06-IP Multicast Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6805 & S6825 & S6850 & S9850 Command References-Release 6715-6W10006-IP Multicast Command Reference
08-Multicast VPN commands
08-Multicast VPN commands 453.73 KB
address-family ipv4
Use address-family ipv4 to create an MVPN IPv4 address family and enter its view, or enter the view of the existing MVPN IPv4 address family.
Use undo address-family ipv4 to delete the MVPN IPv4 address family and configurations in MVPN IPv4 address family view.
address-family ipv4
No MVPN IPv4 address family exists.
MVPN view
Configurations in MVPN IPv4 address family view of a VPN instance apply only to IPv4 multicast packets of that instance.
# In MVPN view of VPN instance mvpn, create an MVPN IPv4 address family and enter its view.
[Sysname] multicast-vpn vpn-instance mvpn mode mdt
[Sysname-mvpn-mvpn] address-family ipv4
[Sysname-mvpn-mvpn-ipv4]
address-family ipv4 mdt
Use address-family ipv4 mdt to create a BGP IPv4 MDT address family and enter its view, or enter the view of the existing BGP IPv4 MDT address family.
Use undo address-family ipv4 mdt to delete the BGP IPv4 MDT address family and all configurations in BGP IPv4 MDT address family view.
No BGP IPv4 MDT address family exists.
BGP instance view
Execute this command before you use the peer enable command to enable BGP peers to exchange MDT information. MDT information includes the IP address of a PE device and the default group to which the PE device belongs. On a public network running PIM-SSM, multicast VPN establishes a default MDT rooted at the PE device (multicast source) based on the MDT information.
Configurations in BGP IPv4 MDT address family view take effect only on BGP MDT messages, BGP MDT peers, and BGP MDT peer groups.
# In BGP instance view of BGP instance default, create a BGP IPv4 MDT address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 mdt
[Sysname-bgp-default-mdt]
# In BGP instance view of BGP instance abc, create a BGP IPv4 MDT address family and enter its view.
[Sysname-bgp-abc] address-family ipv4 mdt
[Sysname-bgp-abc-mdt]
peer enable (see Layer 3—IP Routing Command Reference)
address-family ipv4 mvpn
Use address-family ipv4 mvpn to create a BGP IPv4 MVPN address family and enter its view, or enter the view of the existing BGP IPv4 MVPN address family.
Use undo address-family ipv4 mvpn to delete the BGP IPv4 MVPN address family and all configurations in BGP IPv4 MVPN address family view.
No BGP IPv4 MVPN address family exists.
BGP instance view
Configurations in BGP IPv4 MVPN address family view take effect only on BGP MVPN messages, BGP MVPN peers, and BGP MVPN peer groups.
# In BGP instance view of BGP instance 100, create a BGP IPv4 MVPN address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 mvpn
[Sysname-bgp-default-mvpn]
address-family ipv6
Use address-family ipv6 to create an MVPN IPv6 address family and enter its view, or enter the view of the existing MVPN IPv6 address family.
Use undo address-family ipv6 to delete the MVPN IPv6 address family and configurations in MVPN IPv6 address family view.
address-family ipv6
No MVPN IPv6 address family exists.
MVPN view
Configurations in MVPN IPv6 address family view of a VPN instance apply only to IPv6 multicast packets of that instance.
# In MVPN view of VPN instance mvpn, create an MVPN IPv6 address family and enter its view.
[Sysname-mvpn-mvpn] address-family ipv6
[Sysname-mvpn-mvpn-ipv6]
data-delay
Use data-delay to set the data-delay period (delay period before the device switches over from the default MDT to the data MDT).
Use undo data-delay to restore the default.
data-delay delay
undo data-delay
The data-delay period is 3 seconds.
delay: Specifies a data-delay period in the range of 1 to 60 seconds.
This command is available only for an MDT-based MVPN.
# In MVPN IPv4 address family view of VPN instance mvpn, set the data-delay period to 20 seconds.
[Sysname-mvpn-mvpn-ipv4] data-delay 20
data-group
Use data-group to specify a data group range and optionally configure the criteria for the device to initiate a switchover of the default MDT to a data MDT.
Use undo data-group to restore the default.
data-group group-address { mask-length | mask } [ acl acl-number]
undo data-group
No data group range exists, and the device never initiates a switchover of the default MDT to a data MDT.
group-address: Specifies a multicast group address in the range of 224.0.1.0 to 239.255.255.255.
mask-length: Specifies a mask length for the multicast group address. The value range for this argument is 25 to 32.
mask: Specifies a subnet mask for the multicast group address.The value range for this argument is 255.255.255.x, where x can be only 128, 192, 224, 240, 248, 252, 254, or 255.
acl acl-number: Specifies an advanced ACL by its number in the range of 3000 to 3999. If you specify an ACL, the multicast data permitted by the ACL can trigger the switchover. If you do not specify an ACL, any multicast data can trigger the switchover. For the ACL to take effect, specify the protocol type as IP, and include the source and destination keywords when you create an ACL rule. The source and destination keywords specify a multicast source address range and a multicast group address range, respectively.
On a PE, the data group range for an MVPN cannot include the default group or data groups of any other MVPN. For an MVPN that transmits both IPv4 and IPv6 multicast packets, the data group ranges in MVPN IPv4 address family view and MVPN IPv6 address family view cannot overlap.
All VPN instances share the data group resources. As a best practice to avoid data group resource exhaustion, specify a reasonable data group range for a VPN instance.
The data group range specified in this command cannot contain the multicast group address for flood traffic specified by using the group command in VXLAN view. For more information about the multicast group address for VXLAN flood traffic, see basic VXLAN feature configuration in VXLAN Configuration Guide.
The data group ranges for different MDs on different PE devices cannot overlap with one another if the PIM mode is not PIM-SSM on the public network.
If you execute this command multiple times in the same MVPN IPv4 address family view or IPv6 address family view, the most recent configuration takes effect.
If BIDIR-PIM runs in a VPN instance, the switchover from the default MDT to a data MDT is not supported.
When you reference an ACL, follow these restrictions and guidelines:
·     If the ACL does not exist or contains no rules, any multicast data can trigger a switchover.
·     An ACL rule containing the vpn-instance vpn-instance option does not take effect.
# In MVPN IPv4 address family view of VPN instance mvpn, specify 239.1.2.0 through 239.1.2.255 as the data group range.
[Sysname-mvpn-mvpn-ipv4] data-group 239.1.2.0 25
default-group
Use default-group to specify a default group.
Use undo default-group to restore the default.
default-group group-address
undo default-group
No default group exists.
group-address: Specifies a default group in the range of 224.0.1.0 to 239.255.255.255.
You must specify the same default group on all PE devices that belong to the same MVPN.
The default group for an MVPN must be different from the default group and the data group used by any other MVPN.
The default group address specified in this command must be different from the multicast group address for flood traffic specified by using the group command in VXLAN view. For more information about the multicast group address for VXLAN flood traffic, see basic VXLAN feature configuration in VXLAN Configuration Guide.
For an MVPN that transmits both IPv4 and IPv6 multicast packets, you must specify the same default group in MVPN IPv4 address family view and MVPN IPv6 address family view.
# In MVPN IPv4 address family view and IPv6 address family view of VPN instance mvpn, specify 239.1.1.1 as the default group.
[Sysname-mvpn-mvpn-ipv4] default-group 239.1.1.1
[Sysname-mvpn-mvpn-ipv4] quit
[Sysname-mvpn-mvpn-ipv6] default-group 239.1.1.1
display bgp routing-table ipv4 mdt
Use display bgp routing-table ipv4 mdt to display BGP MDT routing information.
display bgp [ instance instance-name ] routing-table ipv4 mdt [ route-distinguisher route-distinguisher ] [ ip-address [ advertise-info | as-path | cluster-list ] ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays BGP MDT routing information for BGP instance default.
route-distinguisher route-distinguisher: Specifies an RD, a string of 3 to 21 characters. If you do not specify an RD, this command displays BGP MDT routing information for all RDs. An RD can be in one of the following formats:
·     16-bit AS number:32-bit user-defined number. For example, 101:3.
