset scan.
Use undo udp-port to delete a target UDP port for network asset scan.
udp-port port-number
undo udp-port [ port-number ]
The target UDP port is 137.
Asset scan view
context-admin
port-number: Specifies a UDP port for network asset scan, in the range of 1 to 65535.
You can configure multiple target UDP ports. When automatic asset scan is enabled, the device scans the target UDP ports.
Executing the undo udp-port command without specifying the port-number argument deletes all the configured target UDP ports.
If you configure neither target TCP ports nor target UDP ports for network asset scan, the device scans the default target TCP ports and target UDP ports. If you configure target ports for network asset scan, the device scans only the configured target ports.
# Configure a target UDP port for network asset scan.
[Sysname-asset-scan] udp-port 138
auto-scan enable
tcp-port
Use weak-password-scan enable to enable weak password scan.
Use undo weak-password-scan enable to disable weak password scan.
Weak password scan is disabled.
Asset scan view
context-admin
Use this command to detect the weak password risks of users for the specified services. When automatic asset scan is enabled, the device examines whether the user passwords for the services on the hosts, servers and devices at the specified IP addresses or in the specified IP address range are unsafe. Users can change passwords with higher security according to the scanning results.
This command takes effect only after automatic asset scan is enabled.
# Enable weak password scan.
[Sysname-asset-scan] weak-password-scan enable
auto-scan enable
weak-password-scan mode
weak-password-scan password
weak-password-scan service
weak-password-scan user
Use weak-password-scan mode to specify a weak password scan mode.
Use undo weak-password-scan mode to delete the specified weak password scan mode.
weak-password-scan mode { custom | dict } *
No weak password scan mode is specified.
Asset scan view
context-admin
custom: Specifies the custom mode. The device uses the custom weak password dictionary for scanning.
dict: Specifies the predefined mode. The device uses the predefined weak password dictionary for scanning.
The device performs weak password scan by traversing the weak password dictionary. The passwords in the weak password dictionary are selected in turn in combination with specified usernames to try to log in to various services. If a login is successful, a weak password risk of the user is detected.
The device supports two types of weak password dictionaries:
· Custom weak password dictionary—Weak passwords configured by executing the weak-password-scan password command.
· Predefined weak password dictionary.
If you specify both the custom and dict keywords, the device uses both the custom and predefined weak password dictionaries for scanning.
This command takes effect only after weak password scan is enabled.
# Configure weak password scan to use the custom weak password dictionary for scanning.
[Sysname-asset-scan] weak-password-scan mode custom
auto-scan enable
Use weak-password-scan password to configure a custom weak password.
Use undo weak-password-scan password to a delete custom weak password.
weak-password-scan password password
undo weak-password-scan password [ password ]
No custom weak password is configured.
Asset scan view
context-admin
password: Specifies a custom weak password in plaintext form. The password argument is a case-sensitive string of 1 to 31 characters.
This command can be used to generate a weak password dictionary for weak password scan in the custom mode.
You can configure multiple custom weak passwords.
For weak password scan in custom mode to take effect, you must specify the custom weak passwords.
Executing the undo weak-password-scan password command without specifying the password argument deletes all custom weak passwords.
# Configure a custom weak password as 1234.
[Sysname-asset-scan] weak-password-scan password 1234
auto-scan enable
Use weak-password-scan service to configure a service type for weak password scan.
Use undo weak-password-scan service to restore the default.
weak-password-scan service { ftp | http | mysql | sql-server | ssh } *
No service type for weak password scan is configured.
Asset scan view
context-admin
ftp: Specifies the FTP service.
http: Specifies the HTTP service.
mysql: Specifies the MYSQL service.
sql-server: Specifies the SQL Server service.
ssh: Specifies the SSH service.
When weak password scan is enabled, the device examines whether the passwords of the user for the specified services are unsafe.
Week password scan takes effect only after the service types for weak password scan are configured.
# Configure the service types for weak password scan as FTP, SQL Server, and HTTP.
[Sysname-asset-scan] weak-password-scan service ftp sql-server http
auto-scan enable
Use weak-password-scan user to configure a username for weak password scan.
Use undo weak-password-scan user to delete a username for weak password scan.
weak-password-scan user username
undo weak-password-scan user [ username ]
No username for weak password scan is configured.
Asset scan view
context-admin
username: Specifies a username, a case-sensitive string of 1 to 60 characters.
You can specify multiple usernames for weak password scan.
For weak password scan in custom mode to take effect, you must specify the usernames for weak password scan.
Executing the undo weak-password-scan user command without specifying the username argument deletes all usernames for weak password scan.
# Configure a username for weak password scan as admin.
[Sysname-asset-scan] weak-password-scan user admin
auto-scan enable
