08-IP Multicast Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SR6600[SR6600-X] Routers Configuration Guides(V7)-R8149-6W10008-IP Multicast Configuration Guide
07-Multicast VPN configuration
07-Multicast VPN configuration 2.14 MB
Multicast VPN overview·· 1
Typical network diagram·· 1
MVPN scheme· 1
Basic concepts in MDT-based MVPN· 1
How MDT-based MVPN works· 2
Default MDT establishment 2
Default MDT-based delivery· 6
MDT switchover 8
Inter-AS MDT-based MVPN· 8
Inter-AS option A MDT-based MVPN· 9
Inter-AS option B MDT-based MVPN· 9
Inter-AS option C MDT-based MVPN· 11
Basic concepts in RSVP-TE-based MVPN· 11
How RSVP-TE-based MVPN works· 12
RSVP-TE-based MVPN operation· 12
Inclusive tunnel establishment 12
Selective tunnel establishment and tunnel switchover 13
Basic concepts in mLDP-based MVPN· 14
How mLDP-based MVPN works· 14
mLDP-based MVPN operation· 14
Inclusive tunnel establishment 14
Selective tunnel establishment and tunnel switchover 15
Inter-AS mLDP-based MVPN· 16
Inter-AS option A mLDP-based MVPN· 16
Inter-AS option B mLDP-based MVPN· 17
Inter-AS option C mLDP-based MVPN· 18
MVPN extranet 19
M6VPE· 21
Protocols and standards· 22
Configuring multicast VPN·· 23
Multicast VPN tasks at a glance· 23
MDT-based MVPN tasks at a glance· 23
RSVP-TE-based MVPN tasks at a glance· 23
mLDP-TE-based MVPN tasks at a glance· 23
Configuring MDT-based MVPN· 24
Prerequisites for configuring MDT-based MVPN· 24
Enabling IP multicast routing for a VPN instance· 24
Creating an MDT-based MVPN instance· 25
Creating an MVPN address family· 25
Specifying the default group· 25
Specifying the MVPN source interface· 26
Configuring MDT switchover parameters· 26
Configuring the RPF vector feature· 27
Enabling data group reuse logging· 28
Configuring BGP MDT· 28
Configuring BGP MDT peers or peer groups· 28
Configuring a BGP MDT route reflector 29
Preferring routes learned from a peer or peer group during optimal route selection· 30
Configuring RSVP-TE-based MVPN· 30
Prerequisites for configuring RSVP-TE-based MVPN· 30
Enabling IP multicast routing for a VPN instance· 30
Configuring BGP IPv4 MVPN route exchange· 31
Allowing the device to add extended community attributes to C-multicast routes· 32
Creating an RSVP-TE-based MVPN instance· 32
Creating an MVPN IPv4 address family· 33
Specifying the MVPN source interface· 33
Enabling inclusive tunnel creation· 33
Enabling selective tunnel creation· 34
Setting the tunnel switchover delay· 34
Configuring mLDP-based MVPN· 35
Prerequisites for configuring mLDP-based MVPN· 35
Enabling IP multicast routing for a VPN instance· 35
Configuring BGP IPv4 MVPN route exchange· 36
Allowing the device to add extended community attributes to C-multicast routes· 36
Creating an mLDP-based MVPN instance· 37
Creating an MVPN IPv4 address family· 37
Specifying the MVPN source interface· 38
Enabling inclusive tunnel creation· 38
Enabling selective tunnel creation· 38
Setting the tunnel switchover delay· 39
Enabling inter-AS auto-discovery· 39
Display and maintenance commands for multicast VPN· 40
Multicast VPN configuration examples· 42
Example: Configuring intra-AS MDT-based MVPN· 42
Example: Configuring intra-AS RSVP-TE-based MVPN· 55
Example: Configuring intra-AS mLDP-based MVPN· 70
Example: Configuring intra-AS M6VPE· 84
Example: Configuring inter-AS option B MDT-based MVPN· 99
Example: Configuring inter-AS option C MDT-based MVPN· 112
Example: Configuring inter-AS option A mLDP-based MVPN· 126
Example: Configuring inter-AS option B mLDP-based MVPN· 143
Example: Configuring inter-AS option C mLDP-based MVPN· 158
Example: Configuring receiver-PE-based MVPN extranet 173
Troubleshooting MVPN· 182
A default MDT cannot be established· 182
An MVRF cannot be created· 182
Multicast VPN implements multicast delivery in VPNs.
As shown in Figure 1, VPN A contains Site 1 and Site 3, and VPN B contains Site 2 and Site 4.
Figure 1 Typical VPN networking diagram
VPN multicast traffic between the PEs and the CEs is transmitted on a per-VPN-instance basis. The public network multicast traffic between the PEs and the P device is transmitted through the public network. Multicast VPN provides independent multicast services for the public network, VPN A, and VPN B.
For more information about CEs, PEs and Ps, see MPLS Configuration Guide.
MVPN scheme
MVPN is used to implement multicast VPN. MVPN only requires the PEs to support multiple VPN instances and the public network provided by the service provider to support multicast. There is no need to upgrade CEs and Ps or change their original PIM configurations. The MVPN solution is transparent to CEs and Ps.
MVPN supports the following modes: MDT, RSVP-TE, and mLDP.
This section introduces the following basic concepts in MDT-based MVPN:
·     MVPN—An MVPN logically defines the transmission boundary of the multicast traffic of a VPN over the public network. It also physically identifies all the PEs that support that VPN instance on the public network. Different VPN instances correspond to different MVPNs.
·     Multicast distribution tree (MDT)—An MDT is a multicast distribution tree constructed by all PEs in the same VPN. MDT includes default MDT and data MDT.
·     Multicast tunnel (MT)—An MT is a tunnel that interconnects all PEs in an MVPN. The local PE encapsulates a VPN multicast packet into a public network multicast packet and forwards it through the MT over the public network. The remote PE decapsulates the public network multicast packet to get the original VPN multicast packet.
·     Multicast tunnel interface (MTI)—An MTI is the entrance or exit of an MT, equivalent to an entrance or exit of an MVPN. MTIs are automatically created when the MVPN for the VPN instance is created. PEs use the MTI to access the MT. The local PE sends VPN data out of the MTI. The remote PEs receive the private data from their MTIs. An MTI runs the same PIM mode as the VPN instance to which the MTI belongs. PIM is enabled on MTIs when a minimum of one interface in the VPN instance is enabled with PIM. When PIM is disabled on all interfaces in the VPN instance, PIM is also disabled on MTIs.
·     Default group—A default group is a unique multicast address assigned to each MVPN on the public network. It is the unique identifier of an MVPN on the public network and helps build the default MDT for an MVPN on the public network. A PE encapsulates a VPN multicast packet (a multicast protocol packet or a multicast data packet) into a public network multicast packet. The default group address is used as the public network multicast group.
·     Default MDT—A default MDT uses a default group address as its group address. In a VPN, the default MDT is uniquely identified by the default group. A default MDT is automatically created after the default group is specified and will always exist on the public network, regardless of the presence of any multicast services on the public network or the VPN.
·     Data group—An MVPN is assigned a unique data group for MDT switchover. The ingress PE selects a least used address from the data group range to encapsulate the VPN multicast packets when it receives the multicast traffic of the VPN. Other PEs are notified to use the address to forward the multicast traffic for that VPN. This initiates the switchover to the data MDT.
·     Data MDT—A data MDT is an MDT that uses a data group as it group address. At MDT switchover, PEs with downstream receivers join a data group to build a data MDT. The ingress PE forwards the encapsulated VPN multicast traffic along the data MDT over the public network.
For a VPN instance, multicast data transmission on the public network is transparent. The VPN data is exchanged between the MTIs of the local PE and the remote PE. This implements the seamless transmission of the VPN data over the public network. However, the multicast data transmission process (the MDT transmission process) over the public network is very complicated.
The following types of PIM neighboring relationships exist in MVPN:
·     PE-P PIM neighboring relationship—Established between the public network interface on a PE and the peer interface on the P device over the link.
·     PE-PE PIM neighboring relationship—Established between PEs that are in the same VPN instance after they receive the PIM hello packets.
·     PE-CE PIM neighboring relationship—Established between a PE interface that is bound with the VPN instance and the peer interface on the CE over the link.
The multicast routing protocol running on the public network can be PIM-DM, PIM-SM, BIDIR-PIM, or PIM-SSM. The process of creating a default MDT is different in these PIM modes.
For each PIM mode running on the public network, the default MDT has the following characteristics in common:
·     All PEs that support the same VPN instance join the default MDT.
·     All multicast packets that belong to this VPN are forwarded along the default MDT to every PE on the public network, even if no active downstream receivers exist.
Default MDT establishment in a PIM-DM network
As shown in Figure 2, PIM-DM is enabled on the network, and all PEs support VPN instance A. All PEs establish PIM neighboring relationship among each other and build independent SPTs to constitute a default MDT in the MVPN.
Figure 2 Default MDT establishment in a PIM-DM network
The process of establishing a default MDT is as follows:
1.     To establish PIM neighboring relationships with PE 2 and PE 3 through the MTI for VPN instance A, PE 1 does the following:
a.     Encapsulates the PIM protocol packet of the private network into a public network multicast data packet. PE 1 does this by specifying the source address as the IP address of the MVPN source interface and the multicast group address as the default group address.
b.     Sends the multicast data packet to the public network.
For other PEs that support VPN instance A as default group members, PE 1 of VPN instance A initiates a flood-prune process in the entire public network. A (11.1.1.1, 239.1.1.1) state entry is created on each device along the path on the public network. This forms an SPT with PE 1 as the root, and PE 2 and PE 3 as leaves.
2.     At the same time, PE 2 and PE 3 separately initiate a similar flood-prune process.
Finally, three independent SPTs are established in the MVPN, constituting the default MDT in the PIM-DM network.
Default MDT establishment in a PIM-SM network
As shown in Figure 3, PIM-SM is enabled on the network, and all PEs support VPN instance A. All PEs establish PIM neighboring relationship among each other and build independent SPTs to constitute a default MDT in the MVPN with an RPT.
Figure 3 Default MDT establishment in a PIM-SM network
1.     PE 1 initiates a join to the public network RP by specifying the multicast group address as the default group address in the join message. A (*, 239.1.1.1) state entry is created on each device along the path on the public network.
2.     At the same time, PE 2 and PE 3 separately initiate a similar join process.
Finally, an RPT is established in the MVPN, with the public network RP as the root and PE 1, PE 2, and PE 3 as leaves.
3.     To establish PIM neighboring relationships with PE 2 and PE 3 through the MTI for VPN instance A, PE 1 does the following:
The public network interface of PE 1 registers the multicast source with the public network RP, and the public network RP initiates a join to PE 1. A (11.1.1.1, 239.1.1.1) state entry is created on each device along the path on the public network.
4.     At the same time, PE 2 and PE 3 separately initiate a similar register process.
Finally, three SPTs between the PEs and the RP are established in the MVPN.
In the PIM-SM network, the RPT, or the (*, 239.1.1.1) tree, and the three independent SPTs constitute the default MDT.
Default MDT establishment in a BIDIR-PIM network
As shown in Figure 4, BIDIR-PIM runs on the network, and all PEs support VPN instance A. All PEs establish PIM neighboring relationship among each other and build receiver-side and source-side RPTs to constitute a default MDT in the MVPN.
Figure 4 Default MDT establishment in a BIDIR-PIM network
At the same time, PE 2 and PE 3 separately initiate a similar join process. Finally, a receiver-side RPT is established in the MVPN, with the public network RP as the root and PE 1, PE 2, and PE 3 as leaves.
2.     PE 1 sends a multicast packet with the default group address as the multicast group address. The DF of each network segment on the public network forwards the multicast packet to the RP. Each device on the path creates a (*, 239.1.1.1) state entry.
At the same time, PE 2 and PE 3 separately initiate a similar process. Finally, three source-side RPTs are established in the MVPN, with PE 1, PE 2, and PE 3 as the roots and as the public network RP as the leave.
3.     The receiver-side RPT and the three source-side RPTs constitute the default MDT in the BIDIR-PIM network.
Default MDT establishment in a PIM-SSM network
As shown in Figure 5, PIM-SSM runs on the network, and all the PEs support VPN instance A. All PEs establish PIM neighboring relationship among each other and build independent SPTs to constitute a default MDT in the MVPN.
Figure 5 Default MDT establishment in a PIM-SSM network
1.     PE 1, PE 2, and PE 3 exchange MDT route information (including BGP interface address and the default group address) through BGP.
2.     PE 1 sends a subscribe message to PE 2 and PE 3. Each device on the public network creates an (S, G) entries. An SPT is established in the MVPN with PE 1 as the root and PE 2 and PE 3 as the leaves.
At the same time, PE 2 and PE 3 separately initiate a similar process, and establish an SPT with itself as the root and the other PEs as the leaves.
3.     The three independent SPTs constitute the default MDT in the PIM-SSM network.
In PIM-SSM, the term "subscribe message" refers to a join message.
After the default MDT is established, the multicast source forwards the VPN multicast data to the receivers in each site along the default MDT. The VPN multicast packets are encapsulated into public network multicast packets on the local PE, and transmitted along the default-MDT. Then, they are decapsulated on the remote PE and transmitted in that VPN site.
VPN multicast data packets are forwarded across the public network differently in the following circumstances:
·     If PIM-DM or PIM-SSM is running in the VPN, the multicast source forwards multicast data packets to the receivers along the VPN SPT across the public network.
·     When PIM-SM is running in the VPN:
¡     Before the RPT-to-SPT switchover, if the multicast source and the VPN RP are in different sites, the VPN multicast data packets travel to the VPN RP along the VPN SPT across the public network. If the VPN RP and the receivers are in different sites, the VPN multicast data packets travel to the receivers along the VPN RPT over the public network.
¡     After the RPT-to-SPT switchover, if the multicast source and the receivers are in different sites, the VPN multicast data packets travel to the receivers along the VPN SPT across the public network.
·     When BIDIR-PIM is running in the VPN, if the multicast source and the VPN RP are in different sites, the multicast source sends multicast data to the VPN RP across the public network along the source-side RPT. If the VPN RP and the receivers are in different sites, the multicast data packets travel to the receivers across the public network along the receiver-side RPT.
For more information about RPT-to-SPT switchover, see "Configuring PIM."
The following example explains how multicast data packets are delivered based on the default MDT when PIM-DM is running in both the public network and the VPN network.
As shown in Figure 6:
·     PIM-DM is running in both the public network and the VPN sites.
·     Receiver of the VPN multicast group G (225.1.1.1) in Site 2 is attached to CE 2.
·     Source in Site 1 sends multicast data to multicast group (G).
·     The default group address used to forward public network multicast data is 239.1.1.1.
Figure 6 Multicast data packet delivery
A VPN multicast data packet is delivered across the public network as follows:
1.     Source sends a VPN multicast data packet (192.1.1.1, 225.1.1.1) to CE 1.
2.     CE 1 forwards the VPN multicast data packet along an SPT to PE 1, and the VPN instance on PE 1 examines the MVRF.
If the outgoing interface list of the forwarding entry contains an MTI, PE 1 processes the VPN multicast data packet as described in step 3. The VPN instance on PE 1 considers the VPN multicast data packet to have been sent out of the MTI, because step 3 is transparent to it.
3.     PE 1 encapsulates the VPN multicast data packet into a public network multicast packet (11.1.1.1, 239.1.1.1) by using the GRE method. The source IP address of the packet is the MVPN source interface 11.1.1.1, and the destination address is the default group address 239.1.1.1. PE 1 then forwards it to the public network.
4.     The default MDT forwards the multicast data packet (11.1.1.1, 239.1.1.1) to the public network instance on all the PEs. After receiving this packet, every PE decapsulates it to get the original VPN multicast data packet, and passes it to the corresponding VPN instance. If a PE has a downstream interface for an SPT, it forwards the VPN multicast packet down the SPT. Otherwise, it discards the packet.
5.     The VPN instance on PE 2 looks up the MVRF and finally delivers the VPN multicast data to Receiver.
By now, the process of transmitting a VPN multicast data packet across the public network is completed.
MDT switchover
Switching from default MDT to data MDT
When a multicast packet of a VPN is transmitted through the default MDT on the public network, the packet is forwarded to all PEs that support that VPN instance. This occurs whether or not any active receivers exist in the attached sites. When the rate of the multicast traffic of that VPN is high, multicast data might get flooded on the public network. This increases the bandwidth use and brings extra burden on the PEs.
To optimize multicast transmission of large VPN multicast traffic that enters the public network, the MVPN solution introduces a dedicated data MDT. The data MDT is built between the PEs that connect VPN multicast receivers and multicast sources. When specific network criteria are met, a switchover from the default MDT to the data MDT occurs to forward VPN multicast traffic to receivers.
The process of default MDT to data MDT switchover is as follows:
1.     The source-side PE (PE 1, for example) initiates a switchover from the default MDT to a data MDT when it receives the first multicast packet of a VPN that matches the switchover criterion.
2.     PE 1 selects a least-used address from the data group range. Then, it sends an MDT switchover message to all the other PEs down the default MDT. This message contains the VPN multicast source address, the VPN multicast group address, and the data group address.
3.     Each PE that receives this message examines whether it interfaces with a VPN that has receivers of that VPN multicast stream.
If so, it joins the data MDT rooted at PE 1. Otherwise, it caches the message and will join the data MDT when it has attached receivers.
4.     After sending the MDT switchover message, PE 1 starts the data delay timer. When the timer expires, PE 1 uses the default group address to encapsulate the VPN multicast data. The multicast data is then forwarded down the data MDT.
5.     After the multicast traffic is switched from the default MDT to the data MDT, PE 1 continues sending MDT switchover messages periodically. Subsequent PEs with attached receivers can then join the data MDT. When a downstream PE no longer has active receivers attached to it, it leaves the data MDT.
For a given VPN instance, the default MDT and data MDTs are both forwarding tunnels in the same MVPN. A default MDT is uniquely identified by a default group address, and a data MDT is uniquely identified by a data group address. Each default group is uniquely associated with a data group range.
In an inter-AS VPN networking scenario, VPN sites are located in multiple ASs. These sites must be interconnected. Inter-AS VPN provides the following solutions:
·     VRF-to-VRF connections between ASBRs—This solution is also called inter-AS option A.
·     EBGP redistribution of labeled VPN-IPv4 routes between ASBRs—ASBRs advertise VPN-IPv4 routes to each other through MP-EBGP. This solution is also called inter-AS option B.
·     Multihop EBGP redistribution of labeled VPN-IPv4 routes between PE devices—PEs advertise VPN-IPv4 routes to each other through MP-EBGP. This solution is also called inter-AS option C.
For more information about the three inter-AS VPN solutions, see "Configuring MPLS L3VPN."
Based on these solutions, there are three ways to implement inter-AS MDT-based MVPN:
·     Inter-AS option A MDT-based MVPN.
·     Inter-AS option B MDT-based MVPN.
·     Inter-AS option C MDT-based MVPN.
As shown in Figure 7:
·     Two VPN instances are in AS 1 and AS 2.
·     PE 3 and PE 4 are ASBRs for AS 1 and AS 2, respectively.
·     PE 3 and PE 4 are interconnected through their respective VPN instance and treat each other as a CE.
Figure 7 Inter-AS option A MDT-based MVPN
To implement inter-AS option A MDT-based MVPN, a separate MVPN must be created in each AS. Multicast data is transmitted between the VPNs in different ASs through the MVPNs.
Multicast packets of VPN instance 1 are delivered as follows:
1.     CE 1 forwards the multicast packet of VPN instance 1 to PE 1.
2.     PE 1 encapsulates the multicast packet into a public network packet and forwards it to PE 3 through the MTI interface in MVPN 1.
3.     PE 3 considers PE 4 as a CE of VPN instance 1, so PE 3 forwards the multicast packet to PE 4.
4.     PE 4 considers PE 3 as a CE of VPN instance 2, so it forwards the multicast packet to PE 2 through the MTI interface in MVPN 2 on the public network.
5.     PE 2 forwards the multicast packet to CE 2.
Because only VPN multicast data is forwarded between ASBRs, different PIM modes can run within different ASs. However, the same PIM mode must run on all interfaces that belong to the same VPN (including interfaces with VPN bindings on ASBRs).
