20-Network Programmability Command Reference
HomeSupportSwitchesS12500R SeriesReference GuidesCommand ReferencesH3C S12500R-48Y8C&S12500R-48C6D Switch Router Command References(R52xx)-6W10120-Network Programmability Command Reference
04-NETCONF commands
04-NETCONF commands 129.97 KB
NETCONF commands
display netconf service
Use display netconf service to display global NETCONF service settings and statistics.
# Display global NETCONF service settings and statistics.
<Sysname> display netconf service
NETCONF over SOAP over HTTP: Disabled (port 80)
NETCONF over SOAP over HTTPS: Disabled (port 832)
NETCONF over SSH: Disabled (port 830)
NETCONF over Telnet: Enabled
NETCONF over Console: Enabled
SOAP timeout: 10 minutes     Agent timeout: 0 minutes
Active Sessions: 0
Service statistics:
  NETCONF start time: 2019-11-06T09:15:17
  Output notifications: 0
  Output RPC errors: 0
  Dropped sessions: 0
  Sessions: 0
  Received bad hellos: 0
  Received RPCs: 0
  Received bad RPCs: 0
Status and port number of the NETCONF over SOAP over HTTP service:
·     Enabled—The service is enabled.
·     Disabled—The service is disabled.
Status and port number of the NETCONF over SOAP over HTTPS service:
NETCONF over SSH
Status and port number of the NETCONF over SSH service:
NETCONF over Telnet
Status and port number of the NETCONF over Telnet service:
Status and port number of the NETCONF over console service:
SOAP timeout
Idle timeout time for NETCONF over SOAP over HTTP sessions and NETCONF over SOAP over HTTPS sessions, in minutes.
Agent timeout
Aging time for NETCONF over SSH sessions, NETCONF over Telnet session, and NETCONF over console sessions, in minutes.
Active sessions
Number of active NETCONF sessions.
NETCONF start time
Time when the NETCONF service was started.
Number of subscribed notifications output by the device.
Output RPC errors
Number of erroneous RPC requests output by the device.
Dropped sessions
Number of NETCONF sessions dropped due to timeout or abnormal network disconnection.
Sessions
Number of established NETCONF sessions.
Received bad hellos
Number of received erroneous hello messages.
Received RPCs
Total number of RPC requests received by the device.
Received bad RPCs
Number of received erroneous RPC requests.
reset netconf service statistics
display netconf session
Use display netconf session to display NETCONF session statistics.
# Display NETCONF session statistics.
<Sysname> display netconf session
Session ID: 1 Session type : SOAP
  Username : xj
  Login time : 2021-09-28T14:28:04
  Client IP address : 172.31.9.125
  Session statistics:
    Received RPCs    : 0           Received bad RPCs   : 0
    Output RPC errors: 0           Output notifications: 0
Session type
NETCONF session type:
·     SOAP—NETCONF over SOAP over HTTP session or NETCONF over SOAP over HTTPS session.
·     Agent—NETCONF over SSH session, NETCONF over Telnet session, or NETCONF over console session.
Username
Username used by the NETCONF client to establish the session.
If the session type is agent and login authentication was not performed, this field displays a hyphen (-).
Login time
Time when the NETCONF session was established.
Client IP address
IP address of the NETCONF client.
This field displays a hyphen (-) for NETCONF over console sessions.
Received RPCs
Number of received RPC requests.
Received bad RPCs
Output RPC errors
reset netconf session statistics
netconf capability specific-namespace
Use netconf capability specific-namespace to configure the device to use module-specific namespaces.
Use undo netconf capability specific-namespace to restore the default.
The device uses the common namespace.
NETCONF supports both the common namespace and module-specific namespaces. The common namespace is incompatible with module-specific namespaces. To set up a NETCONF session, the device and the client must use the same type of namespaces. By default, the common namespace is used. If the client does not support the common namespace, use this command to configure the device to use module-specific namespaces.
For this command to take effect, you must reestablish the NETCONF session.
# Configure the device to use module-specific namespaces.
[Sysname] netconf capability specific-namespace
netconf idle-timeout
Use netconf idle-timeout to set the NETCONF session idle timeout time.
Use undo netconf idle-timeout to restore the default.
netconf { soap | agent } idle-timeout minute
undo netconf { soap | agent } idle-timeout
The NETCONF session idle timeout time is 10 minutes for NETCONF over SOAP over HTTP sessions and NETCONF over SOAP over HTTPS sessions.
