14-User Access and Authentication Configuration Guide
HomeSupportSwitchesS12500R SeriesConfigure & DeployConfiguration GuidesH3C S12500R-48Y8C&S12500R-48C6D Switch Router Configuration Guides(R52xx)-6W10114-User Access and Authentication Configuration Guide
01-AAA configuration
01-AAA configuration 1.10 MB
Configuring AAA·· 1
About AAA· 1
AAA implementation· 1
AAA network diagram·· 1
RADIUS· 2
HWTACACS· 5
User management based on ISP domains and user access types· 7
Authentication, authorization, and accounting methods· 7
AAA extended functions· 9
AAA for VPNs· 9
Protocols and standards· 10
AAA tasks at a glance· 10
Configuring local users· 11
About local users· 11
Local user configuration tasks at a glance· 11
Configuring attributes for device management users· 12
Configuring user group attributes· 13
Verifying and maintaining local users· 14
Configuring RADIUS· 14
RADIUS tasks at a glance· 14
Configuring a test profile for RADIUS server status detection· 15
Creating a RADIUS scheme· 16
Specifying RADIUS authentication servers· 17
Specifying the RADIUS accounting servers· 17
Specifying private RADIUS servers· 18
Specifying the shared keys for secure RADIUS communication· 20
Specifying the MPLS L3VPN instance for a RADIUS scheme· 20
Setting the status of RADIUS servers· 20
Setting RADIUS timers· 22
Specifying the source IP address of outgoing RADIUS packets· 23
Setting the username format and traffic statistics units· 24
Setting the maximum number of RADIUS request transmission attempts· 25
Setting the maximum number of real-time accounting attempts· 25
Setting the DSCP priority for RADIUS packets· 26
Specifying the NAS IP address of RADIUS packets· 26
Configuring the Login-Service attribute check method for SSH, FTP, and terminal users· 27
Interpreting the RADIUS class attribute as CAR parameters· 28
Configuring the MAC address format for the RADIUS Called-Station-Id attribute· 28
Configuring the MAC address format for RADIUS Calling-Station-Id attribute· 29
Setting the data measurement unit for the Remanent_Volume attribute· 29
Specifying a server version for interoperating with servers with a vendor ID of 2011· 29
Specifying the format for attribute Acct-Session-Id· 30
Including subattribute 218 of vendor 25506 in outgoing RADIUS packets· 30
Configuring the RADIUS attribute translation feature· 31
Specifying the action to take for AAA requests if all RADIUS servers are blocked· 32
Configuring RADIUS stop-accounting packet buffering· 33
Enabling forcibly sending stop-accounting packets· 33
Enabling the RADIUS server load sharing feature· 34
Specifying a RADIUS server selection mode for reauthentication· 34
Configuring the RADIUS accounting-on feature· 35
Configuring the RADIUS session-control feature· 35
Setting the available data threshold· 36
Enabling SNMP notifications for RADIUS· 36
Disabling the RADIUS service· 37
Verifying and maintaining RADIUS· 38
Configuring HWTACACS· 38
HWTACACS tasks at a glance· 38
Creating an HWTACACS scheme· 39
Specifying the HWTACACS authentication servers· 39
Specifying the HWTACACS authorization servers· 40
Specifying the HWTACACS accounting servers· 40
Specifying the shared keys for secure HWTACACS communication· 41
Specifying an MPLS L3VPN instance for the scheme· 41
Setting HWTACACS timers· 42
Specifying the source IP address of outgoing HWTACACS packets· 43
Setting the username format and traffic statistics units· 44
Setting the DSCP priority for HWTACACS packets· 45
Specifying the action to take for AAA requests if all HWTACACS servers are blocked· 45
Configuring HWTACACS stop-accounting packet buffering· 46
Verifying and maintaining HWTACACS· 46
Creating an ISP domain· 47
About ISP domains· 47
Restrictions and guidelines for ISP domain configuration· 47
Specifying the default ISP domain· 48
Specifying an ISP domain for users that are assigned to nonexistent domains· 48
Configuring ISP domain attributes· 48
Setting ISP domain status· 48
Configuring authorization attributes for an ISP domain· 49
Including the idle timeout period in the user online duration to be sent to the server 49
Configuring AAA methods for an ISP domain· 49
Configuring authentication methods for an ISP domain· 49
Configuring authorization methods for an ISP domain· 51
Configuring accounting methods for an ISP domain· 52
Verifying and maintaining ISP domains· 54
Setting the maximum number of concurrent login users· 54
Configuring a NAS-ID·· 54
About NAS-IDs· 54
Setting the NAS-ID in an ISP domain· 54
Configuring the device ID·· 54
Enabling password change prompt logging· 55
Configuring an EAP profile· 56
Configuring user online and offline recording· 57
About user online and offline recording· 57
Restrictions and guidelines for user online and offline recording configuration· 57
Enabling user online failure recording· 57
Enabling user offline recording· 57
Verifying and maintaining user online and offline records· 58
Configuring the connection recording policy· 59
About the connection recording policy· 59
Restrictions and guidelines· 59
Procedure· 59
Verifying and maintaining the connection recording policy· 59
Configuring the AAA test feature· 60
AAA configuration examples· 63
Example: Configuring authentication and authorization for SSH users by a RADIUS server 63
Example: Configuring local authentication and authorization for SSH users· 66
Example: Configuring AAA for SSH users by an HWTACACS server 68
Troubleshooting AAA· 69
RADIUS authentication failure· 69
RADIUS packet delivery failure· 70
RADIUS accounting error 70
Troubleshooting HWTACACS· 71
Appendixes· 71
Appendix A  Commonly used RADIUS attributes· 71
Appendix B  Descriptions of commonly used standard RADIUS attributes· 72
Appendix C  RADIUS subattributes (vendor ID 25506) 74
Appendix D  HWTACACS attributes· 77
Configuring AAA
About AAA
AAA implementation
Authentication, Authorization, and Accounting (AAA) provides a uniform framework for implementing network access management. This feature specifies the following security functions:
·     Authentication—Identifies users and verifies their validity.
·     Authorization—Grants different users different rights, and controls the users' access to resources and services. For example, you can permit office users to read and print files and prevent guests from accessing files on the device.
·     Accounting—Records network usage details of users, including the service type, start time, and traffic. This function enables time-based and traffic-based charging and user behavior auditing.
AAA network diagram
AAA uses a client/server model. The client runs on the access device, or the network access server (NAS), which authenticates user identities and controls user access. The server maintains user information centrally. See Figure 1.
Figure 1 AAA network diagram
To access networks or resources beyond the NAS, a user sends its identity information to the NAS. The NAS transparently passes the user information to AAA servers and waits for the authentication, authorization, and accounting result. Based on the result, the NAS determines whether to permit or deny the access request.
AAA has various implementations, including HWTACACS and RADIUS. RADIUS is most often used.
You can use different servers to implement different security functions. For example, you can use an HWTACACS server for authentication and authorization, and use a RADIUS server for accounting.
You can choose the security functions provided by AAA as needed. For example, if your company wants employees to be authenticated before they access specific resources, you would deploy an authentication server. If network usage information is needed, you would also configure an accounting server.
The device performs dynamic password authentication.
RADIUS
Remote Authentication Dial-In User Service (RADIUS) is a distributed information interaction protocol that uses a client/server model. The protocol can protect networks against unauthorized access and is often used in network environments that require both high security and remote user access.
The RADIUS authorization process is combined with the RADIUS authentication process, and user authorization information is piggybacked in authentication responses. RADIUS uses UDP port 1812 for authentication and UDP port 1813 for accounting.
RADIUS was originally designed for dial-in user access, and has been extended to support additional access methods, such as Ethernet and ADSL.
Client/server model
The RADIUS client runs on the NASs located throughout the network. It passes user information to RADIUS servers and acts on the responses to, for example, reject or accept user access requests.
The RADIUS server runs on the computer or workstation at the network center and maintains information related to user authentication and network service access.
The RADIUS server operates using the following process:
1.     Receives authentication, authorization, and accounting requests from RADIUS clients.
2.     Performs user authentication, authorization, or accounting.
3.     Returns user access control information (for example, rejecting or accepting the user access request) to the clients.
The RADIUS server can also act as the client of another RADIUS server to provide authentication proxy services.
The RADIUS server maintains the following databases:
·     Users—Stores user information, such as the usernames, passwords, applied protocols, and IP addresses.
·     Clients—Stores information about RADIUS clients, such as shared keys and IP addresses.
·     Dictionary—Stores RADIUS protocol attributes and their values.
Figure 2 RADIUS server databases
Information exchange security mechanism
The RADIUS client and server exchange information between them with the help of shared keys, which are preconfigured on the client and server. A RADIUS packet has a 16-byte field called Authenticator. This field includes a signature generated by using the MD5 algorithm, the shared key, and some other information. The receiver of the packet verifies the signature and accepts the packet only when the signature is correct. This mechanism ensures the security of information exchanged between the RADIUS client and server.
The shared keys are also used to encrypt user passwords that are included in RADIUS packets.
User authentication methods
The RADIUS server supports multiple user authentication methods, such as PAP, CHAP, and EAP.
Basic RADIUS packet exchange process
Figure 3 illustrates the interactions between a user host, the RADIUS client, and the RADIUS server.
Figure 3 Basic RADIUS packet exchange process
RADIUS uses in the following workflow:
1.     The host sends a connection request that includes the user's username and password to the RADIUS client.
2.     The RADIUS client sends an authentication request (Access-Request) to the RADIUS server. The request includes the user's password, which has been processed by the MD5 algorithm and shared key.
3.     The RADIUS server authenticates the username and password. If the authentication succeeds, the server sends back an Access-Accept packet that contains the user's authorization information. If the authentication fails, the server returns an Access-Reject packet.
4.     The RADIUS client permits or denies the user according to the authentication result. If the result permits the user, the RADIUS client sends a start-accounting request (Accounting-Request) packet to the RADIUS server.
5.     The RADIUS server returns an acknowledgment (Accounting-Response) packet and starts accounting.
6.     The user accesses the network resources.
7.     The host requests the RADIUS client to tear down the connection.
8.     The RADIUS client sends a stop-accounting request (Accounting-Request) packet to the RADIUS server.
9.     The RADIUS server returns an acknowledgment (Accounting-Response) and stops accounting for the user.
10.     The RADIUS client notifies the user of the termination.
RADIUS packet format
RADIUS uses UDP to transmit packets. The protocol also uses a series of mechanisms to ensure smooth packet exchange between the RADIUS server and the client. These mechanisms include the timer mechanism, the retransmission mechanism, and the backup server mechanism.
Figure 4 RADIUS packet format
Descriptions of the fields are as follows:
·     The Code field (1 byte long) indicates the type of the RADIUS packet. Table 1 gives the main values and their meanings.
Table 1 Main values of the Code field
Code
Packet type
1
Access-Request
From the client to the server. A packet of this type includes user information for the server to authenticate the user. It must contain the User-Name attribute and can optionally contain the attributes of NAS-IP-Address, User-Password, and NAS-Port.
2
Access-Accept
From the server to the client. If all attribute values included in the Access-Request are acceptable, the authentication succeeds, and the server sends an Access-Accept response.
3
Access-Reject
From the server to the client. If any attribute value included in the Access-Request is unacceptable, the authentication fails, and the server sends an Access-Reject response.
4
Accounting-Request
From the client to the server. A packet of this type includes user information for the server to start or stop accounting for the user. The Acct-Status-Type attribute in the packet indicates whether to start or stop accounting.
5
Accounting-Response
From the server to the client. The server sends a packet of this type to notify the client that it has received the Accounting-Request and has successfully recorded the accounting information.
·     The Identifier field (1 byte long) is used to match response packets with request packets and to detect duplicate request packets. The request and response packets of the same exchange process for the same purpose (such as authentication or accounting) have the same identifier.
·     The Length field (2 bytes long) indicates the length of the entire packet (in bytes), including the Code, Identifier, Length, Authenticator, and Attributes fields. Bytes beyond this length are considered padding and are ignored by the receiver. If the length of a received packet is less than this length, the packet is dropped.
·     The Authenticator field (16 bytes long) is used to authenticate responses from the RADIUS server and to encrypt user passwords. There are two types of authenticators: request authenticator and response authenticator.
·     The Attributes field (variable in length) includes authentication, authorization, and accounting information. This field can contain multiple attributes, each with the following subfields:
¡     Type—Type of the attribute.
¡     Length—Length of the attribute in bytes, including the Type, Length, and Value subfields.
¡     Value—Value of the attribute. Its format and content depend on the Type subfield.
Extended RADIUS attributes
The RADIUS protocol features excellent extensibility. The Vendor-Specific attribute (attribute 26) allows a vendor to define extended attributes. The extended attributes can implement functions that the standard RADIUS protocol does not provide.
A vendor can encapsulate multiple subattributes in the TLV format in attribute 26 to provide extended functions. As shown in Figure 5, a subattribute encapsulated in attribute 26 consists of the following parts:
·     Vendor-ID—ID of the vendor. The most significant byte is 0. The other three bytes contains a code compliant to RFC 1700.
·     Vendor-Type—Type of the subattribute.
·     Vendor-Length—Length of the subattribute.
·     Vendor-Data—Contents of the subattribute.
The device supports private RADIUS subattributes with a vendor ID of 25506. For more information, see "Appendix C  RADIUS subattributes (vendor ID 25506)."
Figure 5 Format of attribute 26
HWTACACS
HW Terminal Access Controller Access Control System (HWTACACS) is an enhanced security protocol based on TACACS (RFC 1492). HWTACACS is similar to RADIUS, and uses a client/server model for information exchange between the NAS and the HWTACACS server.
HWTACACS typically provides AAA services for VPDN and terminal users. In a typical HWTACACS scenario, terminal users need to log in to the NAS. Working as the HWTACACS client, the NAS sends users' usernames and passwords to the HWTACACS server for authentication. After passing authentication and obtaining authorized rights, a user logs in to the device and performs operations. The HWTACACS server records the operations that each user performs.
Differences between HWTACACS and RADIUS
HWTACACS and RADIUS have many features in common, such as using a client/server model, using shared keys for data encryption, and providing flexibility and scalability. Table 2 lists the primary differences between HWTACACS and RADIUS.
Table 2 Primary differences between HWTACACS and RADIUS
HWTACACS
RADIUS
Uses TCP, which provides reliable network transmission.
Uses UDP, which provides high transport efficiency.
Encrypts the entire packet except for the HWTACACS header.
Encrypts only the user password field in an authentication packet.
Protocol packets are complicated and authorization is independent of authentication. Authentication and authorization can be deployed on different HWTACACS servers.
Protocol packets are simple and the authorization process is combined with the authentication process.
Supports configuration command authorization. Access to commands depends on both the user's roles and authorization. A user can use only commands that are permitted by the user roles and authorized by the HWTACACS server.
Does not support configuration command authorization. Access to commands solely depends on the user's roles. For more information about user roles, see Fundamentals Configuration Guide.
Basic HWTACACS packet exchange process
Figure 6 describes how HWTACACS performs user authentication, authorization, and accounting for a Telnet user.
Figure 6 Basic HWTACACS packet exchange process for a Telnet user
HWTACACS operates using in the following workflow:
1.     A Telnet user requests to Telnet to the device (HWTACACS client) and provides the username and password as instructed by the system.
2.     The HWTACACS client sends a start-authentication request that includes the username to the HWTACACS server when it receives the Telnet request.
3.     The HWTACACS server sends back an authentication response to request the login password.
4.     Upon receipt of the response, the HWTACACS client sends the HWTACACS server a continue-authentication packet that includes the login password.
5.     If the authentication succeeds, the HWTACACS server sends back an authentication response to indicate that the user has passed authentication.
6.     The HWTACACS client sends a user authorization request packet to the HWTACACS server.
7.     If the authorization succeeds, the HWTACACS server sends back an authorization response, indicating that the user is now authorized.
