17-Intelligent Lossless Network Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6805 & S6825 & S6850 & S9850 Command References-Release 6715-6W10017-Intelligent Lossless Network Command Reference
03-iNOF commands
03-iNOF commands 164.21 KB
iNOF commands
To configure and use the iNOF feature, first install a license. For more information about licenses, see license management configuration in Fundamentals Configuration Guide.
address-family inof
Use address-family inof to create the BGP Intelligent Lossless NVMe Over Fabric (iNOF) address family and enter its view, or enter the view of the existing BGP iNOF address family.
Use undo address-family inof to remove the BGP iNOF address family and all its configurations.
address-family inof
No BGP iNOF address family exists.
BGP instance view
The configuration in BGP iNOF address family view applies only to the BGP iNOF routes and peers in the public network.
# In BGP instance view, create the BGP iNOF address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family inof
[Sysname-bgp-default-inof]
role
peer enable (Layer 3IP Routing Command Reference)
peer reflect-client (Layer 3—IP Routing Command Reference)
reflector cluster-id (Layer 3—IP Routing Command Reference)
default-zone enable
Use default-zone enable to enable automatic adding of free hosts to the default iNOF zone.
Use undo default-zone enable to disable automatic adding of free hosts to the default iNOF zone.
default-zone enable
The device adds free hosts to the default iNOF zone automatically.
iNOF view
The default iNOF zone does not support manual adding of online hosts. The device enabled with this feature adds a host to the default iNOF zone when the following conditions exist:
·     The host is directly connected to the device and comes online.
·     The host is a free host that is not a member of any user-defined iNOF zone.
Support for this command varies by iNOF network type as follows:
·     On a directly-connected iNOF network, all iNOF switches support this command.
·     On a cross-switch iNOF network, only iNOF reflectors support this command. For iNOF clients on such a network, whether to add free hosts to the default zone depends on the configuration of this feature for the iNOF reflector. To specify the role of an iNOF switch on the iNOF network, use the role command.
# Enable automatic adding of free hosts to the default iNOF zone.
[Sysname] inof enable
[Sysname-inof] default-zone enable
display bgp inof
Use display bgp inof to display BGP iNOF route information.
display bgp [ instance instance-name ] inof [ inof-prefix | peer ipv4-address  { advertised | received } [ statistics ] | statistics ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP iNOF route information for the default BGP instance.
inof-prefix: Specifies an iNOF route prefix, a case-sensitive string of 1 to 512 characters. To ensure successful matching, enter a complete iNOF route prefix.
peer ipv4-address: Displays BGP iNOF route information advertised to or received from the specified IPv4 peer.
advertised: Displays BGP iNOF route information advertised to the specified peer.
received: Displays BGP iNOF route information received from the specified peer.
statistics: Displays BGP iNOF route statistics.
If you do not specify any parameters, this command displays brief information about all BGP iNOF route for the public network.
