12-EVPN Configuration Guide
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Configure & DeployConfiguration GuidesH3C MSR5680-X3 Router Configuration Guides-R9141-6W10012-EVPN Configuration Guide
02-EVPN VXLAN configuration
02-EVPN VXLAN configuration 970.54 KB
EVPN VXLAN overview·· 1
EVPN network model 1
Configuration automation· 2
Assignment of traffic to VXLANs· 2
Traffic from the local site to a remote site· 2
Traffic from a remote site to the local site· 2
Layer 2 forwarding· 2
MAC learning· 2
Unicast 3
Flood· 4
Centralized EVPN gateway deployment 5
Distributed EVPN gateway deployment 5
About distributed EVPN gateway deployment 5
Symmetric IRB· 6
Asymmetric IRB· 9
EVPN VXLAN multihoming· 10
About EVPN VXLAN multihoming· 10
DF election· 11
Split horizon· 13
Redundancy mode· 13
IP aliasing· 13
ARP and ND flood suppression· 14
MAC mobility· 15
Configuring EVPN VXLAN·· 1
Restrictions and guidelines: EVPN VXLAN configuration· 1
EVPN VXLAN tasks at a glance· 1
Configuring a VXLAN on a VSI 2
Configuring an EVPN instance· 3
About EVPN instance configuration· 3
Configuring an EVPN instance created in VSI view· 3
Configuring EVPN VXLAN multihoming· 3
Restrictions and guidelines for EVPN VXLAN multihoming· 3
Assigning an ESI to an interface· 4
Configuring the DF election algorithm·· 4
Enabling AC state-based DF election· 5
Setting the DF election delay· 6
Enabling non-revertive mode for preference-based DF election· 6
Configuring ES route advertisement delay· 7
Disabling advertisement of EVPN multihoming routes· 7
Enabling the device to ignore the Ethernet tag when advertising Ethernet auto-discovery routes and MAC/IP advertisement routes· 8
Enabling the device to monitor the BGP peer status of another local edge device· 8
Configuring BGP EVPN routes· 9
Restrictions and guidelines for BGP EVPN route advertisement 9
Enabling BGP to advertise BGP EVPN routes· 9
Configuring route selection and advertisement settings· 10
Preferring routes with an IPv6 next hop during optimal route selection· 12
Configuring routing policy-based recursive lookup· 12
Maintaining BGP sessions· 13
Mapping ACs to a VSI 14
Mapping a Layer 3 interface to a VSI 14
Configuring a centralized EVPN gateway· 14
Configuring a distributed EVPN gateway· 15
Restrictions and guidelines for distributed EVPN gateway configuration· 15
Prerequisites for distributed EVPN gateway configuration· 15
Configuring the traffic forwarding mode for EVPN VXLAN· 15
Configuring a VSI interface· 16
Configuring an L3 VXLAN ID for a VSI interface· 17
Configuring IP prefix route advertisement 19
Configuring BGP route exchange between the public instance and VPN instances· 20
Configuring the EVPN global MAC address· 22
Enabling a distributed EVPN gateway to send RA messages over VXLAN tunnels· 23
Enabling the device to advertise ARP information for the distributed EVPN gateway interfaces through MAC/IP advertisement routes· 23
Managing remote MAC address entries and remote ARP learning· 24
Disabling remote MAC address learning and remote ARP learning· 24
Disabling MAC address advertisement 24
Enabling MAC mobility event suppression· 25
Disabling learning of MAC addresses from ARP or ND information· 26
Disabling ARP information advertisement 26
Enabling ND information advertisement 27
Disabling the VSI interface on a centralized EVPN gateway from learning ARP or ND information across subnets  27
Enabling ARP mobility event suppression· 28
Enabling ARP request proxy· 29
Enabling ND mobility event suppression· 30
Configuring BGP EVPN route redistribution and advertisement 32
Redistributing MAC/IP advertisement routes into BGP unicast routing tables· 32
Setting the metric of BGP EVPN routes added to a VPN instance's routing table· 33
Enabling BGP EVPN route advertisement to the local site· 33
Disabling flooding for a VSI 34
Enabling ARP or ND flood suppression· 34
Enabling SNMP notifications for EVPN· 35
Verifying and maintaining EVPN VXLAN· 35
Displaying EVPN running status and statistics· 35
Verifying MAC address information and ARP and ND information· 37
Advertising suppressed MAC addresses and ARP/ND information for suppressed IP addresses· 37
EVPN VXLAN configuration examples· 38
Example: Configuring a centralized IPv4 EVPN gateway· 38
Example: Configuring distributed IPv4 EVPN gateways in symmetric IRB mode· 46
Example: Configuring distributed IPv6 EVPN gateways in symmetric IRB mode· 55
EVPN VXLAN overview
EVPN VXLAN uses EVPN routes for VXLAN tunnel establishment and assignment and MAC reachability information advertisement in the control plane and uses VXLAN for forwarding in the data plane.
EVPN network model
As shown in Figure 1, EVPN uses the VXLAN technology for traffic forwarding in the data plane. The transport edge devices assign user terminals to different VXLANs, and then forward traffic between sites for user terminals by using VXLAN tunnels. The transport edge devices are VXLAN tunnel endpoints (VTEPs). They can be servers that host VMs or independent network devices.
Supported user terminals include PCs, wireless terminals, and VMs on servers.
This document uses VMs as examples to describe the mechanisms of EVPN. The mechanisms do not differ between different kinds of user terminals.
A VTEP uses ESs, VSIs, and VXLAN tunnels to provide VXLAN services:
·     Ethernet segment (ES)—An ES is a link that connects a site to a VTEP. Each ES is uniquely identified by an Ethernet segment identifier (ESI).
·     VSI—A virtual switch instance is a virtual Layer 2 switched domain. Each VSI provides switching services only for one VXLAN. VSIs learn MAC addresses and forward frames independently of one another. User terminals in different sites have Layer 2 connectivity if they are in the same VXLAN. A VXLAN is identified by a 24-bit VXLAN ID which is also called the virtual network identifier (VNI). A VXLAN corresponds to an EVPN instance.
·     VXLAN tunnel—Logical point-to-point tunnels between VTEPs over the transport network. Each VXLAN tunnel can trunk multiple VXLANs.
All VXLAN processing is performed on VTEPs. The ingress VTEP encapsulates VXLAN traffic in the VXLAN, outer UDP, and outer IP headers, and forwards the traffic through VXLAN tunnels. The egress VTEP removes the VXLAN encapsulation and forwards the traffic to the destination. Transport network devices (for example, the P device in Figure 1) forward VXLAN traffic only based on the outer IP header of VXLAN packets.
Figure 1 EVPN network model
If EVPN is used for Layer 2 forwarding, VTEPs use the following BGP EVPN routes to discover VTEP neighbors, establish VXLAN tunnels, and assign the tunnels to VXLANs:
·     IMET route—VTEPs advertise their VXLAN IDs through IMET routes. If two VTEPs have the same VXLAN ID, they automatically establish a VXLAN tunnel and assign the tunnel to the VXLAN.
·     MAC/IP advertisement route—VTEPs advertise local MAC addresses and VXLAN IDs through MAC/IP advertisement routes. If two VTEPs have the same VXLAN ID, they automatically establish a VXLAN tunnel and assign the tunnel to the VXLAN.
If EVPN is used for Layer 3 forwarding, VTEPs use the following BGP EVPN routes to discover VTEP neighbors, establish VXLAN tunnels, and assign the tunnels to VXLANs:
·     IMET route—VTEPs advertise the VXLAN IDs they have through IMET routes. If two VTEPs have the same VXLAN ID, they automatically establish a VXLAN tunnel and assign the tunnel to the VXLAN.
·     MAC/IP advertisement route and IP prefix advertisement route—In the EVPN gateway deployment, VTEPs advertise MAC/IP advertisement routes or IP prefix advertisement routes which carry the export targets. When a VTEP receives a route, it compares the export targets of the route with the local import targets. If the route targets match, the VTEP establishes a VXLAN tunnel with the remote VTEP and associates the tunnel with the L3 VXLAN ID of the corresponding VPN instance. For more information about the L3 VXLAN ID, see "Distributed EVPN gateway deployment."
The VTEP uses a Layer 3 interface to match customer traffic. The VTEP assigns customer traffic to a VXLAN by mapping the Layer 3 interface to a VSI.
A Layer 3 interface is identical to an attachment circuit (AC) in L2VPN.
When a VXLAN packet arrives at a VXLAN tunnel interface, the VTEP uses the VXLAN ID in the packet to identify its VXLAN.
Layer 2 forwarding
MAC learning
The VTEP performs Layer 2 forwarding based on a VSI's MAC address table. The VTEP learns MAC addresses by using the following methods:
·     Local MAC learning—The VTEP automatically learns the source MAC addresses of frames sent from the local site. The outgoing interfaces of local MAC address entries are site-facing interfaces on which the MAC addresses are learned.
·     Remote MAC learning—The VTEP uses MP-BGP to advertise local MAC reachability information to remote sites and learn MAC reachability information from remote sites. The outgoing interfaces of MAC address entries advertised from a remote site are VXLAN tunnel interfaces.
Unicast
As shown in Figure 2, the VTEP performs typical Layer 2 forwarding for known unicast traffic within the local site.
Figure 2 Intra-site unicast
As shown in Figure 3, the following process applies to a known unicast frame between sites:
1.     The source VTEP encapsulates the Ethernet frame in the VXLAN/UDP/IP header.
In the outer IP header, the source IP address is the source VTEP's VXLAN tunnel source IP address. The destination IP address is the VXLAN tunnel destination IP address.
2.     The source VTEP forwards the encapsulated packet out of the outgoing VXLAN tunnel interface found in the VSI's MAC address table.
3.     The intermediate transport devices (P devices) forward the packet to the destination VTEP by using the outer IP header.
4.     The destination VTEP removes the headers on top of the inner Ethernet frame. It then performs MAC address table lookup in the VXLAN's VSI to forward the frame out of the matching outgoing interface.
Figure 3 Inter-site unicast
Flood
As shown in Figure 4, a VTEP floods a broadcast, multicast, or unknown unicast frame to all site-facing interfaces and VXLAN tunnels in the VXLAN, except for the incoming interface. The source VTEP replicates the flood frame, and then sends one replica to the destination IP address of each VXLAN tunnel in the VXLAN. Each destination VTEP floods the inner Ethernet frame to all the site-facing interfaces in the VXLAN. To avoid loops, the destination VTEPs do not flood the frame to VXLAN tunnels.
Figure 4 Forwarding of flood traffic
Centralized EVPN gateway deployment uses one VTEP to provide Layer 3 forwarding for VXLANs. The VTEP uses virtual Layer 3 VSI interfaces as gateway interfaces for VXLANs. Typically, the gateway-collocated VTEP connects to other VTEPs and the external network. To use this design, make sure the gateway has sufficient bandwidth and processing capability. A centralized EVPN gateway can provide services only for IPv4 sites.
As shown in Figure 5, a VTEP acts as a gateway for VMs in the VXLANs. The VTEP both terminates the VXLANs and performs Layer 3 forwarding for the VMs. The network uses the following process to forward Layer 3 traffic from a VM to the destination:
1.     The VM sends an ARP request to obtain the MAC address of the VSI interface that acts as the gateway, and then sends the Layer 3 traffic to the centralized EVPN gateway.
2.     The local VTEP looks up the matching VSI's MAC address table and forwards the traffic to the centralized EVPN gateway through a VXLAN tunnel.
3.     The centralized EVPN gateway removes the VXLAN encapsulation and forwards the traffic at Layer 3.
4.     The centralized EVPN gateway forwards the replies sent by the destination node to the VM based on the ARP entry for the VM.
Figure 5 Example of centralized EVPN gateway deployment
As shown in Figure 6, each site's VTEP acts as a gateway to perform Layer 3 forwarding for the VXLANs of the local site. A VTEP acts as a border gateway to the Layer 3 network for the VXLANs.
Figure 6 Distributed EVPN gateway placement design
A distributed EVPN gateway supports the following traffic forwarding modes:
·     Asymmetric IRB—The ingress gateway performs Layer 2 and Layer 3 lookups and the egress gateway performs only Layer 2 forwarding.
·     Symmetric IRB—Both the ingress and egress gateways perform Layer 2 and Layer 3 lookups.
Symmetric IRB
Basic concepts
Symmetric IRB introduces the following concepts:
·     L3 VXLAN ID—Also called L3 VNI. An L3 VXLAN ID identifies the traffic of a routing domain where devices have Layer 3 reachability. An L3 VXLAN ID is associated with one VPN instance. Distributed EVPN gateways use VPN instances to isolate traffic of different services on VXLAN tunnel interfaces.
·     Router MAC address—Each distributed EVPN gateway has a unique router MAC address used for inter-gateway forwarding. The MAC addresses in the inner Ethernet header of VXLAN packets are router MAC addresses of distributed EVPN gateways.
VSI interfaces
As shown in Figure 7, each distributed EVPN gateway has the following types of VSI interfaces:
·     VSI interface as a gateway interface of a VXLAN—The VSI interface acts as the gateway interface for VMs in a VXLAN. The VSI interface is associated with a VSI and a VPN instance. On different distributed EVPN gateways, the VSI interface of a VXLAN use the same IP address to provide services.
·     VSI interface associated with an L3 VXLAN ID—The VSI interface is associated with a VPN instance and assigned an L3 VXLAN ID. VSI interfaces associated with the same VPN instance share an L3 VXLAN ID.
A border gateway only has VSI interfaces that are associated with an L3 VXLAN ID.
Figure 7 Example of distributed EVPN gateway deployment
Layer 3 forwarding entry learning
A distributed EVPN gateway forwards Layer 3 traffic based on FIB entries generated from BGP EVPN routes and ARP information.