·     32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
·     32-bit AS number:16-bit user-defined number, where the AS number must be equal to or greater than 65536. For example, 65536:1.
ip-address: Specifies a multicast source by its IP address. The ip-address argument represents the IP address of the PE device in the default MDT. If you do not specify a multicast source, this command displays brief information about BGP MDT routes for all multicast sources.
advertise-info: Displays advertisement information. If you do not specify this keyword, no advertisement information is displayed.
as-path: Displays AS_PATH attribute information for BGP MDT routes.
cluster-list: Displays CLUSTER_LIST attribute information for BGP MDT routes.
# Display brief information about BGP MDT routes for all multicast sources.
<Sysname> display bgp routing-table ipv4 mdt
 Route distinguisher: 100:1
 Total number of routes: 2
     Network            NextHop         MED        LocPrf     PrefVal Path/Ogn
* >  1.1.1.1/32         0.0.0.0                               32768   ?
* >i 2.2.2.2/32         2.2.2.2                    100        0       ?
# Display detailed information about BGP MDT routes for multicast source 1.1.1.1.
<Sysname> display bgp routing-table ipv4 mdt 1.1.1.1
 BGP local router ID: 1.1.1.1
 Local AS number: 100
 Total number of routes: 1
 Paths:   1 available, 1 best
 BGP MDT information of source 1.1.1.1:
 Default-group   : 224.1.1.1
 Original nexthop: 0.0.0.0
 AS-path         : (null)
 Origin          : incomplete
 Attribute value : pref-val 32768
 State           : valid, local, best
IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
# Display advertisement information about BGP MDT routes for multicast source 1.1.1.1.
<Sysname> display bgp routing-table ipv4 mdt 1.1.1.1 advertise-info
 Paths:   1 best
 Default-group: 224.1.1.1
     6.6.6.6
# Display AS_PATH attribute information about BGP MDT routes for multicast source 1.1.1.1.
<Sysname> display bgp routing-table ipv4 mdt 1.1.1.1 as-path
 As-path: 100
# Display CLUSTER_LIST attribute information about BGP MDT routes for multicast source 1.1.1.1.
 Cluster list: 80
BGP local router ID
ID of the local router.
Status codes
Codes of route status:
·     * – valid—Valid route.
·     > – best—Optimal route.
·     d – damped—Dampened route.
·     h – history—History route.
·     s – suppressed—Suppressed route.
·     S – Stale—Stale route.
·     i – internal—Internal route.
·     e – external—External route.
Origin
Origin of the route information:
·     IGP—Originated in the AS.
·     EGP—Learned through EGP.
·     incomplete—Learned by some other means.
Total number of BGP MDT routes.
Network
Source IP address of the default MDT.
NextHop
IP address of the next hop.
MED
Attribute value of Multi-Exit-Discrimination (MED).
LocPrf
Local preference value.
PrefVal
Preferred value of a route.
Path/Ogn
AS PATH attribute and ORIGIN attribute:
·     AS_PATH—Records the ASs the packet has passed to avoid routing loops.
·     ORIGIN—Identifies the origin of the BGP MDT routes.
Paths
Number of the BGP MDT routes:
·     available—Number of valid BGP MDT routes.
·     best—Number of the optimal BGP MDT routes.
BGP MDT routing information for the multicast source 1.1.1.1.
Default-group
Default-group address to which the route belongs.
Peers to which the route has been advertised and total number of peers.
From
IP address of the BGP peer that advertises the BGP MDT route.
Original nexthop
IP address of the original next hop.
If the BGP MDT route is learned from the BGP update message, this field displays the IP address of the next hop that receives the message.
AS-path
AS PATH attribute of the path, recording the ASs that the BGP MDT route has passed to avoid routing loops.
Cluster list
CLUSTER_LIST attribute of the route.
Attribute value
Attributes of the BGP MDT routes:
·     MED—MED value related to destination network.
·     Localpref—Local preferred value.
·     pref-val—Preferred value of the route.
·     pre—Preferred value of the protocol.
Current states:
·     valid—Valid routes.
·     internal—Internal routes.
·     external—External routes.
·     local—Local routes.
·     synchronize—Synchronized routes.
·     best—Optimal routes.
·     not preferred for reason—Reason why the route is not selected as the optimal route. For more information, see Table 2.
IP precedence
IP precedence of the route, which is set by the QPPB feature. This field displays N/A if the route does not carry this attribute.
QoS local ID
QoS local ID of the route, which is set by the QPPB feature. This field displays N/A if the route does not carry this attribute.
Traffic index
Traffic index of the route, which is set by the QPPB feature. This field displays N/A if the route does not carry this attribute.
Table 2 Reason why the route is not selected as the optimal route
Reason
preferred-value
Routes with larger preferred values exist.
local-preference
Routes with larger local preference values exist.
local-origin-route
There are routes whose local-origin-route attribute has a higher priority.
BGP selects the optimal route from local routes in this order: route generated by the network command, route redistributed by the import-route command, and summary route.
as-path
Routes with smaller AS_PATH attribute values exist.
origin
There are routes whose origin has a higher priority. The route origins are IGP, EGP, and INCOMPLETE in descending order of priority.
med
Routes with smaller MED values exist.
remote-route
There are routes whose remote-route attribute has a higher priority.
BGP selects the optimal route from remote routes in this order:
·     Route learned from an EBGP peer.
·     Route learned from a confederation EBGP peer.
·     Route learned from a confederation IBGP peer.
·     Route learned from an IBGP peer.
igp-cost
Routes with smaller IGP metrics exist.
relydepth
Routes with smaller recursion depth values exist.
rfc5004
A route received from an EBGP peer is the current optimal route. BGP does not change the optimal route when it receives routes from other EBGP peers.
router-id
Routes with smaller router IDs exist.
If one of the routes is advertised by a route reflector, BGP compares the ORIGINATOR_ID of the route with the router IDs of other routes. Then, BGP selects the route with the smallest ID as the optimal route.
cluster-list
Routes with smaller CLUSTER_LIST attribute values exist.
peer-address
Routes advertised by peers with lower IP addresses exist.
redist-route
Routes of the current VPN instance exist.
rpki
Routes with higher RPKI validation state preferences exist.
received
Earlier learned routes exist.
# Display statistics about BGP MDT routes for all multicast sources.
<Sysname> display bgp routing-table ipv4 mdt statistics
 Total number of routes from all PEs: 4507
 Total number of routes: 2505
 Route distinguisher: 100:2
 Total number of routes: 2002
display bgp routing-table ipv4 mvpn
Use display bgp routing-table ipv4 mvpn to display BGP IPv4 MVPN routing information.
display bgp [ instance instance-name ] routing-table ipv4 mvpn [ route-distinguisher route-distinguisher [ route-type { inter-as |intra-as | leaf | s-pmsi | shared-tree | source-active | source-tree } ] [ mvpn-prefix [ as-path | cluster-list | ext-community ] ] | statistics ]
display bgp [ instance instance-name ] routing-table ipv4 mvpn [ route-distinguisher route-distinguisher [ mvpn-prefix [ as-path | cluster-list | ext-community ] ] ]
display bgp [ instance instance-name ] routing-table ipv4 mvpn [ route-distinguisher route-distinguisher ] [ mvpn-prefix [ advertise-info ] ]
display bgp [ instance instance-name ] routing-table ipv4 mvpn [ route-type { inter-as | intra-as | leaf | s-pmsi | shared-tree | source-active | source-tree } [ statistics ] ]
display bgp [ instance instance-name ] routing-table ipv4 mvpn peer ip-address { advertised-routes | received-routes } [ statistics ]
display bgp [ instance instance-name ] routing-table ipv4 mvpn [ route-distinguisher route-distinguisher ] [ statistics ] ext-community [ rt route-target ]&<1-32> [ whole-match ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays BGP IPv4 MVPN routing information for BGP instance default.
peer ip-address: Specifies a BGP peer by its IP address.
advertised-routes: Displays BGP IPv4 MVPN routing information advertised to the specified peer.
received-routes: Displays BGP IPv4 MVPN routing information received from the specified peer.
route-distinguisher route-distinguisher: Specifies an RD, a string of 3 to 21 characters. An RD can be in one of the following formats:
·     32-bit AS number:16-bit user-defined number. For example, 65536:1. The AS number must be equal to or greater than 65536.
route-type: Specifies a route type.