8.     Knowing that the user is now authorized, the HWTACACS client pushes its CLI to the user and permits the user to log in.
9.     The HWTACACS client sends a start-accounting request to the HWTACACS server.
10.     The HWTACACS server sends back an accounting response, indicating that it has received the start-accounting request.
11.     The user logs off.
12.     The HWTACACS client sends a stop-accounting request to the HWTACACS server.
13.     The HWTACACS server sends back a stop-accounting response, indicating that the stop-accounting request has been received.
AAA manages users based on the users' ISP domains and access types.
On a NAS, each user belongs to one ISP domain. The NAS determines the ISP domain to which a user belongs based on the username entered by the user at login.
Figure 7 Determining the ISP domain for a user by username
AAA manages users in the same ISP domain based on the users' access types. The device supports the following user access types:
·     Login—Login users include SSH, Telnet, FTP, and terminal users that log in to the device. Terminal users can access through a console port.
·     HTTP/HTTPS—Users log in to the device through HTTP or HTTPS.
As shown in Figure 8, an ISP domain represents a set of authentication, authorization, and accounting methods for different types of users. The NAS determines the ISP domain and access type of a user. The NAS also uses the methods configured for the access type in the domain to control the user's access.
AAA also supports configuring a set of default methods for an ISP domain. These default methods are applied to users for whom no AAA methods are configured.
Figure 8 AAA configuration structure for an ISP domain
Authentication methods
The device supports the following authentication methods:
·     No authentication—This method trusts all users and does not perform authentication. For security purposes, do not use this method.
·     Local authentication—The NAS authenticates users by itself, based on the locally configured user information including the usernames, passwords, and attributes. Local authentication allows high speed and low cost, but the amount of information that can be stored is limited by the size of the storage space.
·     Remote authentication—The NAS works with a remote server to authenticate users. The NAS communicates with the remote server through the RADIUS or HWTACACS protocol. The server manages user information in a centralized manner. Remote authentication provides high capacity, reliable, and centralized authentication services for multiple NASs. You can configure backup methods to be used when the remote server is not available.
Authorization methods
The device supports the following authorization methods:
·     No authorization—The NAS performs no authorization exchange. The following default authorization information applies after users pass authentication:
¡     Login users obtain the level-0 user role. For more information about the level-0 user role, see RBAC configuration in Fundamentals Configuration Guide.
¡     The working directory for FTP, SFTP, and SCP login users is the root directory of the NAS. However, the users do not have permission to access the root directory.
·     Local authorization—The NAS performs authorization according to the user attributes locally configured for users.
·     Remote authorization—The NAS works with a remote server to authorize users. RADIUS authorization is bound with RADIUS authentication. RADIUS authorization can work only after RADIUS authentication is successful, and the authorization information is included in the Access-Accept packet. HWTACACS authorization is separate from authentication, and the authorization information is included in the authorization response after successful authentication. You can configure backup methods to be used when the remote server is not available.
Accounting methods
The device supports the following accounting methods:
·     No accounting—The NAS does not perform accounting for the users.
·     Local accounting—Local accounting is implemented on the NAS. It counts and controls the number of concurrent users that use the same local user account, but does not provide statistics for charging.
·     Remote accounting—The NAS works with a RADIUS server or HWTACACS server for accounting. You can configure backup methods to be used when the remote server is not available.
Authorization attribute configuration methods
You can configure authorization attributes for an ISP domain on the NAS, on a server, or on both the NAS and a server. Typically, server-assigned authorization attributes have higher priority than NAS-assigned settings. NAS-assigned attributes can take effect only if they do not conflict with server-assigned attributes. If a NAS-assigned attribute conflicts with a server-assigned attribute, the server-assigned attribute takes effect.
The device provides the following login services to enhance device security:
·     Command authorization—Enables the NAS to let the authorization server determine whether a command entered by a login user is permitted. Login users can execute only commands permitted by the authorization server. For more information about command authorization, see controlling user access to the device in Fundamentals Configuration Guide.
·     Command accounting—When command authorization is disabled, command accounting enables the accounting server to record all valid commands executed on the device. When command authorization is enabled, command accounting enables the accounting server to record all authorized commands. For more information about command accounting, see controlling user access to the device in Fundamentals Configuration Guide.
·     User role authentication—Authenticates each user that wants to obtain another user role without logging out or getting disconnected. For more information about user role authentication, see Fundamentals Configuration Guide.
AAA for VPNs
You can deploy AAA across VPNs to enable forwarding of authentication, authorization, and accounting packets across VPNs. For example, as shown in Figure 9, the PE at the left side of the MPLS backbone acts as a NAS. The NAS transparently delivers the AAA packets of private users in VPN 1 and VPN 2 to the AAA servers in VPN 3 for centralized authentication. Authentication packets of private users in different VPNs do not affect each other.
Figure 9 Network diagram
·     RFC 2865, Remote Authentication Dial In User Service (RADIUS)
·     RFC 2866, RADIUS Accounting
·     RFC 2867, RADIUS Accounting Modifications for Tunnel Protocol Support
·     RFC 2868, RADIUS Attributes for Tunnel Protocol Support
·     RFC 2869, RADIUS Extensions
·     RFC 3576, Dynamic Authorization Extensions to Remote Authentication Dial In User Service (RADIUS)
·     RFC 4818, RADIUS Delegated-IPv6-Prefix Attribute
·     RFC 5176, Dynamic Authorization Extensions to Remote Authentication Dial In User Service (RADIUS)
·     RFC 1492, An Access Control Protocol, Sometimes Called TACACS
To configure AAA, perform the following tasks:
1.     Configuring AAA schemes
If local authentication is used, configure local users and the related attributes. If remote authentication is used, configure the required RADIUS or HWTACACS schemes.
¡     Configuring local users
¡     Configuring RADIUS
¡     Configuring HWTACACS
2.     Configuring an ISP domain
a.     Creating an ISP domain
b.     Configuring ISP domain attributes
3.     Configuring AAA methods for an ISP domain
Configure authentication, authorization, and accounting methods for an ISP domain as needed. These methods use existing AAA schemes.
¡     Configuring authentication methods for an ISP domain
¡     Configuring authorization methods for an ISP domain
¡     Configuring accounting methods for an ISP domain
4.     (Optional.) Configuring advanced AAA features
¡     Setting the maximum number of concurrent login users
¡     Configuring a NAS-ID
¡     Configuring the device ID
¡     Enabling password change prompt logging
¡     Configuring an EAP profile
¡     Configuring user online and offline recording
¡     Configuring the connection recording policy
¡     Configuring the AAA test feature
About local users
To implement local authentication, authorization, and accounting, create local users and configure user attributes on the device. The local users and attributes are stored in the local user database on the device. A local user is uniquely identified by the combination of a username and a user type.
The following shows the configurable local user attributes:
·     Service type—Services that the user can use. Local authentication checks the service types of a local user. If none of the service types is available, the user cannot pass authentication.
·     User state—Whether or not a local user can request network services. There are two user states: active and blocked. A user in active state can request network services, but a user in blocked state cannot.
·     Upper limit of concurrent logins using the same user name—Maximum number of users that can concurrently access the device by using the same user name. When the number reaches the upper limit, no more local users can access the device by using the user name.
·     User group—Each local user belongs to a local user group and has all attributes of the group. The attributes include the password control attributes and authorization attributes. For more information about local user group, see "Configuring user group attributes."
·     Authorization attributes—Authorization attributes indicate the user's rights after it passes local authentication.
Configure the authorization attributes based on the service type of local users.
You can configure an authorization attribute in user group view or local user view. The setting of an authorization attribute in local user view takes precedence over the attribute setting in user group view.
The attribute configured in user group view takes effect on all local users in the user group.
The attribute configured in local user view takes effect only on the local user.
·     Password control attributes—Password control attributes help control password security for local users. Password control attributes include password aging time, minimum password length, password composition checking, password complexity checking, and login attempt limit.
You can configure a password control attribute in system view, user group view, or local user view. A password control attribute with a smaller effective range has a higher priority. For more information about password management and global password configuration, see "Configuring password control."
To configure local users, perform the following tasks:
1.     Configuring attributes for device management users
2.     (Optional.) Configuring user group attributes
If password control is globally enabled by using the password-control enable command, the device neither displays local user passwords nor retains them in the running configuration. When you globally disable password control, local user passwords are automatically restored to the running configuration. To display the running configuration, use the display current-configuration command.
You can configure authorization attributes and password control attributes in local user view or user group view. The setting in local user view takes precedence over the setting in user group view.
2.     Add a device management user and enter device management user view.
3.     Configure a password for the device management user.
password [ { hash | simple } string ]
A non-password-protected user passes authentication if the user provides the correct username and passes attribute checks. To enhance security, configure a password for each device management user.
4.     Assign services to the device management user.
service-type { ftp | { http | https | ssh | telnet | terminal } * }
By default, no services are authorized to a device management user.
5.     (Optional.) Set the status of the device management user.
state { active | block }
By default, a device management user is in active state and can request network services.
6.     (Optional.) Set the upper limit of concurrent logins using the device management username.
access-limit max-user-number
By default, the number of concurrent logins is not limited for a device management user.
This command takes effect only when local accounting is configured for device management users. This command does not apply to FTP, SFTP, or SCP users that do not support accounting.
7.     (Optional.) Configure authorization attributes for the device management user.
authorization-attribute { idle-cut minutes | user-role role-name | work-directory directory-name } *
The following default settings apply:
¡     The working directory for FTP, SFTP, and SCP users is the root directory of the NAS. However, the users do not have permission to access the root directory.
¡     The network-operator user role is assigned to local users that are created by a network-admin or level-15 user.
8.     (Optional.) Configure password control attributes for the device management user. Choose the following tasks as needed:
¡     Set the password aging time.
¡     Set the minimum password length.
¡     Configure the password composition policy.
¡     Configure the password complexity checking policy.
¡     Configure the maximum login attempts and the action to take if there is a login failure.
By default, a device management user uses password control attributes of the user group to which the user belongs.
9.     (Optional.) Assign the device management user to a user group.
group group-name
By default, a device management user belongs to user group system.
User groups simplify local user configuration and management. A user group contains a group of local users and has a set of local user attributes. You can configure local user attributes for a user group to implement centralized user attributes management for the local users in the group. Local user attributes that are manageable include authorization attributes.
2.     Create a user group and enter user group view.
user-group group-name
By default, a system-defined user group exists. The group name is system.
3.     Configure authorization attributes for the user group.
authorization-attribute { idle-cut minutes | work-directory directory-name } *
By default, no authorization attributes are configured for a user group.
4.     (Optional.) Configure password control attributes for the user group. Choose the following tasks as needed:
¡     Configure the maximum login attempts and the action to take for login failures.
By default, a user group uses the global password control settings. For more information, see "Configuring password control."
Displaying local user and user group information
·     Display the local user configuration and online user statistics.
display local-user [ class manage | idle-cut { disable | enable } | service-type { ftp | http | https | ssh | telnet | terminal } | state { active | block } | user-name user-name class manage | vlan vlan-id ]
·     Display user group configuration.
display user-group { all | name group-name }
Configuring RADIUS
To configure RADIUS, perform the following tasks:
1.     Configuring an EAP profile
To perform EAP-based RADIUS server status detection, you must configure an EAP profile and specify the EAP profile in a test profile.
2.     Configuring a test profile for RADIUS server status detection
To detect the status of a RADIUS server, you must configure a test profile and configure the RADIUS server to use the test profile in a RADIUS scheme.
3.     Creating a RADIUS scheme
4.     Specifying RADIUS authentication servers
5.     Specifying the RADIUS accounting servers
6.     Specifying private RADIUS servers
Perform this task only when the AAA module must process authentication and accounting requests that specify RADIUS server addresses.
7.     Specifying the shared keys for secure RADIUS communication
Perform this task if no shared keys are specified when configuring RADIUS authentication or accounting servers.
8.     Specifying the MPLS L3VPN instance for a RADIUS scheme
Perform this task if no MPLS L3VPN instances are specified when configuring RADIUS authentication or accounting servers.
9.     (Optional.) Setting the status of RADIUS servers
10.     (Optional.) Setting RADIUS timers
11.     (Optional.) Configuring parameters for RADIUS packets
¡     Specifying the source IP address of outgoing RADIUS packets
¡     Setting the username format and traffic statistics units
¡     Setting the maximum number of RADIUS request transmission attempts
¡     Setting the maximum number of real-time accounting attempts
¡     Setting the DSCP priority for RADIUS packets
¡     Specifying the NAS IP address of RADIUS packets
12.     (Optional.) Configuring parameters for RADIUS attributes
¡     Configuring the Login-Service attribute check method for SSH, FTP, and terminal users
¡     Interpreting the RADIUS class attribute as CAR parameters
¡     Configuring the MAC address format for the RADIUS Called-Station-Id attribute
¡     Configuring the MAC address format for RADIUS Calling-Station-Id attribute
¡     Setting the data measurement unit for the Remanent_Volume attribute
¡     Specifying a server version for interoperating with servers with a vendor ID of 2011
¡     Specifying the format for attribute Acct-Session-Id
¡     Including subattribute 218 of vendor 25506 in outgoing RADIUS packets
¡     Configuring the RADIUS attribute translation feature
13.     (Optional.) Configuring extended RADIUS features
¡     Specifying the action to take for AAA requests if all RADIUS servers are blocked
¡     Configuring RADIUS stop-accounting packet buffering
¡     Enabling forcibly sending stop-accounting packets
¡     Enabling the RADIUS server load sharing feature
¡     Specifying a RADIUS server selection mode for reauthentication
¡     Configuring the RADIUS accounting-on feature
¡     Configuring the RADIUS session-control feature
¡     Setting the available data threshold
¡     Enabling SNMP notifications for RADIUS
¡     Disabling the RADIUS service
To detect the reachability or availability of a RADIUS authentication server, specify a test profile for the RADIUS server when you specify the server in a RADIUS scheme. With the test profile, the device refreshes the RADIUS server status according to the detection result. If the server is unreachable or unavailable, the device sets the status of the server to blocked. If the server is reachable or available, the device sets the status of the server to active.
The device supports the following RADIUS server status detection methods:
·     Simple detection—For a RADIUS server, the device simulates an authentication request with the username and password specified in the test profile used by the server. The authentication request is sent to the RADIUS server within each probe interval. The device determines the status of the RADIUS server as follows:
¡     The RADIUS server is reachable if the device has received authentication responses from the server within the specified number of consecutively probe intervals.
¡     The RADIUS server is unreachable if the device does not receive any authentication response from the server within the specified number of consecutive probe intervals.
¡     In other situations, the status of the RADIUS server remains unchanged.
·     EAP-based detection—For a RADIUS server, the device uses the EAP profile (including an EAP authentication method), username, and password specified in the test profile used by the server to simulate an EAP authentication. The simulated EAP authentication starts at the beginning of each probe interval. If the EAP authentication completes within the detection timeout time (not configurable), the device determines that the RADIUS server is available within the current probe interval.
Simulating a complete EAP authentication process, EAP-based detection provides more reliable detection results than simple detection. As a best practice, configure EAP-based detection on a network environment where EAP authentication is configured.
You can configure multiple test profiles in the system.
The device starts detecting the status of a RADIUS authentication server only if an existing test profile is specified for the server.
If you specify a nonexistent EAP profile in a test profile, the device performs simple detection for the RADIUS servers that use the test profile. After the EAP profile is configured, the device will start EAP-based detection at the next probe interval.
The following EAP authentication methods are supported for EAP-based detection:
·     MD5-Challenge.
·     PEAP-GTC.
·     PEAP-MSCHAPv2.
·     TTLS-GTC.
·     TTLS-MSCHAPv2.
The device stops detecting the status of a RADIUS server when one of the following operations is performed:
·     The RADIUS server is removed from the RADIUS scheme.
·     The test profile configuration for the RADIUS server is removed in RADIUS scheme view.
·     The test profile specified for the RADIUS server is deleted.