A VTEP advertises an external route imported in the EVPN address family through MP-BGP. A remote VTEP adds the route to the FIB table of a VPN instance based on the L3 VXLAN ID carried in the route. In the FIB entry, the outgoing interface is a VXLAN tunnel interface, and the next hop is the peer VTEP address in the NEXT_HOP attribute of the route.
A VTEP has the following types of ARP information:
·     Local ARP information—ARP information of VMs in the local site. The VTEP snoops GARP packets and ARP requests for the gateway MAC address to learn the ARP information of the senders and generates ARP entries and FIB entries. In an ARP or FIB entry, the outgoing interface is the site-facing interface where the packet is received, and the VPN instance is the instance associated with the corresponding VSI interface.
·     Remote ARP information—ARP information of VMs in remote sites. Each VTEP uses MP-BGP to advertise its local ARP information with L3 VXLAN IDs in routes to remote sites. A VTEP generates only FIB entries for the remote ARP information. A FIB entry contains the following information:
¡     Outgoing interface: VSI interface associated with the L3 VXLAN ID.
¡     Next hop: Peer VTEP address in the NEXT_HOP attribute of the route.
¡     VPN instance: VPN instance associated with the L3 VXLAN ID.
The VTEP then creates an ARP entry for the next hop in the FIB entry.
Traffic forwarding
A distributed EVPN gateway can work in one of the following mode:
·     Switching and routing mode—Forwards Layer 2 traffic based on the MAC address table and forwards Layer 3 traffic based on the FIB table. In this mode, you need to enable ARP flood suppression on the distributed EVPN gateway to reduce flooding.
·     Routing mode— Forwards both Layer 2 and Layer 3 traffic based on the FIB table. In this mode, you need to enable local proxy ARP on the distributed EVPN gateway.
For more information about MAC address table-based Layer 2 forwarding, see "Unicast."
Figure 8 shows the intra-site Layer 3 forwarding process.
1.     The source VM sends an ARP request to obtain the MAC address of the destination VM.
2.     The gateway replies to the source VM with the MAC address of the VSI interface associated with the source VM's VSI.
3.     The source VM sends a Layer 3 packet to the gateway.
4.     The gateway looks up the FIB table of the VPN instance associated with the source VM's VSI and finds the matching outgoing site-facing interface.
5.     The gateway processes the Ethernet header of the Layer 3 packet as follows:
¡     Replaces the destination MAC address with the destination VM's MAC address.
¡     Replaces the source MAC address with the VSI interface's MAC address.
6.     The gateway forwards the Layer 3 packet to the destination VM.
Figure 8 Intra-site Layer 3 forwarding
Figure 9 shows the inter-site Layer 3 forwarding process.
4.     The gateway looks up the FIB table of the VPN instance associated with the source VM's VSI and finds the matching outgoing VSI interface.
¡     Replaces the destination MAC address with the destination gateway's router MAC address.
¡     Replaces the source MAC address with its own router MAC address.
6.     The gateway adds VXLAN encapsulation to the Layer 3 packet and forwards the packet to the destination gateway. The encapsulated VXLAN ID is the L3 VXLAN ID of the corresponding VPN instance.
7.     The destination gateway identifies the VPN instance of the packet based on the L3 VXLAN ID and removes the VXLAN encapsulation. Then the gateway forwards the packet based on the matching ARP entry.
Figure 9 Inter-site Layer 3 forwarding
Communication between private and public networks
A distributed EVPN gateway uses the public instance to perform Layer 3 forwarding for the public network and to enable communication between private and public networks. The public instance is similar to a VPN instance. A distributed EVPN gateway processes traffic of the public instance in the same way it does for a VPN instance. For the public instance to work correctly, you must configure an RD, an L3 VXLAN ID, and route targets for it. If a VSI interface is not associated with any VPN instance, the VSI interface belongs to the public instance.
Asymmetric IRB
VSI interfaces
Asymmetric IRB uses the same distributed EVPN gateway deployment as symmetric IRB.
As shown in Figure 10, each distributed EVPN gateway has the following types of VSI interfaces:
·     VSI interface as a gateway interface of a VXLAN—The VSI interface is associated with a VSI and a VPN instance. On different distributed EVPN gateways, the VSI interface of a VXLAN must use different IP addresses to provide services.
·     VSI interface associated with an L3 VXLAN ID—The VSI interface acts as the gateway for VMs in a VXLAN to communicate with the external network through the border gateway. The VSI interface is associated with a VPN instance and assigned an L3 VXLAN ID. VSI interfaces associated with the same VPN instance share an L3 VXLAN ID.
Layer 3 forwarding
Asymmetric IRB supports only Layer 3 forwarding in the same VXLAN on distributed EVPN gateways.
After a distributed EVPN gateway learns ARP information about local VMs, it advertises the information to other distributed EVPN gateways through MAC/IP advertisement routes. Other distributed EVPN gateways generate FIB entries based on the advertised ARP information.
As shown in Figure 10, VM 1 and VM 2 belong to VXLAN 10 and they can reach each other at Layer 3 through the distributed EVPN gateways. The distributed EVPN gateways use the following process to perform Layer 3 forwarding in asymmetric IRB mode when VM 1 sends a packet to VM 2:
1.     After GW 1 receives the packet from VM 1, it finds that the destination MAC address is itself. Then, GW 1 removes the Layer 2 frame header and looks up the FIB table for the destination IP address.
2.     GW 1 matches the packet to the FIB entry generated based on the ARP information of VM 2.
3.     GW 1 encapsulates the packet source and destination MAC addresses as the MAC addresses of GW 1 and VM 2, respectively. Then, GW 1 adds VXLAN encapsulation to the packet and forwards the packet to GW 2 through a VXLAN tunnel.
4.     GW 2 removes the VXLAN encapsulation from the packet, and performs Layer 2 forwarding in VXLAN 10 by looking up the MAC address table for the destination MAC address.
5.     GW 2 forwards the packet to VM 2 based on the MAC address table lookup result.
Figure 10 Layer 3 forwarding in the same VXLAN (asymmetric IRB)
As shown in Figure 11, EVPN supports deploying multiple VTEPs at a site for redundancy and high availability. On the redundant VTEPs, Ethernet links connected to the site form an Ethernet segment (ES) that is uniquely identified by an Ethernet segment identifier (ESI).
Figure 11 EVPN VXLAN multihoming
DF election
To prevent redundant VTEPs from sending duplicate flood traffic to a multihomed site, a designated forwarder (DF) is elected from the VTEPs to forward flood traffic to the site. VTEPs that fail the election are assigned the backup designated forwarder (BDF) role. BDFs do not forward flood traffic to the site.
Redundant VTEPs at a site send Ethernet segment routes to one another to advertise ES and VTEP IP mappings. A VTEP accepts the Ethernet segment routes only when it is configured with an ESI. Then, the VTEPs select a DF for each AC based on the ES and VTEP IP mappings. DF election can be performed by using a VLAN tag-based algorithm or preference-based algorithm.
Figure 12 DF election
VLAN tag-based DF election
VTEPs select a DF for each AC based on the VLAN tag and VTEP IP address as follows:
1.     Arrange source IP addresses in Ethernet segment routes with the same ESI in ascending order and assign a sequence number to each IP address, starting from 0.
2.     Divide the lowest VLAN ID permitted on an AC by the number of the redundant VTEPs, and match the reminder to the sequence numbers of IP addresses.
3.     Assign the DF role to the VTEP that uses the IP address with the matching sequence number.
The following uses AC 1 in Figure 13 as an example to explain the DF election procedure:
4.     VTEP 1 and VTEP 2 send Ethernet segment routes to each other.
5.     The VTEPs assign sequence numbers 0 and 1 to IP addresses 1.1.1.1 and 2.2.2.2 in the Ethernet segment routes, respectively.
6.     The VTEPs divide 4 (the lowest VLAN ID permitted by AC 1) by 2 (the number of redundant VTEPs), and match the reminder 0 to the sequence numbers of the IP addresses.
7.     The DF role is assigned to VTEP 1 at 1.1.1.1.
Figure 13 VLAN tag-based DF election
Preference-based DF election
VTEPs select a DF for each ES based on the DF election preference, the Don't Preempt Me (DP) bit in Ethernet segment routes, and VTEP IP address. The DP bit can be set to one of the following values:
·     1—DF preemption is disabled. A DF retains its role when a new DF is elected.
·     0—DF preemption is enabled.
Preference-based DF election uses the following rules to select a DF for an ES:
·     The VTEP with higher preference becomes the DF.
·     If two VTEPs have the same preference, the VTEP with the DP bit set to 1 becomes the DF. If both of the VTEPs have the DP bit set to 1, the VTEP with a lower IP address becomes the DF.
As shown in Figure 14, VTEP 2 is the DF for ES 1, and VTEP 1 is the DF for ES 2.
Figure 14 Preference-based DF election
Split horizon
In a multihomed site, a VTEP forwards multicast, broadcast, and unknown unicast frames received from ACs out of all site-facing interfaces and VXLAN tunnels in the corresponding VXLAN, except for the incoming interface. As a result, the other VTEPs at the site receive these flood frames and forward them to site-facing interfaces, which causes duplicate floods and loops. EVPN introduces split horizon to resolve this issue. Split horizon disables a VTEP to forward flood traffic received from another local VTEP to site-facing interfaces if an ES on that local VTEP has the same ESI as these interfaces. As shown in Figure 15, both VTEP 1 and VTEP 2 have ES 1. When receiving flood traffic from VTEP 1, VTEP 2 does not forward the traffic to interfaces with ESI 1.
Figure 15 Split horizon
Redundancy mode
The device supports the all-active redundancy mode of EVPN VXLAN multihoming. This mode allows all redundant VTEPs at a multihomed site to forward broadcast, multicast, and unknown unicast traffic.
·     For flood frames received from remotes sites, a VTEP forwards them to the ACs of which it is the DF.
·     For flood frames received from the local site, a VTEP forwards them out of all site-facing interfaces and VXLAN tunnels in the corresponding VXLAN, except for the incoming interfaces. For flood frames to be sent out of a VXLAN tunnel interface, a VTEP replicates each flood frame and sends one replica to all the other VTEPs in the corresponding VXLAN.
IP aliasing
In all-active redundancy mode, all redundant VTEPs of an ES advertise the ES to remote VTEPs through MP-BGP. IP aliasing allows a remote VTEP to add the IP addresses of all the redundant VTEPs as the next hops for the MAC or ARP information received from one of these VTEPs. This mechanism creates ECMP routes between the remote VTEP and the redundant VTEPs.
ARP or ND flood suppression reduces ARP request broadcasts or ND request multicasts by enabling the VTEP to reply to ARP or ND requests on behalf of VMs.
As shown in Figure 16, this feature snoops ARP or ND requests, ARP or ND responses, and BGP EVPN routes to populate the ARP or ND flood suppression table with local and remote MAC addresses. If an ARP or ND request has a matching entry, the VTEP replies to the request on behalf of the VM. If no match is found, the VTEP floods the request to both local and remote sites.
Figure 16 ARP flood suppression
The following uses ARP flood suppression as an example to explain the flood suppression workflow:
1.     VM 1 sends an ARP request to obtain the MAC address of VM 7.
2.     VTEP 1 creates a suppression entry for VM 1, floods the ARP request in the VXLAN, and sends the suppression entry to VTEP 2 and VTEP 3 through BGP EVPN.
3.     VTEP 2 and VTEP 3 de-encapsulate the ARP request and broadcast the request in the local site.
4.     VM 7 sends an ARP reply.
5.     VTEP 2 creates a suppression entry for VM 7, forwards the ARP reply to VTEP 1, and sends the suppression entry to VTEP 1 and VTEP 3 through BGP EVPN.
6.     VTEP 1 de-encapsulates the ARP reply and forwards the ARP reply to VM 1.
7.     VM 4 sends an ARP request to obtain the MAC address of VM 1.
8.     VTEP 1 creates a suppression entry for VM 4 and replies to the ARP request.
9.     VM 10 sends an ARP request to obtain the MAC address of VM 1.
10.     VTEP 3 creates a suppression entry for VM 10 and replies to the ARP request.
MAC mobility
MAC mobility refers to that a VM or host moves from one ES to another. The source VTEP is unaware of the MAC move event. To notify other VTEPs of the change, the destination VTEP advertises a MAC/IP advertisement route for the MAC address. The source VTEP withdraws the old route for the MAC address after receiving the new route. The MAC/IP advertisement route has a sequence number that increases when the MAC address moves. The sequence number identifies the most recent move if the MAC address moves multiple times.
Make sure the following VXLAN tunnels are not associated with the same VXLAN when they have the same tunnel destination IP address:
·     A VXLAN tunnel automatically created by EVPN.
·     A manually created VXLAN tunnel.
For more information about manual tunnel configuration, see VXLAN Configuration Guide.
As a best practice to ensure correct traffic forwarding, configure the same MAC address for all VSI interfaces on an EVPN gateway.
