H3C UniServer B5700 G6 Blade Server User Guide-6W100
HomeSupportServersBlade ServerH3C UniServer B16000H3C UniServer B5700 G6Technical DocumentsInstall & UpgradeInstallation GuidesH3C UniServer B5700 G6 Blade Server User Guide-6W100
01-Text
01-Text 2.72 MB
Safety information· 1
General operating safety· 1
Electrical safety· 1
Battery safety· 1
ESD prevention· 2
About the blade server 2
Product overview· 3
Technical parameters· 3
Product specifications· 3
Technical parameters· 4
Components· 5
Front panel 6
Front panel components· 7
LEDs and buttons· 8
SUV cable· 9
Serial asset label pull tab· 9
System board· 10
System board layout 10
DIMM slots· 11
System maintenance switch· 11
PCIe connector 13
HDDs and SSDs· 13
Drive numbering· 13
Drive LEDs· 14
SATA M.2 SSD module· 15
Drive backplane· 16
3SFF drive backplane (1SAS/SATA+2UniBay) 16
Riser cards· 17
RC-LP-B5700G6· 17
RC-LP-SlimSAS-B5700G6· 18
Internal networking· 18
B/D/F information about the server 19
Component installation guidelines· 20
SAS/SATA drive· 20
NVMe drive· 20
NVMe VROC module· 21
Riser card and PCIe card· 21
Storage controller and its power fail safeguard module· 22
Network adapter 24
SATA M.2 SSD module· 25
SATA M.2 SSD adapter module· 25
DIMMs· 25
Processor 29
Guidelines· 29
Installing or removing the blade server 31
Prerequisites· 31
Installing the blade server 31
Removing the blade server 31
Powering on and powering off the blade server 32
Powering on the blade server 32
Supported power-on methods· 32
Prerequisites· 32
Guidelines· 32
Procedure· 33
Powering off the blade server 33
Supported power-off methods· 33
Prerequisites· 34
Guidelines· 34
Configuring the blade server 34
Configuration flowchart 35
Default login parameters· 35
Connecting the blade server to a network· 36
Connecting through the management module· 36
Connecting through ICMs· 37
Verifying the blade server status· 37
Modifying default parameters· 37
Modifying the default user password of OM·· 37
Modifying the default IP address of the OM module· 37
Modifying the default user password of HDM·· 37
Modifying the default IP address of HDM·· 38
Logging into the blade server operating system·· 38
Configuring basic BIOS settings· 38
Setting the server boot order 38
Setting the BIOS passwords· 38
Configuring RAID·· 39
Installing the operating system and hardware drivers· 39
Installing an OS· 39
Installing hardware drivers· 39
Replacing hardware options· 39
Replaceable parts and their videos· 40
Replacing a SAS/SATA drive· 40
Operation scenario· 40
Prerequisites· 41
Removing a SAS/SATA drive· 41
Installing a SAS/SATA drive· 42
Verifying the replacement 42
Replacing an NVMe drive· 42
Operation scenario· 42
Prerequisites· 43
Removing an NVMe drive· 43
Installing an NVMe drive· 44
Verifying the replacement 44
Replacing the riser card and PCIe card· 44
Operation scenario· 44
Prerequisites· 44
Removing the riser card and PCIe card· 45
Installing the riser card and PCIe card· 45
Replacing the storage controller and its power fail safeguard module· 46
Operation scenario· 46
Prerequisites· 46
Removing the storage controller and its power fail safeguard module· 47
Installing a storage controller and a power fail safeguard module· 48
Replacing the straight-through card· 48
Operation scenario· 48
Prerequisites· 48
Removing the straight-through card· 49
Installing the straight-through card· 49
Replacing the network adapter 49
Operation scenario· 50
Prerequisites· 50
Replacing the standard PCIe network adapter 50
Removing a mezzanine network adapter 51
Installing a mezzanine network adapter 51
Replacing a SATA M.2 SSD·· 52
Operation scenario· 52
Prerequisites· 52
Removing a SATA M.2 SSD module· 52
Installing a SATA M.2 SSD module· 53
Replacing a SATA M.2 SSD adapter 53
Operation scenario· 53
Prerequisites· 53
Removing a SATA M.2 SSD adapter 54
Installing a SATA M.2 SSD adapter 54
Replacing the NVMe VROC module· 54
Operation scenario· 54
Prerequisites· 54
Removing the NVMe VROC module· 55
Installing the NVMe VROC module· 55
Replacing the DIMM·· 55
Operation scenario· 56
Prerequisites· 56
Removing a DIMM·· 56
Installing a DIMM·· 56
Verifying the replacement 57
Replacing a processor 57
Operation scenario· 58
Prerequisites· 58
Removing the processor 58
Installing a processor 59
Verifying the replacement 60
Expanding the processor 60
Installing and setting up a TCM or TPM·· 60
Operation scenario· 60
Prerequisites· 61
Installing and setting up a TPM or TCM·· 61
Replacing the system battery· 64
Operation scenario· 64
Prerequisites· 64
Removing the system battery· 65
Installing the system battery· 65
Replacing the system board· 65
Operation scenario· 65
Prerequisites· 66
Removing the system board· 66
Installing the system board· 67
Replacing a drive backplane· 67
Operation scenario· 67
Prerequisites· 67
Removing a drive backplane· 67
Installing a drive backplane· 68
Common operations· 68
Logging in to the blade server operating system·· 68
Local login· 68
Remote login· 70
Accessing the blade server HDM interface· 70
Maintenance· 70
Guidelines· 70
Maintenance tools· 71
Maintenance operation· 71
Task list 71
Observing LED status· 71
Monitoring the temperature and humidity in the equipment room·· 71
Viewing server status· 72
Collecting server logs· 72
Updating firmware for the server 72
Locating faults· 72
Safety information
To avoid bodily injury or damage to the server, read the following information carefully before you operate the server. In practice, the safety information includes but is not limited to what are mentioned in this document.
·     Only H3C-authorized personnel or professional engineers can run the device.
·     Place the device on a clean, stable workbench or floor for servicing.
·     Before running the server, make sure that all cables are correctly connected.
·     To cool the server adequately, follow the guidelines below:
¡     Do not block the ventilation holes on the server.
¡     Filler panels must be installed in idle slots of the server, such as drive slots.
¡     Do not run the server if no chassis cover, air duct, or filler panel for idle slots is installed.
·     Keep the server clean and dust-free, and do not place the device in a wet environment or let liquid flow into the device.
·     Make sure that you move or place the server evenly and slowly.
·     To avoid being burnt, allow the server and its internal modules to cool before touching them.
Electrical safety
To avoid bodily injury or damage to the server, follow these guidelines:
·     Verify whether the operation area has potential risks carefully, such as an ungrounded chassis, unreliable grounding, or wet floor.
·     Make sure that you disable the power supply before you perform actions in power-off state.
·     Power off the server when installing or removing any components that are not hot swappable.
Battery safety
The server's system board contains a system battery, which is designed with a lifespan of 3 to 5 years.
If the BIOS no longer automatically displays the correct date and time, you might need to replace the battery. When you replace the battery, follow these safety guidelines:
·     Do not attempt to recharge the battery.
·     Do not expose the battery to a temperature higher than 60°C (140°F).
·     Do not disassemble, crush, puncture, short external contacts, or dispose of the battery in fire or water.
·     Dispose of the battery at a designated facility. Do not throw the battery away together with other wastes
ESD prevention
Electrostatic charges that build up on people and tools might damage or shorten the lifespan of the system board and electrostatic-sensitive components.
Preventing electrostatic discharge
To prevent electrostatic damage, follow these guidelines:
·     Transport or store the server with the components in antistatic bags.
·     Keep the electrostatic-sensitive components in separate antistatic bags until they arrive at an ESD-protected area.
·     Place the components on a grounded surface before removing them from their antistatic bags.
·     Avoid touching pins, leads, or circuitry.
·     You must take ESD preventions before touching the electrostatic-sensitive components.
Grounding methods to prevent electrostatic discharge
The following are grounding methods that you can use to prevent electrostatic discharge:
·     Wear an ESD wrist strap and make sure it makes good skin contact and is reliably grounded.
·     Take adequate personal grounding measures, including wearing antistatic clothing and static dissipative shoes.
·     Use conductive field service tools.
·     Use a portable field service kit with a folding static-dissipating work mat.
For more safety information, see H3C Indoor Device Operating Environment Requirements.
This manual is a general document for the product. For customized products, the specifications may vary.
In this manual, the models of all components are simplified (for example, the prefix or suffix is deleted). Memory model DDR5-3200-16G-2Rx8-R represents the following models: UN-DDR5-3200-16G-2Rx8-R, UN-DDR5-3200-16G-2Rx8-R-F, and UN-DDR5-3200-16G-2Rx8-R-S.
Figures in this document are for illustration only. The actual product may vary.
Product overview
H3C UniServer B5700 G6 server (hereinafter referred to as the blade server) is an H3C-proprietary blade server with a maximum of two Eagle Stream Sapphire Rapids series processors. The server provides strong computing performance and flexible expansion capability. This blade server is designed for rich configurations and complex deployment scenarios, enabling flexible optimization of core IT applications to reduce TCO. The blade server can be installed in an H3C UniServer B16000 blade chassis (hereinafter referred to as the chassis) and managed through the OM module in a centralized way.
Figure 1 shows the appearance of the blade server.
Figure 1 Appearance of the blade server
This section introduces the product specifications and technical parameters of the blade server.
Table 1 Product Specifications
Feature
Processor
·     Supports 2 Eagle Stream Sapphire Rapids series processors
·     Up to 225 W power consumption per processor
·     Integrated with memory controller that supports 8 memory channels
·     Integrated with a PCIe controller, supporting PCIe 5.0, with a single processor providing 64 PCIe Lanes
·     Uses a 4-way UPI interconnect, each with a transfer rate of up to 16 GT/s
For more information, see the H3C servers compatibility lookup tool at http://www.h3c.com/en/home/qr/default.htm?id=66.
Memory
Up to 16 DDR5 memory slots, with a maximum rate of 4800MT/s
Storage controller
·     Embedded VROC array controller
·     High-performance storage controller
·     NVMe VROC module
Chipset
Intel C741 chipset
Network interface
2 × embedded 1 Gb/s Ethernet interfaces, connected to chassis backplane for interconnection with the active and standby OM modules
I/O port
·     1 × SUV connector (front panel, for SUV cable connection)
·     Supports up to 3 USB ports:
¡     1 × USB 3.0 port (on the front panel)
¡     2 × USB 2.0 ports (expanded by using the SUV cable)
·     1 × VGA port (expanded by using the SUV cable)
·     1 × serial port connector (expanded by using the SUV cable)
Expansion slot
Up to 6 PCIe slots (1 × storage controller slot, 2 × standard PCIe5.0 slot, 3 × Mezz card slots)
Management
Blade chassis integration
Security
Supports TCM/TPM modules
Supports SSH/AAA/attack detection and compliance/SNMP/port mirroring/flow mirroring/sFow
Certification
Environment protection, CE, CB, GS
Table 2 Technical parameters
Category
Item
Physical specifications
Dimensions
·     Height × width: 59.5 × 215 × 613.4 mm
·     Height × width: Half height and half width
·     Maximum number of blade servers in a chassis: 16
Max. weight
8.8 kg (fully equipped)
Power consumption
The power consumption varies by configuration. For more information, see the server power consumption evaluation tool at http://www.h3c.com/en/home/qr/default.htm?id=291.