·     The RADIUS server is manually set to the blocked state.
·     The RADIUS scheme that contains the RADIUS server is deleted.
2.     Configure a test profile for detecting the status of RADIUS authentication servers.
radius-server test-profile profile-name username name [ password { cipher | simple } string ] [ interval interval ] [ probe-count count ] [ eap-profile eap-profile-name ]
You can configure a maximum of 16 RADIUS schemes. A RADIUS scheme can be used by multiple ISP domains.
2.     Create a RADIUS scheme and enter RADIUS scheme view.
radius scheme radius-scheme-name
A RADIUS authentication server completes authentication and authorization together, because authorization information is piggybacked in authentication responses sent to RADIUS clients.
You can specify one primary authentication server and a maximum of 16 secondary authentication servers for a RADIUS scheme. Secondary servers provide AAA services when the primary server becomes unreachable. The device searches for an active server in the order the secondary servers are configured.
When RADIUS server load sharing is enabled, the device distributes the workload over all servers without considering the primary and secondary server roles. The device checks the weight value and number of currently served users for each active server, and then determines the most appropriate server in performance to receive an authentication request.
If redundancy is not required, specify only the primary server.
A RADIUS authentication server can function as the primary authentication server for one scheme and a secondary authentication server for another scheme at the same time.
Two authentication servers in a scheme, primary or secondary, cannot have the same combination of VPN instance, host name, IP address, and port number.
2.     Enter RADIUS scheme view.
3.     Specify the primary RADIUS authentication server.
primary authentication { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | test-profile profile-name | vpn-instance vpn-instance-name | weight weight-value ] *
By default, no primary RADIUS authentication server is specified.
The weight keyword takes effect only when the RADIUS server load sharing feature is enabled for the RADIUS scheme.
4.     (Optional.) Specify a secondary RADIUS authentication server.
secondary authentication { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | test-profile profile-name | vpn-instance vpn-instance-name | weight weight-value ] *
By default, no secondary RADIUS authentication servers are specified.
You can specify one primary accounting server and a maximum of 16 secondary accounting servers for a RADIUS scheme. Secondary servers provide AAA services when the primary server becomes unavailable. The device searches for an active server in the order the secondary servers are configured.
When RADIUS server load sharing is enabled, the device distributes the workload over all servers without considering the primary and secondary server roles. The device checks the weight value and number of currently served users for each active server, and then determines the most appropriate server in performance to receive an accounting request.
A RADIUS accounting server can function as the primary accounting server for one scheme and a secondary accounting server for another scheme at the same time.
Two accounting servers in a scheme, primary or secondary, cannot have the same combination of VPN instance, host name, IP address, and port number.
RADIUS does not support accounting for FTP, SFTP, and SCP users.
3.     Specify the primary RADIUS accounting server.
primary accounting { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | vpn-instance vpn-instance-name | weight weight-value ] *
By default, no primary RADIUS accounting server is specified.
4.     (Optional.) Specify a secondary RADIUS accounting server.
secondary accounting { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | vpn-instance vpn-instance-name | weight weight-value ] *
By default, no secondary RADIUS accounting servers are specified.
Perform this task if the AAA module on the device must process authentication and accounting requests that contain authentication and accounting server addresses.
For example, an enterprise uses a 5G mobile communication network to connect its mobile users to its private data network and deploys private RADIUS servers on its data network for authentication and accounting. To access the private data network, an endpoint must authenticate to the private authentication server after it registers with the 5G network. After authenticated to the private authentication server, the endpoint must send its accounting requests to the private accounting server. In this scenario, the authentication and accounting requests sent for the endpoints contain the addresses of the private authentication and accounting servers, respectively. To have the AAA module on the device to send requests correctly to the private servers, you must specify the private server addresses in the applicable RADIUS scheme on the device.
If a RADIUS scheme contains private server addresses, the device processes requests that match the scheme as follows:
·     If the request contains the IP address of a private server, the device searches the RADIUS scheme for that private server.
¡     If a match is found, the device communicates with the server for authentication or accounting. If the server does not exist or is unreachable, the authentication or accounting operation fails, and the device will not try other servers in the scheme.
¡     If no match is found, the authentication or accounting operation fails.
·     If the request does not contain a server IP address, the device communicates with a non-private server specified in the RADIUS scheme.
An authentication or accounting request might contain an IPv4 server address, an IPv6 server address, or both.
·     If the request contains an IPv4 server address and an IPv6 server address, the device preferentially exchanges information with the IPv6 server.
¡     If the IPv6 server has failed to respond before the timeout timer expires, the device tries the IPv4 server.
¡     If the IPv6 server is in blocked state, the device examines if the IPv4 server is active.
-     If yes, the device communicates with the IPv4 server.
-     If no, the device continues to communicate with the IPv6 server.
·     If the request contains only an IPv4 or IPv6 server address, the device exchanges client information with the server at that IP address without checking its active state.
Make sure the specified UDP port number and shared key are consistent with the configuration on the server.
In a RADIUS scheme, IP address is the unique identifier of a private server. You can specify a maximum of 16 private authentication servers and 16 private accounting servers in a scheme.
You can specify a shared key when specifying a private server. If no shared key is specified, the device uses the key configured for the RADIUS scheme by using the key authentication or key accounting command to communicate with the server.
If the private server resides in a MPLS VPN instance, you must specify the VPN instance for RADIUS packets to be forwarded to the private server successfully. The VPN instance specified for a private server takes precedence over the VPN instance specified for the scheme.
3.     Specify a private authentication server.
private authentication { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | vpn-instance vpn-instance-name ] *
By default, no private authentication servers are specified.
4.     (Optional.) Specify a private accounting server.
private accounting { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | vpn-instance vpn-instance-name ] *
By default, no private accounting servers are specified.
The RADIUS client and server use the MD5 algorithm and shared keys to generate the Authenticator value for packet authentication and user password encryption. The client and server must use the same key for each type of communication.
A key configured in this task is for all servers of the same type (accounting or authentication) in the scheme. The key has a lower priority than a key configured individually for a RADIUS server.
The shared key configured on the device must be the same as the shared key configured on the RADIUS server.
3.     Specify a shared key for secure RADIUS communication.
key { accounting | authentication } { cipher | simple } string
By default, no shared key is specified for secure RADIUS communication.
The VPN instance specified for a RADIUS scheme applies to all authentication and accounting servers in that scheme. If a VPN instance is also configured for an individual RADIUS server, the VPN instance specified for the RADIUS scheme does not take effect on that server.
3.     Specify a VPN instance for the RADIUS scheme.
By default, a RADIUS scheme belongs to the public network.
To control the RADIUS servers with which the device communicates when the current servers are no longer available, set the status of RADIUS servers to blocked or active. You can specify one primary RADIUS server and multiple secondary RADIUS servers. The secondary servers act as the backup for the primary server.
When the RADIUS server load sharing feature is enabled, the device chooses servers based on the following rules:
·     The device checks the weight values and current user counts on all active servers, and then selects an active server based on the server weight and user count information.
·     If the server in use becomes unreachable after you modify or remove it during an authentication or start-accounting process, the device performs the following operations:
a.     When communication with the server times out, the device checks the weight values and current user counts on all active servers to select another active server.
b.     The device tries to communicate with the selected server.
·     If you remove the accounting server to which the device has sent start-accounting requests successfully for an online user, real-time accounting fails for that online user. The reason is that the device can communicate only with the accounting server to which it has sent start-accounting requests successfully for that online user.
When the RADIUS server load sharing feature is disabled, the device chooses servers based on the following rules:
·     When the primary server is in active state, the device first tries to communicate with the primary server. If the primary server is unreachable, the device searches for an active secondary server in the order the servers are configured.
·     When one or more servers are in active state, the device tries to communicate with these active servers only, even if the servers are unavailable.
·     When all servers are in blocked state, the device only tries to communicate with the primary server.
·     If a server is unreachable, the device performs the following operations:
¡     Changes the server status to blocked.
¡     Starts a quiet timer for the server.
¡     Tries to communicate with the next secondary server in active state that has the highest priority.
·     When the quiet timer of a server expires or you manually set the server to the active state, the status of the server changes back to active. The device does not check the server again during the authentication or accounting process.
·     The search process continues until the device finds an available secondary server or has checked all secondary servers in active state. If no server is reachable, the authentication or accounting fails.
·     The device selects a reachable server for the authentication or accounting of a new user according to the server selection rules in this section. However, these rules are inapplicable to the reauthentication of online users if the RADIUS server selection mode for reauthentication is set to inherit by using the reauthentication server-select inherit command.
·     If you remove one server in use and the server becomes unreachable, the device looks for another server in active state when communication with the original server times out. The device first checks the primary server, and then checks secondary servers in the order they are configured.
·     When a RADIUS server's status changes automatically, the device changes this server's status accordingly in all RADIUS schemes in which this server is specified.
·     When a RADIUS server is manually set to blocked, server detection is disabled for the server, regardless of whether a test profile has been specified for the server. When the RADIUS server is set to active state, server detection is enabled for the server on which an existing test profile is specified.
By default, the device sets the status of all RADIUS servers to active. However, in some situations, you must change the status of a server. For example, if a server fails, you can change the status of the server to blocked to avoid communication attempts to the server.
The configured server status cannot be saved to any configuration file, and can only be viewed by using the display radius scheme command.
After the device restarts, all servers are restored to the active state.
3.     Set the RADIUS server status. Choose the following tasks as needed:
¡     Set the status of the primary RADIUS authentication server.
state primary authentication { active | block }
¡     Set the status of the primary RADIUS accounting server.
state primary accounting { active | block }
¡     Set the status of a secondary RADIUS authentication server.
state secondary authentication [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ] { active | block }
¡     Set the status of a secondary RADIUS accounting server.
state secondary accounting [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ] { active | block }
¡     Set the state of a private RADIUS server.
state private { accounting | authentication } [ { ipv4-address | ipv6 ipv6-address } ] { active | block }
This feature is applicable only to private servers. For more information about private servers, see "Specifying private RADIUS servers."
By default, a RADIUS server is in active state.
The device uses the following types of timers to control communication with a RADIUS server:
·     Server response timeout timer (response-timeout)—Defines the RADIUS request retransmission interval. The timer starts immediately after a RADIUS request is sent. If the device does not receive a response from the RADIUS server before the timer expires, it resends the request.
·     Server quiet timer (quiet)—Defines the duration to keep an unreachable server in blocked state. If one server is not reachable, the device changes the server status to blocked, starts this timer for the server, and tries to communicate with another server in active state. After the server quiet timer expires, the device changes the status of the server back to active.
·     Real-time accounting timer (realtime-accounting)—Defines the interval at which the device sends real-time accounting packets to the RADIUS accounting server for online users.
Consider the number of secondary servers when you configure the maximum number of RADIUS packet transmission attempts and the RADIUS server response timeout timer. If the RADIUS scheme includes many secondary servers, the retransmission process might be too long and the client connection in the access module, such as Telnet, can time out.
When the client connections have a short timeout period, a large number of secondary servers can cause the initial authentication or accounting attempt to fail. In this case, reconnect the client rather than adjusting the RADIUS packet transmission attempts and server response timeout timer. Typically, the next attempt will succeed, because the device has blocked the unreachable servers to shorten the time to find a reachable server.
Make sure the server quiet timer is set correctly. A timer that is too short might result in frequent authentication or accounting failures. This is because the device will continue to attempt to communicate with an unreachable server that is in active state. A timer that is too long might temporarily block a reachable server that has recovered from a failure. This is because the server will remain in blocked state until the timer expires.
A short real-time accounting interval helps improve accounting precision but requires many system resources. When there are 1000 or more users, set the interval to 15 minutes or longer.
3.     Set RADIUS timers. Choose the following tasks as needed:
¡     Set the RADIUS server response timeout timer.
timer response-timeout seconds
The default setting is 3 seconds.
¡     Set the quiet timer for the servers.
timer quiet minutes
The default setting is 5 minutes.
¡     Set the real-time accounting timer.
timer realtime-accounting interval [ second ]
The default setting is 12 minutes.
A RADIUS server identifies a NAS by its IP address and processes a RADIUS packet only when the source IP address of the packet is the IP address of a managed NAS. You must make sure the source IP address of RADIUS packets that a NAS sends matches the IP address of the NAS configured on the RADIUS server.
When the device acts as a NAS, it selects a source IP address for outgoing RADIUS packets in the following order:
1.     The source IP address specified by using the source-ip command in RADIUS scheme view.
2.     The source IP address specified by using the radius source-ip command in system view.
3.     The NAS IP address specified by using the nas-ip command in RADIUS scheme view.
4.     The NAS IP address specified by using the radius nas-ip command in system view.
5.     The IP address of the outbound interface for the outgoing RADIUS packets.
Restrictions and guidelines for source IP address configuration
As a best practice to avoid RADIUS packet loss caused by physical port errors, specify a loopback interface address as the source IP address of outgoing RADIUS packets.
Specifying a source IP address for outgoing RADIUS packets in system view
2.     Specify a source IP address for outgoing RADIUS packets.
radius source-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
By default, no IP address is specified as the source IP address of outgoing RADIUS packets.
Specifying a source IP address for outgoing RADIUS packets in RADIUS scheme view
3.     Specify a source IP address for outgoing RADIUS packets.
By default, the source IP address specified by using the radius source-ip command in system view is used.
A username is in the userid@isp-name format, where the isp-name part represents the user's ISP domain name. By default, the ISP domain name is included in a username. However, older RADIUS servers might not recognize usernames that contain the ISP domain names. In this case, you can configure the device to remove the domain name of each username to be sent.
The device reports online user traffic statistics in accounting packets. The traffic measurement units are configurable.
If two or more ISP domains use the same RADIUS scheme, configure the RADIUS scheme to keep the ISP domain name in usernames for domain identification.
For accounting accuracy, make sure the traffic statistics units configured on the device and on the RADIUS accounting servers are the same.
3.     Set the format for usernames sent to the RADIUS servers.
user-name-format { keep-original | with-domain | without-domain }
4.     Set the data flow and packet measurement units for traffic statistics.
data-flow-format { data { byte | giga-byte | kilo-byte | mega-byte } | packet { giga-packet | kilo-packet | mega-packet | one-packet } }*
By default, traffic is counted in bytes and packets.
RADIUS uses UDP packets to transfer data. Because UDP communication is not reliable, RADIUS uses a retransmission mechanism to improve reliability. A RADIUS request is retransmitted if the NAS does not receive a server response for the request within the response timeout timer. For more information about the RADIUS server response timeout timer, see "Setting the status of RADIUS servers."
You can set the maximum number for the NAS to retransmit a RADIUS request to the same server. When the maximum number is reached, the NAS tries to communicate with other RADIUS servers in active state. If no other servers are in active state at the time, the NAS considers the authentication or accounting attempt a failure.
3.     Set the maximum number of RADIUS request transmission attempts.
retry retries
By default, the maximum number is 3 for RADIUS request transmission attempts.
If you set the maximum number of real-time accounting attempts, the device will disconnect users from whom no accounting responses are received within the permitted attempts.
3.     Set the maximum number of real-time accounting attempts.
retry realtime-accounting retries
By default, the maximum number is 5 for real-time accounting attempts.
The DSCP priority in the ToS field of IPv4 packets or the Traffic Class field of IPv6 packets determines the transmission priority of RADIUS packets. A larger value represents a higher priority.
2.     Set the DSCP priority for RADIUS packets.
radius [ ipv6 ] dscp dscp-value
By default, the DSCP priority is 0 for RADIUS packets.
Perform this task to specify a NAS IP address that uniquely identifies the device on a RADIUS server. The device will set the specified NAS IP address in the NAS-IP-Address or NAS-IPv6-Address attribute in outgoing RADIUS requests.
Restrictions and guidelines for NAS IP address configuration
You can specify the NAS IP address in both RADIUS scheme view and system view.
·     The NAS IP address specified by using the nas-ip command in RADIUS scheme view applies only to the RADIUS scheme.
