06-Layer 3—IP Services Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S9825 & S9855 Switch Series Configuration Guides-R913x-6W10006-Layer 3—IP Services Configuration Guide
01-ARP configuration
01-ARP configuration 266.08 KB
Configuring ARP·· 1
About ARP· 1
ARP message format 1
ARP operating mechanism·· 1
ARP entry types· 2
ARP tasks at a glance· 3
Configuring a static ARP entry· 3
Configuring a short static ARP entry· 3
Configuring a long static ARP entry· 4
Configuring features for dynamic ARP entries· 4
Setting the dynamic ARP learning limit for a device· 4
Setting the dynamic ARP learning limit for an interface· 4
Setting the aging timer for dynamic ARP entries· 5
Setting the maximum number of probes for dynamic ARP entries· 5
Setting the interval for probing dynamic ARP entries· 6
Enabling recording user IP address conflicts· 7
Enabling interface consistency check between ARP and MAC address entries· 7
Enabling recording user port migrations· 8
Enabling ARP logging· 8
Verifying and maintaining ARP· 8
Displaying ARP entries· 8
Clearing ARP entries· 9
ARP configuration examples· 9
Example: Configuring a long static ARP entry· 9
Example: Configuring a short static ARP entry· 10
Configuring gratuitous ARP·· 12
About gratuitous ARP· 12
IP conflict detection· 12
Gratuitous ARP packet learning· 12
Periodic sending of gratuitous ARP packets· 12
Gratuitous ARP tasks at a glance· 13
Enabling IP conflict notification· 13
Enabling gratuitous ARP packet learning· 13
Enabling periodic sending of gratuitous ARP packets· 13
Enabling sending gratuitous ARP packets for ARP requests with sender IP address on a different subnet 14
Configuring gratuitous ARP packet retransmission for the device MAC address change· 14
Configuring proxy ARP·· 15
About proxy ARP· 15
Enabling common proxy ARP· 15
Enabling local proxy ARP· 15
Verifying and maintaining proxy ARP· 16
Common proxy ARP configuration example· 16
Example: Configuring common proxy ARP· 16
Configuring ARP snooping· 18
About ARP snooping· 18
Creation of ARP snooping entries· 18
Aging of ARP snooping entries· 18
Protection for ARP snooping· 18
Enabling ARP snooping for a VSI 18
Verifying and maintaining ARP snooping· 18
Displaying ARP snooping entries· 18
Clearing ARP snooping entries· 19
Configuring ARP direct route advertisement 20
About ARP direct route advertisement 20
Mechanism of ARP direct route advertisement 20
Application in Layer 3 access networks· 20
Enabling ARP direct route advertisement 20
Configuring ARP
About ARP
ARP resolves IP addresses into MAC addresses on Ethernet networks.
ARP message format
ARP uses two types of messages: ARP request and ARP reply. Figure 1 shows the format of ARP request/reply messages. Numbers in the figure refer to field lengths.
Figure 1 ARP message format
·     Hardware type—Hardware address type. The value 1 represents Ethernet.
·     Protocol type—Type of the protocol address to be mapped. The hexadecimal value 0x0800 represents IP.
·     Hardware address length and protocol address length—Length, in bytes, of a hardware address and a protocol address. For an Ethernet address, the value of the hardware address length field is 6. For an IPv4 address, the value of the protocol address length field is 4.
·     OP—Operation code, which describes the type of ARP message. The value 1 represents an ARP request, and the value 2 represents an ARP reply.
·     Sender hardware address—Hardware address of the device sending the message.
·     Sender protocol address—Protocol address of the device sending the message.
·     Target hardware address—Hardware address of the device to which the message is being sent.
·     Target protocol address—Protocol address of the device to which the message is being sent.
As shown in Figure 2, Host A and Host B are on the same subnet. Host A sends a packet to Host B as follows:
1.     Host A looks through the ARP table for an ARP entry for Host B. If one entry is found, Host A uses the MAC address in the entry to encapsulate the IP packet into a data link layer frame. Then Host A sends the frame to Host B.