# Display brief information about all BGP iNOF route for the public network.
<Sysname> display bgp inof
Total number of routes: 9
 BGP local router ID is 10.1.1.1
 Status codes: * - valid, > - best, d - dampened, h - history
               a - additional-path
     Inof         PeerID              OriginRouterID      PathID
* >  DefaultZone=TRUE,RouterID=10.1.1.1
                  0.0.0.0             0.0.0.0               0
* >  HardZoning=FALSE,RouterID=10.1.1.1
                  0.0.0.0             0.0.0.0               0
* >  ZoneName=1,RouterID=10.1.1.1
                  0.0.0.0             0.0.0.0               0
* >  ZoneName=1,HostIP=10.10.1.100,RouterID=10.1.1.1
                  0.0.0.0             0.0.0.0               0
* >  ZoneName=1,HostIP=10.10.1.101,RouterID=10.1.1.1
                  0.0.0.0             0.0.0.0               0
* >  ZoneName=1,HostIP=10.10.1.102,RouterID=10.1.1.1
                  0.0.0.0             0.0.0.0               0
* >  ZoneName=1,HostIP=10.10.1.103,RouterID=10.1.1.1
                  0.0.0.0             0.0.0.0               0
* >  ZoneName=1,HostIP=10.10.1.104,RouterID=10.1.1.1
                  0.0.0.0             0.0.0.0               0
* >  ZoneName=1,HostIP=10.10.1.105,RouterID=10.1.1.1
                  0.0.0.0             0.0.0.0               0
# Display information about the BGP iNOF routes received from peer 10.1.1.1.
<Sysname> display bgp inof peer 10.1.1.1 received
 BGP local router ID is 30.1.1.2
               a - additional-path
* >i DefaultZone=TRUE,RouterID=10.1.1.2
                  10.1.1.1            10.1.1.2              0
* >i HardZoning=FALSE,RouterID=10.1.1.2
                  10.1.1.1            10.1.1.2              0
* >i ZoneName=1,RouterID=10.1.1.2
                  10.1.1.1            10.1.1.2              0
* >i ZoneName=1,HostIP=10.10.1.100,RouterID=10.1.1.2
                  10.1.1.1            10.1.1.2              0
* >i ZoneName=1,HostIP=10.10.1.101,RouterID=10.1.1.2
                  10.1.1.1            10.1.1.2              0
* >i ZoneName=1,HostIP=10.10.1.102,RouterID=10.1.1.2
                  10.1.1.1            10.1.1.2              0
* >i ZoneName=1,HostIP=10.10.1.103,RouterID=10.1.1.2
                  10.1.1.1            10.1.1.2              0
* >i ZoneName=1,HostIP=10.10.1.104,RouterID=10.1.1.2
                  10.1.1.1            10.1.1.2              0
* >i ZoneName=1,HostIP=10.10.1.105,RouterID=10.1.1.2
                  10.1.1.1            10.1.1.2              0
Status codes
Route status codes:
·     * – valid—Valid route.
·     > – best—Optimal route.
·     d - dampened—Dampened route.
·     h – history—History route.
·     s – suppressed—Suppressed route.
·     S – stale—Stale route.
·     i – internal—Internal route.
·     e – external—External route.
·     a - additional-path—Add-Path optimal route.
Origin
Origin of the route:
·     i – IGP—Originated in the AS.
·     e – EGP—Learned through Exterior Gateway Protocol (EGP).
·     ? – incomplete—Unknown origin.
Inof
BGP iNOF route prefix.
PeerID
ID of the peer from which the local device received the route. If the route is generated by the local device, this field displays 0.0.0.0.
OriginRouterID
ID of the router that generates the route. If the route is generated by the local device, this field displays 0.0.0.0.
PathID
Add-Path ID of the learned route, which is fixed at 0.
# Display detailed information about the BGP iNOF routes with prefix DefaultZone=TRUE,RouterID=10.1.1.2.
<Sysname> display bgp inof DefaultZone=TRUE,RouterID=10.1.1.2
 BGP local router ID: 30.1.1.2
 Local AS number: 100
 Paths:   1 available, 1 best
 BGP routing table information of DefaultZone=TRUE,RouterID=10.1.1.2:
 Original nexthop: 10.1.1.1
 OutLabel          : NULL
 RxPathID          : 0x0
 TxPathID          : 0x0
 AS-path           : (null)
 Origin            : igp
 Attribute value : localpref 100, pref-val 0
 State             : valid, internal, best
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
Paths
Number of routes:
·     available—Number of valid routes.
·     best—Number of optimal routes. BGP iNOF routes are all optimal routes.
BGP routing table information of iNOF-prefix
Information about the BGP iNOF routes with iNOF-prefix.
Imported route
This route is imported.
RR-client route
This route is received from a route reflection client.
From
IP address of the BGP peer that advertised the route.
Original nexthop
Original next hop of the route. If the route was obtained from a BGP update message, the original next hop is the next hop IP address in the message.
OutLabel
Outgoing label of the route. This field displays NULL for BGP iNOF routes.
RxPathID
Add-Path ID of received routes.
TxPathID
Add-Path ID of advertised routes.
AS-path
AS_PATH attribute of the route.