Environmental specifications
Temperature
Operating temperature: 5°C to 45°C
The maximum operating temperature supported by the server may be reduced under some configurations. For details, see the "Operating temperature requirements".
Storage temperature: –40°C to 70°C
Humidity
·     Operating humidity: 8% to 90% (non-condensing)
·     Storage humidity: 5% to 95% (non-condensing)
Altitude
·     Operating altitude: –60 m to +5000 m. When the altitude is higher than 900 m, the allowed maximum temperature decreases by 0.33°C for every 100 m increased in altitude (HDDs are not supported if the altitude is higher than 3000 m).
·     Storage altitude: –60 m to +5000 m
Components
This section describes components of the blade server.
Figure 2 Components of the blade server
Table 3 Description of blade server components
SN
Name
1
Chassis cover
2
System board
One of the most important parts of a blade server, on which multiple components are installed, such as a processor, memory, and PCIe module. It is integrated with basic server components, including the BIOS chip, BMC chip, and PCIe connectors.
3
System battery
Powers the system clock to ensure a correct system date and time.
4
Mezzanine module
Refers to modules connected by the mezzanine connectors. Mezzanine modules communicate with the processor via the PCIe protocol. One of the mezzanine modules is the mezzanine network adapter, which is used to connect to the interconnect module (ICM) at the rear of the chassis to enable interaction between the blade server and the client.
5
Straight-through card
Connects the embedded VROC array controller soft RAID and SATA drives.
6
processor heatsink
Cools the processor.
7
Memory
Temporarily stores operational data in the processor and data exchanged with external storage devices such as drives. The product supports DDR5 memory modules with up to 4800 MHz frequency.
8
Processor
Integrates the memory controller and PCIe controller to provide powerful data processing capabilities for blade servers.
9
Processor retaining bracket
Attaches a processor to the heatsink.
10
Drive filler panel
Ensures adequate cooling of the blade server. Install a filler panel when no drive is installed on the blade server.
11
Drive backplane
Powers the drive and provides a data transfer channel.
12
Blade server chassis
Centralizes blade server parts and components.
13
Drive
Provides data storage media for blade servers, and supports hot swapping. The product supports SSD and HDD drives and various drive interface types, including SAS, SATA, and M.2.
14
Expands two SATA M.2 SSD modules, and supports hot swapping.
15
Storage controller
Provides RAID support for SAS/SATA drives, and supports RAID expansion, RAID configuration memory, online upgrade and remote setup.
16
Encryption module (TCM/TPM module)
Provides encryption services for servers to improve server data security.
17
Embedded M.2 SSD convert board
Provides slots for expanding two SATA M.2 SSD modules.
18
Supercapacitor
Powers the Flash card integrated or installed on the memory controller in case of unexpected system power failure, to achieve power failure protection for data on the memory controller.
19
Riser card 1
Standard PCIe cards are installed to the blade server through the riser card. Riser card 1 is installed at the node left.
20
Air duct
Provides cooling ducts inside the blade server.
21
Riser card 2
Standard PCIe cards are installed to the blade server through the riser card. Riser card 2 is installed at the node right.
22
NVMe VROC module
Activates the NVMe drive array feature based on the VMD technology.
Front panel
This section introduces the components, LEDs, and interfaces on the front panel.
Figure 3 Front panel of the blade server
Table 4 Description of front panel components
Item
1
Optional riser card 1 (for processor 2)
2
Optional riser card 2 (for processor 1)
3
Optional SAS/SATA drive or NVMe drive
4
Optional SAS/SATA drive or SATA M.2 SSD module (via the adapter module)
5
Pull-out asset label
6
USB 3.0 port
7
Buttons for releasing the locking levers
8
Locking levers
9
SUV connector
USB 3.0 ports can be used to connect the USB flash drive, USB keyboard or mouse, USB optical drive (for OS installation).
LEDs and buttons
Figure 4 Front panel LEDs and buttons
Table 5 Front panel LEDs
SN
Status
1
UID button/LED
·     Steady blue—UID LED is activated. The UID LED can be activated by using the following methods:
¡     Press the UID button LED.
¡     Activate the UID LED from HDM or OM.
·     Flashing blue:
¡     1 Hz—The upgrade is being upgraded or the system is being managed from HDM. Do not power off the server.
¡     4 Hz—HDM is restarting. To restart HDM, press the UID button LED for ten seconds.
·     Off—UID LED is not activated.
2
Health LED
·     Steady green—The system is operating correctly.
·     Flashing green (4 Hz)—HDM is initializing.
·     Flashing amber (0.5 Hz)—A predictive alarm is present.
·     Flashing amber (1 Hz)—A minor alarm is present.
·     Flashing red (1 Hz)—A critical alarm is present.
3
Embedded GE network adapter LED
·     Steady green—A link is present on the port.
·     Flashing green—The port is receiving or sending data.
·     Off—No link is present on the port.
4
Power off/standby button and system power LED
·     Steady green—The system has started.
·     Flashing green (1 Hz)—The system is starting.
·     Steady amber—The system is standby.
·     Off—No power is present.
·     When the Health LED shows that the system is faulty, check the system operating state on HDM.
·     Possible reasons:
¡     No power supplies are present.
¡     The installed power supplies are faulty.
¡     The chassis is not powered.
SUV cable
The SUV cable connects to the SUV connector on the front panel of the blade server. The SUV cable allows for the expansion of two USB 2.0 ports, one serial port and one VGA port for the blade server.
Figure 5 SUV cable
Table 6 SUV cable description
Item
Application
1
Serial port
Diagnoses faults and debugs devices.
2
VGA connector
Connects terminal displays such as monitors or KVM devices
3
2 × USB 2.0 connectors
The extended USB 2.0 connectors and USB 3.0 connector that comes with the default configuration are all available for the following USB devices:
·     USB drives
·     USB keyboards or mouses.
·     USB optical drives for installing operating systems.
The serial label pull tab is on the front panel, as shown in "Front panel components." It provides the following information about the blade server:
·     Product QR code. Users can scan the QR code to access the product document center, and view documents for the blade server.
·     HDM default information.
·     Product serial number.
·     Server model.
System board
System board layout
Figure 6 System board layout
Table 7 Layout description
Item
1
SUV connector
2
XDP connector
3
Storage controller connector
4
Power connector for PCIe riser card 1
5
PCIe connector for riser card 1 (for processor 2)
6
NVMe VROC module connector
7
Power connector for PCIe riser card 2
8
PCIe connector 1 for riser card 2 (for processor 1)
9
PCIe connector 2 for riser card 2 (for processor 1)
10
Mezzanine module connector 2 (for processor 2, ICM 2/5)
11
Mezzanine module connector 3 (slave processor 1, ICM 2/6)
12
Mezzanine module supporting bracket
13
Mezzanine module connector 1 (for processor 1, ICM 1/4)
14
Backplane power connector
15
System battery
16
E1.S drive backplane connector
17
Drive backplane connector
18
TPM/TCM connector
19
USB connector
X
DIMM slots
The DIMM slot layout is shown in Figure 7. A0, B0 ......G0, H0 indicate the DIMM slot number. See "DIMMs" for specific installation guidelines for DIMMs.
Figure 7 DIMM slot layout
The system maintenance switch has 8 pins, as shown in Figure 8.
Figure 8 System maintenance switch
The following problems can be solved with the system maintenance switch. Table 8 describes meanings of the system maintenance switch and "System board layout" shows the layout.
·     Users forget the HDM login user name or password and cannot log in to HDM.
·     Users forget the BIOS password and cannot enter BIOS.
·     Default BIOS settings should be restored.
Table 8 System maintenance switch description
Position
Description (default value: Off)
Remarks
1
l     Off—HDM login requires the username and password of a valid HDM user account.
l     On—HDM login requires the default username and password.
When pin 1 is On, users can permanently log in to HDM with the default username and default password. It is recommended that change pin 1 to Off after completing the operation.
5
l     Off—Normal server startup.
l     On—Restores the default BIOS settings.
When the server is powered off, change pin 5 to On, then to Off again, and finally start the server. The default BIOS settings will be restored.
CAUTION CAUTION:
When pin 5 is changed to On, the server cannot be started. Therefore, stop the running service in advance and make sure the server is powered off. Otherwise it may cause business data loss.
6
l     On—Clears all passwords from the BIOS at server startup.
When pin 6 is On, all passwords will be cleared from the BIOS every time the servers is started. As a best practice, change pin 6 to Off after setting the BIOS password.
2, 3, 4, 7, 8
Reserved
None
PCIe connector
If a processor is absent, the corresponding PCIe devices are not available.
Table 9 Processors to which the PCIe devices correspond
PCIe device
Processor
PCIe standard
PCIe connector physical bandwidth
PCIe connector bus bandwidth
PCIe device form factor
NVMe drive 0
Processor 1
PCIe 5.0
x4
x4
2.5 inches
NVMe drive 1
Processor 2
PCIe 5.0
x4
x4
2.5 inches
PCIe riser card 1
Processor 2
PCIe 5.0
x16
x16
Supports installation of the LP card
PCIe riser card 2
Processor 1
PCIe 5.0
x16
x16
Mezzanine module 1
Processor 1
PCIe 5.0
x16
x16
Non-standard component
Mezzanine module 2
Processor 2
PCIe 5.0
x16
x16
Mezzanine module 3
Processor 1
PCIe 5.0
x16
x16
NVMe drive 0 and NVMe drive 1 represent NVMe drives numbered 0 and 1. For more information about drive numbering, see "Drive numbering."
HDDs and SSDs
Drive numbering
Drive numbering is the physical slot number of the drives. It is used to indicate the location of the drives and is identical to the silkscreen on the front and rear panels of the server.
For the correspondence between the physical number of the drives and the number displayed on the software (HDM, BIOS), see the correspondence table of the slot numbers in Appendix B.
Figure 9 Drive numbering
Drive LEDs
The blade server supports SAS, SATA, and NVMe drives, of which SAS and SATA drives support hot swapping. You can use the LEDs on a drive to identify its status. Figure 10 shows the location of the LEDs on a drive.
Figure 10 Drive LEDs
(1) Drive fault/UID LED
(2) Drive present/active LED
To identify the status of a SAS or SATA drive, use Table 10. To identify the status of an NVMe drive, use Table 11.
