11-VXLAN Configuration Guide
HomeSupportSwitchesS12500R SeriesConfigure & DeployConfiguration GuidesH3C S12500R Switch Router Series Configuration Guides(R52xx)-6W10111-VXLAN Configuration Guide
01-Basic VXLAN configuration
01-Basic VXLAN configuration 421.86 KB
VXLAN overview·· 1
VXLAN benefits· 1
VXLAN network model 1
VXLAN packet format 2
VXLAN working mechanisms· 3
Generic VXLAN network establishment and forwarding process· 3
VXLAN tunnel establishment and assignment 3
Assignment of traffic to VXLANs· 3
MAC learning· 4
Unicast forwarding· 4
Flood· 6
Access modes of VSIs· 7
ARP and ND flood suppression· 8
VXLAN IP gateways· 9
VXLAN M-LAG·· 9
Protocols and standards· 10
Configuring basic VXLAN features· 11
Restrictions: Interface link mode· 11
VXLAN tasks at a glance· 11
Prerequisites for VXLAN· 11
Creating a VXLAN on a VSI 11
Configuring a VXLAN tunnel 12
Manually creating a VXLAN tunnel 12
Manually assigning VXLAN tunnels to a VXLAN· 13
Assigning customer frames to a VSI 13
Mapping an Ethernet service instance to a VSI 13
Managing MAC address entries· 15
About MAC address entry management 15
Configuring static MAC address entries· 15
Disabling remote-MAC address learning· 15
Enabling local-MAC logging· 16
Setting the destination UDP port number of VXLAN packets· 16
Configuring VXLAN packet check· 16
Enabling default VXLAN decapsulation· 17
Enabling ECN for VXLANs· 17
Disabling flooding for a VSI 18
Enabling ARP flood suppression· 18
Enabling ND flood suppression· 19
Configuring VXLAN M-LAG·· 19
Enabling VXLAN packet statistics· 21
Enabling packet statistics for a VSI 21
Enabling packet statistics for an AC· 22
Setting the L2VPN statistics collection interval 22
Testing the connectivity of a VXLAN tunnel 22
Enabling overlay OAM·· 22
Pinging a VXLAN tunnel destination· 23
Tracing the path to a VXLAN tunnel destination· 24
Verifying and maintaining VXLANs· 25
Verifying VXLAN tunnel configuration and running status· 25
Displaying information about Ethernet service instances· 25
Verifying and maintaining VSIs· 25
Verifying and maintaining ACs· 26
Displaying the current packet statistic collection mode· 26
Verifying and maintaining L2VPN entries on M-LAG member devices· 26
VXLAN configuration examples· 27
Example: Configuring a unicast-mode VXLAN· 27
VXLAN overview
Virtual eXtensible LAN (VXLAN) is a MAC-in-UDP technology that provides Layer 2 connectivity between distant network sites across an IP network. VXLAN is typically used in data centers and the access layer of campus networks for multitenant services.
VXLAN benefits
VXLAN provides the following benefits:
·     Support for more virtual switched domains than VLANs—Each VXLAN is uniquely identified by a 24-bit VXLAN ID. The total number of VXLANs can reach 16777216 (224). This specification makes VXLAN a better choice than 802.1Q VLAN to isolate traffic for user terminals.
·     Easy deployment and maintenance—VXLAN requires deployment only on the edge devices of the transport network. Devices in the transport network perform typical Layer 3 forwarding.
VXLAN network model
As shown in Figure 1, a VXLAN is a virtual Layer 2 network (known as the overlay network) built on top of an existing physical Layer 3 network (known as the underlay network). The overlay network encapsulates inter-site Layer 2 frames into VXLAN packets and forwards the packets to the destination along the Layer 3 forwarding paths provided by the underlay network. The underlay network is transparent to tenants, and geographically dispersed sites of a tenant are merged into a Layer 2 network.
The transport edge devices assign user terminals to different VXLANs, and then forward traffic between sites for user terminals by using VXLAN tunnels. Supported user terminals include PCs, wireless terminals, and VMs on servers.
This document uses VMs as examples to describe the mechanisms of VXLAN. The mechanisms do not differ between different kinds of user terminals.
The transport edge devices are VXLAN tunnel endpoints (VTEP). The VTEP implementation of the device uses ACs, VSIs, and VXLAN tunnels to provide VXLAN services.
·     VSI—A virtual switch instance is a virtual Layer 2 switched domain. Each VSI provides switching services only for one VXLAN. VSIs learn MAC addresses and forward frames independently of one another. VMs in different sites have Layer 2 connectivity if they are in the same VXLAN.
·     Attachment circuit (AC)—An AC is a physical or virtual link that connects a VTEP to a local site. Typically, ACs are Ethernet service instances that are associated with the VSI of a VXLAN. Traffic received from an AC is assigned to the VSI associated with the AC. Ethernet service instances are created on site-facing Layer 2 interfaces. An Ethernet service instance matches a list of custom VLANs by using a frame match criterion.
·     VXLAN tunnel—Logical point-to-point tunnels between VTEPs over the transport network. Each VXLAN tunnel can trunk multiple VXLANs.
VTEPs encapsulate VXLAN traffic in the VXLAN, outer UDP, and outer IP headers. The devices in the transport network forward VXLAN traffic only based on the outer IP header.
Figure 1 VXLAN network model
VXLAN packet format
As shown in Figure 2, a VTEP encapsulates a frame in the following headers:
·     8-byte VXLAN header—VXLAN information for the frame.
¡     Flags—If the I bit is 1, the VXLAN ID is valid. If the I bit is 0, the VXLAN ID is invalid. All other bits are reserved and set to 0.
¡     24-bit VXLAN ID—Identifies the VXLAN of the frame. It is also called the virtual network identifier (VNI).
·     8-byte outer UDP header for VXLAN—The default VXLAN destination UDP port number is 4789.
·     20-byte outer IP header—Valid addresses of VTEPs or VXLAN multicast groups on the transport network. Devices in the transport network forward VXLAN packets based on the outer IP header.
Figure 2 VXLAN packet format
The VTEP uses the following process to establish the VXLAN network and forward an inter-site frame:
1.     Discovers remote VTEPs, establishes VXLAN tunnels, and assigns the VXLAN tunnels to VXLANs.
2.     Assigns the frame to its matching VXLAN if the frame is sent between sites.
3.     Performs MAC learning on the VXLAN's VSI.
4.     Forwards the frame through VXLAN tunnels.
This section describes this process in detail. For intra-site frames in a VSI, the system performs typical Layer 2 forwarding, and it processes 802.1Q VLAN tags as described in "Access modes of VSIs."
To provide Layer 2 connectivity for a VXLAN between two sites, you must create a VXLAN tunnel between the sites and assign the tunnel to the VXLAN.
VXLAN supports manual and automatic VXLAN tunnel establishment.