The NETCONF session idle timeout time is 0 minutes for NETCONF over SSH sessions, NETCONF over Telnet sessions, and NETCONF over console sessions. The sessions never time out.
soap: Specifies the NETCONF over SOAP over HTTP sessions and NETCONF over SOAP over HTTPS sessions.
agent: Specifies the NETCONF over SSH sessions, NETCONF over Telnet sessions, and NETCONF over console sessions.
minute: Specifies the NETCONF session idle timeout time in minutes. The value range is as follows:
·     1 to 999 for NETCONF over SOAP over HTTP sessions and NETCONF over SOAP over HTTPS sessions.
·     0 to 999 for NETCONF over SSH sessions, NETCONF over Telnet sessions, and NETCONF over console sessions. To disable the timeout feature, set this argument to 0.
If no NETCONF packets are exchanged on a NETCONF session within the NETCONF session idle timeout time, the device tears down the session.
# Set the NETCONF session idle timeout time to 20 minutes for NETCONF over SOAP over HTTP sessions and NETCONF over SOAP over HTTPS sessions.
[Sysname] netconf soap idle-timeout 20
netconf log
Use netconf log to enable NETCONF logging.
Use undo netconf log to remove the configuration for the specified NETCONF operation sources and NETCONF operations.
netconf log source { all | { agent | soap } * } { protocol-operation { all | { action | config | get | session | set | syntax | others } * } | row-operation | verbose }
undo netconf log source { all | { agent | soap } * } { protocol-operation { all | { action | config | get | session | set | syntax | others } * } | row-operation | verbose }
The device logs only row operations for <action> and <edit-config> operations. NETCONF logging is disabled for all the other types of operations.
source: Specifies a NETCONF operation source that represents clients that use a protocol.
·     all: Specifies NETCONF clients that use all protocols.
·     agent: Specifies clients that use Telnet, SSH, NETCONF over console, NETCONF over Telnet, or NETCONF over SSH.
·     soap: Specifies clients that use SOAP over HTTP, or SOAP over HTTPS.
protocol-operation: Logs requests and replies for specific types of NETCONF operations.
·     all: Specifies all types of NETCONF operations.
·     action: Specifies the <action> operation.
·     config: Specifies the configuration-related NETCONF operations, including the <CLI>, <save>, <load>, <rollback>, <lock>, <unlock>, and <save-point> operations.
·     get: Specifies the data retrieval-related NETCONF operations, including the <get>, <get-config>, <get-bulk>, <get-bulk-config>, and <get-sessions> operations.
·     session: Specifies session-related NETCONF operations, including the <kill-session> and <close-session> operations, and capability exchanges by hello messages.
·     set: Specifies all <edit-config> operations.
·     syntax: Specifies the requests that include XML and schema errors.
·     others: Specifies NETCONF operations except for those specified by keywords action, config, get, set, session, and syntax.
row-operation: Logs row operations for <action> and <edit-config> operations.
verbose: Logs detailed information about requests and replies for types of NETCONF operations, including packet contents of format-correct requests and error information about failed <edit-config> operations.
If you specify the protocol-operation keyword, the device logs the matching operation and operation results on a per-request basis. For example, if the device creates VLANs 3 through 5 in response to a NETCONF request, the device outputs the following log messages:
%Mar 21 17:11:34:479 2019 Sysname XMLSOAP/6/XML_REQUEST: test from 192.168.100.198, session id 2,message-id 100, receive edit-config request.
%Mar 21 17:11:34:483 2019 Sysname XMLSOAP/6/EDIT-CONFIG: test from 192.168.100.198, session id 2,message-id 100, execute success.
If you specify the row-operation keyword, the device logs each row operation and the operation result for an <action> or <edit-config> request. For example, if the device creates VLANs 3 through 5 in response to a NETCONF request, the device outputs one log message about each VLAN operation, as follows:
%Mar 31 17:50:02:608 2019 Sysname XMLSOAP/6/EDIT-CONFIG: User (test, 192.168.100.20, session ID 1), message ID=100, operation=create VLAN/VLANs (ID=3), result=Succeeded. No attributes.
%Mar 31 17:50:02:609 2019 Sysname XMLSOAP/6/EDIT-CONFIG: User (test, 192.168.100.20, session ID 1), message ID=100, operation=create VLAN/VLANs (ID=4), result=Succeeded. No attributes.
%Mar 31 17:50:02:611 2019 Sysname XMLSOAP/6/EDIT-CONFIG: User (test, 192.168.100.20, session ID 1), message ID=100, operation=create VLAN/VLANs (ID=5), result=Succeeded. No attributes.
For NETCONF to correctly send the generated logs to the information center, you must also configure the information center. For information about information center configuration, see System Management Configuration Guide.