Table 10 SAS/SATA drive LED description
Drive fault/UID LED status
Drive present/active LED status
Steady/Flashing (4.0 Hz)
A drive failure is predicted. As a best practice, replace the drive before it fails.
Steady amber
The drive is faulty. Replace the drive immediately.
Steady blue
The drive is operating correctly and is selected by the RAID controller.
Off
Flashing (4.0 Hz)
The drive is performing a RAID migration or rebuilding, or the system is reading or writing data to the drive.
Off
Steady on
The drive is present but no data is being read or written to the drive.
Off
Off
The drive is not securely installed.
NVMe drives support managed hot removal and hot swapping. For information on operating systems that support managed hot removal and hot swapping, contact Technical Support.
Table 11 NVMe drive LED description
Off
The managed hot removal is complete, and you are allowed to remove the drive.
Flashing amber (4 Hz)
Off
The drive is in hot insertion.
Steady amber
Steady blue
Off
Flashing (4.0 Hz)
Off
Steady on
Off
Off
SATA M.2 SSD module
With the SATA M.2 SSD adapter module, the blade server supports up to two SATA M.2 SSD modules. Use the LEDs on the front panel of the SATA M.2 SSD module to identify its status. Table 12 describes the meaning of the LEDs.
Figure 11 SATA M.2 SSD module LEDs
(1): SATA M.2 SSD module fault/UID LED
(2): SATA M.2 SSD module present/active LED
Table 12 SATA M.2 SSD module LED description
Fault/UID LED status
Present/Active LED status
An M.2 SSD module failure is predicted. As a best practice, replace the drive before it fails.
Steady amber
An M.2 SSD module is faulty. Replace the drive immediately.
Steady blue
An M.2 SSD module is operating correctly and is selected by the RAID controller.
Off
Flashing (4.0 Hz)
An M.2 SSD module is performing a RAID migration or rebuilding, or the system is reading or writing data to the drive.
Off
Steady on
An M.2 SSD module drive is present but no data is being read or written to the drive.
Off
Off
An M.2 SSD module drive is not securely installed.
Drive backplane
This section introduces the drive backplanes supported by the server, including components of the backplane, the type and number of drives supported by the backplane.
·     Drive backplanes are classified by the type of drives supported, including the SAS/SATA drive backplane, UniBay drive backplane, and drive backplane (X SAS/SATA + Y UniBay).
¡     SAS/SATA drive backplane: All drive slots support SAS/SATA drives only.
¡     UniBay drive backplane: All drive slots support both SAS/SATA drives and NVMe drives.
¡     Drive backplane (X SAS/SATA+Y UniBay): All drive slots support SAS/SATA drives and some drive slots support NVMe drives.
-     X: Number of slots that support SAS/SATA drives only.
-     Y: Number of slots that support both SAS/SATA drives and NVMe drives.
·     The UniBay drive backplane and drive backplane (X SAS/SATA+Y UniBay) can only support both drive types if both the SAS/SATA data cable and NVMe data cable are connected.
·     The actual number of SAS/SATA drives and NVMe drives supported by the UniBay drive backplane and drive backplane (X SAS/SATA+Y UniBay) is dependent on the cabling scheme.
The 3SFF drive backplane is installed on the front of the chassis and supports up to three 2.5-inch drives, including one SAS/SATA drive and two SAS/SATA/NVMe drives.
Figure 12 3SFF drive backplane
Table 13 3SFF drive backplane component
SN
Silkscreen
1
Data, AUX and power 3-in-1 connector
Riser cards
RC-LP-B5700G6
Figure 13 RC-LP-B5700G6
Table 14 Connectors on the RC-1FHHL-2U-G6 riser card
No.
1
PCIe5.0 x16 (8, 4, 2, 1)
PCIe5.0 x16 (16, 8, 4, 2, 1):
·     PCIe5.0: Fifth-generation signal rate.
·     x16: Connector width.
·     (16, 8, 4, 2, 1): Compatible bus bandwidth, including x16, x8, x4, x2, and x1.
Figure 14 RC-LP-SlimSAS-B5700G6
Figure 15 Connectors on the RC-1FHHL-2U-G6 riser card
No.
1
Power connector
2
MCIO x8 connector
3
MCIO x8 connector
4
Internal networking
The blade server accesses the network through an interconnection module. The interconnection module provides the internal interconnection with blade servers through the infix backplane, and provides uplink interconnection interfaces for blade servers through the panel interfaces. The chassis may contain up to 6 interconnection modules. Among them, the interconnection modules in slots 1 and 4, 2 and 5, and 3 and 6 are interconnected through the internal ports of the chassis to form three pairs. Each pair can be used as a switching plane. You may configure them as active or standby based on service needs.
Internal wiring method of the blade server chassis is shown in Figure 16. Where:
·     The onboard network adapter is connected to the active and standby OM modules.
·     Mezzanine module 1 is connected to interconnect modules in slot 1 and slot 4.
·     Mezzanine module 2 is connected to interconnect modules in slot 2 and slot 5.
·     Mezzanine module 3 is connected to interconnect modules in slot 3 and slot 6.
Figure 16 Internal wiring method of the blade server chassis
The B/D/F information of the server may change with the PCIe card configuration. Users can obtain the B/D/F information of the server through the following ways:
·     BIOS serial port logs: If serial port logs have been collected, users can query the B/D/F information of the server by searching the keyword "dumpiio".
·     UEFI Shell: Users can obtain the B/D/F information of the server by using the pci command. For details on how to use the pci command, use the help pci command.
·     The way to obtain the B/D/F information varies depending on the operating system. The specific ways are as follows:
¡     Linux OS: You can execute the lspci -vvv command to obtain the B/D/F information of the server.
If the operating system does not support the lspci command by default, you can obtain it through the yum source and install the pci-utils package.
¡     Windows OS: After installing the pciutils package, execute the lspci command to obtain the B/D/F information of the server.
¡     VMware OS: The VMware OS supports the lspci command by default. You can obtain the information by executing the lspci command.
SAS/SATA drive
IMPORTANT
IMPORTANT:
·     Using a drive in multiple RAID arrays complicates maintenance and affects RAID performance.
·     As a best practice for HDD drives to be recognized by the system, when you hot swap HDD drives, replace them one by one, and make sure two drives are replaced with an interval of a minimum of 30 seconds.
·     The drives are hot swappable in the following scenarios:
¡     SAS/SATA drives managed by a storage controller support hot swapping only after the device enters the BIOS or operating system.
¡     SATA drives managed by the embedded VROC controller support hot swapping only after the device enters the operating system.
·     As a best practice, install drives that do not contain RAID information.
·     If you are using the drives to create a RAID, follow these restrictions and guidelines:
To avoid degraded RAID performance or RAID creation failures, make sure all drives in the RAID are the same type (HDDs or SSDs) and have the same connector type (SAS or SATA).
·     For efficient use of storage, use drives that have the same capacity to build a RAID. If the drives have different capacities, the lowest capacity is used across all drives in the RAID.
·     As a best practice for SAS/SATA drives to be recognized by the system, when you hot swap SAS/SATA drives, replace them one by one, and make sure two drives are replaced with an interval of a minimum of 30 seconds.
NVMe drive
·     Whether or not NVMe drives support hot swapping and managed hot removal is related to the operating system. You can query the compatibility relationship between the two through the OS compatibility lookup tool at http://www.h3c.com/en/home/qr/default.htm?id=65.
·     As a best practice, all NVMe drives forming a RAID have the same capacity. When the NVMe drive capacities are different, the system regards the capacity of all NVMe drives as the smallest capacity among them. For NVMe drives with a larger capacity, their excess capacity cannot be used to configure the current RAID or other RAIDs.
·     To hot insert NVMe drives, insert the drives steadily without pauses to prevent the operating system from being stuck or restarted.
·     Do not hot swap multiple NVMe drives at the same time. As a best practice, hot swap NVMe drives one after another at intervals longer than 30 seconds for the operating system to identify the installed or removed NVMe drive. If you insert multiple NVMe drives in a short period of time, the system might fail to identify the drives
NVMe VROC module
Table 15 describes the NVMe VROC modules supported by the server and their specifications.
Table 15 NVMe VROC module specifications
Model
Supported RAID level
NVMe-VROC-Key-i
NVMe VROC module Intel edition, supports Intel NVMe drives only.
RAID 0/1/5/10
NVMe-VROC-Key-P
NVMe VROC module advanced edition, supports any brand of NVMe drives.
RAID 0/1/5/10
NVMe-VROC-Key-S
NVMe VROC module standard edition, supports any brand of NVMe drives.
RAID 0/1/10
Compatibility between the riser card and PCIe card
Table 16 PCIe card form factor
Short name
Full name
LP card
Low Profile card
FHHL card
Full Height, Half Length card
FHFL card
Full Height, Full Length card
HHHL card
Half Height, Half Length card
HHFL card
Half Height, Full Length card
Table 17 shows compatibility between riser card and PCIe module.
Table 17 Compatibility between the riser card and PCIe card
Riser card model
Installation location supported by the riser card
PCIe slot or interface description
PCIe device supported by the PCIe connector
Processor
Riser1
PCIe slot for riser card 1
PCIe 5.0 x16 (16, 8, 4, 2, 1)
LP card
Processor 2
Riser2
PCIe slot for riser card 2
LP card
Processor 1
·     For the specific location of the PCIe riser card connector on the system board, see "System board layout."
·     The PCIe connector on the riser card is not available when the processor is not present.
·     Smaller PCIe cards can be inserted into the PCIe connector corresponding to larger PCIe cards. For example, LP cards can be inserted into the PCIe connector corresponding to FHFL cards.
·     PCIe 5.0 x16 (16, 8, 4, 2, 1):
¡     PCIe 5.0: Fifth-generation signal rate.
¡     x16: Connector bandwidth.
¡     (16, 8, 4, 2, 1): Compatible bus bandwidths, including x16, x8, x4, x2 and x1.
Installation guidelines
When a storage controller is installed onto the storage controller connector on the system board, no riser card and PCIe card can be installed on the blade server. For the specific location of the storage controller connector, see "System board layout."
Storage controller
Table 18 shows the front mezzanine storage controller and the onboard VROC array controller supported by the blade server.
Table 18 Storage controller description
Storage controller model
Installation position
Supported drive type
Power fail safeguard module
Installation method
Embedded on the system board, does not need to be installed by users
SATA HDD/SSD
Not supported
Not involved
RAID-LSI-9560-LP-8i-4GB
Storage controller connector for system board
SAS/SATA HDD/SSD
Not supported
Not involved
RAID-P2404-Mf-4i-2GB
SAS/SATA HDD/SSD
Supported, SCAP-PMC-G3 supercapacitor required (Flash embedded in the storage controller)
See "Installing a storage controller and a power fail safeguard module."
RAID-P4408-Mf-8i-2GB
SAS/SATA HDD/SSD
HBA-LSI-9540-LP-8i
SAS/SATA HDD/SSD
Supported, SCAP-LSI-G3-F supercapacitor required (Flash embedded in the storage controller)
Table 19 shows the embedded VROC array controller specifications. For the specifications of other storage controllers, use the server compatibility lookup too at http://www.h3c.com/en/home/qr/default.htm?id=66.