·     The NAS IP address specified by using the radius nas-ip command in system view applies to all RADIUS schemes.
·     The NAS IP address specified in RADIUS scheme view takes precedence over the NAS IP address specified in system view.
In an M-LAG system, you must specify the NAS IP address for outgoing RADIUS packets on both the M-LAG member devices. Each M-LAG member device selects a NAS IP address in the above order. To make user traffic switchover caused by primary/secondary M-LAG member device switchover transparent to the RADIUS server, ensure that the NAS IP address for outgoing RADIUS packets remains unchanged. Therefore, you must specify the NAS IP address according to the load sharing mode for user authentication on M-LAG interfaces:
·     In centralized mode, you must specify the same local NAS IP address on both the M-LAG member devices.
When an M-LAG member device fails, the active M-LAG member device uses the local NAS IP address for outgoing RADIUS packets sent for users authenticated on the failed M-LAG member device.
·     In distributed mode, you must specify a local and peer NAS IP address pair on both the M-LAG member devices. Make sure the peer NAS IP address on an M-LAG member device is the local NAS IP address on the other M-LAG member device.
When an M-LAG member device fails, the active M-LAG member device uses the peer NAS IP address for outgoing RADIUS packets sent for users authenticated on the failed M-LAG member device.
In an M-LAG system, you must specify a virtual IP address as the NAS IP address of RADIUS packets. For more information about virtual IP addresses for the M-LAG system, see M-LAG configuration in Layer 2—LAN Switching Configuration Guide.
You can directly specify a NAS IP address for outgoing RADIUS packets or specify an interface to provide the NAS IP address for outgoing RADIUS packets. The interface configuration and the IP address configuration overwrite each other.
Specifying a NAS IP address for RADIUS packets in system view
2.     Specify a NAS IP address for RADIUS packets.
radius nas-ip { interface interface-type interface-number | { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] }
By default, the NAS IP address of RADIUS packets is the primary IPv4 address or the IPv6 address of the outbound interface.
Specifying a NAS IP address for RADIUS packets in RADIUS scheme view
3.     Specify a NAS IP address for RADIUS packets.
nas-ip [ m-lag { local | peer } ] { ipv4-address | interface | ipv6 ipv6-address }
By default, the NAS IP address of an outgoing RADIUS packet is that specified by using the radius nas-ip command in system view. If the radius nas-ip command is not used, the NAS IP address is the primary IP address of the outbound interface.
The m-lag { local | peer } option specifies the NAS IP address for outgoing RADIUS packets sent for users that access the network through M-LAG interfaces on an M-LAG system. This option is required only on an M-LAG system.
The device supports the following check methods for the Login-Service attribute (RADIUS attribute 15) of SSH, FTP, and terminal users:
·     Strict—Matches Login-Service attribute values 50, 51, and 52 for SSH, FTP, and terminal services, respectively.
·     Loose—Matches the standard Login-Service attribute value 0 for SSH, FTP, and terminal services.
An Access-Accept packet received for a user must contain the matching attribute value. Otherwise, the user cannot log in to the device.
Use the loose check method only when the server does not issue Login-Service attribute values 50, 51, and 52 for SSH, FTP, and terminal users.
3.     Configure the Login-Service attribute check method for SSH, FTP, and terminal users.
attribute 15 check-mode { loose | strict }
The default check method is strict.
A RADIUS server may deliver CAR parameters for user-based traffic monitoring and control by using the RADIUS class attribute (attribute 25) in RADIUS packets. You can configure the device to interpret the class attribute to CAR parameters.
3.     Interpret the RADIUS class attribute as CAR parameters.
attribute 25 car
By default, the RADIUS class attribute is not interpreted as CAR parameters.
RADIUS servers of different types might have different requirements for the MAC address format in the RADIUS Called-Station-Id attribute. Configure the MAC address format for this attribute to meet the requirements of the RADIUS servers.
3.     Configure the MAC address format for the RADIUS Called-Station-Id attribute.
attribute 30 mac-format section { one | { six | three } separator separator-character } { lowercase | uppercase }
By default, the MAC address in the RADIUS Called-Station-Id attribute is in the format of HH-HH-HH-HH-HH-HH. The MAC address is separated by hyphen (-) into six sections with letters in upper case.
RADIUS servers of different types might have different requirements for the MAC address format in the RADIUS Calling-Station-Id attribute (attribute 31). Configure the MAC address format for this attribute to meet the requirements of the RADIUS servers.
3.     Configure the MAC address format for the RADIUS Calling-Station-Id attribute.
attribute 31 mac-format section { one | { six | three } separator separator-character } { lowercase | uppercase }
By default, the MAC address in the RADIUS Calling-Station-Id attribute is in the format of HH-HH-HH-HH-HH-HH. The MAC address is separated by hyphen (-) into six sections with letters in upper case.
The RADIUS server uses the Remanent_Volume attribute in authentication or real-time accounting responses to notify the device of the current amount of data available for online users.
Make sure the configured measurement unit is the same as the user data measurement unit on the RADIUS server.
3.     Set the data measurement unit for the Remanent_Volume attribute.
attribute remanent-volume unit { byte | giga-byte | kilo-byte | mega-byte }
By default, the data measurement unit is kilobyte.
For the device to correctly interpret RADIUS attributes from the servers with a vendor ID of 2011, specify a server version that is the same as the version of the RADIUS servers.
3.     Specify a server version for interoperating with servers with a vendor ID of 2011.
attribute vendor-id 2011 version { 1.0 | 1.1 }
By default, version 1.0 is used.
RADIUS servers of different types might have different requirements for the format of attribute Acct-Session-Id. The following types are available:
·     Common format—In this format, the Acct-Session-Id attribute is a string of 37 characters. This string contains the prefix (indicating the access type), date and time, sequence number, LIP address of the access node, device ID, and job ID of the access process.
·     Simplified format—In this format, the Acct-Session-Id attribute is a string of 16 characters. This string contains the prefix (indicating the access type), month, sequence number, device ID, and LIP address of the access node.
Specify a format for attribute Acct-Session-Id to meet the requirements of the RADIUS servers.
2.     Specify the format for attribute Acct-Session-Id.
aaa session-id mode { common | simplified }
By default, the device uses the common format for attribute Acct-Session-Id.
The RADIUS Vendor-Specific attribute (attribute 26) allows vendors to define extended attributes to implement functions that the standard RADIUS protocol does not provide. Vendor 25506 defines subattribute 218 to carry user DHCP option information.
To send user DHCP option information to RADIUS servers, perform this task to include subattribute 218 of vendor 25506 in outgoing RADIUS start-accounting and update-accounting requests.
In the current software version, only DHCP Option 55 and DHCP Option 61 can be carried in the subattribute.
You can repeat the include-attribute 218 vendor-id 25506 command to configure the device to encapsulate both DHCP Option 55 and DHCP Option 61 in the subattribute. The length of each option is limited to 246 bytes.
If you repeat this command multiple times with the same DHCP option specified, the most recent configuration takes effect.
3.     Include subattribute 218 of vendor 25506 in outgoing RADIUS packets.
include-attribute 218 vendor-id 25506 dhcp-option { 55 | 61 } * { format1 | format2 }
By default, the device uses format 1 to encapsulate DHCP Option 61 in subattribute 218 of vendor 25506 in RADIUS packets.
The RADIUS attribute translation feature enables the device to work correctly with the RADIUS servers of different vendors that support RADIUS attributes incompatible with the device.
RADIUS attribute translation has the following implementations:
·     Attribute conversion—Converts source RADIUS attributes into destination RADIUS attributes based on RADIUS attribute conversion rules.
·     Attribute rejection—Rejects RADIUS attributes based on RADIUS attribute rejection rules.
When the RADIUS attribute translation feature is enabled, the device processes RADIUS packets as follows:
·     For the sent RADIUS packets:
¡     Deletes the rejected attributes from the packets.
¡     Uses the destination RADIUS attributes to replace the attributes that match RADIUS attribute conversion rules in the packets.
·     For the received RADIUS packets:
¡     Ignores the rejected attributes in the packets.
¡     Interprets the attributes that match RADIUS attribute conversion rules as the destination RADIUS attributes.
To identify proprietary RADIUS attributes, you can define the attributes as extended RADIUS attributes, and then convert the extended RADIUS attributes to device-supported attributes.
Restrictions and guidelines for RADIUS attribute translation configuration
Configure either conversion rules or rejection rules for a RADIUS attribute.
Configure either direction-based rules or packet type-based rules for a RADIUS attribute.
For direction-based translation of a RADIUS attribute, you can configure a rule for each direction (inbound or outbound). For packet type-based translation of a RADIUS attribute, you can configure a rule for each RADIUS packet type (RADIUS Access-Accept, RADIUS Access-Request, or RADIUS accounting).
Configuring the RADIUS attribute translation feature for a RADIUS scheme
2.     (Optional.) Define an extended RADIUS attribute.
radius attribute extended attribute-name [ vendor vendor-id ] code attribute-code type { binary | date | integer | interface-id | ip | ipv6 | ipv6-prefix | octets | string }
3.     Enter RADIUS scheme view.
4.     Enable the RADIUS attribute translation feature.
attribute translate
5.     Configure a RADIUS attribute conversion rule or a RADIUS attribute reject rule. Choose the following tasks as needed:
¡     Configure a RADIUS attribute conversion rule.
attribute convert src-attr-name to dest-attr-name { { access-accept | access-request | accounting } * | { received | sent } * }
By default, no RADIUS attribute conversion rules are configured.
¡     Configure a RADIUS attribute rejection rule.
attribute reject attr-name { { access-accept | access-request | accounting } * | { received | sent } * }
By default, no RADIUS attribute rejection rules are configured.
If all servers in a RADIUS scheme are blocked, the device takes one of the following actions upon receiving AAA requests in the domain that uses the scheme:
·     attempt—Attempts to connect to a server (except for servers manually set in block state) in the scheme. For more information about the RADIUS server selection mechanism, see "Setting the status of RADIUS servers."
·     skip—Skips all servers in the scheme and turns to the backup method.
The attempt action gives the device a chance to use the scheme in case the server with the highest priority in the scheme might be available. However, the attempt to communicate with an unavailable server increases the response time for AAA requests. As a best practice, specify the skip action in scenarios that require quick responses to AAA requests.
3.     Specify the action to take for AAA requests if all servers in the scheme are blocked.
server-block-action { attempt | skip }
By default, the attempt action applies.
The device sends RADIUS stop-accounting requests when it receives connection teardown requests from hosts or connection teardown commands from an administrator. However, the device might fail to receive a response for a stop-accounting request in a single transmission. Enable the device to buffer RADIUS stop-accounting requests that have not received responses from the accounting server. The device will resend the requests until responses are received.
To limit the transmission times, set a maximum number of transmission attempts that can be made for individual RADIUS stop-accounting requests. When the maximum attempts are made for a request, the device discards the buffered request.
3.     Enable buffering of RADIUS stop-accounting requests to which no responses have been received.
stop-accounting-buffer enable
By default, the buffering feature is enabled.
4.     (Optional.) Set the maximum number of transmission attempts for individual RADIUS stop-accounting requests.
retry stop-accounting retries
The default setting is 500.
Typically, if the device does not send a start-accounting packet to the RADIUS server for an authenticated user, it does not send a stop-accounting packet when the user goes offline. If the server has generated a user entry for the user without start-accounting packets, it does not release the user entry when the user goes offline. This feature forces the device to send stop-accounting packets to the RADIUS server when the user goes offline for timely releasing the user entry on the server.
3.     Enable the device to send stop-accounting packets when users for which no start-accounting packets are sent go offline.
stop-accounting-packet send-force
By default, forcibly sending stop-accounting packets is disabled. The device does not send stop-accounting packets when users for which no start-accounting packets are sent go offline.
By default, the device communicates with RADIUS servers based on the server roles. It first attempts to communicate with the primary server, and, if the primary server is unreachable, it then searches for the secondary servers in the order they are configured. The first secondary server in active state is used for communication. In this process, the workload is always placed on the active server.
Use the RADIUS server load sharing feature to dynamically distribute the workload over multiple servers regardless of their server roles. The device forwards an AAA request to the most appropriate server of all active servers in the scheme after it compares the weight values and numbers of currently served users. Specify a weight value for each RADIUS server based on the AAA capacity of the server. A larger weight value indicates a higher AAA capacity.
In RADIUS server load sharing, once the device sends a start-accounting request to a server for a user, it forwards all subsequent accounting requests of the user to the same server. If the accounting server is unreachable, the device returns an accounting failure message rather than searching for another active accounting server.
3.     Enable the RADIUS server load sharing feature.
server-load-sharing enable
Use this feature to configure the RADIUS server selection mechanism in reauthentication. The following RADIUS server selection modes are available:
·     Inherit—The device uses the RADIUS server that performed authentication for a user to reauthenticate that user. This mode reduces the amount of time used in reauthentication. However, if the RADIUS server is unreachable, the reauthentication will fail.
·     Reselect—The device searches for a reachable RADIUS server to reauthenticate a user. This mode requires more time than the inherit mode. However, this mode ensures that the device uses the optimal reachable RADIUS server for reauthentication. The following factors affect the RADIUS server selection:
¡     Server configuration in the RADIUS scheme, including the configuration order.
¡     Enabling status of the RADIUS server load sharing feature.
¡     Status of the RADIUS servers in the RADIUS scheme.
3.     Specify a RADIUS server selection mode for reauthentication.
reauthentication server-select { inherit | reselect }
By default, the inherit mode is used.
When the accounting-on feature is enabled, the device automatically sends an accounting-on packet to the RADIUS server after the entire device reboots. Upon receiving the accounting-on packet, the RADIUS server logs out all online users so they can log in again through the device. Without this feature, users cannot log in again after the reboot, because the RADIUS server considers them to come online.
You can configure the interval for which the device waits to resend the accounting-on packet and the maximum number of retries.
3.     Enable accounting-on.
accounting-on enable [ interval interval | send send-times ] *
By default, the accounting-on feature is disabled.
Enable this feature for the RADIUS server to dynamically change the user authorization information or forcibly disconnect users by using session-control packets. This task enables the device to receive RADIUS session-control packets on UDP port 1812.
To verify the session-control packets sent from a RADIUS server, specify the RADIUS server as a session-control client to the device.
The RADIUS session-control feature can only work with RADIUS servers running on IMC. The session-control client configuration takes effect only when the session-control feature is enabled.
2.     Enable the session-control feature.
radius session-control enable
By default, the session-control feature is disabled.
3.     Specify a session-control client.
radius session-control client { ip ipv4-address | ipv6 ipv6-address } [ key { cipher | simple } string | vpn-instance vpn-instance-name ] *
By default, no session-control clients are specified.
Perform this task if the RADIUS server divides the total data quota of an authenticated user into multiple equal portions and assigns one portion to the user each time. When the user's available data on the device reaches the threshold, the device sends a real-time accounting request to the RADIUS server to apply for a new data portion. This process continues till the user uses up the total data quota.
The unit for the available data threshold is determined by using the attribute remanent-volume unit command.
3.     Set the available data threshold.
threshold remanent-volume threshold-value
By default, the available data threshold is 0.
When SNMP notifications are enabled for RADIUS, the SNMP agent supports the following notifications generated by RADIUS:
·     RADIUS server unreachable notification—The RADIUS server cannot be reached. RADIUS generates this notification if it does not receive a response to an accounting or authentication request within the specified number of RADIUS request transmission attempts.
·     RADIUS server reachable notification—The RADIUS server can be reached. RADIUS generates this notification for a previously blocked RADIUS server after the quiet timer expires.
·     Excessive authentication failures notification—The number of authentication failures compared to the total number of authentication attempts exceeds the specified threshold.
For RADIUS SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
2.     Enable SNMP notifications for RADIUS.
snmp-agent trap enable radius [ accounting-server-down | accounting-server-up | authentication-error-threshold | authentication-server-down | authentication-server-up ] *
By default, all SNMP notifications are disabled for RADIUS.