·     intra-as: Specifies the Intra-AS I-PMSI A-D route to establish the inclusive tunnel.
·     inter-as: Specifies the Inter-AS I-PMSI A-D route to establish the inclusive tunnel.
·     s-pmsi: Specifies the S-PMSI A-D route that the source-side PE sends to the receiver-side PE to establish selective tunnels.
·     leaf: Specifies the Leaf A-D route that the receiver-side PE replies to the multicast source-side PE to establish selective tunnels.
·     source-active: Specifies the Source Active A-D route that advertises the multicast source.
·     shared-tree: Specifies the Shared Tree Join route that the receiver-side PE sends to the RP to establish the multicast shared tree.
·     source-tree: Specifies the Source Tree Join route that the receiver-side PE sends to the multicast source to build the multicast source tree.
mvpn-prefix: Specifies the prefix of a BGP IPv4 MVPN route, a case-insensitive string of 1 to 512 characters.
advertise-info: Displays advertisement information of BGP IPv4 MVPN routes.
as-path: Displays AS_PATH attribute information for BGP IPv4 MVPN routes.
cluster-list: Displays CLUSTER_LIST attribute information for BGP IPv4 MVPN routes.
ext-community: Displays extended community attribute information for BGP IPv4 MVPN routes.
statistics: Displays statistics for BGP IPv4 MVPN routes.
rt route-target&<1-32>: Specifies a list of up to 32 RT values. An RT is a string of 3 to 24 characters. If you do not specify an RT, this command displays BGP IPv4 MVPN routes with any RT and the whole-match keyword does not take effect.
An RT has the following formats:
·     16-bit AS number:32-bit user-defined number. For example, 101:3. The value range for the AS number is 0 to 65535, and the value range for the user-defined number is 0 to 4294967295.
·     32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1. The value range for the user-defined number is 0 to 65535.
·     32-bit AS number:16-bit user-defined number. For example, 65536:1. The value range for the AS number is 65536 to 4294967295, and the value range for the user-defined number is 0 to 65535.
·     32-bit IPv4 address/mask length:16-bit user-defined number. For example, 192.168.122.15/24:1.
·     32-bit AS number in dotted notation:16-bit user-defined number. For example, 65535.65535:1.
whole-match: Displays routes exactly matching the specified extended community attribute. If you do not specify this keyword, the command displays routes whose extended community attributes include the specified community attribute.
If you do not specify any parameters, this command displays brief information about all BGP IPv4 MVPN routes.
# Display brief information about all BGP IPv4 MVPN routes.
<Sysname> display bgp routing-table ipv4 mvpn
 BGP local router ID is 1.1.1.2
 Total number of routes: 5
* >  Network : [1][1.1.1.1]/40
     NextHop : 0.0.0.0                                  LocPrf    : 100
     PrefVal : 32768                                    OutLabel  : NULL
     MED     : 0
     Path/Ogn: ?
* >  Network : [3][32][192.168.56.1][32][225.0.0.1][1.1.1.9]/120
     MED     : 0
     Path/Ogn: ?
* >i Network : [4][3][22][100:1][32][192.168.56.1][32][225.0.0.1][1.1.1.9][2.2.2.9]/232
     NextHop : 2.2.2.9                                  LocPrf    : 100
     MED     : 0
     Path/Ogn: ?
* >i Network : [5][32][192.168.56.1][32][225.0.0.1]/88
     MED     : 0
     Path/Ogn: ?
* >i Network : [7][100][32][192.168.56.1][32][225.0.0.1]/120
     MED     : 0
     Path/Ogn: ?
# Display information about all BGP IPv4 MVPN routes that are advertised to peer 3.3.3.9 in BGP instance default.
<Sysname> display bgp routing-table ipv4 mvpn peer 3.3.3.9 advertised-routes
* >i Network : [1][2.2.2.9]/40
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
# Display information about all BGP IPv4 MVPN routes that are received from peer 2.2.2.9 in BGP instance default.
<Sysname> display bgp routing-table ipv4 mvpn peer 2.2.2.9 received-routes
 Total number of routes: 3
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
# Display information about all BGP IPv4 MVPN routes with an extended community attribute.
<Sysname> display bgp routing-table ipv4 mvpn ext-community
     MED     : 0
     Ext-Community: <RT 1:2>
     MED     : 0
Status codes
Origin
·     i – IGP—Originated in the AS.
·     e – EGP—Learned through EGP.
·     ? – incomplete—Learned by some other means.
Total number of BGP IPv4 MVPN routes with the route distinguisher.
Network
BGP IPv4 MVPN route/route length. BGP IPv4 MVPN routes are as follows:
·     [1][Originator IP]
¡     1—Intra-AS I-PMSI A-D route to establish the inclusive tunnel.
¡     Originator IP—IP address of the route originator.
·     [2][Source AS]
¡     2—Inter-AS I-PMSI A-D route to establish the inclusive tunnel.
¡     Source AS—AS number of the source.
·     [3][Source Len][Source IP][Group Len][Group IP][Originator IP]
¡     3—S-PMSI A-D route that the multicast source-side PE sends to the receiver-side PE to establish selective tunnels.
¡     Source Len—Length of the multicast source address.
¡     Source IP—Multicast source address.
¡     Group Len—Length of the multicast group address.
¡     Group IP—Multicast group address.
·     [4][3][3Len][RD][Source Len][Source IP][Group Len][Group IP][3Originator IP][4Originator IP]
¡     4—Leaf A-D route that the receiver-side PE replies to the source-side PE to establish selective tunnels.
¡     3—S-PMSI A-D route that the source-side PE sends to the receiver-side PE to establish selective tunnels.
¡     3Len—Length of the MVPN S-PMSI A-D route, in bytes.
¡     RD—Route distinguisher.
¡     3Originator IP—Originator IP address of the MVPN S-PMSI A-D route.
¡     4Originator IP—Originator IP address of the MVPN Leaf A-D route.
·     [5][Source Len][Source IP][Group Len][Group IP]
¡     5—Source Active A-D route that advertise the multicast source.
·     [6][Source AS][Source Len][Source IP][Group Len][Group IP]
¡     6—Shared Tree Join route that the receiver-side PE sends to the RP to establish the multicast shared tree.
¡     Source AS—AS number of the PE where the RP resides.
·     [7][Source AS][Source Len][Source IP][Group Len][Group IP]
¡     7—Source Tree Join route that the receiver-side PE sends to the multicast source to build the multicast source tree.
¡     Source AS—AS number of the source-side PE.
LocPrf
PrefVal
OutLabel
Outgoing label of a route.
MED
Path/Ogn
Ext-Community
Extended community attribute.
# Display statistics for all BGP IPv4 MVPN routes
<Sysname> display bgp routing-table ipv4 mvpn statistics
# Display statistics for all BGP IPv4 MVPN routes with an extended community attribute.
<Sysname> display bgp routing-table ipv4 mvpn statistics ext-community
Total number of BGP IPv4 MVPN routes from all PEs.
# Display statistics for BGP IPv4 MVPN routes that are advertised to peer 3.3.3.9 on the public network.
<Sysname> display bgp routing-table ipv4 mvpn peer 3.3.3.9 advertised-routes statistics
 Advertised routes total: 2
#  Display statistics for BGP IPv4 MVPN routes that are received from peer 3.3.3.9 on the public network.
<Sysname> display bgp routing-table ipv4 mvpn peer 3.3.3.9 received-routes statistic
 Received routes total: 2
Table 5 Command output
Total number of routes advertised to a peer.
Total number of routes received from a peer.
# Display detailed information about BGP IPv4 MVPN route [1][1.1.1.1]/40 in BGP instance default.
<Sysname> display bgp routing-table ipv4 mvpn [1][1.1.1.1]/40
 BGP local router ID: 1.1.1.2
 BGP routing table information of [1][1.1.1.1]/40:
 Imported route.
 OutLabel        : NULL
 Ext-Community   : <RT: 100:1>
 AS-path         : (null)
 Origin          : incomplete
 Attribute value : MED 0, localpref 100, pref-val 32768
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 MVPN route type : Intra-AS I-PMSI A-D route
 Originator IP   : 1.1.1.1
Table 6 Command output
Paths
Number of routes:
·     available—Number of valid routes.