Table 19 Embedded VROC array controller
Model
Item
8 internal SATA ports
Number of internal ports
6 Gbps SATA 3.0
Supports drive hot swapping
Drive interface
PCIe 5.0 x4 bit width
PCIe connector
RAID 0/1/5
Location/Size
Built-in cache memory
N/A
Flash
N/A
Not supported
Battery connector
N/A
Firmware upgrade
Upgrade with the BIOS
Note: If you want to use the embedded VROC array controller, you need to choose a straight-through module that supports up to 4 ports (model: PTH-PT104-Mf-4L).
A power fail safeguard module provides a flash card and a supercapacitor. There are two types of flash cards: One needs to be installed to the storage controller; the other is embedded in the storage controller and does not need to be installed by users.
In the event of an unexpected power failure of the server system, the supercapacitor can power the flash card for more than 20 seconds, during which the cached data is transferred from the DDR memory of the storage controller to the flash card. Since the flash card is a non-volatile storage medium, it enables permanent storage of cached data or until the server system is powered up and the storage controller retrieves such data.
After the supercapacitor is installed, the power may be low. No action is required at this time. The internal circuitry will automatically charge and enable the supercapacitor when the server is powered on. You can query the supercapacitor status through HDM or OM.
Note on the expiration of the supercapacitor:
·     A supercapacitor has a lifespan of 3 to 5 years.
·     If the lifespan of a supercapacitor expires, a supercapacitor exception might occur. The system notifies users of supercapacitor exceptions by using the following methods:
¡     For a PMC storage controller, the status of the flash card becomes Abnormal_status code. You can check the status code to identify the exception. For more information, see H3C Servers HDM Online Help.
¡     For an LSI supercapacitor, the status of the flash card displayed by HDM becomes Abnormal.
¡     HDM will generate SDS log records. For details on how to query the SDS log, see H3C Servers HDM Online Help.
·     When the supercapacitor expires, it needs to be replaced in time. Otherwise, the power fail data safeguard function of the storage controller will fail.
After replacing the expired supercapacitor, check the logical drive cache status of the storage controller. If the logical drive cache of the storage controller is turned off, re-enable the cache related settings to enable the power fail safeguard function. For details, see H3C Servers HDM Online Help.
Network adapter
Standard PCIe network adapter installation guidelines
Due to structural limitations, the standard PCIe network adapter and the storage controller cannot be installed at the same time. The standard PCIe network adapter is connected via the riser card, which is installed on the PCIe riser card connector, and the storage controller is installed on the storage controller connector. For the specific location of both connectors, see "System board layout."
Mezzanine network adapter installation guidelines
·     The blade server supports installing a maximum of three mezzanine network adapters.
·     When installing the mezzanine network adapter, make sure the corresponding processor is present. See "PCIe connector" for the specific relations.
·     The mezzanine network adapter and the interconnect module are interconnected through the chassis backplane. There is a slot correspondence between them. When installing the mezzanine network adapter, ensure that the interconnect module in the corresponding slot is present. See "Internal networking" for the specific relations.
SATA M.2 SSD module
·     A SATA M.2 SSD module must be used together with a SATA M.2 SSD adapter, and the server can install a maximum of two SATA M.2 SSD modules.
·     The SATA M.2 SSD modules are hot swappable.
·     As a best practice, install SATA M.2 SSD modules that do not contain any RAID information.
·     For efficient use of storage, use SATA M.2 SSD modules that have the same capacity to build a RAID. If the SATA M.2 SSD modules have different capacities, the lowest capacity is used across all SATA M.2 SSD modules in the RAID.
The SATA M.2 SSD adapter module supports hot swapping.
DIMMs
The server supports DDR5 memory modules.
About DIMMs
DIMMs include DDR4 and PMem 200 DIMMs. DDR4 DIMMs include LRDIMM and RDIMM.
DDR
The server supports DDR5 RDIMMs and can provide address parity check protection. The data in DDR5 will be lost in the event of an unexpected power failure of the server system.
Rank
The number of ranks is usually 1, 2, 4, or 8, generally abbreviated as 1R/SR, 2R, 4R, 8R, or single-rank, dual-rank, quad-rank, or 8-rank.
·     A 1R DIMM has a set of DIMM chips that will be accessed when data is written to or read from the DIMM.
·     A 2R DIMM is equivalent to a module containing two 1R DIMMs, but only one rank can be accessed at a time.
·     A 4R DIMM is equivalent to a module containing two 2R DIMMs, but only one rank can be accessed at a time.
·     A 8R DIMM is equivalent to a module containing two 4R DIMMs, but only one rank can be accessed at a time.
When writing or reading data in a DIMM, the server memory control subsystem will select the correct rank from the DIMM.
DIMM specifications
DIMM specifications can be identified by the label on it. The memory labels across different DDR generations have similar meanings. This section uses DDR5 memory as an example to explain the significance of each character in the label.
Figure 17 DIMM identification
Table 20 Description of DIMM identification
SN
Definition
1
Capacity
·     8 GB
·     16 GB
·     32 GB
2
Number of ranks
·     1R = The number of ranks is 1.
·     2R = The number of ranks is 2.
·     4R = The number of ranks is 4.
·     8R = The number of ranks is 8.
3
Data width
·     x4 = 4-bit
·     x8 = 8-bit
4
DIMM generation
DDR5
5
DIMM equivalent speed
·     2666V: 2666 MHz
·     2933Y: 2933 MHz
·     3200AA: 3200MHz
·     4800: 4800MHz
6
DIMM type
·     R = RDIMM
·     L = LRDIMM
DIMM mode
The blade server supports the following DIMM modes to protect the data in the DIMM.
Independent Mode is the default mode and is not available on the BIOS interface.
·     Independent Mode (default)
·     Mirror Mode
Independent Mode
Standard ECC can correct 1-bit memory errors and detects multi-bit memory errors. When standard ECC detects multi-bit errors, it informs the server and stops the server. Together with other RAS technologies, independent mode can correct 1-bit or 4-bit memory errors (when the errors are located on the same DDR5 on the DIMM). Independent mode can provide more powerful protection and correct memory errors that cannot be corrected by standard ECC and cause the server to shut down.
Mirror Mode
Mirror mode uses a portion of the system memory for mirroring, to improve system stability and prevent uncorrectable memory errors that cause server downtime. When an uncorrectable error is detected in a memory channel, the blade server will fetch data from the mirrored memory. Mirroring mode supports both full and partial mirroring. In full mirroring, half of the system memory is used as mirrored memory. Partial mirroring allows flexible configuration of mirrored memory capacity.
DIMM installation guidelines
The blade server supports 1 or 2 processors, each processor supports 8 channels, and each channel supports 1 DIMM, that is, one processor supports 8 DIMMs and 2 processors support 16 DIMMs. The server supports only DDR5.
The operating frequency of the DIMM can be up to 4800 MHz only when both of the following conditions are met:
·     Use a processor with a maximum DIMM frequency of 4800 MHz.
·     Use a DIMM with a maximum frequency of 4800 MHz.
DIMM and processor compatibility
Table 21 describes the DIMM and processor compatibility.
Table 21 DIMM and processor compatibility
Processor type
Processor -compatible DIMM type @ frequency
Maximum DIMM capacity supported by a single processor
Sapphire Rapids
DDR5 @4800MHz
6 TB
Montage Jintide C4 series
DDR5 @4800MHz
6 TB
DIMM operating frequency
You can query the DIMM frequency and the maximum DIMM frequency supported by the processor with the server-compatible part query tool. In the query tool, query the DIMM frequency by the part name of "memory module". Query the maximum DIMM frequency supported by the processor by the part name of "processor".
·     The operating frequency of DIMM in the server is equal to the lower of the DIMM frequency or the maximum DIMM frequency supported by the processor. For example, if the DIMM frequency is 2666 MHz and the maximum DIMM frequency supported by the processor is 3200 MHz, then the DIMM will run at 2666 MHz.
Guidelines for installing only DDR5 DIMMs
·     Make sure the corresponding processor is installed.
·     As a best practice, use DDR5 DIMMs of the same specifications (type, capacity, ranks, data width, and rate) on the same server. For DIMM specifications, use the server compatibility lookup tool at http://www.h3c.com/en/home/qr/default.htm?id=66. To expand the memory capacity or replace with DIMMs of different specifications, contact Technical Support.
·     In addition to the above guidelines, different DIMM modes have their own specific guidelines, as described in Table 22. Note that when the actual DIMM installation does not meet these specific guidelines, the system will use the default Independent mode regardless of the DIMM mode configured by the user.
Table 22 Specific installation guidelines for different DIMM modes
Memory mode
DIMM population requirements
·     Strictly follow the DIMM population schemes:
·     If one processor is present, see Figure 18.
·     If two processors are present, see Figure 19 and Figure 20.
Mirror Mode
·     A minimum of two DIMMs for a processor.
·     This mode does not support DIMM population schemes that are not recommended.
¡     If one processor is present, see Figure 18.
¡     If two processors are present, see Figure 19 and Figure 20.
Figure 18 1-processor DIMM configuration guidelines
Figure 19 2-processor DIMM configuration guidelines (1)
Figure 20 2-processor DIMM configuration guidelines (2)
Processor
Guidelines
You can install one or two processors.
·     To avoid damage to a processor or the system board, only H3C authorized or professional server engineers can install, replace, or remove a processor.
·     Make sure the processors on the server are the same model.
·     A processor model is suffixed with U, indicating the CP supports single-socket operation only. Use "Meaning of processor product model suffix" to identify processor model suffixes.
·     Processors of the same model support two types of heatsinks: one with sparse fins and one with dense fins. Heatsinks with sparse fins labeled with Front must be installed on processor 2 and the heatsinks with dense fins labeled with Rear must be installed on processor 1. For more information about the position of processors, see "System board layout."
·     For the server to operate correctly, make sure processor 1 is in position. For more information about processor locations, see "System board layout."
·     The pins in the processor sockets are very fragile and prone to damage. Install a protective cover if a processor socket is empty.
·     To prevent static electricity from damaging the electronic components, wear an ESD wrist strap before operation and ground the other end of the ESD wrist strap.
If the processor model is UN-CPU-INTEL-6448Y, then it is suffixed with "Y" (abbreviated as processor model suffix). For information about processors supported by the server, use the servers compatibility lookup tool at http://www.h3c.com/en/home/qr/default.htm?id=66.
Table 23 describes meaning of the Intel Eagle Stream processor model suffix.