In inter-AS option B MDT-based MVPN, RPF vector and BGP connector are introduced:
·     RPF vector—Attribute encapsulated in a PIM join message. It is the next hop of BGP MDT route from the local PE to the remote PE. Typically, it is the ASBR in the local AS.
When a device receives the join message with the RPF vector, it first checks whether the RPF vector is its own IP address. If so, the device removes the RPF vector, and sends the message to its upstream neighbor according to the route to the remote PE. Otherwise, it keeps the RPF vector, looks up the route to the RPF vector, and sends the message to the next hop of the route. In this way, the PIM message can be forwarded across the ASs and an MDT is established.
·     BGP connector—Attribute shared by BGP peers when they exchange VPNv4 routes. It is the IP address of the remote PE.
The local PE fills the upstream neighbor address field with the BGP connector in a join message. This ensures that the message can pass the RPF check on the remote PE after it travels along the MT.
To implement inter-AS option B MDT-based MVPN, only one MVPN needs to be established for the two ASs. VPN multicast data is transmitted between different ASs on the public network within this MVPN.
As shown in Figure 8:
·     A VPN network involves AS 1 and AS 2.
·     PE 3 and PE 4 are the ASBRs for AS 1 and AS 2, respectively.
·     PE 3 and PE 4 are interconnected through MP-EBGP and treat each other as a P device.
·     PE 3 and PE 4 advertise VPN-IPv4 routes to each other through MP-EBGP.
·     An MT is established between PE 1 and PE 2 for delivering VPN multicast traffic across the ASs.
Figure 8 Inter-AS option B MDT-based MVPN
The establishment of the MVPN on the public network is as follows:
1.     PE 1 originates a PIM join message to join the SPT rooted at PE 2. In the join message, the upstream neighbor address is the IP address of PE 2 (the BGP connector). The RPF vector attribute is the IP address of PE 3. PE 1 encapsulates the join message as a public network packet and forwards it through the MTI.
2.     P 1 determines that the RPF vector is not an IP address of its own. It looks up the routing table for a route to PE 3, and forwards the packet to PE 3.
3.     PE 3 removes the RPF vector because the RPF vector is its own IP address. It fails to find a BGP MDT route to PE 2, so it encapsulates a new RPF vector (IP address of PE 4) in the packet and forwards it to PE 4.
4.     PE 4 removes the RPF vector because the RPF vector is its own IP address. It has a local route to PE 2, so it forwards the packet to P 2, which is the next hop of the route to PE 2.
5.     P 2 sends the packet to PE 2.
6.     PE 2 receives the packet on the MTI and decapsulates the packet. The receiving interface is the RPF interface of the RPF route back to PE 1 for the join message, and the join message passes the RPF check. The SPT from PE 1 to PE 2 is established.
When PE 1 joins the SPT rooted at PE 1, PE 2 also initiates a join process to the SPT rooted at PE 1. An MDT is established when the two SPTs are finished.
The public network supports only PIM-SSM on an inter-AS option B MDT-based MVPN network.
As shown in Figure 9:
·     PEs in different ASs establish a multihop MP-EBGP session to advertise VPN-IPv4 routes to each other.
Figure 9 Inter-AS option C MDT-based MVPN
To implement inter-AS option C MDT-based MVPN, only one MVPN needs to be created for the two ASs. Multicast data is transmitted between the two ASs through the MVPN.
Multicast packets are delivered as follows:
1.     CE 1 forwards the VPN instance multicast packet to PE 1.
2.     PE 1 encapsulates the multicast packet into a public network multicast packet and forwards it to PE 3 through the MTI interface on the public network.
3.     PE 3 and PE 4 are interconnected through MP-EBGP, so PE 3 forwards the public network multicast packet to PE 4 along the VPN IPv4 route.
4.     The public network multicast packet arrives at the MTI interface of PE 2 in AS 2. PE 2 decapsulates the public network multicast packet and forwards the VPN multicast packet to CE 2.
This section introduces the following concepts in RSVP-TE-based MVPN:
·     MVPN—An MVPN logically defines the transmission boundary of the multicast traffic of a VPN over the public network. It also physically identifies all the PEs that support that VPN instance on the public network. Different VPN instances correspond to different MVPNs. All PEs in an MVPN are MVPN peers.
·     Inclusive tunnel—Transmits all multicast packets (including multicast protocol packets and multicast data packets of all multicast groups) for an MVPN. Only one inclusive tunnel can be established between two PEs in the MVPN. A PE encapsulates multicast data packets and PIM BSMs of an MVPN into public network multicast data packets and sends them over the public network through the inclusive tunnel.
·     Selective tunnel—Transmits multicast packets of one or more multicast groups for an MVPN. Multiple selective tunnels can be established between two PEs in the MVPN.
Packet transmission on the public network is transparent for a VPN instance. Each two PEs establish IBGP neighbor relationship and use BGP to advertise routing information for MVPN. The following types of routes are used to create RSVP-TE tunnels for an MVPN:
·     Intra-AS I-PMSI A-D route—PEs use this type of route to establish inclusive tunnels.
·     S-PMSI A-D route—The multicast source-side PE sends this type of route to receiver-side PEs for tunnel switchover when selective tunnel creation is enabled and the tunnel creation criterion is met.
·     Leaf A-D route—A receiver-side PE that has attached receivers replies with a Leaf A-D route when it receives an S-PMSI A-D route from the multicast source-side PE. RSVP-TE creates selective tunnels between receiver-side PEs and the multicast-side PE based on the neighbor information contained in Leaf A-D routes.
·     Source Active A-D route—The multicast source-side PE sends this type of route to receiver-side PEs to advertise the location of the multicast source.
·     C-Multicast Route—After receiving the Source Active A-D route from the multicast source-side PE, a receiver-side PE replies with a C-Multicast route to request the multicast source-side PE to send multicast data.
Multicast packets of a VPN instance are seamlessly transmitted from a CE to the inclusive tunnel on the PE based on the PIM routing table. These packets are then transmitted to the remote PE through the inclusive tunnel. After receiving the packets, the remote PE decapsulates the packets to get the original private packets. The multicast source-side PE creates selective tunnels when multicast traffic that meets the tunnel switchover criterion arrives.
As shown in Figure 10, the private network runs PIM, and the public network uses MPLS backbone. The inclusive tunnels are established as follows:
1.     PE 1, PE 2, and PE 3 mutually establish IBGP neighbor relationship and exchange routing information to get the public network address of each PE.
2.     The source of the tunnel (PE 1) sends an Intra-AS I-PMSI A-D route to the destination of the tunnel (PE 2 and PE 3) to advertise the inclusive tunnel information.
3.     PE 2 and PE 3 each establish an inclusive tunnel with PE 1. The inclusive tunnel on the public network does not rely on PIM running on the private network.
Figure 10 Inclusive tunnel establishment
As shown in Figure 11, selective tunnels are established and switched as follows:
1.     After multicast source-side PE 1 receives a multicast packet of the (S, G) entries that meets the tunnel switchover criterion, it sends an S-PMSI A-D route to PE 2 and PE 3.
2.     PE 2 does not send a response because it has no receivers of the (S,G) entry attached. PE 3 replies with a Leaf A-D route because it is attached to a receiver of the entry.
3.     PE 1 and PE 3 establish a selective tunnel.
4.     Subsequent multicast packets of the (S,G) entry that enter the public network from PE 1 are switched over to the selective tunnel from the inclusive tunnel.
Figure 11 Selective tunnel establishment
Basic concepts in mLDP-based MVPN are the same as those in RSVP-TE-based MVPN. For more information about basic concepts in RSVP-TE-based MVPN, see "Basic concepts in RSVP-TE-based MVPN."
The operation of mLDP-based MVPN is similar to that of RSVP-TE-based MVPN. They differ in the direction in which the public network P2MP tunnel is created.
·     RSVP-TE-based MVPN—Starting from the ingress PE, the upstream devices use RSVP to establish RSVP-TE P2MP tunnels with downstream devices. In this mode, the ingress PE needs to know the IP address of the egress PE.
·     mLDP-based MVPN—Starting from the egress PE, the downstream devices use LDP to establish mLDP P2MP tunnels with downstream devices. In this mode, the egress PE needs to the IP address of the ingress PE.
For more information about the RSVP-TE-based MVPN operation, see "How RSVP-TE-based MVPN works."
As shown in Figure 12, the private network runs PIM, and the public network uses MPLS backbone. The inclusive tunnels are established as follows:
1.     PE 1, PE 2, and PE 3 mutually establish IBGP neighbor relationship and exchange routing information.
2.     PE 1 (the source of the tunnel) advertises the inclusive tunnel information to PE 2 and PE 3.
3.     PE 2 and PE 3 each use LDP to establish an inclusive mLDP tunnel with PE 1. The inclusive tunnel on the public network does not rely on PIM running on the private network.
Figure 12 Establishment of the inclusive tunnel
mLDP-based MVPN supports switchover from the inclusive tunnel to selective tunnels to off-load traffic for specific (S, G) entries from the inclusive tunnel. An MVPN can have multiple selective tunnels.
As shown in Figure 13, the process of selective tunnel creation and the tunnel switchover is as follows:
1.     Upon receiving a multicast packet for the (S, G) entries that meets the tunnel switchover criterion, the multicast source-side PE 1 sends an S-PMSI A-D route to PE 2 and PE 3.
2.     PE 2 does not respond to the route because it has no receivers of the (S,G) entry attached.
3.     PE 3 which has a receiver attached usesLDP to establish a selective tunnel with PE 1.
4.     Subsequent multicast packets for the (S,G) entry are transmitted over the selective tunnel instead of the inclusive tunnel on the public network.
Figure 13 Selective tunnel establishment and tunnel switchover
For more information about the three inter-AS VPN solutions, see MPLS L3VPN configuration in MPLS Configuration Guide.
As shown in Figure 14:
·     A VPN instance spans AS 100 and AS 200.
·     PE 3 and PE 4 are ASBRs for AS 100 and AS 200, respectively.
Figure 14 Inter-AS option A mLDP-based MVPN
To implement inter-AS option A mLDP-based MVPN, a separate MVPN must be created in each AS. Multicast data of the VPN instance is transmitted across the ASs through the separate MVPN in each AS.
Multicast packets of the VPN instance are delivered as follows:
1.     CE 1 forwards a multicast packet of VPN instance 1 to PE 1.
2.     PE 1 encapsulates the multicast packet into an MPLS packet and forwards it to PE 3 through mLDP tunnel 1.
3.     PE 3 considers PE 4 as a CE of MVPN 1, so PE 3 decapsulates the MPLS packet and forwards the multicast packet to PE 4.
4.     PE 4 considers PE 2 as a CE of MVPN 2, so PE 4 encapsulates the multicast packet into an MPLS packet and then forwards the packet to PE 2 through mLDP tunnel 2.
5.     PE 2 decapsulates the MPLS packet and then forwards the multicast packet to CE 2.
In inter-AS option A, PEs in different ASs cannot advertise Source Active A-D routes to each other. Therefore, you must configure MSDP or Anycast-RP between RPs to allow Source Active A-D routes to be advertised across ASs.
As shown in Figure 15:
·     PE 3 and PE 4 are the ASBRs for AS 100 and AS 200, respectively.
Figure 15 Inter-AS option B mLDP-based MVPN
To implement inter-AS option B mLDP-based MVPN, only one MVPN needs to be established across all ASs. VPN multicast data is transmitted across the ASs through this MVPN.
Multicast packets of the VPN instance are transmitted as follows:
1.     Upon receiving a multicast packet of a multicast group in the VPN instance, CE 1 advertises the RP information for this group to PE 1 as follows:
¡     If the RP is PE 1, CE 1 directly sends a register message to PE 1 to advertise the RP information.
¡     If the RP is CE 1 or CE 2, CE 1 advertises the RP information to PE 1 through MSDP or Anycast-RP depending on the actual configuration.
2.     PE 1 sends a Source Active A-D route to PE 3, PE 4, and PE 2 through BGP.
3.     PE 2 sends a C-multicast route to join the multicast group if it has a receiver attached. The C-multicast route will be advertised to PE 4, PE 3, and PE 1 through BGP.
4.     Upon receiving the C-multicast route, PE 1 encapsulates the multicast packet into an MPLS packet and then sends the packet to PE 2 through the mLDP tunnel.
5.     PE 2 decapsulates the MPLS packet and then sends the multicast packet to CE 2.
As shown in Figure 16:
Figure 16 Inter-AS option C mLDP-based MVPN
To implement inter-AS option C mLDP-based MVPN, only one MVPN needs to be created cross all ASs. Multicast data is transmitted across the ASs through this MVPN.
2.     PE 1 sends a source-active A-D route to PE 2 through BGP.
3.     PE 2 sends a C-multicast route to join the multicast group if it has a receiver attached. The C-multicast route will be advertised to PE 1 through BGP.
4.     PE 1 encapsulates the multicast packet into an MPLS packet and then sends the packet to PE 2 through the mLDP tunnel.
MVPN extranet
MVPN extranet implements inter-VPN multicast traffic transmission. In MVPN extranet, the multicast source and receivers are in different VPNs. In actual application, the MVPN extranet solution ensures that the service provider in a VPN provides multicast services for users in other VPNs.
The following terms are used in the MVPN extranet solution:
·     Source VPN instance—VPN instance to which the multicast source belongs.
·     Receiver VPN instance—VPN instance to which the multicast receiver belongs.
·     Source PE—PE directly connected to the multicast source.
·     Receiver PE—PE directly connected to multicast receivers.
As shown in Figure 17, multicast source Source 1 is in Site 1 of VPN A. Receiver 1 and Receiver 2 are located in Site 2 of VPN A and Site 1 of VPN B, respectively. MVPN enables Receiver 1 to receive multicast data from Source 1, and MVPN extranet enables Receiver 2 to receive multicast data from Source 1.
The MVPN extranet solution can be implemented through the source-PE-based MVPN extranet option or the receiver-PE-based MVPN extranet option.
Figure 17 MVPN extranet
Source-PE-based MVPN extranet option
To use this option, create a receiver VPN instance on the source PE and specify a default group for this VPN instance. The default group for the receiver VPN instance must be the same as the default group specified on other PEs in this VPN instance.
This option is available only in MDT-based MVPN.
As shown in Figure 18, perform the following tasks:
1.     For multicast traffic transmission from Site 1 to Site 2, configure MVPN for VPN A on PE 1 and PE 2.
2.     For multicast traffic transmission from Site 1 to Site 3, create VPN B and configure MVPN for VPN B on PE 1.
3.     Configure an MVPN extranet RPF selection policy for VPN B on PE 1.
Figure 18 Source-PE-based MVPN extranet option
When Receiver 2 in VPN B joins the multicast group that matches the policy, multicast packets from Source 1 are transmitted as follows:
1.     PE 1 replicates and encapsulates the packets for VPN A and VPN B and forwards them.
2.     The packets travel along default MDTs of VPN A and VPN B and arrive at PE 2 and PE 3.
3.     PE 2 and PE 3 decapsulate and forward the packets to receivers.
Receiver-PE-based MVPN extranet option
To use this option, create a source VPN instance on the receiver PE and specifies a default group for this VPN instance. The default group for the source VPN instance must be the same as the default group specified on other PEs in this VPN instance.
This option is available in MDT-based MVPN, RSVP-TE-based MVPN, and mLDP-based MVPN. This example uses MDT-based MVPN.
As shown in Figure 19, configure PEs as follows:
2.     For multicast traffic transmission from Site 1 to Site 3, create VPN A and configure MVPN for VPN A on PE 3.
3.     Configure an MVPN extranet RPF selection policy for VPN B on PE 3.
Figure 19 Receiver-PE-based MVPN extranet option
When Receiver 2 in VPN B joins the multicast group that matches the RPF selection policy, multicast packets from Source 1 are encapsulated on PE 1 and transmitted along the default MDT.
1.     When the packets arrive at PE 2, PE 2 decapsulates the packets and forwards them to Receiver 1.
2.     When the packets arrive at PE 3, PE 3 decapsulates the packets and forwards them to Receiver 2 based on the MVPN extranet RPF selection policy.
M6VPE
The multicast IPv6 VPN provider edge (M6VPE) feature enables PEs to transmit IPv6 multicast traffic of a VPN instance over the public network. Only the IPv4 network is available for the backbone network.
As shown in Figure 20, the public network runs IPv4 protocols, and sites of VPN instance VPN A run IPv6 multicast protocols. To transmit IPv6 multicast traffic between CE 1 and CE 2, configure M6VPE on the PEs.
Figure 20 M6VPE network
IPv6 multicast traffic forwarding over the IPv4 public network is as follows:
1.     CE 1 forwards an IPv6 multicast packet for VPN instance VPN A to PE 1.
2.     PE 1 encapsulates the IPv6 multicast packet with an IPv4 packet header and transmits the IPv4 packet in the IPv4 backbone network.
3.     PE 2 decapsulates the IPv4 packet and forwards the IPv6 multicast packet to CE 2.
·     RFC 6037, Cisco Systems' Solution for Multicast in BGP/MPLS IP VPNs
·     RFC 6513, Multicast in MPLS/BGP IP VPNs
·     RFC 6514, BGP Encodings and Procedures for Multicast in MPLS/BGP IP VPNs
To configure multicast VPN, perform the following tasks:
1.     Configuring MDT-based MVPN
a.     Enabling IP multicast routing for a VPN instance
b.     Creating an MDT-based MVPN instance
c.     Creating an MVPN address family
d.     Specifying the default group
e.     Specifying the MVPN source interface
f.     Configuring MDT switchover parameters
g.     (Optional.) Configuring the RPF vector feature
h.     (Optional.) Enabling data group reuse logging
2.     Configuring BGP MDT
If PIM-SSM is running on the public network, you must configure BGP MDT.
a.     Configuring BGP MDT peers or peer groups
b.     (Optional.) Configuring a BGP MDT route reflector
c.     (Optional.) Preferring routes learned from a peer or peer group during optimal route selection
To configure RSVP-TE-based MVPN, perform the following tasks on PEs:
1.     Enabling IP multicast routing for a VPN instance
2.     Configuring BGP IPv4 MVPN route exchange
3.     Allowing the device to add extended community attributes to C-multicast routes
4.     Creating an RSVP-TE-based MVPN instance
5.     Creating an MVPN IPv4 address family
6.     Specifying the MVPN source interface
7.     Enabling inclusive tunnel creation
8.     (Optional.) Enabling selective tunnel creation
9.     (Optional.) Setting the tunnel switchover delay
To configure mLDP-based MVPN, perform the following tasks on PEs:
4.     Creating an mLDP-based MVPN instance
10.     (Optional.) Enabling inter-AS auto-discovery
Before you configure MDT-based MVPN, complete the following tasks:
·     Configure a unicast routing protocol on the public network.
·     Configure MPLS L3VPN on the public network.
·     Configure PIM-DM, PIM-SM, BIDIR-PIM, or PIM-SSM on the public network.
2.     Create a VPN instance and enter its view.
For more information about this command, see MPLS Command Reference.
3.     Configure an RD for the VPN instance.
4.     Return to system view.
5.     Enter interface view.
6.     Associate the interface with the VPN instance.
By default, an interface is associated with no VPN instance and belongs to the public network.
7.     Return to system view.
8.     Enable IP multicast routing for the VPN instance and enter MRIB view of the VPN instance.
IPv4:
multicast routing vpn-instance vpn-instance-name
By default, IPv4 multicast routing is disabled for a VPN instance.
For more information about this command, see IP Multicast Command Reference.
IPv6:
ipv6 multicast routing vpn-instance vpn-instance-name
By default, IPv6 multicast routing is disabled for a VPN instance.
To provide multicast services for a VPN instance, you must create an MDT-based MVPN instance on PEs that belong to the VPN instance. After the MVPN instance is created, the system automatically creates MTIs and binds them with the VPN instance.
You can create one or more MDT-based MVPN instances on a PE.
2.     Create an MDT-based MVPN instance and enter MVPN view.
multicast-vpn vpn-instance vpn-instance-name mode mdt
You must create an MVPN IPv4 or IPv6 address family for a VPN instance before you can perform other MVPN VPN configuration tasks for the VPN instance. For a VPN instance, configurations in MVPN IPv4 and IPv6 address family views apply to IPv4 and IPv6 multicast packets of the instance, respectively.
2.     Enter MVPN view of a VPN instance.
3.     Create an MVPN address family and enter MVPN address family view.
IPv4:
address-family ipv4
IPv6:
address-family ipv6
You must specify the same default group on all PEs that belong to the same MVPN.