2.     If Host A finds no entry for Host B, Host A buffers the packet and broadcasts an ARP request. The payload of the ARP request contains the following information:
¡     Sender IP address and sender MAC address—Host A's IP address and MAC address.
¡     Target IP address—Host B's IP address.
¡     Target MAC address—An all-zero MAC address.
All hosts on this subnet can receive the broadcast request, but only the requested host (Host B) processes the request.
3.     Host B compares its own IP address with the target IP address in the ARP request. If they are the same, Host B operates as follows:
a.     Adds the sender IP address and sender MAC address into its ARP table.
b.     Encapsulates its MAC address into an ARP reply.
c.     Unicasts the ARP reply to Host A.
4.     After receiving the ARP reply, Host A operates as follows:
a.     Adds the MAC address of Host B into its ARP table.
b.     Encapsulates the MAC address into the packet and sends the packet to Host B.
Figure 2 ARP address resolution process
If Host A and Host B are on different subnets, Host A sends a packet to Host B as follows:
1.     Host A broadcasts an ARP request where the target IP address is the IP address of the gateway.
2.     The gateway responds with its MAC address in an ARP reply to Host A.
3.     Host A uses the gateway's MAC address to encapsulate the packet, and then sends the packet to the gateway.
4.     If the gateway has an ARP entry for Host B, it forwards the packet to Host B directly. If not, the gateway broadcasts an ARP request, in which the target IP address is the IP address of Host B.
5.     After the gateway gets the MAC address of Host B, it sends the packet to Host B.
ARP entry types
An ARP table stores dynamic ARP entries and static ARP entries.
Dynamic ARP entry
ARP automatically creates and updates dynamic entries. A dynamic ARP entry is removed when its aging timer expires or the output interface goes down. In addition, a dynamic ARP entry can be overwritten by a static ARP entry.
Static ARP entry
A static ARP entry is manually configured and maintained. It does not age out and cannot be overwritten by any dynamic ARP entry.
Static ARP entries protect communication between devices because attack packets cannot modify the IP-to-MAC mapping in a static ARP entry.
The device supports the following types of static ARP entries:
·     Long static ARP entry—It is directly used for forwarding packets. A long static ARP entry contains the IP address, MAC address, and one of the following combinations:
¡     VLAN and output interface.
¡     Input and output interfaces.
·     Short static ARP entry—It contains only the IP address and MAC address.
If the output interface is a Layer 3 Ethernet interface, the short ARP entry can be directly used to forward packets.
If the output interface is a VLAN interface, the device sends an ARP request whose target IP address is the IP address in the short entry. If the sender IP and MAC addresses in the received ARP reply match the short static ARP entry, the device performs the following operations:
¡     Adds the interface that received the ARP reply to the short static ARP entry.
¡     Uses the resolved short static ARP entry to forward IP packets.
To communicate with a host by using a fixed IP-to-MAC mapping, configure a short static ARP entry on the device. To communicate with a host by using a fixed IP-to-MAC mapping through an interface in a VLAN, configure a long static ARP entry on the device.
All ARP tasks are optional.
·     Configuring a static ARP entry
¡     Configuring a short static ARP entry
¡     Configuring a long static ARP entry
·     Configuring features for dynamic ARP entries
¡     Setting the dynamic ARP learning limit for a device
¡     Setting the dynamic ARP learning limit for an interface
¡     Setting the aging timer for dynamic ARP entries
¡     Setting the maximum number of probes for dynamic ARP entries
¡     Setting the interval for probing dynamic ARP entries
·     Enabling recording user IP address conflicts
·     Enabling interface consistency check between ARP and MAC address entries
·     Enabling recording user port migrations
·     Enabling ARP logging
Static ARP entries are effective when the device functions correctly.
A resolved short static ARP entry becomes unresolved upon certain events, for example, when the resolved output interface goes down, or the corresponding VLAN or VLAN interface is deleted.
2.     Configure a short static ARP entry.
arp static ip-address mac-address [ vpn-instance vpn-instance-name ]
Long static ARP entries can be effective or ineffective. Ineffective long static ARP entries cannot be used for packet forwarding. A long static ARP entry is ineffective when any of the following conditions exists:
·     The IP address in the entry conflicts with a local IP address.