Table 23 Intel Eagle Stream processor model suffix description
Processor model suffix
Suffix meaning
Suffix description
P
Cloud – IaaS
Optimized for the IaaS scenario, applicable to VM applications requiring higher clock speeds
V
Cloud – SaaS
Optimized for the SaaS scenario, applicable to high-density and low-power consumption VM applications
M
Media Transcode
Optimized for the media processing scenario
H
DB and Analytics
Optimized for database and analysis
N
Network/5G/Edge(High TPT/Low Latency)
Supports network/5G/Edge (high throughput/low latency) services
S
Storage & HCI
Supports storage and hyper converged infrastructure
T
Long-life Use/High Tcase
Supports long-life use and high-temperature use
U
1-Socket
Only supports single-processor operating
Q
Liquid cooling
Dedicated for liquid-cooled servers
The list is for reference only. For detailed information, see the official website of Intel.
This section describes the specific steps for installing or removing the blade server.
Take the following ESD prevention measures:
·     Wear antistatic clothing.
·     Do not wear any conductive objects, such as jewelry or watches.
·     Before removing the blade server, make sure you back up the data, stop all services, and power off the server.
·     When you replace a component, examine the slot and connector for damages. Make sure the pins are not damaged (bent for example) and do not contain any foreign objects.
·     You might also remove other components. For the removed components to be reinstalled correctly, record their positions and connections before removal, for example, taking pictures of cable connection and drive installation positions, or labeling cables.
·     For more information about installation principles of blade servers, see the user guide for the server.
1.     Remove the blade server blank. Press the two latches at both sides at the same time and pull the blank out.
2.     Take the half-width blade server out of the antistatic bag.
3.     Press the buttons to release the locking levers at two sides.
4.     Insert the server into the enclosure slowly and horizontally, and then close the locking levers.
1.     Remove the half-width blade server. Press the buttons to release the locking levers at two sides, and pull the server out of the enclosure slowly and horizontally.
2.     Put the server into an antistatic bag.
This section describes how to power on the blade server.
If the server is connected to external storage devices, make sure the server is the first device to power off and then the last device to power on. This restriction prevents the server from mistakenly identifying the external storage devices as faulty devices.
Table 24 describes power-on methods supported by the blade server.
Table 24 Blade server power-on methods
Power-on method
Application scenario
Powering on the blade server together with the enclosure
The blade server is installed and the chassis is not powered on.
Powering on the blade server from the OM Web interface
The chassis is powered on, the blade server is installed but is in a down state. The blade server system power LED is steady amber.
Powering on the blade server by using an OM command
Powering on the blade server through the blade server HDM Web UI.
Before you power on the server, you must complete the following tasks:
·     Install the server and internal components correctly.
·     Connect the server to a power source.
·     As a best practice for the internal components to operate correctly, do not perform the power on action immediately after powering off the server. Wait for over 30 seconds for HDD drives to stop rotation and electronic components to be powered off completely
Guidelines
If the blade server is successfully powered on, the system power LED turns steady green. For more information about the position of the LEDs, see “LEDs and buttons.”
If you want to power on the server together with the enclosure, configure the power-on delay for slots first. After configuration, power on the enclosure, and the blade server is powered on automatically based on previous settings. No extra action is required.
For more information about the power-on delay for slots, see the OM online help.
Access the server management page from the OM Web interface and power on the server. For more information, see the OM online help.
Execute the psu-blade command to power on the server. For more information, see the OM command reference.
Power on the blade server through the blade server HDM Web UI
The blade server can be powered on through the power management function of the blade server HDM Web UI. For the specific operations, see the H3C Servers HDM Online Help.
This section describes how to power off the blade server.
The blade server will be powered off when the chassis is powered off.
Table 25 describes power-off methods supported by the blade server.
Table 25 Blade server power-off methods
Power-off method
Powering off the server from its operating system
Both the chassis and the blade server are powered on and the blade server is working correctly.
Powering off the server from the OM Web interface
Powering off the server by using an OM command
Power off the blade server through the power management function on the blade server HDM Web UI.
Power off the blade server through the power off/standby button on the front panel of the blade server.
Both the chassis and the blade server are powered on, but the blade server is abnormal.
Before powering off the server, you must complete the following tasks:
·     Back up all critical data.
·     Make sure all services have stopped or have been migrated to other servers.
Guidelines
If the blade server is successfully powered off, the system power LED turns steady amber. For more information about the position of the system power LED, see "LEDs and buttons."
Use the SUV cables to connect a monitor, mouse, and keyboard to the blade server, and then shut down the operating system to power off the server.
Access the server management page from the OM Web interface and power off the server. For more information, see OM online help.
Execute the psu-blade command to power off the server. For more information, see the OM online help.
Powering off the server from the HDM Web interface
The blade server can be powered off through the power management function of the blade server HDM Web UI. For the specific operations, see the H3C Servers HDM Online Help.
Powering off the server forcedly by pressing the power off/standby button
This method forces the server to enter standby mode without properly exiting applications and the operating system. Use this method only when the server system crashes. For example, a process gets stuck.
Press and hold the power off/standby button for more than five seconds to power off the server.
The following information describes the procedures to configure the server after the server installation is complete.
Figure 21 Configuration flowchart
The default IP address, default username and password for the chassis OM management interface are listed in Table 26.
Table 26 Default OM parameters
Item
Default value
Username
Admin
Password
Password@_
IP address of the management port
192.168.100.100/24
The default IP address, default username and password for the blade server HDM management port are shown in Table 27.
Table 27 Default HDM parameters
Item
Default value
Username
Admin
Password
Password@_
IP address of the management interface
Obtained from the DHCP server
Use either of the following methods to connect the blade server to the network through the management module:
·     Connect the network cable to one of the four service ports on the management module.
Figure 22 Service ports on the management module
·     The management module provides a management port (MGMT) to which a network cable is connected. Thought this port, you can log in to the chassis OM and the HDM of the blade server to monitor the operating status of the chassis and the blade server and set basic information.
The mezzanine network adapter on each blade server has a corresponding ICM. To connect a blade server to the network through an ICM, make sure the corresponding ICM are present. For more information about mezzanine network adapter and ICM mapping relations, see "Internal networking."
1.     After powering on the server, perform the following tasks to make sure that the server is working correctly. Power on the blade server. For more information, see "Powering on the blade server."
·     Verify that the state of the four LEDs on the front panel of the blade server are as expected. For more information about the LEDs, see "LEDs and buttons."
·     Log in to OM and verify that the firmware versions are as expected. If not, upgrade the firmware. For more information, see the OM online help.
·     Log in to OM and verify that the server is operating correctly. If not, troubleshoot the server.
1.     Log in to OM. For more information, see the OM user guide.
2.     Modify the OM default user password. For more information, see the OM online help
2.     Modify the default IP address of the OM module. For details on how to modify it, see OM Online Help.
You cannot modify HDM password from OM.
To modify the default password of HDM:
1.     Log in to HDM. For more information, see "Accessing the blade server HDM."
2.     Modify the HDM default user password. For more information about the password requirements and password setting method, see H3C Servers HDM Online Help.
Modifying IP through OM
2.     Modify the HDM default IP address. For more information, see the OM online help.
Modifying IP through HDM
2.     Modify the HDM default IP address. For more information, see H3C Servers HDM Online Help
For more information, see "Logging in to the blade server operating system."
The server has a default boot order. Users can modify the boot sequence of the blade server as needed. For the default boot order and the procedure of changing the server boot order, see the BIOS user guide for the server.
BIOS passwords include a boot password as well as an administrator password and a user password for the BIOS setup utility. By default, no passwords are set.
To prevent unauthorized access and changes to the BIOS settings, set both the administrator and user passwords for accessing the BIOS setup utility. Make sure the two passwords are different.
After setting the administrator password and user password for the BIOS setup utility, you must enter the administrator password or user password each time you access the BIOS setup utility.
·     To obtain administrator privileges, enter the administrator password.
·     To obtain the user privileges, enter the user password.
For the difference between the administrator and user privileges and guidelines for setting the BIOS passwords, see the BIOS user guide for the server.
Configuring RAID
Configure physical and logical drives (RAID arrays) for the server.
The supported RAID levels and RAID configuration methods vary by storage controller model. For more information, see the storage controller user guide for the server.
This section introduces how to install the operating system and drivers.
Installing an OS
The blade server is compatible with many types of operating systems such as Windows and Linux. For more information, use the OS compatibility lookup tool at http://www.h3c.com/en/home/qr/default.htm?id=65.
For details on how to install the OS, see the OS installation guide.
For newly installed hardware to operate correctly, the operating system must have the required hardware drivers.
To install a hardware driver, see the operating system installation guide for the server.
To avoid hardware unavailability caused by an update failure, always back up the drivers before you update them.
This section describes replaceable parts of the blade server and the detailed procedures for part replacement.
If you are replacing multiple hardware options, read their replacement procedures and identify similar steps to streamline the entire replacement procedure.
Set out below are the specific method of replacing each part and the replaceable parts of the server:
·     SAS/SATA drive (Replacing a SAS/SATA drive)
·     NVMe drive (Replacing an NVMe drive)
·     Riser card and PCIe card (Replacing the riser card and PCIe card)
·     Storage controller and its power fail safeguard module (Replacing the storage controller and its power fail safeguard module)
·     Straight-through card (Replacing the straight-through card)
·     Network adapter (Replacing the network adapter)
·     SATA M.2 SSD module (Replacing a SATA M.2 SSD)
·     SATA M.2 SSD adapter module (Replacing a SATA M.2 SSD adapter)
·     NVMe VROC module (Replacing the NVMe VROC module)
·     DIMMs (Replacing the DIMM)
·     Processor (Replacing a processor and Expanding the processor)
·     TPM/TCM (Installing and setting up a TCM or TPM)
·     System battery (Replacing the system battery)
·     System board (Replacing the system board)
·     Drive backplane (Replacing a drive backplane)
To configure RAID settings after the drive is replaced, see the storage controller user guide for the server.
Operation scenario
·     The drive fails.
·     Expand the drive.
·     Replace the drive with full space.
·     Replace the drive with another model.
·     The drive hinders maintenance of other parts.
·     Identify the position of the drive to be replaced.
·     To replace a drive that is installed with an operating system and is not configured with a RAID or is in a non-redundancy array, back up data, stop all services, and power off the blade server. For more information, see "Powering off the blade server."
·     Identify the RAID array information of the drive to be replaced. To replace a drive that is not configured with a RAID, back up all data if the old drive is full or the new drive is of a different model
·     Understand the guidelines for installing a SAS/SATA drive: SAS/SATA drive
IMPORTANT
IMPORTANT:
·     SAS/SATA drives managed by a storage controller support hot swapping only after the device enters the BIOS or operating system.
·     SATA drives managed by the embedded VROC controller support hot swapping only after the device enters the operating system.
1.     Remove the drive:
¡     To remove an SSD, press the button on the drive panel to release the locking lever, and then hold the locking lever and pull the drive out of the slot.
¡     To remove an HDD, press the button on the drive panel to release the locking lever. Pull the drive 3 cm (1.18 in) out of the slot. Wait for a minimum of 30 seconds for the drive to stop rotating, and then pull the drive out of the slot.