To configure EVPN VXLAN, perform the following tasks:
1.     Configuring a VXLAN on a VSI
2.     Configuring an EVPN instance
3.     (Optional.) Configuring EVPN VXLAN multihoming
a.     Assigning an ESI to an interface
b.     (Optional.) Configuring the DF election algorithm
c.     (Optional.) Enabling AC state-based DF election
d.     (Optional.) Setting the DF election delay
e.     (Optional.) Enabling non-revertive mode for preference-based DF election
f.     (Optional.) Configuring ES route advertisement delay
g.     (Optional.) Disabling advertisement of EVPN multihoming routes
h.     (Optional.) Enabling the device to ignore the Ethernet tag when advertising Ethernet auto-discovery routes and MAC/IP advertisement routes
i.     (Optional.) Enabling the device to monitor the BGP peer status of another local edge device
4.     Configuring BGP EVPN routes
a.     Enabling BGP to advertise BGP EVPN routes
b.     (Optional.) Configuring route selection and advertisement settings
c.     (Optional.) Preferring routes with an IPv6 next hop during optimal route selection
d.     (Optional.) Configuring routing policy-based recursive lookup
e.     (Optional.) Maintaining BGP sessions
5.     Mapping ACs to a VSI
6.     Configuring an EVPN gateway
¡     Configuring a centralized EVPN gateway
¡     Configuring a distributed EVPN gateway
7.     (Optional.) Managing remote MAC address entries and remote ARP learning
¡     Disabling remote MAC address learning and remote ARP learning
¡     Disabling MAC address advertisement
¡     Enabling MAC mobility event suppression
¡     Disabling learning of MAC addresses from ARP or ND information
¡     Disabling ARP information advertisement
¡     Enabling ND information advertisement
¡     Disabling the VSI interface on a centralized EVPN gateway from learning ARP or ND information across subnets
¡     Enabling ARP mobility event suppression
¡     Enabling ARP request proxy
¡     Enabling ND mobility event suppression
8.     (Optional.) Enabling BGP EVPN route advertisement to the local site
¡     Redistributing MAC/IP advertisement routes into BGP unicast routing tables
¡     Setting the metric of BGP EVPN routes added to a VPN instance's routing table
¡     Enabling BGP EVPN route advertisement to the local site
9.     (Optional.) Maintaining and optimizing an EVPN network
¡     Disabling flooding for a VSI
¡     Enabling ARP or ND flood suppression
¡     Enabling SNMP notifications for EVPN
For more information about the VXLAN commands in this task, see VXLAN Command Reference.
2.     Enable L2VPN.
l2vpn enable
By default, L2VPN is disabled.
3.     Create a VSI and enter VSI view.
vsi vsi-name
4.     Configure a VSI description.
By default, a VSI does not have a description.
5.     Enable the VSI.
By default, a VSI is enabled.
6.     Create a VXLAN and enter VXLAN view.
vxlan vxlan-id
You can create only one VXLAN on a VSI. The VXLAN ID must be unique for each VSI.
If a VXLAN requires only Layer 2 connectivity, you do not need to associate a VPN instance with it. The BGP EVPN routes advertised by a VTEP carry the RD and route targets configured for the EVPN instance associated with the VXLAN.
In EVPN instance view, you can configure routing policies to filer the routes redistributed from BGP EVPN to an EVPN instance and vice versa.
2.     Enter VSI view.
vsi vsi-name
3.     Create an EVPN instance and enter VSI EVPN instance view.
evpn encapsulation vxlan
4.     Configure an RD for the EVPN instance.
route-distinguisher { route-distinguisher | auto }
By default, no RD is configured for an EVPN instance.
5.     Configure route targets for the EVPN instance.
vpn-target { vpn-target&<1-8> | auto } [ both | export-extcommunity | import-extcommunity ]
By default, an EVPN instance does not have route targets.
Make sure the import targets of the EVPN instance do not match the export targets of VPN instances or the public instance, and vice versa. For more information about VPN instance configuration and public instance configuration, see "Configuring an L3 VXLAN ID for a VSI interface."
6.     (Optional.) Apply an export routing policy to the EVPN instance.
By default, no export routing policy is applied to an EVPN instance.
7.     (Optional.) Apply an import routing policy to the EVPN instance.
By default, no import routing policy is applied to an EVPN instance.
8.     (Optional.) Apply a tunnel policy to EVPN.
tunnel-policy tunnel-policy-name
By default, no tunnel policy is specified for EVPN.
In a multihomed site, AC configuration and VXLAN IDs must be consistent on redundant VTEPs of the same ES. For each VXLAN ID, you must configure unique RDs for the EVPN instance of VSIs on the redundant VTEPs. You must configure different RDs for the VPN instances and the public instance that use the same VXLAN IP gateway.
You can assign ESIs to a main interface and its subinterfaces.
·     If you assign an ESI to a subinterface, the subinterface-specific ESI and ES configuration take precedence over those configured on the main interface. The ES configuration includes the following:
¡     evpn df-election algorithm.
¡     evpn df-election preference.
¡     evpn df-election preference non-revertive.
¡     evpn timer es-delay.
·     If you do not assign an ESI to a subinterface, it inherits the ESI and ES configuration (if configured) of the main interface. In this scenario, the ES configuration on the subinterface does not take effect.
An ESI uniquely identifies an ES. The links on interfaces with the same ESI belong to the same ES. Traffic of the ES can be distributed among the links for load sharing.
2.     Enter interface view.
¡     Enter Layer 3 Ethernet interface view.
¡     Enter Layer 3 aggregate interface view.
3.     Assign an ESI to the interface.
esi esi-id
By default, no ESI is assigned to an interface.
At a multihomed EVPN network site, you can modify the DF election algorithm to control the DF election result.
If ambiguous VLAN termination is enabled on a subinterface acting as an AC, do not configure the VLAN tag-based algorithm for DF election on the subinterface. Otherwise, traffic forwarding errors will occur.
You can configure the DF election algorithm in system view and in interface view. The global DF election algorithm takes effect on all ESs, and the interface-specific DF election algorithm takes effect only on the ESs on an interface. The interface-specific DF election algorithm takes precedence over the global DF election algorithm.
Configuring the DF election algorithm globally
2.     Configure the DF election algorithm.
evpn df-election algorithm algorithm
By default, the VLAN tag-based algorithm is used for DF election.
Configuring the DF election algorithm on an interface
3.     Configure the DF election algorithm.
By default, the DF election algorithm specified in system view takes effect.
Configuring preference-based DF election
3.     Set the DF election preference.
evpn df-election preference preference
By default, the DF election preference is 32767.
The larger the value, the higher the preference.
At a multihomed EVPN network site, all VTEPs in an ES participate in DF election by default, regardless of their AC states. If the AC on the VTEP elected as the DF is down, traffic forwarding will fail. You can configure this feature to resolve this issue.
After you configure this feature, a VTEP participates in DF election only when the AC on the VTEP is up. A VTEP determines that the AC on the remote VTEP is up only when it receives AD per ES and AD per EVI routes from the remote VTEP.
This feature takes effect only when you enable this feature on all VTEPs in an ES.
2.     Enable AC state-based DF election.
evpn df-election ac-influence enable
By default, AC state-based DF election is disabled.
The DF election can be triggered by site-facing interface status changes, redundant VTEP membership changes, and interface ESI changes. To prevent frequent DF elections from degrading network performance, set the DF election delay. The DF election delay defines the minimum interval allowed between two DF elections.
2.     Set the DF election delay.
evpn multihoming timer df-delay delay-value
By default, the DF election delay is 3 seconds
At a multihomed EVPN network site, configuration changes, device restarts, or process restarts will trigger DF re-election, and DF switchover might cause packet loss. You can configure this feature to resolve this issue.
For example, VTEP 1 and VTEP 2 are in the same ES, and VTEP 1 is the DF. When VTEP 1 restarts and VTEP 2 becomes the new DF, non-revertive mode for preference-based DF election works as follows:
·     If VTEP 1 receives Ethernet segment routes from VTEP 2 after the restart, VTEP 1 compares the DF election preference in the Ethernet segment routes with the local DF election preference.
¡     If the local DF election preference is smaller than that in the received Ethernet segment routes, VTEP 1 uses the local DF election preference in the advertised Ethernet segment routes.
¡     If the local DF election preference is equivalent to that in the received Ethernet segment routes, VTEP 1 compares the IP addresses as follows:
-     If VTEP 1's IP address is lower than VTEP 2's IP address, VTEP 1 uses the local DF election preference and the DP value of 0 in the advertised Ethernet segment routes.
-     If VTEP 1's IP address is higher than VTEP 2's IP address, VTEP 1 uses the local DF election preference and the DP value of 1 in the advertised Ethernet segment routes.
¡     If the local DF election preference is larger than that in the received Ethernet segment routes, VTEP 1 uses the DF election preference in the received Ethernet segment routes and the DP value of 0 when advertising Ethernet segment routes.
·     If VTEP 1 does not receive Ethernet segment routes from VTEP 2 after the restart, VTEP 1 uses the local DF election preference in the advertised Ethernet segment routes.
As a best practice, configure this feature when the all-active redundancy mode is used, and do not configure this feature when the single-active redundancy mode is used.
When the DF restarts or the process restarts and a new DF is elected, the original DF will immediately advertise Ethernet segment routes after the restart to become the DF again. However, access-side connections restore slowly and packet loss might occur after DF switchover. To resolve this issue, configure this feature together with the Ethernet segment route advertisement delay feature on all VTEPs in an ES.
3.     Enable non-revertive mode for preference-based DF election.
By default, non-revertive mode is disabled for preference-based DF election.
When the DF restarts or the process restarts and a new DF is elected, the original DF will immediately advertise ES routes after the restart to become the DF again. However, access-side connections restore slowly and packet loss might occur after DF switchover. To resolve this issue, perform this task to configure a VTEP to delay the advertisement of ES routes.
3.     Configure ES route advertisement delay when preference-based DF election is used.
evpn timer es-recovery recovery-time
By default, ES route advertisement delay is disabled when preference-based DF election is used.
EVPN multihoming routes include Ethernet auto-discovery routes and Ethernet segment routes.
In a multihomed EVPN network, perform this task on a redundant VTEP before you reboot it. This operation allows other VTEPs to refresh their EVPN routing table to prevent traffic interruption caused by the reboot.
2.     Disable advertisement of EVPN multihoming routes and withdraw the EVPN multihoming routes that have been advertised to remote sites.
evpn multihoming advertise disable
By default, the device advertises EVPN multihoming routes.
This task enables the device to withdraw the Ethernet auto-discovery routes and MAC/IP advertisement routes that have been advertised, set their Ethernet tag field to 0, and then re-advertise them.
After you configure ESIs for ACs on the redundant edge devices at a dualhomed site, the edge devices advertise Ethernet auto-discovery routes and MAC/IP advertisement routes that carry Ethernet tags. If the remote peers are unable to identify Ethernet tags, you must perform this task on the redundant edge devices to enable communication with the peers.
After you assign an ESI to a Layer 3 main interface, its subinterfaces inherit the ESI if they do not have one. In addition, you must map two subinterfaces to different VSIs if the subinterfaces have the same ESI.
2.     Enable the device to ignore the Ethernet tag when advertising Ethernet auto-discovery routes and MAC/IP advertisement routes.
evpn multihoming advertise ignore-ethernet-tag
By default, the device advertises Ethernet auto-discovery routes and MAC/IP advertisement routes that carry Ethernet tags.
Perform this task on the CE-facing interfaces of the edge devices multihomed to a site to prevent device reboots from causing inter-site forwarding failure.
This task excludes unavailable edge devices from DF election at a multihomed site. After an edge device recovers from failure and brings up its CE-facing interface, it starts the advertisement delay timer for Ethernet segment routes and checks the status of the BGP peer specified in the evpn track peer command. If the BGP peer comes up before the timer expires, the edge device advertises Ethernet segment routes to the peer. If the BGP peer is still down when the timer expires, the edge device does not advertise Ethernet segment routes to the peer. The edge devices then perform DF election based on the Ethernet segment routes they have received.
3.     Enable the device to monitor the BGP peer status of another local edge device.
evpn track peer { peer-ipv4-address | peer-ipv6-address }
By default, the device does not monitor the BGP peer status of the other edge devices at a multihomed site.
4.     Set the advertisement delay timer for Ethernet segment routes.
evpn timer es-delay delay-time
By default, advertisement of Ethernet segment routes is not delayed.
For more information about BGP commands in this task, see Layer 3—IP Routing Command Reference.
2.     Configure a global router ID.
router id router-id
By default, no global router ID is configured.
3.     Enable a BGP instance and enter BGP instance view.
By default, BGP is disabled and no BGP instances exist.
4.     Specify remote VTEPs as BGP peers.
5.     Create the BGP EVPN address family and enter BGP EVPN address family view.
address-family l2vpn evpn
6.     Enable BGP to exchange BGP EVPN routes with a peer or peer group.
By default, BGP does not exchange BGP EVPN routes with peers.
3.     Enter BGP EVPN address family view.
4.     Advertise a default route to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-route-advertise { ipv4 | ipv6 } vpn-instance vpn-instance-name
By default, no default route is advertised to any peers or peer groups.
5.     Permit the local AS number to appear in routes from a peer or peer group and set the number of appearances.
By default, the local AS number is not allowed in routes from peers.
6.     Enable route target filtering for BGP EVPN routes.
policy vpn-target
By default, route target filtering is enabled for BGP EVPN routes.
7.     Enable the device to filter advertised objects based on the first AS number in EBGP routes.
peer-as-check enable
By default, the device advertises a received EBGP route to all BGP peers except the peer that sends the EBGP route.
After you execute this command, the device checks the first AS number in the AS_Path attribute of an EBGP route when advertising the EBGP route to EBGP peers. The device will not advertise the EBGP route to the EBGP peers in that AS.
8.     Configure BGP route reflection settings:
a.     Configure the device as an RR and specify a peer or peer group as its client.
By default, no RR or client is configured.
b.     (Optional.) Enable BGP EVPN route reflection between clients.
reflect between-clients
By default, BGP EVPN route reflection between clients is enabled.
c.     (Optional.) Configure the cluster ID of the RR.
By default, an RR uses its own router ID as the cluster ID.
d.     (Optional.) Create a reflection policy for the RR to filter reflected BGP EVPN routes.
rr-filter { ext-comm-list-number | ext-comm-list-name }
By default, an RR does not filter reflected BGP EVPN routes.
9.     Configure the device to not change the next hop of routes advertised to an EBGP peer or peer group.
By default, the device uses its address as the next hop of routes advertised to EBGP peers.
10.     Set a preferred value for routes received from a peer or peer group.
By default, the preferred value is 0 for routes received from a peer or peer group.
11.     (Optional.) Set the optimal route selection delay timer. Choose one of the following tasks or both:
¡     Set the optimal route selection delay timer for all BGP routes in the current address family.