The default group for an MVPN must be different from the default group and the data group used by any other MVPN.
For an MVPN that transmits both IPv4 and IPv6 multicast packets, you must specify the same default group in MVPN IPv4 address view and MVPN IPv6 address family view.
2.     Enter MVPN view.
3.     Enter MVPN address family view.
IPv4:
address-family ipv4
IPv6:
address-family ipv6
4.     Specify the default group.
default-group group-address
An MTI of a VPN instance uses the IP address of the MVPN source interface as the source address to encapsulate multicast packets for the VPN instance.
For the PE to obtain correct routing information, you must specify the interface used for establishing BGP peer relationship as the MVPN source interface.
For an MVPN that transmits both IPv4 and IPv6 multicast packets, you must specify the same MVPN source interface in MVPN IPv4 address family view and MVPN IPv6 address family view.
The MTI takes effect only after the default group and MVPN source interface are specified and the MTI obtains the public IP address of the MVPN source interface.
2.     Enter MVPN view.
IPv4:
address-family ipv4
IPv6:
address-family ipv6
4.     Specify the MVPN source interface.
source interface-type interface-number
By default, no MVPN source interface is specified.
To decrease traffic interruption caused by frequent default-MDT to data-MDT switchovers, you can adjust the data-delay period. The switchover occurs a data-delay period after the multicast VPN data first arrives, regardless of whether multicast VPN data keeps arriving during the period.
On a PE, the data group range for an MVPN cannot include the default group or data groups of any other MVPN. The data group ranges for different MVPNs on different PE devices cannot overlap with one another if the PIM mode is not PIM-SSM on the public network.
For an MVPN that transmits both IPv4 and IPv6 multicast packets, the data group range in MVPN IPv4 address family view and MVPN IPv6 address family view cannot overlap.
All VPN instances share the data group resources. As a best practice to avoid data group resource exhaustion, specify a reasonable data group range for a VPN instance.
If BIDIR-PIM runs in a VPN instance, the switchover from the default MDT to a data MDT is not supported.
2.     Enter MVPN view.
IPv4:
address-family ipv4
IPv6:
address-family ipv6
4.     Configure the data group range and the switchover criteria.
data-group group-address { mask-length | mask } [ acl acl-number ] *
By default, no data group range is configured, and the default MDT to data MDT switchover never occurs.
5.     Set the data delay period.
data-delay delay
By default, the data delay period is 3 seconds.
In inter-AS MDT-based MVPN, this feature enables the device to insert the RPF vector (IP address of the ASBR in the local AS) in PIM join messages for other devices to perform RPF check.
Perform this task on PEs that have attached receivers.
For the device to work with other manufacturers' products on the RPF vector, you must enable RPF vector compatibility for all H3C P devices and H3C PE devices on the public network.
2.     Enter MRIB view of a VPN instance.
3.     Enable the RPF vector feature.
rpf proxy vector
By default, the RPF vector feature is disabled.
4.     Enable RPF vector compatibility.
multicast rpf-proxy-vector compatible
By default, RPF vector compatibility is disabled.
For a given VPN, the number of VPN multicast streams to be switched to data MDTs might exceed the number of addresses in the data group range. In this case, the VPN instance on the source-side PE can reuse the addresses in the address range. With data group reuse logging enabled, the address reuse information will be logged.
Attributed to the MVPN module, the group address reuse logging information has a severity level informational. For more information about the logging information, see information center configuration in Network Management and Monitoring Configuration Guide.
2.     Enter MVPN view.
IPv4:
address-family ipv4
IPv6:
address-family ipv6
4.     Enable data group reuse logging.
log data-group-reuse
By default, data group reuse logging is disabled.
Configuring BGP MDT
Perform this task so that the PE can exchange MDT information with the BGP peer or peer group. MDT information includes the IP address of the PE and default group to which the PE belongs. On a public network running PIM-SSM, the multicast VPN establishes a default MDT rooted at the PE (multicast source) based on the MDT information.
Before you configure a BGP MDT peer or peer group, you must create a BGP peer or peer group in BGP instance view. For more information about creating a BGP peer or peer group, see BGP configuration in Layer 3—IP Routing Configuration Guide.
3.     Create a BGP IPv4 MDT address family and enter its view.
address-family ipv4 mdt
By default, no BGP IPv4 address family exists.
4.     Enable the device to exchange MDT routing information with the BGP peer or the peer group.
By default, the device cannot exchange BGP MDT routing information with a BGP peer or peer group.
For more information about this command, see BGP commands in Layer 3—IP Routing Command Reference.
·     Configuring a BGP MDT route reflector—BGP MDT peers in the same AS must be fully meshed to maintain connectivity. However, when multiple BGP MDT peers exist in an AS, connection establishment among them might result in increased costs. To reduce connections between BGP MDT peers, you can configure one of them as a route reflector and specify other devices as clients.
·     Disabling routing reflection between clients—When clients establish BGP MDT connections with the route reflector, the route reflector forwards (or reflects) BGP MDT routing information between clients. The clients are not required to be fully meshed. To save bandwidth if the clients have been fully meshed, you can disable the routing reflection between clients by using the undo reflect between-clients command.
·     Configuring the cluster ID of the route reflector—The route reflector and its clients form a cluster. Typically, a cluster has only one route reflector whose router ID identifies the cluster. However, you can configure several route reflectors in a cluster to improve network reliability. To avoid routing loops, make sure the route reflectors in a cluster have the same cluster ID.
3.     Enter BGP IPv4 MDT address family view.
4.     Configure the device as a route reflector and specify its peers or peer groups as clients.
5.     (Optional.) Disable route reflection between clients.
By default, route reflection between clients is disabled.
6.     (Optional.) Configure the cluster ID of the route reflector.
By default, a route reflector uses its router ID as the cluster ID.
By default, BGP selects an optimal route based on route selection rules. It does not prefer routes learned from any peer or peer groups during optimal route selection.
After you perform this task, routes learned from the specified peer or peer group take precedence over other routes if these routes have the same prefix. BGP uses this rule to continue route selection if it fails to select an optimal route by using the peer type selection rule. If BGP still fails route selection, it uses the IGP metric selection rule to select an optimal route. For more information about BGP route selection rules, see BGP in in Layer 3IP Routing Configuration Guide.
3.     Enter BGP IPv4 MDT address family view:
4.     Prefer routes learned from the specified peer or peer group during optimal route selection.
peer { group-name | ipv4-address [ mask-length ] } high-priority [ preferred ]
By default, BGP does not prefer routes learned from any peer or peer groups during optimal route selection.
Before you configure RSVP-TE-based MVPN, complete the following tasks:
·     Configure MPLS TE on the public network.
·     Configure RSVP on the public network.
·     Configure BGP to enable PEs to establish neighbor relationship with each other.
IPv4:
IPv6:
3.     Specify a BGP MVPN peer and its AS number.
4.     Enter BGP IPv4 MVPN address family view.
address-family ipv4 mvpn
5.     Enable BGP to exchange IPv4 unicast routing information with dynamic BGP peers.
By default, BGP cannot exchange IPv4 unicast routing information with dynamic BGP peers.
For more information about this command, see BGP commands in Layer 3-IP Routing Command Reference.
6.     (Optional.) Disable route target filtering of received BGP IPv4 MVPN routes.
undo policy vpn-target
By default, a PE device filters route targets for received BGP IPv4 MVPN routes.
7.     (Optional.) Prefer routes learned from the specified peer or peer group during optimal route selection.
8.     (Optional.) Prefer BGP routes of a specific next hop IP type during optimal route selection.
bestroute nexthop-priority { ipv4 | ipv6 } [ preferred ]
By default, BGP prefers routes with IPv4 next hops during optimal route selection.
The following BGP extended community attributes are used to identify the route originator of a BGP VPNv4 route:
·     Source AS—Carries the number of AS where the MVPN source resides. The format of this attribute is 32-bit AS number:0, for example, 100:0.
·     VRF Route Import—Carries the originating address and the VPN instance to which the BGP VPNv4 route belongs. The format of the attribute is 32-bit originating address:VPN instance index, for example, 192.168.122.15:1. The value of the originating address depends on the MVPN source interface configuration.
¡     If the source command is used to specify the MVPN source interface, the originating address is the IP address of the MVPN source interface.
¡     If the source command is not used, the originating address is the router ID of the BGP instance to which the device belongs.
Before you perform this task, you must establish BGP IPv4 MVPN neighbor relationship and specify BGP MVPN peers.
3.     Enter BGP VPNv4 address family view.
address-family vpnv4
4.     Allow the device to add Source AS and VRF Route Import extended community attributes to routes sent to BGP VPNv4 peers.
mvpn-advertise-rt-import
By default, the device is disabled from adding Source AS and RF Route Import extended community attributes to routes sent to BGP VPNv4 peers.
You can create one or more RSVP-TE-based MVPN instances on a PE device.
A VPN instance supports only one MVPN mode.
2.     Create an RSVP-TE-based MVPN instance and enter its view.
multicast-vpn vpn-instance vpn-instance-name mode rsvp-te
Configurations in MVPN IPv4 address family view apply only to IPv4 multicast.
2.     Enter MVPN view.
3.     Create an MVPN IPv4 address family and enter its view.
address-family ipv4
An RSVP tunnel uses the IP address of the MVPN source interface as the source address to encapsulate multicast packets from the private network.
2.     Enter MVPN view.
3.     Enter MVPN IPv4 address family view.
address-family ipv4
Once created, the inclusive tunnel always exists whether the multicast traffic is present or not.
Only one inclusive tunnel can be established between two PEs in an MVPN.
2.     Enter MVPN view.
address-family ipv4
4.     Enable dynamic inclusive tunnel creation.
inclusive-tunnel dynamic
By default, dynamic inclusive tunnel creation is disabled.
Multicast traffic that matches the tunnel switchover criterion is switched over to selective tunnels from the inclusive tunnel after selective tunnel are created.
Selective tunnels are created only after the multicast traffic is transmitted over the inclusive tunnel.
Multicast packets of multiple (S, G) entries can share one selective tunnel.
Multiple selective tunnels can be created between two PEs in an MVPN. These selective tunnels are independent from one another.
2.     Enter MVPN view.
address-family ipv4
4.     Enable dynamic selective tunnel creation.
selective-tunnel dynamic [ acl ipv4-acl-number ]
By default, dynamic selective tunnel creation is disabled.
To avoid multicast data loss during tunnel switchover, adjust the delay time for multicast data to switch over from the inclusive tunnel to selective tunnels.
2.     Enter MVPN view.
address-family ipv4
4.     Set the tunnel switchover delay.
selective-tunnel delay delay
By default, the tunnel switchover delay is 3 seconds.
Before you configure mLDP-based MVPN, complete the following tasks:
·     Configure MPLS LDP on the public network.
·     Configure BGP to enable PEs to mutually establish neighbor relationship.
For more information about this command, see MPLS L3VPN commands in MPLS Command Reference.
For more information about this command, see multicast routing and forwarding commands in IP Multicast Command Reference.
7.     (Optional.) Set the optimal route selection delay timer.
By default, the optimal route selection delay timer is 0 seconds, which means optimal route selection is not delayed.
8.     (Optional.) Prefer routes learned from the specified peer or peer group during optimal route selection.
9.     (Optional.) Prefer BGP routes of a specific next hop IP type during optimal route selection.
Before you perform this task, you must establish BGP VPNv4 peer relationship and BGP IPv4 MVPN neighbor relationship between the device and other devices.
You can create one or more mLDP-based MVPN instances on a PE device.
2.     Create an mLDP-based MVPN instance and enter its view.
multicast-vpn vpn-instance vpn-instance-name mode mldp
2.     Enter MVPN view.
address-family ipv4
An mLDP tunnel uses the IP address of the MVPN source interface as the source address to encapsulate multicast packets from the private network.
2.     Enter MVPN view.
address-family ipv4
Once created, the inclusive tunnel always exists no matter whether multicast traffic is present or not.
2.     Enter MVPN view.
address-family ipv4
Multicast packets for multiple (S, G) entries can share the same selective tunnel.
2.     Enter MVPN view.
address-family ipv4
2.     Enter MVPN view.
address-family ipv4
This feature inhibits the device from carrying the NO_EXPORT attribute in intra-AS A-D routes and S-PMSI A-D routes sent to BGP. Use this feature on the multicast source-side PE in an inter-AS MVPN scenario so that these routes can be discovered on the devices out of the local AS.
2.     Enter MVPN view.
address-family ipv4
4.     Enable inter-AS auto-discovery.
auto-discovery inter-as
By default, inter-AS auto-discovery is disabled.
Display and maintenance commands for MDT-based MVPN:
Display BGP MDT peer group information.
display bgp [ instance instance-name ] group ipv4 mdt [ group-name group-name ]
Display information about BGP MDT peers or peer groups.
display bgp [ instance instance-name ] peer ipv4 mdt [ ip-address mask-length | { ip-address | group-name group-name } log-info | [ ip-address ] verbose ]
Display information about BGP MVPN peers or peer groups.
display bgp [ instance instance-name ] peer ipv4 mvpn [ ip-address mask-length | { ip-address | group-name group-name } log-info | [ ip-address ] verbose ]
Display BGP MDT routing information.
display bgp [ instance instance-name ] routing-table ipv4 mdt [ route-distinguisher route-distinguisher ] [ ip-address [ advertise-info ] ]
Display information about BGP update groups for the BGP IPv4 MDT address family.
display bgp [ instance instance-name ] update-group ipv4 mdt [ ip-address ]
Display information about data groups for IPv4 multicast transmission that are received in a VPN instance.
display multicast-vpn vpn-instance vpn-instance-name data-group receive [ brief | [ active | group group-address | sender source-address | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] * ]
Display information about data groups for IPv6 multicast transmission that are received in a VPN instance.
display multicast-vpn vpn-instance vpn-instance-name ipv6 data-group receive [ brief | [ active | group group-address | sender source-address | vpn-source-address [ mask-length ] | vpn-group-address [ mask-length ] ] * ]
Display information about data groups for IPv4 multicast transmission that are sent in a VPN instance.
display multicast-vpn vpn-instance vpn-instance-name data-group send [ group group-address | reuse interval | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] *
Display information about data groups for IPv6 multicast transmission that are sent in a VPN instance.
display multicast-vpn vpn-instance vpn-instance-name ipv6 data-group send [ group group-address | reuse interval | vpn-source-address [ mask-length ] | vpn-group-address [ mask-length ] ] *
Display information about default groups for IPv4 multicast transmission.
display multicast-vpn [ vpn-instance vpn-instance-name ] default-group { local | remote }
Display information about default groups for IPv6 multicast transmission.
display multicast-vpn [ vpn-instance vpn-instance-name ] ipv6 default-group { local | remote }
Reset BGP sessions for BGP IPv4 MDT address family.
reset bgp [ instance instance-name ] { as-number | ip-address [ mask-length ] | all | external | group group-name | internal } ipv4 mdt
Display and maintenance commands for RSVP-TE-based MVPN and mLDP-based MVPN:
Display BGP MVPN peer group information.
display bgp [ instance instance-name ] group ipv4 mvpn [ group-name group-name ]
Display information about BGP IPv4 MVPN routes.
display bgp [ instance instance-name ] routing-table ipv4 mvpn [ route-distinguisher route-distinguisher [ route-type { intra-as I inter-as | s-pmsi | leaf | source-active | shared-tree | source-tree } ] [ mvpn-prefix ] | statistics ]
display bgp [ instance instance-name ] routing-table ipv4 mvpn [ [ route-distinguisher route-distinguisher [ mvpn-prefix [ advertise-info ] ] ]
display bgp [ instance instance-name ] routing-table ipv4 mvpn [ route-type { intra-as I inter-as | s-pmsi | leaf | source-active | shared-tree | source-tree } [ statistics ] ]
display bgp [ instance instance-name ] routing-table ipv4 mvpn peer ip-address { advertised-routes | received-routes } [ statistics ]
Display information about C-multicast A-D routes for RSVP-TE-based MVPN.
display multicast-vpn vpn-instance vpn-instance-name c-multicast routing-table [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | outgoing-interface { exclude | include | match } interface-type interface-number ]
Display RSVP-TE tunnel neighbor information for MVPN.
display multicast-vpn vpn-instance vpn-instance-name neighbor [ interface tunnel number ]
Display information about the inclusive tunnel for a VPN instance.
display multicast-vpn vpn-instance vpn-instance-name inclusive-tunnel { local | remote }
Display information about selective tunnels for a VPN instance.
display multicast-vpn vpn-instance vpn-instance-name selective-tunnel { local [ interface interface-type interface-number ] | remote }
Reset BGP sessions for BGP IPv4 MVPN address family.
reset bgp [ instance instance-name ] { as-number | ip-address [ mask-length ] | all | external | group group-name | internal } ipv4 mvpn
For more information about the display bgp group, display bgp peer, display bgp update-group, and reset bgp commands, see BGP commands in Layer 3—IP Routing Command Reference.
As shown in Figure 21, configure intra-AS MVPN to meet the following requirements:
Item
Multicast sources and receivers
·     In VPN instance a, S 1 is a multicast source, and R 1, R 2, and R 3 are receivers.
·     In VPN instance b, S 2 is a multicast source, and R 4 is a receiver.
·     For VPN instance a, the default group is 239.1.1.1, and the data group range is 225.2.2.0 to 225.2.2.15.
·     For VPN instance b, the default group is 239.2.2.2, and the data group range is 225.4.4.0 to 225.4.4.15.
VPN instances to which PE interfaces belong
·     PE 1: GigabitEthernet 2/0/2 and GigabitEthernet 2/0/3 belong to VPN instance a. GigabitEthernet 2/0/1 and Loopback 1 belong to the public network.
·     PE 2: GigabitEthernet 2/0/2 belongs to VPN instance b. GigabitEthernet 2/0/3 belongs to VPN instance a. GigabitEthernet 2/0/1 and Loopback 1 belong to the public network.
·     PE 3: GigabitEthernet 2/0/2 belongs to VPN instance a. GigabitEthernet 2/0/3 and Loopback 2 belongs to VPN instance b. GigabitEthernet 2/0/1 and Loopback 1 belong to the public network.
Unicast routing protocols and MPLS
·     Configure OSPF on the public network, and configure RIP between the PE devices and the CE devices.
·     Establish BGP peer connections between PE 1, PE 2, and PE 3 on their respective Loopback 1.
·     Configure MPLS on the public network.
·     Enable IP multicast routing on the P router.
·     Enable IP multicast routing on the public network instance on PE 1, PE 2, and PE 3.
·     Enable IP multicast routing for VPN instance a on PE 1, PE 2, and PE 3.
·     Enable IP multicast routing for VPN instance b on PE 2 and PE 3.
·     Enable IP multicast routing on CE a1, CE a2, CE a3, CE b1, and CE b2.
IGMPv2
·     Enable IGMPv2 on GigabitEthernet 2/0/2 of PE 1.
·     Enable IGMPv2 on GigabitEthernet 2/0/1 of CE a2, CE a3, and CE b2.
PIM-SM
Enable PIM-SM on the public network and for VPN instances a and b:
·     Enable PIM-SM on all interfaces of the P router.
·     Enable PIM-SM on all public and private network interfaces on PE 1, PE 2, and PE 3.
·     Enable PIM-SM on all interfaces that do not have attached receiver hosts on CE a1, CE a2, CE a3, CE b1, and CE b2.
·     Configure Loopback 1 of P as a public network C-BSR and C-RP to provide services for all multicast groups.
·     Configure Loopback 1 of CE a2 as a C-BSR and a C-RP for VPN instance a to provide services for all multicast groups.
·     Configure Loopback 2 of PE 3 as a C-BSR and a C-RP for VPN instance b to provide services for all multicast groups.