By default, the RADIUS service is enabled. The device can send and receive RADIUS packets. Attackers might use RADIUS session-control and DAE ports to attack the device. To protect the device when such an attack occurs, disable the RADIUS service temporarily on the device. After the network is secure, re-enable the RADIUS service.
If settings on the RADIUS servers require modification or the RADIUS servers cannot provide services temporarily, you can temporarily disable the RADIUS service on the device.
When the RADIUS service is disabled, the device stops sending and receiving RADIUS packets. If a new user comes online, the device uses the backup authentication, authorization, or accounting method to process that user. If the device has not finished requesting authentication or accounting for a user before the RADIUS service is disabled, it uses the following rules to process that user:
·     If the device has sent RADIUS authentication requests for that user to a RADIUS server, the device processes that user depending on whether it receives a response from the RADIUS server.
¡     If the device receives a response from the RADIUS server, it uses the response to determine whether that user has passed authentication. If that user has passed authentication, the device assigns authorization information to that user according to the response.
¡     If the device does not receive any response from the RADIUS server, it attempts to use the backup authentication method to authenticate that user.
·     If the device has sent RADIUS start-accounting requests for that user to a RADIUS server, the device processes that user depending on whether it receives a response from the RADIUS server.
¡     If the device receives a response from the RADIUS server, it allows that user to come online. However, the device cannot send out accounting-update or stop-accounting requests to the RADIUS server. It cannot buffer the accounting requests, either. When that user goes offline, the RADIUS server cannot log off that user in time. The accounting result might be inaccurate.
¡     If the device does not receive any response from the RADIUS server, it attempts to use the backup accounting method.
Disabling the RADIUS service does not affect the RADIUS server feature of the device.
The authentication, authorization, and accounting processes undertaken by other methods are not switched to RADIUS when you re-enable the RADIUS service.
2.     Disable the RADIUS service.
undo radius enable
To re-enable the RADIUS service, use the radius enable command.
Verifying and maintaining RADIUS
Verifying the RADIUS scheme configuration
To verify the configuration for all RADIUS schemes or for the specified RADIUS scheme, execute the following command in any view:
display radius scheme [ radius-scheme-name ]
Displaying and clearing RADIUS statistics
To display RADIUS packet statistics, execute the following command in any view:
display radius statistics
To clear RADIUS statistics, execute the following command in user view:
reset radius statistics
Displaying and clearing information about buffered RADIUS stop-accounting requests
To display information about buffered RADIUS stop-accounting requests to which no responses have been received, execute the following command in any view:
display stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time end-time | user-name user-name }
To clear the buffered RADIUS stop-accounting requests to which no responses have been received, execute the following command in user view:
reset stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time end-time | user-name user-name }
Displaying and clearing authentication and accounting load statistics for all RADIUS servers
To display authentication and accounting load statistics for all RADIUS servers, execute the following command in any view:
display radius server-load statistics
To clear history authentication and accounting load statistics for all RADIUS servers, execute the following command in user view:
reset radius server-load statistics
HWTACACS tasks at a glance
To configure HWTACACS, perform the following tasks:
1.     Creating an HWTACACS scheme
2.     Specifying the HWTACACS authentication servers
3.     Specifying the HWTACACS authorization servers
4.     Specifying the HWTACACS accounting servers
5.     Specifying the shared keys for secure HWTACACS communication
Perform this task if no shared keys are specified when configuring HWTACACS servers.
6.     Specifying an MPLS L3VPN instance for the scheme
Perform this task if no MPLS L3VPN instances are specified when configuring HWTACACS servers.
7.     (Optional.) Setting HWTACACS timers
8.     (Optional.) Configuring parameters for HWTACACS packets
¡     Specifying the source IP address of outgoing HWTACACS packets
¡     Setting the DSCP priority for HWTACACS packets
9.     (Optional.) Specifying the action to take for AAA requests if all HWTACACS servers are blocked
10.     (Optional.) Configuring HWTACACS stop-accounting packet buffering
You can configure a maximum of 16 HWTACACS schemes. An HWTACACS scheme can be used by multiple ISP domains.
2.     Create an HWTACACS scheme and enter HWTACACS scheme view.
hwtacacs scheme hwtacacs-scheme-name
You can specify one primary authentication server and a maximum of 16 secondary authentication servers for an HWTACACS scheme. When the primary server is unreachable, the device searches for the secondary servers in the order they are configured. The first secondary server in active state is used for communication.
An HWTACACS server can function as the primary authentication server in one scheme and as the secondary authentication server in another scheme at the same time.
Two HWTACACS authentication servers in a scheme, primary or secondary, cannot have the same combination of VPN instance, host name, IP address, and port number.
2.     Enter HWTACACS scheme view.
3.     Specify the primary HWTACACS authentication server.
primary authentication { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
By default, no primary HWTACACS authentication server is specified.
4.     (Optional.) Specify a secondary HWTACACS authentication server.
secondary authentication { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
By default, no secondary HWTACACS authentication servers are specified.
You can specify one primary authorization server and a maximum of 16 secondary authorization servers for an HWTACACS scheme. When the primary server is not available, the device searches for the secondary servers in the order they are configured. The first secondary server in active state is used for communication.
An HWTACACS server can function as the primary authorization server of one scheme and as the secondary authorization server of another scheme at the same time.
Two HWTACACS authorization servers in a scheme, primary or secondary, cannot have the same combination of VPN instance, host name, IP address, and port number.
3.     Specify the primary HWTACACS authorization server.
primary authorization { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
By default, no primary HWTACACS authorization server is specified.
4.     (Optional.) Specify a secondary HWTACACS authorization server.
secondary authorization { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
By default, no secondary HWTACACS authorization servers are specified.
You can specify one primary accounting server and a maximum of 16 secondary accounting servers for an HWTACACS scheme. When the primary server is not available, the device searches for the secondary servers in the order they are configured. The first secondary server in active state is used for communication.
An HWTACACS server can function as the primary accounting server of one scheme and as the secondary accounting server of another scheme at the same time.
Two HWTACACS accounting servers in a scheme, primary or secondary, cannot have the same combination of VPN instance, host name, IP address, and port number.
HWTACACS does not support accounting for FTP, SFTP, and SCP users.
3.     Specify the primary HWTACACS accounting server.
primary accounting { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
By default, no primary HWTACACS accounting server is specified.
4.     (Optional.) Specify a secondary HWTACACS accounting server.
secondary accounting { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
By default, no secondary HWTACACS accounting servers are specified.
The HWTACACS client and server use the MD5 algorithm and shared keys to generate the Authenticator value for packet authentication and user password encryption. The client and server must use the same key for each type of communication.
Perform this task to configure shared keys for servers in an HWTACACS scheme. The keys take effect on all servers for which a shared key is not individually configured.
Make sure the shared key configured on the device is the same as the shared key configured on the HWTACACS server.
3.     Specify a shared key for secure HWTACACS authentication, authorization, or accounting communication.
key { accounting | authentication | authorization } { cipher | simple } string
By default, no shared key is specified for secure HWTACACS communication.
The VPN instance specified for an HWTACACS scheme applies to all servers in that scheme. If a VPN instance is also configured for an individual HWTACACS server, the VPN instance specified for the HWTACACS scheme does not take effect on that server.
3.     Specify a VPN instance for the HWTACACS scheme.
By default, an HWTACACS scheme belongs to the public network.
The device uses the following timers to control communication with an HWTACACS server:
·     Server response timeout timer (response-timeout)—Defines the HWTACACS server response timeout timer. The device starts this timer immediately after an HWTACACS authentication, authorization, or accounting request is sent. If the device does not receive a response from the server within the timer, it sets the server to blocked. Then, the device sends the request to another HWTACACS server.
·     Real-time accounting timer (realtime-accounting)—Defines the interval at which the device sends real-time accounting packets to the HWTACACS accounting server for online users.
·     Server quiet timer (quiet)—Defines the duration to keep an unreachable server in blocked state. If a server is not reachable, the device changes the server status to blocked, starts this timer for the server, and tries to communicate with another server in active state. After the server quiet timer expires, the device changes the status of the server back to active.
The server quiet timer setting affects the status of HWTACACS servers. If the scheme includes one primary HWTACACS server and multiple secondary HWTACACS servers, the device communicates with the HWTACACS servers based on the following rules:
·     When the primary server is in active state, the device communicates with the primary server. When the primary server is unreachable, the device researches a secondary server in active status in the order they are configured.
·     When one or more servers are in active state, the device tries to communicate with these servers only, even if they are unreachable.
·     If the primary server is unreachable, the device changes the server status to blocked and starts a quiet timer for the server. When the quiet timer of the server expires, the status of the server changes back to active. The device does not check the server again during the authentication, authorization, or accounting process.
·     The search process continues until the device finds an available secondary server or has checked all secondary servers in active state. If no server is available, the device considers the authentication, authorization, or accounting attempt a failure.
·     When you remove a server in use, communication with the server times out. The device looks for a server in active state by first checking the primary server, and then checking secondary servers in the order they are configured.
·     When an HWTACACS server's status changes automatically, the device changes this server's status accordingly in all HWTACACS schemes in which this server is specified.
A short real-time accounting interval helps improve accounting precision but requires many system resources. When there are 1000 or more users, set a real-time accounting interval longer than 15 minutes.
3.     Set the HWTACACS timers. Choose the following tasks as needed:
¡     Set the HWTACACS server response timeout timer.
By default, the HWTACACS server response timeout timer is 5 seconds.
¡     Set the real-time accounting interval.
timer realtime-accounting minutes
By default, the real-time accounting interval is 12 minutes.
¡     Set the server quiet timer.
timer quiet minutes
By default, the server quiet timer is 5 minutes.
The source IP address of HWTACACS packets that a NAS sends must match the IP address of the NAS configured on the HWTACACS server. An HWTACACS server identifies a NAS by IP address. When the HWTACACS server receives a packet, it checks the source IP address of the packet.
·     If it is the IP address of a managed NAS, the server processes the packet.
·     If it is not the IP address of a managed NAS, the server drops the packet.
Before sending an HWTACACS packet, the NAS selects a source IP address in the following order:
1.     The source IP address specified for the HWTACACS scheme.
2.     The source IP address specified in system view for the VPN or public network, depending on where the HWTACACS server resides.
3.     The IP address of the outbound interface specified by the route.
You can specify the source IP address for outgoing HWTACACS packets in HWTACACS scheme view or in system view.
·     The IP address specified in HWTACACS scheme view applies to one HWTACACS scheme.
·     The IP address specified in system view applies to all HWTACACS schemes.
The source IP address of HWTACACS packets that a NAS sends must match the IP address of the NAS that is configured on the HWTACACS server.
As a best practice to avoid HWTACACS packet loss caused by physical port errors, specify a loopback interface address as the source IP address of outgoing HWTACACS packets.
To communicate with the HWTACACS server, the source address of outgoing HWTACACS packets is typically the IP address of an egress interface on the NAS.
You can directly specify a source IP address for outgoing HWTACACS packets or specify a source interface to provide the source IP address for outgoing HWTACACS packets. The source interface configuration and the source IP address configuration overwrite each other.
Specifying a source IP address for outgoing HWTACACS packets in system view
2.     Specify a source IP address for outgoing HWTACACS packets.
hwtacacs nas-ip { interface interface-type interface-number | { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] }
By default, the source IP address of an HWTACACS packet sent to the server is the primary IPv4 address or the IPv6 address of the outbound interface.
Specifying a source IP address for outgoing HWTACACS packets in HWTACACS scheme view
3.     Specify a source IP address for outgoing HWTACACS packets.
nas-ip { ipv4-address | interface interface-type interface-number | ipv6 ipv6-address }
By default, the source IP address of an outgoing HWTACACS packet is that configured by using the hwtacacs nas-ip command in system view. If the hwtacacs nas-ip command is not used, the source IP address is the primary IP address of the outbound interface.
Setting the username format and traffic statistics units
A username is typically in the userid@isp-name format, where the isp-name part represents the user's ISP domain name. By default, the ISP domain name is included in a username. If HWTACACS servers do not recognize usernames that contain ISP domain names, you can configure the device to send usernames without domain names to the servers.
If two or more ISP domains use the same HWTACACS scheme, configure the HWTACACS scheme to keep the ISP domain name in usernames for domain identification.
For accounting accuracy, make sure the traffic measurement units configured on the device are the same as the traffic measurement units configured on the HWTACACS accounting servers.
3.     Set the format of usernames sent to the HWTACACS servers.
DSCP priority determines the transmission priority of HWTACACS packets. A larger value represents a higher priority.
DSCP priority is contained in the ToS field of the IPv4 header and in the Traffic Class field of the IPv6 header.
2.     Set the DSCP priority for HWTACACS packets.
hwtacacs [ ipv6 ] dscp dscp-value
By default, the DSCP priority is 0 for HWTACACS packets.
If all servers in an HWTACACS scheme are blocked, the device takes one of the following actions upon receiving AAA requests in the domain that uses the scheme:
·     attempt—Attempts to connect to the server that has the highest priority in the scheme. (Typically, the highest-priority server is the primary server. If no primary server is specified, it is the firstly configured secondary server. Primary and secondary servers manually set in block state are not used.) If the device fails to connect to the server, it turns to the backup method.
The device sends HWTACACS stop-accounting requests when it receives connection teardown requests from hosts or connection teardown commands from an administrator. However, the device might fail to receive a response for a stop-accounting request in a single transmission. Enable the device to buffer HWTACACS stop-accounting requests that have not received responses from the accounting server. The device will resend the requests until responses are received.
To limit the transmission times, set a maximum number of attempts that can be made for transmitting individual HWTACACS stop-accounting requests. When the maximum attempts are made for a request, the device discards the buffered request.
3.     Enable buffering of HWTACACS stop-accounting requests to which no responses have been received.
4.     (Optional.) Set the maximum number of transmission attempts for individual HWTACACS stop-accounting requests.
The default setting is 100.
Verifying and maintaining HWTACACS
Verifying the HWTACACS scheme configuration
To verify the configuration for all HWTACACS schemes or for the specified HWTACACS scheme, execute the following command in any view:
display hwtacacs scheme [ hwtacacs-scheme-name ]
Displaying and clearing HWTACACS statistics
To display HWTACACS statistics, execute the following command in any view:
display hwtacacs scheme hwtacacs-scheme-name statistics
To clear HWTACACS statistics, execute the following command in user view:
reset hwtacacs statistics { accounting | all | authentication | authorization }
Displaying and clearing information about buffered HWTACACS stop-accounting requests
To display information about buffered HWTACACS stop-accounting requests to which no responses have been received, execute the following command in any view:
display stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name
To clear the buffered HWTACACS stop-accounting requests to which no responses have been received, execute the following command in user view:
reset stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name
Creating an ISP domain
About ISP domains
In a networking scenario with multiple ISPs, the device can connect to users of different ISPs. These users can have different user attributes, such as different username and password structures, different service types, and different rights. To manage users of different ISPs, configure authentication, authorization, and accounting methods and domain attributes for each ISP domain as needed.
The device supports a maximum of 1024 ISP domains, including the system-defined ISP domain system. You can specify one of the ISP domains as the default domain.
On the device, each user belongs to an ISP domain. If a user does not provide an ISP domain name at login, the device considers the user belongs to the default ISP domain.
Each ISP domain has a set of system-defined AAA methods, which are local authentication, local authorization, and local accounting. If you do not configure any AAA methods for an ISP domain, the device uses the system-defined AAA methods for users in the domain.
The device chooses an authentication domain for each user in the following order:
1.     The authentication domain specified for the access module.
2.     The ISP domain in the username.
3.     The default ISP domain of the device.
If the chosen domain does not exist on the device, the device searches for the ISP domain that accommodates users assigned to nonexistent domains. (Support for the authentication domain configuration depends on the access module.) If no such ISP domain is configured, user authentication fails.
