07-Layer 3—IP Routing Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9825 & S9855 Switch Series Command References-R913x-6W10007-Layer 3—IP Routing Command Reference
07-Advanced BGP commands
07-Advanced BGP commands 472.45 KB
Advanced BGP commands· 1
additional-paths select-best 1
address-family link-state· 1
bgp update-delay wait-other-protocol 2
display bgp link-state· 3
display bgp monitor-group· 9
display bgp peer received prefix-list 10
domain-distinguisher 12
ebgp-interface-sensitive· 12
fast-reroute route-policy· 13
flush suboptimal-route· 14
graceful-restart 15
graceful-restart peer-reset 15
graceful-restart timer purge-time· 16
graceful-restart timer restart 17
graceful-restart timer wait-for-rib· 18
ignore all-peers· 19
isolate enable· 20
monitor-group· 21
nexthop recursive-lookup delay· 22
nexthop recursive-lookup route-policy· 23
peer additional-paths· 25
peer advertise additional-paths best 27
peer bfd· 28
peer bfd parameters· 30
peer capability-advertise conventional 31
peer capability-advertise orf non-standard· 32
peer capability-advertise orf prefix-list 33
peer capability-advertise route-refresh· 35
peer capability-advertise suppress-4-byte-as· 36
peer capability-advertise withdraw-refresh· 37
peer dscp· 39
peer flap-dampen· 40
peer graceful-restart timer restart extra· 41
peer ignore· 42
peer keep-all-routes· 44
peer low-memory-exempt 45
peer monitor-group· 46
peer monitor-link group· 48
peer nexthop-recursive-policy disable· 50
peer password· 51
peer reflect-nearby-group· 52
peer soo· 53
peer tcp-mss· 55
peer tracking· 56
pic· 58
primary-path-detect bfd· 59
refresh bgp· 60
reset monitor-group· 62
route-select delay· 63
server vpn-instance· 64
shutdown process· 64
Use additional-paths select-best to set the maximum number of Add-Path optimal routes that can be advertised to all peers.
Use undo additional-paths select-best to restore the default.
A maximum of one Add-Path optimal route can be advertised to all peers.
BGP IPv4 unicast address family view
BGP-VPN IPv4 unicast address family view
BGP IPv6 unicast address family view
BGP-VPN IPv6 unicast address family view
BGP EVPN address family view
best-number: Specifies the maximum number of Add-Path optimal routes that can be advertised to all peers, in the range of 2 to 64.
The number of optimal routes cannot exceed the maximum number of Add-Path optimal routes that can be advertised to all peers.
# In BGP IPv4 unicast address family view, set the maximum number to 3 for Add-Path optimal routes that can be advertised to all peers.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] additional-paths select-best 3
Use address-family link-state to create the BGP LS address family and enter its view, or enter the view of the existing address family.
Use undo address-family link-state to remove the BGP LS address family and all its configurations.
No BGP LS address family exists.
BGP instance view
Configurations made in BGP LS address family view apply only to the BGP LS routes and peers of the public network.
# In BGP instance view, create the BGP LS address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family link-state
[Sysname-bgp-default-ls]
Use bgp update-delay wait-other-protocol to configure the time that BGP must wait for other protocols to complete GR after BGP completes GR.
Use undo bgp update-delay wait-other-protocol to restore the default.
bgp update-delay wait-other-protocol seconds
After BGP completes GR, it must wait a maximum of 300 seconds for other protocols to complete GR.
BGP instance view
seconds: Specifies the time that BGP must wait for other protocols to complete GR after BGP completes GR. The value range is 60 to 1200 seconds.
If the updated routes rely on other protocols, for example, redistributed OSPF routes, BGP starts a wait timer for the other protocols to complete GR. This ensures that incorrect and unreachable routes are not advertised. When the following conditions exist, BGP might advertise incomplete routes after completing GR:
·     The routes rely on other protocols.
·     BGP maintains a large amount of routing information. In this case, BGP and the protocols take a long time to complete GR.
For BGP to correctly advertise the routes after BGP and the protocols complete GR, set a larger wait timer for BGP.
# Configure BGP to wait a maximum of 600 seconds for other protocols to complete GR after BGP completes GR.
[Sysname] bgp 100
[Sysname-bgp-default] bgp update-delay wait-other-protocol 600
bgp update-delay on-startup
Use display bgp link-state to display BGP LS information.
display bgp [ instance instance-name ] link-state [ ls-prefix [ advertise-info | as-path | cluster-list ] | peer { ipv4-address | ipv6-address } { advertised | received } [ statistics ] | statistics ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP LS information for the default BGP instance.
ls-prefix: Specifies an LS prefix. If you do not specify this argument, the command displays all BGP LS information.
advertise-info: Displays advertisement information for the specified LS prefix.
as-path: Displays AS_PATH attribute information for the specified LS prefix.
cluster-list: Displays CLUSTER_LIST attribute information for the specified LS prefix.
ipv4-address: Specifies a peer by its IPv4 address.
ipv6-address: Specifies a peer by its IPv6 address.
advertised: Displays advertised LS information.
received: Displays received LS information.
statistics: Displays statistics about LS messages.
If you do not specify any parameters, this command displays brief BGP LS information.
# Display brief BGP LS information for the public network.
<Sysname> display bgp link-state
 Total number of routes: 2
 BGP local router ID is 1.1.2.1
 Status codes: * - valid, > - best, d – dampened, h – history,
               s – suppressed, S – stale, i - internal, e - external
               a - additional-path
 Prefix codes: E link, V node, T4 IPv4 route, T6 IPv6 route, SD SRv6 SID desc
               u/U unknown,
               I Identifier, N local node, R remote node, L link, P prefix,
               L1/L2 ISIS level-1/level-2, O OSPF, O3 OSPFv3,
               D direct, S static, B BGP, SS SRv6 SID,
               a area-ID, l link-ID, t topology-ID, s ISO-ID,
               c confed-ID/ASN, b bgp-identifier, r router-ID,
               i if-address, n peer-address, o OSPF Route-type, p IP-prefix
               d designated router address/interface, ID Link Descriptor Identifer
* >e Network : [V][O][I0x0][N[c20][b1.1.1.2][a0.0.0.0][r1.1.1.2]]/376
     NextHop : 1.1.1.2                                  LocPrf    :
     MED     :
     Path/Ogn: 20i
* >e Network : [T4][O][I0x0][N[c20][b1.1.1.2][a0.0.0.0][r1.1.1.2]][P[o0x1][p1.1.1.0/24]]/480
     MED     :
     Path/Ogn: 20i
Status codes
Status codes:
·     * – valid—Valid route.
·     > – best—Optimal route.
·     d - dampened—Dampened route.
·     h – history—History route.
·     s – suppressed—Suppressed route.
·     S – stale—Stale route.
·     i – internal—Internal route.
·     e – external—External route.
·     a - additional-path—Add-Path optimal route.
Prefix codes
Route prefix codes:
·     E—Link.
·     V—Node.
·     T4—IPv4 route.
·     T6—IPv6 route.
·     u/U—Unknown.
·     I—Identifier.
·     N—Local node.
·     R—Remote node.
·     L—Link.
·     P—Prefix.
·     L1/L2—ISIS level-1/level-2.
·     O—OSPF.
·     O3—OSPFv3.
·     D—Direct.
·     S—Static.
·     B—BGP.
·     SS—SRv6 SID.
·     a—Area-ID.
·     l—Link-ID.
·     t—Topology-ID.
·     s—ISO-ID.
·     c—Confed-ID/ASN.
·     b—BGP-identifier.
·     r—Router-ID.
·     i—If-address.
·     n—Peer-address.
·     o—OSPF Route-type.
·     p—IP-prefix.
·     d—Designated router address/interface ID.
·     ID Link Descriptor Identifer—Link descriptor ID.
Origin
Origin of the route:
·     i – IGP—Originated in the AS.
·     e – EGP—Learned through EGP.
·     ? – incomplete—Unknown origin.
Network
NLRI for the LS.
NextHop
Next hop IP address.
LocPrf
Local preference.
OutLabel
Outgoing label of the route.
MED
MED attribute.
Path/Ogn
AS_PATH and ORIGIN attributes of the route:
·     AS_PATH—Records the ASs the route has passed, which avoids routing loops.
·     ORIGIN—Identifies the origin of the route.
bgp-ls-identifier
Area ID of BGP LS.
bgp-router-id
BGP router ID.
protocol-origin3
Configuration origin.
Flag
Flag.
originator-as
AS number.
originator-address
Address identifier.
discriminator
Path identifier.
# Display detailed BGP LS information with the specified LS prefix.
<Sysname> display bgp link-state [V][O][I0x0][N[c20][b1.1.1.2][a0.0.0.0][r1.1.1.2]]/376
 BGP local router ID: 1.1.1.2
 Local AS number: 20
 Paths:   1 available, 1 best
 BGP LS information of [V][O][I0x0][N[c20][b1.1.1.2][a0.0.0.0][r1.1.1.2]]/376:
 Imported route.
 Original nexthop: 0.0.0.0
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0xffffffff
 LS              : Node flag bits: 30[EA]
 AS-path         : (null)
 Origin          : igp
 Attribute value : pref-val 32768
 State           : valid, local, best
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
# Display AS_PATH attribute information for a specific LS prefix.
<Sysname> display bgp link-state [V][O][I0x0][N[c20][b1.1.1.2][a0.0.0.0][r1.1.1.2]]/376 as-path
 Local AS number: 20
 As-path: 100
# Display CLUSTER_LIST attribute information for a specific LS prefix.
<Sysname> display bgp link-state [V][O][I0x0][N[c20][b1.1.1.2][a0.0.0.0][r1.1.1.2]]/376 cluster-list
 Local AS number: 20
 Cluster list: 100
Paths
Number of routes:
·     available—Number of valid routes.
·     best—Number of optimal routes.
NLRI prefix.
Original nexthop
Original next hop of the route. If the route was obtained from a BGP update message, the original next hop is the next hop IP address in the message.
LS
LS attribute:
·     Node flag bits—Node attribute in hexadecimal format:
¡     10[A]—OSPF/OSPFv3 ABR bit.
¡     30[E]—OSPF/OSPFv3 External bit.
·     Metric—Link or prefix cost.
·     Local TE router ID.
·     Average delay flag—Flag indicating whether the average delay exceeds 16777215 microseconds.
¡     0: Stable link state whose average delay is not higher than 16777215 microseconds.