·     Manual creation—Manually create a VXLAN tunnel interface, and specify the tunnel source and destination IP addresses on the peer VTEPs.
·     Automatic creation—Configure Ethernet Virtual Private Network (EVPN) to automatically discover VTEPs and set up VXLAN tunnels. For more information about EVPN, see EVPN Configuration Guide.
VXLAN tunnel assignment
VXLAN supports manual and automatic VXLAN tunnel assignment.
·     Manual assignment—Manually assign VXLAN tunnels to VXLANs.
·     Automatic assignment—Run EVPN to automatically assign VXLAN tunnels to VXLANs. For more information about EVPN, see EVPN Configuration Guide.
Traffic from the local site to a remote site
The VTEP uses the Ethernet service instance-to-VSI mapping method to assign customer frames to a VXLAN. This method uses the frame match criterion of an Ethernet service instance to match a list of VLANs on a site-facing Layer 2 interface. The frame match criterion specifies the characteristics of traffic from the VLANs, such as tagging status and VLAN IDs. The VTEP assigns customer traffic to a VXLAN by mapping the Ethernet service instance to a VSI.
As shown in Figure 3, Ethernet service instance 1 matches VLAN 2 and is mapped to VSI A (VXLAN 10). When a frame from VLAN 2 arrives, the VTEP assigns the frame to VXLAN 10, and looks up VSI A's MAC address table for the outgoing interface.
Figure 3 Identifying traffic from the local site
Traffic from a remote site to the local site
When a frame arrives at a VXLAN tunnel, the VTEP uses the VXLAN ID in the frame to identify its VXLAN.
MAC learning
The VTEP performs source MAC learning on the VSI as a Layer 2 switch.
·     For traffic from the local site to the remote site, the VTEP learns the source MAC address before VXLAN encapsulation.
·     For traffic from the remote site to the local site, the VTEP learns the source MAC address after removing the VXLAN header.
A VSI's MAC address table includes the following types of MAC address entries:
·     Local MAC—MAC entries learned from the local site. The outgoing interfaces for the MAC address entries are site-facing interfaces.
¡     Static—Manually added MAC entries.
¡     Dynamic—Dynamically learned MAC entries.
·     Remote MAC—MAC entries learned from a remote site, including static and dynamic MAC entries. The outgoing interfaces for the MAC addresses are VXLAN tunnel interfaces.
¡     Dynamic—MAC entries learned in the data plane from incoming traffic on VXLAN tunnels. The learned MAC addresses are contained in the inner Ethernet header.
¡     BGP EVPN—MAC entries advertised through BGP EVPN. For more information, see EVPN Configuration Guide.
¡     OpenFlow—MAC entries issued by a remote controller through OpenFlow. For more information, see OpenFlow Configuration Guide.
The following shows the priority order of different types of remote MAC address entries:
a.     Static MAC address entries and MAC address entries issued by a remote controller through OpenFlow. These types of entries have the same priority and overwrite each other.
b.     MAC address entries advertised through BGP EVPN.
c.     Dynamic MAC address entries.
Unicast forwarding
Intra-site unicast forwarding
The VTEP uses the following process to forward a known unicast frame within a site:
1.     Identifies the VSI of the frame.
2.     Looks up the destination MAC address in the VSI's MAC address table for the outgoing interface.
3.     Sends the frame out of the matching outgoing interface.
As shown in Figure 4, VTEP 1 forwards a frame from VM 1 to VM 4 within the local site in VLAN 10 as follows:
4.     Identifies that the frame belongs to VSI A when the frame arrives at Interface A.
5.     Looks up the destination MAC address (MAC 4) in the MAC address table of VSI A for the outgoing interface.
6.     Sends the frame out of the matching outgoing interface (Interface B) to VM 4 in VLAN 10.
Figure 4 Intra-site unicast
Inter-site unicast forwarding
The following process (see Figure 5) applies to a known unicast frame between sites:
1.     The source VTEP encapsulates the Ethernet frame in the VXLAN/UDP/IP header.
In the outer IP header, the source IP address is the source VTEP's VXLAN tunnel source IP address. The destination IP address is the VXLAN tunnel destination IP address.
2.     The source VTEP forwards the encapsulated packet out of the outgoing VXLAN tunnel interface found in the VSI's MAC address table.
3.     The intermediate transport devices (P devices) forward the frame to the destination VTEP by using the outer IP header.
4.     The destination VTEP removes the headers on top of the inner Ethernet frame. It then performs MAC address table lookup in the VXLAN's VSI to forward the frame out of the matching outgoing interface.
Figure 5 Inter-site unicast
Flood
The source VTEP floods a broadcast, multicast, or unknown unicast frame to all site-facing interfaces and VXLAN tunnels in the VXLAN, except for the incoming interface. Each destination VTEP floods the inner Ethernet frame to all site-facing interfaces in the VXLAN. To avoid loops, the destination VTEPs do not flood the frame back to VXLAN tunnels.
In the current software version, VXLAN supports only the unicast mode (also called head-end replication).
Unicast mode (head-end replication)
As shown in Figure 6, the source VTEP replicates the flood frame, and then sends one replica to the destination IP address of each VXLAN tunnel in the VXLAN.
Figure 6 Unicast mode
The access mode of a VSI determines how the VTEP processes the 802.1Q VLAN tags in the Ethernet frames.
VLAN access mode
In this mode, Ethernet frames received from or sent to the local site must contain 802.1Q VLAN tags.
·     For an Ethernet frame received from the local site, the VTEP removes all its 802.1Q VLAN tags before forwarding the frame.
·     For an Ethernet frame destined for the local site, the VTEP adds 802.1Q VLAN tags to the frame before forwarding the frame.
In VLAN access mode, VXLAN packets sent between sites do not contain 802.1Q VLAN tags. You can use different 802.1Q VLANs to provide the same service in different sites.
Ethernet access mode
The VTEP does not process the 802.1Q VLAN tags of Ethernet frames received from or sent to the local site.
·     For an Ethernet frame received from the local site, the VTEP forwards the frame with the 802.1Q VLAN tags intact.
·     For an Ethernet frame destined for the local site, the VTEP forwards the frame without adding 802.1Q VLAN tags.
In Ethernet access mode, VXLAN packets sent between VXLAN sites contain 802.1Q VLAN tags. You must use the same VLAN to provide the same service between sites.
ARP or ND flood suppression reduces ARP request broadcasts or ND request multicasts by enabling the VTEP to reply to ARP or ND requests on behalf of VMs.
As shown in Figure 7, this feature snoops ARP or ND packets to populate the ARP or ND flood suppression table with local and remote MAC addresses. If an ARP or ND request has a matching entry, the VTEP replies to the request on behalf of the VM. If no match is found, the VTEP floods the request to both local and remote sites.