·     No local interface has an IP address in the same subnet as the IP address in the ARP entry.
A long static ARP entry in a VLAN is deleted if the VLAN or VLAN interface is deleted.
2.     Configure a long static ARP entry.
arp static ip-address mac-address [ vlan-id interface-type interface-number ] [ vpn-instance vpn-instance-name ]
A device can dynamically learn ARP entries. To prevent a device from holding too many ARP entries, you can set the maximum number of dynamic ARP entries that the device can learn. When the limit is reached, the device stops ARP learning.
If you set a value lower than the number of existing dynamic ARP entries, the device does not delete the existing entries unless they age out. You can use the reset arp dynamic command to clear dynamic ARP entries.
2.     Set the dynamic ARP learning limit for the device.
arp max-learning-number max-number slot slot-number
By default, the device can learn a maximum of 163840 dynamic ARP entries.
To disable the device from dynamic ARP learning, set the value to 0.
An interface can dynamically learn ARP entries. To prevent an interface from holding too many ARP entries, you can set the maximum number of dynamic ARP entries that the interface can learn. When the limit is reached, the interface stops ARP learning.
You can set limits for both a Layer 2 interface and the VLAN interface for a permitted VLAN on the Layer 2 interface. The Layer 2 interface learns an ARP entry only when neither limit is reached.
The total dynamic ARP learning limit for all interfaces will not be higher than the dynamic ARP learning limit for the device.
2.     Enter interface view.
3.     Set the dynamic ARP learning limit for the interface.
arp max-learning-num max-number
By default, an interface can learn a maximum of 163840 dynamic ARP entries.
To disable the interface from dynamic ARP learning, set the value to 0.
Each dynamic ARP entry in the ARP table has a limited lifetime, called an aging timer. The aging timer of a dynamic ARP entry is reset each time the dynamic ARP entry is updated. A dynamic ARP entry that is not updated before its aging timer expires is deleted from the ARP table.
You can set the aging timer for dynamic ARP entries in system view or in interface view. The aging timer set in interface view takes precedence over the aging timer set in system view.
2.     Set the aging timer for dynamic ARP entries.
¡     Set the aging timer for dynamic ARP entries in system view.
arp timer aging { aging-minutes | second aging-seconds }
By default, the aging timer for dynamic ARP entries in system view is 20 minutes.
¡     Execute the following commands in sequence to set the aging timer for dynamic ARP entries in interface view:
By default, the aging timer for dynamic ARP entries in interface view is the aging timer set in system view.
This probe mechanism keeps legal dynamic ARP entries valid and avoids unnecessary ARP resolution during later traffic forwarding. It sends ARP requests for the IP address in a dynamic ARP entry.
·     If the device receives an ARP reply before the entry aging timer expires, the device resets the aging timer.
·     If the device does not receive any ARP reply after the maximum number of probes is made, the device deletes the entry when the entry aging timer expires.
You can set the maximum number of probes in system view or in interface view. The setting in interface view takes precedence over that in system view.
2.     Set the maximum number of probes for dynamic ARP entries.
¡     Set the maximum number of probes for dynamic ARP entries in system view.
arp timer aging probe-count count
By default, the maximum number of probes for dynamic ARP entries is 3 in system view.
¡     Execute the following commands in sequence to set the maximum number of probes for dynamic ARP entries on an interface:
By default, the maximum number of probes for dynamic ARP entries set on an interface is that set in system view.
The probing feature keeps legal dynamic ARP entries valid and avoids unnecessary ARP resolution during later traffic forwarding.
Before a dynamic ARP entry is aged out, the device sends ARP requests for the IP address in the ARP entry.
·     If the device receives an ARP reply during the probe interval, the device resets the aging timer.
·     If the device does not receive any ARP reply during the probe interval, the device starts a new probe.
·     If the maximum number probes are made, and still no ARP reply is received, the device deletes the entry.
You can set the probe interval in system view and in interface view. The probe interval in interface view takes precedence over the probe interval in system view.
·     If massive traffic exists in the network, set a long interval.
