03-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath F1000[F5000] Firewalls Series Command Reference(V7)-6W90003-Security Command Reference
12-SMS commands
12-SMS commands 99.91 KB
SMS commands
app id
Use app-id to specify the app ID for the third-party SMS platform.
Use undo app-id to restore the default.
app-id app-id
undo app-id
No app ID is specified for the third-party SMS platform.
SMS gateway view
context-admin
app-id: Specifies the app ID of the third-party SMS platform, a case-sensitive string of 1 to 31 characters.
You need to configure this command only for an Emay Softcom or TP-LINK SMS platform.
When the third-party SMS platform is Emay Softcom (configured by using the sms-platform emay command), the app ID is encapsulated in the header field of HTTP requests and sent to the third-party SMS platform for the identity authentication of the SMS gateway. The platform determines the secret key according to the received app ID and grants the corresponding services to the SMS gateway.
When the third-party SMS platform is TP-LINK (configured by using the sms-platform tplink command), the app ID is encapsulated in the HTTP requests and sent to the third-party SMS platform for the platform to authenticate the identity of the SMS gateway and grant services.
The app ID is provided by the third-party SMS platform.
# Specify abc as the app ID of the third-party SMS platform for SMS gateway gw1.
[Sysname] sms-gateway gw1
[Sysname-sms-gateway-gw1] app-id abc
secret-key
display sms-gateway
Use display sms-gateway to display SMS gateway information.
display sms-gateway [ brief | name gateway-name ]
context-admin
context-operator
brief: Displays brief information about all SMS gateways. If you do not specify this keyword, the command displays detailed SMS gateway information.
name gateway-name: Specifies an SMS gateway by its name. An SMS gateway name is a case-insensitive string of 1 to 31 characters, and can contain only letters, digits, and underscores (_). If you do not specify an SMS gateway, this command displays information about all SMS gateways.
The configured secret key for SMS data encryption will be displayed in cipher text.
# Display detailed information about all SMS gateways.
<Sysname> display sms-gateway
Total Number of SMS gateways: 4
SMS gateway name: gw1
  SMS platform: emay
  App ID: abc
  Secret key: $c$3$zvzJI1AMQ4OVHCkSnXXoAOUyd2STdtIFtQDlJETCg=
  VPN instance: vpn1
SMS gateway name: gw2
  SMS platform: emay
  App ID: 123
  Secret key: $c$3$AS4tqlnOVODYEQ5IMHJNyNTTAyBPotXgw==
  VPN instance: vpn1
SMS gateway name: gw3
  SMS platform: tplink
  App ID: 123
  VPN instance: vpn1
  URL: https://example.com/EmPlat/rest/message/sendVpnCode
SMS gateway name: gw4
  SMS platform: pingan
  VPN instance: vpn1
  URL: http://wehub-sf.fat.qa.pab.com.cn/api/brcp_mpp.brcp-mpp-mms.sendOneRealTimeMsg
  Consumer ID: 3031
  Provider ID: 679900
  ChannelCode: 104936
  Access token: 25F2B4DCC07F43768CF3D948791E461F
  Message type: NYH_ZH220119018
SMS gateway name: gw5
  SMS platform: smp
  Server host: smp.test.com
  Server key: $c$3$zvzJI1AMQ4OVHCkSnXXoAOUyd2STdtIFtQDlJETCg=
  VPN instance: vpn1
SMS platform
SMS platform used by the SMS gateway to send SMS messages.
·     emayEmay Softcom.
·     pingan—Ping An bank.
·     smp—SMP.
·     tplink—TP-LINK.
App ID
App ID for the third-party SMS platform.
Secret key
Secret key (in cipher text) for SMS data encryption.
VPN instance
VPN instance associated with the SMS gateway.
URL
URL address of the TP-Link SMS platform.
Consumer ID
Consumer ID of the Ping An SMS platform.
Provider ID
Provider ID of the Ping An SMS platform.
ChannelCode
Channel code of the Ping An SMS platform.
Access token
Access token of the Ping An SMS platform.
Message type
Event code of the Ping An SMS platform.
Server host
Host name of the SMP security management platform.
Server key
Key of the SMP security management platform.