¡     1: Unstable link state whose average delay is higher than 16777215 microseconds.
·     Average delay—Average delay in microseconds.
·     Min/Max delay flag—Flag indicating whether the Min/Max delay exceeds 16777215 microseconds.
¡     0: Stable link state whose Min/Max delay is not higher than 16777215 microseconds.
¡     1: Unstable link state whose Min/Max delay is higher than 16777215 microseconds.
·     Min delay—Minimum delay in microseconds.
·     Max delay—Maximum delay in microseconds.
·     Delay variation—Acceptable delay variation in microseconds.
·     Remaining bandwidth—Available bandwidth in bit/s.
·     Utilized bandwidth—Used bandwidth in bit/s.
RxPathID
Add-path ID of received routes.
TxPathID
Add-path ID of advertised routes.
AS-path
AS_PATH attribute of the route, which records the ASs the route has passed and avoids routing loops.
Cluster list
CLUSTER_LIST attribute of the route.
Attribute value
BGP path attributes:
·     MED—MED value.
·     localpref—Local preference value.
·     pref-val—Preferred value.
·     pre—Route preference.
Current state of the route:
·     valid.
·     internal.
·     external.
·     local.
·     synchronize.
·     best.
IP precedence
IP precedence in the range of 0 to 7. N/A indicates that the route does not support this field.
QoS local ID
QoS local ID in the range of 1 to 4095. N/A indicates that the route does not support this field.
Traffic index
Traffic index in the range of 1 to 64. N/A indicates that the route does not support this field.
# Display advertisement information for the specified LS prefix.
<Sysname> display bgp link-state [E][B][I0x0][N[r1.1.1.2]][c65008][R[r44.33.22.11]][c65009]][L[i2.1.1.3][n1.1.1.3]]/536 advertise-info
 Local AS number: 65008
 Paths:  1 best
 BGP LS information of [E][B][I0x0][N[r1.1.1.2]][c65008][R[r44.33.22.11]][c65009]][L[i2.1.1.3][n1.1.1.3]]/536
(TxPathID:0):
10.1.1.2
 LS attribute :
   Peer node segment identifier : Flag c0[VL], Metric 0, Label 23001
Paths
Number of routes:
NLRI prefix.
Peers to which the information has been advertised, and the total number of such peers.
Peer node SID:
·     Flag c0[VL]:
¡     V—Value flag. If set, the SID carries a label value.
¡     L—Local flag. If set, the SID has local significance.
·     Metric—Link cost.
·     Label—Label value.
TxPathID
# Display BGP LS statistics.
<Sysname> display bgp link-state statistics
 Total number of routes: 1
Number of BGP routes.
Use display bgp monitor-group to display peer monitoring group information.
display bgp [ instance instance-name ] monitor-group { all | monitor-group-name }
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays peer monitoring group information for the default BGP instance.
all: Displays information about all peer monitoring groups.
monitor-group-name: Specifies a peer monitoring group by its name, a case-sensitive string of 1 to 47 characters.
# Display information about all peer monitoring groups in the default BGP instance.
<Sysname> display bgp monitor-group all
Monitor group a information:
Monitor group status : UP
Down threshold       : 7
Total sessions : 5
Down sessions  : 4
Peer             VPN instance name       State
10.2.1.2         b1                      DOWN
10.2.1.2         b2                      DOWN
10.2.1.2         b3                      DOWN
10.3.1.2         -                       DOWN
10.4.1.2         -                       UP
Monitor group b information:
Monitor group status : DOWN
Down threshold       : 4
Total sessions : 5
Down sessions  : 5
10.2.1.2         b1                      DOWN
10.3.1.2         -                       DOWN
10.4.1.2         -                       DOWN
10.5.1.2         b1                      DOWN
10.6.1.2         -                       DOWN
Table 5 Command output
Monitor group xxx information
Information about peer monitoring group xxx, where xxx represents the name of the group.
Peer monitoring group state:
·     UP—The number of disconnected BGP sessions in the peer monitoring group does not reach the threshold.
·     DOWN—The number of disconnected BGP sessions in the peer monitoring group reaches the threshold, and all BGP sessions are disconnected.
Down threshold
Threshold for the number of disconnected BGP sessions.
Total sessions
Number of BGP sessions in the peer monitoring group.
Down sessions
Number of disconnected BGP sessions.
Peer
IP address of the BGP peer.
VPN instance name
VPN instance to which the BGP peer belongs. This field displays a hyphen (-) if the BGP peer belongs to the public instance.
BGP peer state:
·     UP—The BGP session between the local device and peer is in Established state.
·     DOWN—The BGP session between the local device and peer is not in Established state.
reset monitor-group
Use display bgp peer received prefix-list to display the ORF prefix information received by a peer.
display bgp [ instance instance-name ] peer ipv4 [ [ unicast ] [ vpn-instance vpn-instance-name ] ] ipv4-address received prefix-list
display bgp [ instance instance-name ] peer ipv6 [ [ unicast ] [ vpn-instance vpn-instance-name ] ] ipv6-address received prefix-list
display bgp [ instance instance-name ] peer ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] ipv6-address received prefix-list
display bgp [ instance instance-name ] peer ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] { ipv4-address | link-local-address interface interface-type interface-number } received prefix-list
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays ORF prefix information for the default BGP instance.
ipv4: Displays BGP IPv4 peer information.
ipv6: Displays BGP IPv6 peer information.
unicast: Displays BGP unicast peer information.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays information for the public network.
link-local-address: Specifies a peer by its link-local address.
# Display the ORF prefix information received by peer 10.110.25.20.
<Sysname> display bgp peer ipv4 10.110.25.20 received prefix-list
ORF prefix list entries: 2
    index: 10               prefix  1.1.1.0/24              ge  26  le  32
    index: 20               prefix  2.1.1.0/24              ge  26  le  32
Table 6 Command output
Number of ORF prefixes.
index
Prefix index.
prefix
Prefix information.
ge
Greater than or equal to.
le
Less than or equal to.
Use domain-distinguisher to specify an AS number and a router ID for BGP LS messages.
Use undo domain-distinguisher to restore the default.
domain-distinguisher as-number:router-id
The AS number and router ID of the current BGP process are used.
as-number:router-id: Specifies the AS number and router ID. The value range for the as-number argument is 1 to 4294967295, and the router ID is in IP address format.
# Set the AS number and router ID for BGP LS messages to 65009 and 1.1.1.1, respectively.
[Sysname] bgp 100
[Sysname-bgp-default-ls] domain-distinguisher 65009:1.1.1.1
Use ebgp-interface-sensitive to enable immediate re-establishment of direct EBGP sessions.
Use undo ebgp-interface-sensitive to disable immediate re-establishment of direct EBGP sessions.
Immediate re-establishment of direct EBGP sessions is enabled.
BGP instance view
When a direct link to an EBGP peer fails, BGP tears down the session and re-establishes a session to the peer immediately. If the feature is not enabled, the router does not tear down the session until the hold time expires. However, disabling this feature can prevent routing flaps from affecting EBGP session state.
This command applies only to direct EBGP sessions.
# Enable immediate re-establishment of direct EBGP sessions.
[Sysname] bgp 100
[Sysname-bgp-default] ebgp-interface-sensitive
Use fast-reroute route-policy to apply a routing policy to fast reroute (FRR) for a BGP address family.
Use undo fast-reroute route-policy to restore the default.
No routing policy is applied to FRR.
route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
You can use the following methods to configure BGP FRR:
·     Method 1—Execute the pic command in BGP address family view. BGP calculates a backup next hop for a BGP route in the address family if there are two or more unequal-cost routes to reach the destination.
·     Method 2—Execute the fast-reroute route-policy command to use a routing policy in which a backup next hop is specified by using the command apply [ ipv6 ] fast-reroute backup-nexthop. For BGP to generate a backup next hop for the primary route, the backup next hop calculated by BGP must be the same as the specified backup next hop. You can also configure if-match clauses in the routing policy to identify the routes protected by FRR.
If both methods are configured, Method 2 takes precedence over Method 1.
# Apply routing policy frr-policy to FRR in BGP IPv4 unicast address family view.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] fast-reroute route-policy frr-policy
apply fast-reroute
apply ipv6 fast-reroute
pic
route-policy
Use flush suboptimal-route to enable BGP to flush the suboptimal BGP route to the RIB.
Use undo flush suboptimal-route to disable BGP from flushing the suboptimal BGP route to the RIB.
BGP is disabled from flushing the suboptimal BGP route to the RIB. Only the optimal route is flushed to the RIB.
BGP instance view
This command flushes the suboptimal BGP route to the RIB when the following conditions are met:
·     The optimal route is generated by the network command or is redistributed by the import-route command.
·     The suboptimal route is received from a BGP peer.
After the suboptimal route is flushed to the RIB on a network, BGP immediately switches traffic to the suboptimal route when the optimal route fails.
For example, the device has a static route to the subnet 1.1.1.0/24 that has a higher priority than a BGP route. BGP redistributes the static route and receives a route to 1.1.1.0/24 from a peer. After the flush suboptimal-route command is executed, BGP flushes the received BGP route to the RIB as the suboptimal route. When the static route fails, BGP immediately switches traffic to the suboptimal route if inter-protocol FRR is enabled. For more information about inter-protocol FRR, see Layer 3—IP Routing Configuration Guide.
# Enable BGP to flush the suboptimal BGP route to the RIB.
[Sysname] bgp 100
[Sysname-bgp-default] flush suboptimal-route
graceful-restart
Use graceful-restart to enable BGP Graceful Restart (GR) capability.
Use undo graceful-restart to disable BGP GR capability.
graceful-restart
BGP GR capability is disabled.
BGP instance view
GR ensures continuous forwarding when BGP restarts or an active/standby switchover occurs.
BGP peers exchange Open messages containing GR information. If both parties have GR capability, they establish a GR-capable session.
After you execute this command, the device re-establishes BGP sessions.
# Enable GR capability for BGP process 100.
[Sysname] bgp 100
[Sysname-bgp-default] graceful-restart
Use graceful-restart peer-reset to enable BGP to reset peer sessions gracefully.
Use undo graceful-restart peer-reset to disable BGP from resetting peer sessions gracefully.
graceful-restart peer-reset [ all ]
BGP does not reset peer sessions gracefully.
BGP instance view
all: Enables BGP to reset peer sessions gracefully when the TCP connection goes down, the hold timer expires, or the address families supporting route exchange change. If you do not specify this keyword, BGP resets peer sessions gracefully only when the address families supporting route exchange change.