·     best—Number of optimal routes.
Network
Information about a BGP IPv4 MVPN.
LocPrf
PrefVal
OutLabel
MED
Path/Ogn
NLRI prefix.
Original nexthop
Original next hop of the route. If the route was obtained from a BGP update message, the original next hop is the next hop IP address in the message.
Ext-Community
Attribute value of the extended community. RT indicates the route target attribute.
PMSI tunnel
Information about the PMSI tunnel:
·     Flag—Flag bit value.
·     TunnelType—Tunnel type.
·     Label—Label value.
·     P2MP—Point to multiple points.
·     TunnelId—Tunnel ID.
·     ExtTunnelId—Extended tunnel ID.
AS-path
AS_PATH attribute of the route, which records the ASs the packet has passed to avoid routing loops.
Origin
Attribute value
BGP path attributes:
·     MED—MED value.
·     localpref—Local preference value.
·     pref-val—Preferred value.
·     pre—Route preference.
Current states:
IP precedence
IP precedence in the range of 0 to 7. This field displays N/A if the route does not carry this attribute.
QoS local ID
QoS local ID in the range of 1 to 4095. This field displays N/A if the route does not carry this attribute.
Traffic index
Traffic index in the range of 1 to 64. This field displays N/A if the route does not carry this attribute.
MVPN route type
Type of the BGP IPv4 MVPN route. The Intra-AS I-PMSI A-D route is an automatically discovered route that is used to establish the inclusive tunnel.
Originator IP
# Display detailed information about BGP IPv4 MVPN route [2][100]/40 in BGP instance default.
<Sysname> display bgp routing-table ipv4 mvpn [2][100]/40
 BGP routing table information of [2][100]/40:
 Imported route.
 OutLabel        : NULL
 AS-path         : (null)
 Origin          : incomplete
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 Source AS       : 100
Table 7 Command output
Paths
Number of routes:
Network
LocPrf
PrefVal
OutLabel
MED
Path/Ogn
NLRI prefix.
Original nexthop
Ext-Community
PMSI tunnel
AS-path
Origin
Attribute value
·     MED—MED value.
Current status:
IP precedence
QoS local ID
Traffic index
MVPN route type
Type of the BGP IPv4 MVPN route. The Inter-AS I-PMSI A-D route is an automatically discovered route that is used to establish the inclusive tunnel.
Source AS
Number of the AS where the route originator resides.
# Display detailed information about BGP IPv4 MVPN route [3][32][192.168.56.1][32][225.0.0.1][1.1.1.9]/120 with RD 100:1 in BGP instance default.
<Sysname> display bgp routing-table ipv4 mvpn route-distinguisher 100:1 [3][32][192.1
 BGP local router ID: 1.1.1.9
 BGP routing table information of [3][32][192.168.56.1][32][225.0.0.1][1.1.1.9]/120:
 Imported route.
 OutLabel        : NULL
 PMSI tunnel     : Flag 1, TunnelType 1, Label 0, P2MPId 1.1.1.9, Reserved 0,
                   TunnelId 1, ExtTunnelId 1.1.1.9
 AS-path         : (null)
 Origin          : incomplete
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 MVPN route type : S-PMSI A-D route
 Source Len      :32
 Source IP       : 192.168.56.1
 Group Len       : 32
 Group IP        : 225.0.0.1
 Originator IP   : 1.1.1.9
Table 8 Command output
Paths
Number of routes:
Network
LocPrf
PrefVal
OutLabel
MED
Path/Ogn
NLRI prefix.
Original nexthop
Ext-Community
PMSI tunnel
Information about a PMSI tunnel:
AS-path
Origin
Attribute value
·     MED—MED value.
Current states:
IP precedence
QoS local ID
Traffic index
MVPN route type
Type of the BGP IPv4 MVPN route. The S-PMSI A-D route is an automatically discovered route that multicast source-side PE sends to the receiver-side PE to establish selective tunnels.
Source Len
Source IP
Group Len
Group IP
Originator IP
# Display detailed information about BGP IPv4 MVPN route [4][3][22][100:1][32][192.168.56.1][32][225.0.0.2][1.1.1.9][2.2.2.9]/232 with RD 100:1 in BGP instance default.
<Sysname> display  bgp routing-table ipv4 mvpn route-distinguisher 100:1 [4][3][22][1
 BGP routing table information of [4][3][22][100:1][32][192.168.56.1][32][225.0.0.2][1.1.1.9][2.2.2.9]/232:
 Rely nexthop    : 192.168.1.2
 Original nexthop: 2.2.2.9
 OutLabel        : NULL
 Ext-Community   : <RT: 1.1.1.9:0>
                   TunnelId 2, ExtTunnelId 1.1.1.9
 AS-path         : (null)
 Origin          : incomplete
 State           : valid, internal, best
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 MVPN route type : Leaf A-D route
 RD              : 100:1
 Source Len      : 32
 Group Len       : 32
 Group IP        : 225.0.0.2
 Remote origin IP: 1.1.1.9
 Originator IP   : 2.2.2.9
Table 9 Command output
Paths
Number of routes:
Network
LocPrf
PrefVal
OutLabel
MED
Path/Ogn
NLRI prefix.
Imported route
The route is an imported route.
Original nexthop
Ext-Community
PMSI tunnel
AS-path
Origin
Attribute value
·     MED—MED value.
Current states:
IP precedence
QoS local ID
Traffic index
MVPN route type
Type of the BGP IPv4 MVPN route. The Leaf A-D route is an automatically discovered route that that receiver-side PE replies to the multicast source-side PE to establish selective tunnels.
Source Len
Source IP
Group Len
Group IP
Remote origin IP
IP address of the remote router.
Originator IP
# Display detailed information about BGP IPv4 MVPN route [5][32][192.168.56.1][32][225.0.0.1]/8 with RD 100:1 in BGP instance default.
<Sysname> display bgp routing-table ipv4 mvpn route-distinguisher 100:1 [5][32][192
 BGP routing table information of [5][32][192.168.56.1][32][225.0.0.1]/88:
 Imported route.
 OutLabel        : NULL
 AS-path         : (null)
 Origin          : incomplete
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 MVPN route type : Source Active A-D route
 Source Len      : 32
 Group Len       : 32
Table 10 Command output
Paths
Number of routes:
Network
LocPrf
PrefVal
OutLabel
MED
Path/Ogn
NLRI prefix.
Imported route
Original nexthop
Ext-Community
PMSI tunnel
AS-path
Origin
·     IGP—Originated in the AS. The origins of the routes advertised by the network command are IGP.
Attribute value
·     MED—MED value.
Current states:
IP precedence
QoS local ID
Traffic index
MVPN route type
Type of the BGP IPv4 MVPN route. The Source Active A-D route is an automatically discovered route that advertises the multicast source.
Source Len
Source IP
Group Len
Group IP
# Display detailed information about BGP IPv4 MVPN route [6][100][32][192.168.56.1][32][225.0.0.1]/120 with RD 100:1 in BGP instance default.
<Sysname> display bgp routing-table ipv4 mvpn [6][100][32][192.168.56.1][32][225.0.0.1]/120
 BGP routing table information of [6][100][32][192.168.56.1][32][225.0.0.1]/120:
 Imported route.
 OutLabel        : NULL
 AS-path         : (null)
 Origin          : incomplete
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 MVPN route type : Shared Tree Join route
 Source AS       : 100
 Source Len      : 32
 Group Len       : 32
Table 11 Command output
Paths
Number of routes:
Network
LocPrf
PrefVal
OutLabel
MED
Path/Ogn
NLRI prefix.
Imported route
Original nexthop
Ext-Community
PMSI tunnel
AS-path
Origin
Attribute value
·     MED—MED value.
Current states:
IP precedence
QoS local ID
Traffic index
MVPN route type
Type of the BGP IPv4 MVPN route. The Shared Tree Join route is a route that the receiver-side PE sends to the RP to establish the multicast shared tree.
Source AS
AS number of the PE where the multicast source resides.
Source Len
Source IP
Group Len
Group IP
# Display detailed information about BGP IPv4 MVPN route [6][100][32][192.168.56.1][32][225.0.0.2]/120 with RD 100:1 in BGP instance default.