Figure 7 ARP and ND flood suppression
The following uses ARP flood suppression as an example to explain the flood suppression workflow:
1.     VM 1 sends an ARP request to obtain the MAC address of VM 7.
2.     VTEP 1 creates a suppression entry for VM 1, and floods the ARP request in the VXLAN.
3.     VTEP 2 and VTEP 3 de-encapsulate the ARP request. The VTEPs create a suppression entry for VM 1, and broadcast the request in the local site.
4.     VM 7 sends an ARP reply.
5.     VTEP 2 creates a suppression entry for VM 7 and forwards the ARP reply to VTEP 1.
6.     VTEP 1 de-encapsulates the ARP reply, creates a suppression entry for VM 7, and forwards the ARP reply to VM 1.
7.     VM 4 sends an ARP request to obtain the MAC address of VM 1 or VM 7.
8.     VTEP 1 creates a suppression entry for VM 4 and replies to the ARP request.
9.     VM 10 sends an ARP request to obtain the MAC address of VM 1.
10.     VTEP 3 creates a suppression entry for VM 10 and replies to the ARP request.
VXLAN IP gateways
A VXLAN IP gateway provides Layer 3 forwarding services for VMs in VXLANs. A VXLAN IP gateway can be an independent device or be collocated with a VTEP. For more information about VXLAN IP gateway placement, see "Configuring VXLAN IP gateways."
VXLAN M-LAG
IMPORTANT
IMPORTANT:
VXLAN M-LAG supports only IPv4 sites and IPv4 underlay networks.
About VXLAN M-LAG
As shown in Figure 8, VXLAN M-LAG virtualizes two VTEPs or VXLAN IP gateways into one M-LAG system through M-LAG to avoid single points of failure. The VTEPs or VXLAN IP gateways are called M-LAG member devices. For more information about M-LAG, see Layer 2—LAN Switching Configuration Guide.
Figure 8 VXLAN M-LAG
VM reachability information synchronization
To ensure VM reachability information consistency in the M-LAG system, the M-LAG member devices synchronize MAC address entries and ARP information with each other through a peer link. The peer link can be an Ethernet aggregate link or a VXLAN tunnel. An Ethernet aggregate link acting as a peer link is called a direct peer link A VXLAN tunnel acting as a peer link is called a tunnel peer link.
·     IMPORTANT
IMPORTANT:
The VXLAN tunnel that acts as the peer link is automatically associated with all VXLANs on each M-LAG member device.
Virtual VTEP address
The M-LAG member devices use the same IP address to set up VXLAN tunnels with remote VTEPs or VXLAN IP gateways.
Dual-homed ACs
As shown in Figure 8, a VM is dual-homed to the VTEPs in an M-LAG system through Ethernet links. The Ethernet links connected to the same VM are aggregated into one Layer 2 aggregation group across VTEPs. On the corresponding Layer 2 aggregate interface, Ethernet service instances are configured as ACs of VXLANs to match customer traffic. These ACs are dual-homed ACs.
·     If a direct peer link is used, the site-facing link backup mechanism is as follows:
When a site-facing AC is configured on a VTEP, the VTEP automatically creates an AC on the peer link with the same traffic match criterion as the site-facing AC. Then, it maps the automatically created AC to the VSI of the site-facing AC. When the site-facing AC is down, traffic sent to the AC is forwarded to the other VTEP through the peer link. This mechanism ensures service continuity in case of AC failure.
·     If a tunnel peer link is used, the site-facing link backup mechanism is as follows:
If a site-facing AC on a VTEP is down, traffic sent to the AC will be encapsulated into VXLAN packets. The VXLAN ID belongs to the VXLAN that is associated with the VSI of the site-facing AC. The VTEP forwards the VXLAN packets through the VXLAN tunnel acting as the peer link to the peer VTEP. The peer VTEP assigns the traffic to the correct VSI based on the VXLAN ID in the received packets.
Communication between single-homed ACs
An AC that is attached to only one of the VTEPs in an M-LAG system is called a single-homed AC. Two single-homed ACs attached to different VTEPs communicate through the peer link.
·     If a direct peer link is used, the traffic forwarding mechanism is as follows:
When a single-homed AC is configured on a VTEP, the VTEP automatically creates an AC on the peer link with the same traffic match criterion as the single-homed AC. Then, it maps the automatically created AC to the VSI of the single-homed AC. When receiving traffic from the single-homed AC, the VTEP sends the traffic to the other VTEP through the peer link. Then, the other VTEP identifies the VSI of the traffic and forwards it.
·     If a tunnel peer link is used, the traffic forwarding mechanism is as follows:
When receiving traffic from a single-homed AC, a VTEP encapsulates the traffic into VXLAN packets and sends them to the other VTEP through the peer link. The VXLAN ID in the VXLAN packets belongs to the VSI to which the single-homed AC is mapped. Then, the other VTEP identifies the VSI of the traffic and forwards it.
RFC 7348, Virtual eXtensible Local Area Network (VXLAN): A Framework for Overlaying Virtualized Layer 2 Networks over Layer 3 Networks
By default, interfaces on the device operate in Layer 3 mode. To have interfaces operate in Layer 2 mode, use the port link-mode command.
To configure basic VXLAN settings, perform the following tasks on VTEPs:
1.     Creating a VXLAN on a VSI
2.     Configuring a VXLAN tunnel
3.     Manually assigning VXLAN tunnels to a VXLAN
4.     Assigning customer frames to a VSI
5.     (Optional.) Managing MAC address entries
¡     Configuring static MAC address entries
¡     Disabling remote-MAC address learning
¡     Enabling local-MAC logging
6.     (Optional.) Configuring VXLAN packet parameters
¡     Setting the destination UDP port number of VXLAN packets
¡     Configuring VXLAN packet check
¡     Enabling default VXLAN decapsulation
¡     Enabling ECN for VXLANs
7.     (Optional.) Reducing flood traffic in the transport network
¡     Disabling flooding for a VSI
¡     Enabling ARP flood suppression
¡     Enabling ND flood suppression
8.     (Optional.) Configuring VXLAN M-LAG
9.     Maintaining VXLAN networks
¡     Enabling VXLAN packet statistics
¡     Testing the connectivity of a VXLAN tunnel
Configure a routing protocol on the devices in the transport network to make sure the VTEPs can reach one another.
2.     Enable L2VPN.
l2vpn enable
By default, L2VPN is disabled.
3.     Create a VSI and enter VSI view.
vsi vsi-name
4.     Configure a description for the VSI.
By default, a VSI does not have a description.
5.     Enable the VSI.
By default, a VSI is enabled.
6.     Create a VXLAN and enter VXLAN view.
vxlan vxlan-id
You can create only one VXLAN on a VSI.
The VXLAN ID must be unique for each VSI.
When you manually create a VXLAN tunnel, specify addresses on the local VTEP and the remote VTEP as the tunnel source and destination addresses, respectively.