When the TCP connection goes down, the hold timer expires, or the address families supporting route exchange change, BGP tears down and then re-establishes the peer sessions, which will cause traffic interruption. To avoid traffic interruption in these cases, execute this command to enable BGP to reset peer sessions gracefully.
# Enable BGP to reset peer sessions gracefully.
[Sysname] bgp 100
[Sysname-bgp-default] graceful-restart peer-reset
graceful-restart
Use graceful-restart timer purge-time to set the Routing Information Base (RIB) purge timer.
Use undo graceful-restart timer purge-time to restore the default.
The RIB purge timer is 480 seconds.
BGP instance view
timer: Sets the RIB purge timer in the range of 1 to 6000 seconds.
BGP starts the RIB purge timer when an active/standby switchover occurs or BGP restarts. If BGP route exchange is not completed within the RIB purge timer, the GR restarter quits the GR process. It updates the RIB with the BGP routes already learned, and removes the stale routes from RIB.
Enable BGP GR before you execute this command.
Set the RIB purge timer to be long enough to complete GR, especially when large numbers of BGP routes exist.
As a best practice, set the RIB purge timer in the following way:
·     Set the timer to be greater than the timer set by the graceful-restart timer wait-for-rib command
·     Set the timer to be less than the timer set by the protocol lifetime command.
# Set the RIB purge timer to 300 seconds.
[Sysname] bgp 100
[Sysname-bgp-default] graceful-restart timer purge-time 300
graceful-restart
protocol lifetime (Layer 3—IP Routing Command Reference)
Use graceful-restart timer restart to configure the GR timer.
Use undo graceful-restart timer restart to restore the default.
The GR timer is 150 seconds.
BGP instance view
timer: Specifies the GR timer in the range of 3 to 600 seconds.
The GR restarter sends the GR timer to the GR helper in an Open message. When the GR helper detects that an active/standby switchover or a BGP restart occurred on the GR restarter, the GR helper performs the following operations:
1.     Marks all routes learned from the GR restarter as stale.
2.     Starts the GR timer.
3.     If no BGP session is established before the GR timer expires, the GR helper removes the stale routes.
Before you configure this command, enable the BGP GR capability.
To apply a new GR timer, you must re-establish BGP sessions.
# Set the GR timer to 300 seconds.
[Sysname] bgp 100
[Sysname-bgp-default] graceful-restart timer restart 300
graceful-restart
Use graceful-restart timer wait-for-rib to configure the time to wait for the End-of-RIB marker.
Use undo graceful-restart timer wait-for-rib to restore the default.
The time to wait for the End-of-RIB marker is 600 seconds.
BGP instance view
timer: Specifies the time to wait for the End-of-RIB marker, in the range of 3 to 3600 seconds.
BGP uses this timer to control the time to receive updates from the peer. The timer is not advertised to the peer.
After the GR restarter and GR helper re-establish a BGP session, they start this timer. If they do not complete route exchange within the time period, the GR restarter does not receive new routes. It updates its routing table and forwarding table with learned BGP routes, and the GR helper removes the stale routes. Set a large value for the maximum time to wait for the End-of-RIB marker when a large number of routes exist.
This command controls the routing convergence speed. A smaller timer value means faster routing convergence but possibly results in incomplete routing information.
Before configuring this command, you must enable the BGP GR capability.
# Set the time to wait for the End-of-RIB marker on the local end to 100 seconds.
[Sysname] bgp 100
[Sysname-bgp-default] graceful-restart timer wait-for-rib 100
graceful-restart
ignore all-peers
Use ignore all-peers to disable BGP session establishment with all peers and peer groups.
Use undo ignore all-peers to restore the default.
ignore all-peers [ graceful graceful-time { community { community-number | aa:nn } | local-preference preference | med med } * ]
BGP can establish sessions to all peers and peer groups.
BGP instance view
graceful graceful-time: Sets the time to wait before the device shuts down all BGP sessions to peers and peer groups. The value range for the graceful-time argument is 0 to 65535 seconds. If you set the value for the graceful-time argument to 0, BGP does not shut down all BGP sessions to peers and peer groups. If you do not specify this option, the command immediately shuts down the sessions to all peers and peer groups.
community { community-number | aa:nn }: Specifies the community attribute for routes advertised to all peers and peer groups. The community-number argument represents the community sequence number in the range of 1 to 4294967295. The aa:nn argument represents the community number. Both aa and nn are in the range of 0 to 65535. If you do not specify this option, the command does not change the community attribute for routes advertised to all peers and peer groups.
local-preference preference: Specifies the local preference for routes advertised to all peers and peer groups, in the range of 0 to 4294967295. A larger value represents a higher preference. If you do not specify this option, the command does not change the local preference for routes advertised to all peers and peer groups.
med med: Specifies the MED value for routes advertised to all peers and peer groups, in the range of 0 to 4294967295. The smaller the MED value, the higher the route priority. If you do not specify this option, the command does not change the MED value for routes advertised to all peers and peer groups.
CAUTION
CAUTION:
Executing the ignore all-peers command tears down all existing sessions to peers and peer groups and clears all related routing information.
This command enables you to temporarily tear down the BGP sessions to all peers and peer groups. You can perform network upgrade and maintenance without needing to delete and reconfigure the peers and peer groups. To recover the sessions, execute the undo ignore all-peers command.
If you specify the graceful keyword in the ignore all-peers command, BGP performs the following tasks:
1.     Starts the wait timer specified with the graceful keyword.
2.     Advertises all routes to all peers and peer groups and changes the attribute for the advertised routes to the specified value.
3.     Shuts down all sessions to peers and peer groups after the wait timer expires.
This configuration lowers the priority of the routes advertised by BGP and BGP peers can select other peers' routes as optimal routes, which avoids traffic interruption upon wait timer expiration or peer disconnection. To enable BGP to advertise low-priority routes without tearing down BGP sessions, you can set the value for the graceful graceful-time option to 0.
For a BGP peer or peer group, the configuration made by the peer ignore command takes precedence over the configuration made by the ignore all-peers command.
# In BGP instance view, configure BGP to gracefully shut down the sessions to all peers and peer groups in 60 seconds, advertise all routes to all peers and peer groups, and change the community attribute and local preference for the advertised routes to 1:1 and 200, respectively.
[Sysname] bgp 1
[Sysname-bgp-default] ignore all-peers graceful 60 community 1:1 local-preference 200
peer ignore
isolate enable
Use isolate enable to enable BGP isolation.
Use undo isolate enable to restore the default.
isolate enable
undo isolate enable
BGP isolation is disabled.
BGP instance view
To maintain a BGP network device, you can use BGP isolation to remove the device from the network. This feature reduces configuration workload and impact on the network by retaining the device configuration during the maintenance. After maintenance, you can disable BGP isolation to add the device back to the network.
BGP isolation works as follows:
1.     BGP withdraws all routes advertised by the device except for the direct routes.
2.     BGP keeps all routes learned from its peers.
3.     Each peer of the device reselects an optimal route and updates the FIB table. During optimal route selection, the peers can still use the routes advertised by the device to forward traffic.
4.     After an optimal route is selected and the FIB table is updated, the peers stop forwarding packets except for those destined for the device to the device. The device is fully isolated from the network and you can upgrade it.
5.     After the maintenance, disable BGP isolation on the device to gracefully add it back to the network. After returning to the network, the device advertises and learns routes as follows:
¡     Advertises routes to its peers.
¡     Learns routes if BGP was reset during the isolation.
To avoid isolation failure, do not use this feature when GR is enabled for the device.
# Isolate the device from the network in BGP instance view.
[Sysname] bgp 100
[Sysname-bgp-default] isolate enable
monitor-group
Use monitor-group to create a peer monitoring group.
Use undo monitor-group to delete a peer monitoring group.
monitor-group monitor-group-name threshold number
undo monitor-group monitor-group-name
No peer monitoring groups exist.
BGP instance view
threshold number: Specifies the threshold for the number of disconnected BGP sessions, in the range of 1 to 600.
Application scenarios
A peer monitoring group is mainly used in traffic switchover scenarios. For example, when the local device receives multiple BGP routes to the same destination from multiple BGP peers in AS 10 and AS 20, the traffic to that destination can be load shared between AS 10 and AS 20. If multiple BGP peers within AS 10 are disconnected from the local device, the network administrator might perceive a risk in the network status within AS 10 even if there are still running BGP sessions within the AS. The administrator might need to switch all traffic passing through AS 10 to other ASs. You can configure the peer monitoring group feature to implement automatic traffic switchover in such scenarios.
Operating mechanism
Execute the monitor-group command to create a peer monitoring group, and then execute the peer monitor-group command to add shared-risk BGP peers to the group. When the number of disconnected BGP sessions in the group reaches the specified threshold, the local device will disconnect from all BGP peers in the group to avoid potential traffic loss.
After the local device disconnects from all BGP peers in a peer monitoring group, the local device will not proactively establish sessions to the devices in the group. To re-establish BGP sessions to the devices in the group, execute the reset monitor-group command.
# Create BGP peer monitoring group 1, and set the threshold to four for the number of disconnected BGP sessions.
[Sysname] bgp 1
[Sysname-bgp-default] monitor-group 1 threshold 4
peer monitor-group
reset monitor-group
Use nexthop recursive-lookup delay to set the delay time for responding to recursive next hop changes.
Use undo nexthop recursive-lookup delay to disable BGP from delaying responding to recursive next hop changes.
nexthop recursive-lookup [ non-critical-event ] delay [ delay-value ]
undo nexthop recursive-lookup [ non-critical-event ] delay
BGP responds to recursive next hop changes immediately.
BGP L2VPN address family view
non-critical-event: Delays responding to noncritical next hop changes. If you do not specify this keyword, BGP delays responding to both critical and noncritical next hop changes.
Next hop changes include the following types:
·     Critical route recursion changes—Changes that cause route unreachability and service interruption. For example, a BGP route cannot find a recursive next hop because of network failures.
·     Noncritical route recursion changes—A recursive or related route changes but the change will not cause route unreachability or service interruption. For example, the recursive interface of a BGP route changes but traffic forwarding is not affected.
delay-value: Specifies a delay time in the range of 1 to 240 seconds. The default delay time is 5 seconds.
When recursive or related routes change frequently, configure this command to reduce unnecessary path selection and update messages and prevent traffic loss.
To avoid traffic loss, do not configure this command if only one route is available to a specific destination.