Restrictions and guidelines for ISP domain configuration
An ISP domain cannot be deleted when it is the default ISP domain. Before you use the undo domain command, change the domain to a non-default ISP domain by using the undo domain default enable command.
You can modify the settings of the system-defined ISP domain system, but you cannot delete the domain.
To avoid RADIUS authentication, authorization, or accounting failures, use short domain names to ensure that usernames containing a domain name do not exceed 253 characters.
To avoid RADIUS accounting failures, make sure the domain name contained in usernames sent to the RADIUS server does not exceed 247 characters.
2.     Create an ISP domain and enter ISP domain view by using one of the following commands:
¡     domain name isp-name
¡     domain isp-name
By default, a system-defined ISP domain exists. The domain name is system.
Valid characters in the ISP domain name depend on the command synatx. For more information, see AAA commands in User Access and Authentication Command Reference.
Specifying the default ISP domain
2.     Specify the default ISP domain.
domain default enable isp-name
By default, the default ISP domain is the system-defined ISP domain system.
Specifying an ISP domain for users that are assigned to nonexistent domains
2.     Specify the ISP domain to accommodate users that are assigned to nonexistent domains.
domain if-unknown isp-name
By default, no ISP domain is specified to accommodate users that are assigned to nonexistent domains.
Configuring ISP domain attributes
Setting ISP domain status
By setting the state of an ISP domain, you can allow or deny network service requests from users in the domain.
·     Active—The device allows network service requests from users in the domain.
·     Blocked—The device denies network service requests from users in the domain. To deny user network service requests during specific time, you can configure the device to place the domain in blocked state during the specified time ranges.
2.     Enter ISP domain view.
3.     Set the status of the ISP domain.
state { active | block [ time-range ] }
By default, an ISP domain is in active state, and users in the domain can request network services.
4.     Specify time ranges during which the ISP domain is placed in blocked state.
state block time-range name time-range-name
By default, no time ranges are specified during which an ISP domain is placed in blocked state.
Configuring authorization attributes for an ISP domain
After successful authentication, the user prefers to use the authorization attributes assigned by the server. If no attribute is assigned, the user uses the authorization attributes configured for the ISP domain.
3.     Configure authorization attributes for authenticated users in the ISP domain.
authorization-attribute user-group user-group-name
Including the idle timeout period in the user online duration to be sent to the server
If a user goes offline due to connection failure or malfunction, the user's online duration sent to the server includes the idle timeout period assigned by the authorization server. The online duration generated on the server is longer than the actual online duration of the user.
3.     Configure the device to include the idle timeout period in the user online duration to be sent to the server.
session-time include-idle-time
By default, the user online duration sent to the server does not include the idle timeout period.
Configuring AAA methods for an ISP domain
Configuring authentication methods for an ISP domain
When you configure authentication, follow these restrictions and guidelines:
·     For high availability, you can specify one primary authentication method and multiple backup authentication methods. When the primary method is invalid, the device attempts to use the backup methods in sequence.
For example, the radius-scheme radius-scheme-name local none parameters specify a primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
The remote authentication method is invalid in the following situations:
¡     The specified authentication scheme does not exist.
¡     Authentication packet sending fails.
¡     The device does not receive any authentication response packets from an authentication server.
The local authentication method is invalid if the device fails to find the matching local user configuration.
·     If the authentication method uses a RADIUS scheme and the authorization method does not use a RADIUS scheme, AAA accepts only the authentication result from the RADIUS server. The Access-Accept message from the RADIUS server also includes the authorization information, but the device ignores the information.
·     If an HWTACACS scheme is specified, the device uses the entered username for role authentication.
·     If a RADIUS scheme is specified, the device uses username $enabn$ on the RADIUS server for role authentication.
¡     To obtain a level-n user role, you must create a user account for the level-n user role in the $enabn$ format on the RADIUS server. The variable n represents the target user role level.
¡     To obtain a non-level-n user role, you must perform the following tasks:
-     Create a user account named $enab0$ on the server.
-     Configure the cisco-av-pair attribute for the account in the form of allowed-roles="role". The variable role represents the target user role.
For more information about user role authentication, see RBAC configuration in Fundamentals Configuration Guide.
When the primary authentication method is local, the following rules apply to the authentication of a user:
·     The device uses the backup authentication methods in sequence only if local authentication is invalid for one of the following reasons:
¡     An exception occurs in the local authentication process.
¡     The user account is not configured on the device or the user is not allowed to use the access service.
·     The device does not turn to the backup authentication methods if local authentication is invalid because of any other reason. Authentication fails for the user.
Before configuring authentication methods, complete the following tasks:
1.     Determine the access type or service type to be configured. With AAA, you can configure an authentication method for each access type and service type.
2.     Determine whether to configure the default authentication method for all access types or service types. The default authentication method applies to all access users. However, the method has a lower priority than the authentication method that is specified for an access type or service type.
3.     (Optional.) Specify default authentication methods for all types of users.
authentication default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name ] * [ none ] | local [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
By default, the default authentication method is local.
4.     Specify authentication methods for a user type or a service.
¡     Specify authentication methods for login users.
authentication login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name ] * [ none ] | local [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
By default, the default authentication methods are used for login users.
¡     Specify authentication methods for obtaining a temporary user role.
authentication super { hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name } *
By default, the default authentication methods are used for obtaining a temporary user role.
Configuring authorization methods for an ISP domain
For high availability, you can specify one primary authorization method and multiple backup authorization methods. When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the radius-scheme radius-scheme-name local none parameters specify a primary RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
The remote authorization method is invalid in the following situations:
·     The specified authorization scheme does not exist.
·     Authorization packet sending fails.
·     The device does not receive any authorization response packets from an authorization server.
The local authorization method is invalid if the device fails to find the matching local user configuration.
To use a RADIUS scheme as the authorization method, specify the name of the RADIUS scheme that is configured as the authentication method for the ISP domain. If an invalid RADIUS scheme is specified as the authorization method, RADIUS authentication and authorization fail.
When the primary authorization method is local, the following rules apply to the authorization of a user:
·     The device uses the backup authorization methods in sequence only if local authorization is invalid for one of the following reasons:
¡     An exception occurs in the local authorization process.
·     The device does not turn to the backup authorization methods if local authorization is invalid because of any other reason. Authorization fails for the user.
Before configuring authorization methods, complete the following tasks:
1.     Determine the access type or service type to be configured. With AAA, you can configure an authorization scheme for each access type and service type.
2.     Determine whether to configure the default authorization method for all access types or service types. The default authorization method applies to all access users. However, the method has a lower priority than the authorization method that is specified for an access type or service type.
3.     (Optional.) Specify default authorization methods for all types of users.
authorization default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
By default, the authorization method is local.
4.     Specify authorization methods for a user type or a service.
¡     Specify command authorization methods.
authorization command { hwtacacs-scheme hwtacacs-scheme-name [ local ] [ none ] | local [ none ] | none }
By default, the default authorization methods are used for command authorization.
¡     Specify authorization methods for login users.
authorization login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
By default, the default authorization methods are used for login users.
Configuring accounting methods for an ISP domain
For high availability, you can specify one primary accounting method and multiple backup accounting methods. When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the radius-scheme radius-scheme-name local none parameters specify a primary RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
The remote accounting method is invalid in the following situations:
·     The specified accounting scheme does not exist.
·     Accounting packet sending fails.
·     The device does not receive any accounting response packets from an accounting server.
The local accounting method is invalid if the device fails to find the matching local user configuration.
FTP, SFTP, and SCP users do not support accounting.
Local accounting does not provide statistics for charging. It only counts and controls the number of concurrent users that use the same local user account. The threshold is configured by using the access-limit command.
When the primary accounting method is local, the following rules apply to the accounting of a user:
·     The device uses the backup accounting methods in sequence only if local accounting is invalid for one of the following reasons:
¡     An exception occurs in the local accounting process.
·     The device does not turn to the backup accounting methods if local accounting is invalid because of any other reason. Accounting fails for the user.
Before configuring accounting methods, complete the following tasks:
1.     Determine the access type or service type to be configured. With AAA, you can configure an accounting method for each access type and service type.
2.     Determine whether to configure the default accounting method for all access types or service types. The default accounting method applies to all access users. However, the method has a lower priority than the accounting method that is specified for an access type or service type.
3.     (Optional.) Specify default accounting methods for all types of users.
accounting default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
By default, the accounting method is local.
4.     Specify accounting methods for a user type.
¡     Specify the command accounting method.
accounting command hwtacacs-scheme hwtacacs-scheme-name
By default, the default accounting methods are used for command accounting.
¡     Specify accounting methods for login users.
accounting login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
By default, the default accounting methods are used for login users.
Verifying and maintaining ISP domains
To display configuration information about an ISP domain or all ISP domains, execute the following command in any view:
display domain [ isp-name ]
Setting the maximum number of concurrent login users
Perform this task to set the maximum number of concurrent users that can log on to the device through a specific protocol, regardless of their authentication methods. The authentication methods include no authentication, local authentication, and remote authentication.
2.     Set the maximum number of concurrent login users.
aaa session-limit { ftp | http | https | ssh | telnet } max-sessions
By default, the maximum number of concurrent login users is 32 for each user type.
Configuring a NAS-ID
About NAS-IDs
During RADIUS authentication, the device uses a NAS-ID to set the NAS-Identifier attribute of RADIUS packets so that the RADIUS server can identify the access location of users.
You can configure a NAS-ID in ISP domain view. If no NAS-ID is set in ISP domain view, the device uses the device name (set by using the sysname command) as the NAS-ID.
Setting the NAS-ID in an ISP domain
3.     Set the NAS-ID in the ISP domain.
aaa nas-id nas-identifier
By default, no NAS-ID is set in an ISP domain.
Configuring the device ID
RADIUS uses the value of the Acct-Session-ID attribute as the accounting ID for a user. The device generates an Acct-Session-ID value that includes the device ID for each online user.
2.     Configure the device ID.
aaa device-id device-id
By default, the device ID is 0.
Enabling password change prompt logging
Use this feature to enhance the protection of passwords for Telnet, SSH, HTTP, HTTPS, NETCONF over SSH, and NETCONF over SOAP users and improve the system security.
This feature enables the device to generate logs to prompt users to change their weak passwords at an interval of 24 hours and at the users' login.
A password is a weak password if it does not meet the following requirements:
·     Password composition restriction configured by using the password-control composition command.
·     Minimum password length restriction set by using the password-control length command.
·     Password complexity checking policy configured by using the password-control complexity command.
For a NETCONF over SSH or NETCONF over SOAP user, the device also generates a password change prompt log if any of the following conditions exists:
·     The current password of the user is the default password or has expired.
·     The user logs in to the device for the first time or uses a new password to log in after global password control is enabled.
The device will no longer generate password change prompt logs for a user when one of the following conditions exists:
·     The password change prompt logging feature is disabled.
·     The user has changed the password and the new password meets the password control requirements.
·     The enabling status of a related password control feature has changed so the current password of the user meets the password control requirements.
·     The password composition policy or the minimum password length has changed.
You can use the display password-control command to display password control configuration. For more information about password control commands, see password control commands in User Access and Authentication Command Reference.
2.     Enable password change prompt logging.
local-server log change-password-prompt
By default, password change prompt logging is enabled.
Configuring an EAP profile
An EAP profile is a collection of EAP authentication settings, including the EAP authentication method and the CA certificate file to be used for some EAP authentication methods.
You can specify an EAP profile in multiple test profiles for RADIUS server status detection.
The system supports a maximum of 16 EAP profiles.
The device supports multiple EAP authentication methods. When the device initiates an authentication request to the peer, it preferentially uses the default EAP authentication method in an EAP profile. If the peer uses a different EAP authentication method, it will notify the device of its supported EAP authentication methods. The device will select a method that is supported both locally and by the peer to re-initiate the authentication request. However, if the access device uses the EAP termination mode in authentication for wireless clients, you can specify only the PEAP-GTC method as the default EAP authentication method.
Before you specify a local certificate, private key, or CA certificate, use FTP or TFTP to transfer the corresponding file to the root directory of the default storage medium on the device.
Before you specify an SSL server policy, complete the configuration of the SSL server policy and the PKI domain specified for the policy. For more information about SSL server policies and PKI domains, see SSL configuration and PKI configuration in Security Configuration Guide.
2.     Create an EAP profile and enter EAP profile view.
eap-profile eap-profile-name
3.     Specify the EAP authentication method.
method { md5 | peap-gtc | peap-mschapv2 | tls | ttls-gtc | ttls-mschapv2 }
By default, the EAP authentication method is MD5-challenge.
4.     Specify the local certificate file and the private key file for EAP authentication.
a.     Specify the local certificate file.
certificate-file file-name
By default, no local certificate file is specified for EAP authentication.
Perform this step if the PEAP-GTC, PEAP-MSCHAPv2, TTLS-GTC, TTLS-MSCHAPv2, or TLS EAP authentication method is used on the client and the client requests to authenticate the certificate of the server.
b.     Specify the private key file.
private-key-file file-name
By default, no private key file is specified for EAP authentication.
If the local certificate file for EAP authentication includes a private key, specify the local certificate file as the private key file.
c.     Specify the private key password for the local certificate.
private-key-password { cipher | simple } string
By default, no private key password is specified for the local certificate.
The private key password must be provided when the device imports or uses the private key of the local certificate. Make sure the private key password specified by using this command is the same as the private key password provided when the private key is imported to the device.
5.     Specify the CA certificate file for EAP authentication.
ca-file file-name
By default, no CA certificate file is specified for EAP authentication.
Perform this step for the device to authenticate certificates of the client if the client uses the PEAP-GTC, PEAP-MSCHAPv2, TTLS-GTC, or TTLS-MSCHAPv2 EAP authentication method.
6.     Specify an SSL server policy for EAP authentication.
ssl-server-policy policy-name
By default, no SSL server policy is specified for EAP authentication.
This step is required if the access device uses the EAP termination mode in authentication for wireless clients and the clients use the PEAP-GTC EAP method. The specified SSL server policy will be used for the access device to perform TLS tunnel negotiation with the clients.
Configuring user online and offline recording
About user online and offline recording
This feature enables the device to record user information when the users fail to come online, or the users go offline normally or abnormally. These records help the administrator to quickly identify the causes of user online and offline faults. The feature occupies the system memory. To reduce the memory usage, you can disable this feature.
Restrictions and guidelines for user online and offline recording configuration
This feature is applicable only to login users.
Enabling user online failure recording
2.     Enable user online failure recording.
aaa online-fail-record enable
By default, user online failure recording is disabled.
Enabling user offline recording
2.     Enable user offline recording.
aaa offline-record enable
By default, user offline recording is disabled.
User normal offline recording and user abnormal offline recording take effect only when this feature is enabled.
3.     Enable user normal offline recording.
aaa normal-offline-record enable
By default, user normal offline recording is disabled.
Verifying and maintaining user online and offline records
Displaying user online failure records
To display user online failure records, execute the following command in any view:
display aaa online-fail-record { access-type login | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number | username user-name [ fuzzy-match ] } * [ brief | count count ]
display aaa online-fail-record time begin-time end-time [ date begin-date end-date ] [ brief ]
Displaying user normal offline records
To display user normal offline records, execute the following command in any view:
display aaa normal-offline-record { access-type login | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number | username user-name [ fuzzy-match ] } * [ brief | count count ]
display aaa normal-offline-record time begin-time end-time [ date begin-date end-date ] [ brief ]
Displaying user abnormal offline records
To display user abnormal offline records, execute the following command in any view:
display aaa abnormal-offline-record { access-type login | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | svlan svlan-id [ cvlan cvlan-id ] | slot slot-number | username user-name [ fuzzy-match ] } * [ brief | count count ]
display aaa abnormal-offline-record offline-reason { idle-cut | quota-out | realtime-acct-fail | session-timeout | user-detect-fail } [ brief ]
display aaa abnormal-offline-record time begin-time end-time [ date begin-date end-date ] [ brief ]
Displaying user offline records
To display user offline records, execute the following command in any view:
display aaa offline-record { access-type login | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number | username user-name [ fuzzy-match ] } * [ brief | count count ]
display aaa offline-record time begin-time end-time [ date begin-date end-date ] [ brief ]
Clearing user online and offline records
Perform clear tasks in user view.