¡     Delay optimal route selection for a peer in the specified duration after the peer comes up.
route-select suppress on-peer-up milliseconds
By default, optimal route selection is not delayed.
12.     Prefer routes learned from the specified peer or peer group during optimal route selection.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } high-priority
By default, BGP does not prefer routes learned from any peer or peer groups during optimal route selection.
13.     Apply a routing policy to routes received from or advertised to a peer or peer group.
By default, no routing policies are applied to routes received from or advertised to peers or peer groups.
14.     Advertise the COMMUNITY attribute to a peer or peer group.
By default, the device does not advertise the COMMUNITY attribute to peers or peer groups.
15.     Remove the default-gateway extended community attribute from the EVPN gateway routes advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-gateway no-advertise
By default, EVPN gateway routes advertised to peers and peer groups contain the default-gateway extended community attribute.
16.     Configure the device to advertise BGP routes with the lowest priority to peers. Choose one of the following options:
¡     Configure the device to advertise BGP routes with the lowest priority to a peer within a specified period of time after the peer goes down.
advertise lowest-priority on-peer-up duration seconds
¡     Configure the device to advertise BGP routes with the lowest priority to peers within a specified period of time after the BGP process restarts because of a device reboot.
advertise lowest-priority on-startup duration seconds
By default, the device does not change the priority of the BGP routes advertised to peers.
To set the priority of BGP routes to the lowest, the device sets the local preference and MED value of the BGP routes to 0 and 4294967295, respectively. To restore the original priority of the BGP routes during the specified duration, execute the reset bgp advertise lowest-priority command in user view.
17.     Configure the BGP additional path feature:
¡     Configure BGP additional path capabilities.
peer { group-name | ipv4-address [ mask-length ] } additional-paths { receive | send } *
By default, no BGP Additional Paths capabilities are configured.
¡     Set the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } advertise additional-paths best number
By default, a maximum of one Add-Path optimal route can be advertised to a peer or peer group.
¡     Set the maximum number of Add-Path optimal routes that can be advertised to all peers.
By default, a maximum of one Add-Path optimal route can be advertised to all peers.
18.     Enable BGP FRR.
pic
By default, BGP FRR is disabled.
Configure this feature for the VXLAN packets in an EVPN network to be forwarded through IPv6 routes when both IPv4 and IPv6 routes exist.
4.     Enable BGP to prefer routes with an IPv6 next hop during optimal route selection.
bestroute ipv6-nexthop
By default, BGP prefers routes with an IPv4 next hop during optimal route selection.
Configure routing policy-based recursive lookup to control route recursion results, such as to prefer a path during route recursion or to ensure correctness of recursive routes.
If routing policy-based recursive lookup is configured, all recursive routes are filtered by using the specified routing policy. If no recursive route for a route matches a permit node in the routing policy, that route is considered unreachable and invalid.
To disable routing policy-based recursive lookup for the BGP routes learned from a specific peer or peer group, use the peer nexthop-recursive-policy disable command.
The nexthop recursive-lookup route-policy command does not take effect on the routes learned from directly connected EBGP peers.
The protocol nexthop recursive-lookup command executed in RIB IPv4 or IPv6 address family view also takes effect on BGP routes of the BGP EVPN address family. If you execute both the nexthop recursive-lookup route-policy and protocol nexthop recursive-lookup commands, the nexthop recursive-lookup route-policy command is preferred for BGP EVPN routes.
For more information about the nexthop recursive-lookup route-policy and peer nexthop-recursive-policy disable commands, see BGP commands in Layer 3—IP Routing Command Reference.
For more information about the protocol nexthop recursive-lookup command, see IP routing basics commands in Layer 3—IP Routing Command Reference.
4.     Configure routing policy-based recursive lookup.
nexthop recursive-lookup route-policy route-policy-name
By default, BGP does not perform routing policy-based recursive lookup.
IMPORTANT
IMPORTANT:
If no recursive route of the BGP EVPN address family matches a permit node in the specified routing policy, all BGP routes of this address family will become unreachable. To avoid traffic interruption, plan your desired recursive routes and configure the routing policy accordingly.
5.     (Optional.) Disable routing policy-based recursive lookup for the BGP routes learned from a peer or peer group.
a.     Return to BGP instance view.
b.     Exempt a peer or peer group from routing policy-based recursive lookup.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } nexthop-recursive-policy disable
By default, routing policy-based recursive lookup takes effect on routes learned from all peers and peer groups.
For more information about this command, see BGP commands in Layer 3—IP Routing Command Reference.
The nexthop recursive-lookup route-policy and protocol nexthop recursive-lookup commands do not take effect on the exempted peers and peer groups.
Perform the following tasks in user view:
·     Reset BGP sessions of the BGP EVPN address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | group group-name | internal } l2vpn evpn
·     Soft-reset BGP sessions of the BGP EVPN address family.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | all | external | group group-name | internal } { export | import } l2vpn evpn
To assign the customer traffic on a Layer 3 interface to a VXLAN, map the interface to the VXLAN's VSI. The VSI uses its MAC address table to forward the customer traffic.
Link aggregation group membership is mutually exclusive with VSI mappings on a Layer 3 interface. Do not map a VSI to a Layer 3 interface that is in a Layer 3 aggregation group.
2.     Enter Layer 3 interface view.
3.     Map the Layer 3 interface to a VSI.
xconnect vsi vsi-name
By default, a Layer 3 interface is not mapped to any VSI.
If an EVPN network contains a centralized EVPN gateway, you must enable ARP or ND flood suppression on VTEPs. Typically remote ARP or ND learning is disabled in an EVPN network. When ARP or ND requests for the gateway MAC address are sent to the centralized EVPN gateway through VXLAN tunnels, the gateway does not respond to the requests. If ARP or ND flood suppression is disabled on VTEPs, VMs cannot obtain the MAC address of the gateway.
2.     Create a VSI interface and enter VSI interface view.
interface vsi-interface vsi-interface-id
For more information about this command, see VXLAN Command Reference.
3.     Assign an IPv4 address to the VSI interface.
By default, no IPv4 address is assigned to a VSI interface.
4.     Return to system view.
5.     Enter VSI view.
vsi vsi-name
6.     Specify the VSI interface as the gateway interface for the VSI.
gateway vsi-interface vsi-interface-id
By default, no gateway interface is specified for a VSI.
Make sure a VSI interface uses the same MAC address to provide service on distributed EVPN gateways connected to IPv4 sites. Make sure a VSI interface uses different link-local addresses to provide service on distributed EVPN gateways connected to both IPv4 and IPv6 sites.
As a best practice, do not use ARP flood suppression and local proxy ARP or ND flood suppression and local ND proxy together on distributed EVPN gateways. If both ARP flood suppression and local proxy ARP are enabled on a distributed EVPN gateway, only local proxy ARP takes effect. If both ND flood suppression and local ND proxy are enabled on a distributed EVPN gateway, only local ND proxy takes effect.
On a distributed EVPN gateway, make sure the VSI interfaces configured with L3 VXLAN IDs use the same MAC address. To modify the MAC address of a VSI interface, use the mac-address command.
For a VXLAN to access the external network, specify the VXLAN's VSI interface on the border gateway as the next hop on distributed EVPN gateways by using one of the following methods:
·     Configure a static route.
·     Configure a routing policy, and apply the policy by using the apply default-next-hop or apply next-hop command. For more information about configuring routing policies, see routing policy configuration in Layer 3—IP Routing Configuration Guide.
The asymmetric IRB mode is supported only on distributed EVPN gateways. The mode takes effect only on Layer 3 traffic forwarded in the same VXLAN. In addition, the same VSI interface on different distributed EVPN gateways must have different IP addresses.
2.     Configure the traffic forwarding mode for EVPN VXLAN. Choose one of the following options:
¡     Enable asymmetric IRB mode.
evpn irb asymmetric [ route-policy route-policy-name ]
¡     Enable symmetric IRB mode.
undo evpn irb asymmetric
By default, a distributed EVPN gateway forwards EVPN VXLAN traffic in symmetric IRB mode.
To save Layer 3 interface resources on a distributed EVPN gateway, multiple VSIs can share one VSI interface. You can assign multiple IPv4 addresses (one primary address and multiple secondary addresses) or multiple IPv6 addresses to the VSI interface for the VSIs to use as gateway addresses.
When VSIs share a VSI interface, you must specify the subnet of each VSI for the VSI interface to identify the VSI of a packet. The subnets must be unique.
3.     Assign an IP address to the VSI interface.
IPv4:
IPv6:
See IPv6 basics in Layer 3—IP Services Configuration Guide.
By default, no IP address is assigned to a VSI interface.
4.     Assign a MAC address to the VSI interface.
mac-address mac-address
By default, VSI interfaces use the bridge MAC address of the device.
To ensure correct forwarding after VM migration, you must assign the same MAC address to the VSI interfaces of a VXLAN on all distributed gateways.
5.     Specify the VSI interface as a distributed gateway.
distributed-gateway local
By default, a VSI interface is not a distributed gateway.
6.     (Optional.) Enable local proxy ARP.
local-proxy-arp enable [ ip-range startIP to endIP ]
By default, local proxy ARP is disabled.
For more information about the command, see proxy ARP commands in Layer 3—IP Services Command Reference.
7.     Return to system view.
8.     Enter VSI view.
vsi vsi-name
9.     Specify the VSI interface as the gateway interface for the VSI.
10.     Assign a subnet to the VSI.
gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
By default, no subnet exists on a VSI.
Configuring an L3 VXLAN ID for the VSI interface of a VPN instance
2.     Configure a VPN instance:
a.     Create a VPN instance and enter VPN instance view.
b.     Configure an RD for the VPN instance.
By default, no RD is configured for a VPN instance.
c.     Configure route targets for the VPN instance.
vpn-target { vpn-target&<1-8> [ both | export-extcommunity | import-extcommunity ]
By default, a VPN instance does not have route targets.
d.     (Optional.) Apply an export routing policy to the VPN instance.
By default, no export routing policy is applied to a VPN instance.
e.     (Optional.) Apply an import routing policy to the VPN instance.
By default, no import routing policy is applied to a VPN instance. The VPN instance accepts a route when the export route targets of the route match local import route targets.
3.     Configure EVPN on the VPN instance:
a.     Enter VPN instance EVPN view.
address-family evpn
b.     Configure route targets for EVPN on the VPN instance.
By default, EVPN does not have route targets on a VPN instance.
Make sure the following requirements are met:
-     The import targets of EVPN do not match the export targets of the VPN instance.
-     The export targets of EVPN do not match the import targets of the VPN instance.
c.     (Optional.) Apply an export routing policy to EVPN on the VPN instance.
By default, no export routing policy is applied to EVPN on a VPN instance.
d.     (Optional.) Apply an import routing policy to EVPN on the VPN instance.
By default, no import routing policy is applied to EVPN on a VPN instance. The VPN instance accepts a route when the route targets of the route match local import route targets.
4.     Execute the following commands in sequence to return to system view.
a.     quit
b.     quit
5.     Create a VSI interface and enter VSI interface view.
6.     Associate the VSI interface with the VPN instance.
By default, a VSI interface is not associated with a VPN instance. The interface is on the public network.
7.     Configure an L3 VXLAN ID for the VSI interface.
l3-vni vxlan-id
By default, no L3 VXLAN ID is configured for a VSI interface.
A VPN instance can have only one L3 VXLAN ID. If multiple L3 VXLAN IDs are configured for a VPN instance, the VPN instance uses the lowest one. To view the L3 VXLAN ID of a VPN instance, use the display evpn routing-table command.
Configuring an L3 VXLAN ID for the VSI interface of the public instance
2.     Create the public instance and enter its view.
ip public-instance
3.     Configure an RD for the public instance.
By default, no RD is configured for the public instance.
4.     (Optional.) Configure route targets for the public instance.
By default, the public instance does not have route targets.
5.     Configure an L3 VXLAN ID for the public instance.
l3-vni vxlan-id
By default, the public instance does not have an L3 VXLAN ID.
The public instance can have only one L3 VXLAN ID. To modify the L3 VXLAN ID for the public instance, you must first delete the original L3 VXLAN ID.
6.     Enter IPv4 address family view, IPv6 address family view, or EVPN view.
¡     Enter IPv4 address family view.
address-family ipv4
¡     Enter IPv6 address family view.
address-family ipv6
¡     Enter EVPN view.
address-family evpn
7.     Configure route targets for IPv4 VPN, IPv6 VPN, or EVPN.
By default, IPv4 VPN, IPv6 VPN, and EVPN do not have route targets on the public instance.
¡     The import targets of an EVPN instance do not match the export targets of the public instance.
¡     The export targets of an EVPN instance do not match the import targets of the public instance.
8.     Execute the following commands in sequence to return to system view.
a.     quit
b.     quit
9.     Enter VSI interface view.
10.     Configure an L3 VXLAN ID for the VSI interface.
l3-vni vxlan-id
Of the VSI interfaces associated with the public instance, a minimum of one VSI interface must use the same L3 VXLAN ID as the public instance.
If IGP routes are imported to the BGP-VPN IPv4 or IPv6 unicast address family and the corresponding VPN instance has an L3 VXLAN ID, the device advertises the imported routes as IP prefix advertisement routes.
If IGP routes are imported to the BGP IPv4 or IPv6 unicast address family and the public instance has an L3 VXLAN ID, the device advertises the imported routes as IP prefix advertisement routes.
A VTEP compares the export route targets of received IP prefix advertisement routes with the import route targets configured for IPv4 VPN or IPv6 VPN on a VPN instance or the public instance. If the route targets match, the VTEP accepts the routes and adds the routes to the routing table of the VPN instance or public instance.
This feature is supported only by distributed EVPN gateway deployment.
For more information about the BGP commands in this task, see Layer 3—IP Routing Command Reference.
3.     Enter BGP address family view.
¡     Enter BGP IPv4 unicast address family view.
¡     Execute the following commands in sequence to enter BGP-VPN IPv4 unicast address family view.