<Sysname> display bgp routing-table ipv4 mvpn route-distinguisher 100:1 [7][100][32][192.168.56.1][32][225.0.0.2]/120
 BGP routing table information of [7][100][32][192.168.56.1][32][225.0.0.2]/120:
 OutLabel        : NULL
 Ext-Community   : <RT: 1.1.1.9:2>
 AS-path         : (null)
 Origin          : incomplete
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 MVPN route type : Source Tree Join route
 Source AS       : 100
 Source Len      : 32
 Group Len        : 32
Table 12 Command output
Paths
Number of routes:
Network
LocPrf
PrefVal
OutLabel
MED
Path/Ogn
NLRI prefix.
Imported route
Original nexthop
Ext-Community
PMSI tunnel
AS-path
Origin
Attribute value
·     MED—MED value.
Current states:
IP precedence
QoS local ID
Traffic index
MVPN route type
Type of the BGP IPv4 MVPN route. The Source Tree Join route is an automatically discovered route that the receiver-side PE sends to the multicast source to build the multicast source tree.
Source AS
Source Len
Source IP
Group Len
Group IP
# Display extended community attribute information about BGP IPv4 MVPN routewith RD 100:1 in BGP instance default.
<Sysname> display bgp routing-table ipv4 mvpn route-distinguisher 100:1 [7][100][32][192.168.56.1][32][225.0.0.2]/120 ext-community
 Ext-Community: <RT: 1.1.1.9:2>
# Display AS_PATH attribute information about BGP IPv4 MVPN routewith RD 100:1 in BGP instance default.
<Sysname> display bgp routing-table ipv4 mvpn route-distinguisher 100:1 [7][100][32][192.168.56.1][32][225.0.0.2]/120 as-path
 As-path: 100
# Display CLUSTER_LIST attribute information about BGP IPv4 MVPN routewith RD 100:1 in BGP instance default.
<Sysname> display bgp routing-table ipv4 mvpn route-distinguisher 100:1 [7][100][32][192.168.56.1][32][225.0.0.2]/120 cluster-list
 Cluster list: 80
Table 13 Command output
Paths
Number of routes:
NLRI prefix.
Ext-Community
Extended community attribute of the route.
As-path
AS_PATH attribute of the route.
Cluster list
# Display advertisement information about BGP IPv4 MVPN route [1][1.1.1.9]/40 with RD 100:1 in BGP instance default.
<Sysname> display bgp routing-table ipv4 mvpn route-distinguisher 100:1 [1][1.1.1.9]/40 advertise-info
 Paths:   1 best
 BGP routing table information of [1][1.1.1.9]/40:
    2.2.2.9
Table 14 Command output
Paths
Number of optimal routes to the destination.
Advertisement information to reach BGP IPv4 MVPN route [1][1.1.1.9]/40.
Peers to which the network has been advertised.
display multicast-vpn c-multicast routing-table
Use display multicast-vpn c-multicast routing-table to display C-multicast A-D routing entries.
display multicast-vpn vpn-instance vpn-instance-name c-multicast routing-table [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | outgoing-interface { exclude | include | match } interface-type interface-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
group-address: Specifies a multicast group by its address in the range of 224.0.0.0 to 239.255.255.255. If you do not specify a multicast group, this command displays the C-multicast A-D routing information for all multicast groups.
source-address: Specifies a multicast source by its address.
mask-length: Specifies a mask length of the specified multicast source address or multicast group address. The value range for this argument is 0 to 32, and the default is 32.
mask: Specifies a subnet mask of the specified multicast source address or multicast group address. The default is 255.255.255.255.
outgoing-interface { exclude | include | match } interface-type interface-number: Specifies an outgoing interface. If you do not specify an outgoing interface, this command displays information about C-multicast A-D routing entries for all outgoing interfaces. If you specify an outgoing interface, whether this command displays C-multicast A-D routing entries that include the specified outgoing interface depends on the following keyword:
·     exclude: Specifies C-multicast A-D routing entries that do not include the outgoing interface.
·     include: Specifies C-multicast A-D routing entries that include the outgoing interface.
·     match: Specifies C-multicast A-D routing entries that include only the outgoing interface.
# Display C-multicast A-D routing information for MVPN instance mvpn.
<Sysname> display multicast-vpn vpn-instance mvpn c-multicast routing-table
 Total 0 (*, G) entry; 2 (S, G) entries
(172.168.0.12, 227.0.0.1)
   CreateTime: 02:54:43
   Tunnel Information: Tunnel1
   Leaf neighbors information:
   Total number of leaf neighbors: 2
   1: 13.1.1.2
   2: 14.1.1.2
(172.168.0.12, 227.0.0.2)
   Tunnel Information: NULL
   1: 13.1.1.2
   2: 14.1.1.2
Table 15 Command output
Total number of (*, G) and (S, G) entries in the C-multicast routing table.
CreateTime
Time that has elapsed since the (*, G) or (S, G) entry was created.
Tunnel Information
RSVP-TE tunnel information. If the tunnel has not been successfully established, this field displays NULL.
Information of the neighbors that have replied with a Leaf A-D route.
Number of neighbors that have replied with a Leaf A-D route.
display multicast-vpn data-group receive
Use display multicast-vpn data-group receive to display information about data groups for IPv4 multicast transmission that are received in a VPN instance.
display multicast-vpn vpn-instance vpn-instance-name data-group receive [ brief | [ active | group group-address | sender source-address | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] * ]
brief: Displays brief information. If you do not specify this keyword, the command displays detailed information.
active: Specifies data groups that have joined the data MDT.
group group-address: Specifies a data group by its IP address in the range of 224.0.1.0 to 239.255.255.255.
sender source-address: Specifies an MVPN source interface by its IP address.
vpn-source-address: Specifies a multicast source address of the specified VPN instance.
vpn-group-address: Specifies a multicast group address of the specified VPN instance. The value range for this argument is 224.0.0.0 to 239.255.255.255.
# Display detailed information about data groups for IPv4 multicast transmission that are received in VPN instance mvpn.
<Sysname> display multicast-vpn vpn-instance mvpn data-group receive
MVPN data-group information received by VPN instance: mvpn
Total 2 data-groups for 8 entries
Total 2 data-groups and 8 entries matched
Data-group: 226.1.1.0   Reference count: 4   Active count: 2
  Sender: 172.100.1.1   Active count: 1
    (192.6.1.5, 239.1.1.1)       expires: 00:03:10 active
    (192.6.1.5, 239.1.1.158)     expires: 00:03:10
  Sender:  181.100.1.1, active count: 1
    (195.6.1.2, 239.1.2.12)      expires: 00:03:10 active
    (195.6.1.2, 239.1.2.197)     expires: 00:03:10
Data-group: 229.1.1.0   Reference count: 4   Active count: 2
  Sender: 185.100.1.1   Active count: 1
    (198.6.1.5, 239.1.3.62)      expires: 00:03:10 active
    (198.6.1.5, 225.1.1.109)     expires: 00:03:10
  Sender: 190.100.1.1   Active count: 1
    (200.6.1.2, 225.1.4.80)      expires: 00:03:10 active
    (200.6.1.2, 225.1.4.173)     expires: 00:03:10
# Display brief information about data groups for IPv4 multicast transmission that are received in VPN instance mvpn.
<Sysname> display multicast-vpn vpn-instance mvpn data-group receive brief
Table 16 Command output
Information about data groups for IPv4 multicast transmission that are received in VPN instance mvpn.
A total of 2 data groups, associated with 8 (S, G) entries.
A total of 2 matching data groups, associated with 8 (S, G) entries.
Data-group
IP address of the received data group.
Sender
BGP peer address of the PE device that sent the data group.
Reference count
Number of (S, G) entries that use the data group in the VPN instance.
Active count
Number of active (S, G) entries (entries with active receivers) that use the data group in the VPN instance.
expires
Remaining time for the (S, G) entry that uses the data group in the VPN instance.
display multicast-vpn data-group send
Use display multicast-vpn data-group send to display information about data groups for IPv4 multicast transmission that are sent in a VPN instance.
display multicast-vpn vpn-instance vpn-instance-name data-group send [ group group-address | reuse interval | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] *
reuse interval: Specifies an interval during which data group reuses occur, in the range of 1 to 2147483647 seconds.