As a best practice, do not configure multiple VXLAN tunnels to use the same source and destination IP addresses.
Make sure the following VXLAN tunnels are not associated with the same VXLAN when they have the same tunnel destination IP address:
·     A VXLAN tunnel automatically created by EVPN.
·     A manually created VXLAN tunnel.
This task provides basic VXLAN tunnel configuration. For more information about tunnel interface configuration and commands, see Interface Configuration Guide and Interface Command Reference.
2.     (Optional.) Specify a global source IP address for VXLAN tunnels.
tunnel global source-address { ipv4-address | ipv6 ipv6-address }
By default, no global source IP address is specified for VXLAN tunnels.
A VXLAN tunnel uses the global source address if you do not specify a source interface or source address for the tunnel.
3.     Create a VXLAN tunnel interface and enter tunnel interface view.
interface tunnel tunnel-number mode vxlan [ ipv6 ]
The endpoints of a tunnel must use the same tunnel mode.
4.     Specify a source address for the tunnel. Choose one of the following methods:
¡     Specify a source IP address for the tunnel.
source { ipv4-address | ipv6-address }
The specified IP address is used in the outer IP header of tunneled VXLAN packets.
¡     Specify a source interface for the tunnel.
source interface-type interface-number
The primary IP address of the specified interface is used in the outer IP header of tunneled VXLAN packets.
By default, no source IP address or source interface is specified for a tunnel.
5.     Specify a destination IP address for the tunnel.
destination { ipv4-address | ipv6-address }
By default, no destination IP address is specified for a tunnel.
Specify the remote VTEP's IP address. This IP address will be the destination IP address in the outer IP header of tunneled VXLAN packets.
To provide Layer 2 connectivity for a VXLAN between two sites, you must assign the VXLAN tunnel between the sites to the VXLAN.
You can assign multiple VXLAN tunnels to a VXLAN, and configure a VXLAN tunnel to trunk multiple VXLANs. For a unicast-mode VXLAN, the system floods unknown unicast, multicast, and broadcast traffic to each tunnel associated with the VXLAN.
For full Layer 2 connectivity in the VXLAN, make sure the VXLAN contains the VXLAN tunnel between each pair of sites in the VXLAN.
2.     Enter VSI view.
vsi vsi-name
3.     Enter VXLAN view.
vxlan vxlan-id
4.     Assign VXLAN tunnels to the VXLAN.
tunnel { tunnel-number | all }
By default, a VXLAN does not contain any VXLAN tunnels.
An Ethernet service instance matches a list of VLANs on a site-facing interface. The VTEP assigns customer traffic from the VLANs to a VXLAN by mapping the Ethernet service instance to a VSI.
When the rewrite inbound tag or rewrite outbound tag command is executed on an Ethernet service instance, the Ethernet service instance must be mapped to a VSI in Ethernet access mode.
For packets to be normally forwarded, make sure the interface where an Ethernet service instance resides permits the matching inner and outer VLANs of the Ethernet service instance.
2.     Enter interface view.
¡     Enter Layer 2 Ethernet interface view.
¡     Enter Layer 2 aggregate interface view.
3.     Create an Ethernet service instance and enter Ethernet service instance view.
service-instance instance-id
4.     Configure a frame match criterion. Choose one of the following options:
¡     Match frames tagged with the specified outer 802.1Q VLAN IDs.
encapsulation s-vid vlan-id-list [ only-tagged ]
¡     Match frames tagged with the specified outer and inner 802.1Q VLAN IDs.
encapsulation s-vid vlan-id-list c-vid vlan-id-list
You can specify only one consecutive inner VLAN ID range.
¡     Match any 802.1Q untagged frames.
encapsulation untagged
¡     Match frames that do not match any other service instance on the interface.
encapsulation default
An interface can contain only one Ethernet service instance that uses the encapsulation default match criterion.
An Ethernet service instance that uses the encapsulation default match criterion matches any frames if it is the only instance on the interface.
By default, an Ethernet service instance does not contain a frame match criterion.
5.     (Optional.) Configure the VLAN tag processing rule for incoming traffic.
rewrite inbound tag [ c-vid vlan-id ] | remark { 1-to-1 s-vid vlan-id | 2-to-1 { c-vid vlan-id | s-vid vlan-id } | { 1-to-2 | 2-to-2 } s-vid vlan-id c-vid vlan-id } | strip s-vid [ c-vid ] } [ symmetric ]
By default, VLAN tags of incoming traffic are not processed.
6.     (Optional.) Configure the VLAN tag processing rule for outgoing traffic.
rewrite outbound tag { nest s-vid vlan-id [ c-vid vlan-id ] | remark { 1-to-1 s-vid vlan-id | 2-to-1 { c-vid vlan-id | s-vid vlan-id } | { 1-to-2 | 2-to-2 } s-vid vlan-id c-vid vlan-id } | strip s-vid [ c-vid ] }
By default, VLAN tags of outgoing traffic are not processed.
7.     Map the Ethernet service instance to a VSI.
xconnect vsi vsi-name [ access-mode { ethernet | vlan } ]
By default, an Ethernet service instance is not mapped to any VSI.
Local-MAC address entries can be manually added or dynamically learned. You can log local MAC addresses and local-MAC changes.
Remote-MAC address entries have a variety of types, including manually added entries and dynamically learned entries.
Do not configure static remote-MAC entries for VXLAN tunnels that are automatically established by using EVPN.
·     EVPN re-establishes VXLAN tunnels if the transport-facing interface goes down and then comes up. If you have configured static remote-MAC entries, the entries are deleted when the tunnels are re-established.
·     EVPN re-establishes VXLAN tunnels if you perform configuration rollback. If the tunnel IDs change during tunnel re-establishment, configuration rollback fails, and static remote-MAC entries on the tunnels cannot be restored.
2.     Add a static local-MAC address entry.
mac-address static mac-address interface interface-type interface-number service-instance instance-id vsi vsi-name
For successful configuration, make sure the Ethernet service instance has been mapped to the VSI.
3.     Add a static remote-MAC address entry.
mac-address static mac-address interface tunnel tunnel-number vsi vsi-name
For the setting to take effect, make sure the VSI's VXLAN has been specified on the VXLAN tunnel.
When network attacks occur, disable remote-MAC address learning to prevent the device from learning incorrect remote MAC addresses. You can manually add static remote-MAC address entries.
2.     Disable remote-MAC address learning.
By default, remote-MAC address learning is enabled.
When the local-MAC logging feature is enabled, the VXLAN module immediately sends a log message with its local MAC addresses to the information center. When a local MAC address is added or removed, a log message is also sent to the information center to notify the local-MAC change.
With the information center, you can set log message filtering and output rules, including output destinations. For more information about configuring the information center, see System Management Configuration Guide.