2.     Remove the drive carrier. Remove the screws that secure the drive and then remove the drive from the carrier.
IMPORTANT
IMPORTANT:
As a best practice, install drives that do not carry RAID information.
1.     (Optional) Please confirm in advance whether the newly installed SAS/SATA drive contains RAID information. If yes, please delete the RAID information.
2.     (Optional) Attach the drive to the drive carrier. Place the drive in the carrier and then use four screws to secure the drive into place.
3.     (Optional) Remove the blank from the drive slot, if any. Pressing the red button on the blank to the right, pull the blank out of the slot.
4.     Install the drive. Press the button on the drive panel to release the locking lever, and then insert the drive into the drive slot.
5.     After the storage controller detects the new SAS/SATA drive, please confirm whether to configure RAID according to the actual situation. For the method of configuring RAID, refer to the storage controller user guide of the product.
Use one of the following methods to verify that the drive has been replaced correctly:
·     Verify the drive properties (including capacity) by using one of the following methods:
¡     Log in to OM. For more information, see the OM online help.
¡     Log in to HDM. For more information, see H3C Servers HDM online help.
¡     Access the BIOS. For more information, see the storage controller user guide for the server.
¡     Access the CLI or GUI of the server.
·     Observe the drive LEDs to verify that the drive is operating correctly. For more information about drive LEDs, see "LEDs and buttons."
Operation scenario
·     The drive fails.
·     Expand the drive.
·     Identify the RAID array information for the drive to be replaced. To replace a drive that is not configured with a RAID, back up all data if the old drive is full or the new drive is of a different model.
·     Understand the guidelines for installing the NVMe drive: NVMe drive.
·     For the operating systems that support NVMe drive hot swapping and managed hot removal, see "NVMe drive."
·     Perform the predictive hot-swap operation. For the specific steps, refer to the online replacement operation guide of NVMe drive.
Removing an NVMe drive
When you remove multiple NVMe drives, remove the drives one after another at intervals of more than five seconds.
1.     Remove the drive. Press the button on the drive panel to release the locking lever, and then pull the drive out of the slot.
2.     Remove the drive carrier, if any. Remove all screws that secure the drive, and then remove the drive from the carrier.
Installing an NVMe drive
1.     Read the installation guidelines.  See "NVMe drive."
2.     Attach the drive to the drive carrier. Place the new drive in the carrier and then use screws to secure the drive into place.
3.     Remove the drive blank from the drive slot, if any. Pressing the red button to the right on the blank, pull the blank out of the slot.
4.     Install the drive. Press the button on the drive panel to release the locking lever, and then insert the drive into the slot.
5.     Clear the RAID information in the newly installed NVMe drive, if any.
6.     Configure the RAID according to the real situation. For more information, see the BIOS users guide.
Use the following methods to verify that the drive is installed correctly:
¡     Log in to HDM. For more information, see H3C Servers HDM Online Help.
¡     Access the BIOS. For more information, see the BIOS user guide for the server.
·     After entering the operating system, check whether the NVMe drive capacity and other information are correct.
Operation scenario
·     The riser card fails.
·     The PCIe card fails.
·     Install another model of riser card.
·     Install another model of PCIe card.
·     Expand the riser card.
·     Expand the PCIe card.
·     The riser card or PCIe card hinders maintenance of other parts.
·     Before replacing, back up data, stop all services, and power off the server. For more information, see "Powering off the blade server."
·     Replace the blade server.
·     For the specific installation guidelines of riser card and PCIe card, see "Riser card and PCIe card."
Removing the riser card and PCIe card
1.     Remove the chassis cover. Press the chassis cover unlock button, slide toward the rear of the blade server, and then lift the cover up.
a.     Press the chassis cover unlock button and slide toward the rear of the server.
b.     Lift the chassis cover up to remove it from the server.
2.     Remove the riser card with PCIe card. Lift the riser card up to remove it from the server chassis.
3.     Remove the PCIe card from the riser card. Press and open the fixing buckle on the riser card, and then lift the PCIe card up to remove it from the riser card.
Installing the riser card and PCIe card
1.     Install the PCIe card to the riser card.
a.     Open the fixing buckle on the riser card. Press the locking button on the fixing buckle and open the fixing buckle.
b.     (Optional) Remove the PCIe card filler panel. Lift the filler panel up and remove it from the riser card.
c.     Install the PCIe card to riser card connector Insert the PCIe card along the PCIe connector on the riser card, and then close the PCIe card fixing buckle.
2.     Install the riser card with the PCIe card in the blade server.
a.     (Optional) Remove the filler panel. Lift the filler panel up.
b.     Install the riser card with the PCIe card in the blade server. Insert the riser card downward as aligning the two mushroom-shaped heads on the riser card with the two notches on the blade server.
3.     Install the chassis cover. Place the chassis cover horizontally downward as aligning the mushroom-shaped head on the chassis cover with the groove on the chassis, and slide the chassis cover toward the front of the server until it is locked.
4.     Install the blade server.
5.     Power on the blade server. For the specific steps, see "Powering on the blade server."
This section describes the detailed operating steps for replacing the storage controller and its power fail safeguard module.
Operation scenario
·     The storage controller fails.
·     Replace the storage controller with another model.
·     The storage controller hinders maintenance of other parts.
·     The power fail safeguard module fails.
·     The power fail safeguard module hinders the maintenance of other parts.
·     Expand the storage controller.
·     Expand the power fail safeguard module
·     Replace the storage controller with one of the same model. Please specify the information about the storage controller and BIOS to be replaced.
¡     The model, operating mode, and firmware version of the storage controller.
¡     Specify the boot mode of BIOS.
¡     Specify the first boot item setting of the storage controller in the Legacy boot mode.
·     To replace the storage controller with another model, back up in advance the data in the drive controlled by the storage controller to be replaced, and clear the RAID configuration information.
·     Identify the position of the SATA M.2 SSD to be replaced.
·     Identify the RAID array information of the SSD to be replaced. To replace an SSD that is not configured with a RAID or is in a non-redundancy RAID array, back up all data.
·     Before replacing, make sure that you stop all services and power off the server. For more information, see "Powering off the blade server."
·     Remove the blade server.
·     To learn about the specific installation guidelines of the storage controller and its power fail safeguard module, see "Storage controller and its power fail safeguard module."
Removing the storage controller and its power fail safeguard module
2.     (Optional) Remove the supercapacitor.
a.     Disconnect the cable between the storage controller and the supercapacitor.
b.     Disconnect the fixing buckle of the supercapacitor outward and take out the supercapacitor from the slot.
3.     Remove the storage controller. Remove the fixing screws from the storage controller, and then lift the storage controller up to remove it from the blade server.
1.     Install the storage controller. Align the three screw holes in the storage controller with the three threaded studs on the system board, insert the storage controller, and use screws to secure the controller.
2.     Install a supercapacitor to the air baffle, if any, and connect the supercapacitor cable to the storage controller.
The accessories delivered with the supercapacitor include a supercapacitor fixing base, an uncoded adapter cable, and an adapter cable with code 0404A0X1. Neither the fixing base nor the uncoded adapter cable will be used. When installing the supercapacitor, fix the supercapacitor directly to the air guide hood of the blade server, and use the adapter cable with code 0404A0X1 to connect the storage controller and the supercapacitor.
a.     Install the supercapacitor onto the air baffle. Tilt the supercapacitor and insert one end of the supercapacitor into the supercapacitor slot, and press the other end into the slot.
b.     Use the 0404A0X1 extension cable to connect the supercapacitor to the storage controller.
4.     Installing the blade server
This section describes the detailed operation steps for replacing the straight-through card.
Operation scenario
·     The straight-through card fails.
·     Expand the straight-through card.
·     The straight-through card hinders maintenance of other parts.
·     Wear an ESD wrist strap and make sure it makes good skin contact and is reliably grounded.
Removing the straight-through card
2.     (Optional) Remove the riser card and PCIe card that prevent users from accessing the straight-through card.
3.     Remove the straight-through card. Remove two screws, hold the middle of the straight-through card, lift the straight-through card horizontally, and then put the straight-through card into an ESD bag.
Installing the straight-through card
1.     Install the straight-through card. Remove the straight-through card to be installed from the ESD bag, and insert it downward by aligning it with the connector on the main board. Then tighten the two screws.
2.     (Optional) Reinstall the removed riser card and PCIe card.
This section describes the detailed steps for replacing the standard PCIe network card and mezzanine network card.
Operation scenario
·     The standard PCIe network card or Mezz network adapter fails.
·     Expand the standard PCIe network adapter or mezzanine network adapter.
·     Replace the standard PCIe network adapter with another model.
·     The standard PCIe network adapter or mezzanine network adapter hinders the maintenance of other parts.
·     For the specific installation guidelines of the standard PCIe network adapter or mezzanine network adapter, see “Network adapter.
Replacing the standard PCIe network adapter
Removing the standard PCIe network adapter
2.     Remove the riser card with a standard PCIe card. Lift the riser card up.
3.     Remove the standard PCIe network adapter from the riser card. Open the fixing buckle while pressing the locking button on the fixing buckle, and then lift up the standard PCIe network adapter to remove it from the riser card.
Installing the standard PCIe network adapter
1.     Install the PCIe network adapter to the riser card.
a.     Open PCIe card fixing buckle. Press the locking button on the PCIe card fixing buckle and open the PCIe card fixing buckle at the same time.
c.     Install PCIe card to riser card connector Insert the PCIe network adapter along the PCIe connector on the riser card, and then close the PCIe card fixing buckle.
2.     Install the riser card with the PCIe network adapter in the blade server.
b.     Install the riser card with the PCIe network adapter in the blade server. Insert the riser card downward as aligning the two mushroom-shaped heads on the riser card with the two notches on the blade server.
5.     Power on the blade server. For more information, see "Powering on the blade server."
Removing a mezzanine network adapter
1.     Remove the access panel. Press the unlock button on the access panel, slide the access panel to the server rear, and lift the panel.
2.     Remove other mezzanine network adapters that might hinder your operation, if any.
3.     Remove the mezzanine network adapter. Loosen the captive screws that secure the adapter, and then lift the adapter out of the chassis.
Installing a mezzanine network adapter
1.     Remove other mezzanine network adapters that might hinder your installation, if any.
2.     Install the mezzanine network adapter. Insert the adapter onto the mezzanine module connector on the system board, and use screws to secure the adapter.
3.     Install other mezzanine modules removed before, if any.
4.     Install the access panel. Align the standouts on the access panel with the notches in the chassis side panels, place the access panel onto the chassis, and slide the panel to the server front until the panel is securely locked.
5.     Installing the blade server
6.     Power on the blade server. For the specific steps, see "Powering on the blade server."
This section describes the detailed steps for replacing the SATA M.2 SSD module.
Operation scenario
·     Expand the SATA M.2 SSD module.
·     The SATA M.2 SSD module fails.