·     During the dynamic ARP entry probing process, a dynamic ARP entry will not be deleted when its aging time expires. If a reply is received during the probe, the aging timer of the ARP entry is reset.
·     To allow the device to perform the specified number of probes, make sure the following requirement is met:
Aging time of the dynamic ARP entries > the maximum number of probes × probe interval
2.     Set the interval for probing dynamic ARP entries.
¡     Set the interval for probing dynamic ARP entries in system view.
arp timer aging probe-interval interval
By default, the probe interval is 5 seconds.
¡     Execute the following commands in sequence to set the interval for probing dynamic ARP entries on an interface:
By default, the probe interval equals the setting in system view.
This feature enables the device to detect and record user IP address conflicts. The device determines that a conflict occurs if an incoming ARP packet has the same sender IP address as an existing ARP entry but a different sender MAC address. The device generates a user IP address conflict record, logs the conflict, and sends the log to the information center. For information about the log destination and output rule configuration in the information center, see the information center in System Management Configuration Guide.
2.     Enable recording user IP address conflicts.
arp user-ip-conflict record enable
By default, recording user IP address conflicts is disabled.
In an unstable network, the receiving interface for packets from a user might change. The interface in the MAC address entry can be updated immediately while the interface in the ARP entry cannot. In this case, the packets matching the ARP entry will be sent out of an incorrect interface. To solve this problem, you can use this feature to periodically check the interface consistency between the ARP and MAC address entry for a user. If the interfaces are not the same, ARP sends ARP requests in the VLAN of the ARP entry and updates the entry with the ARP reply receiving interface.
Use display mac-address to display MAC address entries. For more information about this command, see MAC address table in Layer 2—LAN Switching Command Reference.
2.     Enable interface consistency check between ARP and MAC address entries.
arp mac-interface-consistency check enable
By default, interface consistency check between ARP and MAC address entries is disabled.
This feature enables the device to detect and record user port migration events. A user port migrates if an incoming ARP packet has the same sender IP address and sender MAC address as an existing ARP entry but a different ingress port. The device generates a user port migration record, logs the migration event, sends the log to the information center, and updates the interface for the ARP entry. For information about the log destination and output rule configuration in the information center, see the information center in System Management Configuration Guide.
To avoid device performance degradation, disable recording user port migrations if too many user port migration logs are generated.
2.     Enable recording user port migrations.
arp user-move record enable
By default, recording user port migrations is disabled.
This feature enables a device to log ARP events when ARP cannot resolve IP addresses correctly. The log information helps administrators locate and solve problems. The device can log the following ARP events:
·     On a proxy ARP-disabled interface, the target IP address of a received ARP packet is not the IP address of the receiving interface.
·     The sender IP address of a received ARP reply conflicts with the IP address of the receiving interface.
The device sends ARP log messages to the information center. You can use the info-center source command to specify the log output rules for the information center. For more information about information center, see System Management Configuration Guide.
2.     Enable ARP logging.
arp check log enable
By default, ARP logging is disabled.
Perform all display tasks in any view.
·     Display ARP entries.
display arp [ [ all | dynamic | static ] [ slot slot-number ] | vlan vlan-id | interface interface-type interface-number ] [ count | verbose ]
·     Display the ARP entry for an IP address.
display arp ip-address [ slot slot-number ] [ verbose ]
·     Display the ARP entries for a VPN instance.
display arp vpn-instance vpn-instance-name [ count | verbose ]
·     Display the maximum number of ARP entries that a device supports.
display arp entry-limit
·     Display the aging timer of dynamic ARP entries.
display arp timer aging
·     Display user IP address conflict records.
display arp user-ip-conflict record [ slot slot-number ]
·     Display user port migration records.
display arp user-move record [ slot slot-number ]
Clearing ARP entries from the ARP table might cause communication failures. Make sure the entries to be cleared do not affect current communications.
To clear ARP entries from the ARP table, execute the following command in user view:
reset arp { all | dynamic | interface interface-type interface-number | slot slot-number | static }
CAUTION
CAUTION:
The reset arp command will clear existing ARP entries from the ARP table. It might cause that external users cannot quickly communicate with the LAN users.