2.     Enable local-MAC logging.
vxlan local-mac report
By default, local-MAC logging is disabled.
2.     Set a destination UDP port for VXLAN packets.
vxlan udp-port port-number
By default, the destination UDP port number is 4789 for VXLAN packets.
You must configure the same destination UDP port number on all VTEPs in a VXLAN.
The device can check the 802.1Q VLAN tags of each received VXLAN packet. The device checks the inner Ethernet header of each VXLAN packet for 802.1Q VLAN tags. If the header contains 802.1Q VLAN tags, the device drops the packet.
If a remote VTEP uses the Ethernet access mode, its VXLAN packets might contain 802.1Q VLAN tags. To prevent the local VTEP from dropping the VXLAN packets, do not execute the vxlan invalid-vlan-tag discard command on the local VTEP.
The access mode is configurable by using the xconnect vsi command.
2.     Enable the VTEP to drop VXLAN packets that have 802.1Q VLAN tags in the inner Ethernet header.
By default, the VTEP does not check the inner Ethernet header for 802.1Q VLAN tags.
If a VXLAN tunnel is configured on only one VTEP of a pair of VTEPs, the VXLAN tunnel is a unidirectional tunnel to the VTEP not configured with the tunnel. In this situation, that VTEP drops the VXLAN packets received from the unidirectional VXLAN tunnel. For a VTEP to receive VXLAN packets from a unidirectional VXLAN tunnel, enable default VXLAN decapsulation on the interface whose IP address is the tunnel destination address. The VTEP will decapsulate all the VXLAN packets destined for the IP address of that interface.
This feature takes effect only when the specified interface has an IP address.
Default VXLAN decapsulation does not take effect on bidirectional VXLAN tunnels. If you remove the one-way communication issue for a VXLAN tunnel by configuring the tunnel on both the local and remote VTEPs, this feature no longer takes effect on that tunnel.
Enabling default IPv4 VXLAN decapsulation
2.     Enable default IPv4 VXLAN decapsulation.
vxlan default-decapsulation source interface interface-type interface-number
By default, default IPv4 VXLAN decapsulation is disabled.
Enabling default IPv6 VXLAN decapsulation
2.     Enable default IPv6 VXLAN decapsulation.
vxlan ipv6 default-decapsulation source interface interface-type interface-number
By default, default IPv6 VXLAN decapsulation is disabled.
Explicit Congestion Notification (ECN)  allows end-to-end notification of network congestion without dropping packets. You can execute this command to apply ECN to VXLAN/EVPN VXLAN networks. After you configure this feature,  the following rules apply:
·     For the VXLAN packets to be decapsulated, the device will map the ECN field in the outer IP header of VXLAN packets to the ECN field in the inner IP header of packets.
·     For packets to be encapsulated by VXLAN, the device will map the ECN field in the original IP header of packets to the ECN field in the outer IP header of packets.
In this way, the ECN field is the same in the inner IP header and outer IP header, and packets will not be lost when the VXLAN network is congested.
2.     Enable ECN for VXLANs.
vxlan mapping-ecn enable
By default, ECN is disabled for VXLANs.
By default, the VTEP floods broadcast, unknown unicast, and unknown multicast frames received from the local site to the following interfaces in the frame's VXLAN:
·     All site-facing interfaces except for the incoming interface.
·     All VXLAN tunnel interfaces.
When receiving broadcast, unknown unicast, and unknown multicast frames on VXLAN tunnel interfaces, the device floods the frames to all site-facing interfaces in the frames' VXLAN.
To confine a kind of flood traffic, disable flooding for that kind of flood traffic on the VSI bound to the VXLAN.
To exclude a remote MAC address from the remote flood suppression done by using this feature, enable selective flood for the MAC address. The VTEP will flood the frames destined for the MAC address to remote sites.
2.     Enter VSI view.
vsi vsi-name
3.     Disable flooding for the VSI.
flooding disable { all | { broadcast | unknown-multicast | unknown-unicast } * } [ dci ]
By default, flooding is enabled for a VSI.
If VXLAN-DCI is configured, flood traffic is also sent out of VXLAN-DCI tunnel interfaces. To confine flood traffic to the site-facing interfaces and VXLAN tunnels within a data center, you can specify the dci keyword to disable flooding only to VXLAN-DCI tunnel interfaces.
The all-direction keyword disables flooding traffic received from an AC or VXLAN tunnel interface to any other ACs and VXLAN tunnel interfaces of the same VSI. If VXLAN-DCI is configured, this keyword also disables flooding between VXLAN tunnel interfaces and VXLAN-DCI tunnel interfaces.
4.     (Optional.) Enable selective flood for a MAC address.
selective-flooding mac-address mac-address
The aging timer is fixed at 25 minutes for ARP flood suppression entries. If the suppression table is full, the VTEP stops learning new entries. For the VTEP to learn new entries, you must wait for old entries to age out, or use the reset arp suppression vsi command to clear the table.
If the flooding disable command is configured, set the MAC aging timer to a higher value than the aging timer for ARP flood suppression entries on all VTEPs. This setting prevents the traffic blackhole that occurs when a MAC address entry ages out before its ARP flood suppression entry ages out. To set the MAC aging timer, use the mac-address timer command.
When remote ARP learning is disabled for VXLANs, the device does not use ARP flood suppression entries to respond to ARP requests received on VXLAN tunnels.
2.     Enter VSI view.
vsi vsi-name
3.     (Optional.) Set the ARP flood suppression mode.
arp suppression mode { proxy-reply | unicast-forward } [ mismatch-discard ]
If ARP flood suppression is enabled, the default ARP flood suppression mode is proxy reply. In proxy reply mode, the device broadcasts the ARP requests that are not targeted at the device and do not match any ARP flood suppression entries.
4.     Enable ARP flood suppression.
arp suppression enable [ no-broadcast ]
By default, ARP flood suppression is disabled.
2.     Enter VSI view.
vsi vsi-name
3.     (Optional.) Set the ND flood suppression mode.
ipv6 nd suppression mode { proxy-reply | unicast-forward } [ mismatch-discard ]
If ND flood suppression is enabled, the default ND flood suppression mode is proxy reply. In proxy reply mode, the device broadcasts the NS packets that are not targeted at the device and do not match any ND flood suppression entries.
4.     Enable ND flood suppression.
ipv6 nd suppression enable [ no-broadcast ]
By default, ND flood suppression is disabled.
VXLAN M-LAG virtualizes two VTEPs or VXLAN IP gateways into one M-LAG system to avoid single points of failure.
When you configure VXLAN M-LAG, follow these restrictions and guidelines:
·     An M-LAG system does not support Layer 2 multicast.
·     M-LAG member devices must use the same tunnel source address to establish VXLAN tunnels to remote devices.