Figure 21 Network diagram
Device
IP address
Device
IP address
S 1
10.110.7.2/24
PE 3
GE2/0/1
192.168.8.1/24
S 2
10.110.8.2/24
PE 3
GE2/0/2
10.110.5.1/24
R 1
10.110.1.2/24
PE 3
GE2/0/3
10.110.6.1/24
R 2
10.110.9.2/24
PE 3
Loop1
1.1.1.3/32
R 3
10.110.10.2/24
PE 3
Loop2
33.33.33.33/32
R 4
10.110.11.2/24
CE a1
GE2/0/1
10.110.7.1/24
P
GE2/0/1
192.168.6.2/24
CE a1
GE2/0/2
10.110.2.2/24
P
GE2/0/2
192.168.7.2/24
CE a2
GE2/0/1
10.110.9.1/24
P
GE2/0/3
192.168.8.2/24
CE a2
GE2/0/2
10.110.4.2/24
P
Loop1
2.2.2.2/32
CE a2
GE2/0/3
10.110.12.1/24
PE 1
GE2/0/1
192.168.6.1/24
CE a2
Loop1
22.22.22.22/32
PE 1
GE2/0/2
10.110.1.1/24
CE a3
GE2/0/1
10.110.10.1/24
PE 1
GE2/0/3
10.110.2.1/24
CE a3
GE2/0/2
10.110.5.2/24
PE 1
Loop1
1.1.1.1/32
CE a3
GE2/0/3
10.110.12.2/24
PE 2
GE2/0/1
192.168.7.1/24
CE b1
GE2/0/1
10.110.8.1/24
PE 2
GE2/0/2
10.110.3.1/24
CE b1
GE2/0/2
10.110.3.2/24
PE 2
GE2/0/3
10.110.4.1/24
CE b2
GE2/0/1
10.110.11.1/24
PE 2
Loop1
1.1.1.2/32
CE b2
GE2/0/2
10.110.6.2/24
1.     Configure PE 1:
# Configure a global router ID, and enable IP multicast routing on the public network.
<PE1> system-view
[PE1] router id 1.1.1.1
[PE1] multicast routing
[PE1-mrib] quit
# Configure an LSR ID, and enable LDP globally.
[PE1] mpls lsr-id 1.1.1.1
[PE1] mpls ldp
[PE1-ldp] quit
# Create a VPN instance named a, and configure an RD and route targets for the VPN instance.
[PE1] ip vpn-instance a
[PE1-vpn-instance-a] route-distinguisher 100:1
[PE1-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE1-vpn-instance-a] vpn-target 100:1 import-extcommunity
[PE1-vpn-instance-a] quit
# Enable IP multicast routing in VPN instance a.
[PE1] multicast routing vpn-instance a
[PE1-mrib-a] quit
# Create an MVPN for VPN instance a.
[PE1] multicast-vpn vpn-instance a mode mdt
# Create an MVPN IPv4 address family for VPN instance a.
[PE1-mvpn-a] address-family ipv4
# Specify the default group, the MVPN source interface, and the data group range for VPN instance a.
[PE1-mvpn-a-ipv4] default-group 239.1.1.1
[PE1-mvpn-a-ipv4] source loopback 1
[PE1-mvpn-a-ipv4] data-group 225.2.2.0 28
[PE1-mvpn-a-ipv4] quit
[PE1-mvpn-a] quit
# Assign an IP address to GigabitEthernet 2/0/1.
[PE1] interface gigabitethernet 2/0/1
[PE1-GigabitEthernet2/0/1] ip address 192.168.6.1 24
# Enable PIM-SM, MPLS, and IPv4 LDP on GigabitEthernet 2/0/1.
[PE1-GigabitEthernet2/0/1] pim sm
[PE1-GigabitEthernet2/0/1] mpls enable
[PE1-GigabitEthernet2/0/1] mpls ldp enable
[PE1-GigabitEthernet2/0/1] quit
# Associate GigabitEthernet 2/0/2 with VPN instance a.
[PE1] interface gigabitethernet 2/0/2
[PE1-GigabitEthernet2/0/2] ip binding vpn-instance a
# Assign an IP address to GigabitEthernet 2/0/2, and enable IGMP on the interface.
[PE1-GigabitEthernet2/0/2] ip address 10.110.1.1 24
[PE1-GigabitEthernet2/0/2] igmp enable
[PE1-GigabitEthernet2/0/2] quit
# Associate GigabitEthernet 2/0/3 with VPN instance a.
[PE1] interface gigabitethernet 2/0/3
[PE1-GigabitEthernet2/0/3] ip binding vpn-instance a
# Assign an IP address to GigabitEthernet 2/0/3, and enable PIM-SM on the interface.
[PE1-GigabitEthernet2/0/3] ip address 10.110.2.1 24
[PE1-GigabitEthernet2/0/3] pim sm
[PE1-GigabitEthernet2/0/3] quit
# Assign an IP address to Loopback 1, and enable PIM-SM on the interface.
[PE1] interface loopback 1
[PE1-LoopBack1] ip address 1.1.1.1 32
[PE1-LoopBack1] pim sm
[PE1-LoopBack1] quit
# Configure BGP.
[PE1] bgp 100
[PE1-bgp-default] group vpn-g internal
[PE1-bgp-default] peer vpn-g connect-interface loopback 1
[PE1-bgp-default] peer 1.1.1.2 group vpn-g
[PE1-bgp-default] peer 1.1.1.3 group vpn-g
[PE1–bgp-default] ip vpn-instance a
[PE1-bgp-default-a] address-family ipv4
[PE1-bgp-default-ipv4-a] import-route rip 2
[PE1-bgp-default-ipv4-a] import-route direct
[PE1-bgp-default-ipv4-a] quit
[PE1-bgp-default-a] quit
[PE1–bgp-default] address-family vpnv4
[PE1–bgp-default-vpnv4] peer vpn-g enable
[PE1–bgp-default-vpnv4] quit
[PE1-bgp-default] address-family ipv4 mdt
[PE1-bgp-default-mdt] peer vpn-g enable
[PE1-bgp-default-mdt] quit
[PE1–bgp-default] quit
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1] area 0.0.0.0
[PE1-ospf-1-area-0.0.0.0] network 192.168.6.0 0.0.0.255
[PE1-ospf-1] quit
# Configure RIP.
[PE1] rip 2 vpn-instance a
[PE1-rip-2] network 10.110.1.0 0.0.0.255
[PE1-rip-2] network 10.110.2.0 0.0.0.255
[PE1-rip-2] import-route bgp
[PE1-rip-2] return
2.     Configure PE 2:
<PE2> system-view
[PE2] router id 1.1.1.2
[PE2] multicast routing
[PE2-mrib] quit
[PE2] mpls lsr-id 1.1.1.2
[PE2] mpls ldp
[PE2-ldp] quit
# Create a VPN instance named b, and configure an RD and route targets for the VPN instance.
[PE2] ip vpn-instance b
[PE2-vpn-instance-b] route-distinguisher 200:1
[PE2-vpn-instance-b] vpn-target 200:1 export-extcommunity
[PE2-vpn-instance-b] vpn-target 200:1 import-extcommunity
[PE2-vpn-instance-b] quit
# Enable IP multicast routing for VPN instance b.
[PE2] multicast routing vpn-instance a
[PE2-mrib-a] quit
# Create an MVPN for VPN instance b.
[PE2] multicast-vpn vpn-instance b mode mdt
# Create an MVPN IPv4 address family for VPN instance b.
[PE2-mvpn-b] address-family ipv4
# Specify the default group, the MVPN source interface, and the data group range for VPN instance b.
[PE2-mvpn-b-ipv4] default-group 239.2.2.2
[PE2-mvpn-b-ipv4] source loopback 1
[PE2-mvpn-b-ipv4] data-group 225.4.4.0 28
[PE2-mvpn-b-ipv4] quit
[PE2-mvpn-b] quit
[PE2] ip vpn-instance a
[PE2-vpn-instance-a] route-distinguisher 100:1
[PE2-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE2-vpn-instance-a] vpn-target 100:1 import-extcommunity
[PE2-vpn-instance-a] quit
# Enable IP multicast routing for VPN instance a.
[PE2-mrib-a] quit
[PE2] multicast-vpn vpn-instance a mode mdt
[PE2-mvpn-a] address-family ipv4
# Specify the default group, MVPN source interface, and the data group range for VPN instance a.
[PE2-mvpn-a-ipv4] default-group 239.1.1.1
[PE2-mvpn-a-ipv4] source loopback 1
[PE2-mvpn-a-ipv4] data-group 225.2.2.0 28
[PE2-mvpn-a-ipv4] quit
[PE2-mvpn-a] quit
[PE2] interface gigabitethernet 2/0/1
[PE2-GigabitEthernet2/0/1] ip address 192.168.7.1 24
[PE2-GigabitEthernet2/0/1] pim sm
[PE2-GigabitEthernet2/0/1] mpls enable
[PE2-GigabitEthernet2/0/1] mpls ldp enable
[PE2-GigabitEthernet2/0/1] quit
# Associate GigabitEthernet 2/0/2 with VPN instance b.
[PE2] interface gigabitethernet 2/0/2
[PE2-GigabitEthernet2/0/2] ip binding vpn-instance b
# Assign an IP address to GigabitEthernet 2/0/2, and enable PIM-SM on the interface.
[PE2-GigabitEthernet2/0/2] ip address 10.110.3.1 24
[PE2-GigabitEthernet2/0/2] pim sm
[PE2-GigabitEthernet2/0/2] quit
[PE2] interface gigabitethernet 2/0/3
[PE2-GigabitEthernet2/0/3] ip binding vpn-instance a
[PE2-GigabitEthernet2/0/3] ip address 10.110.4.1 24
[PE2-GigabitEthernet2/0/3] pim sm
[PE2-GigabitEthernet2/0/3] quit
[PE2] interface loopback 1
[PE2-LoopBack1] ip address 1.1.1.2 32
[PE2-LoopBack1] pim sm
[PE2-LoopBack1] quit
# Configure BGP.
[PE2] bgp 100
[PE2-bgp-default] group vpn-g internal
[PE2-bgp-default] peer vpn-g connect-interface loopback 1
[PE2-bgp-default] peer 1.1.1.1 group vpn-g
[PE2-bgp-default] peer 1.1.1.3 group vpn-g
[PE2–bgp-default] ip vpn-instance a
[PE2-bgp-default-a] address-family ipv4
[PE2-bgp-default-ipv4-a] import-route rip 2
[PE2-bgp-default-ipv4-a] import-route direct
[PE2-bgp-default-ipv4-a] quit
[PE2-bgp-default-a] quit
[PE2–bgp-default] ip vpn-instance b
[PE2-bgp-default-b] address-family ipv4
[PE2-bgp-default-ipv4-b] import-route rip 3
[PE2-bgp-default-ipv4-b] import-route direct
[PE2-bgp-default-ipv4-b] quit
[PE2-bgp-default-b] quit
[PE2–bgp-default] address-family vpnv4
[PE2–bgp-default-vpnv4] peer vpn-g enable
[PE2–bgp-default-vpnv4] quit
[PE2-bgp-default] address-family ipv4 mdt
[PE2-bgp-default-mdt] peer vpn-g enable
[PE2-bgp-default-mdt] quit
[PE2–bgp-default] quit
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1] area 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 1.1.1.2 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 192.168.7.0 0.0.0.255
[PE2-ospf-1] quit
# Configure RIP.
[PE2] rip 2 vpn-instance a
[PE2-rip-2] network 10.110.4.0 0.0.0.255
[PE2-rip-2] import-route bgp
[PE2-rip-2] quit
[PE2] rip 3 vpn-instance b
[PE2-rip-3] network 10.110.3.0 0.0.0.255
[PE2-rip-3] import-route bgp
[PE2-rip-3] return
3.     Configure PE 3:
<PE3> system-view
[PE3] router id 1.1.1.3
[PE3] multicast routing
[PE3-mrib] quit
[PE3] mpls lsr-id 1.1.1.3
[PE3] mpls ldp
[PE3-ldp] quit
# Create loopback interface 1.
[PE3] interface loopback 1
[PE3-LoopBack1] quit
# Create loopback interface 2.
[PE3] interface loopback 2
[PE3-LoopBack2] quit
[PE3] ip vpn-instance a
[PE3-vpn-instance-a] route-distinguisher 100:1
[PE3-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE3-vpn-instance-a] vpn-target 100:1 import-extcommunity
[PE3-vpn-instance-a] quit
[PE3] multicast routing vpn-instance a
[PE3-mrib-a] quit
[PE3] multicast-vpn vpn-instance a mode mdt
[PE3-mvpn-a] address-family ipv4
[PE3-mvpn-a-ipv4] default-group 239.1.1.1
[PE3-mvpn-a-ipv4] source loopback 1
[PE3-mvpn-a-ipv4] data-group 225.2.2.0 28
[PE3-mvpn-a-ipv4] quit
[PE3-mvpn-a] quit
[PE3] ip vpn-instance b
[PE3-vpn-instance-b] route-distinguisher 200:1
[PE3-vpn-instance-b] vpn-target 200:1 export-extcommunity
[PE3-vpn-instance-b] vpn-target 200:1 import-extcommunity
[PE3-vpn-instance-b] quit
[PE3] multicast routing vpn-instance b
[PE3-mrib-b] quit
[PE3] multicast-vpn vpn-instance b mode mdt
[PE3-mvpn-b] address-family ipv4
[PE3-mvpn-b-ipv4] default-group 239.2.2.2
[PE3-mvpn-b-ipv4] source loopback 2
[PE3-mvpn-b-ipv4] data-group 225.4.4.0 28
[PE3-mvpn-b-ipv4] quit
[PE3-mvpn-b] quit
[PE3] interface gigabitethernet 2/0/1
[PE3-GigabitEthernet2/0/1] ip address 192.168.8.1 24
[PE3-GigabitEthernet2/0/1] pim sm
[PE3-GigabitEthernet2/0/1] mpls enable
[PE3-GigabitEthernet2/0/1] mpls ldp enable
[PE3-GigabitEthernet2/0/1] quit
[PE3] interface gigabitethernet 2/0/2
[PE3-GigabitEthernet2/0/2] ip binding vpn-instance a
[PE3-GigabitEthernet2/0/2] ip address 10.110.5.1 24
[PE3-GigabitEthernet2/0/2] pim sm
[PE3-GigabitEthernet2/0/2] quit
# Associate GigabitEthernet 2/0/3 with VPN instance b.
[PE3] interface gigabitethernet 2/0/3
[PE3-GigabitEthernet2/0/3] ip binding vpn-instance b
[PE3-GigabitEthernet2/0/3] ip address 10.110.6.1 24
[PE3-GigabitEthernet2/0/3] pim sm
[PE3-GigabitEthernet2/0/3] quit
# Assign an IP address to Loopback 1, and enable PIM-SM on this interface.
[PE3-LoopBack1] ip address 1.1.1.3 32
[PE3-LoopBack1] pim sm
# Associate Loopback 2 with VPN instance b.
[PE3-LoopBack2] ip binding vpn-instance b
# Assign an IP address to Loopback 2, and enable PIM-SM on the interface.
[PE3-LoopBack2] ip address 33.33.33.33 32
[PE3-LoopBack2] pim sm
# Configure Loopback 2 as a C-BSR and a C-RP.
[PE3] pim vpn-instance b
[PE3-pim-b] c-bsr 33.33.33.33
[PE3-pim-b] c-rp 33.33.33.33
[PE3-pim-b] quit
# Configure BGP.
[PE3] bgp 100
[PE3-bgp-default] group vpn-g internal
[PE3-bgp-default] peer vpn-g connect-interface loopback 1
[PE3-bgp-default] peer 1.1.1.1 group vpn-g
[PE3-bgp-default] peer 1.1.1.2 group vpn-g
[PE3–bgp-default] ip vpn-instance a
[PE3-bgp-default-a] address-family ipv4
[PE3-bgp-default-ipv4-a] import-route rip 2
[PE3-bgp-default-ipv4-a] import-route direct
[PE3-bgp-default-ipv4-a] quit
[PE3-bgp-default-a] quit
[PE3–bgp-default] ip vpn-instance b
[PE3-bgp-default-b] address-family ipv4
[PE3-bgp-default-ipv4-b] import-route rip 3
[PE3-bgp-default-ipv4-b] import-route direct
[PE3-bgp-default-ipv4-b] quit
[PE3-bgp-default-b] quit
[PE3–bgp-default] address-family vpnv4
[PE3–bgp-default-vpnv4] peer vpn-g enable
[PE3–bgp-default-vpnv4] quit
[PE3-bgp-default] address-family ipv4 mdt
[PE3-bgp-default-mdt] peer vpn-g enable
[PE3-bgp-default-mdt] quit
[PE3–bgp-default] quit
# Configure OSPF.
[PE3] ospf 1
[PE3-ospf-1] area 0.0.0.0
[PE3-ospf-1-area-0.0.0.0] network 1.1.1.3 0.0.0.0
[PE3-ospf-1-area-0.0.0.0] network 192.168.8.0 0.0.0.255
[PE3-ospf-1] quit
# Configure RIP.
[PE3] rip 2 vpn-instance a
[PE3-rip-2] network 10.110.5.0 0.0.0.255
[PE3-rip-2] import-route bgp
[PE3-rip-2] quit
[PE3] rip 3 vpn-instance b
[PE3-rip-3] network 10.110.6.0 0.0.0.255
[PE3-rip-3] network 33.33.33.33 0.0.0.0
[PE3-rip-3] import-route bgp
[PE3-rip-3] return
4.     Configuring the P router:
# Enable IP multicast routing on the public network.
<P> system-view
[P] multicast routing
[P-mrib] quit
[P] mpls lsr-id 2.2.2.2
[P] mpls ldp
[P-ldp] quit
[P] interface gigabitethernet 2/0/1
[P-GigabitEthernet2/0/1] ip address 192.168.6.2 24
[P-GigabitEthernet2/0/1] pim sm
[P-GigabitEthernet2/0/1] mpls enable
[P-GigabitEthernet2/0/1] mpls ldp enable
[P-GigabitEthernet2/0/1] quit
# Assign an IP address to GigabitEthernet 2/0/2.
[P] interface gigabitethernet 2/0/2
[P-GigabitEthernet2/0/2] ip address 192.168.7.2 24
# Enable PIM-SM, MPLS, and IPv4 LDP on GigabitEthernet 2/0/2.
[P-GigabitEthernet2/0/2] pim sm
[P-GigabitEthernet2/0/2] mpls enable
[P-GigabitEthernet2/0/2] mpls ldp enable
[P-GigabitEthernet2/0/2] quit
# Assign an IP address to GigabitEthernet 2/0/3.
[P] interface gigabitethernet 2/0/3
[P-GigabitEthernet2/0/3] ip address 192.168.8.2 24
# Enable PIM-SM, MPLS, and IPv4 LDP on GigabitEthernet 2/0/3.
[P-GigabitEthernet2/0/3] pim sm
[P-GigabitEthernet2/0/3] mpls enable
[P-GigabitEthernet2/0/3] mpls ldp enable
[P-GigabitEthernet2/0/3] quit
[P] interface loopback 1
[P-LoopBack1] ip address 2.2.2.2 32
[P-LoopBack1] pim sm
[P-LoopBack1] quit
# Configure Loopback 1 as a C-BSR and a C-RP.
[P] pim
[P-pim] c-bsr 2.2.2.2
[P-pim] c-rp 2.2.2.2
[P-pim] quit
# Configure OSPF.
[P] ospf 1
[P-ospf-1] area 0.0.0.0
[P-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[P-ospf-1-area-0.0.0.0] network 192.168.6.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 192.168.7.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 192.168.8.0 0.0.0.255