¡     Enter BGP IPv6 unicast address family view.
¡     Execute the following commands in sequence to enter BGP-VPN IPv6 unicast address family view.
4.     Enable BGP to redistribute routes from an IGP protocol.
By default, BGP does not redistribute IGP routes.
5.     (Optional.) Enable default route redistribution into the BGP routing table.
default-route imported
By default, default route redistribution into the BGP routing table is disabled.
6.     (Optional.) Configure ECMP VPN route redistribution:
b.     Enter BGP EVPN address family view.
c.     Enable ECMP VPN route redistribution.
vpn-route cross multipath
By default, ECMP VPN route redistribution is disabled. If multiple routes have the same prefix and RD, BGP only imports the optimal route into the EVPN routing table.
ECMP VPN route redistribution enables BGP to import all routes that have the same prefix and RD into the EVPN routing table.
By default, the BGP routes of one VPN instance are isolated from those of another VPN instance. If inter-VPN route exchange is required and the routes of a VPN instance must be hidden, configure other VPN instances to advertise routes of that VPN instance.
Figure 17 BGP route exchange between the public instance and VPN instances
As shown in Figure 17, PE 1 and PE 2 set up public IBGP sessions with PE 3, and the public instance and VPN instances exchange routes to enable communication between the public network and the VPN sites. PE 1 and PE 2 set up BGP EVPN IBGP peer relationships with each other to exchange VPN instance routes. When all links operate correctly, PE 2 receives the public routes advertised by PE 3 and redistributes the routes to the local VPN site. When the link between PE 2 and PE 3 fails, perform the following tasks for PE 1 to reoriginate the public routes in a specified VPN instance and advertise them to PE 2:
1.     Configure route targets for the public instance on PE 1. Make sure the route targets match those of the VPN instance to redistribute public routes.
2.     Execute the route-replicate enable command on PE 1 to redistribute the BGP routes of the public instance to the target VPN instance.
3.     Execute the advertise route-reoriginate command on PE 1 to enable reoriginating the BGP routes of other VPN instances in the target VPN instance. This command enables reoriginating BGP routes based on only the BGP routes that match the route targets of the target VPN instance. The VPN instance does not reoriginate BGP routes based on the redistributed local routes, such as the IGP routes redistributed by using the import-route command.
4.     Execute the peer advertise vpn-reoriginate ibgp command on PE 1 to advertised reoriginated routes to IBGP peer PE 2.
You must use the peer advertise vpn-reoriginate ibgp command in combination with the advertise route-reoriginate command. If you execute only the peer advertise vpn-reoriginate ibgp command, it does not take effect.
In BGP-VPN IPv4 unicast address family view, the advertise route-reoriginate command enables reoriginating IPv4 unicast routes. In BGP-VPN IPv6 unicast address family view, the advertise route-reoriginate command enables reoriginating IPv6 unicast routes.
For more information about the advertise route-reoriginate and route-replicate enable commands, see MPLS L3VPN commands in MPLS Command Reference.
3.     (Optional.) Enable BGP route replication between public and VPN instances.
By default, BGP route replication between public and VPN instances is disabled
4.     Enter BGP address family view.
5.     Enable reoriginating BGP routes for a VPN instance based on the BGP routes received from other VPN instances.
advertise route-reoriginate [ route-policy route-policy-name ] [ replace-rt ]
By default, a VPN instance does not reoriginate BGP unicast routes for the BGP routes of other VPN instances.
This command enables reoriginating BGP routes based on only the BGP routes that match the route targets of the current VPN instance. The VPN instance does not reoriginate BGP routes based on the redistributed local routes.
6.     (Optional.) Enable advertising the IP prefix advertisement routes reoriginated for a VPN instance to an IBGP peer or peer group.
c.     Enable advertising the IP prefix advertisement routes reoriginated for a VPN instance to an IBGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise vpn-reoriginate ibgp
By default, the device does not advertise the IP prefix advertisement routes reoriginated for a VPN instance to IBGP peers or peer groups.
Configuring the EVPN global MAC address
The EVPN global MAC address is used only by VSI interfaces associated with an L3 VXLAN ID. For such a VSI interface, the MAC address assigned to it by using the mac-address command takes precedence over the EVPN global MAC address.
Do not use a reserved MAC address as the EVPN global MAC address.
2.     Configure the EVPN global MAC address.
evpn global-mac mac-address
By default, no EVPN global MAC address is configured.
Enabling a distributed EVPN gateway to send RA messages over VXLAN tunnels
By default, a distributed EVPN gateway drops the RS messages received from VXLAN tunnels and periodically advertises RA messages only to the local site. As a result, a distributed EVPN gateway does not send RA messages over VXLAN tunnels, and remote gateways cannot update information about the gateway based on RA messages. To resolve the issue, perform this task to enable distributed EVPN gateways to reply to remote RS messages with RA messages and periodically advertise RA messages over VXLAN tunnels.
2.     Globally enable VSI interfaces to send RA messages over VXLAN tunnels.
ipv6 nd ra tunnel-broadcast global enable
By default, VSI interfaces do not send RA messages over VXLAN tunnels.
Enabling the device to advertise ARP information for the distributed EVPN gateway interfaces through MAC/IP advertisement routes
If a distributed EVPN gateway has downstream VTEPs attached, the gateway advertises ARP information for gateway interfaces through IP prefix advertisement routes. Because the VTEPs do not have gateway configuration, they cannot learn the ARP information for the gateway interfaces or forward traffic to the gateway. For the VTEPs to learn ARP information for the gateway interfaces, enable the distributed EVPN gateway to advertise ARP information for the gateway interfaces through MAC/IP advertisement routes.
2.     Enable the device to advertise ARP information for the distributed EVPN gateway interfaces through MAC/IP advertisement routes.
evpn mac-ip advertise distributed-gateway
By default, the device does not advertise ARP information for the distributed EVPN gateway interfaces through MAC/IP advertisement routes.
By default, the device learns MAC information and ARP information of remote user terminals from packets received on VXLAN tunnel interfaces. The automatically learned remote MAC and ARP information might conflict with the remote MAC and ARP information advertised through BGP. As a best practice to avoid the conflicts, disable remote MAC address learning and remote ARP learning on the device.
2.     Disable remote MAC address learning.
By default, remote MAC address learning is enabled.
3.     Disable remote ARP learning.
vxlan tunnel arp-learning disable
By default, remote ARP learning is enabled.
The MAC information and ARP information advertised by the VTEP overlap. To avoid duplication, disable MAC address advertisement and withdraw the MAC addresses advertised to remote VTEPs.
Disabling MAC address advertisement in VSI EVPN instance view
2.     Enter VSI view.
vsi vsi-name
3.     Enter VSI EVPN instance view.
4.     Disable MAC address advertisement and withdraw advertised MAC addresses.
mac-advertising disable
By default, MAC address advertisement is enabled.
On an EVPN VXLAN network, misconfiguration of MAC addresses might cause two sites to contain the same MAC address. In this condition, VTEPs at the two sites constantly synchronize and update EVPN MAC entries and determine that MAC mobility events occur. As a result, an inter-site loop might occur, and the bandwidth is occupied by MAC entry synchronization traffic. To eliminate loops and suppress those MAC mobility events, enable MAC mobility event suppression on the VTEPs.
The MAC mobility event suppression feature allows a MAC address to move at most the specified number of times (MAC mobility suppression threshold) out of a site within a MAC mobility detection cycle. If the suppression threshold has been reached for a MAC address within a detection cycle, the VTEP at the site suppresses the subsequent move after the MAC address moves back to the site. In addition, the VTEP learns the MAC address but does not advertise it.
After you execute the undo evpn route mac-mobility suppression command or when the MAC mobility suppression time expires, a VTEP acts as follows:
·     Advertises MAC address entries immediately for the suppressed MAC address entries that have not aged out.
·     Relearns the MAC addresses for the suppressed MAC address entries that have aged out and advertises the MAC address entries.
If both MAC address entry conflicts and ARP entry conflicts exist for a MAC address, you must enable both MAC mobility event suppression and ARP mobility event suppression. If you enable only MAC mobility event suppression, the system cannot suppress MAC mobility events for the MAC address.
The MAC mobility event suppression setting configured in system view takes effect on all EVPN instances. The MAC mobility event suppression setting configured in EVPN instance view takes effect on all associated VSIs. The MAC mobility event suppression setting configured in VSI EVPN instance view takes effect only on the associated VSI. The MAC mobility event suppression setting configured in Layer 3 interface view takes effect only on that interface.
The MAC mobility event suppression settings configured in the following views are in descending order of priority:
1.     Layer 3 interface view.
2.     EVPN instance view or VSI EVPN instance view.
3.     System view.
Enabling MAC mobility event suppression in system view
2.     Enable MAC mobility event suppression.
evpn route mac-mobility suppression [ detect-cycle detect-time | detect-threshold  move-times | suppression-time [ suppression-time | permanent ] ] *
By default, MAC mobility event suppression is disabled.
Enabling MAC mobility event suppression in VSI EVPN instance view
2.     Enter VSI view.
vsi vsi-name
4.     Enable MAC mobility event suppression.
Enabling MAC mobility event suppression in Layer 3 interface view
3.     Enable MAC mobility event suppression.
The MAC information and ARP or ND information advertised by a remote VTEP overlap. To avoid duplication, disable the learning of MAC addresses from ARP or ND information. EVPN will learn remote MAC addresses only from the MAC information advertised from remote sites.
Disabling learning of MAC addresses from ARP or ND information in VSI EVPN instance view
2.     Enter VSI view.
vsi vsi-name
4.     Disable the EVPN instance from learning MAC addresses from ARP information.
arp mac-learning disable
By default, an EVPN instance learns MAC addresses from ARP information.
5.     Disable the EVPN instance from learning MAC addresses from ND information.
nd mac-learning disable
By default, an EVPN instance learns MAC addresses from ND information.
In an EVPN network with distributed gateways, you can disable ARP information advertisement for a VXLAN to save resources if all its user terminals use the same EVPN gateway device. The EVPN instance of the VXLAN will stop advertising ARP information through MAC/IP advertisement routes and withdraw advertised ARP information. When ARP information advertisement is disabled, user terminals in other VXLANs still can communicate with that VXLAN through IP prefix advertisement routes.
Disabling ARP information advertisement in VSI EVPN instance view
2.     Enter VSI view.
vsi vsi-name
4.     Disable ARP information advertisement for the EVPN instance.
arp-advertising disable
By default, ARP information advertisement is enabled for an EVPN instance.
In an EVPN network with distributed gateways, you can disable ND information advertisement for a VXLAN to save resources if all its user terminals use the same EVPN gateway device. The EVPN instance of the VXLAN will stop advertising ND information through MAC/IP advertisement routes and withdraw advertised ND information. When ND information advertisement is disabled, user terminals in other VXLANs still can communicate with that VXLAN through IP prefix advertisement routes.
Procedure (VSI EVPN instance view)
2.     Enter VSI view.
vsi vsi-name
4.     Enable ND information advertisement for the EVPN instance.
nd-advertising disable
By default, ND information advertisement is enabled for an EVPN instance.
On an EVPN VXLAN network deployed with a centralized EVPN gateway, VM 1 and VM 2 belong to the same VXLAN in subnet 10.1.1.0/24. The gateway interface is VSI-interface 1 and the gateway is connected to external Layer 3 network 10.1.2.0/24. The VTEP to which VM 2 is attached is configured with ARP or ND flood suppression. The IP address of VM 2 is mistakenly configured as an IP address in subnet 10.1.2.0/24 (for example, 10.1.2.2). In this situation, the VTEP connected to VM 2 advertises MAC/IP advertisement routes that contain ARP or ND information to the gateway. The IP address and MAC address in the routes are the IP address and MAC address of VM 2, respectively. The gateway learns the ARP or ND information and issues the information to the forwarding table. When VM 1 visits 10.1.2.2 in the external network, the gateway will forward the traffic to VM 2. As a result, VM 1 cannot visit 10.1.2.2.
To resolve the above issue, perform this task on the VSI interface to disable the VSI interface from learning ARP or ND information across subnets from MAC/IP advertisement routes.
2.     Enter VSI interface view on a centralized EVPN gateway.
3.     Disable the VSI interface from learning ARP or ND information that does not belong to its subnet from MAC/IP advertisement routes.
evpn span-segment { arp-learning | nd-learning } disable
By default, the VSI interface on a centralized EVPN gateway learns ARP or ND information that does not belong to its subnet from MAC/IP advertisement routes.
On an EVPN VXLAN network, misconfiguration of IP addresses might cause two sites to contain the same IP address. In this condition, VTEPs at the two sites constantly synchronize and update EVPN ARP entries and determine that ARP mobility events occur. As a result, an inter-site loop might occur, and the bandwidth is occupied by ARP entry synchronization traffic. To eliminate loops and suppress those ARP mobility events, enable ARP mobility event suppression on the VTEPs.
The ARP mobility event suppression feature allows an IP address to move at most the specified number of times (ARP mobility suppression threshold) out of a site within an ARP mobility detection cycle. If the suppression threshold has been reached for an IP address within a detection cycle, the VTEP at the site suppresses the subsequent move after the IP address moves back to the site. In addition, the VTEP learns ARP information for the IP address but does not advertise the ARP information.
ARP mobility event suppression takes effect only on an EVPN VXLAN network configured with distributed VXLAN IP gateways.
After you execute the undo evpn route arp-mobility suppression command or when the ARP mobility suppression time expires, a VTEP acts as follows:
·     Advertises ARP information immediately for the suppressed ARP entries that have not aged out.
·     Relearns ARP information for the suppressed ARP entries that have aged out and advertises the ARP information.
The ARP mobility event suppression setting configured in system view takes effect on all EVPN instances. The ARP mobility event suppression setting configured in EVPN instance view takes effect on all associated VSIs. The ARP mobility event suppression setting configured in VSI EVPN instance view takes effect only on the associated VSI. The ARP mobility event suppression setting configured in Layer 3 interface view takes effect only on that interface.