If a direct peer link is used, follow these restrictions:
·     If the frame match criteria of dynamic ACs on the peer link are created based on site-facing Ethernet service instances, you can configure only the following criteria for site-facing Ethernet service instances:
¡     encapsulation s-vid { vlan-id | vlan-id-list }
¡     encapsulation untagged
In addition, you must set the access mode to VLAN for site-facing Ethernet service instances.
The above restrictions are not applicable when the frame match criteria of dynamic ACs on the peer link are created based on VXLAN IDs.
·     Make sure the Ethernet service instances that use the same match criterion are mapped to the same VSI.
·     Make sure the following settings are consistent on the M-LAG member devices:
¡     Ethernet service instances and their match criterion on the M-LAG interfaces in the same M-LAG group or single-homed site-facing interfaces.
¡     VXLAN IDs of VSIs.
In addition, the Ethernet service instances must be created manually.
If a VXLAN tunnel is used as the peer link, follow these restrictions:
·     As a best practice, use different physical interfaces as the traffic outgoing interfaces of the peer link VXLAN tunnel and non-peer link VXLAN tunnels.
·     To prioritize transmission of M-LAG protocol packets on the peer link, use the tunnel tos command on the VXLAN tunnel interface to set a high ToS value for tunneled packets.
·     You must disable spanning tree on the Layer 2 Ethernet interface that acts as the physical traffic outgoing interface of the peer link VXLAN tunnel. If you enable spanning tree on that interface, the upstream device will block the interfaces connected to the M-LAG member devices.
·     Use the reserved vxlan command to specify a reserved VXLAN to forward M-LAG protocol packets. The M-LAG member devices in an M-LAG system must have the same reserved VXLAN.
¡     Ethernet service instances and their match criterion on the M-LAG interfaces in the same M-LAG group.
The VTEPs in an M-LAG system synchronize local MAC address entries with each other over the peer link. However, they do not synchronize MAC address entry deletions. When you delete a MAC address entry from one VTEP, the other VTEP retains the entry that contains the same MAC address until the entry ages out.
Configure basic VXLAN settings before you configure M-LAG.
1.     Configure M-LAG as described in Layer 2—LAN Switching Configuration Guide.
2.     Exclude interfaces from the shutdown action by M-LAG MAD.
m-lag mad exclude interface interface-type interface-number
By default, M-LAG MAD shuts down all network interfaces when detecting a multi-active collision, except for the network interfaces set by the system to not shut down.
Exclude all interfaces used by VXLAN from the MAD shutdown action by M-LAG. The interfaces include VSI interfaces, interfaces used for setting up the keepalive link, and transport-facing outgoing interfaces of VXLAN tunnels. Also exclude IPPs from the shutdown action by M-LAG MAD if the peer link is a VXLAN tunnel.
For more information about this command, see M-LAG commands in Layer 2—LAN Switching Command Reference.
3.     Set the data restoration interval.
m-lag restore-delay value
By default, the data restoration interval is 30 seconds.
Set the data restoration interval to a value equal to or larger than 180 seconds on a VXLAN M-LAG system.
4.     (Optional.) Enable the device to create frame match criteria based on VXLAN IDs for the dynamic ACs on the direct peer link.
l2vpn m-lag peer-link ac-match-rule vxlan-mapping
By default, on an M-LAG system that uses a direct peer link, dynamic ACs on the peer link use frame match criteria that are identical to those of site-facing ACs.
If you do not execute this command, do not configure overlapping outer VLAN IDs for Ethernet service instances of different VSIs.
If you execute this command, do not create VXLANs with IDs larger than 16000000.
For more information about this command, see EVPN Command Reference.
To display the packet statistics for a VSI, use the display l2vpn vsi verbose command in any view.
To clear the packet statistics for a VSI, use the reset l2vpn statistics vsi command in user view.
2.     Set the packet statistic collection mode to VSI.
statistic mode vsi
The default packet statistic collection mode is VSI.
3.     Enter VSI view.
vsi vsi-name
4.     Enable packet statistics for the VSI.
statistics enable
By default, the packet statistics feature is disabled for all VSIs.
For the statistics enable command to take effect on an Ethernet service instance, you must configure a frame match criterion for the Ethernet service instance and map it to a VSI. When you modify the frame match criterion or VSI mapping, the packet statistics of the instance are cleared.
2.     Set the packet statistic collection mode to AC.
statistic mode ac
3.     Enter interface view.
4.     Enter Ethernet service instance view.
5.     Enable packet statistics for the Ethernet service instance.
statistics enable
By default, the packet statistics feature is disabled for all Ethernet service instances.
Perform this task to set the interval for collecting VSI, AC, and VXLAN tunnel packet statistics.
2.     Set the L2VPN statistics collection interval
l2vpn statistics interval interval
The default L2VPN statistics collection interval is 15 minutes.
You must enable overlay OAM on the tunnel destination device for a VXLAN tunnel before you can use the ping vxlan or tracert vxlan command to test reachability of the VXLAN tunnel on the tunnel source device.
To specify the -r 3 parameter in the ping vxlan or tracert vxlan command on the tunnel source device, you must also enable overlay OAM on the tunnel source device.
2.     Enable overlay OAM.
overlay oam enable
By default, overlay OAM is disabled.
Perform this task to test the connectivity of a VXLAN tunnel in a VXLAN or EVPN VXLAN network when the tunnel has traffic loss or interruption issues. The process of a ping VXLAN operation is as follows:
1.     The tunnel source VTEP sends VXLAN-encapsulated VXLAN echo requests to the tunnel destination VTEP.
2.     The tunnel destination VTEP responds with VXLAN echo replies.
3.     The tunnel source VTEP outputs packet statistics and the test result based on the received VXLAN echo replies.
Before you perform this task on the tunnel source device, you must enable overlay OAM on the tunnel destination device by using the overlay oam enable command.
The VTEP can distribute VXLAN echo requests among multiple paths to the destination based on the source UDP port. When a VXLAN tunnel has multiple paths on the transport network, you can configure load sharing parameters to ensure accuracy of the test result. You can use one of the following methods to configure source UDP ports for VXLAN echo requests:
·     Specify a source UDP port range. The device will send VXLAN echo requests sourced from each UDP port in the UDP port range. You need to execute the ping vxlan command only once.
·     Specify load balancing parameters such as source and destination MAC addresses, source and destination IP addresses, and protocol for the VTEP to calculate a source UDP port number. You need to execute the ping vxlan command multiple times to test connectivity of all paths.
The load balancing parameters change only the source UDP port number of VXLAN echo requests. Other fields of the requests will not be changed.
If you specify the vxlan-source-udpport vxlan-source-udpport [ end-vxlan-src-udpport ] parameters, the number of VXLAN echo requests sourced from each UDP port in the UDP port range is determined by the -c count parameter.