# Display brief information about all SMS gateways.
<Sysname> display sms-gateway brief
SMS gateway name                SMS platform     VPN instance
gw1                             emay             vpn1
gw2                             emay             vpn1
gw3                             tplink           vpn1
gw4                             pingan           vpn1
gw5                             smp              vpn1
SMS platform
·     emayEmay Softcom.
·     smp—SMP.
·     tplink—TP-LINK.
VPN instance
VPN instance associated with the SMS gateway. "-" is displayed if no VPN instance is configured.
secret-key
Use secret-key to specify the secret key for a third-party SMS platform.
Use undo secret-key to restore the default.
secret-key { cipher | simple } string
undo secret-key
No secret key is specified for a third-party SMS platform.
SMS gateway view
context-admin
cipher: Specifies a ciphertext secret key.
simple: Specifies a plaintext secret key. A plaintext secret key is stored in cipher text.
string: Specifies a case-sensitive secret-key string. A plaintext secret key is a string of 1 to 63 characters, and a ciphertext secret key is a string of 1 to 117 characters.
You need to configure this command only for an Emay Softcom, TP-LINK, or SMP SMS platform.
The secret key is provided by the third-party SMS platform.
The secret key uniquely corresponds to the app ID configured by the app-id command for the third-party SMS platform.
If the third-party SMS platform is Emay Softcom (configured by using the sms-platform emay command), the service module sends SMS data to the SMS gateway, and then the SMS gateway performs the following operations:
1.     Parses and converts the SMS data into data that can be recognized by the third-party SMS platform.
2.     Uses the secret key and algorithms to encrypt the SMS data.
3.     Sends the encrypted data to the third-party SMS platform.
The third-party SMS platform performs the following operations after receiving the encrypted data:
1.     Obtains the app ID in the header field of the HTTP request.
2.     Uses the secret key that corresponds to the app ID to decrypt the data to plaintext data.
3.     Sends the data in an SMS message to the user mobile number.
If the third-party SMS platform is TP-LINK (configured by using the sms-platform tplink command), the service module sends SMS data to the SMS gateway, and then the SMS gateway performs the following operations:
2.     Encapsulates the secret key, SMS platform app ID, SMS data, and other parameters in the HTTPS request message and sends them to the third-party SMS platform.
After receiving the HTTPS request message, the third-party SMS platform verifies the identity of the SMS gateway based on the app ID and secret key in the message. If the verification is successful, the SMS platform sends the SMS to the user's mobile phone.
If the SMP SMS platform is specified by using sms-platform smp, exectue the secret-key command to configure the username and password in the format of username:password.
# Specify the plaintext secret key of the third-party SMS platform as TESTplat&!.
[Sysname-sms-gateway-gw1] secret-key simple TESTplat&!
app-id
sms-gateway
Use sms-gateway to create an SMS gateway and enter its view, or enter the view of an existing SMS gateway.
Use undo sms-gateway to remove an SMS gateway.
sms-gateway gateway-name
undo sms-gateway gateway-name
No SMS gateways exist.
context-admin
gateway-name: Specifies an SMS gateway by its name, a case-insensitive string of 1 to 31 characters. Valid characters are letters, digits, and underscores (_).
The device implements SMS sending through an SMS gateway as follows:
1.     A service module sends SMS data to the SMS gateway.
2.     The SMS gateway converts the SMS data to the data that can be recognized by the third-party SMS platform.
3.     The SMS gateway sends the SMS data to the third-party SMS platform through HTTP.
4.     The third-party SMS platform sends the SMS message to the user mobile number.
SMS settings are configured in SMS gateway view, including the SMS platform, app ID for logging in to the third-party SMS platform, and secret key for SMS data encryption.
An SMS gateway can be associated with multiple service modules that require SMS services.
# Create an SMS gateway named gw1 and enter its view.
display sms-gateway
sms-platform
Use sms-platform to specify the SMS platform that sends messages.
Use undo sms-platform to restore the default.
sms-platform { emay | pingan sms-platform-url consumerid providerid channelcode accesstoken messagetype | smp server-host | tplink sms-platform-url }
undo sms-platform
No SMS platform is specified for sending messages.