5.     Configure CE a1:
# Enable IP multicast routing.
<CEa1> system-view
[CEa1] multicast routing
[CEa1-mrib] quit
# Assign an IP address to GigabitEthernet 2/0/1, and enable PIM-SM on the interface.
[CEa1] interface gigabitethernet 2/0/1
[CEa1-GigabitEthernet2/0/1] ip address 10.110.7.1 24
[CEa1-GigabitEthernet2/0/1] pim sm
[CEa1-GigabitEthernet2/0/1] quit
[CEa1] interface gigabitethernet 2/0/2
[CEa1-GigabitEthernet2/0/2] ip address 10.110.2.2 24
[CEa1-GigabitEthernet2/0/2] pim sm
[CEa1-GigabitEthernet2/0/2] quit
# Configure RIP.
[CEa1] rip 2
[CEa1-rip-2] network 10.110.2.0 0.0.0.255
[CEa1-rip-2] network 10.110.7.0 0.0.0.255
6.     Configure CE b1:
<CEb1> system-view
[CEb1] multicast routing
[CEb1-mrib] quit
[CEb1] interface gigabitethernet 2/0/1
[CEb1-GigabitEthernet2/0/1] ip address 10.110.8.1 24
[CEb1-GigabitEthernet2/0/1] pim sm
[CEb1-GigabitEthernet2/0/1] quit
[CEb1] interface gigabitethernet 2/0/2
[CEb1-GigabitEthernet2/0/2] ip address 10.110.3.2 24
[CEb1-GigabitEthernet2/0/2] pim sm
[CEb1-GigabitEthernet2/0/2] quit
# Configure RIP.
[CEb1] rip 3
[CEb1-rip-3] network 10.110.3.0 0.0.0.255
[CEb1-rip-3] network 10.110.8.0 0.0.0.255
7.     Configure CE a2:
<CEa2> system-view
[CEa2] multicast routing
[CEa2-mrib] quit
# Assign an IP address to GigabitEthernet 2/0/1, and enable IGMP on the interface.
[CEa2] interface gigabitethernet 2/0/1
[CEa2-GigabitEthernet2/0/1] ip address 10.110.9.1 24
[CEa2-GigabitEthernet2/0/1] igmp enable
[CEa2-GigabitEthernet2/0/1] quit
[CEa2] interface gigabitethernet 2/0/2
[CEa2-GigabitEthernet2/0/2] ip address 10.110.4.2 24
[CEa2-GigabitEthernet2/0/2] pim sm
[CEa2-GigabitEthernet2/0/2] quit
[CEa2] interface gigabitethernet 2/0/3
[CEa2-GigabitEthernet2/0/3] ip address 10.110.12.1 24
[CEa2-GigabitEthernet2/0/3] pim sm
[CEa2-GigabitEthernet2/0/3] quit
[CEa2] interface loopback 1
[CEa2-LoopBack1] ip address 22.22.22.22 32
[CEa2-LoopBack1] pim sm
[CEa2-LoopBack1] quit
[CEa2] pim
[CEa2-pim] c-bsr 22.22.22.22
[CEa2-pim] c-rp 22.22.22.22
[CEa2-pim] quit
# Configure RIP.
[CEa2] rip 2
[CEa2-rip-2] network 10.110.4.0 0.0.0.255
[CEa2-rip-2] network 10.110.9.0 0.0.0.255
[CEa2-rip-2] network 10.110.12.0 0.0.0.255
[CEa2-rip-2] network 22.22.22.22 0.0.0.0
8.     Configure CE a3:
<CEa3> system-view
[CEa3] multicast routing
[CEa3-mrib] quit
[CEa3] interface gigabitethernet 2/0/1
[CEa3-GigabitEthernet2/0/1] ip address 10.110.10.1 24
[CEa3-GigabitEthernet2/0/1] igmp enable
[CEa3-GigabitEthernet2/0/1] quit
[CEa3] interface gigabitethernet 2/0/2
[CEa3-GigabitEthernet2/0/2] ip address 10.110.5.2 24
[CEa3-GigabitEthernet2/0/2] pim sm
[CEa3-GigabitEthernet2/0/2] quit
[CEa3] interface gigabitethernet 2/0/3
[CEa3-GigabitEthernet2/0/3] ip address 10.110.12.2 24
[CEa3-GigabitEthernet2/0/3] pim sm
[CEa3-GigabitEthernet2/0/3] quit
# Configure RIP.
[CEa3] rip 2
[CEa3-rip-2] network 10.110.5.0 0.0.0.255
[CEa3-rip-2] network 10.110.10.0 0.0.0.255
[CEa3-rip-2] network 10.110.12.0 0.0.0.255
9.     Configure CE b2:
<CEb2> system-view
[CEb2] multicast routing
[CEb2-mrib] quit
[CEb2] interface gigabitethernet 2/0/1
[CEb2-GigabitEthernet2/0/1] ip address 10.110.11.1 24
[CEb2-GigabitEthernet2/0/1] igmp enable
[CEb2-GigabitEthernet2/0/1] quit
[CEb2] interface gigabitethernet 2/0/2
[CEb2-GigabitEthernet2/0/2] ip address 10.110.6.2 24
[CEb2-GigabitEthernet2/0/2] pim sm
[CEb2-GigabitEthernet2/0/2] quit
# Configure RIP.
[CEb2] rip 3
[CEb2-rip-3] network 10.110.6.0 0.0.0.255
[CEb2-rip-3] network 10.110.11.0 0.0.0.255
# Display information about the local default group for IPv4 multicast transmission in each VPN instance on PE 1.
[PE1] display multicast-vpn default-group local
MVPN local default-group information:
 Group address    Source address   Interface     VPN instance
 239.1.1.1        1.1.1.1          MTunnel0      a
# Display information about the local default group for IPv4 multicast transmission in each VPN instance on PE 2.
[PE2] display multicast-vpn default-group local
 239.1.1.1        1.1.1.2          MTunnel0      a
 239.1.1.1        1.1.1.2          MTunnel1      b
# Display information about the local default group for IPv4 multicast transmission in each VPN instance on PE 3.
[PE3] display multicast-vpn default-group local
 239.1.1.1        1.1.1.3          MTunnel0      a
 239.2.2.2        1.1.1.3          MTunnel1      b
Example: Configuring intra-AS RSVP-TE-based MVPN
As shown in Figure 22, configure intra-AS RSVP-TE-based MVPN to meet the following requirements:
Item
·     Configure OSPF on the public network, and configure RIP between the PEs and the CEs.
·     Configure MPLS TE and MPLS RSVP on the public network.
IGMP
PIM
·     Enable PIM-SM on all interfaces that do not have attached receiver hosts on PE 1, PE 2, and PE 3.
MSDP
·     Enable MSDP on CE a2, and specify GigabitEthernet 2/0/2 as the local MSDP connection interface.
·     Enable MSDP on PE 2 for VPN instance a, and specify GigabitEthernet 2/0/3 as the local MSDP connection interface.
Figure 22 Network diagram
Device
IP address
Device
IP address
S 1
10.110.7.2/24
PE 3
GE2/0/1
192.168.8.1/24
S 2
10.110.8.2/24
PE 3
GE2/0/2
10.110.5.1/24
R 1
10.110.1.2/24
PE 3
GE2/0/3
10.110.6.1/24
R 2
10.110.9.2/24
PE 3
Loop1
1.1.1.3/32
R 3
10.110.10.2/24
PE 3
Loop2
33.33.33.33/32
R 4
10.110.11.2/24
CE a1
GE2/0/1
10.110.7.1/24
P
GE2/0/1
192.168.6.2/24
CE a1
GE2/0/2
10.110.2.2/24
P
GE2/0/2
192.168.7.2/24
CE a2
GE2/0/1
10.110.9.1/24
P
GE2/0/3
192.168.8.2/24
CE a2
GE2/0/2
10.110.4.2/24
P
Loop1
2.2.2.2/32
CE a2
GE2/0/3
10.110.12.1/24
PE 1
GE2/0/1
192.168.6.1/24
CE a2
Loop1
22.22.22.22/32
PE 1
GE2/0/2
10.110.1.1/24
CE a3
GE2/0/1
10.110.10.1/24
PE 1
GE2/0/3
10.110.2.1/24
CE a3
GE2/0/2
10.110.5.2/24
PE 1
Loop1
1.1.1.1/32
CE a3
GE2/0/3
10.110.12.2/24
PE 2
GE2/0/1
192.168.7.1/24
CE b1
GE2/0/1
10.110.8.1/24
PE 2
GE2/0/2
10.110.3.1/24
CE b1
GE2/0/2
10.110.3.2/24
PE 2
GE2/0/3
10.110.4.1/24
CE b2
GE2/0/1
10.110.11.1/24
PE 2
Loop1
1.1.1.2/32
CE b2
GE2/0/2
10.110.6.2/24
1.     Configure PE 1:
# Configure a global router ID.
<PE1> system-view
# Configure an LSR ID, and enable MPLS TE, MPLS LDP, and RSVP globally.
[PE1] mpls te
[PE1-te] quit
[PE1] rsvp
[PE1-rsvp] quit
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-mrib-a] quit
# Create an RSVP-TE-based MVPN for VPN instance a.
[PE1] multicast-vpn vpn-instance a mode rsvp-te
# Specify the MVPN source interface for VPN instance a.
# Enable dynamic inclusive tunnel creation.
[PE1-mvpn-a-ipv4] inclusive-tunnel dynamic
# Enable dynamic selective tunnel creation.
[PE1-mvpn-a-ipv4] selective-tunnel dynamic
[PE1-mvpn-a] quit
# Enable MPLS, MPLS TE, MPLS LDP, and RSVP on GigabitEthernet 2/0/1.
[PE1-GigabitEthernet2/0/1] mpls te enable
[PE1-GigabitEthernet2/0/1] rsvp enable
# Assign an IP address to Loopback 1.
# Configure BGP.
[PE1] bgp 100
[PE1-bgp-default] peer 1.1.1.2 as-number 100
[PE1-bgp-default] peer 1.1.1.2 connect-interface loopback 1
[PE1-bgp-default] peer 1.1.1.3 as-number 100
[PE1-bgp-default] peer 1.1.1.3 connect-interface loopback 1
[PE1-bgp-default] address-family ipv4 unicast
[PE1-bgp-default-ipv4] peer 1.1.1.2 enable
[PE1-bgp-default-ipv4] peer 1.1.1.3 enable
[PE1-bgp-default-ipv4] quit
[PE1-bgp-default] address-family ipv4 mvpn
[PE1-bgp-default-mvpn] peer 1.1.1.2 enable
[PE1-bgp-default-mvpn] peer 1.1.1.3 enable
[PE1-bgp-default-mvpn]quit
[PE1-bgp-default-vpnv4] mvpn-advertise-rt-import
[PE1-bgp-default-vpnv4] peer 1.1.1.2 enable
[PE1-bgp-default-vpnv4] peer 1.1.1.3 enable
[PE1-bgp-default-vpnv4] quit
[PE1-bgp-default-a] address-family ipv4 unicast
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1] quit
# Configure RIP.
[PE1-rip-2] quit
2.     Configure PE 2:
<PE2> system-view
[PE2] mpls te
[PE2-te] quit
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] rsvp
[PE2-rsvp] quit
[PE2-mrib-a] quit
# Create an RSVP-TE-based MVPN for VPN instance b.
[PE2] multicast-vpn vpn-instance b mode rsvp-te
# Specify the MVPN source interface for VPN instance b.
[PE2-mvpn-b-ipv4] inclusive-tunnel dynamic
[PE2-mvpn-b-ipv4] selective-tunnel dynamic
[PE2-mvpn-b] quit
[PE2-mrib-a] quit
# Enable MSDP for VPN instance a.
[PE2] msdp vpn-instance a
[PE2-msdp-a] peer 10.110.4.2 connect-interface gigabitethernet 2/0/3
[PE2-msdp-a] quit
[PE2] multicast-vpn vpn-instance a mode rsvp-te
[PE2-mvpn-a-ipv4] inclusive-tunnel dynamic
[PE2-mvpn-a-ipv4] selective-tunnel dynamic
[PE2-mvpn-a] quit
[PE2-GigabitEthernet2/0/1] mpls te enable
[PE2-GigabitEthernet2/0/1] rsvp enable
# Configure BGP.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.1 as-number 100
[PE2-bgp-default] peer 1.1.1.1 connect-interface loopback 1
[PE2-bgp-default] peer 1.1.1.3 as-number 100
[PE2-bgp-default] peer 1.1.1.3 connect-interface loopback 1
[PE2-bgp-default] address-family ipv4 unicast
[PE2-bgp-default-ipv4] peer 1.1.1.1 enable
[PE2-bgp-default-ipv4] peer 1.1.1.3 enable
[PE2-bgp-default-ipv4] quit
[PE2-bgp-default] address-family ipv4 mvpn
[PE2-bgp-default-mvpn] peer 1.1.1.1 enable
[PE2-bgp-default-mvpn] peer 1.1.1.3 enable
[PE2-bgp-default-mvpn]quit
[PE2-bgp-default-vpnv4] mvpn-advertise-rt-import
[PE2-bgp-default-vpnv4] peer 1.1.1.1 enable
[PE2-bgp-default-vpnv4] peer 1.1.1.3 enable
[PE2-bgp-default-vpnv4] quit
[PE2-bgp-default-a] address-family ipv4 unicast
[PE2-bgp-default-b] address-family ipv4 unicast
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1] quit
# Configure RIP.
[PE2-rip-2] quit
[PE2-rip-3] return
3.     Configure PE 3:
<PE3> system-view
[PE3] mpls te
[PE3-te] quit
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] rsvp
[PE3-rsvp] quit
[PE3-mrib-a] quit
[PE3] multicast-vpn vpn-instance a mode rsvp-te
[PE3-mvpn-a-ipv4] inclusive-tunnel dynamic
[PE3-mvpn-a-ipv4] selective-tunnel dynamic
[PE3-mvpn-a] quit
[PE3-mrib-b] quit
[PE3] multicast-vpn vpn-instance b mode rsvp-te
[PE3-mvpn-b-ipv4] source loopback 1
[PE3-mvpn-b-ipv4] inclusive-tunnel dynamic
[PE3-mvpn-b-ipv4] selective-tunnel dynamic
[PE3-mvpn-b] quit
# Enable MPLS, MPLS-TE, MPLS LDP, and RSVP on GigabitEthernet 2/0/1.
[PE3-GigabitEthernet2/0/1] mpls te enable
[PE3-GigabitEthernet2/0/1] rsvp enable
[PE3-pim-b] quit
# Configure BGP.
[PE3] bgp 100
[PE3-bgp-default] peer 1.1.1.1 as-number 100
[PE3-bgp-default] peer 1.1.1.1 connect-interface loopback 1
[PE3-bgp-default] peer 1.1.1.2 as-number 100
[PE3-bgp-default] peer 1.1.1.2 connect-interface loopback 1
[PE3-bgp-default] address-family ipv4 unicast
[PE3-bgp-default-ipv4] peer 1.1.1.1 enable
[PE3-bgp-default-ipv4] peer 1.1.1.2 enable
[PE3-bgp-default-ipv4] quit
[PE3-bgp-default] address-family ipv4 mvpn
[PE3-bgp-default-mvpn] peer 1.1.1.1 enable
[PE3-bgp-default-mvpn] peer 1.1.1.2 enable
[PE3-bgp-default-mvpn]quit
[PE3-bgp-default] address-family vpnv4
[PE3-bgp-default-vpnv4] mvpn-advertise-rt-import
[PE3-bgp-default-vpnv4] peer 1.1.1.1 enable
[PE3-bgp-default-vpnv4] peer 1.1.1.2 enable
[PE3-bgp-default-vpnv4] quit
[PE3-bgp-default-a] address-family ipv4 unicast
# Configure OSPF.
[PE3] ospf 1
[PE3-ospf-1] quit
# Configure RIP.
[PE3-rip-2] quit
[PE3-rip-3] quit
[P] mpls te
[P-te] quit
[P] mpls ldp
[P-ldp] quit
[P] rsvp
[P-rsvp] quit
[P-GigabitEthernet2/0/1] mpls te enable
[P-GigabitEthernet2/0/1] rsvp enable
# Enable MPLS, MPLS TE, MPLS LDP, and RSVP on GigabitEthernet 2/0/2.
[P-GigabitEthernet2/0/2] mpls te enable
[P-GigabitEthernet2/0/2] rsvp enable
# Assign an IP address to GigabitEthernet2/0/3.
# Enable MPLS, MPLS TE, MPLS LDP, and RSVP on GigabitEthernet2/0/3.
[P-GigabitEthernet2/0/3] mpls te enable
[P-GigabitEthernet2/0/3] rsvp enable
[P-LoopBack1] quit
# Configure OSPF.
[P] ospf 1
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
5.     Configure CE a1:
<CEa1> system-view
[CEa1-mrib] quit
# Configure RIP.
[CEa1] rip 2
[CEa1-rip-2] quit
6.     Configure CE b1:
<CEb1> system-view
[CEb1-mrib] quit
# Configure RIP.
[CEb1] rip 3
[CEb1-rip-2] quit
7.     Configure CE a2:
<CEa2> system-view
[CEa2-mrib] quit
[CEa2] pim vpn-instance a
[CEa2-pim] quit
# Configure MSDP.
[CEa2] msdp
[CEa2-msdp] peer 10.110.4.1 connect-interface GigabitEthernet 2/0/2
[CEa2-msdp] quit
# Configure RIP.
[CEa2] rip 2
[CEa2-rip-2] quit
8.     Configure CE a3:
<CEa3> system-view
[CEa3-mrib] quit
# Configure RIP.
[CEa3] rip 2
[CEa3-rip-2] quit
9.     Configure CE b2:
<CEb2> system-view
[CEb2-mrib] quit
# Configure RIP.
[CEb2] rip 3
[CEb2-rip-2] quit
# Display the C-multicast A-D routing information VPN instances on PE 1.
[PE1] display multicast-vpn vpn-instance a c-multicast routing-table
 Total 0 (*, G) entries; 1 (S, G) entries
(10.110.7.2, 225.0.0.1)
   CreateTime: 02:54:43
   Tunnel information: Tunnel2
   Leaf neighbor information:
   Total number of Leaf neighbors: 2
   1: 1.1.1.2
   2: 1.1.1.3
# Display RSVP-TE tunnel neighbor information for VPN instances on PE 1.
[PE1] display multicast-vpn vpn-instance a neighbor
Total 1 Selective Tunnels in using
Total 0 Selective Tunnels in creating
Inclusive Tunnel : Tunnel1
Tunnel Identifier:<0x01010101, 0x0, 0x5, 0x01010101>
Neighbor        State       Up/DownTime
1.1.1.2         Up           02:50:49
1.1.1.3         Up           02:50:49
Selective Tunnel : Tunnel2
Tunnel Identifier:<0x01010101, 0x0, 0x8, 0x01010101>
1.1.1.2         Up           01:10:23
1.1.1.3         Up           01:10:23
# Display the C-multicast A-D routing information VPN instances on PE 2.
[PE2] display multicast-vpn vpn-instance b c-multicast routing-table
(10.110.8.2, 225.0.0.2)
   UpTime: 02:54:43
   Total number of Leaf neighbors: 1
   1: 1.1.1.3
# Display RSVP-TE tunnel neighbor information for VPN instances on PE 2.
[PE2] display multicast-vpn vpn-instance b neighbor
Tunnel Identifier:<0x01010102, 0x0, 0x8, 0x01010102>
1.1.1.3         Up           02:50:49
1.1.1.3         Up           01:10:23
Example: Configuring intra-AS mLDP-based MVPN
As shown in Figure 23, configure intra-AS mLDP-based MVPN to meet the following requirements:
Item
·     PE 3: GigabitEthernet 2/0/2 belongs to VPN instance a. GigabitEthernet 2/0/3 and Loopback 2 belong to VPN instance b. GigabitEthernet 2/0/1 and Loopback 1 belong to the public network.
IGMP
PIM
MSDP
Figure 23 Network diagram
Table 3 Interface and IP address assignment
Device
IP address
Device
IP address
S 1
10.110.7.2/24
PE 3
GE2/0/1
192.168.8.1/24
S 2
10.110.8.2/24
PE 3
GE2/0/2
10.110.5.1/24
R 1
10.110.1.2/24
PE 3
GE2/0/3
10.110.6.1/24
R 2
10.110.9.2/24
PE 3
Loop1
1.1.1.3/32
R 3
10.110.10.2/24
PE 3
Loop2
33.33.33.33/32
R 4
10.110.11.2/24
CE a1
GE2/0/1
10.110.7.1/24
P
GE2/0/1
192.168.6.2/24
CE a1
GE2/0/2
10.110.2.2/24
P
GE2/0/2
192.168.7.2/24
CE a2
GE2/0/1
10.110.9.1/24
P
GE2/0/3
192.168.8.2/24
CE a2
GE2/0/2
10.110.4.2/24
P
Loop1
2.2.2.2/32
CE a2
GE2/0/3
10.110.12.1/24
PE 1
GE2/0/1
192.168.6.1/24
CE a2
Loop1
22.22.22.22/32
PE 1
GE2/0/2
10.110.1.1/24
CE a3
GE2/0/1
10.110.10.1/24
PE 1
GE2/0/3
10.110.2.1/24
CE a3
GE2/0/2
10.110.5.2/24
PE 1
Loop1
1.1.1.1/32
CE a3
GE2/0/3
10.110.12.2/24
PE 2
GE2/0/1
192.168.7.1/24
CE b1
GE2/0/1
10.110.8.1/24
PE 2
GE2/0/2
10.110.3.1/24
CE b1
GE2/0/2
10.110.3.2/24
PE 2
GE2/0/3
10.110.4.1/24
CE b2
GE2/0/1
10.110.11.1/24
PE 2
Loop1
1.1.1.2/32
CE b2
GE2/0/2
10.110.6.2/24
1.     Configure PE 1:
<PE1> system-view
# Configure an LSR ID, and enable MPLS LDP and mLDP P2MP globally.
[PE1] mpls ldp
[PE1-ldp] mldp p2mp
[PE1-ldp] quit
[PE1-mrib-a] quit
# Create an mLDP-based MVPN for VPN instance a.
[PE1] multicast-vpn vpn-instance a mode mldp
# Enable dynamic inclusive tunnel creation and dynamic selective tunnel creation for VPN instance a.
[PE1-mvpn-a] quit
# Assign an IP address to GigabitEthernet 2/0/1, and enable MPLS and IPv4 LDP on GigabitEthernet 2/0/1.
# Associate GigabitEthernet 2/0/2 with VPN instance a, assign an IP address to the interface, and enable IGMP on the interface.