Execute the following command in any view.
ping vxlan [ -a inner-src-address | -c count | -m interval | -r reply-mode | -t timeout | -tos tos-value ] * vxlan-id vxlan-id tunnel-source source-address tunnel-destination dest-address [ destination-udpport dest-port ] [ vxlan-source-address vxlan-source-address ] [ load-balance { vxlan-source-udpport vxlan-source-udpport [ end-vxlan-src-udpport ] | source-address lb-src-address destination-address lb-dest-address protocol { udp | lb-protocol-id } source-port lb-src-port destination-port lb-dest-port source-mac lb-source-mac destination-mac lb-destination-mac } ]
Perform this task to locate failed nodes on the path for a VXLAN tunnel that has traffic loss or interruption issues in a VXLAN or EVPN VXLAN network. The process of a tracert VXLAN operation is as follows:
1.     The tunnel source VTEP sends VXLAN-encapsulated VXLAN echo requests to the tunnel destination VTEP. The TTL in the IP header of the requests is set to 1.
2.     The first hop on the path responds to the tunnel source VTEP with a TTL-expired ICMP error message.
3.     The tunnel source VTEP sends VXLAN echo requests with the TTL set to 2.
4.     The second hop responds with a TTL-expired ICMP error message.
5.     This process continues until a VXLAN echo request reaches the tunnel destination VTEP or the maximum TTL value is reached. If a VXLAN echo request reaches the tunnel destination VTEP, the tunnel destination VTEP sends a VXLAN echo reply to the tunnel source VTEP.
6.     The tunnel source VTEP outputs packet statistics and the test result based on the received ICMP error messages and whether a VXLAN echo reply is received.
tracert vxlan [ -a inner-src-address | -h ttl-value | -r reply-mode | -t timeout ] * vxlan-id vxlan-id  tunnel-source source-address tunnel-destination dest-address [ destination-udpport dest-port ] [ vxlan-source-address vxlan-source-address ] [ load-balance { vxlan-source-udpport vxlan-source-udpport | source-address lb-src-address destination-address lb-dest-address protocol { udp | lb-protocol-id } source-port lb-src-port destination-port lb-dest-port source-mac lb-source-mac destination-mac lb-destination-mac } ]
·     Display information about tunnel interfaces.
display interface [ tunnel [ number ] ] [ brief [ description | down ] ]
For more information about this command, see tunnel interface commands in Interface Command Reference.
·     Display VXLAN tunnel information for VXLANs.
display vxlan tunnel [ vxlan vxlan-id ]
To display information about Ethernet service instances, execute the following command in any view:
Verifying VSI configuration
·     Display information about VSIs.
display l2vpn vsi [ name vsi-name | vxlan ] [ count | verbose ]
Displaying and clearing MAC address entries on VSIs
To display MAC address entries for VSIs, execute the following command in any view:
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count | verbose ]
To clear dynamic MAC address entries on VSIs, execute the following command in user view:
reset l2vpn mac-address [ vsi vsi-name ]
Displaying and clearing ARP flood suppression entries on VSIs
To display ARP flood suppression entries on VSIs, execute the following command in any view:
display arp suppression vsi [ name vsi-name ] [ slot slot-number [ cpu cpu-number ] ] [ count ]
To clear ARP flood suppression entries on VSIs, execute the following command in user view:
reset arp suppression vsi [ name vsi-name ]
Displaying and clearing ND flood suppression entries on VSIs
To display ND flood suppression entries on VSIs, execute the following command in any view:
display ipv6 nd suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
To clear ND flood suppression entries on VSIs, execute the following command in user view:
reset ipv6 nd suppression vsi [ name vsi-name ]
Clearing packet statistics on VSIs
To clear packet statistics on VSIs, execute the following command in user view:
reset l2vpn statistics vsi [ name vsi-name ]
Displaying L2VPN AC forwarding information
To display L2VPN AC forwarding information, execute the following command in any view:
display l2vpn forwarding ac [ vsi vsi-name ] [ slot slot-number [ cpu cpu-number ] ] [ verbose ]
Clearing packet statistics on ACs
To clear packet statistics on ACs, execute the following command in user view:
reset l2vpn statistics ac [ interface interface-type interface-number service-instance instance-id ]
To display the current packet statistic collection mode, execute the following command in any view:
display statistic mode
Displaying L2VPN MAC address entries on an M-LAG member device
To display L2VPN MAC address entries on an M-LAG member device, execute the following command in any view:
display l2vpn m-lag mac-address [ local | remote ] [ count | vsi vsi-name [ count | mac-address ] ]
Displaying L2VPN ARP entries and ARP flood suppression entries on an M-LAG member device
·     Display L2VPN ARP entries  on an M-LAG member device.
display l2vpn m-lag arp [ local | remote ] [ count | { public-instance | vpn-instance vpn-instance-name } [ count | ip-address ] ]
·     Display L2VPN ARP flood suppression entries on an M-LAG member device.
display l2vpn m-lag arp suppression [ local | remote ] [ count | vsi vsi-name [ count | ip-address ] ]
Displaying L2VPN ND entries and ND flood suppression entries on an M-LAG member device
·     Display L2VPN ND entries  on an M-LAG member device.
display l2vpn m-lag nd [ local | remote ] [ count | { public-instance | vpn-instance vpn-instance-name } [ ipv6-address | count ] ]
·     Display L2VPN ND flood suppression entries on an M-LAG member device.
display l2vpn m-lag nd suppression [ local | remote ] [ count | vsi vsi-name [ ipv6-address | count ] ]
As shown in Figure 9:
·     Configure VXLAN 10 as a unicast-mode VXLAN on Switch A, Switch B, and Switch C to provide Layer 2 connectivity for the VMs across the network sites.
·     Manually establish VXLAN tunnels and assign the tunnels to VXLAN 10.
·     Enable remote-MAC address learning.
Figure 9 Network diagram
IMPORTANT
IMPORTANT:
·     By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
·     By default, interfaces on the device operate in route (Layer 3) mode. To configure Ethernet service instances on an interface, first execute the port link-mode bridge command in interface view to configure the interface to operate in bridge (Layer 2) mode.
1.     Configure IP addresses and unicast routing settings:
# Assign IP addresses to interfaces, as shown in Figure 9. (Details not shown.)
# Configure OSPF on all transport network switches (Switches A through D). (Details not shown.)
2.     Configure Switch A:
# Enable L2VPN.
[SwitchA] l2vpn enable
# Create VSI vpna and VXLAN 10.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] vxlan 10
[SwitchA-vsi-vpna] quit
# Assign an IP address to Loopback 0. The IP address will be used as the source IP address of the VXLAN tunnels to Switch B and Switch C.