Set an appropriate delay time based on your network condition. A short delay time cannot reduce unnecessary path selection or update messages, and a long delay time might cause traffic loss.
When you configure both the nexthop recursive-lookup delay and nexthop recursive-lookup non-critical-event delay commands for an address family, follow these guidelines:
·     BGP delays responding to both critical and noncritical next hop changes in the address family.
·     For noncritical next hop changes, the delay time specified by the nexthop recursive-lookup non-critical-event delay command takes effect.
If you execute the nexthop recursive-lookup delay command multiple times, the most recent configuration takes effect.
If you execute the nexthop recursive-lookup non-critical-event delay command multiple times, the most recent configuration takes effect.
# In BGP IPv4 unicast address family view, set the delay time for responding to recursive next hop changes to 100 seconds.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] nexthop recursive-lookup delay 100
Use nexthop recursive-lookup route-policy to enable routing policy-based nexthop recursion.
Use undo nexthop recursive-lookup route-policy to restore the default.
nexthop recursive-lookup route-policy route-policy-name
BGP does not perform routing policy-based nexthop recursion for routes.
CAUTION
CAUTION:
Before executing this command, make sure that BGP routes can be iterated to the desired paths under the constraints of the specified routing policy. If the recursion results of a BGP route are all filtered out by the specified routing policy, BGP considers the route unreachable.
When BGP performs nexthop recursion for a route without any constraints, the route might be iterated to an incorrect traffic forwarding path. To resolve this issue, use this command to enable routing policy-based nexthop recursion. BGP can then iterate routes to the desired forwarding paths under the constraints of the specified routing policy.
Operating mechanism
With this command configured, a BGP route can take effect only when some of its nexthop recursion results can match a permit node of the specified routing policy. If the recursion results of a route are all filtered out by the specified routing policy, the route is considered unreachable and cannot take effect.
·     Before configuring this command for an address family, perform the following task:
a.     Determine the routes to which that the BGP routes in that address family can be iterated.
b.     Configure a routing policy that contains the desired match criteria.
·     After you configure this command for an address family, BGP reperforms next hop recursion for the routes in that address family.
·     If the routing policy specified in this command does not exist, this command does not take effect. It will take effect immediately after you create the specified routing policy.
·     This command does not take effect on the routes learned from directly-connected EBGP peers.
·     This command does not take effect on the routes learned from the specified peer or peer group when you configure this command together with the peer nexthop-recursive-policy disable command.
·     When you configure the nexthop recursive-lookup route-policy command and the protocol nexthop recursive-lookup command, follow these restrictions and guidelines:
¡     If the following conditions exist, only the nexthop recursive-lookup route-policy command takes effect on the routes in a BGP address family:
-     You configure the nexthop recursive-lookup route-policy command in the view of the BGP address family.
-     You configure the protocol nexthop recursive-lookup command in RIB IPv4 or IPv6 address family view.
¡     If the following conditions exist, BGP performs nexthop recursion for the routes in a BGP address family according to the configuration of the protocol nexthop recursive-lookup command in RIB IPv4 or IPv6 address family view:
-     You do not configure the nexthop recursive-lookup route-policy command in the view of the BGP address family.
# In BGP IPv4 unicast address family view, specify routing policy test-policy to filter the nexthop recursion results of public BGP IPv4 unicast routes.
[Sysname] bgp 100
[Sysname-bgp-default-ipv6] nexthop recursive-lookup route-policy test-policy
protocol nexthop recursive-lookup (Layer 3—IP Routing Command Reference)
Use peer additional-paths to configure the BGP Additional Paths capabilities.
Use undo peer additional-paths to remove the configuration.
In BGP EVPN address family view:
peer { group-name | ipv4-address [ mask-length ] } additional-paths { receive | send } *
undo peer { group-name | ipv4-address [ mask-length ] } additional-paths { receive | send } *
In BGP IPv4 unicast address family view/BGP-VPN IPv4 unicast address family view/BGP IPv6 unicast address family view/BGP-VPN IPv6 unicast address family view:
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } additional-paths { receive | send } *
In BGP IPv6 unicast address family view/BGP-VPN IPv6 unicast address family view:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } additional-paths { receive | send } *
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } additional-paths { receive | send } *
No BGP Additional Paths capabilities are configured.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must have been created.
ipv4-address: Specifies a peer by its IPv4 address. The peer must have been created.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command configures the BGP Additional Paths capabilities for all dynamic peers in the subnet.
ipv6-address: Specifies a peer by its IPv6 address. The peer must have been created.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command configures the BGP Additional Paths capabilities for all dynamic peers in the subnet.
interface-peer interface-type interface-number: Specifies an interface by its type and number. The specified peer must have been created.
receive: Enables the BGP additional path receiving capability.
send: Enables the BGP additional path sending capability.
You can enable the BGP additional path sending, receiving, or both sending and receiving capabilities on a BGP router. For two BGP peers to successfully negotiate the Additional Paths capabilities, make sure one end has the sending capability and the other end has the receiving capability.
# In BGP IPv4 unicast address family view, enable the BGP additional path receiving capability.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 additional-paths receive
Use peer advertise additional-paths best to set the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group.
Use undo peer advertise additional-paths best to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] } advertise additional-paths best number
undo peer { group-name | ipv4-address [ mask-length ] } advertise additional-paths best
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise additional-paths best
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise additional-paths best number
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise additional-paths best
A maximum of one Add-Path optimal route can be advertised to a peer or peer group.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command sets the maximum number of Add-Path optimal routes that can be advertised to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command sets the maximum number of Add-Path optimal routes that can be advertised to all dynamic peers in the subnet.
number: Specifies the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group, in the range of 2 to 64.
If the number of Add-Path optimal routes advertised to a peer or peer group exceeds the number of optimal routes, the number of optimal routes takes effect.
# In BGP IPv4 unicast address family view, set the maximum number to 3 for Add-Path optimal routes that can be advertised to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 advertise additional-paths best 3
peer bfd
Use peer bfd to enable BFD for the link to a BGP peer or peer group.
Use undo peer bfd to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } bfd [ echo | multi-hop | single-hop ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } bfd
peer link-local-address interface interface-type interface-number bfd [ multi-hop | single-hop ]
undo peer link-local-address interface interface-type interface-number bfd
BFD is disabled for the link to a BGP peer or peer group.
BGP instance view
BGP-VPN instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables BFD for links to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command enables BFD for links to all dynamic peers in the subnet.
echo: Specifies the echo packet mode for BFD.
multi-hop: Specifies the control packet mode for multi-hop BFD.
single-hop: Specifies the control packet mode for single-hop BFD.
interface interface-type interface-number: Specifies an interface by its type and number. The specified peer must have been created.
When you do not specify the multi-hop, single-hop, or echo keyword:
·     If an IBGP peer or peer group is specified, this command enables multi-hop BFD in control packet mode for the IBGP peer or peer group.
·     If a directly connected EBGP peer or peer group is specified and the peer ebgp-max-hop command is not configured, this command enables single-hop BFD in control packet mode for the EBGP peer or peer group. If the EBGP peer or peer group is not directly connected or the peer ebgp-max-hop command is configured, this command enables multi-hop BFD in control packet mode for the EBGP peer or peer group.
Follow these restrictions and guidelines when you configure echo packet mode BFD:
·     Echo packet mode BFD is applicable only to directly connected BGP peers.
·     Echo packet mode BFD is not applicable to BGP peers established by using loopback interfaces.
·     For successful BFD session establishment, make sure a source address has been specified for echo packets by using the bfd echo-source-ip or bfd echo-source-ipv6 command.
To detect the link to a BGP peer established through link-local addresses, you must configure single-hop BFD in control packet mode.
To establish a control packet mode BFD session to a BGP peer, you must configure the same BFD detection mode (multi-hop or single-hop) on the local router and the BGP peer.
For more information about BFD, see BFD configuration in High Availability Configuration Guide.
BFD helps speed up BGP routing convergence upon link failures. However, if you have enabled GR, use BFD with caution. BFD might detect a failure before the system performs GR, resulting in GR failure. If you have enabled both BFD and GR for BGP, do not disable BFD during a GR process to avoid GR failure.
# In BGP instance view, enable control packet mode single-hop BFD for the link to BGP peer group test.
[Sysname] bgp 100
[Sysname-bgp-default] peer test bfd single-hop
bfd echo-source-ip (High Availability Command Reference)
bfd echo-source-ipv6 (High Availability Command Reference)
display bgp peer
display bfd session (High Availability Command Reference)
peer bfd parameters
Use peer bfd parameters to configure BFD parameters for the specified BGP peer or peer group.
Use undo peer bfd parameters to restore the default.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } bfd parameters { detect-multiplier detect-multiplier | min-receive-interval min-receive-interval | min-transmit-interval min-transmit-interval } *
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } bfd parameters { detect-multiplier | min-receive-interval | min-transmit-interval } *
No BFD parameters are configured for a BGP peer or peer group.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command takes effect on all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command takes effect on all dynamic peers in the subnet.
detect-multiplier detect-multiplier: Specifies the detection time multiplier. The value range for the detect-multiplier argument is 3 to 50.
min-receive-interval min-receive-interval: Specifies the minimum interval for receiving BFD control packets, , in milliseconds. The value range for the min-receive-interval argument is 100 to 10000.
min-transmit-interval min-transmit-interval: Specifies the minimum interval for transmitting BFD control packets,, in milliseconds. The value range for the min-transmit-interval argument is 100 to 10000.
When you configure BFD parameters for a BGP peer or peer group, follow these restrictions and guidelines:
·     When you add a peer to a peer group, the peer will inherit the BFD settings of the peer group.
·     When you configure BFD parameters for a peer group, the configuration takes effect on all peers in the peer group.
·     If you configure a BFD parameter multiple times for a peer or peer group, the most recent configuration takes effect.
·     For a peer, the most recent configuration of a BFD parameter takes effect regardless of the configuration source.
# Configure BFD parameters for peer 2.2.2.9.
[Sysname] bgp 100
[Sysname-bgp-default] peer 2.2.2.9 bfd parameters min-transmit-interval 100 min-receive-interval 100 detect-multiplier 5
display bgp peer
peer bfd
Use peer capability-advertise conventional to disable the BGP multi-protocol extension, route refresh, and 4-byte AS number features for a peer or peer group.