The ARP mobility event suppression settings configured in the following views are in descending order of priority:
3.     System view.
Enabling ARP mobility event suppression in system view
2.     Enable ARP mobility event suppression.
evpn route arp-mobility suppression [ detect-cycle detect-time | detect-threshold move-times | suppression-time [ suppression-time | permanent ] ] *
By default, ARP mobility event suppression is disabled.
Enabling ARP mobility event suppression in VSI EVPN instance view
2.     Enter VSI view.
vsi vsi-name
4.     Enable ARP mobility event suppression.
Enabling ARP mobility event suppression in Layer 3 interface view
3.     Enable ARP mobility event suppression.
ARP request proxy allows a VSI interface to send an ARP request sourced from itself when the VTEP forwards an ARP request. This feature helps resolve certain communication issues.
In an EVPN VXLAN network, VM 1 and VM 2 are attached to VTEP 1 and VTEP 2, respectively, and the VMs are in the same subnet. The gateway interfaces of VM 1 and VM 2 are VSI-interface 1 on VTEP 1 and VSI-interface 2 on VTEP 2, respectively. The following conditions exist on the VTEPs:
·     The VTEPs have established BGP EVPN neighbor relationships.
·     EVPN is disabled from learning MAC addresses from ARP information.
·     MAC address advertisement is disabled, and advertised MAC addresses are withdrawn.
·     Remote-MAC address learning is disabled.
·     Local proxy ARP is enabled on the VSI interfaces.
·     The VSI interfaces use different IP addresses and MAC addresses.
In this network, when VM 1 attempts to communicate with VM 2, the following procedure occurs:
1.     VM 1 sends an ARP request.
2.     VTEP 1 learns the MAC address of VM 1 from the ARP request, replies to VM 1 on behalf of VM 2, and sends an ARP request to obtain the MAC address of VM 2.
3.     VTEP 2 forwards the ARP request, and VM 2 replies to VTEP 1.
4.     VTEP 2 forwards the ARP reply sent by VM 2 without learning the MAC address of VM 2 because EVPN is disabled from learning MAC addresses from ARP information.
5.     VTEP 1 does not learn the MAC address of VM 2 because remote-MAC address learning is disabled.
As a result, VM 1 fails to communicate with VM 2.
For VM 1 to communicate with VM 2, enable ARP request proxy on VSI-interface 2 of VTEP 2. When receiving the ARP request sent by VTEP 1, VTEP 2 forwards it and sends an ARP request sourced from VSI-interface 2 simultaneously, and VM 2 replies to both ARP requests. Then, VTEP 2 learns the MAC address of VM 2 from the ARP reply destined from VSI-interface 2 and advertises the MAC address to VTEP 1 through BGP EVPN routes. In this way, VTEP 1 obtains the MAC address of VM 2, and VM 1 and VM 2 can communicate.
2.     Enter VSI interface view.
3.     Enable ARP request proxy.
arp proxy-send enable
By default, ARP request proxy is disabled on VSI interfaces.
On an EVPN VXLAN network, misconfiguration of IP addresses might cause two sites to contain the same IP address. In this condition, VTEPs at the two sites constantly synchronize and update EVPN ND entries and determine that ND mobility events occur. As a result, an inter-site loop might occur, and the bandwidth is occupied by ND entry synchronization traffic. To eliminate loops and suppress those ND mobility events, enable ND mobility event suppression on the VTEPs. This feature allows an IP address to move a specified number of times (the ND mobility suppression threshold) from a site within an ND mobility detection cycle. If an IP address moves more than the ND mobility suppression threshold, the VTEP at the site will suppress the last ND move to the local site and will not advertise ND information for the IP address.
After you execute the undo evpn route nd-mobility suppression command or the suppression time expires, a VTEP acts as follows:
·     Advertises ND information immediately for the suppressed ND entries that have not aged out.
·     Relearns ND information for the suppressed ND entries that have aged out and advertises the ND information.
ND mobility event suppression takes effect only on the following EVPN VXLAN networks:
·     EVPN VXLAN network enabled with ND flood suppression.
·     EVPN VXLAN network configured with distributed VXLAN IP gateways.
If both MAC address entry conflicts and ND entry conflicts exist for a MAC address, you must enable both MAC mobility event suppression and ND mobility event suppression. If you enable only MAC mobility event suppression, the system cannot suppress MAC mobility events for the MAC address.
The ND mobility event suppression setting configured in system view takes effect on all EVPN instances. The ND mobility event suppression setting configured in EVPN instance view takes effect on all associated VSIs. The ND mobility event suppression setting configured in VSI EVPN instance view takes effect only on the associated VSI. The ND mobility event suppression setting configured in Layer 3 interface view takes effect only on that interface.
The ND mobility event suppression settings configured in the following views are in descending order of priority:
3.     System view.
Enabling ND mobility event suppression in system view
2.     Enable ND mobility event suppression.
evpn route nd-mobility suppression [ detect-cycle detect-time | detect-threshold move-times | suppression-time [ suppression-time | permanent ] ] *
By default, ND mobility event suppression is disabled.
Enabling ND mobility event suppression in VSI EVPN instance view
2.     Enter VSI view.
vsi vsi-name
4.     Enable ND mobility event suppression.
Enabling ND mobility event suppression in Layer 3 interface view
3.     Enable ND mobility event suppression.
Configuring BGP EVPN route redistribution and advertisement
This task enables the device to redistribute received MAC/IP advertisement routes that contain ARP or ND information into a BGP unicast routing table.
·     If you perform this task for the BGP IPv4 or IPv6 unicast address family, the device will redistribute the routes into the BGP IPv4 or IPv6 unicast routing table. In addition, the device will advertise the routes to the local site.
·     If you perform this task for the BGP-VPN IPv4 or IPv6 unicast address family, the device will redistribute the routes into the BGP-VPN IPv4 or IPv6 unicast routing table of the corresponding VPN instance. To advertise the routes to the local site, you must configure the advertise l2vpn evpn command.
Procedure (BGP instance view)
3.     Enter BGP IPv4 or IPv6 unicast address family view.
address-family { ipv4 | ipv6 }
4.     Redistribute MAC/IP advertisement routes that contain ARP or ND information into the BGP IPv4 or IPv6 unicast routing table.
import evpn mac-ip
By default, MAC/IP advertisement routes that contain ARP or ND information are not redistributed into the BGP IPv4 or IPv6 unicast routing table.
Procedure (BGP-VPN instance view)
3.     Enter BGP-VPN instance view.
4.     Enter BGP-VPN IPv4 or IPv6 unicast address family view.
5.     Redistribute MAC/IP advertisement routes that contain ARP or ND information into the BGP-VPN IPv4 or IPv6 unicast routing table.
import evpn mac-ip
By default, MAC/IP advertisement routes that contain ARP or ND information are not redistributed into the BGP-VPN IPv4 or IPv6 unicast routing table.
After you perform this task, the device sets the metric of a BGP EVPN route added to a VPN instance's routing table to the metric of the IGP route pointing to the next hop in the original BGP EVPN route.
4.     Set the metric of a BGP EVPN route added to a VPN instance's routing table to the metric of the IGP route pointing to the next hop in the original BGP EVPN route.
igp-metric inherit
By default, the device sets the metric to 0 when adding BGP EVPN routes a VPN instance's routing table.
This feature enables the device to advertise private BGP EVPN routes to the local site after the device adds the routes to the routing table of a VPN instance.
Procedure (IPv4)
4.     Enter BGP-VPN IPv4 unicast address family view.
5.     Enable BGP EVPN route advertisement to the local site.
By default, BGP EVPN route advertisement to the local site is enabled.
Procedure (IPv6)
4.     Enter BGP-VPN IPv6 unicast address family view.
By default, the VTEP floods broadcast, unknown unicast, and unknown multicast frames received from the local site to the following interfaces in the frame's VXLAN:
·     All site-facing interfaces except for the incoming interface.
·     All VXLAN tunnel interfaces.
When receiving broadcast, unknown unicast, and unknown multicast frames on VXLAN tunnel interfaces, the device floods the frames to all site-facing interfaces in the frames' VXLAN.
To confine a kind of flood traffic, disable flooding for that kind of flood traffic on the VSI bound to the VXLAN.
You can use selective flood to exclude a remote MAC address from the remote flood suppression done by using the flooding disable command. The VTEP will flood the frames destined for the specified MAC address to remote sites when floods are confined to the local site.
2.     Enter VSI view.
vsi vsi-name
3.     Disable flooding for the VSI.
flooding disable { all | { broadcast | unknown-multicast | unknown-unicast } * } [ all-direction ]
By default, flooding is enabled for a VSI.
4.     (Optional.) Enable selective flood for a MAC address.
selective-flooding mac-address mac-address
Use ARP or ND flood suppression to reduce ARP or ND request broadcasts.
The aging timer is fixed at 25 minutes for ARP or ND flood suppression entries. If the flooding disable command is configured, set the MAC aging timer to a higher value than the aging timer for ARP or ND flood suppression entries on all VTEPs. This setting prevents the traffic blackhole that occurs when a MAC address entry ages out before its ARP or ND flood suppression entry ages out. To set the MAC aging timer, use the mac-address timer command.
When remote ARP or ND learning is disabled for VXLANs, the device does not use ARP or ND flood suppression entries to respond to ARP or ND requests received on VXLAN tunnels.
To delete ARP flood suppression entries, use the reset arp suppression vsi command instead of the reset arp command. For more information about the reset arp suppression vsi command, see VXLAN Command Reference. For more information about the reset arp command, see ARP commands in Layer 3—IP Services Command Reference.
The device does not support ND flood suppression.
Enabling ARP flood suppression
2.     Enter VSI view.
vsi vsi-name
3.     Enable ARP flood suppression.
arp suppression enable
By default, ARP flood suppression is disabled.
If SNMP notifications are enabled for EVPN, a MAC mobility suppression notification is sent to SNMP module after the MAC mobility suppression threshold is reached. For SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
2.     Enable SNMP notifications for EVPN.
snmp-agent trap enable evpn [ mac-mobility-suppression ]
By default, SNMP notifications are disabled for EVPN.
Verifying and maintaining EVPN VXLAN
Displaying EVPN running status and statistics
·     Display BGP peer group information.
display bgp [ instance instance-name ] group l2vpn evpn [ group-name group-name ]
For more information about this command, see basic BGP commands in Layer 3—IP Routing Command Reference.
·     Display BGP peer or peer group information.
display bgp [ instance instance-name ] peer l2vpn evpn [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ]
·     Display information about BGP update groups.
display bgp [ instance instance-name ] update-group l2vpn evpn [ ipv4-address ]
·     Display information about IPv4 peers that are automatically discovered through BGP.
display evpn auto-discovery { imet [ peer ip-address ] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
·     Display EVPN instance information.
display evpn instance [ name instance-name | vsi vsi-name ]
·     Display VSI information.
display l2vpn vsi [ name vsi-name | evpn-vxlan ] [ count | verbose ]
·     Display EVPN ES information.
display evpn es { local [ count | [ vsi vsi-name ] [ esi esi-id ] [ verbose ] ] | remote [ vsi vsi-name ] [ esi esi-id ] [ nexthop next-hop ] [ verbose ] }
·     Display DF election information.
display evpn df-election [ vsi vsi-name ] [ esi esi-id ]
·     Display site-facing interfaces excluded from traffic forwarding by split horizon.
display l2vpn forwarding evpn split-horizon { ac interface interface-type interface-number | ac interface interface-type interface-number service-instance instance-id | tunnel tunnel-number } [ slot slot-number ]
·     Display information about IPv6 peers that are automatically discovered through BGP.
display evpn ipv6 auto-discovery { { imet | mac-ip } [ vxlan ] [ peer ipv6-address ] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
·     Display EVPN routing table information.
display evpn routing-table [ ipv6 ] { public-instance | vpn-instance vpn-instance-name } [ count ]
·     Display BGP EVPN routes.
display bgp [ instance instance-name ] l2vpn evpn [ peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ statistics ] | [ route-distinguisher route-distinguisher | route-type { auto-discovery | es | igmp-js | igmp-ls | imet | ip-prefix | mac-ip | smet } ] * [ { evpn-route route-length | evpn-prefix } [ advertise-info | as-path | cluster-list | community | ext-community ] | ipv4-address | ipv6-address | mac-address ] | statistics ]
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ statistics ] community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ]
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ statistics ] community-list { basic-community-list-number | comm-list-name | adv-community-list-number } [ whole-match ]
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ statistics ] ext-community [ bandwidth link-bandwidth-value | rt route-target | soo site-of-origin | color color ]&<1-32> [ whole-match ]
Verifying MAC address information and ARP and ND information
·     Display IPv4 EVPN MAC address entries.
display evpn route mac [ vxlan ] [ local | remote ] [ vsi vsi-name ] [ mac-address mac-address ] [ count ]
·     Display EVPN ARP entries.
display evpn route arp [ local | remote ] [ public-instance | vpn-instance vpn-instance-name [ ip ipv4-address ] ] [ count ]
·     Display ARP flood suppression entries.
display evpn route arp suppression [ vxlan ] [ local | remote ] [ vsi vsi-name ] [ ip ipv4-address ] [ count ]
·     Display EVPN ND entries.
display evpn route nd [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ ipv6 ipv6-address ] [ count ]
·     Display ND flood suppression entries.
display evpn route nd suppression [ local | remote ] [ vsi vsi-name ] [ ipv6 ipv6-address ] [ count ]
·     Display EVPN ARP mobility information.
display evpn route arp-mobility [ public-instance | vpn-instance vpn-instance-name ] [ ip ip-address ] [ verbose ]
·     Display EVPN MAC mobility information.
display evpn route mac-mobility [ evpn-instance instance-name | interface interface-type interface-number | vsi vsi-name ] [ mac-address mac-address ] [ verbose ]
·     Display EVPN ND mobility information.
display evpn route nd-mobility [ public-instance | vpn-instance vpn-instance-name ] [ ipv6 ipv6-address ] [ verbose ]
Advertising suppressed MAC addresses and ARP/ND information for suppressed IP addresses
Perform reset tasks in user view.