As shown in Figure 3, hosts are connected to Device B. Device B is connected to Device A through interface HundredGigE 1/0/1 in VLAN 10.
To ensure secure communications between Device A and Device B, configure a long static ARP entry for Device A on Device B.
Figure 3 Network diagram
# Create VLAN 10.
[DeviceB] vlan 10
[DeviceB-vlan10] quit
# Add interface HundredGigE 1/0/1 to VLAN 10.
[DeviceB] interface hundredgige 1/0/1
[DeviceB-HundredGigE1/0/1] port access vlan 10
[DeviceB-HundredGigE1/0/1] quit
# Create VLAN-interface 10 and configure its IP address.
[DeviceB] interface vlan-interface 10
[DeviceB-vlan-interface10] ip address 192.168.1.2 8
[DeviceB-vlan-interface10] quit
# Configure a long static ARP entry that has IP address 192.168.1.1, MAC address 00e0-fc01-0000, and output interface HundredGigE 1/0/1 in VLAN 10.
[DeviceB] arp static 192.168.1.1 00e0-fc01-0000 10 hundredgige 1/0/1
# Verify that Device B has a long static ARP entry for Device A.
[DeviceB] display arp static
  Type: S-Static   D-Dynamic   O-Openflow   R-Rule  I-Invalid
IP address      MAC address    VLAN/VSI name Interface                Aging Type
192.168.1.1      00e0-fc01-0000 10        HGE1/0/1                 --    S
As shown in Figure 4, hosts are connected to Device B. Device B is connected to Device A through interface HundredGigE 1/0/2.
To ensure secure communications between Device A and Device B, configure a short static ARP entry for Device A on Device B.
Figure 4 Network diagram
# Configure an IP address for HundredGigE 1/0/2.
[DeviceB] interface hundredgige 1/0/2
[DeviceB-HundredGigE1/0/2] ip address 192.168.1.2 24
[DeviceB-HundredGigE1/0/2] quit
# Configure a short static ARP entry that has IP address 192.168.1.1 and MAC address 00e0-fc01-001f.
[DeviceB] arp static 192.168.1.1 00e0-fc01-001f
# Verify that Device B has a short static ARP entry for Device A
192.168.1.1     00e0-fc01-001f --            --                       --    S
In a gratuitous ARP packet, the sender IP address and the target IP address are the IP address of the sending device.
A device sends a gratuitous ARP packet for either of the following purposes:
·     Determine whether its IP address is already used by another device. If the IP address is already used, the device is informed of the conflict by an ARP reply.
·     Inform other devices of a MAC address change.
When an interface obtains an IP address, the device broadcasts gratuitous ARP packets in the LAN where the interface resides. If the device receives an ARP reply, its IP address conflicts with the IP address of another device in the LAN. The device displays a log message about the conflict and informs the administrator to change the IP address. The device will not use the conflicting IP address. If no ARP reply is received, the device uses the IP address.
This feature enables a device to create or update ARP entries by using the sender IP and MAC addresses in received gratuitous ARP packets.
When this feature is disabled, the device uses received gratuitous ARP packets to update existing ARP entries only. ARP entries are not created based on the received gratuitous ARP packets, which saves ARP table space.
Periodic sending of gratuitous ARP packets helps downstream devices update ARP entries or MAC entries in a timely manner.
This feature can implement the following functions:
·     Prevent gateway spoofing.
Gateway spoofing occurs when an attacker uses the gateway address to send gratuitous ARP packets to the hosts on a network. The traffic destined for the gateway from the hosts is sent to the attacker instead. As a result, the hosts cannot access the external network.
To prevent such gateway spoofing attacks, you can enable the gateway to send gratuitous ARP packets at intervals. Gratuitous ARP packets contain the primary IP address and manually configured secondary IP addresses of the gateway, so hosts can learn correct gateway information.
·     Prevent ARP entries from aging out.
If network traffic is heavy or if the host CPU usage is high, received ARP packets can be discarded or are not promptly processed. Eventually, the dynamic ARP entries on the receiving host age out. The traffic between the host and the corresponding devices is interrupted until the host re-creates the ARP entries.