Use undo peer capability-advertise conventional to enable the BGP multi-protocol extension, route refresh, and 4-byte AS number features for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise conventional
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise conventional
The BGP multi-protocol extension, route refresh, and 4-byte AS number features are enabled.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command disables BGP multi-protocol extension and route refresh for all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command disables BGP multi-protocol extension and route refresh for all dynamic peers in the subnet.
The route refresh feature enables BGP to send and receive Route-refresh messages and implement BGP session soft-reset.
The multi-protocol extension feature enables BGP to advertise and receive routing information for various protocols (for example, IPv6 routing information).
The 4-byte AS number feature enables BGP to use 4-byte AS numbers in the range of 1 to 4294967295.
If both the peer capability-advertise conventional and peer capability-advertise route-refresh commands are executed, the most recent configuration takes effect.
# In BGP instance view, disable the multi-protocol extension, route refresh, and 4-byte AS number features for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 as-number 100
[Sysname-bgp-default] peer 1.1.1.1 capability-advertise conventional
display bgp peer
Use peer capability-advertise orf non-standard to enable nonstandard ORF capabilities negotiation for a peer or peer group.
Use undo peer capability-advertise orf non-standard to disable nonstandard ORF capabilities negotiation for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise orf non-standard
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise orf non-standard
Nonstandard ORF capabilities negotiation is disabled for a peer or peer group.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ip-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables BGP to negotiate nonstandard ORF capabilities with all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command enables BGP to negotiate nonstandard ORF capabilities with all dynamic peers in the subnet.
To enable BGP peers to negotiate nonstandard ORF capabilities, you must configure this command together with the peer capability-advertise orf prefix-list command.
# Enable nonstandard ORF capabilities negotiation for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 capability-advertise orf non-standard
Use peer capability-advertise orf prefix-list to enable BGP ORF capabilities negotiation for a peer or peer group.
Use undo peer capability-advertise orf prefix-list to disable BGP ORF capabilities negotiation for a peer or peer group.
In BGP IPv4 unicast address family view/BGP-VPN IPv4 unicast address family view:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise orf prefix-list { both | receive | send }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise orf prefix-list { both | receive | send }
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ]  | link-local-address interface interface-type interface-number } capability-advertise orf prefix-list { both | receive | send }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ]  | link-local-address interface interface-type interface-number } capability-advertise orf prefix-list { both | receive | send }
BGP ORF capabilities are disabled.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command specifies all dynamic peers in the subnet.
both: Enables BGP to send and receive route fresh messages that carry the ORF information.
receive: Enables BGP to receive route fresh messages that carry the ORF information.
send: Enables BGP to send route fresh messages that carry the ORF information.
After you configure this command, the BGP peers negotiate the ORF capabilities through Open messages. After completing the negotiation process, the BGP peers can exchange ORF information through route refresh messages. To enable the peers to exchange nonstandard ORF information, you must also configure the peer capability-advertise orf non-standard command.
# Enables BGP ORF capabilities negotiation for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 capability-advertise orf prefix-list both
Use peer capability-advertise route-refresh to enable BGP route refresh for a peer or peer group.
Use undo peer capability-advertise route-refresh to disable BGP route refresh for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise route-refresh
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise route-refresh
BGP route refresh is enabled.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables BGP route refresh for all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command enables BGP route refresh for all dynamic peers in the subnet.
The route refresh feature enables BGP to send and receive Route-refresh messages.
BGP uses the route refresh feature to implement BGP session soft-reset. After a policy is modified, the router advertises a Route-refresh message to the peers. The peers resend their routing information to the router. After receiving the routing information, the router filters the routing information by using the new policy. This method allows you to refresh the BGP routing table and apply the new route selection policy without tearing down BGP sessions.
BGP route refresh requires that both the local router and the peer support route refresh.
If both the peer capability-advertise route-refresh and peer capability-advertise conventional commands are executed, the most recent configuration takes effect.
# In BGP instance view, enable BGP route refresh for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 capability-advertise route-refresh
display bgp peer
refresh bgp
Use peer capability-advertise suppress-4-byte-as to enable 4-byte AS number suppression.
Use undo peer capability-advertise suppress-4-byte-as to disable 4-byte AS number suppression.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise suppress-4-byte-as
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise suppress-4-byte-as
The 4-byte AS number suppression feature is disabled.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables 4-byte AS number suppression for all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command enables 4-byte AS number suppression for all dynamic peers in the subnet.
BGP supports 4-byte AS numbers. The 4-byte AS number occupies four bytes, in the range of 1 to 4294967295. By default, a device sends an Open message to the peer device for session establishment. The Open message indicates that the device supports 4-byte AS numbers. If the peer device supports 2-byte AS numbers instead of 4-byte AS numbers, the session cannot be established. To resolve this issue, enable the 4-byte AS number suppression feature. The device then sends an Open message to inform the peer that it does not support 4-byte AS numbers, so the BGP session can be established.
If the peer device supports 4-byte AS numbers, do not enable the 4-byte AS number suppression feature. If this feature is enabled, the BGP session cannot be established.
# In BGP instance view, enable 4-byte AS number suppression for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 capability-advertise suppress-4-byte-as
display bgp peer
peer capability-advertise withdraw-refresh
Use peer capability-advertise withdraw-refresh to enable BGP to exchange withdrawal ROUTE-REFRESH messages with a peer or peer group.
Use undo peer capability-advertise withdraw-refresh to disable BGP from exchanging withdrawal ROUTE-REFRESH messages with a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise withdraw-refresh
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise withdraw-refresh
BGP cannot exchange withdrawal ROUTE-REFRESH messages with any peer or peer group.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command takes effect on all dynamic peers in the network.
This command is applicable to multi-level BGP networking scenarios.
When all uplinks of an upstream device fail and the device cannot complete route convergence in time, the device might also fail to send route withdrawal messages to downstream devices in time. At this time, those downstream devices still forward some user traffic to the upstream device, resulting in traffic forwarding failure.
To avoid this issue, enable the upstream device to exchange withdrawal ROUTE-REFRESH messages with downstream devices. When all uplinks of the upstream device fail, it sends withdrawal ROUTE-REFRESH messages to the downstream devices. On receipt of the withdrawal ROUTE-REFRESH messages, the downstream devices immediately perform route switchover and forward traffic to another upstream device with normal uplinks.
Operating mechanism
After this command is executed on an upstream device, the upstream device performs the following operations:
1.     Terminates and re-establishes the BGP session to the specified downstream device.
2.     Exchanges OPEN messages with the downstream device to negotiate the capability of exchanging withdrawal ROUTE-REFRESH messages.
To ensure successful negotiation, you must configure this command at both ends of the BGP session, specifying the other end.
With the withdrawal ROUTE-REFRESH capability negotiated successfully, if the upstream device is disconnected from all peers in the same AS, it sends a withdrawal ROUTE-REFRESH message to the downstream device. The sent message carries the AS number from which the upstream device is disconnected.
After receiving the withdrawal ROUTE-REFRESH message, the downstream device performs the following operations:
1.     Searches in all BGP routes received from the upstream BGP device for routes whose NEXT_HOP attributes contain the AS number carried by the withdrawal ROUTE-REFRESH message.
To view the NEXT_HOP attribute of a BGP route, see the AS-path field in the output of the display rib nib or display ipv6 rib nib command.
2.     Marks the IP routes corresponding to routes whose NEXT_HOP attributes contain AS 10 as backup routes.
The downstream device no longer uses these routes for traffic forwarding, achieving fast route switchover.
After receiving a withdrawal ROUTE-REFRESH message, the device forwards the message to its peers as follows:
·     If the message is received from an IBGP peer, the device forwards the message only to EBGP peers.
·     If the message is received from an EBGP peer, the device replaces the original AS number of the message with its own AS number and forwards the message to IBGP peers.
You can use this command in conjunction with the peer tracking command on an upstream device. The peer tracking command enables the upstream device to fast detect status of the specified BGP peer session. When the related peer is unreachable, the local device immediately terminates the BGP peer session in time and sends withdrawal ROUTE-REFRESH messages to downstream devices. Collaboration of the two commands expedites forwarding path convergence upon uplink failures.
Execute this command with caution, because this operation will terminate and re-establish the BGP session between the local device and the specified peer.
# In BGP instance view, enable BGP to exchange withdrawal ROUTE-REFRESH messages with peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 capability-advertise withdraw-refresh
display ipv6 rib nib (Layer 3—IP Routing Command Reference)
display rib nib (Layer 3—IP Routing Command Reference)
peer tracking
peer dscp
Use peer dscp to set a DSCP value for outgoing BGP packets.
Use undo peer dscp to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } dscp dscp-value
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } dscp
The DSCP value for outgoing BGP packets is 48.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies a DSCP value for outgoing BGP packets to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command specifies a DSCP value for outgoing BGP packets to all dynamic peers in the subnet.
dscp-value: Specifies a DSCP value in the range of 0 to 63.
The DSCP value of an IP packet specifies the priority level of the packet and affects the transmission priority of the packet. A larger DSCP value represents a higher priority.
# In BGP instance view, set the DSCP value to 10 for outgoing BGP packets to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default] peer test dscp 10
peer flap-dampen
Use peer flap-dampen to configure flap dampening for a peer or peer group.
Use undo peer flap-dampen to disable flap dampening for a peer or peer group.
peer { group-name | ipv4-address | ipv6-address } flap-dampen [ max-idle-time max-time | min-established-time min-time ] *
undo peer { group-name | ipv4-address | ipv6-address } flap-dampen
Flap dampening is disabled for all peers and peer groups.
BGP instance view
max-time: Specifies the maximum time during which a BGP peer remains in idle state. The value range for this argument is 1 to 65536 seconds, and the default value is 1800 seconds.
min-time: Specifies the minimum time during which a BGP peer remains in Established state so as to exit the dampened state. The value range for this argument is 1 to 4294967295 seconds, and the default value is 600 seconds.
Execute this command to dampen a BGP peer when the peer state frequently changes between up and down. BGP increases the idle time of the peer each time the peer comes up until the maximum idle time is reached. To exit the dampened state, the peer must remain in Established state for a time period longer than the minimum established time. After the peer exits the dampened state, BGP resets the idle time of the peer when the peer comes up again.
Set a maximum idle time and a minimum established time based on your network condition.
# In BGP instance view, enable flap dampening for peer group test, and set the maximum idle time and minimum established time to 800 seconds and 2000 seconds, respectively.
[Sysname] bgp 100
[Sysname-bgp-default] peer test flap-dampen max-idle-time 800 min-established-time 2000
peer graceful-restart timer restart extra
Use peer graceful-restart timer restart extra to set the extra time to wait after the restart timer expires.