·     The SATA M.2 SSD module hinders maintenance of other parts
·     Replace the SATA M.2 SSD module with full space.
·     Replace the SATA M.2 SSD module with another model.
·     Remove the blade server. For more information, see "Removing the blade server."
·     When you replace a component, examine the slot and connector for damages. Make sure the pins are not damaged (bent for example) and do not contain any foreign objects. You might also remove other components. For the removed components to be reinstalled correctly, record their positions and connections before removal, for example, taking pictures of cable connection and drive installation positions, or labeling cables.
·     Understand the installation of SATA M.2 SSD module, see”SATA M.2 SSD module.”
Removing a SATA M.2 SSD module
Hold a SATA M.2 SSD module by its handle, and pull the module out from the slot.
Installing a SATA M.2 SSD module
1.     Insert the SATA M.2 SSD module into the adapter module.
2.     (Optional.) Power on the blade server. For more information, see "Powering on the blade server.
3.     Configure RAID for the SATA M.2 SSD module. For the specific methods, see the storage controller user guide of the product.
This section describes the detailed steps for replacing the SATA M.2 SSD adapter module.
Operation scenario
·     The SATA M.2 SSD adapter module fails.
·     The SATA M.2 SSD adapter module hinders maintenance of other parts
For the specific installation guidelines of the SATA M.2 SSD adapter module, see "SATA M.2 SSD adapter module."
·     Identify the position of the SATA M.2 SSD adapter module to be replaced.
·     The SATA M.2 SSD adapter module is installed with an operating system. Make sure that you back up service data and stop all services before replacing.
Removing a SATA M.2 SSD adapter
1.     Remove a SATA M.2 SSD adapter. Press to release the handle on the adapter, and hold the handle to pull the adapter out of the slot.
2.     Remove the SATA M.2 SSDs from the adapter. Hold a SATA M.2 SSD by its handle, and pull the SATA M.2 SSD out of the slot. Put the adapter into an antistatic bag.
Installing a SATA M.2 SSD adapter
1.     To learn the specific installation guidelines of the SATA M.2 SSD adapter module, see "SATA M.2 SSD adapter module."
2.     Take the SATA M.2 SSD adapter out of the antistatic bag, and insert the SATA M.2 SSDs into the adapter.
3.     Remove the adapter blank, if any. Pressing the button on the blank to the right, pull the blank out of the chassis.
4.     Insert the adapter into the slot on the server.
5.     (Optional.) Power on the blade server. For more information, see "Powering on the blade server."
6.     (Optional) Configure RAID for the SATA M.2 SSD module. For the specific methods, see the storage controller user guide of the product.
This section describes the detailed steps for replacing the NVMe VROC module.
Operation scenario
·     The NVMe VROC module fails.
·     Replace the NVMe VROC module with another model.
·     Expand the NVMe VROC module.
·     The NVMe VROC module hinders maintenance of other parts.
·     Before replacing, make sure that you back up the data, stop all services, and power off the blade server. For more information, see "Powering off the blade server."
·     Remove the blade server. When you replace a component, examine the slot and connector for damages. Make sure the pins are not damaged (bent for example) and do not contain any foreign objects.
Removing the NVMe VROC module
1.     Remove the access panel. Press the unlock button on the access panel, slide the panel to the server rear, and lift the access panel.
2.     (Optional) Remove the riser card and PCIe card that prevent users from accessing the NVMe VROC module.
3.     Remove the NVMe VROC module. Hold the ring part of the NVMe VROC module and pull the module out.
Installing the NVMe VROC module
1.     Install a new NVMe VROC module. Insert the NVMe VROC module onto the NVMe VROC module connector on the system board.
3.     Install the access panel. Align the standouts on the access panel with the notches in the chassis side panels, place the panel onto the chassis, and slide the panel to the server front until it is secured into place.
6.     (Optional) Configure RAID for the NVMe drive. For the specific methods, see the BIOS user guide of the product.
Replacing the DIMM
This section describes the detailed steps for replacing the DIMM.
Operation scenario
·     The DIMM fails.
·     Replace the DIMM with another model.
·     Expand the DIMM.
·     The DIMM hinders maintenance of other parts.
·     Before replacing the DIMM, remove the blade server.
·     For the specific installation guidelines of the DIMM, see "DIMMs."
Removing a DIMM
The DIMM is not hot swappable.
2.     Remove the air baffle that might hinder you operation.
3.     Open the DIMM slot latches and pull the DIMM out of the slot to remove the DIMM.
Installing a DIMM
1.     Install the DIMM
The DIMM slot is fool-proof. If you encounter any resistance when inserting the DIMM, re-orient the DIMM and try again.
a.     (Optional) If the DIMM is installed for the first time, open the fixing clamps on both sides of the DIMM slot.
b.     Install the DIMM. Align the notch at the bottom of the DIMM with that on the slot, and then insert the DIMM vertically along the slot by exerting uniform force. Now, the fixing clamp will be automatically locked. Make sure that the fixing clamp has locked the DIMM and is engaged tightly.
2.     Install the air baffle.
3.     Install the access panel. Align the standouts on the access panel with the notches in the chassis side panels, place the access panel onto the chassis, and slide the access panel to the server front until it is secured into place.
Verifying the replacement
Use one of the following methods to verify that the DIMM is installed correctly:
·     Using the operating system:
¡     In Windows, select Run in the Start menu, enter msinfo32, and verify the memory capacity of the DIMM.
¡     In Linux, execute the cat /proc/meminfo command to verify the memory capacity.
·     Using OM:
Log in to OM and verify the memory capacity of the DIMM. For more information, see the OM online help.
·     Using HDM:
Log in to HDM and verify the memory capacity of the DIMM. For more information, see H3C Servers HDM Online Help.
·     Using BIOS:
Access the BIOS, select Socket Configuration > Memory Configuration > Memory Topology, and press Enter. Then, verify the memory capacity of the DIMM.
If the memory capacity displayed is inconsistent with the actual capacity, remove and then reinstall the DIMM, or replace the DIMM with a new DIMM.
If the DIMM is in Mirror mode, it is normal that the displayed capacity is smaller than the actual capacity.
This section describes the detailed operation steps for replacing the processor.
Operation scenario
·     The processor fails.
·     Replace the processor with another model.
·     The processor hinders maintenance of other parts.
·     For the specific installation guidelines of processor, see "Processor."
Removing the processor
2.     Remove the air baffle that hinders you operation
3.     Remove the radiator with the processor.
a.     Unscrew the four retaining screws on the radiator in turn.
b.     Pull the four threads on the radiator to unlock it.
4.     Lift the radiator up to remove it from the server.
CAUTION
CAUTION:
The pins in the processor socket are fragile and prone to damage. To avoid damage to the system board, do not touch the pins.
5.     Remove the processor.
a.     Pull up the wrench to make one end of the processor warped.
6.     Hold both sides of the processor to separate it from the clamping piece.
7.     Remove the clamping piece.
a.     Loosen the four corners of the clamping piece. Use hands to force apart one corner of the clamping piece and the fixing spring plate on its diagonal outward, and then force apart the other corner of the clamping piece and the fixing spring plate on its diagonal outward.
b.     Lift the clamping piece up to remove it from the radiator.
8.     Clean up the residual thermal silicone grease. Use an isopropyl alcohol wiping cloth to clean the processor top and the radiator surface to ensure that the surface is clean and tidy.
Installing a processor
1.     Install the clamping piece on the radiator.
a.     Close the wrench on the clamping piece.
2.     Make sure that the wrench on the clamping piece is closed; otherwise the processor may not be installed in place.
3.     Align the corner with the triangle mark on the clamping piece with the corner with a notch on the radiator, place and press down the clamping piece until you hear a clatter, when the four corners of the clamping piece and the four corners of the radiator are tightly buckled.
4.     Apply thermal silicone grease to the radiator. Use a thermal silicone grease syringe to extrude 0.6 ml of thermal silicone grease, and then apply the thermal silicone grease evenly to the surface of the radiator according to the five-spot method.
CAUTION
CAUTION:
Before the operation, make sure that the radiator surface has been cleaned and is free of residual thermal silicone grease.
5.     Install the processor to the clamping piece.
CAUTION
CAUTION:
When taking the processor, hold the edge of the processor carefully without touching the contact on the bottom of the processor, to avoid damaging the processor.
6.     Tilt the processor so that the corner with the triangle mark on the processor is aligned with that with the triangle mark on the clamping piece. Meanwhile, clamp one end of the processor to the buckle at one end of the clamping piece, hold one end of the radiator using two thumbs, and push hard the other side of the processor towards the thumb side and place the processor downward at the same time.
a.     Force apart the buckle around the clamping piece outward until the buckle catches the processor so that the processor can be installed in place.
7.     Install the radiator with the processor and the clamping piece on the server.
CAUTION
CAUTION:
Be sure to paste the barcode label delivered with the processor on the side of the radiator to cover the original barcode label on the radiator; otherwise H3C will be unable to provide subsequent warranty service for the processor.
a.     Align the triangle on the clamping piece with the corner with a notch on the processor base, align the four screw holes on the radiator with the four guide pins on the processor base, and place the radiator on the processor base downward.
b.     Pull the four threads to the locking position to lock the radiator with the processor.
c.     Use a T30 Torx star screwdriver to tighten the four retaining screws on the radiator.
CAUTION
CAUTION:
Adjust the screwdriver torque to 0.9N·m (8in-lbs); otherwise it may cause poor processor contact or damage the pins in the processor base.
8.     Install the removed air baffle.
9.     Install the access panel. Align the standouts on the access panel with the notches in the chassis side panels, place the panel onto the chassis, and slide the panel to the server front until the panel is securely locked.
10.     Install the blade server.
11.     Power on the blade server. For more information, see "Powering on the blade server."
Use one of the following methods to verify that the processor has been replaced correctly:
·     Access the BIOS. For more information, see the BIOS user guide for the server.
·     Log in to OM. For more information, see the OM online help.
·     Log in to HDM. For more information, see H3C Servers HDM Online Help.
For details, see the quick installation guide of processor.
This section introduces the detailed installation steps of the TPM/TCM module and how to enable the TPM/TCM module functions.
Operation scenario
Expand the TPM/TCM module.
·     Before installing, make sure that you back up the data, stop all services, and power off the server. For more information, see "Powering off the blade server."
Installing and setting up a TPM or TCM
·     Trusted platform module (TPM or TCM) is a microchip embedded in the system board. It stores encryption information (such as encryption keys) for authenticating server hardware and software. The TPM operates with drive encryption programs such as Microsoft Windows BitLocker to provide operating system security and data protection. For information about Microsoft Windows BitLocker, visit the Microsoft website at http://www.microsoft.com.
·     Trusted cryptography module (TPM or TCM) is a trusted computing platform-based hardware module with protected storage space, which enables the platform to implement password calculation.
Installation and setup flowchart
Figure 23 TCM/TPM installation and setup flowchart
Installing a TCM or TPM
2.     (Optional) Remove the riser card and PCIe card that prevent you from accessing the TPM/TCM connector.