# Associate GigabitEthernet 2/0/3 with VPN instance a, assign an IP address to the interface, and enable PIM-SM on the interface.
# Configure BGP.
[PE1] bgp 100
[PE1-bgp-default-mvpn] quit
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1] quit
# Configure RIP.
[PE1-rip-2] quit
2.     Configure PE 2:
<PE2> system-view
[PE2] mpls ldp
[PE2-ldp] mldp p2mp
[PE2-ldp] quit
[PE2-mrib-a] quit
# Create an mLDP-based MVPN for VPN instance b.
[PE2] multicast-vpn vpn-instance b mode mldp
# Enable dynamic inclusive tunnel creation and dynamic selective tunnel creation for VPN instance b.
[PE2-mvpn-b] quit
[PE2-mrib-a] quit
[PE2] multicast-vpn vpn-instance a mode mldp
[PE2-mvpn-a] quit
# Assign an IP address to GigabitEthernet 2/0/1, and enable MPLS and IPv4 LDP on the interface.
# Associate GigabitEthernet 2/0/2 with VPN instance b, assign an IP address to the interface, and enable PIM-SM on the interface.
# Configure BGP.
[PE2] bgp 100
[PE2-bgp-default-mvpn] quit
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1] quit
# Configure RIP.
[PE2-rip-2] quit
[PE2-rip-3] quit
3.     Configure PE 3:
<PE3> system-view
[PE3] mpls ldp
[PE3-ldp] mldp p2mp
[PE3-ldp] quit
[PE3-mrib-a] quit
[PE3] multicast-vpn vpn-instance a mode mldp
[PE3-mvpn-a] quit
[PE3-mrib-b] quit
[PE3] multicast-vpn vpn-instance b mode mldp
[PE3-mvpn-b] quit
# Associate GigabitEthernet 2/0/2 with VPN instance a, assign an IP address to the interface, and enable PIM-SM on the interface.
# Associate GigabitEthernet 2/0/3 with VPN instance b, assign an IP address to the interface, and enable PIM-SM on the interface.
# Associate Loopback 2 with VPN instance b, assign an IP address to the interface, and enable PIM-SM on the interface.
[PE3-pim-b] quit
# Configure BGP.
[PE3] bgp 100
[PE3-bgp-default-b] address-family ipv4 unicast
# Configure OSPF.
[PE3] ospf 1
[PE3-ospf-1] quit
# Configure RIP.
[PE3-rip-2] quit
[PE3-rip-3] quit
4.     Configure P:
[P] mpls ldp
[P-ldp] mldp p2mp
[P-ldp] quit
# Assign an IP address to GigabitEthernet 2/0/2, and enable MPLS and IPv4 LDP on the interface.
# Assign an IP address to GigabitEthernet2/0/3, and enable MPLS and IPv4 LDP on the interface.
[P-LoopBack1] quit
# Configure OSPF.
[P] ospf 1
[P-ospf-1] quit
5.     Configure CE a1:
<CEa1> system-view
[CEa1-mrib] quit
# Configure RIP.
[CEa1] rip 2
[CEa1-rip-2] quit
6.     Configure CE b1:
<CEb1> system-view
[CEb1-mrib] quit
# Configure RIP.
[CEb1] rip 3
[CEb1-rip-2] quit
7.     Configure CE a2:
<CEa2> system-view
[CEa2-mrib] quit
[CEa2-pim] quit
# Configure MSDP.
[CEa2] msdp
[CEa2-msdp] quit
# Configure RIP.
[CEa2] rip 2
[CEa2-rip-2] quit
8.     Configure CE a3:
<CEa3> system-view
[CEa3-mrib] quit
# Configure RIP.
[CEa3] rip 2
[CEa3-rip-2] quit
9.     Configure CE b2:
<CEb2> system-view
[CEb2-mrib] quit
# Configure RIP.
[CEb2] rip 3
[CEb2-rip-2] quit
# Display information about the mLDP inclusive tunnel for VPN instance a on PE 1.
[PE1] display multicast-vpn vpn-instance a inclusive-tunnel local
Tunnel interface: LSPVOif0
Tunnel identifier: mLDP P2MP <0xe4000000>
Tunnel state: Up
Opaque value: 0x010004e4000000
Root: 1.1.1.1 (local)
Leafs:
  1: 1.1.1.2
  2: 1.1.1.3
# Display information about mLDP selective tunnels for VPN instance a on PE 1.
[PE1]display multicast-vpn vpn-instance a selective-tunnel local
Total 1 selective tunnel in using
Total 0 selective tunnel in creating
Tunnel interface: LSPVOif1
Tunnel identifier: mLDP P2MP <0xe4000001>
Tunnel state: Up
Opaque value: 0x010004e4000001
# Display C-multicast A-D route information for VPN instance a on PE 1.
   Tunnel Information: LSPVOif1
# Display information about the mLDP inclusive tunnel for VPN instance a on PE 2.
[PE2] display multicast-vpn vpn-instance a inclusive-tunnel remote
Tunnel interface: --
Tunnel state: --
Root: 1.1.1.1
Leaf:
  1: 1.1.1.2 (local)
# Display information about mLDP selective tunnels for VPN instance a on PE 2.
[PE2] display multicast-vpn vpn-instance a selective-tunnel remote
Tunnel state: --
Root: 1.1.1.1
Leaf:
  1: 1.1.1.2 (local)
# Display information about the mLDP inclusive tunnel for VPN instance b on PE 2.
[PE2] display multicast-vpn vpn-instance b inclusive-tunnel local
Tunnel state: Up
Root: 1.1.1.2 (local)
Leafs:
  1: 1.1.1.1
  2: 1.1.1.3
# Display information about mLDP selective tunnels for VPN instance b on PE 2.
[PE2] display multicast-vpn vpn-instance b selective-tunnel local
Tunnel state: Up
# Display C-multicast A-D route information for VPN instance b on PE 2.
# Display information about the mLDP inclusive tunnel for VPN instance b on PE 3.
[PE3] display multicast-vpn vpn-instance b inclusive-tunnel remote
Tunnel state: --
Root: 1.1.1.2
Leaf:
  1: 1.1.1.3 (local)
# Display information about mLDP selective tunnels for VPN instance b on PE 3.
[PE3] display multicast-vpn vpn-instance b selective-tunnel remote
Tunnel state: --
Root: 1.1.1.2
Leaf:
  1: 1.1.1.3 (local)
Example: Configuring intra-AS M6VPE
As shown in Figure 24, configure intra-AS M6VPE to meet the following requirements:
Item
·     Configure OSPF on the public network, and configure OSPFv3 between the PE devices and the CE devices.
IP multicast routing and IPv6 multicast routing
·     Enable IP multicast routing on P.
·     Enable IP multicast routing for the public network on PE 1, PE 2, and PE 3.
·     Enable IPv6 multicast routing for VPN instance a on PE 1, PE 2, and PE 3.
·     Enable IPv6 multicast routing for VPN instance b on PE 2 and PE 3.
·     Enable IPv6 multicast routing on CE a1, CE a2, CE a3, CE b1, and CE b2.
MLDv1
·     Enable MLDv1 on GigabitEthernet 2/0/2 of PE 1.
·     Enable MLDv1 on GigabitEthernet 2/0/1 of CE a2, CE a3, and CE b2.
PIM and IPv6 PIM
Enable PIM-SM on the public network and IPv6 PIM-SM for VPN instances a and b:
·     Enable PIM-SM on all interfaces of P.
·     Enable PIM-SM on all public network interfaces and IPv6 PIM-SM on private network interfaces of PE 1, PE 2, and PE 3.
·     Enable IPv6 PIM-SM on all interfaces that do not have receivers on CE a1, CE a2, CE a3, CE b1, and CE b2.
·     Configure Loopback 1 of P as a C-BSR and a C-RP for the public network to provide services for all IPv4 multicast groups.
·     Configure Loopback 1 of CE a2 as a C-BSR and a C-RP for VPN instance a to provide services for all IPv6 multicast groups.
·     Configure Loopback 2 of PE 3 as a C-BSR and a C-RP for VPN instance b to provide services for all IPv6 multicast groups.
Figure 24 Network diagram
Table 4 Interface and IP address assignment
Device
IPv4/IPv6 address
Device
IPv4/IPv6 address
S 1
10:110:7::2/64
PE 3
GE2/0/1
192.168.8.1/24
S 2
10:110:8::2/64
PE 3
GE2/0/2
10:110:5::1/64
R 1
10:110:1::2/64
PE 3
GE2/0/3
10:110:6::1/64
R 2
10:110:9::2/64
PE 3
Loop1
1.1.1.3/32
R 3
10:110:10::2/64
PE 3
Loop2
33.33.33.33/32
R 4
10:110:11::2/64
CE a1
GE2/0/1
10:110:7::1/64
P
GE2/0/1
192.168.6.2/24
CE a1
GE2/0/2
10:110:2::2/64
P
GE2/0/2
192.168.7.2/24
CE a2
GE2/0/1
10:110:9::1/64
P
GE2/0/3
192.168.8.2/24
CE a2
GE2/0/2
10:110:4::2/64
P
Loop1
2.2.2.2/32
CE a2
GE2/0/3
10:110:12::1/64
PE 1
GE2/0/1
192.168.6.1/24
CE a2
Loop1
22:22:22::22/128
PE 1
GE2/0/2
10:110:1::1/64
CE a3
GE2/0/1
10:110:10::1/64
PE 1
GE2/0/3
10:110:2::1/64
CE a3
GE2/0/2
10:110:5::2/64
PE 1
Loop1
1.1.1.1/32
CE a3
GE2/0/3
10:110:12::2/64
PE 2
GE2/0/1
192.168.7.1/24
CE b1
GE2/0/1
10:110:8::1/64
PE 2
GE2/0/2
10:110:3::1/64
CE b1
GE2/0/2
10:110:3::2/64
PE 2
GE2/0/3
10:110:4::1/64
CE b2
GE2/0/1
10:110:11::1/64
PE 2
Loop1
1.1.1.2/32
CE b2
GE2/0/2
10:110:6::2/64
1.     Configure PE 1:
<PE1> system-view
[PE1-mrib] quit
[PE1] mpls ldp
[PE1-ldp] quit
# Create a VPN instance named a, and configure the RD and route targets for the VPN instance.
# Enable IPv6 multicast routing for VPN instance a.
[PE1] ipv6 multicast routing vpn-instance a
[PE1-mrib6-a] quit
# Create an MVPN IPv6 address family for VPN instance a.
[PE1-mvpn-a] address-family ipv6
[PE1-mvpn-a-ipv6] default-group 239.1.1.1
[PE1-mvpn-a-ipv6] source loopback 1
[PE1-mvpn-a-ipv6] data-group 225.2.2.0 28
[PE1-mvpn-a-ipv6] quit
[PE1-mvpn-a] quit
# Associate GigabitEthernet 2/0/2 with VPN instance a, and assign an IPv6 address to the interface.
[PE1-GigabitEthernet2/0/2] ipv6 address 10:110:1::1 64
# Configure GigabitEthernet 2/0/2 to run OSPFv3 process 2 in Area 0, and enable MLD on the interface.
[PE1-GigabitEthernet2/0/2] ospfv3 2 area 0.0.0.0
[PE1-GigabitEthernet2/0/2] mld enable
# Associate GigabitEthernet 2/0/3 with VPN instance a, and assign an IPv6 address to the interface.
[PE1-GigabitEthernet2/0/3] ipv6 address 10:110:2::1 64
# Configure GigabitEthernet 2/0/3 to run OSPFv3 process 2 in Area 0, and enable IPv6 PIM-SM on the interface.
[PE1-GigabitEthernet2/0/3] ospfv3 2 area 0.0.0.0
[PE1-GigabitEthernet2/0/3] ipv6 pim sm
# Configure BGP.
[PE1] bgp 100
[PE1-bgp-default-a] address-family ipv6
[PE1-bgp-default-ipv6-a] import-route ospfv3 2
[PE1-bgp-default-ipv6-a] import-route direct
[PE1-bgp-default-ipv6-a] quit
[PE1–bgp-default] address-family vpnv6
[PE1–bgp-default-vpnv6] peer vpn-g enable
[PE1–bgp-default-vpnv6] quit
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1] quit
# Configure OSPFv3.
[PE1] ospfv3 2 vpn-instance a
[PE1-ospfv3-2] router-id 1.1.1.1
[PE1-ospfv3-2] import-route bgp4+
[PE1-ospfv3-2] import-route direct
[PE1-ospfv3-2] area 0
[PE1-ospfv3-2-area-0.0.0.0] return
2.     Configure PE 2:
# Configure a global RD, and enable IP multicast routing on the public network.
<PE2> system-view
[PE2-mrib] quit
[PE2] mpls ldp
[PE2-ldp] quit
# Create a VPN instance named b, and configure the RD and route targets for the VPN instance.
# Enable IPv6 multicast routing for VPN instance b.
[PE2] ipv6 multicast routing vpn-instance b
[PE2-mrib6-b] quit
# Create an MVPN IPv6 address family for VPN instance b.
[PE2-mvpn-b] address-family ipv6
[PE2-mvpn-b-ipv6] default-group 239.2.2.2
[PE2-mvpn-b-ipv6] source loopback 1
[PE2-mvpn-b-ipv6] data-group 225.4.4.0 28
[PE2-mvpn-b-ipv6] quit
[PE2-mvpn-b] quit
[PE2] ipv6 multicast routing vpn-instance a
[PE2-mrib6-a] quit
[PE2-mvpn-a] address-family ipv6
[PE2-mvpn-a-ipv6] default-group 239.1.1.1
[PE2-mvpn-a-ipv6] source loopback 1
[PE2-mvpn-a-ipv6] data-group 225.2.2.0 28
[PE2-mvpn-a-ipv6] quit
[PE2-mvpn-a] quit
# Associate GigabitEthernet 2/0/2 with VPN instance b, and assign an IPv6 address to the interface.
[PE2-GigabitEthernet2/0/2] ipv6 address 10:110:3::1 64
# Configure GigabitEthernet 2/0/2 to run OSPFv3 process 3 in Area 0, and enable IPv6 PIM-SM on the interface.
[PE2-GigabitEthernet2/0/2] ospfv3 3 area 0.0.0.0
[PE2-GigabitEthernet2/0/2] ipv6 pim sm
[PE2-GigabitEthernet2/0/3] ipv6 address 10:110:4::1 64
# Enable IPv6 PIM-SM on GigabitEthernet 2/0/3, and configure the interface to run OSPFv3 process 2 in Area 0.
[PE2-GigabitEthernet2/0/3] ipv6 pim sm
[PE2-GigabitEthernet2/0/3] ospfv3 2 area 0.0.0.0
# Configure BGP.
[PE2] bgp 100
[PE2-bgp-default-a] address-family ipv6
[PE2-bgp-default-ipv6-a] import-route ospfv3 2
[PE2-bgp-default-ipv6-a] import-route direct
[PE2-bgp-default-ipv6-a] quit
[PE2-bgp-default-b] address-family ipv6
[PE2-bgp-default-ipv6-b] import-route ospfv3 3
[PE2-bgp-default-ipv6-b] import-route direct
[PE2-bgp-default-ipv6-b] quit
[PE2–bgp-default] address-family vpnv6
[PE2–bgp-default-vpnv6] peer vpn-g enable
[PE2–bgp-default-vpnv6] quit
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1] quit
# Configure OSPFv3.
[PE2] ospfv3 2 vpn-instance a
[PE2-ospfv3-2] router-id 2.2.2.2
[PE2-ospfv3-2] import-route bgp4+
[PE2-ospfv3-2] import-route direct
[PE2-ospfv3-2] area 0
[PE2-ospfv3-2-area-0.0.0.0] quit
[PE2] ospfv3 3 vpn-instance b
[PE2-ospfv3-3] router-id 3.3.3.3
[PE2-ospfv3-3] import-route bgp4+
[PE2-ospfv3-3] import-route direct
[PE2-ospfv3-3]  area 0
[PE2-ospfv3-3-area-0.0.0.0] quit
[PE2-ospfv3-3] quit
3.     Configure PE 3:
<PE3> system-view
[PE3-mrib] quit
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] ipv6 multicast routing vpn-instance a