SMS gateway view
context-admin
emay: Specifies the Emay SMS platform.
pingan sms-platform-url: Specifies the Ping AN Bank SMS platform. sms-platform-url represents the URL address of Ping An bank, a case-sensitive string of 1 to 255 characters.
consumerid: Specifies the consumer ID, a string of 1 to 10 digits, which is encapsulated in the x-g-consumerid field of the HTTP header in the request message sent from the SMS gateway to the Ping An Bank SMS platform.
providerid: Specifies the provider ID, a string of 1 to 10 digits, which is encapsulated in the x-g-providerid field of the HTTP header in the request message sent from the SMS gateway to the Ping An Bank SMS platform.
channelcode: Specifies the channel code, a string of 1 to 10 digits, used by the SMS gateway when sending a request message to the Ping An Bank SMS platform.
accesstoken: Specifies the access token, a case-sensitive string of 1 to 63 characters in plaintext, used by the SMS gateway when sending a request message to the Ping An Bank SMS platform.
messagetype: Specifies the event code, a case-sensitive string of 1 to 63 characters in plaintext, used by the SMS gateway when sending a request message to the Ping An Bank SMS platform.
smp server-host: Specifies the SMP security management platform by its host name. The host name is a case-insensitive string of 1 to 127 characters that can contain only letters, digits, underscores (_), colons (:), hyphens (-), and dots (.).
tplink sms-platform-url: Specifies the TP-LINK SMS platform. sms-platform-url represents the URL address of TP-LINK, a case-sensitive string of 1 to 255 characters.
To use an Emay or TP-LINK SMS platform, in addition to use this command to specify the platform, you must also configure the app-id and secret-key commands for the platform.
If you select the SMP SMS platform, specify the username and password by using the secret-key command before using this third-party SMS platform.
If the specified URL contains a domain name, you must configure Domain Name System (DNS) on the device to translate the domain name to the corresponding IP address. For more information about DNS, see DNS configuration in Layer 3—IP Services Configuration Guide.
# Specify the SMS platform as emay for SMS gateway gw1.
[Sysname-sms-gateway-gw1] sms-platform emay
# Specify the TP-LINK SMS platform by its URL address on SMS gateway gw2.
[Sysname] sms-gateway gw2
[Sysname-sms-gateway-gw2] sms-platform tplink https://example.com/EmPlat/rest/message/sendVpnCode
# Specify the Ping An bank SMS platform by its URL address on SMS gateway gw3. Set the consumer ID to 3031, provider ID to 679900, channel code to 104936, key to 25F2B4DCC07F43768CF3D948791E461F, and event code to NYH_ZH220119018.
[Sysname] sms-gateway gw3
[Sysname-sms-gateway-gw3] sms-platform pingan http://example.com.cn:8888/api/brcp_mpp.brcp-mpp-mms.sendOneRealTimeMsg 3031 679900 104936 25F2B4DCC07F43768CF3D948791E461F NYH_ZH220119018
# Specify the SMP SMS platform by its host name on SMS gateway gw3.
[Sysname-sms-gateway-gw3] sms-platform smp smp.test.com
app-id
secret-key
sms-send test-mobile
Use sms-send test-mobile to send a test SMS message to the specified mobile number.
sms-send test-mobile number
SMS gateway view
context-admin
number: Specifies the mobile number for receiving test messages, which is a string of 1 to 31 digits.
Use this command to test whether the configured SMS gateway can operate correctly. The SMS gateway is considered to be normal if the mobile number receives an App ID XXX verification passed message.
# Send a test message to mobile number 111111 for SMS gateway gw1.
[Sysname-sms-gateway-gw1] sms-send test-mobile 111111
app-id
secret-key
sms-platform
vpn-instance
Use vpn-instance to specify the VPN instance for an SMS gateway.
Use undo vpn-instance to restore the default.
undo vpn-instance
An SMS gateway belongs to the public network.
SMS gateway view
context-admin
vpn-instance-name: Specifies the name of an MPLS L3VPN instance, a case-sensitive string of 1 to 31 characters.
After you execute this command, the resources contained by an SMS gateway will belong to the associated VPN instance.
You can specify only one VPN instance for an SMS gateway.
# Specify VPN instance vpn1 for SSL VPN gateway gw1.
[Sysname-sms-gateway-gw1] vpn-instance vpn1