# Display information about data groups for IPv4 multicast transmission that are sent in VPN instance mvpn.
<Sysname> display multicast-vpn vpn-instance mvpn data-group send
MVPN data-group information sent by VPN instance: mvpn
Total 2 data-groups for 6 entries
Total 2 data-groups and 6 entries matched
  Reference count of 226.1.1.0: 3
    (192.6.1.5, 239.1.1.1)                  switch time: 00:00:21
    (192.6.1.5, 239.1.1.158)                switch time: 00:00:21
    (192.6.1.5, 239.1.2.50)                 switch time: 00:00:05
  Reference count of 226.1.1.1: 3
    (192.6.1.2, 225.1.1.1)                  switch time: 00:00:21
    (192.6.1.2, 225.1.2.50)                 switch time: 00:00:05
    (192.6.1.5, 239.1.1.159)                switch time: 00:00:21
# Display reuse information about data groups for IPv4 multicast transmission that are sent in VPN instance mvpn within 30 seconds.
<Sysname> display multicast-vpn vpn-instance mvpn data-group send reuse 30
Total 2 data-groups for 3 entries
Total 2 data-groups and 3 entries matched
  Reuse count of 226.1.1.0: 1
  Reuse count of 226.1.1.1: 1
  Reuse count of 226.1.1.2: 1
Table 17 Command output
Information about data groups for IPv4 multicast transmission that are sent in VPN instance mvpn.
A total of 2 data groups, associated with 6 (S, G) entries.
A total of 2 matching data groups, associated with 6 (S, G) entries.
switch time
Switchover time of the (S, G) entry that uses the data group in the VPN instance.
Number of times that the data group is reused during the specified length of time.
display multicast-vpn default-group
Use display multicast-vpn default-group to display information about default groups for IPv4 multicast transmission.
display multicast-vpn [ vpn-instance vpn-instance-name ] default-group { local | remote }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about default groups of all VPN instances for IPv4 multicast transmission.
local: Specifies local default groups for IPv4 multicast transmission.
remote: Specifies remote default groups for IPv4 multicast transmission.
# Display information about the local default group for IPv4 multicast transmission in each VPN instance.
<Sysname> display multicast-vpn default-group local
MVPN local default-group information of VPN instance mvpna:
 Group address    Source address   Interface
 239.1.1.1        1.1.1.1          MTunnel0
MVPN local default-group information of VPN instance mvpnb:
 239.2.1.1        1.1.1.1          MTunnel1
MVPN local default-group information of VPN instance mvpnc:
 239.3.1.1        1.1.1.1          MTunnel2
# Display information about the remote default group for IPv4 multicast transmission in each VPN instance.
<Sysname> display multicast-vpn default-group remote
MVPN remote default-group information:
 Group address   Source address  Next hop         VPN instance
 239.1.1.1       1.2.0.1         1.2.0.1          a
 239.1.1.1       1.2.0.2         1.2.0.2          a
 239.1.1.1       1.2.0.3         1.2.0.3          a
 239.1.1.2       1.2.0.1         1.2.0.1          b
 239.1.1.2       1.2.0.2         1.2.0.2          b
 239.1.1.3       1.2.0.1         1.2.0.1          -
Table 18 Command output
Group address
IP address of the default group for IPv4 multicast transmission.
Source address
IP address of the MVPN source interface, which is used by the MTI as the source address to encapsulate multicast packets for the VPN instance.
MTI interface.
Next hop
VPN instance
VPN instance to which the default group belongs.
display multicast-vpn ipv6 data-group receive
Use display multicast-vpn ipv6 data-group receive to display information about data groups for IPv6 multicast transmission that are received in a VPN instance.
display multicast-vpn vpn-instance vpn-instance-name ipv6 data-group receive [ brief | [ active | group group-address | sender source-address | vpn-source-address [ mask-length ] | vpn-group-address [ mask-length ] ] * ]
group group-address: Specifies a data group by its address in the range of 224.0.1.0 to 239.255.255.255.
sender source-address: Specifies an MVPN source interface by its address.
vpn-source-address: Specifies an IPv6 multicast source address of the specified VPN instance.
vpn-group-address: Specifies an IPv6 multicast group address of the specified VPN instance. The value range for this argument is FFxy::/16, where "x" and "y" represent any hexadecimal numbers from 0 to F.
mask-length: Specifies a mask length of the specified IPv6 multicast source address or IPv6 multicast group address. For the IPv6 multicast source address, the value range for this argument is 8 to 128, and the default is 128. For the IPv6 multicast group address, the value range for this argument is 0 to 128, and the default is 128.
# Display detailed information about data groups for IPv6 multicast transmission that are received in VPN instance mvpn.
<Sysname> display multicast-vpn vpn-instance mvpn ipv6 data-group receive
(192::1, ff1e::1)
(192::1, ff1e::2)
expires: 00:03:10
(192::2, ff1e::11)
(192::2, ff1e::12)
expires: 00:03:10
(192::6, ff1e::15)
(192::6, ff1e::16)
expires: 00:03:10
(192::11, ff1e::21)
(192::11, ff1e::22)
expires: 00:03:10
# Display brief information about data groups for IPv6 multicast transmission that are received in VPN instance mvpn.
<Sysname> display multicast-vpn vpn-instance mvpn ipv6 data-group receive brief
Table 19 Command output
Information about data groups for IPv6 multicast transmission that are received in VPN instance mvpn.
A total of 2 matching data groups, associated with 8 matching (S, G) entries.
Data-group
Sender
Reference count
Active count
Number of active (S, G) entries (entries with receivers) that use the data group in the VPN instance.
expires
display multicast-vpn ipv6 data-group send
Use display multicast-vpn ipv6 data-group send to display information about data groups for IPv6 multicast transmission that are sent in a VPN instance.
display multicast-vpn vpn-instance vpn-instance-name ipv6 data-group send [ group group-address | reuse interval | vpn-source-address [ mask-length ] | vpn-group-address [ mask-length ] ] *
mask-length: Specifies a mask length of the specified IPv6 multicast source or IPv6 multicast group address. For the IPv6 multicast source address, the value range for this argument is 8 to 128, and the default is 128. For the IPv6 multicast group address, the value range for this argument is 0 to 128, and the default is 128.
# Display information about data groups for IPv6 multicast transmission that are sent in VPN instance mvpn.
<Sysname> display multicast-vpn vpn-instance mvpn ipv6 data-group send
(192::1, ff1e::1)
(192::1, ff1e::2)
(192::1, ff1e::3)
(192::2, ff1e::4)
(192::2, ff1e::5)
(192::2, ff1e::6)
# Display reuse information about data groups for IPv6 multicast transmission that are sent in VPN instance mvpn within 30 seconds.
<Sysname> display multicast-vpn vpn-instance mvpn ipv6 data-group send reuse 30
Table 20 Command output
Information about data groups for IPv6 multicast transmission that are sent in VPN instance mvpn.
A total of 2 matching data groups, associated with 6 matching (S, G) entries.
switch time
display multicast-vpn ipv6 default-group
Use display multicast-vpn ipv6 default-group to display information about default groups for IPv6 multicast transmission.
display multicast-vpn [ vpn-instance vpn-instance-name ] ipv6 default-group { local | remote }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about default groups of all VPN instances for IPv6 multicast transmission.
local: Specifies local default groups for IPv6 multicast transmission.
remote: Specifies remote default groups for IPv6 multicast transmission.
# Display information about the local default group for IPv6 multicast transmission in each VPN instance.
<Sysname> display multicast-vpn ipv6 default-group local
MVPN local default-group information:
Group address    Source address   Interface     VPN instance
239.1.1.1        1.1.1.1          MTunnel0      mvpna
239.2.1.1        1.1.1.1          MTunnel1      mvpnb
239.3.1.1        --               MTunnel2      mvpnc
# Display information about the remote default group for IPv6 multicast transmission in each VPN instance.
<Sysname> display multicast-vpn ipv6 default-group remote
Table 21 Command output
Group address
IP address of the default group for IPv6 multicast transmission.
Source address
IP address of the MVPN source interface, which is used by the MTI as the source address to encapsulate IPv6 multicast packets of the VPN instance.
