00-Preface
Preface
This document describes hardware information and specifications for H3C S5170-EI & S5570S-EI switch series, covering the product models and technical specifications, chassis views, removable components and their compatibilities, ports and LEDs, and cooling system.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S5170-EI & S5570S-EI switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