·     Advertise suppressed MAC addresses for one time.
reset evpn route mac-mobility suppression [ evpn-instance instance-name | interface interface-type interface-number  | vsi vsi-name ] [ mac mac-address ]
·     Advertise ARP information for suppressed IP addresses for one time.
reset evpn route arp-mobility suppression [ public-instance | vpn-instance vpn-instance-name [ ip ip-address ] ]
·     Advertise ND information for suppressed IP addresses for one time.
reset evpn route nd-mobility suppression [ public-instance | vpn-instance vpn-instance-name [ ipv6 ipv6-address ] ]
EVPN VXLAN configuration examples
Example: Configuring a centralized IPv4 EVPN gateway
As shown in Figure 18:
·     Configure VXLAN 10 and VXLAN 20 on Router A, Router B, and Router C to provide connectivity for the VMs in the VXLANs across the network sites.
·     Configure Router C as a centralized EVPN gateway to provide gateway services and access to the connected Layer 3 network.
·     Configure Router D as an RR to reflect BGP EVPN routes between Router A, Router B, and Router C.
Figure 18 Network diagram
1.     On VM 1 and VM 3, specify 10.1.1.1 as the gateway address. On VM 2 and VM 4, specify 10.1.2.1 as the gateway address. (Details not shown.)
2.     Configure IP addresses and unicast routing settings:
# Assign IP addresses to interfaces, as shown in Figure 18. (Details not shown.)
# Configure OSPF on all transport network routers (Routers A through D) for them to reach one another. (Details not shown.)
3.     Configure Router A:
# Enable L2VPN.
[RouterA] l2vpn enable
# Disable remote MAC address learning and remote ARP learning.
[RouterA] vxlan tunnel mac-learning disable
[RouterA] vxlan tunnel arp-learning disable
# Create an EVPN instance on VSI vpna, and configure the router to automatically generate an RD and a route target for the EVPN instance.
[RouterA] vsi vpna
[RouterA-vsi-vpna] arp suppression enable
[RouterA-vsi-vpna] evpn encapsulation vxlan
[RouterA-vsi-vpna-evpn-vxlan] route-distinguisher auto
[RouterA-vsi-vpna-evpn-vxlan] vpn-target auto
[RouterA-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[RouterA-vsi-vpna] vxlan 10
[RouterA-vsi-vpna-vxlan-10] quit
[RouterA-vsi-vpna] quit
# Create an EVPN instance on VSI vpnb, and configure the router to automatically generate an RD and a route target for the EVPN instance.
[RouterA] vsi vpnb
[RouterA-vsi-vpnb] arp suppression enable
[RouterA-vsi-vpnb] evpn encapsulation vxlan
[RouterA-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[RouterA-vsi-vpnb-evpn-vxlan] vpn-target auto
[RouterA-vsi-vpnb-evpn-vxlan] quit
# Create VXLAN 20.
[RouterA-vsi-vpnb] vxlan 20
[RouterA-vsi-vpnb-vxlan-20] quit
[RouterA-vsi-vpnb] quit
# Configure BGP to advertise BGP EVPN routes.
[RouterA] bgp 200
[RouterA-bgp-default] peer 4.4.4.4 as-number 200
[RouterA-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[RouterA-bgp-default] address-family l2vpn evpn
[RouterA-bgp-default-evpn] peer 4.4.4.4 enable
[RouterA-bgp-default-evpn] quit
[RouterA-bgp-default] quit
# Map GigabitEthernet 1/0/1 to VSI vpna.
[RouterA-GigabitEthernet1/0/1] xconnect vsi vpna
# Map GigabitEthernet 1/0/2 to VSI vpnb.
[RouterA-GigabitEthernet1/0/2] xconnect vsi vpnb
4.     Configure Router B:
# Enable L2VPN.
<RouterB> system-view
[RouterB] l2vpn enable
[RouterB] vxlan tunnel mac-learning disable
[RouterB] vxlan tunnel arp-learning disable
[RouterB] vsi vpna
[RouterB-vsi-vpna] arp suppression enable
[RouterB-vsi-vpna] evpn encapsulation vxlan
[RouterB-vsi-vpna-evpn-vxlan] route-distinguisher auto
[RouterB-vsi-vpna-evpn-vxlan] vpn-target auto
[RouterB-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[RouterB-vsi-vpna] vxlan 10
[RouterB-vsi-vpna-vxlan-10] quit
[RouterB-vsi-vpna] quit
[RouterB] vsi vpnb
[RouterB-vsi-vpnb] arp suppression enable
[RouterB-vsi-vpnb] evpn encapsulation vxlan
[RouterB-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[RouterB-vsi-vpnb-evpn-vxlan] vpn-target auto
[RouterB-vsi-vpnb-evpn-vxlan] quit
# Create VXLAN 20.
[RouterB-vsi-vpnb] vxlan 20
[RouterB-vsi-vpnb-vxlan-20] quit
[RouterB-vsi-vpnb] quit
[RouterB] bgp 200
[RouterB-bgp-default] peer 4.4.4.4 as-number 200
[RouterB-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[RouterB-bgp-default] address-family l2vpn evpn
[RouterB-bgp-default-evpn] peer 4.4.4.4 enable
[RouterB-bgp-default-evpn] quit
[RouterB-bgp-default] quit
[RouterB-GigabitEthernet1/0/1] xconnect vsi vpna
[RouterB-GigabitEthernet1/0/2] xconnect vsi vpnb
5.     Configure Router C:
# Enable L2VPN.
<RouterC> system-view
[RouterC] l2vpn enable
[RouterC] vxlan tunnel mac-learning disable
[RouterC] vxlan tunnel arp-learning disable
[RouterC] vsi vpna
[RouterC-vsi-vpna] arp suppression enable
[RouterC-vsi-vpna] evpn encapsulation vxlan
[RouterC-vsi-vpna-evpn-vxlan] route-distinguisher auto
[RouterC-vsi-vpna-evpn-vxlan] vpn-target auto
[RouterC-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[RouterC-vsi-vpna] vxlan 10
[RouterC-vsi-vpna-vxlan-10] quit
[RouterC-vsi-vpna] quit
[RouterC] vsi vpnb
[RouterC-vsi-vpnb] evpn encapsulation vxlan
[RouterC-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[RouterC-vsi-vpnb-evpn-vxlan] vpn-target auto
[RouterC-vsi-vpnb-evpn-vxlan] quit
# Create VXLAN 20.
[RouterC-vsi-vpnb] vxlan 20
[RouterC-vsi-vpnb-vxlan-20] quit
[RouterC-vsi-vpnb] quit
[RouterC] bgp 200
[RouterC-bgp-default] peer 4.4.4.4 as-number 200
[RouterC-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[RouterC-bgp-default] address-family l2vpn evpn
[RouterC-bgp-default-evpn] peer 4.4.4.4 enable
[RouterC-bgp-default-evpn] quit
[RouterC-bgp-default] quit
# Create VSI-interface 1 and assign the interface an IP address. The IP address will be used as the gateway address for VXLAN 10.
[RouterC] interface vsi-interface 1
[RouterC-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[RouterC-Vsi-interface1] quit
# Specify VSI-interface 1 as the gateway interface for VSI vpna.
[RouterC] vsi vpna
[RouterC-vsi-vpna] gateway vsi-interface 1
# Create VSI-interface 2 and assign the interface an IP address. The IP address will be used as the gateway address for VXLAN 20.
[RouterC] interface vsi-interface 2
[RouterC-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[RouterC-Vsi-interface2] quit
# Specify VSI-interface 2 as the gateway interface for VSI vpnb.
[RouterC] vsi vpnb
[RouterC-vsi-vpnb] gateway vsi-interface 2
6.     Configure Router D:
# Establish BGP connections with other transport network routers.
<RouterD> system-view
[RouterD] bgp 200
[RouterD-bgp-default] group evpn
[RouterD-bgp-default] peer 1.1.1.1 group evpn
[RouterD-bgp-default] peer 2.2.2.2 group evpn
[RouterD-bgp-default] peer 3.3.3.3 group evpn
[RouterD-bgp-default] peer evpn as-number 200
[RouterD-bgp-default] peer evpn connect-interface loopback 0
# Configure BGP to advertise BGP EVPN routes, and disable route target filtering for BGP EVPN routes.
[RouterD-bgp-default] address-family l2vpn evpn
[RouterD-bgp-default-evpn] peer evpn enable
[RouterD-bgp-default-evpn] undo policy vpn-target
# Configure Router D as an RR.
[RouterD-bgp-default-evpn] peer evpn reflect-client
[RouterD-bgp-default-evpn] quit
[RouterD-bgp-default] quit
1.     Verify the EVPN gateway settings on Router C:
# Verify that Router C has advertised MAC/IP advertisement routes and IMET routes for the gateways and received MAC/IP advertisement routes and IMET routes from Router A and Router B. (Details not shown.)
# Verify that the VXLAN tunnel interfaces are up on Router C.
[RouterC] display interface tunnel
Tunnel0
Interface index: 261
Current state: UP
Line protocol state: UP
Bandwidth: 64 kbps
Tunnel source 3.3.3.3, destination 2.2.2.2
Tunnel1
Interface index: 262
Current state: UP
Bandwidth: 64 kbps
Tunnel source 3.3.3.3, destination 1.1.1.1
Input: 277 packets, 20306 bytes, 0 drops
Output: 1099 packets, 0 bytes, 0 drops
# Verify that the VSI interfaces are up on Router C.
[RouterC] display interface vsi-interface
Vsi-interface1
Interface index: 263
Current state: UP
Description: Vsi-interface1 Interface
Bandwidth: 1000000 kbps
IP packet frame type: Ethernet II, hardware address: 0003-0003-0003
IPv6 packet frame type: Ethernet II, hardware address: 0003-0003-0003
Vsi-interface2
Interface index: 264
Current state: UP
Description: Vsi-interface2 Interface
# Verify that the VXLAN tunnels have been assigned to the VXLANs, and the VSI interfaces are the gateway interfaces of their respective VXLANs.
[RouterC] display l2vpn vsi verbose
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Diffserv Mode           : -
  Bandwidth               : -
  Broadcast Restrain      : -
  Multicast Restrain      : -
  Unknown Unicast Restrain: -
  MAC Learning            : -
  MAC Table Limit         : -
  MAC Learning rate       : -
  Drop Unknown            : -
  PW Redundancy Mode      : Independent
  DSCP                    : -
  Service Class           : -
  ESI                     : 0000.0000.0000.0000.0000
  Redundancy Mode         : All-active
  Statistics              : Disabled
  Gateway Interface       : VSI-interface 1
  VXLAN ID                : 10
  EVPN Encapsulation      : VXLAN
  Tunnels:
    Tunnel Name          Link ID    State    Type        Flood Proxy
    Tunnel0              0x5000000  UP       Auto        Disabled
    Tunnel1              0x5000001  UP       Auto        Disabled
VSI Name: vpnb
  VSI Index               : 1
  VSI State               : Up
  Diffserv Mode           : -
  Bandwidth               : -
  MAC Learning            : -
  MAC Table Limit         : -
  Drop Unknown            : -
  DSCP                    : -
  Service Class           : -
  Gateway Interface       : VSI-interface 2
  VXLAN ID                : 20
  Tunnels:
# Verify that Router C has created EVPN ARP entries for the VMs.
[RouterC] display evpn route arp
Flags: D - Dynamic   B - BGP      L - Local active
       G - Gateway   S - Static   M - Mapping
Public instance                               Interface: Vsi-interface1
IP address      MAC address     Router MAC      VSI index   Flags
10.1.1.1        0003-0003-0003  -               0           GL
10.1.1.10       0000-1234-0001  -               0           B
10.1.1.20       0000-1234-0003  -               0           B
Public instance                               Interface: Vsi-interface2
10.1.2.1        0005-0005-0005  -               1           GL
10.1.2.10       0000-1234-0002  -               1           B
10.1.2.20       0000-1234-0004  -               1           B
# Verify that Router C has created FIB entries for the VMs.
[RouterC] display fib 10.1.1.10
Flag:
  U:Usable    G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
  R:Relay     F:FRR
10.1.1.10/32       10.1.1.10       UH       Vsi1                     Null
2.     Verify that VM 1, VM 2, VM 3, and VM 4 can communicate with one another. (Details not shown.)
Example: Configuring distributed IPv4 EVPN gateways in symmetric IRB mode
As shown in Figure 19:
·     Configure VXLAN 10 and VXLAN 20 on Router A and Router B to provide connectivity for the VMs in the VXLANs across the network sites.
·     Configure Router A and Router B as distributed EVPN gateways to provide gateway services in symmetric IRB mode. Configure Router C as a border gateway to provide access to the connected Layer 3 network.