[PE3-mrib6-a] quit
[PE3-mvpn-a] address-family ipv6
[PE3-mvpn-a-ipv6] default-group 239.1.1.1
[PE3-mvpn-a-ipv6] source loopback 1
[PE3-mvpn-a-ipv6] data-group 225.2.2.0 28
[PE3-mvpn-a-ipv6] quit
[PE3-mvpn-a] quit
[PE3] ipv6 multicast routing vpn-instance b
[PE3-mrib6-b] quit
[PE3-mvpn-b] address-family ipv6
[PE3-mvpn-b-ipv6] default-group 239.2.2.2
[PE3-mvpn-b-ipv6] source loopback 1
[PE3-mvpn-b-ipv6] data-group 225.4.4.0 28
[PE3-mvpn-b-ipv6] quit
[PE3-mvpn-b] quit
[PE3-GigabitEthernet2/0/2] ipv6 address 10:110:5::1 64
# Enable IPv6 PIM-SM on GigabitEthernet 2/0/2, and configure the interface to run OSPFv3 process 2 in Area 0.
[PE3-GigabitEthernet2/0/2] ipv6 pim sm
[PE3-GigabitEthernet2/0/2] ospfv3 2 area 0.0.0.0
# Associate GigabitEthernet 2/0/3 with VPN instance b, and assign an IPv6 address to the interface.
[PE3-GigabitEthernet2/0/3] ipv6 address 10:110:6::1 64
# Enable IPv6 PIM-SM on GigabitEthernet 2/0/3, and configure the interface to run OSPFv3 process 3 in Area 0.
[PE3-GigabitEthernet2/0/3] ipv6 pim sm
[PE3-GigabitEthernet2/0/3] ospfv3 3 area 0.0.0.0
# Associate Loopback 2 with VPN instance b, and assign an IPv6 address to the interface.
[PE3-LoopBack2] ip address 33:33:33::33 128
# Enable IPv6 PIM-SM on Loopback 2, and configure the interface to run OSPFv3 process 3 in Area 0.
[PE3-LoopBack2] ipv6 pim sm
[PE3-LoopBack2] ospfv3 3 area 0.0.0.0
[PE3] ipv6 pim vpn-instance b
[PE3-pim6-b] c-bsr 33:33:33::33
[PE3-pim6-b] c-rp 33:33:33::33
[PE3-pim6-b] quit
# Configure BGP.
[PE3] bgp 100
[PE3-bgp-default-a] address-family ipv6
[PE3-bgp-default-ipv6-a] import-route ospfv3 2
[PE3-bgp-default-ipv6-a] import-route direct
[PE3-bgp-default-ipv6-a] quit
[PE3-bgp-default-b] address-family ipv6
[PE3-bgp-default-ipv6-b] import-route ospfv3 3
[PE3-bgp-default-ipv6-b] import-route direct
[PE3-bgp-default-ipv6-b] quit
[PE3–bgp-default] address-family vpnv6
[PE3–bgp-default-vpnv6] peer vpn-g enable
[PE3–bgp-default-vpnv6] quit
# Configure OSPF.
[PE3] ospf 1
[PE3-ospf-1] quit
# Configure OSPFv3.
[PE3] ospfv3 2 vpn-instance a
[PE3-ospfv3-2] router-id 4.4.4.4
[PE3-ospfv3-2] import-route bgp4+
[PE3-ospfv3-2] import-route direct
[PE3-ospfv3-2]  area 0
[PE3-ospfv3-2-area-0.0.0.0] quit
[PE3-ospfv3-2] quit
[PE3] ospfv3 3 vpn-instance b
[PE3-ospfv3-3] router-id 5.5.5.5
[PE3-ospfv3-3] import-route bgp4+
[PE3-ospfv3-3] import-route direct
[PE3-ospfv3-3]  area 0
[PE3-ospfv3-3-area-0.0.0.0] quit
[PE3-ospfv3-3] quit
4.     Configure P:
<P> system-view
[P-mrib] quit
[P] mpls ldp
[P-ldp] quit
[P-LoopBack1] quit
[P] pim
[P-pim] quit
# Configure OSPF.
[P] ospf 1
5.     Configure CE a1:
# Enable IPv6 multicast routing.
<CEa1> system-view
[CEa1] ipv6 multicast routing
[CEa1-mrib6] quit
# Assign an IPv6 address to GigabitEthernet 2/0/1.
[CEa1-GigabitEthernet2/0/1] ipv6 address 10:110:7::1 64
# Enable IPv6 PIM-SM on GigabitEthernet 2/0/1, and configure the interface to run OSPFv3 process 2 in Area 0.
[CEa1-GigabitEthernet2/0/1] ipv6 pim sm
[CEa1-GigabitEthernet2/0/1] ospfv3 2 area 0.0.0.0
# Assign an IPv6 address to GigabitEthernet 2/0/2.
[CEa1-GigabitEthernet2/0/2] ipv6 address 10:110:2::2 64
[CEa1-GigabitEthernet2/0/2] ipv6 pim sm
[CEa1-GigabitEthernet2/0/2] ospfv3 2 area 0.0.0.0
# Configure OSPFv3.
[CEa1] ospfv3 2
[CEa1-ospfv3-2] area 0.0.0.0
[CEa1-ospfv3-2] router-id 6.6.6.6
[CEa1-ospfv3-2-area-0.0.0.0] quit
6.     Configure CE b1:
<CEb1> system-view
[CEb1] ipv6 multicast routing
[CEb1-mrib6] quit
[CEb1-GigabitEthernet2/0/1] ipv6 address 10:110:8::1 64
# Enable IPv6 PIM-SM on GigabitEthernet 2/0/1, and configure the interface to run OSPFv3 process 3 in Area 0.
[CEb1-GigabitEthernet2/0/1] ipv6 pim sm
[CEb1-GigabitEthernet2/0/1] ospfv3 3 area 0.0.0.0
[CEb1-GigabitEthernet2/0/2] ipv6 address 10:110:3::2 64
# Enable IPv6 PIM-SM on GigabitEthernet 2/0/2, and configure the interface to run OSPFv3 process 3 in Area 0.
[CEb1-GigabitEthernet2/0/2] ipv6 pim sm
[CEb1-GigabitEthernet2/0/2] ospfv3 3 area 0.0.0.0
# Configure OSPFv3.
[CEb1] ospfv3 3
[CEb1-ospfv3-3] router-id 7.7.7.7
[CEb1-ospfv3-3] area 0.0.0.0
[CEb1-ospfv3-3-area-0.0.0.0] quit
7.     Configure CE a2:
<CEa2> system-view
[CEa2] ipv6 multicast routing
[CEa2-mrib6] quit
[CEa2-GigabitEthernet2/0/1] ipv6 address 10:110:9::1 64
# Configure GigabitEthernet 2/0/1 to run OSPFv3 process 2 in Area 0, and enable MLD on the interface.
[CEa2-GigabitEthernet2/0/1] ospfv3 2 area 0.0.0.0
[CEa2-GigabitEthernet2/0/1] mld enable
[CEa2-GigabitEthernet2/0/2] ipv6 address 10:110:4::2 64
# Configure GigabitEthernet 2/0/2 to run OSPFv3 process 2 in Area 0, and enable IPv6 PIM-SM on the interface.
[CEa2-GigabitEthernet2/0/2] ospfv3 2 area 0.0.0.0
[CEa2-GigabitEthernet2/0/2] ipv6 pim sm
# Assign an IPv6 address to GigabitEthernet 2/0/3.
[CEa2-GigabitEthernet2/0/3] ipv6 address 10:110:12::1 64
[CEa2-GigabitEthernet2/0/3] ospfv3 2 area 0.0.0.0
[CEa2-GigabitEthernet2/0/3] ipv6 pim sm
# Assign an IPv6 address to Loopback 1.
[CEa2-LoopBack1] ipv6 address 22:22:22::22 128
# Configure Loopback 1 to run OSPFv3 process 2 in Area 0, and enable IPv6 PIM-SM on the interface.
[CEa2-LoopBack1] ospfv3 2 area 0.0.0.0
[CEa2-LoopBack1] ipv6 pim sm
[CEa2] ipv6 pim
[CEa2-pim6] c-bsr 22:22:22::22
[CEa2-pim6] c-rp 22:22:22::22
[CEa2-pim6] quit
# Configure OSPFv3.
[CEa2] ospfv3 2
[CEa2-ospfv3-2] router-id 8.8.8.8
[CEa2-ospfv3-2] area 0.0.0.0
[CEa2-ospfv3-2-area-0.0.0.0] quit
8.     Configure CE a3:
<CEa3> system-view
[CEa3] ipv6 multicast routing
[CEa3-mrib6] quit
[CEa3-GigabitEthernet2/0/1] ipv6 address 10:110:10::1 64
[CEa3-GigabitEthernet2/0/1] ospfv3 2 area 0.0.0.0
[CEa3-GigabitEthernet2/0/1] mld enable
[CEa3-GigabitEthernet2/0/2] ipv6 address 10:110:5::2 64
[CEa3-GigabitEthernet2/0/2] ospfv3 2 area 0.0.0.0
[CEa3-GigabitEthernet2/0/2] ipv6 pim sm
[CEa3-GigabitEthernet2/0/3] ipv6 address 10:110:12::2 64
[CEa3-GigabitEthernet2/0/3] ospfv3 2 area 0.0.0.0
[CEa3-GigabitEthernet2/0/3] ipv6 pim sm
# Configure OSPFv3.
[CEa3] ospfv3 2
[CEa3-ospfv3-2] area 0.0.0.0
[CEa3-ospfv3-2] router-id 9.9.9.9
[CEa3-ospfv3-2-area-0.0.0.0] quit
9.     Configure CE b2:
<CEb2> system-view
[CEb2] ipv6 multicast routing
[CEb2-mrib6] quit
[CEb2-GigabitEthernet2/0/1] ipv6 address 10:110:11::1 64
# Configure GigabitEthernet 2/0/1 to run OSPFv3 process 3 in Area 0, and enable MLD on the interface.
[CEb2-GigabitEthernet2/0/1] ospfv3 3 area 0.0.0.0
[CEb2-GigabitEthernet2/0/1] mld enable
[CEb2-GigabitEthernet2/0/2] ipv6 address 10:110:6::2 64
[CEb2-GigabitEthernet2/0/2] ospfv3 3 area 0.0.0.0
[CEb2-GigabitEthernet2/0/2] ipv6 pim sm
# Configure OSPFv3.
[CEb2] ospfv3 3
[CEb2-ospfv3-3] router-id 10.10.10.10
[CEb2-ospfv3-3] area 0.0.0.0
[CEb2-ospfv3-3-area-0.0.0.0] quit
# Display information about the local default group for IPv6 multicast transmission in each VPN instance on PE 1.
[PE1] display multicast-vpn ipv6 default-group local
# Display information about the local default group for IPv6 multicast transmission in each VPN instance on PE 2.
[PE2] display multicast-vpn ipv6 default-group local
# Display information about the local default group for IPv6 multicast transmission in each VPN instance on PE 3.
[PE3] display multicast-vpn ipv6 default-group local
Example: Configuring inter-AS option B MDT-based MVPN
As shown in Figure 25, configure inter-AS option B MDT-based MVPN to meet the following requirements:
Item
·     In VPN instance a, S 1 is a multicast source, and R 2 is a receiver.
·     In VPN instance b, S 2 is a multicast source, and R 1 is a receiver.
·     For VPN instance a, the default group is 232.1.1.1, and the data group range is 232.2.2.0 to 232.2.2.15. They are in the SSM group range.
·     For VPN instance b, the default group is 232.3.3.3, and the data group range is 232.4.4.0 to 232.4.4.15. They are in the SSM group range.
·     PE 1: GigabitEthernet 2/0/2 belongs to VPN instance a. GigabitEthernet 2/0/3 belongs to VPN instance b. GigabitEthernet 2/0/1 and Loopback 1 belong to the public network instance.
·     PE 2: GigabitEthernet 2/0/1, GigabitEthernet 2/0/2, and Loopback 1 belong to the public network instance.
·     PE 3: GigabitEthernet 2/0/1, GigabitEthernet 2/0/2, and Loopback 1 belong to the public network instance.
·     PE 4: GigabitEthernet 2/0/2 belongs to VPN instance a. GigabitEthernet 2/0/3 belongs to VPN instance b. GigabitEthernet 2/0/1 and Loopback 1 belong to the public network instance.
·     Configure OSPF in AS 100 and AS 200, and configure OSPF between the PEs and CEs.
·     Establish IBGP peer connections between PE 1, PE 2, PE 3, and PE 4 on their respective Loopback 1.
·     Establish EBGP peer connections between GigabitEthernet 2/0/2 on PE 2 and PE 3.
·     Configure BGP MDT peer connections between PE 1, PE 2, PE 3, and PE 4 on their respective Loopback 1 and between PE 2 and PE 3 on their respective GigabitEthernet 2/0/2.
·     Configure MPLS in AS 100 and AS 200.
·     Enable IP multicast routing on P 1 and P 2.
·     Enable IP multicast routing for the public network on PE 1, PE 2, PE 3, and PE 4.
·     Enable IP multicast routing for VPN instance a on PE 1 and PE 4.
·     Enable IP multicast routing for VPN instance b on PE 1 and PE 4.
·     Enable IP multicast routing on CE a1, CE a2, CE b1, and CE b2.
IGMPv2
·     Enable IGMPv2 on GigabitEthernet 2/0/1 of CE a2.
·     Enable IGMPv2 on GigabitEthernet 2/0/1 of CE b2.
PIM
Enable PIM-SSM on the public network and PIM-SM for VPN instances a and b:
·     Enable PIM-SM on all interfaces of P 1 and P 2.
·     Enable PIM-SM on all public network interfaces of PE 2 and PE 3.
·     Enable PIM-SM on all public and private network interfaces of PE 1 and PE 4.
·     Enable PIM-SM on all interfaces that do not have attached receiver hosts on CE a1, CE a2, CE b1, and CE b2.
·     Configure GigabitEthernet 2/0/2 of CE a1 as a C-BSR and a C-RP for VPN instance a to provide services for all multicast groups.
·     Configure GigabitEthernet 2/0/2 of CE a1 as a C-BSR and a C-RP for VPN instance b to provide services for all multicast groups.
RPF vector
Enable the RPF vector feature on PE 1 and PE 4.
Figure 25 Network diagram
Table 5 Interface and IP address assignment
Device
IP address
Device
IP address
S 1
12.1.1.100/24
R 1
12.4.1.100/24
S 2
12.2.1.100/24
R 2
12.3.1.100/24
PE 1
GE2/0/1
10.1.1.1/24
PE 3
GE2/0/1
10.4.1.1/24
PE 1
GE2/0/2
11.1.1.1/24
PE 3
GE2/0/2
10.3.1.2/24
PE 1
GE2/0/3
11.2.1.1/24
PE 3
Loop1
3.3.3.3/32
PE 1
Loop1
1.1.1.1/32
PE 4
GE2/0/1
10.5.1.2/24
PE 2
GE2/0/1
10.2.1.2/24
PE 4
GE2/0/2
11.3.1.1/24
PE 2
GE2/0/2
10.3.1.1/24
PE 4
GE2/0/3
11.4.1.1/24
PE 2
Loop1
2.2.2.2/32
PE 4
Loop1
4.4.4.4/24
P 1
GE2/0/1
10.1.1.2/24
P 2
GE2/0/1
10.5.1.1/24
P 1
GE2/0/2
10.2.1.1/24
P 2
GE2/0/2
10.4.1.2/24
P 1
Loop1
5.5.5.5/32
P 2
Loop1
6.6.6.6/32
CE a1
GE2/0/1
12.1.1.1/24
CE b1
GE2/0/1
12.2.1.1/24
CE a1
GE2/0/2
11.1.1.2/24
CE b1
GE2/0/2
11.2.1.2/24
CE a2
GE2/0/1
12.3.1.1/24
CE b2
GE2/0/1
12.4.1.1/24
CE a2
GE2/0/2
11.3.1.2/24
CE b2
GE2/0/2
11.4.1.2/24
1.     Configure PE 1:
<PE1> system-view
[PE1-mrib] quit
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-vpn-instance-sa] route-distinguisher 100:1
# Enable IP multicast routing and RPF vector for VPN instance a.
[PE1-mrib-a] rpf proxy vector
[PE1-mrib-a] quit
[PE1-mvpn-a-ipv4] default-group 232.1.1.1
[PE1-mvpn-a-ipv4] data-group 232.2.2.0 28
[PE1-mvpn-a] quit
[PE1] ip vpn-instance b
[PE1-vpn-instance-b] route-distinguisher 200:1
[PE1-vpn-instance-b] vpn-target 200:1 export-extcommunity
[PE1-vpn-instance-b] vpn-target 200:1 import-extcommunity
[PE1-vpn-instance-b] quit
# Enable IP multicast routing and RPF vector for VPN instance b.
[PE1] multicast routing vpn-instance b
[PE1-mrib-b] rpf proxy vector
[PE1-mrib-b] quit
[PE1] multicast-vpn vpn-instance b mode mdt
[PE1-mvpn-b] address-family ipv4
[PE1-mvpn-b-ipv4] default-group 232.3.3.3
[PE1-mvpn-b-ivp4] source loopback 1
[PE1-mvpn-b-ipv4] data-group 232.4.4.0 28
[PE1-mvpn-b-ipv4] quit
[PE1-mvpn-b] quit
[PE1-GigabitEthernet2/0/1] ip address 10.1.1.1 24
[PE1-GigabitEthernet2/0/2] ip address 11.1.1.1 24
[PE1-GigabitEthernet2/0/2] pim sm
[PE1-GigabitEthernet2/0/3] ip binding vpn-instance b
[PE1-GigabitEthernet2/0/3] ip address 11.2.1.1 24
# Configure BGP.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.2 as-number 100
[PE1-bgp-default] peer 2.2.2.2 connect-interface loopback 1
[PE1-bgp-default-ipv4-a] import-route ospf 2
[PE1–bgp-default] ip vpn-instance b
[PE1-bgp-default-b] address-family ipv4
[PE1-bgp-default-ipv4-b] import-route ospf 3
[PE1-bgp-default-ipv4-b] import-route direct
[PE1-bgp-default-ipv4-b] quit
[PE1-bgp-default-b] quit
[PE1–bgp-default-vpnv4] peer 2.2.2.2 enable
[PE1-bgp-default-mdt] peer 2.2.2.2 enable
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1] quit
# Configure OSPF.
[PE1] ospf 2 vpn-instance a
[PE1-ospf-2] area 0.0.0.0
[PE1-ospf-2-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[PE1-ospf-2-area-0.0.0.0] quit
[PE1-ospf-2] quit
[PE1] ospf 3 vpn-instance b
[PE1-ospf-3] area 0.0.0.0
[PE1-ospf-3-area-0.0.0.0] network 11.2.1.0 0.0.0.255
[PE1-ospf-3-area-0.0.0.0] quit
[PE1-ospf-3] quit
2.     Configure PE 2:
<PE2> system-view
[PE2] router id 2.2.2.2
[PE2-mrib] quit
[PE2] mpls lsr-id 2.2.2.2
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-GigabitEthernet2/0/1] ip address 10.2.1.2 24
[PE2-GigabitEthernet2/0/2] ip address 10.3.1.1 24
# Enable PIM-SM and MPLS on GigabitEthernet 2/0/2.
[PE2-GigabitEthernet2/0/2] mpls enable
[PE2-LoopBack1] ip address 2.2.2.2 32
# Configure BGP.
[PE2] bgp 100
[PE2-bgp-default] peer 10.3.1.2 as-number 200
[PE2-bgp-default-vpnv4] undo policy vpn-target
[PE2-bgp-default-vpnv4] peer 10.3.1.2 enable
[PE2-bgp-default-mdt] peer 1.1.1.1 enable
[PE2-bgp-default-mdt] peer 10.3.1.2 enable
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
[PE2-ospf-1] quit
3.     Configure PE 3:
<PE3> system-view
[PE3] router id 3.3.3.3
[PE3-mrib] quit
[PE3] mpls lsr-id 3.3.3.3
[PE3] mpls ldp
[PE3-ldp] quit
[PE3-GigabitEthernet2/0/1] ip address 10.4.1.1 24
[PE3-GigabitEthernet2/0/2] ip address 10.3.1.2 24
[PE3-GigabitEthernet2/0/2] mpls enable
[PE3-LoopBack1] ip address 3.3.3.3 32
# Configure BGP.
[PE3] bgp 200
[PE3-bgp-default] peer 4.4.4.4 as-number 200
[PE3-bgp-default] peer 4.4.4.4 connect-interface loopback 1
[PE3-bgp-default] peer 10.3.1.1 as-number 100
[PE3-bgp-default-vpnv4] undo policy vpn-target
[PE3-bgp-default-vpnv4] peer 4.4.4.4 enable
[PE3-bgp-default-vpnv4] peer 10.3.1.1 enable
[PE3-bgp-default-mdt] peer 4.4.4.4 enable
[PE3-bgp-default-mdt] peer 10.3.1.1 enable
# Configure OSPF.
[PE3] ospf 1
[PE3-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[PE3-ospf-1-area-0.0.0.0] network 10.4.1.0 0.0.0.255
[PE3-ospf-1] quit
4.     Configure PE 4:
<PE4> system-view
[PE4] router id 4.4.4.4
[PE4] multicast routing
[PE4-mrib] quit
[PE4] mpls lsr-id 4.4.4.4
[PE4] mpls ldp
[PE4-ldp] quit
[PE4] ip vpn-instance a
[PE4-vpn-instance-a] route-distinguisher 100:1
[PE4-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE4-vpn-instance-a] vpn-target 100:1 import-extcommunity