Origin
·     igp—Originated in the AS.
·     egp—Learned through Exterior Gateway Protocol (EGP).
·     incomplete—Unknown origin.
Attribute value
BGP path attributes:
·     MED—MED value.
·     localprefLocal preference value.
·     pref-val—Preferred value.
·     pre—Route preference.
Current state of the route:
·     valid.
·     internal.
·     external.
·     local.
·     synchronize.
·     best.
IP precedence
IP precedence in the range of 0 to 7. N/A indicates that the route does not support this field.
QoS local ID
QoS local ID in the range of 1 to 4095. N/A indicates that the route does not support this field.
Traffic index
Traffic index in the range of 1 to 64. N/A indicates that the route does not support this field.
# Display statistics of the BGP iNOF routes advertised to peer 10.2.1.2.
<Sysname> display bgp inof peer 10.1.1.2 advertised statistics
 Advertised routes total: 2
# Display statistics of the BGP iNOF routes received from peer 10.2.1.2.
<Sysname> display bgp inof peer 10.1.1.2 received statistics
 Received routes total: 2
Number of the BGP iNOF routes advertised to the peer.
Number of the BGP iNOF routes received from the peer.
# Display BGP iNOF route statistics.
<Sysname> display bgp inof statistics
 Total number of routes: 4
display inof configuration
Use display inof configuration to display global iNOF configuration information.
# Display global iNOF configuration information.
<Sysname> display inof configuration
iNOF         : Enabled
iNOF role   : Standalone
Default-zone: Enabled
Hard-zoning : Disabled
iNOF
Whether iNOF is enabled on the device.
iNOF role
Role of the device on the iNOF network:
·     Reflect-clientThe device acts as an iNOF client.
·     Reflector—The device acts as an iNOF reflector.
·     Standalone—The device runs in standalone mode.
Default-zone
Whether the device automatically adds free hosts to the default iNOF zone.
Hard-zoning
Whether iNOF hard zoning is enabled on the device.
display inof configuration zone
Use display inof configuration zone to display information about user-defined iNOF zones.
display inof [ ipv6 ] configuration zone [ zone-name ] [ inconsistent ]
ipv6: Displays information about the IPv6 hosts in the specified iNOF zone. If you do not specify this keyword, this command displays information about the IPv4 hosts in the specified iNOF zone.
zone-name: Specifies a user-defined iNOF zone by its name, a case-sensitive string of 1 to 31 characters.
inconsistent: Displays the iNOF zones configured on only one iNOF reflector.
iNOF reflectors on the same network must have the same iNOF zone configuration. You can use the inconsistent keyword to discover inconsistent iNOF zone configuration.
If you do not specify a user-defined iNOF zone or the inconsistent keyword, the command displays information about all user-defined iNOF zones.
# Display information about the IPv4 hosts in user-defined iNOF zones.
<Sysname> display inof configuration zone
Total Zone number: 2
iNOF Default-Zone: Enable
ZoneName                          Host             Learned-From
Default                           --                Local
Test                               10.1.1.10        Local
Test                               10.1.1.20        Local
# Display information about the IPv6 hosts in user-defined iNOF zones.
<Sysname> display inof ipv6 configuration zone
Total Zone number: 3
Default                           C0A8:386E:C0A8:386E:C0A8:386E:C0A8:386E 10.1.1.2
Test                               --                                             Local
TestIPv6                          1::1                                           Local
Table 5 Command output
Total Zone number
Number of iNOF zones in the current iNOF network. The default iNOF zone is included in the statistics only when it is enabled.
iNOF Default-Zone
ZoneName
Name of the iNOF zone to which the host belongs.
Host
IP address of the host.
·     If you execute the display inof configuration zone command and this field displays double hyphens (--), the iNOF zone does not have any IPv4 hosts.
·     If you execute the display inof ipv6 configuration zone command and this field displays double hyphens (--), the iNOF zone does not have any IPv6 hosts.
Learned-From
Source of the iNOF zone configuration:
·     iNOF reflector IP address—The iNOF zone is learned from the iNOF reflector.