3.     (Optional) Remove the storage controller that prevents you from accessing the TPM/TCM connector.
4.     Install the TCM or TPM.
a.     Align the TPM/TCM connector on the system board and slowly to firmly insert the TPM/TCM module downward. For the specific location of the TPM/TCM connector, see "System board."
b.     Align the hole on the TPM/TCM module to insert the pin downward.
c.     Insert the security rivet into the hole in the rivet pin and press the security rivet until it is firmly seated.
5.     (Optional) Reinstall the removed riser card and PCIe card.
6.     Install the removed riser cards, if any.
7.     Install the access panel. Align the standouts on the access panel with the notches in the chassis side panels, place the panel onto the chassis, and slide the access panel to the server front until it is secured into place.
8.     Install the blade server.
9.     Power on the blade server. For more information, see "Powering on the blade server."
Enabling the TCM or TPM in the BIOS
1.     Access the BIOS utility. For information about how to enter the BIOS utility, see the BIOS user guide.
2.     Select Advanced > Trusted Computing, and press Enter.
3.     Enable TCM or TPM. By default, the TCM and TPM are enabled for a server.
·     If the server is installed with a TPM, perform the following actions:
a.     Select TPM State > Enabled, and then press Enter.
b.     Select a TPM type. Click Device Select and press Enter. After setting, press F4 to save the configuration. For more information, see the BIOS user guide for the server.
·     If the TPM is installed with a TCM, perform the following actions:
a.     Select TCM State > Enabled, and then press Enter.
b.     Select a TCM type. Click Device Select and press Enter. After setting, press F4 to save the configuration. For more information, see the BIOS user guide for the server.
4.     Log in to HDM to verify that the TCM or TPM is operating correctly. For more information, see HDM online help.
Configuring encryption in the operating system
For more information about this task, see the encryption technology feature documentation that came with the operating system.
The recovery key/password is generated during BitLocker setup, and can be saved and printed after BitLocker is enabled. When using BitLocker, always retain the recovery key/password. The recovery key/password is required to enter Recovery Mode after BitLocker detects a possible compromise of system integrity or firmware or hardware change.
For security purposes, follow these guidelines when retaining the recovery key/password:
·     Always store the recovery key/password in multiple locations.
·     Always store copies of the recovery key/password away from the server.
·     Do not save the recovery key/password on the encrypted hard drive.
For more information about Microsoft Windows BitLocker drive encryption, visit the Microsoft website at http://technet.microsoft.com/en-us/library/cc732774.aspx.
Guidelines
·     Do not remove an installed TCM or TPM. Once installed, the module becomes a permanent part of the system board.
·     When installing or replacing hardware, H3C technicians cannot configure the TCM or TPM or enter the recovery key. For security reasons, only the user can perform the tasks.
·     When replacing the system board, do not remove the TCM or TPM from the system board. H3C will provide a TCM or TPM with a spare system board for the replacement.
·     Any attempt to remove an installed TCM or TPM from the system board breaks or disfigures the TCM or TPM security rivet. Upon locating a broken or disfigured rivet on an installed TCP or TPM, administrators should consider the system compromised and take appropriate measures to ensure the integrity of the system data.
·     H3C is not liable for blocked data access caused by improper use of the TCM or TPM. For more information, see the encryption technology feature documentation provided by the operating system.
·     The user cannot remove the TPM/TCM module without permission; otherwise the fixing rivet of the TPM/TCM module may be destroyed or damaged, leading to system damage.
·     If you want to replace the failed TCM or TPM, remove the system board, and then contact H3C Support to replace the TCM or TPM and the system board.
This section describes the detailed steps for replacing the system battery.
Operation scenario
The server comes with a system battery (BR2032) installed on the system board, which supplies power to the real-time clock and has a lifespan of 3 to 5 years.
If the server no longer automatically displays the correct date and time, you might need to replace the battery. Use the BR2032 battery to replace the old one.
The BIOS will restore to the default settings after the replacement. You must reconfigure the BIOS to have the desired settings, including the system date and time. For more information, see the BIOS user guide for the server.
Removing the system battery
2.     (Optional) Remove the mezzanine network adapter that prevents the user from contacting the system battery.
3.     Remove the system battery. Pinch the system battery by its top edge and the battery will disengage from the battery holder.
For environment protection purposes, dispose of the used-up system battery at a designated site.
Installing the system battery
1.     Install the system battery.
a.     Insert the system battery with the plus sign "+" facing up into the system battery holder.
b.     Press down the battery to secure it into place.
2.     (Optional) If the mezzanine network adapter has been removed, install it.
3.     Install the access panel. Align the standouts on the access panel with the notches in the chassis side panels, place the panel onto the chassis, and slide the access panel to the server front.
6.     Access the BIOS to reconfigure the system date and time. For more information, see the BIOS user guide for the server.
This section describes the detailed steps of replacing the system board.
Operation scenario
The system board fails.
Removing the system board
CAUTION
CAUTION:
·     To prevent electrostatic discharge, place the removed parts on an antistatic surface or in antistatic bags.
·     If the server is installed with a TCM/TPM, to avoid damage to the connector, do not remove the TCM/TPM.
1.     Remove all front drives.
2.     Remove the access panel. Press the unlock button on the access panel, slide the panel to the server rear, and lift the access panel.
3.     Remove the supercapacitor, if any.
4.     Remove the air baffle.
5.     Remove the front drive backplane.
6.     (Optional) If the riser card and PCIe card have been installed, remove them.
7.     (Optional) If the storage controller has been installed, remove it.
8.     (Optional) If the straight-through card has been installed, remove it.
9.     Remove all storage controllers, NVMe VROC modules, and mezzanine modules, if any.
10.     Remove all DIMMs, processors, and heatsinks.
11.     Install protective covers over empty processor sockets.
12.     Remove the system board:
a.     Loosen the two captive screws on the system board.
b.     Hold the system board handle and slide the system board toward the server rear to disengage onboard connectors (for example, USB and SUV connectors) from the chassis. Then, lift the system board to remove it from the chassis.
Installing the system board
Follow the reverse order of removal to install the system board.
This section describes how to replace the drive backplane.
Operation scenario
·     The drive backplane fails.
·     The drive backplane hinders maintenance of other parts.
Removing a drive backplane
1.     Remove the drives attached to the backplane.
2.     Remove the access panel. Press the unlock button on the access panel, slide the panel to the serve rear, and lift the access panel.
3.     Remove the drive backplane. Hold the handle on the backplane to lift the backplane up.
Installing a drive backplane
1.     Install a drive backplane. Align both sides of the drive backplane with the two guide slots on the drive frame to insert the drive backplane downward.
2.     Install the access panel. Align the standouts on the access panel with the notches in the chassis side panels, place the panel onto the chassis, and slide the access panel to the server front until it is secured into place.
3.     Install the removed drives.
4.     Install the blade server. Power on the blade server. For more information, see "Powering on the blade server."
Common operations
The software interfaces are subject to change without notice. Figures in this section are for illustration only.
Local login
This section describes the specific steps of local login. When performing BIOS, HDM, UniSystem, RAID, operating system accessing, and other operations and configurations on the server, you may need to connect the mouse, keyboard, and display terminal to complete local login of the server.
The server provides two DB15 VGA connectors for connecting the display terminal.
·     The front panel provides one VGA connector.
·     The rear panel provides one VGA connector.
The server does not provide the standard PS2 mouse and keyboard connectors. You can connect the mouse and keyboard through the USB connectors on the front and rear panels. Two connection methods can be adopted according to different connector types of the mouse and keyboard:
·     Connect the USB mouse and keyboard directly using the connection method the same as that for the general USB cable.
·     Connect the PS2 mouse and keyboard through the USB to PS2 cable.
1.     As shown in Figure 24, plug one end of the video cable into the VGA connector extended from the server SUV cable and fix it using the screws on both sides of the plug.
Figure 24 Connecting the VGA connector
2.     Plug the other end of the video cable into the VGA connector of the display terminal and fix it using the screws on both sides of the plug.
3.     As shown in Figure 25, plug one end of the USB connector of the USB-PS2 cable into the USB connector extended from the server SUV cable, and connect the PS2 connectors at the other end to the mouse and keyboard respectively.
Figure 25 Connecting the USB to PS2 cable
Remote login
1.     Log in to OM. Enter https://OM_IP_address in the browser and press Enter. On the page that opens, enter the OM username and password, and then click Login.
2.     Log in to the blade server. Click Compute Node Management > Corresponding Blade Server > Remote Console > KVM or H5 KVM on the OM management page.
Accessing the blade server HDM interface
1.     Log in to OM. Enter https://OM IP_address in the browser and press Enter. On the page that opens, enter the OM username and password, and then click Login.
2.     Log in to the HDM web UI. Click Compute Node Management > Corresponding Blade Server > Remote Console > Authentication-free on the OM management page.
Maintenance
The following information describes the guidelines and tasks for daily server maintenance.
Guidelines
·     Keep  the equipment room clean and tidy. Remove unnecessary devices and objects from the equipment room.
·     Make sure the temperature and humidity in the equipment room meet the server operating requirements.
·     Regularly check the server from HDM or OM for operating health issues.
·     Keep the operating system and software up to date as required.
·     Make a reliable backup plan:
¡     Back up data regularly.
¡     If data operations on the server are frequent, back up data as needed in shorter intervals than the regular backup interval.
¡     Check the backup data regularly for data corruption.
·     Stock spare components on site in case replacements are needed. After a spare component is used, prepare a new one.
·     Keep the network topology up to date to facilitate network troubleshooting.
Maintenance tools
The following are major tools for server maintenance:
·     Temperature and humidity meterMonitors the operating environment of the server.
·     HDM and OM—Monitor the operating status of the server.
Maintenance operation
This section describes the routine maintenance task operations and operation methods of the blade server.
Task list
Table 28 lists the routine maintenance tasks.
Table 28 Maintenance tasks
Maintenance tasks
Maintenance tools
Observing LED status
N/A
Monitoring the temperature and humidity in the equipment room
Hygrothermograph
Viewing server status
N/A
Collecting server logs
N/A
Updating firmware for the server
N/A
Observe the LED status on the front panels of the server to verify that the server modules are operating correctly. For more information about the status of the front panel LEDs, see "LEDs and buttons."
Use a hygrothermograph to monitor the temperature and humidity in the equipment room.
The temperature and humidity in the equipment room must meet the server requirements described in "Technical parameters."
·     To view the health, operating, and power states of the server, see information about status diagnoses in the OM online help.
·     To view basic information and status of the subsystems of the server, see "View device information" in H3C Servers HDM Online Help.
For the procedure for collecting server logs, see collecting logs in the OM online help.
For the procedure for updating HDM, the BIOS, or CPLD, see the firmware upgrade guide for the server.
Locating faults
For more information, see the troubleshooting guide.