MTI interface.
Next hop
VPN instance
display multicast-vpn neighbor
Use display multicast-vpn neighbor to display information about RSVP-TE tunnel neighbors.
display multicast-vpn vpn-instance vpn-instance-name neighbor [ interface tunnel number ]
interface tunnel number: Specifies an existing tunnel interface by its number.
# Display information about RSVP-TE tunnel neighbors in VPN instance mvpn.
<Sysname> display multicast-vpn vpn-instance mvpn neighbor
Total 1 Selective Tunnels in using
Total 1 Selective Tunnels in creating
Inclusive Tunnel: Tunnel8
Tunnel Identifier: RSVP P2MP <0x01010101, 0x0, 0x8, 0x01010101>
Neighbor        State       UpDowntime
10.1.1.2        Up          02:50:49
20.1.1.2        Up          02:49:39
30.1.1.2        Down        02:00:39
Selective Tunnel: Tunnel2
Tunnel Identifier: RSVP P2MP <0x01010101, 0x0, 0x2, 0x01010101>
Selective Tunnel: NULL
Tunnel Identifier: unknow
Table 22 Command output
Number of selective tunnels in use.
Number of selective tunnels being created.
Inclusive Tunnel
Name of the inclusive tunnel. If the tunnel is being created, this field displays NULL.
Selective Tunnel
Name of the selective tunnel. If the tunnel is being created, this field displays NULL.
Tunnel Identifier
Tunnel information, including the tunnel type and tunnel identifier. Only RSVP P2MP tunnels are supported in the current software version. If the tunnel is being created, this field displays unknow.
Neighbor
IP address of the neighbor.
Neighbor status:
·     Up—The neighbor is up.
·     Down—The neighbor is down.
UpDowntime
Length of time that the neighbor has been up or down.
dscp
Use dscp to set the DSCP value for outgoing data group switchover packets.
Use undo dscp to restore the default.
dscp dscp-value
undo dscp
The DSCP value is 48 for outgoing data group switchover packets.
MVPN view
dscp-value: Specifies a DSCP value in the range of 0 to 63.
The DSCP value determines the packet transmission priority. A greater DSCP value represents a higher priority.
# Set the DSCP value to 63 for outgoing data group switchover packets.
[Sysname-mvpn-mvpn] dscp 63
inclusive-tunnel dynamic
Use inclusive-tunnel dynamic to enable dynamic inclusive tunnel creation.
Use undo inclusive-tunnel dynamic to restore the default.
Dynamic inclusive tunnel creation is disabled.
# In MVPN IPv4 address family view of VPN instance mvpn, enable dynamic inclusive tunnel creation.
[Sysname] multicast-vpn vpn-instance mvpn mode rsvp-te
[Sysname-mvpn-mvpn-ipv4] inclusive-tunnel dynamic
ipv6 multicast extranet select-rpf
Use ipv6 multicast extranet select-rpf to configure an IPv6 MVPN extranet RPF selection policy.
Use undo ipv6 multicast extranet select-rpf to delete an IPv6 MVPN extranet RPF selection policy.
ipv6 multicast extranet select-rpf [ vpn-instance vpn-instance-name ] { source ipv6-source-address prefix-length | group ipv6-group-address  prefix-length }*
undo ipv6 multicast extranet select-rpf [ vpn-instance vpn-instance-name ] { source ipv6-source-address prefix-length | group ipv6-group-address  prefix-length }*
No IPv6 MVPN extranet RPF selection policies are configured.
IPv6 MRIB view
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the IPv6 multicast source belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. The PIM routing entry will select this VPN instance for the upstream RPF neighbor. If the multicast source belongs to the public network, do not specify this option.
source ipv6-source-address: Specifies a source address in the policy, which can an IPv6 multicast source address or the address of the RP designated to multicast groups. If you do not specify this option, all multicast traffic that matches the multicast group in the policy in the source VPN instance will be directed to the receiver VPN instance.
group ipv6-group-address: Specifies an IPv6 multicast group address in the policy. The address range is FFxy::/16 (excluding FFx1::/16 and FFx2::/16), where "x" and "y" represent any hexadecimal numbers in the range of 0 to F. If you do not this option, all multicast traffic that matches the source address in the policy in the source VPN instance will be directed to the receiver VPN instance.
prefix-length: Specifies an IPv6 address prefix length. For an IPv6 multicast group address, the value range for this argument is 8 to 128. For an IPv6 multicast source address, the value range for this argument is 0 to 128.
MVPN extranet RPF routing policies are used for multicast transmission when multicast sources and receivers are located in different VPNs.
The IPv6 PIM modes in the source VPN instance and the receiver VPN instance must be the same. Only IPv6 PIM-SM and IPv6 PIM-SSM are supported.
As a best practice, if IPv6 PIM-SM is used for MVPN extranet solution to implement inter-VPN multicast transmission for multiple IPv6 multicast groups, configure a dedicated RP for these groups. In addition, specify the address of the RP as the source address in RPF selection policies.
In IPv6 PIM-SM mode, you can configure only one RPF selection policy for a multicast group in a VPN instance.
To implement source-specific RPF selection in MVPN extranet, you must configure two MVPN extranet RPF routing policies as follows:
·     In one policy, specify the address of the RP designated to the multicast group that requires inter-VPN multicast communication as the source address.
·     In the other policy, specify the multicast source in the source VPN instance as the source address.
To implement source-and-group-specific RPF selection in MVPN extranet, you must configure two MVPN extranet RPF routing policies as follows:
·     In one policy, specify the address of the RP designated to the multicast group as the source address, and specify the multicast group.
·     In the other policy, specify the multicast source in the source VPN instance as the source address, and specify the multicast group.
·     Make sure the multicast groups in the two policies are the same to avoid inter-VPN multicast transmission failure.
If an IPv6 MVPN extranet RPF selection policy with only the multicast group address specified is configured in the receiver VPN instance, the intra-VPN multicast traffic transmission will be interrupted.
IPv6 multicast source addresses in different MVPN extranet RPF routing policies cannot be the same, but they can be overlapped with each other. The same restriction applies to the IPv6 multicast group addresses in different MVPN extranet RPF routing policies. If multiple routing policies exist for an (S, G) entry, the device selects the policy in which the IPv6 multicast group address has the longest prefix. If multiple policies have the same prefix length, the device selects the policy in which the IPv6 multicast source address has the longest prefix.
# Configure an IPv6 MVPN extranet RPF selection policy to direct multicast traffic from VPN instance vpn-source to VPN instance vpn-receiver.
[Sysname] ipv6 multicast routing vpn-instance vpn-receiver
[Sysname-mrib6-vpn-receiver] ipv6 multicast extranet select-rpf vpn-instance vpn-source source 5555::55 64
[Sysname-mrib6-vpn-receiver] ipv6 multicast extranet select-rpf vpn-instance vpn-source source 1:1:1::1 64
log data-group-reuse
Use log data-group-reuse to enable data group reuse logging.
Use undo log data-group-reuse to disable data group reuse logging.
Data group reuse logging is disabled.
# In MVPN IPv4 address family view of VPN instance mvpn, enable data group reuse logging.
[Sysname-mvpn-mvpn-ipv4] log data-group-reuse
Use multicast extranet select-rpf to configure an IPv4 MVPN extranet RPF selection policy.
Use undo multicast extranet select-rpf to delete an IPv4 MVPN extranet RPF selection policy.
multicast extranet select-rpf [ vpn-instance vpn-instance-name ] { source source-address { mask | mask-length } | group group-address { mask | mask-length } } *
undo multicast extranet select-rpf [ vpn-instance vpn-instance-name ] { source source-address { mask | mask-length } | group group-address { mask | mask-length } } *
No IPv4 MVPN extranet RPF selection policies are configured.
MRIB view
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the multicast source belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. The PIM routing entry will select this VPN instance for the upstream RPF neighbor. If the multicast source belongs to the public network, do not specify this option.
source source-address: Specifies a source address in the policy, which can a multicast source address or the address of the RP designated to multicast groups. If you do not specify this option, all multicast traffic that matches the multicast group in the policy in the source VPN instance will be directed to the receiver VPN instance.
group group-address: Specifies a multicast group address in the policy. The address range is 224.0.0.0 to 239.255.255.255. If you do not this option, all multicast traffic that matches the source address in the policy in the source VPN instance will be directed to the receiver VPN instance.
mask: Specifies a subnet mask for the multicast source address or the multicast group address.
mask-length: Specifies a mask length for the multicast source address or the multicast group address. For a multicast group address, the value range for this argument is 4 to 32. For a multicast source address, the value range for this argument is 0 to 32.