·     Local—The iNOF zone is configured on the local device.
display inof information host
Use display inof information host to display iNOF host information.
display inof [ ipv6 ] information host [ ip-address | local | remote ]
ipv6: Display information about IPv6 iNOF hosts. If you do not specify this keyword, this command displays information about IPv4 iNOF hosts.
ip-address: Specifies an iNOF host by its IP address.
local: Displays information about the iNOF hosts connected to the local device.
remote: Displays information about the iNOF hosts learned from the iNOF reflector.
# Display information about IPv4 iNOF hosts.
<Sysname> display inof information host
Host            Type   AccessDevice                            AccessInterface          HardZoning
192.168.1.155 Local  192.168.2.151                           WGE1/0/1                       Normal
192.168.1.156 Local  192.168.2.151                           WGE1/0/1                       Normal
192.168.1.157 Local  192.168.2.151                           WGE1/0/1                       Normal
192.168.1.185 Local  192.168.2.151                           WGE1/0/1                       Normal
# Display information about IPv6 iNOF hosts.
<Sysname> display inof ipv6 information host
C0A8:386E:C0A8:386E:C0A8:386E:C0A8:386E local  21.1.1.4                                 WGE1/0/1                   Abnormal
C0A8:386E:C0A8:386E:C0A8:386E:C0A8:3861 local  21.1.1.4                                 WGE1/0/1                   Abnormal
C0A8:386E:C0A8:386E:C0A8:386E:C0A8:3862 local  21.1.1.4                                 WGE1/0/1                   Abnormal
C0A8:386E:C0A8:386E:C0A8:386E:C0A8:3863 local  21.1.1.4                                 WGE1/0/1                   Abnormal
Table 6 Command output
Host
IP address of the iNOF host.
Access type the iNOF host:
·     Local—The host is connected to the local device.
·     Remote—The host is connected to a remote device. The local device learned the host information from the iNOF reflector.
Access Device
IP address of the device to which the host is connected.
Access Interface
Host-facing interface or reflector-facing interface on the device.
Hard Zoning
iNOF hard zoning status on the access interface:
·     Normal—iNOF hard zoning is enabled.
·     Abnormal—iNOF hard zoning is abnormal and cannot take effect.
·     Hyphen (--)—The host is connected to a remote device. To view the iNOF hard zoning status on the real access interface, use the display inof information host command on that remote device.
display inof reflector
Use display inof reflector to display iNOF reflector information.
# Display iNOF reflector information.
<Sysname> display inof reflector
Index   ReflectorIP           DefaultZone            HardZoning
1        Local                  Enabled                 Disabled
2        100.1.1.2             Enabled                 Disabled
Table 7 Command output
Index
Index of the iNOF reflector.
ReflectorIP
Router ID of the iNOF reflector. The Local attribute indicates that the device is an iNOF reflector.
DefaultZone
Whether the iNOF reflector automatically adds free hosts to the default iNOF zone.
HardZoning
Whether iNOF hard zoning is enabled on the iNOF reflector.
hard-zoning enable
Use hard-zoning enable to enable iNOF hard zoning.
Use undo hard-zoning enable to disable iNOF hard zoning.
hard-zoning enable
iNOF hard zoning is disabled.
iNOF view
If iNOF hard zoning is enabled, the following rules apply:
·     Hosts in the same iNOF zone can access each other.
·     Hosts in different iNOF zones cannot access each other.
·     On a cross-switch iNOF network, only iNOF reflectors support this command. For iNOF clients on such a network, the status of iNOF hard zoning depends on the configuration of this feature for the iNOF reflector. To specify the role of an iNOF switch on the iNOF network, use the role command.
# Enable iNOF hard zoning.
[Sysname-inof] hard-zoning enable
zone
host
Use host to add members (hosts) into a user-defined iNOF zone.
