- 18-High Availability Command Reference
- 01-Ethernet OAM commands
- 02-CFD commands
- 03-DLDP commands
- 04-S-Trunk commands
- 05-VRRP commands
- 06-VSRP commands
- 07-BFD commands
- 08-Track commands
- 09-Process placement commands
- 10-Interface backup commands
- 11-Interface collaboration commands
- 12-Error code detection commands
- 13-Monitor Link commands
00-Preface | 109.40 KB |
Preface
This command reference covers high availability commands for managing failure detection and failover.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