·     Clear user online failure records.
reset aaa online-fail-record
·     Clear user normal offline records.
reset aaa normal-offline-record
·     Clear user offline records.
reset aaa offline-record
Configuring the connection recording policy
About the connection recording policy
Use this feature on scenarios where the device acts as an FTP, SSH, SFTP, or Telnet login client to establish a connection with a login server. This feature enables the device to provide an accounting server with the connection start and termination information. When the login client establishes a connection with the login server, the system sends a start-accounting request to the accounting server. When the connection is terminated, the system sends a stop-accounting request to the accounting server.
The device includes the username entered by a user in the accounting packets to be sent to the AAA server for connection recording. The username format configured by using the user-name-format command in the accounting scheme does not take effect.
2.     Create a connection recording policy and enter its view.
aaa connection-recording policy
3.     Specify the accounting method for the connection recording policy.
accounting hwtacacs-scheme hwtacacs-scheme-name
Verifying and maintaining the connection recording policy
To display the connection recording policy configuration, execute the following command in any view:
display aaa connection-recording policy
Configuring the AAA test feature
This feature enables the device to send authentication or accounting requests to the specified AAA servers to simulate an authentication or accounting process of a user. Use this feature to identify the reasons for the failure of the interaction between the device and the AAA servers. This feature is applicable only to RADIUS.
When performing an AAA test, the device ignores the status of the specified AAA servers and the RADIUS server load sharing feature. The process of an AAA test is as follows:
1.     The device sends authentication requests that carry the specified username and password to the specified authentication server or to the authentication servers in the specified RADIUS scheme. The device tries to communicate with the authentication servers in the specified scheme in sequence.
The process goes to the next step in the following situations:
¡     The device receives an authentication response (no matter the authentication succeeds or fails).
¡     The device does not receive any authentication response after making all authentication request attempts.
This step is skipped if no correct authentication server is specified for the AAA test or no authentication servers are configured in the specified RADIUS scheme.
2.     The device sends start-accounting requests to the specified accounting server or to the accounting servers in the specified RADIUS scheme. The device tries to communicate with the accounting servers in the specified scheme in sequence.
¡     The device receives a start-accounting response (no matter the accounting succeeds or fails).
¡     The device does not receive any start-accounting response after making all start-accounting request attempts.
This step and the next step are skipped if no correct accounting server is specified for the AAA test or no accounting servers are configured in the specified RADIUS scheme.
3.     The device sends stop-accounting requests to the accounting servers to which it has sent a start-accounting request.
The process finishes in the following situations:
¡     The device receives a stop-accounting response.
¡     The device does not receive any stop-accounting response after making all stop-accounting request attempts.
To identify attributes that cause authentication or accounting failures, you can configure the device to carry specific attributes in RADIUS requests or define values for specific attributes in the requests. Table 3 shows the attributes that RADIUS requests carry by default.
Table 3 Attributes that RADIUS requests carry by default
Packet type
Attributes that the type of packets carry by default
User-Name
CHAP-Password (or User-Password)
CHAP-Challenge
NAS-IP-Address (or NAS-IPv6-Address)
Service-Type
Framed-Protocol
NAS-Identifier
NAS-Port-Type
Acct-Session-Id
RADIUS accounting request
User-Name
Acct-Status-Type
NAS-Identifier
Acct-Session-Id
Acct-Delay-Time
Acct-Terminate-Cause
When you perform an AAA test, follow these restrictions and guidelines:
·     The device might communicate with the AAA servers incorrectly during an AAA test. Make sure no users come online or go offline during an AAA text.
·     If the configuration of the specified RADIUS scheme changes, the new configuration does not affect the current AAA test. The modification will take effect in the next test.
·     The system can have only one AAA test at a time. Another AAA test can be performed only after the current test finishes.
When you configure attributes to be included in or excluded from RADIUS requests, follow these restrictions and guidelines:
·     Before you include an attribute that is already configured to be excluded from RADIUS requests, you must cancel the exclusion configuration by using the undo exclude command.
·     Before you exclude an attribute that is already configured to be included in RADIUS requests, you must cancel the inclusion configuration by using the undo include command.
Before you perform an AAA test, you must configure a RADIUS scheme that contains the RADIUS servers to be tested.
Plan the RADIUS attributes to be included in RADIUS requests. Besides the attributes carried by default, the device adds the specified attributes to RADIUS packets in the order that they are specified by using the include command. Additional attributes cannot be added to a RADIUS request if the length of the RADIUS request reaches 4096 bytes.
1.     (Optional.) Configure a RADIUS attribute test group:
a.     Enter system view.
b.     Create a RADIUS attribute test group and enter its view.
radius attribute-test-group attr-test-group-name
You can create multiple RADIUS attribute test groups.
c.     Include an attribute in RADIUS requests.
include { accounting | authentication } { name attribute-name | [ vendor vendor-id ] code attribute-code } type { binary | date | integer | interface-id | ip | ipv6 | ipv6-prefix | octets | string } value attribute-value
Use this command to add attributes that RADIUS requests do not carry by default to the RADIUS requests.
For an attribute that RADIUS requests carry by default, you can use this command to change its attribute value.
d.     Exclude an attribute from RADIUS requests.
exclude { accounting | authentication } name attribute-name
Use this command to exclude an attribute that RADIUS requests carry by default from the RADIUS requests sent during an AAA test to help troubleshoot authentication or accounting failures.
e.     Return to system view.
f.     Return to user view.
2.     Perform an AAA test in user view.
test-aaa user user-name password password radius-scheme radius-scheme-name [ radius-server { ipv4-address | ipv6 ipv6-address } port-number [ vpn-instance vpn-instance-name ] ] [ chap | pap ] [ attribute-test-group attr-test-group-name ] [ trace ]
Recommended actions on failed test results
If you receive an error message after you execute the test-aaa command, use the following information to remove the issue:
Message
Possible causes
Recommended action
Authentication or accounting request expired
The device cannot reach the RADIUS server.
Check for communication issues between the device and the server.
The device and the RADIUS server are inconsistent in the following settings:
·     UDP port number for RADIUS authentication or accounting service.
·     Shared key for authentication or accounting.
1.     Examine the RADIUS scheme used in the authentication domain.
2.     Make sure the scheme contains the same service port numbers and shared keys as the RADIUS authentication, authorization, and accounting servers.
The IP address of the device is not added to the RADIUS server.
Incorrect IP address is added to the RADIUS server for the device.
Add the node IP address of the device to the RADIUS server.
IMPORTANT IMPORTANT:
This IP address must be the source IP address used by the device to send RADIUS packets to the RADIUS server.
The RADIUS authentication or accounting service port number has been used by another program on the server.
3.     Search the server for conflicting service numbers.
4.     Close the program that uses the same port number as the RADIUS authentication or accounting service.
Authentication request rejected by the RADIUS server
This issue might result from various errors, for example, user information not found in the database of the RADIUS server or incorrect user password.
5.     Review the authentication log on the RADIUS server.
6.     Take action depending on the cause of rejection and the failure cause provided in the log.
The RADIUS scheme does not contain RADIUS authentication or accounting servers or does not contain the specified server
The RADIUS scheme specified for the test-aaa command has one of the following issues:
·     The scheme does not contain RADIUS authentication or accounting servers.
·     The RADIUS server parameters specified in the scheme are inconsistent with the actual settings for the target servers.
7.     Examine the RADIUS scheme and make sure:
¡     The scheme contains a minimum of one RADIUS authentication server and a minimum of one RADIUS accounting server.
¡     The RADIUS server parameters specified in the scheme are consistent with the actual settings for the target servers.
8.     Re-execute the test-aaa command with the correct RADIUS scheme.
AAA configuration examples
Example: Configuring authentication and authorization for SSH users by a RADIUS server
As shown in Figure 10, configure the router to meet the following requirements:
·     Use the RADIUS server for SSH user authentication and authorization.
·     Include domain names in the usernames sent to the RADIUS server.
·     Assign the network-admin user role to SSH users after they pass authentication.
The RADIUS server runs IMC PLAT 7.3 (E0605) and IMC UAM 7.3 (E0512). Add an account with username hello@bbb on the RADIUS server.
The RADIUS server and the router use expert as the shared key for secure RADIUS communication. The ports for authentication and accounting are 1812 and 1813, respectively.
Figure 10 Network diagram
Configure IP addresses for interfaces, and make sure the devices are reachable.
Configuring the RADIUS server
1.     Add the router to the IMC Platform as an access device:
a.     Log in to IMC.
b.     Click the User tab.
c.     From the navigation tree, select User Access Policy > Access Device Management > Access Device.
d.     Click Add.
The Add Access Device page opens.
e.     In the Access Configuration area, configure the following parameters, as shown in Figure 11:
-     Set the authentication port and accounting port to 1812 and 1813, respectively.
-     Select Device Management Service from the Service Type list.
-     Select H3C (General) from the Access Device Type list.
-     Set the shared key for secure RADIUS communication to expert.
-     Use the default values for other parameters.
f.     In the Device List area, click Select or Add Manually to add the device at 10.1.1.2 as an access device.
IMPORTANT
IMPORTANT:
You must specify the source IP address of outgoing RADIUS packets on the router as the IP address of the access device on the server.
On the router, the source IP address configured by using the source-ip command has higher priority than the source IP address configured by using the radius source-ip command. If no IP address is specified as the source IP address, the IP address of the packet outbound interface is used as the source IP address.
In this example, no source IP address is specified on the router. The IP address of the packet outbound interface on the router is specified as the IP address of the access device on the server, which is 10.1.1.2.
g.     Click OK.
Figure 11 Adding the router as an access device
2.     Add an account for device management:
a.     Click the User tab.
b.     From the navigation tree, select Device User > Device User.
c.     Click Add.
d.     On the Add Device User page, configure the following parameters, as shown in Figure 12:
-     Enter account name hello@bbb and specify the password.
-     Select SSH from the Login Type list.
-     Enter network-admin in the Role Name field.
-     In the IP Address List of Managed Devices area, click Add to specify an IP segment (from 10.1.1.0 to 10.1.1.255) for management.
IMPORTANT
IMPORTANT:
The managed IP segment must contain the NAS IP address of the router.
On the router, the NAS IP address configured by using the nas-ip command has higher priority than the NAS IP address configured by using the radius nas-ip command. If no IP address is specified as the NAS IP address, the IP address of the packet outbound interface is used as the NAS IP address.
In this example, no NAS IP address is specified on the router. The IP address (10.1.1.2) of the packet outbound interface on the router must be contained in the managed IP segment.
e.     Click OK.
Figure 12 Adding an account for device management
Configuring the router
# Create local RSA and DSA key pairs.
<Router> system-view
[Router] public-key local create rsa
[Router] public-key local create dsa
# Enable the Stelnet service.
[Router] ssh server enable
# Enable scheme authentication for user lines VTY 0 through VTY 63.
[Router] line vty 0 63
[Router-line-vty0-63] authentication-mode scheme
[Router-line-vty0-63] quit
# Create a RADIUS scheme.
[Router] radius scheme rad
# Specify the primary authentication server.
[Router-radius-rad] primary authentication 10.1.1.1 1812
# Set the shared key to expert in plaintext form for secure communication with the server.
[Router-radius-rad] key authentication simple expert
# Include domain names in the usernames sent to the RADIUS server.
[Router-radius-rad] user-name-format with-domain
[Router-radius-rad] quit
# Create an ISP domain named bbb and configure authentication, authorization, and accounting methods for login users. Because RADIUS user authorization information is piggybacked in authentication responses, the authentication and authorization methods must use the same RADIUS scheme.
[Router] domain name bbb
[Router-isp-bbb] authentication login radius-scheme rad
[Router-isp-bbb] authorization login radius-scheme rad
[Router-isp-bbb] accounting login none
[Router-isp-bbb] quit
# Specify ISP domain bbb as the default ISP domain.
[Router] domain default enable bbb
# Initiate an SSH connection to the router, and enter username hello@bbb and the correct password. The user logs in to the router. (Details not shown.)
# Verify that the user can use the commands permitted by the network-admin user role. (Details not shown.)
Example: Configuring local authentication and authorization for SSH users
As shown in Figure 13, configure the router to meet the following requirements:
·     Perform local authentication and authorization for SSH users.
Figure 13 Network diagram
# Create a device management user.
[Router] local-user ssh class manage
# Assign the SSH service to the local user.
[Router-luser-manage-ssh] service-type ssh
# Set the password to 123456TESTplat&! in plaintext form for the local user.
[Router-luser-manage-ssh] password simple 123456TESTplat&!
# Specify the user role for the user as network-admin.
[Router-luser-manage-ssh] authorization-attribute user-role network-admin
[Router-luser-manage-ssh] quit
# Create an ISP domain named bbb and configure the domain to use local authentication and authorization for login users.
[Router-isp-bbb] authentication login local
[Router-isp-bbb] authorization login local
# Initiate an SSH connection to the router, and enter username ssh@bbb and the correct password. The user logs in to the router. (Details not shown.)
Example: Configuring AAA for SSH users by an HWTACACS server
As shown in Figure 14, configure the router to meet the following requirements:
·     Use the HWTACACS server for SSH user authentication, authorization, and accounting.
·     Assign the default user role network-operator to SSH users after they pass authentication.
·     Exclude domain names from the usernames sent to the HWTACACS server.
·     Use expert as the shared keys for secure HWTACACS communication.
Figure 14 Network diagram
Configuring the HWTACACS server
# Set the shared keys to expert for secure communication with the router.
# Add an account for the SSH user, specify the password, but do not specify a user role for the user. (Details not shown.)
# Create local RSA key pairs with default names.
# Create a local DSA key pair with the default name.
# Enable the Stelnet server.
# Create an HWTACACS scheme.
[Router] hwtacacs scheme hwtac
[Router-hwtacacs-hwtac] primary authentication 10.1.1.1 49
# Specify the primary authorization server.
[Router-hwtacacs-hwtac] primary authorization 10.1.1.1 49
# Specify the primary accounting server.
[Router-hwtacacs-hwtac] primary accounting 10.1.1.1 49
# Set the shared keys to expert in plaintext form for secure HWTACACS communication.
[Router-hwtacacs-hwtac] key authentication simple expert
[Router-hwtacacs-hwtac] key authorization simple expert
[Router-hwtacacs-hwtac] key accounting simple expert
# Exclude domain names from the usernames sent to the HWTACACS server.
[Router-hwtacacs-hwtac] user-name-format without-domain
[Router-hwtacacs-hwtac] quit
# Create an ISP domain and configure the domain to use the HWTACACS scheme for login user authentication, authorization, and accounting.
[Router-isp-bbb] authentication login hwtacacs-scheme hwtac
[Router-isp-bbb] authorization login hwtacacs-scheme hwtac
[Router-isp-bbb] accounting login hwtacacs-scheme hwtac
# Enable the default user role feature to assign authenticated SSH users the default user role network-operator.
[Router] role default-role enable
# Initiate an SSH connection to the router, and enter the correct username and password. The user logs in to the router. (Details not shown.)
# Verify that the user can use the commands permitted by the network-operator user role. (Details not shown.)
Troubleshooting AAA
RADIUS authentication failure
Symptom
User authentication always fails.
Analysis
Possible reasons include:
·     A communication failure exists between the NAS and the RADIUS server.
·     The username does not include a domain name, the format of the username containing a domain name is incorrect, or the ISP domain is not correctly configured on the NAS.
·     The user is not configured on the RADIUS server.
·     The password entered by the user is incorrect.
·     The RADIUS server and the NAS are configured with different shared keys.