Use undo host to remove hosts from a user-defined iNOF zone.
host [ ipv6 ] { ip-address | ip-address1 to ip-address2 }
undo host [ ipv6 ] { ip-address | ip-address1 to ip-address2 }
The user-defined iNOF zone has no members.
iNOF zone view
ipv6: Adds IPv6 hosts into the user-defined iNOF zone. To add IPv4 hosts, do not specify this keyword.
ip-address1 to ip-address2: Specifies an IP address range of iNOF hosts. The ip-address1 argument represents the start IP address and the ip-address2 argument represents the end IP address. The end IP address cannot be lower than the start IP address.
The iNOF zone can manage its members as long as these members come online.
To add multiple hosts into a user-defined iNOF zone, repeat this command. You can add a host into multiple user-defined iNOF zones.
# Add host 192.168.56.111 into user-defined iNOF zone zone1.
[Sysname-inof] zone 1
[Sysname-inof-zone-1] host 192.168.56.111
inof enable
Use inof enable to enable iNOF and enter its view, or enter iNOF view if it is already enabled.
Use undo inof enabl to disable iNOF.
inof enable
undo inof enable
iNOF is disabled.
CAUTION
CAUTION:
Disabling iNOF removes all configurations in iNOF view. Make sure you have understood the potential impact before performing this operation.
A storage system needs to manage a large number of hosts for data storage. The system might have a slow reaction to host changes, which degrades storage performance. To resolve this issue, enable iNOF. When a host is connected to or is disconnected from a device, all devices on the same iNOF zone can detect the event immediately and report it to the storage system. Then, the system can intelligently adjust related settings to accommodate this change. This ensure the storage system can achieve lossless storage with low latency and high throughput.
# Enable iNOF and enter its view.
[Sysname-inof]
role
Use role to specify the role of the device on the iNOF network.
Use undo role to restore the default.
role { reflect-client | reflector }
undo role
The iNOF role of the device is not specified.
reflect-client: Specifies the iNOF role of the device as client.
reflector: Specifies the iNOF role of the device as reflector.
On a cross-switch iNOF network, each iNOF switch acts as one of the following:
·     ReflectorUpon receiving iNOF route information from a client, the iNOF reflector advertises it to other clients.
·     Client—When the device acts as an iNOF client, it establishes an iNOF connection to the iNOF reflector for iNOF route advertisement. iNOF clients do not exchange iNOF route information.
The application of BGP route reflection simplifies the maintenance of iNOF network by reducing the number of iNOF connections.
This command configures a logical role for an iNOF switch to specify the iNOF features that you can configure on that switch. To configure the iNOF switch as an actual iNOF reflector, perform the following tasks:
·     Use the role reflector command to specify the iNOF role of the switch as reflector.
·     Use the peer reflect-client command to specify the switch as a route reflector.
For an iNOF client, the peer reflect-client command is not supported in BGP iNOF address family view and the zone command is not supported in iNOF zone view.
After you use the peer reflect-client or zone command on an iNOF switch, you cannot specify the iNOF role of that switch as client.
To ensure iNOF clients receive iNOF routes only from iNOF reflectors, do not establish any BGP sessions between clients in BGP iNOF address family.
# Specify the iNOF role of an iNOF switch as reflector.
[Sysname] bgp 100
[Sysname-bgp-default-inof] role reflector
# Specify the iNOF role of the switch as client.
[Sysname] bgp 100
[Sysname-bgp-default-inof] role reflect-client
address-family inof
zone
zone
Use zone to create an iNOF zone and enter its view, or enter iNOF zone view if the zone already exists.
Use undo zone to delete a user-defined iNOF zone.
zone zone-name
undo zone zone-name
The device has a default iNOF zone and the zone name is Default.
iNOF view
iNOF introduces the concept of zone to manage hosts. By default, the device has a default iNOF zone that cannot be deleted. After you create an iNOF zone, you can add hosts into that zone.
·     On a cross-switch iNOF network, only iNOF reflectors support this command. After you create iNOF zones and add hosts into these zones on an iNOF reflector, the reflector issues the configuration to its clients. To implement iNOF zone configuration backup among the reflectors on the iNOF network, configure the same iNOF zones on each reflector separately.
# Create iNOF zone 1.
default-zone enable
hard-zoning enable
host