[SwitchA-Loopback0] ip address 1.1.1.1 255.255.255.255
[SwitchA-Loopback0] quit
# Create a VXLAN tunnel to Switch B. The tunnel interface name is Tunnel 1.
[SwitchA-Tunnel1] quit
# Create a VXLAN tunnel to Switch C. The tunnel interface name is Tunnel 2.
[SwitchA] interface tunnel 2 mode vxlan
[SwitchA-Tunnel2] source 1.1.1.1
[SwitchA-Tunnel2] destination 3.3.3.3
[SwitchA-Tunnel2] quit
# Assign Tunnel 1 and Tunnel 2 to VXLAN 10.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna-vxlan-10] tunnel 1
[SwitchA-vsi-vpna-vxlan-10] tunnel 2
# On HundredGigE 1/0/1, create Ethernet service instance 1000 to match VLAN 2.
[SwitchA] interface hundredgige 1/0/1
[SwitchA-HundredGigE1/0/1] service-instance 1000
[SwitchA-HundredGigE1/0/1] port link-type trunk
[SwitchA-HundredGigE1/0/1] port trunk permit vlan 2
[SwitchA-HundredGigE1/0/1-srv1000] encapsulation s-vid 2
# Map Ethernet service instance 1000 to VSI vpna.
[SwitchA-HundredGigE1/0/1-srv1000] xconnect vsi vpna
[SwitchA-HundredGigE1/0/1-srv1000] quit
[SwitchA-HundredGigE1/0/1] quit
3.     Configure Switch B:
# Enable L2VPN.
[SwitchB] l2vpn enable
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] vxlan 10
[SwitchB-vsi-vpna] quit
# Assign an IP address to Loopback 0. The IP address will be used as the source IP address of the VXLAN tunnels to Switch A and Switch C.
[SwitchB-Loopback0] ip address 2.2.2.2 255.255.255.255
[SwitchB-Loopback0] quit
# Create a VXLAN tunnel to Switch A. The tunnel interface name is Tunnel 2.
[SwitchB] interface tunnel 2 mode vxlan
[SwitchB-Tunnel2] source 2.2.2.2
[SwitchB-Tunnel2] destination 1.1.1.1
[SwitchB-Tunnel2] quit
# Create a VXLAN tunnel to Switch C. The tunnel interface name is Tunnel 3.
[SwitchB] interface tunnel 3 mode vxlan
[SwitchB-Tunnel3] source 2.2.2.2
[SwitchB-Tunnel3] destination 3.3.3.3
[SwitchB-Tunnel3] quit
# Assign Tunnel 2 and Tunnel 3 to VXLAN 10.
[SwitchB] vsi vpna
[SwitchB-vsi-vpna-vxlan-10] tunnel 2
[SwitchB-vsi-vpna-vxlan-10] tunnel 3
[SwitchB] interface hundredgige 1/0/1
[SwitchB-HundredGigE1/0/1] service-instance 1000
[SwitchB-HundredGigE1/0/1] port link-type trunk
[SwitchB-HundredGigE1/0/1] port trunk permit vlan 2
[SwitchB-HundredGigE1/0/1-srv1000] encapsulation s-vid 2
[SwitchB-HundredGigE1/0/1-srv1000] xconnect vsi vpna
[SwitchB-HundredGigE1/0/1-srv1000] quit
[SwitchB-HundredGigE1/0/1] quit
4.     Configure Switch C:
# Enable L2VPN.
[SwitchC] l2vpn enable
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] vxlan 10
[SwitchC-vsi-vpna] quit
# Assign an IP address to Loopback 0. The IP address will be used as the source IP address of the VXLAN tunnels to Switch A and Switch B.
[SwitchC-Loopback0] ip address 3.3.3.3 255.255.255.255
[SwitchC-Loopback0] quit
# Create a VXLAN tunnel to Switch A. The tunnel interface name is Tunnel 1.
[SwitchC] interface tunnel 1 mode vxlan
[SwitchC-Tunnel1] source 3.3.3.3
[SwitchC-Tunnel1] destination 1.1.1.1
[SwitchC-Tunnel1] quit
# Create a VXLAN tunnel to Switch B. The tunnel interface name is Tunnel 3.
[SwitchC] interface tunnel 3 mode vxlan
[SwitchC-Tunnel3] source 3.3.3.3
[SwitchC-Tunnel3] destination 2.2.2.2
[SwitchC-Tunnel3] quit
# Assign Tunnel 1 and Tunnel 3 to VXLAN 10.
[SwitchC] vsi vpna
[SwitchC-vsi-vpna-vxlan-10] tunnel 1
[SwitchC-vsi-vpna-vxlan-10] tunnel 3
[SwitchC] interface hundredgige 1/0/1
[SwitchC-HundredGigE1/0/1] service-instance 1000
[SwitchC-HundredGigE1/0/1] port link-type trunk
[SwitchC-HundredGigE1/0/1] port trunk permit vlan 2
[SwitchC-HundredGigE1/0/1-srv1000] encapsulation s-vid 2
[SwitchC-HundredGigE1/0/1-srv1000] xconnect vsi vpna
[SwitchC-HundredGigE1/0/1-srv1000] quit
[SwitchC-HundredGigE1/0/1] quit
1.     Verify the VXLAN settings on the VTEPs. This example uses Switch A.
# Verify that the VXLAN tunnel interfaces on the VTEP are up.
[SwitchA] display interface tunnel 1
Tunnel1
Current state: UP
Line protocol state: UP
Bandwidth: 64 kbps
Maximum transmission unit: 64000
# Verify that the VXLAN tunnels have been assigned to the VXLAN.
[SwitchA] display l2vpn vsi verbose
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  MTU                     : -
  Diffserv Mode           : -
  Bandwidth               : Unlimited
  Broadcast Restrain      : Unlimited
  Multicast Restrain      : Unlimited
  Unknown Unicast Restrain: Unlimited
  MAC Table Limit         : -
  MAC Learning rate       : -
  Drop Unknown            : -
  PW Redundancy Mode      : Slave
  Flooding                : Enabled
  ESI                     : 0000.0000.0000.0000.0000
  Redundancy Mode         : All-active
  Statistics              : Disabled
  VXLAN ID                : 10
  Tunnels:
    Tunnel Name          Link ID    State  Type        Flood proxy
    Tunnel1              0x5000001  Up     Manual      Disabled
    Tunnel2              0x5000002  Up     Manual      Disabled
  ACs:
    AC                                                Link ID   State       Type
    HGE1/0/1 srv1000                                            0          Up
    Statistics: Disabled
# Verify that the VTEP has learned the MAC addresses of remote VMs.
<SwitchA> display l2vpn mac-address
MAC Address      State    VSI Name                        Link ID/Name  Aging
cc3e-5f9c-6cdb   Dynamic  vpna                            Tunnel1       Aging
cc3e-5f9c-23dc   Dynamic  vpna                            Tunnel2       Aging
--- 2 mac address(es) found  ---
2.     Verify that VM 1, VM 2, and VM 3 can ping each other. (Details not shown.)