Use undo peer graceful-restart timer restart extra to restore the default.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } graceful-restart timer restart extra { time | no-limit }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } graceful-restart timer restart extra
The extra time to wait after the restart timer expires is 0 seconds.
BGP instance view
time: Specifies the extra time to wait after the restart timer expires, in the range of 0 to 86400 seconds.
no-limit: Sets an unlimited time to wait for BGP session re-establishment.
After the active/standby switchover or BGP restart completes, the GR helper marks the routes it learned from the GR restarter as stale routes. If the GR helper fails to establish a BGP session after both the GR timer and the extra timer to wait expire, the GR helper removes the stale routes.
# Set the extra time to wait after the restart timer expires to 100 seconds.
[Sysname] bgp 100
[Sysname-bgp-default] peer 10.1.100.2 graceful-restart timer restart extra 100
peer ignore
Use peer ignore to disable BGP session establishment with a peer or peer group.
Use undo peer ignore to enable BGP session establishment with a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } ignore  [ graceful graceful-time { community { community-number | aa:nn } | local-preference preference | med med } * ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } ignore
BGP can establish a session to a peer or peer group.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet in this command, BGP tears down sessions to all dynamic peers in the subnet.
graceful graceful-time: Sets the time to wait before the device shuts down the session to the specified peer or peer group. The value range for the graceful-time argument is 0 to 65535 seconds. If you set the value for the graceful-time argument to 0, the device does not shut down the session to the specified peer or peer group. If you do not specify this option, the command immediately shuts down the session to the specified peer or peer group.
community { community-number | aa:nn }: Specifies the community attribute for advertised routes. The community-number argument represents the community sequence number in the range of 1 to 4294967295. The aa:nn argument represents the community number. Both aa and nn are in the range of 0 to 65535. If you do not specify this option, the command does not change the community attribute for advertised routes.
local-preference preference: Specifies the local preference for advertised routes, in the range of 0 to 4294967295. A larger value represents a higher preference. If you do not specify this option, the command does not change the local preference for advertised routes.
med med: Specifies the MED value for advertised routes, in the range of 0 to 4294967295. The smaller the MED value, the higher the route priority. If you do not specify this option, the command does not change the MED value for advertised routes.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet in this command, BGP tears down sessions to all dynamic peers in the subnet.
CAUTION
CAUTION:
·     If a session has been established to a peer, executing the peer ignore command for the peer tears down the session and clears all related routing information.
·     If sessions have been established to a peer group, executing the peer ignore command for the peer group tears down the sessions to all peers in the group and clears all related routing information.
This command enables you to temporarily tear down the BGP session to a peer or peer group. You can perform network upgrade and maintenance without needing to delete and reconfigure the peer or peer group. To recover the session, execute the undo peer ignore command.
If you specify the graceful keyword in the peer ignore command, BGP performs the following tasks:
2.     Advertises all routes to the specified peer or peer group and changes the attribute for the advertised routes to the specified value.
Advertises the routes from the specified peer or peer group to other IBGP peers and peer groups and changes the attribute for the advertised routes to the specified value.
3.     Shuts down the session to the specified peer or peer group after the wait timer expires.
# In BGP instance view, disable session establishment with peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 ignore
# In BGP instance view, configure BGP to gracefully shut down the session to peer 1.1.1.1 in 60 seconds, advertise all routes to peer 1.1.1.1, and change the community attribute and local preference for the advertised routes to 1:1 and 200, respectively.
[Sysname] bgp 1
[Sysname-bgp-default] peer 1.1.1.1 ignore graceful 60 community 1:1 local-preference 200
ignore all-peers
peer keep-all-routes
Use peer keep-all-routes to save all route updates from a peer or peer group, regardless of whether the routes have passed the configured routing policy.
Use undo peer keep-all-routes to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } keep-all-routes
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } keep-all-routes
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } keep-all-routes
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } keep-all-routes
Route updates from a peer or peer group are not saved.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command saves all route updates from all dynamic peers in the subnet, regardless of whether the routes have passed the configured routing policy.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command saves all route updates from all dynamic peers in the subnet, regardless of whether the routes have passed the configured routing policy.
link-local-address: Specifies a peer by its link-local address.
To implement BGP session soft-reset when the local router and a peer or peer group do not support the route refresh feature, use the peer keep-all-routes command. The command saves all route updates received from the peer or peer group. After modifying the route selection policy, filter all saved routes with the new policy to refresh the routing table. This method avoids tearing down BGP sessions.
# In BGP IPv4 unicast address family view, save all route updates from peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] peer 1.1.1.1 keep-all-routes
refresh bgp
peer low-memory-exempt
Use peer low-memory-exempt to configure BGP to protect EBGP peers or peer groups when the memory usage reaches level 2 threshold.
Use undo peer low-memory-exempt to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } low-memory-exempt
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } low-memory-exempt
When the memory usage reaches level 2 threshold, BGP tears down an EBGP session to release memory resources periodically.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet in this command, BGP protects all dynamic peers in the subnet when the memory usage reaches level 2 threshold.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet in this command, BGP protects all dynamic peers in the subnet when the memory usage reaches level 2 threshold.
When level 2 memory usage threshold is reached, BGP tears down an EBGP session to release memory resources periodically until the memory usage is exempt from level 2 threshold. You can use this command to avoid tearing down the BGP session to an EBGP peer when memory usage reaches level 2 threshold. For more information about thresholds, see hardware resource management configuration in System Management Configuration Guide.
# In BGP instance view, configure BGP to protect EBGP peer 1.1.1.1 when the memory usage reaches level 2 threshold.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 as-number 200
[Sysname-bgp-default] peer 1.1.1.1 low-memory-exempt
peer monitor-group
Use peer monitor-group to add a peer or peer group to a peer monitoring group.
Use undo peer monitor-group to remove a peer or peer group from its peer monitoring group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } monitor-group monitor-group-name
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } monitor-group
A peer or peer group does not belong to any peer monitoring group.
BGP instance view
group-name: Specifies a BGP peer group by its name, a case-sensitive string of 1 to 47 characters. The specified peer group must have been created.
ipv4-address: Specifies a BGP peer by its IPv4 address. The specified peer group must have been created.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command adds all dynamic peers in the subnet to the peer monitoring group.
ipv6-address: Specifies a BGP peer by its IPv6 address. The specified peer group must have been created.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command adds all dynamic peers in the subnet to the peer monitoring group.
monitor-group-name: Specifies a peer monitoring group by its name, a case-sensitive string of 1 to 47 characters. The specified group must have been created.
A peer monitoring group is mainly used in traffic switchover scenarios. For example, when the local device receives multiple BGP routes to the same destination from multiple BGP peers in AS 10 and AS 20, the traffic to that destination can be load shared between AS 10 and AS 20. If multiple BGP peers within AS 10 are disconnected from the local device, the network administrator might perceive a risk in the network status within AS 10 even if there are still running BGP sessions within the AS. The administrator might need to switch all traffic passing through AS 10 to other ASs. You can configure this feature to implement automatic traffic switchover in such scenarios.
Operating mechanism
Execute the monitor-group command to create a peer monitoring group, and then execute the peer monitor-group command to add shared-risk BGP peers to the group. When the number of disconnected BGP sessions in the group reaches the specified threshold, the local device will disconnect from all BGP peers in the group to avoid potential traffic loss. The number of disconnected BGP sessions accumulates only when a BGP peer is disconnected unexpectedly. Administratively disconnected BGP peers do not increase the number.
Only BGP peers in Established state can be added to a peer monitoring group.
The number of BGP sessions in a peer monitoring group depends on the number of BGP peers in the group. Each BGP peer is counted as one BGP session, regardless of whether the peer has established sessions in multiple address families. The BGP sessions created by using the same IP address in different BGP-VPN instances and the public instance are considered as different sessions.
A BGP peer or peer group can be added to only one peer monitoring group.
# In BGP instance view, add peer 1.1.1.1 to peer monitoring group 1.
[Sysname] bgp 1
[Sysname-bgp-default] peer 1.1.1.1 monitor-group 1
display bgp monitor-group
monitor-group threshold
reset monitor-group
peer monitor-link group
Use peer monitor-link group to configure the BGP session state to collaborate with the monitor link downlink interfaces.
Use undo peer monitor-link group to disable the BGP session state from collaborating with the monitor link downlink interfaces.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } monitor-link group group-id
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } monitor-link group
The BGP session state does not collaborate with the monitor link downlink interfaces.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command applies to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command applies to all dynamic peers in the subnet.
group-id: Specifies a monitor link group by its ID. The value range for the group-id argument is 1 to 16.
Non-default vSystems do not support this command.
Operating mechanism
After this command is executed, the BGP session between the local device and a peer or peer group specified by this command will be used as an uplink interface of the specified monitor link group. The uplink interfaces and downlink interfaces in a monitor link group collaborate as follows:
·     Uplink interfaces are defined as follows:
¡     In a monitor link group, an interface specified by using the port uplink or port monitor-link group uplink command is considered as an uplink interface.
¡     In a monitor link group, each BGP process specified by using the monitor bgp command is considered as an uplink interface.
¡     In a monitor link group, a BGP session specified by using the peer monitor-link group command is considered as an uplink interface.
If the BGP sessions specified by using the peer monitor-link group command are established in the BGP process specified by using the monitor bgp command, and at least one of these BGP sessions is in Established state, the BGP process is not considered as an uplink interface. If the BGP sessions specified by using the peer monitor-link group command are established in the BGP process specified by using the monitor bgp command, and none of these BGP sessions is in Established state, these BGP sessions are not considered as uplink interfaces, and only the BGP process is considered as an uplink interface.
For example, use the monitor bgp command to specify BGP instances aaa and bbb as two uplink interfaces in a monitor link group, use the peer monitor-link group command in BGP instance aaa to specify two BGP sessions as the uplink interfaces, and do not use the peer monitor-link group command in BGP instance bbb to specify uplink interfaces. In this case, when at least one of the two specified BGP sessions are in Established state, the monitor link group has three uplink interfaces in total, including two BGP sessions and one BGP process without BGP sessions specified. When neither of the two specified BGP sessions is in Established state, the monitor link group has two uplink interfaces in total. One uplink interface is the BGP process with BGP sessions specified but neither of the BGP sessions is in Established state. The other is the BGP process without BGP sessions specified.
