- H3C WX5860X Access Controllers Installation Guide-5W103
- 01-Preparing for installation
- 02-Installing the device
- 03-Log in to the device
- 04-Troubleshooting
- 05-Hardware management and maintenance
- 06-Appendix A Chassis views and technical specifications
- 07-Appendix B LEDs
- 08-Appendix C Removable components and compatibility matrixes
| 07-Appendix B LEDs | 250.69 KB |
1 Appendix B LEDs
LEDs
Figure1-1 LEDs on the front panel
(1) System status LED (SYS) |
(2) Management Ethernet copper port status LEDs (LINK/ACT) |
(3) Power supply status LEDs (3 and 4, 7 and 8) |
(4) Fan tray status LEDs (5 and 6) |
Figure1-2 LEDs on the rear panel
(1) 1000Base-T Ethernet port status LED |
(2) SFP port status LED |
(3) 10G SFP+ port status LED |
(4) 40G QSFP+ port status LED |
LED description
LED |
Mark |
Status |
System status LED |
SYS |
Fast flashing green (4 Hz) |
The system is starting up. |
Slow flashing green (0.5 Hz) |
The system is operating correctly. |
Steady red |
A critical alarm has been triggered, for example, power supply alarm, fan tray alarm, high temperature alarm, and software loss. |
Off |
No power is present. |
Management Ethernet copper port status LED |
LINK/ACT |
Steady green |
A 100/1000 Mbps link is present. |
Flashing green |
The port is receiving or transmitting data at 100/1000 Mbps. |
Off |
No link is present. |
Power supply status LED |
N/A |
Steady green |
The power supply is operating correctly and in active state. |
Flashing green |
The power supply is operating correctly and in standby state. |
Steady red |
The power supply is faulty or has entered self-protection mode. |
Alternative flashing red/green |
An alarm has occurred on the power supply. The power supply has exceptional power output issues, for example, overvoltage output, undervoltage output, overcurrent output, overload, and overtemperature, but does not enter protection state. |
Flashing red |
The power supply does not have power input. The device has two power supplies. If one has power input, but the other does not, the status LED of the power supply that does not have power input flashes red. |
Off |
No power input. |
Fan tray status LED |
N/A |
On |
The fan tray is operating incorrectly. |
Off |
The fan tray is operating correctly or the device is not powered on. |
10/100/1000BASE-T Ethernet port status LED |
N/A |
Steady green |
A 1000 Mbps link is present on the port. |
Flashing green |
The port is receiving or transmitting data at 1000 Mbps. |
Off |
No link is present on the port. |
N/A |
Steady green |
Flashing green |
Off |
N/A |
Steady green |
A 10 Gbps link is present on the port. |
Flashing green |
The port is receiving or transmitting data at 10 Gbps. |
Off |
N/A |
Steady green |
A 40 Gbps link is present on the port. |
Flashing green |
The port is receiving or transmitting data at 40 Gbps. |
Off |
