- 04-DPI Command Reference
- 01-DPI engine commands
- 02-IPS commands
- 03-URL filtering commands
- 04-Data filtering commands
- 05-File filtering commands
- 06-Anti-virus commands
- 07-Data analysis center commands
- 08-Proxy policy commands
- 09-WAF commands
- 10-APT defense commands
- 11-IP reputation commands
- 12-Domain reputation commands
- 13-DGA detection commands
- 14-Intelligent service platform commands
| 14-Intelligent service platform commands | 51.15 KB |
The following compatibility matrix shows the support of hardware platforms for intelligent service platform:
Series |
Models |
Intelligent service platform compatibility |
F5000 series |
F5000-AI-40, F5000-AI-20, F5000-AI-15 |
Yes |
F5000-AI160, F5000-CN160, F5000-CN-G85, F5000-CN-G65, F5000-CN-G55 |
No |
F1000 series |
F1000-AI-25 |
Yes |
display intelligent-inspect status
Use display intelligent-inspect status to display the connection status of the intelligent service platform.
# Display the connection status of the intelligent service platform.
<Sysname> display intelligent-inspect status
State: Connected.
State |
Connection status of the intelligent service platform: · Connected—The device is connected to the intelligent service platform. · Disconnected—The device is disconnected from the intelligent service platform. |
intelligent-inspect ip
Use intelligent-inspect ip to assign an IP address to the intelligent service platform.
Use undo intelligent-inspect ip to restore the default.
intelligent-inspect ip ip-address
The intelligent service platform does not have an IP address.
ip-address: Specifies an IP address.
This address acts as the IP address of the internal Ethernet interface. The device communicates with the intelligent service platform through this IP address.
Only IPv4 addresses can be configured for the intelligent service platform.
# Assign IP address 192.22.1.30 to the intelligent service platform.
[Sysname] intelligent-inspect ip 192.22.1.30
enhanced-inspect anti-virus enable
service enable