·     Downlink interfaces are defined as follows: In a monitor link group, an interface specified by using the port downlink or port monitor-link group downlink command is considered as a downlink interface.
·     Uplink interfaces and downlink interfaces collaborate as follows:
¡     When the number of uplink interfaces in up state in a monitor link group is lower than the threshold configured by using the uplink up-port-threshold command, the physical state is set to down for all downlink interfaces in the monitor link group. An uplink interface is determined as up or down following these rules:
-     For an interface specified by using the port uplink or port monitor-link group uplink command, the uplink interface is considered as up if the interface is physically up, and the uplink interface is considered as down if the interface is physically down.
-     For a BGP process specified by using the monitor bgp command, the uplink interface is considered as up when the BGP instance exists and runs normally, and the uplink interface is considered as down when the BGP instance is deleted and the corresponding process exits.
-     For a BGP session specified by using the peer monitor-link group command, the uplink interface is considered as up when the BGP session is in Established state, and the uplink interface is considered as down when the BGP session is in any other state.
¡     When the number of uplink interfaces in up state in a monitor link group is greater than or equal to the threshold configured by using the uplink up-port-threshold command, the physical state is set to up for all downlink interfaces in the monitor link group.
To prevent BGP session flappings from causing frequent downlink switchovers in a monitor link group, execute the downlink up-delay command in the monitor link group to set the switchover delay for the downlink interfaces in the monitor link group.
For more information about monitor link, see monitor link configuration in High Availability Configuration Guide.
If you execute this command multiple times for the same peer or peer group, the most recent configuration takes effect.
# In BGP instance view, configure the BGP session between the local device and peer 1.1.1.1 to collaborate with the downlink interfaces of monitor link group 1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 monitor-link group 1
downlink up-delay (High Availability Command Reference)
monitor bgp (High Availability Command Reference)
monitor-link group (High Availability Command Reference)
port (High Availability Command Reference)
port monitor-link group (High Availability Command Reference)
Use peer nexthop-recursive-policy disable to disable route recursion policy control for routes received from the specified peer or peer group.
Use undo peer nexthop-recursive-policy disable to remove the configuration.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } nexthop-recursive-policy disable
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } nexthop-recursive-policy disable
The route recursion policy applies to routes received from the specified peer or peer group.
BGP instance view
If you configure routing policy-based recursive lookup for BGP routes, this route recursion policy applies to BGP routes learned from all peers. This command allows you to disable route recursion policy control for routes learned from certain peers, for example, direct EBGP peers.
# In BGP instance view, disable route recursion policy control for routes received from peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 nexthop-recursive-policy disable
peer password
Use peer password to enable MD5 authentication for a BGP peer or peer group.
Use undo peer password to remove MD5 authentication for a BGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } password { cipher | simple } password
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } password
MD5 authentication is disabled.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables MD5 authentication for all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command enables MD5 authentication for all dynamic peers in the subnet.
password: Specifies the password. Its encrypted form is a case-sensitive string of 33 to 137 characters. Its plaintext form is a case-sensitive string of 1 to 80 characters.
You can enable MD5 authentication to enhance security using the following methods:
·     Perform MD5 authentication when establishing TCP connections. Only the two parties that have the same password configured can establish TCP connections.
·     Perform MD5 calculation on TCP segments to avoid modification to the encapsulated BGP packets.
# In BGP instance view, perform MD5 authentication on the TCP connection between local router 10.1.100.1 and peer router 10.1.100.2. Set the authentication password to aabbcc in plaintext form.
[Sysname] bgp 100
[Sysname-bgp-default] peer 10.1.100.2 password simple aabbcc
peer reflect-nearby-group
Use peer reflect-nearby-group to specify a peer or peer group as a client of the nearby cluster.
Use undo peer reflect-nearby-group to remove a peer or peer group from the nearby cluster.
peer { group-name | ipv4-address [ mask-length ] } reflect-nearby-group
undo peer { group-name | ipv4-address [ mask-length ] } reflect-nearby-group
The nearby cluster does not have any clients.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies all dynamic peers in the subnet as clients of the nearby cluster.
The RR does not change the next hop of routes reflected to clients in the nearby cluster.
After you specify the RR as the next hop of routes to be reflected, you can execute this command to add a peer or peer group to the nearby cluster. Then, the RR does not change the next hop of routes reflected to the peer or peer group.
To specify the RR as the next hop of routes to be reflected, perform one of the following tasks:
·     Execute the reflect change-path-attribute command on the RR to allow the RR to change the attributes of routes to be reflected. Then, execute the peer next-hop-local command to set the local router as the next hop of routes sent to a peer or peer group.
·     Execute the reflect change-path-attribute command on the RR to allow the RR to change the attributes of routes to be reflected. Then, use a routing policy to set the RR as the next hop of routes to be reflected.
# In BGP VPNv4 address family view, specify peer 1.1.1.1 as a client of the nearby cluster.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 reflect-nearby-group
peer soo
Use peer soo to configure the Site of Origin (SoO) attribute for a BGP peer or peer group.
Use undo peer soo to remove the configuration.
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } soo
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } soo site-of-origin
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } soo
No SoO attribute is configured for a peer or peer group.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command configures the SoO attribute for all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command configures the SoO attribute for all dynamic peers in the subnet.
site-of-origin: Specifies the SoO attribute, a string of 3 to 24 characters. The SoO attribute has the following formats:
·     16-bit AS number:32-bit user-defined number. For example, 100:3.
·     32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
·     32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
·     32-bit IP address/IPv4 address mask length:16-bit user-defined number. For example, 192.168.122.15/24:1.
·     32-bit AS number in dotted format:16-bit user-defined number. For example, 65535.65535:1.
The SoO attribute specifies the site where the route was originated. It prevents advertising a route back to the originating site. If the AS-path attribute is lost, the router can use the SoO attribute to avoid routing loops.
After you configure the SoO attribute for a BGP peer or peer group, BGP adds the SoO attribute into the route updates received from the BGP peer or peer group. Before advertising route updates to the peer or peer group, BGP checks the SoO attribute of the route update against the configured SoO attribute. If they are the same, BGP does not advertise the route updates to the BGP peer or peer group to avoid loops.
If a PE configured with AS number substitution connects to multiple CEs in the same VPN site through different interfaces, routing loops will occur. To avoid routing loops, configure the same SoO attribute for the CEs on the PE.
# In BGP IPv4 unicast address family view, set the SoO attribute to 100:1 for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer 1.1.1.1 soo 100:1
peer substitute-as
peer tcp-mss
Use peer tcp-mss to set the TCP maximum segment size (MSS) for a peer or peer group.
Use undo peer tcp-mss to restore the default.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } tcp-mss mss-value
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } tcp-mss
The TCP MSS is not set.
BGP instance view
mask-length: Specifies a mask length in the range of 0 to 32. If you use the ipv4-address and mask-length arguments together to specify a subnet, this command applies to all dynamic peers in the subnet.
prefix-length: Specifies a prefix length in the range of 0 to 128. If you use the ipv6-address and prefix-length arguments together to specify a subnet, this command applies to all dynamic peers in the subnet.
mss-value: Specifies the TCP MSS in bytes. The value range for this argument is 176 to 4096.
BGP typically establishes a multihop TCP connection with a peer. Multiple intermediate devices might fragment BGP packets due to their MTU settings, resulting in frequent packet encapsulations and decapsulations that reduce forwarding efficiency.
To resolve this issue, you can execute this command to set the TCP MSS for a peer or peer group. TCP segments sent by the source will not be re-fragmented along the path to the destination.
This command might cause BGP session re-establishment. Make sure you understand the potential impact before executing this command.
During TCP connection establishment with the peer or peer group specified in the peer tcp-mss command, the minimum of the following MSSs takes effect:
·     The MSS calculated according to the IPv4 MTU set by the ip mtu command on the peer-facing interface.
·     The MSS set by the tcp mss command for the peer-facing interface.
·     The MSS calculated according to the path MTU detected by TCP path MTU discovery (enabled with the tcp path-mtu-discovery command).
·     The MSS set by the peer tcp-mss command.
The MSS is calculated by using the following formula:
MSS = path MTU (or interface MTU) – IP header length – TCP header length
For more information about MTU and MSS, see IP performance optimization configuration in Layer 3—IP Services Configuration Guide.
# Set the TCP MSS to 500 for peer group test.
[Sysname] bgp 100
[Sysname-bgp-default] peer test tcp-mss 500
Warning:This operation might reset the peer session. Continue? [Y/N]:
tcp path-mtu-discovery (Layer 3IP Services Command Reference)
peer tracking
Use peer tracking to enable peer unreachability detection.
Use undo peer tracking to disable peer unreachability detection.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } tracking [ delay delay-time ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } tracking
Peer unreachability detection is disabled.
BGP instance view
delay delay-time: Sets the delay time of peer disconnection, in seconds. The value range for the delay-time argument is 0 to 65535. If you specify this option, BGP disconnects from the specified peer or peer group immediately if that peer or peer group is detected unreachable.
Peer unreachability detection enables BGP to discover link failures quickly. With this feature enabled, BGP will disconnect from the specified peer or peer group if that peer or peer group is detected unreachable.
BGP considers a peer unreachable if one of the following conditions exists:
·     BGP cannot find a route to that peer in the routing table of the public network instance or VPN instance to which the peer belongs.
·     BGP finds the route to that peer is a blackhole route in the routing table of the public network instance or VPN instance to which the peer belongs.
When you set the delay time of peer disconnection, follow these guidelines to improve network stability:
·     To avoid IBGP session flappings caused by unstable traffic, make sure the delay time of peer disconnection specified for an IBGP peer or peer group is longer than the convergence time of IGP routes.
·     With peer unreachability detection enabled, the GR helper can detect whether the GR restarter is reachable. To ensure successful GR, make sure the delay time of peer disconnection is longer than the GR timer plus the extra timer to wait.
For more information about the GR timer and the extra timer to wait, see commands "graceful-restart timer restart" and "peer graceful-restart timer restart extra".
This command does not take effect if you specify a link-local address for the ipv6-address argument.
# Enable peer unreachability detection for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 tracking
pic
Use pic to enable BGP FRR for a BGP address family.
Use undo pic to disable BGP FRR for a BGP address family.
pic
undo pic
BGP FRR is disabled.
BGP IPv6 unicast address family view
BGP-VPN IPv6 unicast address family view
BGP EVPN address family view
FRR is used in a dual-homing network to protect a primary route with a backup route. It uses ARP (for IPv4), ND (for IPv6), or echo-mode BFD (for IPv4) to detect the connectivity of the primary route. When the primary route fails, BGP directs packets to the backup route.