Figure 19 Network diagram
# Assign IP addresses to interfaces, as shown in Figure 19. (Details not shown.)
# Enable L2VPN.
[RouterA] vsi vpna
# Create VXLAN 10.
[RouterA] vsi vpnb
# Create VXLAN 20.
[RouterA] bgp 200
# Configure RD and route target settings for VPN instance l3vpna.
[RouterA] ip vpn-instance l3vpna
[RouterA-vpn-instance-l3vpna] route-distinguisher 1:1
[RouterA-vpn-instance-l3vpna] address-family ipv4
[RouterA-vpn-ipv4-l3vpna] vpn-target 2:2
[RouterA-vpn-ipv4-l3vpna] quit
[RouterA-vpn-instance-l3vpna] address-family evpn
[RouterA-vpn-evpn-l3vpna] vpn-target 1:1
[RouterA-vpn-evpn-l3vpna] quit
[RouterA-vpn-instance-l3vpna] quit
# Configure VSI-interface 1.
[RouterA] interface vsi-interface 1
[RouterA-Vsi-interface1] ip binding vpn-instance l3vpna
[RouterA-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[RouterA-Vsi-interface1] mac-address 1-1-1
[RouterA-Vsi-interface1] distributed-gateway local
[RouterA-Vsi-interface1] local-proxy-arp enable
[RouterA-Vsi-interface1] quit
# Configure VSI-interface 2.
[RouterA] interface vsi-interface 2
[RouterA-Vsi-interface2] ip binding vpn-instance l3vpna
[RouterA-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[RouterA-Vsi-interface2] mac-address 2-2-2
[RouterA-Vsi-interface2] distributed-gateway local
[RouterA-Vsi-interface2] local-proxy-arp enable
[RouterA-Vsi-interface2] quit
# Associate VSI-interface 3 with VPN instance l3vpna, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[RouterA] interface vsi-interface 3
[RouterA-Vsi-interface3] ip binding vpn-instance l3vpna
[RouterA-Vsi-interface3] l3-vni 1000
[RouterA-Vsi-interface3] quit
[RouterA] vsi vpna
[RouterA-vsi-vpna] gateway vsi-interface 1
[RouterA] vsi vpnb
[RouterA-vsi-vpnb] gateway vsi-interface 2
# Enable L2VPN.
[RouterB] vsi vpna
# Create VXLAN 10.
[RouterB] vsi vpnb
# Create VXLAN 20.
[RouterB] bgp 200
[RouterB] ip vpn-instance l3vpna
[RouterB-vpn-instance-l3vpna] route-distinguisher 1:1
[RouterB-vpn-instance-l3vpna] address-family ipv4
[RouterB-vpn-ipv4-l3vpna] vpn-target 2:2
[RouterB-vpn-ipv4-l3vpna] quit
[RouterB-vpn-instance-l3vpna] address-family evpn
[RouterB-vpn-evpn-l3vpna] vpn-target 1:1
[RouterB-vpn-evpn-l3vpna] quit
[RouterB-vpn-instance-l3vpna] quit
[RouterB] interface vsi-interface 1
[RouterB-Vsi-interface1] ip binding vpn-instance l3vpna
[RouterB-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[RouterB-Vsi-interface1] mac-address 1-1-1
[RouterB-Vsi-interface1] distributed-gateway local
[RouterB-Vsi-interface1] local-proxy-arp enable
[RouterB-Vsi-interface1] quit
[RouterB] interface vsi-interface 2
[RouterB-Vsi-interface2] ip binding vpn-instance l3vpna
[RouterB-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[RouterB-Vsi-interface2] mac-address 2-2-2
[RouterB-Vsi-interface2] distributed-gateway local
[RouterB-Vsi-interface2] local-proxy-arp enable
[RouterB-Vsi-interface2] quit
[RouterB] interface vsi-interface 3
[RouterB-Vsi-interface3] ip binding vpn-instance l3vpna
[RouterB-Vsi-interface3] l3-vni 1000
[RouterB-Vsi-interface3] quit
[RouterB] vsi vpna
[RouterB-vsi-vpna] gateway vsi-interface 1
[RouterB] vsi vpnb
[RouterB-vsi-vpnb] gateway vsi-interface 2
# Enable L2VPN.
[RouterC] bgp 200
[RouterC] ip vpn-instance l3vpna
[RouterC-vpn-instance-l3vpna] route-distinguisher 1:1
[RouterC-vpn-instance-l3vpna] address-family ipv4
[RouterC-vpn-ipv4-l3vpna] vpn-target 2:2
[RouterC-vpn-ipv4-l3vpna] quit
[RouterC-vpn-instance-l3vpna] address-family evpn
[RouterC-vpn-evpn-l3vpna] vpn-target 1:1
[RouterC-vpn-evpn-l3vpna] quit
[RouterC-vpn-instance-l3vpna] quit
[RouterC] interface vsi-interface 3
[RouterC-Vsi-interface3] ip binding vpn-instance l3vpna
[RouterC-Vsi-interface3] l3-vni 1000
[RouterC-Vsi-interface3] quit
# Configure a default route. The next hop is the IP address of a device in the Layer 3 network.
[RouterC] ip route-static vpn-instance l3vpna 0.0.0.0 0 20.1.1.100
# Import the default route to the BGP IPv4 unicast routing table of VPN instance l3vpna.
[RouterC] bgp 200
[RouterC-bgp-default] ip vpn-instance l3vpna
[RouterC-bgp-default-l3vpna] address-family ipv4 unicast
[RouterC-bgp-default-ipv4-l3vpna] default-route imported
[RouterC-bgp-default-ipv4-l3vpna] import-route static
[RouterC-bgp-default-ipv4-l3vpna] quit
[RouterC-bgp-default-l3vpna] quit
# Associate GigabitEthernet 1/0/2 with VPN instance l3vpna. GigabitEthernet 1/0/2 provides access to the Layer 3 network connected to Router C.
[RouterC-GigabitEthernet1/0/2] ip binding vpn-instance l3vpna
[RouterC-GigabitEthernet1/0/2] ip address 20.1.1.3 24
[RouterD] bgp 200
1.     Verify the distributed EVPN gateway settings on Router A:
# Verify that Router A has advertised the IP prefix advertisement routes for the gateways and the MAC/IP advertisement routes and IMET routes for each VSI. Verify that Router A has received the IP prefix advertisement routes for the gateways and the MAC/IP advertisement routes and IMET routes for each VSI from Router B. (Details not shown.)
# Verify that the VXLAN tunnel interfaces are up on Router A. (This example uses Tunnel 0.)
[RouterA] display interface tunnel 0
Tunnel0
Current state: UP
Bandwidth: 64 kbps
# Verify that the VSI interfaces are up on Router A. (This example uses VSI-interface 1.)
[RouterA] display interface vsi-interface 1
Vsi-interface1
Current state: UP
[RouterA] display l2vpn vsi verbose
VSI Name: Auto_L3VNI1000_3
  VSI Index               : 1
  VSI State               : Down
  Diffserv Mode           : -
  Bandwidth               : -
  MAC Learning            : -
  MAC Table Limit         : -
  Drop Unknown            : -
  DSCP                    : -
  Service Class           : -
  Gateway Interface       : VSI-interface 3
  VXLAN ID                : 1000
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Diffserv Mode           : -
  Bandwidth               : -
  MAC Learning            : -
  MAC Table Limit         : -
  Drop Unknown            : -
  DSCP                    : -
  Service Class           : -
  VXLAN ID                : 10
  Tunnels:
    Tunnel Name          Link ID    State  Type      Flood proxy
    Tunnel0              0x5000001  Up     Auto      Disabled
    Tunnel1              0x5000002  Up     Auto      Disabled
  ACs:
    AC                                                           Link ID    State         Type
    GE1/0/1                                             0x0        Up        Manual
    Statistics: Disabled
VSI Name: vpnb
  VSI Index               : 2
  VSI State               : Up
  Diffserv Mode           : -
  Bandwidth               : -
  MAC Learning            : -
  MAC Table Limit         : -
  Drop Unknown            : -
  DSCP                    : -
  Service Class           : -
  VXLAN ID                : 20
  Tunnels:
  ACs:
    GE1/0/2                                             0x1        Up        Manual
# Verify that Router A has created ARP entries for the VMs.
[RouterA] display arp
  Type: S-Static   D-Dynamic   O-Openflow   R-Rule   M-Multiport  I-Invalid
IP address      MAC address    VLAN/VSI name Interface                Aging Type
10.1.1.10       0000-1234-0001 0             GE1/0/1                  20    D
10.1.2.10       0000-1234-0002 0             GE1/0/2                  19    D
2.2.2.2         a0ce-5e24-0100 1             Tunnel0                  --    R
# Verify that Router A has created EVPN ARP entries for the local VMs.
[RouterA] display evpn route arp
VPN instance: l3vpna                          Interface:Vsi-interface1
IP address      MAC address     Router MAC      VSI Index   Flags
10.1.1.1        0001-0001-0001  a0ce-7e40-0400  0           GL
10.1.1.10       0000-1234-0001  a0ce-7e40-0400  0           DL
10.1.2.10       0000-1234-0002  a0ce-7e40-0400  0           DL
10.1.1.20       0000-1234-0003  a0ce-7e40-0400  0           B
10.1.2.20       0000-1234-0004  a0ce-7e40-0400  0           B
Example: Configuring distributed IPv6 EVPN gateways in symmetric IRB mode
As shown in Figure 20:
Figure 20 Network diagram
1.     On VM 1 and VM 3, specify 11::1 as the gateway address. On VM 2 and VM 4, specify 12::1 as the gateway address. (Details not shown.)
# Assign IP addresses to interfaces, as shown in Figure 20. (Details not shown.)
# Enable L2VPN.
# Disable remote MAC address learning and remote ND learning.
[RouterA] vxlan tunnel nd-learning disable
[RouterA] vsi vpna
# Create VXLAN 10.
[RouterA] vsi vpnb
# Create VXLAN 20.
[RouterA] bgp 200
[RouterA-vpn-instance-l3vpna] address-family ipv6
[RouterA-vpn-ipv6-l3vpna] vpn-target 2:2
[RouterA-vpn-ipv6-l3vpna] quit
[RouterA-Vsi-interface1] ipv6 address 11::1 64
[RouterA-Vsi-interface1] local-proxy-nd enable
[RouterA-Vsi-interface2] ipv6 address 12::1 64
[RouterA-Vsi-interface2] local-proxy-nd enable
[RouterA-Vsi-interface3] ipv6 address auto link-local
[RouterA] vsi vpna
[RouterA] vsi vpnb
# Enable L2VPN.
[RouterB] vxlan tunnel nd-learning disable
[RouterB] vsi vpna
# Create VXLAN 10.
[RouterB] vsi vpnb
# Create VXLAN 20.
[RouterB] bgp 200
[RouterB-vpn-instance-l3vpna] address-family ipv6
[RouterB-vpn-ipv6-l3vpna] vpn-target 2:2
[RouterB-vpn-ipv6-l3vpna] quit
[RouterB-Vsi-interface1] ipv6 address 11::1 64
[RouterB-Vsi-interface1] local-proxy-nd enable
[RouterB-Vsi-interface2] ipv6 address 12::1 64
[RouterB-Vsi-interface2] local-proxy-nd enable
[RouterB-Vsi-interface3] ipv6 address auto link-local
[RouterB] vsi vpna
[RouterB] vsi vpnb
# Enable L2VPN.
[RouterC] vxlan tunnel nd-learning disable
[RouterC] bgp 200
[RouterC-vpn-instance-l3vpna] address-family ipv6
[RouterC-vpn-ipv6-l3vpna] vpn-target 2:2
[RouterC-vpn-ipv6-l3vpna] quit
[RouterC-Vsi-interface3] ipv6 address auto link-local
[RouterC] ipv6 route-static vpn-instance l3vpna :: 0 20::100
# Import the default route to the BGP IPv6 unicast routing table of VPN instance l3vpna.
[RouterC] bgp 200
[RouterC-bgp-default-l3vpna] address-family ipv6 unicast
[RouterC-bgp-default-ipv6-l3vpna] default-route imported
[RouterC-bgp-default-ipv6-l3vpna] import-route static
[RouterC-bgp-default-ipv6-l3vpna] quit
# Associate VLAN-interface 20 with VPN instance l3vpna.
[RouterC] interface vlan-interface 20
[RouterC-Vlan-interface20] ip binding vpn-instance l3vpna
[RouterC-Vlan-interface20] ipv6 address 20::1 64
[RouterC-Vlan-interface20] quit
[RouterD] bgp 200
Tunnel0
Current state: UP
Bandwidth: 64 kbps
Vsi-interface1
Current state: UP
Maximum transmission unit: 1444
IP packet frame type: Ethernet II, hardware address: 0001-0001-0001
IPv6 packet frame type: Ethernet II, hardware address: 0001-0001-0001
# Verify that the VXLAN tunnels have been assigned to the VXLANs, and that the VSI interfaces are the gateway interfaces of their respective VXLANs.
  VSI Index               : 1
  VSI State               : Down
  Diffserv Mode           : -
  Bandwidth               : -
  MAC Learning            : -
  MAC Table Limit         : -
  Drop Unknown            : -
  DSCP                    : -
  Service Class           : -
  VXLAN ID                : 1000
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Diffserv Mode           : -
  Bandwidth               : -
  MAC Learning            : -
  MAC Table Limit         : -
  Drop Unknown            : -
  DSCP                    : -
  Service Class           : -
  VXLAN ID                : 10
  Tunnels:
  ACs:
VSI Name: vpnb
  VSI Index               : 2
  VSI State               : Up
  Diffserv Mode           : -
  Bandwidth               : -
  MAC Learning            : -
  MAC Table Limit         : -
  Drop Unknown            : -
  DSCP                    : -
  Service Class           : -
  VXLAN ID                : 20
  Tunnels:
  ACs:
# Verify that Router A has created EVPN ND entries for the local VMs.
[RouterA] display evpn route nd
       G - Gateway   S - Static   M - Mapping        I - Invalid
VPN instance: l3vpna                          Interface: Vsi-interface1
IPv6 address :   11::7
MAC address  :   0001-0001-0001       Router MAC   :   8291-a344-0400
VSI index    :   0                    Flags        :   GL
IPv6 address :   12::7
MAC address  :   0001-0002-0001       Router MAC   :   8291-7342-0200
IPv6 address :   11::8
MAC address  :   0001-0002-0002       Router MAC   :   8291-a342-0100
IPv6 address :   12::8
MAC address  :   0002-0002-0002       Router MAC   :   8291-a741-0420
IPv6 address :   11::11
MAC address  :   0003-0003-0003       Router MAC   :   a0ce-7e80-0460