# Configure the device to log NETCONF edit-config information sourced from agent clients.
[Sysname] netconf log source agent protocol-operation set
netconf soap acl
Use netconf soap acl to apply an IPv4 ACL to control NETCONF over SOAP access.
Use undo netconf soap acl to restore the default.
netconf soap { http | https } acl { ipv4-acl-number | name ipv4-acl-name }
undo netconf soap { http | https } acl
No IPv4 ACL is applied to control NETCONF over SOAP access. Any NETCONF clients can establish NETCONF over SOAP sessions with the device.
ipv4-acl-number: Specifies a numbered IPv4 ACL by its number in the range of 2000 to 2999.
http: Applies an IPv4 ACL to control NETCONF over SOAP over HTTP access.
https: Applies an IPv4 ACL to control NETCONF over SOAP over HTTPS access.
name ipv4-acl-name: Specifies a named IPv4 basic ACL by its name. The ipv4-acl-name argument is a case-insensitive string of 1 to 63 characters. It must start with an English letter. To avoid confusion, it cannot be all.
To control NETCONF over SOAP access, specify an ACL that exists and has rules.
·     If the specified ACL exists and has rules, only clients permitted by the ACL can establish NETCONF over SOAP sessions. A client cannot establish a NETCONF over SOAP session with the device if it does not match the ACL or is denied by the ACL.
·     If the applied ACL does not exist or does not have rules, any NETCONF clients can establish NETCONF over SOAP sessions with the device.
·     To apply an ACL rule only to a VPN instance, specify that VPN instance in the rule. If you do not specify a VPN instance, the rule applies to packets on the public network.
If you execute the netconf soap http acl command multiple times, the most recent configuration takes effect. The same is true for the netconf soap https acl command.
# Use IPv4 ACL 2001 to allow only NETCONF clients from subnet 10.10.0.0/16 to establish NETCONF over SOAP over HTTP sessions.
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit source 10.10.0.0 0.0.255.255
[Sysname] netconf soap http acl 2001
netconf soap domain
Use netconf soap domain to specify a mandatory authentication domain for NETCONF users.
Use undo netconf soap domain to restore the default.
netconf soap domain domain-name
No mandatory authentication domain is specified for NETCONF users.
domain-name: Specifies an ISP domain by its name, a case-insensitive string of 1 to 255 characters. For information about ISP domains, see User Access and Authentication Configuration Guide.
You can use either of the following methods to specify an authentication domain:
·     Execute the netconf soap domain command to specify a mandatory authentication domain. After you execute this command, all NETCONF users are placed in the domain for authentication.
·     Add an authentication domain to the <UserName> parameter of a SOAP request. The authentication domain takes effect only on the current request.
The authentication domain specified by using this command takes precedence over the authentication domain specified by the <UserName> parameter of a SOAP request.
# Specify mandatory authentication domain my-domain for NETCONF users.
[Sysname] netconf soap domain my-domain
netconf soap dscp
Use netconf soap dscp to set the DSCP value for outgoing NETCONF over SOAP packets.
Use undo netconf soap dscp to restore the default.
netconf soap { http | https } dscp dscp-value
undo netconf soap { http | https } dscp
The DSCP value is 0 for outgoing NETCONF over SOAP packets.
dscp-value: Specifies a DSCP value in the range of 0 to 63. A larger DSCP value represents a higher priority.
http: Specifies NETCONF over SOAP over HTTP packets.
https: Specifies NETCONF over SOAP over HTTPS packets.
# Set the DSCP value to 30 for outgoing NETCONF over SOAP over HTTP packets.
[Sysname] netconf soap http dscp 30
netconf soap enable
Use netconf soap enable to enable NETCONF over SOAP.
Use undo netconf soap enable to disable NETCONF over SOAP.
netconf soap { http | https } enable
undo netconf soap { http | https } enable
NETCONF over SOAP is disabled.
http: Specifies NETCONF over SOAP over HTTP.
https: Specifies NETCONF over SOAP over HTTPS.
This command enables the device to resolve NETCONF messages that are encapsulated with SOAP in HTTP or HTTPS packets.
# Enable NETCONF over SOAP over HTTP.
[Sysname] netconf soap http enable
netconf soap http port
Use netconf soap http port to specify a port to listen for NETCONF over SOAP over HTTP session requests.
Use undo netconf soap http port to restore the default.
netconf soap http port port-number
The device uses port 80 to listen for NETCONF over SOAP over HTTP session requests.
port-number: Specifies a port by its number in the range of 1 to 65535.
Executing this command causes existing NETCONF over SOAP sessions to become ineffective. You must re-establish the sessions again.