After you enable FRR, BGP calculates a backup route for each BGP route in the address family if there are two or more unequal-cost routes to reach the destination.
You can also configure BGP FRR by using the fast-reroute route-policy command, which takes precedence over the pic command. For more information about routing policies, see Layer 3—IP Routing Configuration Guide.
Use the pic command with caution because it might cause routing loops in specific scenarios.
# Enable BGP FRR in BGP IPv4 unicast address family view.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] pic
primary-path-detect bfd
Use primary-path-detect bfd to configure BGP FRR to use BFD to detect next hop connectivity for the primary route.
Use undo primary-path-detect bfd to restore the default.
primary-path-detect bfd { ctrl | echo }
BGP FRR uses ARP to detect the connectivity to the next hop of the primary route.
BGP instance view
ctrl: Uses control-mode BFD to detect the connectivity to the next hop of the primary route.
echo: Uses echo-mode BFD to detect the connectivity to the next hop of the primary route.
This command enables BGP to create an IP FRR BFD session that detects next hop connectivity for the primary route. This can speed up primary and backup route switchover when the next hop of the primary route fails.
This command takes effect and creates an IP FRR BFD session only when the primary route has a backup next hop.
BGP does not support backup next hop calculation for the routes used for load balancing. This command cannot take effect when the primary route is an ECMP route. To enable BFD-based next hop detection for ECMP routes, use the primary-path-detect bfd protocol-ecmp bgp command or the primary-path-detect bfd protocol-ecmp bgp4+ command. For more information about the two commands, see basic IP routing configuration in Layer 3—IP Routing Command Reference.
BGP can establish a control-mode BFD session with a peer only after negotiation. To use control-mode BFD to detect the next hop of the primary link, perform one of the following tasks:
·     Configure the primary-path-detect bfd command on the peer device in the primary link.
This task is applicable when both ends of the primary link are configured with FRR.
·     Manually configure a static BFD session that uses the following settings on the peer device in the primary link:
¡     Source IP address: Destination IP address of the BFD session automatically created on the local device in the primary link.
¡     Destination IP address: Source IP address of the BFD session automatically created on the local device in the primary link.
¡     Remote ID: Local ID of the BFD session automatically created on the local device in the primary link.
When another routing protocol (such as RIB, OSPF, or IS-IS) uses BFD to detect next hop connectivity for the primary route, it also creates a BFD session. If the detected link is the same as the link attached to the next hop of the BGP primary route, BGP reuses the BFD session created by the protocol. In this situation, BGP will not create an additional BFD session.
# In BGP instance view, configure BGP FRR to use echo-mode BFD to detect next hop connectivity for the primary route.
[Sysname] bgp 100
[Sysname-bgp-default] primary-path-detect bfd echo
pic
primary-path-detect bfd (Layer 3—IP Routing Command Reference)
refresh bgp
Use refresh bgp to manually soft-reset BGP sessions.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | all | external | group group-name | internal } { export | import } ipv4 [ [ unicast ] [ vpn-instance vpn-instance-name ] ]
refresh bgp [ instance instance-name ] ipv6-address [ mask-length ] { export | import } ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
refresh bgp [ instance instance-name ] { ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } ipv6 [ [ unicast ] [ vpn-instance vpn-instance-name ] ]
refresh bgp [ instance instance-name ] [ link-local-address ] interface interface-type interface-number { export | import } { ipv4 | ipv6 } [ unicast ] [ vpn-instance vpn-instance-name ]
refresh bgp [ instance instance-name ] ipv4-address [ mask-length ] { export | import } ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } link-state
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | all | external | group group-name | internal } { export | import } l2vpn evpn
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command soft-resets BGP sessions for the default BGP instance.
ipv4-address: Soft-resets the BGP session to a peer specified by its IP address.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command soft-resets BGP sessions to all dynamic peers in the subnet.
ipv6-address: Soft-resets the BGP session to a peer specified by its IPv6 address.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command soft-resets BGP sessions to all dynamic peers in the subnet.
link-local-address: Specifies a peer by its link-local address. If you do not specify this option, the command specifies all link-local addresses that have established BGP sessions with the local device in the ND table entries learned by the interface specified by the interface-type interface-number argument. This argument is not supported in multicast address families.
interface interface-type interface-number: Specifies an interface by its type and number. The specified peer must have been created.
all: Soft-resets all BGP sessions.
external: Soft-resets all EBGP sessions.
group group-name: Soft-resets the BGP sessions to the peers of the specified peer group. The group-name argument refers to the name of a peer group, a case-sensitive string of 1 to 47 characters.
internal: Soft-resets all IBGP sessions.
export: Performs outbound soft-reset (filters routes advertised to the specified peer or peer group by using the new configuration).
import: Performs inbound soft-reset (filters routes received from the specified peer or peer group by using the new configuration).
ipv4: Soft-resets BGP sessions for IPv4 address family.
ipv6: Soft-resets BGP sessions for IPv6 address family.
link-state: Soft-resets BGP sessions for LS address family.
unicast: Soft-resets BGP sessions for unicast address family.
l2vpn evpn: Soft-resets BGP sessions for EVPN address family.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command soft-resets BGP sessions in the public network.
A soft-reset operation enables the router to apply a new route selection policy without tearing down BGP connections.
To apply a new policy to outbound BGP sessions, execute this command with the export keyword. The router uses the new policy to filter routing information and sends the routing information that passes the filtering to the BGP peers.
To apply a new policy to inbound sessions, execute this command with the import keyword. The router advertises a route-refresh message to the peer and the peer resends its routing information to the router. After receiving the routing information, the router uses the new policy to filter the routing information.
This command requires that both the local router and the peer support route refresh.
If the peer keep-all-routes command is configured, the refresh bgp import command does not take effect.
By default, the unicast keyword is used if you do not specify the unicast keyword.
# Soft-reset all inbound BGP sessions for the IPv4 unicast address family.
<Sysname> refresh bgp all import ipv4
reset monitor-group
Use reset monitor-group to restore the normal sessions in a peer monitoring group.
reset bgp [ instance instance-name ] monitor-group monitor-group-name
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command takes effect on the default BGP instance.
Application scenarios
With the peer monitoring group feature configured, when the number of disconnected BGP sessions reaches the specified threshold, the local device disconnects from all peers in the group. The local device will not proactively establish sessions to the devices in the group. To re-establish BGP sessions to the devices in the group, execute the reset monitor-group command.
Operating mechanism
Execute the reset monitor-group command to place the peer monitoring group in up state. Then, normal sessions in the group will be restored to Established state, and abnormal sessions remain disconnected, but these abnormal sessions no longer increase the number of disconnected BGP sessions. The number of disconnected BGP sessions accumulates only when an Established BGP peer is disconnected.
# Restore the normal sessions in peer monitoring group 1.
<Sysname> reset bgp monitor-group 1
peer monitor-group
route-select delay
Use route-select delay to configure optimal route selection delay.
Use undo route-select delay to restore the default.
The optimal route selection delay timer is 0 seconds, which means optimal route selection is not delayed.
BGP LS address family view
delay-value: Specifies the optimal route selection delay timer in the range of 0 to 600 seconds. A value of 0 means optimal route selection is not delayed.
To avoid packet loss caused by path switchover, configure this command to delay optimal route selection upon a route change.
Follow these restrictions and guidelines when you configure the command:
·     The optimal route selection delay setting applies only when multiple effective routes with the same prefix exist after a route change occurs.
·     For routes being delayed for optimal route selection, modifying the optimal route selection delay timer has the following effects:
¡     If you modify the delay timer to a non-zero value, the routes are not affected, and they still use the original delay timer.
¡     If you execute the undo form of the command or modify the delay timer to 0, the device performs optimal route selection immediately.
·     If you execute the command multiple times for an address family, the most recent configuration takes effect.
·     The optimal route selection delay configuration does not apply to the following conditions:
¡     A route change is caused by execution of a command or by route withdrawal.
¡     After a route change occurs, only one route exists for a specific destination network.
¡     An active/standby process switchover occurs.
¡     A route change occurs among equal-cost routes.
¡     Only the optimal and suboptimal routes exist when FRR is configured.
¡     Optimal route selection is triggered by a redistributed route.
¡     The next hop of the optimal route changes and a route with the same prefix is waiting for the delay timer to expire.
# In BGP IPv4 unicast address family view, set the optimal route selection delay timer to 100 seconds.
[Sysname] bgp 65009
[Sysname-bgp-default-ipv4] route-select delay 100
server vpn-instance
Use server vpn-instance to specify a VPN instance for the BMP server.
Use undo server vpn-instance to restore the default.
server vpn-instance vpn-instance-name
A BMP server belongs to the public network.
BMP server view
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified MPLS L3VPN instance must have been created.
When the specified VPN instance is deleted, the configuration of this command will not be deleted, but the connection to the BMP server will be interrupted. After the VPN instance is created again, the connection to the BMP server will be automatically re-established.
If you execute this command multiple times for a monitoring server, the most recent configuration takes effect.
# Assign BMP server 5 to VPN instance vpna.
[Sysname] bmp server 5
[Sysname-bmpserver-5] server address 100.1.1.1 port 8888
[Sysname-bmpserver-5] server vpn-instance vpna
server connect-interface
shutdown process
Use shutdown process to shut down BGP sessions to all peers and peer groups.
Use undo shutdown process to restore the default.
shutdown process
BGP does not shut down sessions to any peers or peer groups.
BGP instance view
For maintenance purposes, you can execute this command to temporarily disconnect BGP sessions from all peers and peer groups on the device. After maintenance, you can restore the sessions by simply executing the undo form of the command without reconfiguring peer or peer group settings.
This command enables the device to tear down all sessions and clear all routing information.
When you configure the shutdown process command together with the peer ignore or ignore all-peers command, follow these restrictions and guidelines:
·     Once BGP shutdown is enabled by the shutdown process command, the device cannot establish BGP sessions with all peers and peer groups.
·     To disable BGP session establishment with a peer or peer group if you have disabled BGP shutdown, perform one of the following tasks:
¡     Disable BGP session establishment with that peer or peer group by using the peer ignore command.
¡     Disable BGP session establishment with all peers and peer groups by using the ignore all-peers command.
# Shut down BGP sessions to all peers and peer groups for BGP instance 100.
[Sysname] bgp 100
[Sysname-bgp-default] shutdown process