Solution
To resolve the problem:
1.     Verify the following items:
¡     The NAS and the RADIUS server can ping each other.
¡     The username contains a domain name, the format of the username is correct, and the ISP domain is correctly configured on the NAS.
¡     The user is configured on the RADIUS server.
¡     The correct password is entered.
¡     The same shared key is configured on both the RADIUS server and the NAS.
2.     If the problem persists, contact H3C Support.
RADIUS packet delivery failure
Symptom
RADIUS packets cannot reach the RADIUS server.
Analysis
·     The NAS is not configured with the IP address of the RADIUS server.
·     The authentication and accounting UDP ports configured on the NAS are incorrect.
·     The RADIUS server's authentication and accounting port numbers are being used by other applications.
Solution
¡     The link between the NAS and the RADIUS server works well at both the physical and data link layers.
¡     The IP address of the RADIUS server is correctly configured on the NAS.
¡     The authentication and accounting UDP port numbers configured on the NAS are the same as those of the RADIUS server.
¡     The RADIUS server's authentication and accounting port numbers are available.
RADIUS accounting error
Symptom
A user is authenticated and authorized, but accounting for the user is not normal.
Analysis
The accounting server configuration on the NAS is not correct. Possible reasons include:
·     The accounting port number configured on the NAS is incorrect.
·     The accounting server IP address configured on the NAS is incorrect. For example, the NAS is configured to use a single server to provide authentication, authorization, and accounting services, but in fact the services are provided by different servers.
Solution
¡     The accounting port number is correctly configured.
¡     The accounting server IP address is correctly configured on the NAS.
Troubleshooting HWTACACS
Similar to RADIUS troubleshooting. See "RADIUS authentication failure," "RADIUS packet delivery failure," and "RADIUS accounting error."
Appendixes
Appendix A  Commonly used RADIUS attributes
Commonly used RADIUS attributes are defined in RFC 2865, RFC 2866, RFC 2867, and RFC 2868.
Table 4 Commonly used RADIUS attributes
No.
Attribute
No.
Attribute
1
User-Name
45
Acct-Authentic
2
User-Password
46
Acct-Session-Time
3
CHAP-Password
47
Acct-Input-Packets
4
NAS-IP-Address
48
Acct-Output-Packets
5
NAS-Port
49
6
Service-Type
50
Acct-Multi-Session-Id
7
Framed-Protocol
51
Acct-Link-Count
8
Framed-IP-Address
52
Acct-Input-Gigawords
9
Framed-IP-Netmask
53
Acct-Output-Gigawords
10
Framed-Routing
54
(unassigned)
11
Filter-ID
55
Event-Timestamp
12
Framed-MTU
56-59
(unassigned)
13
Framed-Compression
60
CHAP-Challenge
14
Login-IP-Host
61
NAS-Port-Type
15
Login-Service
62
Port-Limit
16
Login-TCP-Port
63
Login-LAT-Port
17
(unassigned)
64
Tunnel-Type
18
Reply-Message
65
Tunnel-Medium-Type
19
Callback-Number
66
Tunnel-Client-Endpoint
20
Callback-ID
67
Tunnel-Server-Endpoint
21
(unassigned)
68
Acct-Tunnel-Connection
22
Framed-Route
69
Tunnel-Password
23
Framed-IPX-Network
70
ARAP-Password
24
71
ARAP-Features
25
Class
72
ARAP-Zone-Access
26
Vendor-Specific
73
ARAP-Security
27
Session-Timeout
74
ARAP-Security-Data
28
Idle-Timeout
75
Password-Retry
29
Termination-Action
76
Prompt
30
Called-Station-Id
77
Connect-Info
31
Calling-Station-Id
78
Configuration-Token
32
NAS-Identifier
79
EAP-Message
33
Proxy-State
80
Message-Authenticator
34
Login-LAT-Service
81
Tunnel-Private-Group-ID
35
Login-LAT-Node
82
Tunnel-Assignment-id
36
Login-LAT-Group
83
Tunnel-Preference
37
Framed-AppleTalk-Link
84
ARAP-Challenge-Response
38
Framed-AppleTalk-Network
85
Acct-Interim-Interval
39
Framed-AppleTalk-Zone
86
Acct-Tunnel-Packets-Lost
40
Acct-Status-Type
87
NAS-Port-Id
41
Acct-Delay-Time
88
Framed-Pool
42
Acct-Input-Octets
89
(unassigned)
43
Acct-Output-Octets
90
Tunnel-Client-Auth-id
44
Acct-Session-Id
91
Tunnel-Server-Auth-id
Appendix B  Descriptions of commonly used standard RADIUS attributes
No.
Attribute
1
User-Name
Name of the user to be authenticated.
2
User-Password
User password for PAP authentication, only present in Access-Request packets when PAP authentication is used.
3
CHAP-Password
Digest of the user password for CHAP authentication, only present in Access-Request packets when CHAP authentication is used.
4
NAS-IP-Address
IP address for the server to use to identify the client. Typically, a client is identified by the IP address of its access interface. This attribute is only present in Access-Request packets.
5
NAS-Port
Physical port of the NAS that the user accesses.
6
Service-Type
Type of service that the user has requested or type of service to be provided.
7
Framed-Protocol
Encapsulation protocol for framed access.
8
Framed-IP-Address
IP address assigned to the user.
11
Filter-ID
Name of the filter list. This attribute is parsed as follows:
·     The attribute value represents an ACL number, if it is a string of all digits.
·     The attribute value is an ACL name if it is not a string of all digits, does not contain an equal sign (=), and is followed by the H3c-ACL-Version attribute.
·     The attribute value is a user profile name, if it is not a string of all digits, does not contain an equal sign (=), and is not followed by the H3c-ACL-Version attribute.
14
Login-IP-Host
IP address of the NAS interface that the user accesses.
15
Login-Service
Type of service that the user uses for login.
18
Reply-Message
Text to be displayed to the user, which can be used by the server to communicate information, for example, the cause of the authentication failure.
26
Vendor-Specific
Vendor-specific proprietary attribute. A packet can contain one or more proprietary attributes, each of which can contain one or more subattributes.
27
Session-Timeout
Maximum service duration for the user before termination of the session.
Value 0 indicates that the user will be logged out. Value 4294967295 indicates that no limit is placed on the online duration of the user.
28
Idle-Timeout
Maximum idle time permitted for the user before termination of the session.
31
Calling-Station-Id
User identification that the NAS sends to the server. For the LAN access service provided by an H3C device, this attribute includes the MAC address of the user.
32
NAS-Identifier
Identification that the NAS uses to identify itself to the RADIUS server.
40
Acct-Status-Type
Type of the Accounting-Request packet. Possible values include:
·     1—Start.
·     2—Stop.
·     3—Interim-Update.
·     4—Reset-Charge.
·     7—Accounting-On. (Defined in the 3rd Generation Partnership Project.)
·     8—Accounting-Off. (Defined in the 3rd Generation Partnership Project.)
·     9 to 14—Reserved for tunnel accounting.
·     15—Reserved for failed.
45
Acct-Authentic
Authentication method used by the user. Possible values include:
·     1—RADIUS.
·     2—Local.
·     3—Remote.
60
CHAP-Challenge
CHAP challenge generated by the NAS for MD5 calculation during CHAP authentication.
61
NAS-Port-Type
Type of the physical port of the NAS that is authenticating the user. Possible values include:
·     15—Ethernet.
·     16—Any type of ADSL.
·     17—Cable. (With cable for cable TV.)
·     19—WLAN-IEEE 802.11.
·     201—VLAN.
·     202—ATM.
If the port is an ATM or Ethernet one and VLANs are implemented on it, the value of this attribute is 201.
64
Tunnel-Type
Tunneling protocols used.
The value 13 represents VLAN. If the value is 13, the device interprets the Tunnel-Type, Tunnel-Medium-Type, and Tunnel-Private-Group-ID attributes as attributes to assign VLANs.
65
Tunnel-Medium-Type
Transport medium type to use for creating a tunnel.
For VLAN assignment, the value must be 6 to indicate the 802 media plus Ethernet.
79
EAP-Message
Used to encapsulate EAP packets to allow RADIUS to support EAP authentication.
80
Used for authentication and verification of authentication packets to prevent spoofing Access-Requests. This attribute is present when EAP authentication is used.
81
Group ID for a tunnel session. To assign VLANs, the NAS conveys VLAN IDs by using this attribute.
87
NAS-Port-Id
String for describing the port of the NAS that is authenticating the user.
168
Framed-IPv6-Address
Server-assigned IPv6 address for the NAS to assign to the host. The address must be unique.
185
WLAN-Reason-Code
Reason code for WLAN endpoint authentication failure.
The length is 32 bits. The first 16 bits are reserved and the remaining 16 bits represent the reason code.
186
WLAN-Pairwise-Cipher
Cipher suite for WLAN unicast frames.
The length is 32 bits. The first 24 bits represent the OUI and the remaining 8 bits represent the suite type.
187
WLAN-Group-Cipherr
Cipher suite for WLAN multicast frames.
188
WLAN-AKM-Suite
Authentication and Key Management (AKM) mode.
189
WLAN-Group-Mgmt-Cipher
Cipher suite for WLAN multicast management frames.
Appendix C  RADIUS subattributes (vendor ID 25506)
Table 5 lists all RADIUS subattributes with a vendor ID of 25506. Support for these subattributes depends on the device model.
Table 5 RADIUS subattributes (vendor ID 25506)
No.
Subattribute
1
Input-Peak-Rate
Peak rate in the direction from the user to the NAS.
By default, the measurement unit is bps.
If a measurement unit is assigned to CAR attributes through the AV-Pair attribute, the assigned measurement unit takes effect.
2
Input-Average-Rate
Average rate in the direction from the user to the NAS.
3
Input-Basic-Rate
Basic rate in the direction from the user to the NAS.
4
Output-Peak-Rate
Peak rate in the direction from the NAS to the user.
5
Output-Average-Rate
Average rate in the direction from the NAS to the user.
6
Output-Basic-Rate
Basic rate in the direction from the NAS to the user.
15
Remanent_Volume
Total amount of data available for the connection, in different units for different server types.
17
ISP-ID
ISP domain where the user obtains authorization information.
20
Operation for the session, used for session control. Possible values include:
·     1—Trigger-Request.
·     2—Terminate-Request.
·     3—SetPolicy.
·     4—Result.
·     5—PortalClear.
25
Result_Code
Result of the Trigger-Request or SetPolicy operation, zero for success and any other value for failure.
26
Connect_ID
Index of the user connection.
28
Ftp_Directory
FTP, SFTP, or SCP user working directory.
When the RADIUS client acts as the FTP, SFTP, or SCP server, this attribute is used to set the working directory for an FTP, SFTP, or SCP user on the RADIUS client.
29
Exec_Privilege
EXEC user priority.
59
NAS_Startup_Timestamp
Startup time of the NAS in seconds, which is represented by the time elapsed after 00:00:00 on Jan. 1, 1970 (UTC).
60
Ip_Host_Addr
User IP address and MAC address included in authentication and accounting requests, in the format A.B.C.D hh:hh:hh:hh:hh:hh. A space is required between the IP address and the MAC address.
61
User_Notify
Information that must be sent from the server to the client transparently.
98
Multicast_Receive_Group
IP address of the multicast group that the user's host joins as a receiver. This subattribute can appear multiple times in a multicast packet to indicate that the user belongs to multiple multicast groups.
100
IP6_Multicast_Receive_Group
IPv6 address of the multicast group that the user's host joins as a receiver. This subattribute can appear multiple times in a multicast packet to indicate that the user belongs to multiple multicast groups.
103
IGMP-Access-Limit
Maximum number of IGMP multicast groups that the user can join concurrently.
104
VPN-Instance
MPLS L3VPN instance to which a user belongs.
105
ANCP-Profile
ANCP profile name.
135
Client-Primary-DNS
IP address of the primary DNS server.
136
Client-Secondary-DNS
IP address of the secondary DNS server.
140
User_Group
User groups assigned after the user passes authentication.
Typically, a user can belong to only one user group.
144
Acct_IPv6_Input_Octets
Bytes of IPv6 packets in the inbound direction. The measurement unit depends on the configuration on the device.
145
Acct_IPv6_Output_Octets
Bytes of IPv6 packets in the outbound direction. The measurement unit depends on the configuration on the device.
146
Acct_IPv6_Input_Packets
Number of IPv6 packets in the inbound direction. The measurement unit depends on the configuration on the device.
147
Acct_IPv6_Output_Packets
Number of IPv6 packets in the outbound direction. The measurement unit depends on the configuration on the device.
148
Acct_IPv6_Input_Gigawords
Bytes of IPv6 packets in the inbound direction. The measurement unit is 4G bytes.
149
Acct_IPv6_Output_Gigawords
Bytes of IPv6 packets in the outbound direction. The measurement unit is 4G bytes.
155
User-Roles
List of space-separated user roles.
210
Av-Pair
User-defined attribute pair. Available attribute pairs include:
·     Server-assigned user role in the format of shell:role=xxx.
·     Server-assigned ACL in the format of url-redirect-acl=xxx.
·     Server-assigned Web redirect URL in the format of url-redirect=xxx.
·     Server-deployed command to reboot a port, in the format of subscriber:command=bounce-host-port.
·     Server-assigned port shutdown duration in the format of bounce:seconds=xxx.
·     Server-deployed command to shut down a port, in the format of subscriber:command=disable-host-port.
·     Server-assigned blackhole MAC address attribute in the format of mac:block-mac=xxx.
·     Server-assigned measurement unit for CAR attributes, in the format of car:car-unit="xxx".
215
Accounting-Level
ITA traffic level in the range of 1 to 8.
216
Ita-Policy
ITA policy name.
230
NAS-Port-Name
Interface through which the user is connected to the NAS.
246
Auth_Detail_Result
Accounting details. The server sends Access-Accept packets with subattributes 246 and 250 in the following situations:
·     1—The subscriber charge is overdue. The subscriber is allowed to access network resources in the whitelist. If the subscriber accesses other network resources, the device redirects it to the URL specified by subattribute 250.
·     2—The broadband lease of the subscriber expires. The device redirects the subscriber to the URL specified by subattribute 250 when the subscriber requests to access webpages for the first time.
247
Input-Committed-Burst-Size
Committed burst size from the user to the NAS, in bits. The total length cannot exceed 4 bytes for this field.
This subattribute must be assigned together with the Input-Average-Rate attribute.
248
Output-Committed-Burst-Size
Committed burst size from the NAS to the user, in bits. The total length cannot exceed 4 bytes for this field.
This subattribute must be assigned together with the Output-Average-Rate attribute.
249
authentication-type
Authentication type. The value can be:
·     1—Intranet access authentication.
·     2—Internet access authentication.
If the packet does not contain this subattribute, common authentication applies.
250
WEB-URL
Redirect URL for users.
251
Subscriber-ID
Family plan ID.
252
Subscriber-Profile
QoS policy name for the family plan of the subscriber.
255
Product_ID
Product name.
Appendix D  HWTACACS attributes
HWTACACS authorization and accounting packets include the HWTACACS attributes assigned by the server to a user and the HWTACACS attributes uploaded by a user to the server. Table 6 shows the HWTACACS attributes supported by the device. The device ignores an HWTACACS attribute if it does not support that attribute.
Table 6 Supported HWTACACS attributes
Attribute name
acl
Number of the ACL assigned to the user.
idletime
Idle timeout period, in seconds.
priv-lvl
User privilege level in the range of level 0 to level 15.
ftp-directory
Initial working directory of the FTP user.
addr
addr-pool
IP address pool assigned to the user.
tunnel-type
Type of the tunnel to be established. Only L2TP is supported.
ip-addresses
LNS IP addresses.
tunnel-id
Group ID of the L2TP tunnel.
gw-password
Authentication password of the L2TP tunnel.
roles
User roles assigned to the user.
allowed-roles
Roles for which the user is allowed to obtain temporary authorization.