# Use port 1000 to listen for NETCONF over SOAP over HTTP session requests.
[Sysname] netconf soap http port 1000
netconf soap https ssl-server-policy
Use netconf soap https ssl-server-policy to apply an SSL server policy to the NETCONF over SOAP over HTTPS service.
Use undo netconf soap https ssl-server-policy to restore the default.
netconf soap https ssl-server-policy policy-name
No SSL server policy is applied to the NETCONF over SOAP over HTTPS service.
policy-name: Specifies an SSL server policy name, a string of 1 to 31 characters.
The NETCONF over SOAP over HTTPS service will use the SSL server policy to enhance service security. For more information about SSL server policies, see SSL configuration in Security Configuration Guide.
You can execute this command only when NETCONF over SOAP over HTTPS is disabled. If the service has been enabled, disable it by using the undo netconf soap https enable command.
This command takes effect after you enable NETCONF over SOAP over HTTPS by using the netconf soap https enable command.
If you modify the applied SSL server policy after NETCONF over SOAP over HTTPS is enabled, the changes apply only to the NETCONF over SOAP over HTTPS sessions established subsequently. They do not take effect on the NETCONF over SOAP over HTTPS sessions that have been established before you modify the policy.
# Apply SSL server policy myssl to the NETCONF over SOAP over HTTPS service.
[Sysname] netconf soap https ssl-server-policy myssl
netconf soap enable
ssl server-policy (Security Command Reference)
netconf ssh server enable
Use netconf ssh server enable to enable NETCONF over SSH.
Use undo netconf ssh server enable to disable NETCONF over SSH.
NETCONF over SSH is disabled.
This feature allows you to use an SSH client to invoke NETCONF as an SSH subsystem. Then, you can directly use XML messages to perform NETCONF operations without using the xml command.
Before you execute this command, configure the authentication mode for users as scheme on the device. Then, the NETCONF-over-SSH-enabled user terminals can access the device through NETCONF over SSH.
Only capability set urn:ietf:params:netconf:base:1.0 is available. It is supported by both the device and user terminals.
# Enable NETCONF over SSH.
[Sysname] netconf ssh server enable
netconf ssh server port
Use netconf ssh server port to specify a port to listen for NETCONF over SSH session requests.
Use undo netconf ssh server port to restore the default.
netconf ssh server port port-number
The device uses port 830 to listen for NETCONF over SSH session requests.
Make sure the specified port is not being used by other services.
# Use port 800 to listen for NETCONF over SSH session requests.
[Sysname] netconf ssh server port 800
Use reset netconf service statistics to clear global NETCONF service statistics.
# Clear global NETCONF service statistics.
<Sysname> reset netconf service statistics
Use reset netconf session statistics to clear NETCONF session statistics.
# Clear NETCONF session statistics.
<Sysname> reset netconf session statistics
xml
Use xml to enter XML view.
xml
In XML view, use NETCONF messages to configure the device or obtain data from the device. The NETCONF operations you can perform depend on the user roles you have, as shown in Table 3.
Table 3 NETCONF operations available for the predefined user roles
User role
NETCONF operations
All NETCONF operations
·     Get
·     Get-bulk
·     Get-bulk-config
·     Get-config
·     Get-sessions
·     Close-session
To ensure the format correctness of NETCONF messages in XML view, do not enter NETCONF messages manually. Copy and paste the messages.
While the device is performing a NETCONF operation, do not perform any other operations, such as pasting a NETCONF message or pressing Enter.
For the device to identify NETCONF messages, you must add end mark ]]>]]> at the end of each NETCONF message.
After you enter XML view, the device automatically advertises its NETCONF capabilities to the client. In response, you must configure the client to notify the device of its supported NETCONF capabilities. After the capability exchange, you can use the client to configure the device.
NETCONF messages must comply with the XML format requirements and semantic and syntactic requirements in the NETCONF XML API reference for the device. As a best practice, use third-party software to generate NETCONF messages to ensure successful configuration.
To quit XML view, use a NETCONF message instead of the quit command.
If you have configured a shortcut key (Ctrl + C, by default) by using the escape-key command in user line/user line class view, the NETCONF message should not contain the shortcut key string. If the NETCONF message contains the shortcut key string, relevant configurations in XML view might be affected. For example, in user line view, you configured "a" as the shortcut key by using the escape-key a command. When a NETCONF message includes the character "a," only the content after the last "a" in the message can be processed.
# Enter XML view.
<Sysname> xml
# Notify the device of the NETCONF capabilities supported on the client.
<hello xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <capabilities>
    <capability>
    </capability>
  </capabilities>
</hello>]]>]]>
# Quit XML view.
<rpc message-id="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <close-session/>
</rpc>]]>]]>