To prevent this problem, you can enable the gateway to send gratuitous ARP packets periodically. Gratuitous ARP packets contain the primary IP address and manually configured secondary IP addresses of the gateway, so the receiving hosts can update ARP entries in a timely manner.
All gratuitous ARP tasks are optional. If all of the following features are disabled, gratuitous ARP still provides the IP conflict detection function.
·     Enabling IP conflict notification
·     Enabling gratuitous ARP packet learning
·     Enabling periodic sending of gratuitous ARP packets
·     Enabling sending gratuitous ARP packets for ARP requests with sender IP address on a different subnet
·     Configuring gratuitous ARP packet retransmission for the device MAC address change
Upon detecting an IP conflict, the device will sends a gratuitous ARP request. By default, the device displays an error message only after it receives an ARP reply. You can enable this feature to allow the device to display an error message immediately upon detecting an IP conflict.
2.     Enable IP conflict notification.
arp ip-conflict log prompt
By default, IP conflict notification is disabled.
2.     Enable gratuitous ARP packet learning.
gratuitous-arp-learning enable
By default, gratuitous ARP packet learning is enabled.
·     You can enable periodic sending of gratuitous ARP packets on a maximum of 1024 interfaces.
·     Periodic sending of gratuitous ARP packets takes effect on an interface only when the following conditions are met:
¡     The data link layer state of the interface is up.
¡     The interface has an IP address.
·     If you change the sending interval for gratuitous ARP packets, the configuration takes effect at the next sending interval.
·     The sending interval for gratuitous ARP packets might be much longer than the specified sending interval in any of the following circumstances:
¡     This feature is enabled on multiple interfaces.
¡     Each interface is configured with multiple secondary IP addresses.
¡     A small sending interval is configured when the previous two conditions exist.
3.     Enable periodic sending of gratuitous ARP packets.
arp send-gratuitous-arp [ interval interval ]
By default, periodic sending of gratuitous ARP packets is disabled.
2.     Enable the device to send gratuitous ARP packets upon receiving ARP requests whose sender IP address belongs to a different subnet.
gratuitous-arp-sending enable
By default, a device does not send gratuitous ARP packets upon receiving ARP requests whose sender IP address belongs to a different subnet.
The device sends a gratuitous ARP packet to inform other devices of its MAC address change. However, the other devices might fail to receive the packet because the device sends the gratuitous ARP packet once only by default. Configure the gratuitous ARP packet retransmission feature to ensure that the other devices can receive the packet.
2.     Set the times and the interval for retransmitting a gratuitous ARP packet for the device MAC address change.
gratuitous-arp mac-change retransmit times interval seconds
By default, the device sends a gratuitous packet to inform its MAC address change once only.
About proxy ARP
Proxy ARP enables a device on one network to answer ARP requests for an IP address on another network. With proxy ARP, hosts on different broadcast domains can communicate with each other as they would on the same broadcast domain.
Proxy ARP includes common proxy ARP and local proxy ARP.
·     Common proxy ARP—Allows communication between hosts that connect to different Layer 3 interfaces and reside in different broadcast domains.
·     Local proxy ARP—Allows communication between hosts that connect to the same Layer 3 interface and reside in different broadcast domains.
Common proxy ARP is available on the following types of interfaces:
¡     VLAN interface.
¡     Layer 3 Ethernet interface.
¡     Layer 3 Ethernet subinterface.
¡     Layer 3 aggregate interface.
¡     Layer 3 aggregate subinterface.
3.     Enable common proxy ARP.
proxy-arp enable
By default, common proxy ARP is disabled.
Local proxy ARP is available on the following types of interfaces:
¡     VLAN interface.
3.     Enable local proxy ARP.
local-proxy-arp enable [ ip-range start-ip-address to end-ip-address ]
By default, local proxy ARP is disabled.
·     Display common proxy ARP status.
display proxy-arp [ interface interface-type interface-number ]
·     Display local proxy ARP status.
display local-proxy-arp [ interface interface-type interface-number ]
·     Display statistics for proxy ARP reply packets.
display proxy-arp statistics
As shown in Figure 5, Host A and Host D have the same IP prefix and mask, but they are located on different subnets separated by the switch. Host A belongs to VLAN 1, and Host D belongs to VLAN 2. No default gateway is configured on Host A and Host D.