The PIM modes in the source VPN instance and the receiver VPN instance must be the same. Only PIM-SM and PIM-SSM are supported.
As a best practice, if PIM-SM is used for MVPN extranet solution to implement inter-VPN multicast transmission for multiple multicast groups, configure a dedicated RP for these groups. In addition, specify the address of the RP as the source address in RPF selection policies.
In PIM-SM mode, you can configure only one RPF selection policy for a multicast group in a VPN instance.
If an MVPN extranet RPF selection policy with only the multicast group address specified is configured in the receiver VPN instance, the intra-VPN multicast traffic transmission will be interrupted.
Multicast source addresses in different MVPN extranet RPF routing policies cannot be the same, but they can be overlapped with each other. The same restriction applies to the multicast group addresses in different MVPN extranet RPF routing policies. If multiple routing policies exist for an (S, G) entry, the device selects the policy in which the multicast group address has the longest mask. If multiple policies have the same mask length, the device selects the policy in which the multicast source address has the longest mask.
# Configure an IPv4 MVPN extranet RPF selection policy to direct multicast traffic from VPN instance vpn-source to VPN instance vpn-receiver.
[Sysname] multicast routing vpn-instance vpn-receiver
[Sysname-mrib-vpn-receiver] multicast extranet select-rpf vpn-instance vpn-source source 192.168.10.0 24
[Sysname-mrib-vpn-receiver] multicast extranet select-rpf vpn-instance vpn-source source 1.1.1.1 24
multicast rpf-proxy-vector compatible
Use multicast rpf-proxy-vector compatible to enable RPF vector compatibility.
Use undo multicast rpf-proxy-vector compatible to disable RPF vector compatibility.
RPF vector compatibility is disabled.
This command enables the device to work with other manufacturers' products on the RPF vector. You must configure this command on all H3C routers on the public network for multicast VPN inter-AS option B.
# Enable RPF vector compatibility.
[Sysname] multicast rpf-proxy-vector compatible
multicast-vpn
Use multicast-vpn to create an MVPN for a VPN instance and enter its view, or enter the view of the existing MVPN.
Use undo multicast-vpn to delete configurations in MVPN view for a VPN instance.
multicast-vpn vpn-instance vpn-instance-name mode { mdt | rsvp-te }
undo multicast-vpn vpn-instance vpn-instance-name
No MVPN exists.
mode: Specifies the mode of the MVPN.
mdt: Specifies the MDT mode.
rsvp-te: Specifies the RSVP-TE mode.
# Create an MDT-based MVPN for VPN instance mvpn and enter MVPN view.
[Sysname] multicast-vpn vpn-instance mvpn mode mdt
[Sysname-mvpn-mvpn]
mvpn-advertise-rt-import
Use mvpn-advertise-rt-import to add attributes Source AS Extended Community and RF Route Import Extended Community to routes that are sent to the BGP IPv4 MVPN neighbors.
Use undo mvpn-advertise-rt-import to delete attributes Source AS Extended Community and RF Route Import Extended Community to routes that are sent to BGP IPv4 MVPN neighbors.
Attributes Source AS Extended Community and RF Route Import Extended Community are not included in routes that are sent to BGP IPv4 MVPN neighbors.
BGP IPv4 MVPN address family view
Before you execute this command, you must establish BGP IPv4 MVPN neighbor relationship and specify BGP MVPN peers.
The following BGP extended community attributes are used to identify the local device as the route originator:
·     Source AS Extended Community—Carries the number of AS where the MVPN source resides. The format of this attribute is 32-bit AS number:0, for example, 100:0.
·     VRF Route Import Extended Community—Carries Router ID of the local BGP instance and the VPN instance to which the BGP VPNv4 route belongs. The format of the attribute is 32-bit router address:VPN instance index, for example, 192.168.122.15:1.
# Add attributes Source AS Extended Community and VRF Route Import Extended Community to routes sent to the BGP IPv4 MVPN neighbors.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] mvpn-advertise-rt-import
policy vpn-target
Use policy vpn-target to enable route target filtering for BGP MVPN routes. Only BGP MVPN routes of which the export route target attribute matches the local import route target attribute are added to the BGP MVPN routing table.
Use undo policy vpn-target to disable route target filtering for BGP MVPN routes.
policy vpn-target
Route target filtering is enabled for BGP MVPN routes.
If the device needs to save all BGP MVPN routes, use the undo policy vpn-target command to disable route target filtering for BGP MVPN routes.
# Disable route target filtering for BGP IPv4 MVPN routes.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 mvpn
[Sysname-bgp-default-mvpn] undo policy vpn-target
rpf proxy vector
Use rpf proxy vector to enable the RPF vector feature.
Use undo rpf proxy vector to disable the RPF vector feature.
rpf proxy vector
The RPF vector feature is disabled.
MRIB view
This feature enables PE devices to carry the RPF vector information in PIM join messages for other devices to perform RPF check on the messages.
You must enable this feature on PE devices (excluding the PE devices that do not have attached receivers) when you configure multicast VPN inter-AS option B.
Only the configuration made in MRIB view of a VPN instance takes effect. The configuration made in MRIB view on the public network does not take effect.
This command is available only for an MDT-based MVPN.
# Enable the RPF vector feature for VPN instance mvpn.
[Sysname] multicast routing vpn-instance mvpn mode mdt
[Sysname-mrib-mvpn] rpf proxy vector
selective-tunnel delay
Use selective-tunnel delay to set the tunnel switchover delay.
Use undo selective-tunnel delay to restore the default.
selective-tunnel delay delay
The tunnel switchover delay is 3 seconds.
delay: Specifies the tunnel switchover delay, in the range of 1 to 60 seconds.
# In MVPN IPv4 address family view of VPN instance mvpn, set the tunnel switchover delay time to 20 seconds.
[Sysname-mvpn-mvpn] address-family ipv4
[Sysname-mvpn-mvpn-ipv4] selective-tunnel delay 20
selective-tunnel dynamic
Use selective-tunnel dynamic to enable dynamic selective tunnel creation.
Use undo selective-tunnel dynamic to restore the default.
selective-tunnel dynamic [ acl ipv4-acl-number ]
Dynamic selective tunnel creation is disabled.
acl ipv4-acl-number: Specifies an IPv4 advanced ACL by its number in the range of 3000 to 3999. The source and destination keywords in ACL rules are used to match the multicast source and multicast group addresses, respectively. If you do not specify an ACL, multicast packets of all (S, G) entries can trigger a tunnel switchover.
When you reference an ACL, follow these restrictions and guidelines:
·     If the ACL does not exist or contains no rules, multicast packets of all (S, G) entries can trigger a tunnel switchover.
·     An ACL rule containing the vpn-instance vpn-instance option does not take effect.
# In MVPN IPv4 address family view of VPN instance mvpn, enable dynamic selective tunnel creation.
[Sysname-mvpn-mvpn-ipv4] selective-tunnel dynamic
source
Use source to specify an MVPN source interface.
Use undo source to restore the default.
source interface-type interface-number
undo source
No MVPN source interface is specified.
MVPN IPv6 address family view
For the PE device to obtain correct routing information, you must specify the interface used for establishing BGP peer relationship as the MVPN source interface.
For an MVPN that transmits both IPv4 and IPv6 multicast packets, you must specify the same MVPN source interface in MVPN IPv4 and IPv6 address family views.
# In MVPN IPv4 address family view and IPv6 address family view of VPN instance mvpn, specify Loopback 1 as the MVPN source interface. (Loopback 1 is the source interface used for establishing BGP peer relationship.)
[Sysname-mvpn-mvpn-ipv4] source loopback 1
[Sysname-mvpn-mvpn-ipv4] quit
[Sysname-mvpn-mvpn] address-family ipv6
[Sysname-mvpn-mvpn-ipv6] source loopback 1