Configure common proxy ARP on the switch to enable communication between the two hosts.
Figure 5 Network diagram
# Create VLAN 2.
<Switch> system-view
[Switch] vlan 2
[Switch-vlan2] quit
# Configure the IP address of VLAN-interface 1.
[Switch] interface vlan-interface 1
[Switch-Vlan-interface1] ip address 192.168.10.99 255.255.255.0
# Enable common proxy ARP on VLAN-interface 1.
[Switch-Vlan-interface1] proxy-arp enable
[Switch-Vlan-interface1] quit
# Configure the IP address of VLAN-interface 2.
[Switch-Vlan-interface2] ip address 192.168.20.99 255.255.255.0
# Enable common proxy ARP on VLAN-interface 2.
[Switch-Vlan-interface2] proxy-arp enable.
# Verify that Host A and Host D can ping each other.
About ARP snooping
ARP snooping is used in Layer 2 switching networks. It creates ARP snooping entries by using information in ARP packets. ARP fast-reply and manual-mode MFF can use the ARP snooping entries. For more information about MFF, see Security Configuration Guide.
If you enable ARP snooping for a VXLAN, ARP packets received in the VXLAN are redirected to the CPU. The CPU uses the sender IP and MAC addresses of the ARP packets, VSI name, and link ID of the outgoing link to create ARP snooping entries. For more information about VXLAN, see VXLAN Configuration Guide.
The aging timer and valid period of an ARP snooping entry are 25 minutes and 15 minutes. If an ARP snooping entry is not updated in 12 minutes, the device sends an ARP request. The ARP request uses the IP address of the entry as the target IP address. If an ARP snooping entry is not updated in 15 minutes, it becomes invalid and cannot be used. After that, if an ARP packet matching the entry is received, the entry becomes valid, and its aging timer restarts.
If the aging timer of an ARP snooping entry expires, the entry is removed.
On a VXLAN network, the device updates the valid ARP snooping entry instead of removing the entry.
2.     Enter VSI view.
vsi vsi-name
3.     Enable ARP snooping for the VSI.
arp snooping enable
By default, ARP snooping is disabled for a VSI.
To display ARP snooping entries, execute the following command in any view:
display arp snooping vsi [vsi-name ] [ slot slot-number ] [ count ]
To clear ARP snooping entries, execute the following command in user view:
reset arp snooping vsi [vsi-name ]
This feature generates host routes based on ARP entries for packet forwarding and route advertisement. The route preference value determines the match order of a route. Dynamic routing protocols use the tag value as the route identifier when they redistribute the route.
After you enable ARP direct route advertisement on an interface, the device generates direct routes and adjacency table entries based on ARP entries learned on that interface. If the direct routes are generated before the adjacency table entries for them, temporary packet loss will occur due to lack of Layer 2 information for packet encapsulation. To avoid such an issue, set a route generation delay for ARP direct route advertisement on the interface.
If you edit the direct route advertisement configuration before the delay timer expires, the device advertises the direct route based on the new configuration immediately.
The direct routes generated for interfaces are typically network routes. On host-attached interfaces, you can enable ARP direct route advertisement to have the device generate and advertise host routes based on ARP entries. This helps conserve bandwidth by preventing traffic not destined for the hosts attached to those interfaces from being sent to the device.
As shown in Figure 6, enable ARP direct route advertisement on server-attached Interface A and Interface B. This feature generates a host route to Server A and a host route to Server B for the routing protocols to advertise. So each device forwards only the traffic destined to the server within the network, which saves bandwidth.
Figure 6 Application in a Layer 3 access network
3.     (Optional.) Set a route generation delay for ARP direct route advertisement.
arp route-direct advertise delay delay-time
By default, the device generates a direct route immediately after an ARP entry is learned on an interface enabled with ARP direct route advertisement.
4.     Enable the ARP direct route advertisement feature.
arp route-direct advertise [ preference preference-value | tag tag-value ] *
By default, the ARP direct route advertisement feature is disabled.