[PE4-vpn-instance-a] quit
[PE4] multicast routing vpn-instance a
[PE4-mrib-a] rpf proxy vector
[PE4-mrib-a] quit
[PE4] multicast-vpn vpn-instance a mode mdt
[PE4-mvpn-a] address-family ipv4
[PE4-mvpn-a-ipv4] default-group 232.1.1.1
[PE4-mvpn-a-ipv4] source loopback 1
[PE4-mvpn-a-ipv4] data-group 232.2.2.0 28
[PE4-mvpn-a-ipv4] quit
[PE4-mvpn-a] quit
[PE4] ip vpn-instance b
[PE4-vpn-instance-b] route-distinguisher 200:1
[PE4-vpn-instance-b] vpn-target 200:1 export-extcommunity
[PE4-vpn-instance-b] vpn-target 200:1 import-extcommunity
[PE4-vpn-instance-b] quit
[PE4] multicast routing vpn-instance b
[PE4-mrib-b] rpf proxy vector
[PE4-mrib-b] quit
[PE4] multicast-vpn vpn-instance b mode mdt
[PE4-mvpn-b] address-family ipv4
[PE4-mvpn-b-ipv4] default-group 232.3.3.3
[PE4-mvpn-b-ipv4] source loopback 1
[PE4-mvpn-b-ipv4] data-group 232.4.4.0 28
[PE4-mvpn-b-ipv4] quit
[PE4-mvpn-b] quit
[PE4] interface gigabitethernet 2/0/1
[PE4-GigabitEthernet2/0/1] ip address 10.5.1.2 24
[PE4-GigabitEthernet2/0/1] pim sm
[PE4-GigabitEthernet2/0/1] mpls enable
[PE4-GigabitEthernet2/0/1] mpls ldp enable
[PE4-GigabitEthernet2/0/1] quit
[PE4] interface gigabitethernet 2/0/2
[PE4-GigabitEthernet2/0/2] ip binding vpn-instance a
[PE4-GigabitEthernet2/0/2] ip address 11.3.1.1 24
[PE4-GigabitEthernet2/0/2] pim sm
[PE4-GigabitEthernet2/0/2] quit
[PE4] interface gigabitethernet 2/0/3
[PE4-GigabitEthernet2/0/3] ip binding vpn-instance b
[PE4-GigabitEthernet2/0/3] ip address 11.4.1.1 24
[PE4-GigabitEthernet2/0/3] pim sm
[PE4-GigabitEthernet2/0/3] quit
[PE4] interface loopback 1
[PE4-LoopBack1] ip address 4.4.4.4 32
[PE4-LoopBack1] pim sm
[PE4-LoopBack1] quit
# Configure BGP.
[PE4] bgp 200
[PE4-bgp-default] peer 3.3.3.3 as-number 200
[PE4-bgp-default] peer 3.3.3.3 connect-interface loopback 1
[PE4–bgp-default] ip vpn-instance a
[PE4-bgp-default-a] address-family ipv4
[PE4-bgp-default-ipv4-a] import-route ospf 2
[PE4-bgp-default-ipv4-a] import-route direct
[PE4-bgp-default-ipv4-a] quit
[PE4-bgp-default-a] quit
[PE4–bgp-default] ip vpn-instance b
[PE4-bgp-default-b] address-family ipv4
[PE4-bgp-default-ipv4-b] import-route ospf 3
[PE4-bgp-default-ipv4-b] import-route direct
[PE4-bgp-default-ipv4-b] quit
[PE4-bgp-default-b] quit
[PE4–bgp-default] address-family vpnv4
[PE4–bgp-default-vpnv4] peer 3.3.3.3 enable
[PE4–bgp-default-vpnv4] quit
[PE4-bgp-default] address-family ipv4 mdt
[PE4-bgp-default-mdt] peer 3.3.3.3 enable
[PE4-bgp-default-mdt] quit
[PE4–bgp-default] quit
# Configure OSPF.
[PE4] ospf 1
[PE4-ospf-1] area 0.0.0.0
[PE4-ospf-1-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[PE4-ospf-1-area-0.0.0.0] network 10.5.1.0 0.0.0.255
[PE4-ospf-1-area-0.0.0.0] quit
[PE4-ospf-1] quit
[PE4] ospf 2 vpn-instance a
[PE4-ospf-2] area 0.0.0.0
[PE4-ospf-2-area-0.0.0.0] network 11.3.1.0 0.0.0.255
[PE4-ospf-2-area-0.0.0.0] quit
[PE4-ospf-2] quit
[PE4] ospf 3 vpn-instance b
[PE4-ospf-3] area 0.0.0.0
[PE4-ospf-3-area-0.0.0.0] network 11.4.1.0 0.0.0.255
[PE4-ospf-3-area-0.0.0.0] quit
[PE4-ospf-3] quit
5.     Configure P 1:
<P1> system-view
[P1] multicast routing
[P1-mrib] quit
[P1] mpls lsr-id 5.5.5.5
[P1] mpls ldp
[P1-ldp] quit
[P1] interface gigabitethernet 2/0/1
[P1-GigabitEthernet2/0/1] ip address 10.1.1.2 24
[P1-GigabitEthernet2/0/1] pim sm
[P1-GigabitEthernet2/0/1] mpls enable
[P1-GigabitEthernet2/0/1] mpls ldp enable
[P1-GigabitEthernet2/0/1] quit
[P1] interface gigabitethernet 2/0/2
[P1-GigabitEthernet2/0/2] ip address 10.2.1.1 24
[P1-GigabitEthernet2/0/2] pim sm
[P1-GigabitEthernet2/0/2] mpls enable
[P1-GigabitEthernet2/0/2] mpls ldp enable
[P1-GigabitEthernet2/0/2] quit
[P1] interface loopback 1
[P1-LoopBack1] ip address 5.5.5.5 32
[P1-LoopBack1] pim sm
[P1-LoopBack1] quit
# Configure OSPF.
[P1] ospf 1
[P1-ospf-1] area 0.0.0.0
[P1-ospf-1-area-0.0.0.0] network 5.5.5.5 0.0.0.0
[P1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[P1-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
6.     Configure P 2:
<P2> system-view
[P2] multicast routing
[P2-mrib] quit
[P2] mpls lsr-id 6.6.6.6
[P2] mpls ldp
[P2-ldp] quit
[P2] interface gigabitethernet 2/0/1
[P2-GigabitEthernet2/0/1] ip address 10.5.1.1 24
[P2-GigabitEthernet2/0/1] pim sm
[P2-GigabitEthernet2/0/1] mpls enable
[P2-GigabitEthernet2/0/1] mpls ldp enable
[P2-GigabitEthernet2/0/1] quit
[P2] interface gigabitethernet 2/0/2
[P2-GigabitEthernet2/0/2] ip address 10.4.1.2 24
[P2-GigabitEthernet2/0/2] pim sm
[P2-GigabitEthernet2/0/2] mpls enable
[P2-GigabitEthernet2/0/2] mpls ldp enable
[P2-GigabitEthernet2/0/2] quit
[P2] interface loopback 1
[P2-LoopBack1] ip address 6.6.6.6 32
[P2-LoopBack1] pim sm
[P2-LoopBack1] quit
# Configure OSPF.
[P2] ospf 1
[P2-ospf-1] area 0.0.0.0
[P2-ospf-1-area-0.0.0.0] network 6.6.6.6 0.0.0.0
[P2-ospf-1-area-0.0.0.0] network 10.4.1.0 0.0.0.255
[P2-ospf-1-area-0.0.0.0] network 10.5.1.0 0.0.0.255
7.     Configure CE a1:
<CEa1> system-view
[CEa1-mrib] quit
[CEa1-GigabitEthernet2/0/1] ip address 12.1.1.1 24
[CEa1-GigabitEthernet2/0/2] ip address 11.1.1.2 24
# Configure GigabitEthernet 2/0/2 as a C-BSR and a C-RP.
[CEa1] pim
[CEa1-pim] c-bsr 11.1.1.2
[CEa1-pim] c-rp 11.1.1.2
[CEa1-pim] quit
# Configure OSPF.
[CEa1] ospf 1
[CEa1-ospf-1] area 0.0.0.0
[CEa1-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[CEa1-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[CEa1-ospf-1-area-0.0.0.0] quit
[CEa1-ospf-1] quit
8.     Configure CE b1:
<CEb1> system-view
[CEb1-mrib] quit
[CEb1-GigabitEthernet2/0/1] ip address 12.2.1.1 24
[CEb1-GigabitEthernet2/0/2] ip address 11.2.1.2 24
[CEb1] pim
[CEb1-pim] c-bsr 11.2.1.2 24
[CEb1-pim] c-rp 11.2.1.2 24
[CEb1-pim] quit
# Configure OSPF.
[CEb1] ospf 1
[CEb1-ospf-1] area 0.0.0.0
[CEb1-ospf-1-area-0.0.0.0] network 12.2.1.0 0.0.0.255
[CEb1-ospf-1-area-0.0.0.0] network 11.2.1.0 0.0.0.255
[CEb1-ospf-1-area-0.0.0.0] quit
[CEb1-ospf-1] quit
9.     Configure CE a2:
<CEa2> system-view
[CEa2-mrib] quit
[CEa2-GigabitEthernet2/0/1] ip address 12.3.1.1 24
[CEa2-GigabitEthernet2/0/2] ip address 11.3.1.2 24
# Configure OSPF.
[CEa2] ospf 1
[CEa2-ospf-1] area 0.0.0.0
[CEa2-ospf-1-area-0.0.0.0] network 12.3.1.0 0.0.0.255
[CEa2-ospf-1-area-0.0.0.0] network 11.3.1.0 0.0.0.255
[CEa2-ospf-1-area-0.0.0.0] quit
[CEa2-ospf-1] quit
10.     Configure CE b2:
<CEb2> system-view
[CEb2-mrib] quit
[CEb2-GigabitEthernet2/0/1] ip address 12.4.1.1 24
[CEb2-GigabitEthernet2/0/2] ip address 11.4.1.2 24
# Configure OSPF.
[CEb2] ospf 1
[CEb2-ospf-1] area 0.0.0.0
[CEb2-ospf-1-area-0.0.0.0] network 12.4.1.0 0.0.0.255
[CEb2-ospf-1-area-0.0.0.0] network 11.4.1.0 0.0.0.255
[CEb2-ospf-1-area-0.0.0.0] quit
[CEb2-ospf-1] quit
 232.1.1.1        1.1.1.1          MTunnel0      a
 232.3.3.3        1.1.1.1          MTunnel1      b
# Display information about the remote default group for IPv4 multicast transmission in each VPN instance on PE 1.
[PE1] display multicast-vpn default-group remote
MVPN remote default-group information:
 Group address   Source address  Next hop         VPN instance
 232.1.1.1       4.4.4.4         2.2.2.2          a
 232.3.3.3       4.4.4.4         2.2.2.2          b
# Display information about the local default group for IPv4 multicast transmission in each VPN instance on PE 4.
[PE4] display multicast-vpn default-group local
 232.1.1.1        4.4.4.4          MTunnel0      a
 233.3.3.3        4.4.4.4          MTunnel1      b
# Display information about the remote default group for IPv4 multicast transmission in each VPN instance on PE 4.
[PE4] display multicast-vpn default-group remote
 232.1.1.1       1.1.1.1         3.3.3.3          a
 232.3.3.3       1.1.1.1         3.3.3.3          b
Example: Configuring inter-AS option C MDT-based MVPN
As shown in Figure 26, configure inter-AS option C MDT-based MVPN to meet the following requirements:
Item
Multicast sources and receivers
·     For VPN instance a, the default group is 239.1.1.1, and the data group range is 225.1.1.0 to 225.1.1.15.
·     For VPN instance b, the default group is 239.4.4.4, and the data group range is 225.4.4.0 to 225.4.4.15.
VPN instances to which PE interfaces belong
·     PE 2: GigabitEthernet 2/0/1, GigabitEthernet 2/0/2, Loopback 1, and Loopback 2 belong to the public network instance.
·     PE 3: GigabitEthernet 2/0/1, GigabitEthernet 2/0/2, Loopback 1, and Loopback 2 belong to the public network instance.
Unicast routing protocols and MPLS
·     Configure OSPF separately in AS 100 and AS 200, and configure OSPF between the PEs and CEs.
·     Establish BGP peer connections between PE 1, PE 2, PE 3, and PE 4 on their respective Loopback 1.
·     Configure MPLS separately in AS 100 and AS 200.
·     Enable IP multicast routing on the public network on PE 1, PE 2, PE 3, and PE 4.
IGMPv2
PIM-SM
Enable PIM-SM on the public network and for VPN instances a and b:
·     Configure Loopback 2 of PE 2 and PE 3 as a C-BSR and a C-RP for their own AS to provide services for all multicast groups.
·     Configure Loopback 0 of CE a1 as a C-BSR and a C-RP for VPN instance a to provide services for all multicast groups.
·     Configure Loopback 0 of CE b1 as a C-BSR and a C-RP for VPN instance b to provide services for all multicast groups.
MSDP
Establish an MSDP peering relationship between PE 2 and PE 3 on their Loopback 1.
Figure 26 Network diagram
Device
IP address
Device
IP address
S 1
10.11.5.2/24
R 1
10.11.8.2/24
S 2
10.11.6.2/24
R 2
10.11.7.2/24
PE 1
GE2/0/1
10.10.1.1/24
PE 3
GE2/0/1
10.10.2.1/24
PE 1
GE2/0/2
10.11.1.1/24
PE 3
GE2/0/2
192.168.1.2/24
PE 1
GE2/0/3
10.11.2.1/24
PE 3
Loop1
1.1.1.3/32
PE 1
Loop1
1.1.1.1/32
PE 3
Loop2
22.22.22.22/32
PE 2
GE2/0/1
10.10.1.2/24
PE 4
GE2/0/1
10.10.2.2/24
PE 2
GE2/0/2
192.168.1.1/24
PE 4
GE2/0/2
10.11.3.1/24
PE 2
Loop1
1.1.1.2/32
PE 4
GE2/0/3
10.11.4.1/32
PE 2
Loop2
11.11.11.11/32
PE 4
Loop1
1.1.1.4/32
CE a1
GE2/0/1
10.11.5.1/24
CE b1
GE2/0/1
10.11.6.1/24
CE a1
GE2/0/2
10.11.1.2/24
CE b1
GE2/0/2
10.11.2.2/24
CE a1
Loop0
2.2.2.2/32
CE b2
GE2/0/1
10.11.8.1/24
CE a2
GE2/0/1
10.11.7.1/24
CE b2
GE2/0/2
10.11.4.2/24
CE a2
GE2/0/2
10.11.3.2/24
CE b2
Loop0
3.3.3.3/32
1.     Configure PE 1:
# Configure a global router ID, and enable IP multicast routing on the public network.
<PE1> system-view
[PE1] router id 1.1.1.1
[PE1-mrib] quit
# Configure an LSR ID, and enable LDP globally.
[PE1] mpls lsr-id 1.1.1.1
[PE1] mpls ldp
[PE1-ldp] quit
# Create a VPN instance named a, and configure an RD and route targets for the VPN instance.
[PE1] ip vpn-instance a
[PE1-vpn-instance-a] route-distinguisher 100:1
[PE1-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE1-vpn-instance-a] vpn-target 100:1 import-extcommunity
[PE1-vpn-instance-a] quit
# Enable IP multicast routing for VPN instance a.
[PE1] multicast routing vpn-instance a
[PE1-mrib-a] quit
# Create an MVPN for VPN instance a.
[PE1] multicast-vpn vpn-instance a mode mdt
# Create an MVPN IPv4 address family for VPN instance a.
[PE1-mvpn-a] address-family ipv4
# Specify the default group, the MVPN source interface, and the data group range for VPN instance a.
[PE1-mvpn-a-ipv4] default-group 239.1.1.1
[PE1-mvpn-a-ipv4] source loopback 1
[PE1-mvpn-a-ipv4] data-group 225.1.1.0 28
[PE1-mvpn-a-ipv4] quit
[PE1-mvpn-a] quit
# Create a VPN instance named b, and configure an RD and route targets for the VPN instance.
# Enable IP multicast routing for VPN instance b.
[PE1-mrib-b] quit
# Create an MVPN for VPN instance b.
# Create an MVPN IPv4 address family for VPN instance b.
# Specify the default group, the MVPN source interface, and the data group range for VPN instance b.
[PE1-mvpn-b-ipv4] default-group 239.4.4.4
[PE1-mvpn-b-ipv4] source loopback 1
[PE1-mvpn-b-ipv4] data-group 225.4.4.0 28
[PE1-mvpn-b] quit
# Assign an IP address to GigabitEthernet 2/0/1.
[PE1] interface gigabitethernet 2/0/1
[PE1-GigabitEthernet2/0/1] ip address 10.10.1.1 24
# Enable PIM-SM, MPLS, and IPv4 LDP on GigabitEthernet 2/0/1.
[PE1-GigabitEthernet2/0/1] pim sm
[PE1-GigabitEthernet2/0/1] mpls enable
[PE1-GigabitEthernet2/0/1] mpls ldp enable
[PE1-GigabitEthernet2/0/1] quit
# Associate GigabitEthernet 2/0/2 with VPN instance a.
[PE1] interface gigabitethernet 2/0/2
[PE1-GigabitEthernet2/0/2] ip binding vpn-instance a
# Assign an IP address to GigabitEthernet 2/0/2, and enable PIM-SM on the interface.
[PE1-GigabitEthernet2/0/2] ip address 10.11.1.1 24
[PE1-GigabitEthernet2/0/2] quit
[PE1] interface gigabitethernet 2/0/3
# Assign an IP address to GigabitEthernet 2/0/3, and enable PIM-SM on the interface.
[PE1-GigabitEthernet2/0/3] ip address 10.11.2.1 24
[PE1-GigabitEthernet2/0/3] pim sm
[PE1-GigabitEthernet2/0/3] quit
# Assign an IP address to Loopback 1, and enable PIM-SM on the interface.
[PE1] interface loopback 1
[PE1-LoopBack1] ip address 1.1.1.1 32
[PE1-LoopBack1] pim sm
[PE1-LoopBack1] quit
# Configure BGP.
[PE1] bgp 100
[PE1-bgp-default] group pe1-pe2 internal
[PE1-bgp-default] peer pe1-pe2 connect-interface loopback 1
[PE1-bgp-default] peer 1.1.1.2 group pe1-pe2
[PE1-bgp-default] group pe1-pe4 external
[PE1-bgp-default] peer pe1-pe4 as-number 200
[PE1-bgp-default] peer pe1-pe4 ebgp-max-hop 255
[PE1-bgp-default] peer pe1-pe4 connect-interface loopback 1
[PE1-bgp-default] peer 1.1.1.4 group pe1-pe4
[PE1–bgp-default] ip vpn-instance a
[PE1-bgp-default-ipv4-a] import-route direct
[PE1-bgp-default-ipv4-a] quit
[PE1-bgp-default-a] quit
[PE1–bgp-default] address-family ipv4
[PE1-bgp-default-ipv4] peer pe1-pe2 enable
[PE1-bgp-default-ipv4] peer pe1-pe2 label-route-capability
[PE1–bgp-default] address-family vpnv4
[PE1–bgp-default-vpnv4] peer pe1-pe4 enable
[PE1–bgp-default-vpnv4] quit
[PE1–bgp-default] quit
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1] area 0.0.0.0
[PE1-ospf-1-area-0.0.0.0] network 10.10.1.0 0.0.0.255
[PE1-ospf-1] quit
[PE1-ospf-2] import-route bgp
[PE1-ospf-2-area-0.0.0.0] network 10.11.1.0 0.0.0.255
[PE1-ospf-2] quit
[PE1-ospf-3] import-route bgp
[PE1-ospf-3-area-0.0.0.0] network 10.11.2.0 0.0.0.255
[PE1-ospf-3] quit
2.     Configure PE 2:
<PE2> system-view
[PE2] router id 1.1.1.2
[PE2] multicast routing
[PE2-mrib] quit
[PE2] mpls lsr-id 1.1.1.2
[PE2] mpls ldp
[PE2-mpls-ldp] quit
[PE2] interface gigabitethernet 2/0/1
[PE2-GigabitEthernet2/0/1] ip address 10.10.1.2 24
[PE2-GigabitEthernet2/0/1] pim sm
[PE2-GigabitEthernet2/0/1] mpls enable
[PE2-GigabitEthernet2/0/1] mpls ldp enable
[PE2-GigabitEthernet2/0/1] quit
[PE2] interface gigabitethernet 2/0/2
[PE2-GigabitEthernet2/0/2] ip address 192.168.1.1 24
[PE2-GigabitEthernet2/0/2] pim sm
[PE2-GigabitEthernet2/0/2] quit
[PE2] interface loopback 1
[PE2-LoopBack1] ip address 1.1.1.2 32
[PE2-LoopBack1] pim sm
[PE2-LoopBack1] quit
[PE2] interface loopback 2
[PE2-LoopBack2] ip address 11.11.11.11 32
[PE2-LoopBack2] pim sm
[PE2-LoopBack2] quit
[PE2] pim
[PE2-pim] c-bsr 11.11.11.11
[PE2-pim] c-rp 11.11.11.11
[PE2-pim] quit
# Configure GigabitEthernet 2/0/2 as a PIM-SM domain border.
[PE2-GigabitEthernet2/0/2] pim bsr-boundary
# Establish an MSDP peering relationship.
[PE2] msdp
[PE2-msdp] encap-data-enable
[PE2-msdp] peer 1.1.1.3 connect-interface loopback 1
# Configure a static route.
[PE2] ip route-static 1.1.1.3 32 gigabitethernet 2/0/2 192.168.1.2
# Configure BGP.
[PE2] bgp 100
[PE2-bgp-default] group pe2-pe1 internal
[PE2-bgp-default] peer pe2-pe1 connect-interface loopback 1
[PE2-bgp-default] peer 1.1.1.1 group pe2-pe1
[PE2-bgp-default] group pe2-pe3 external
[PE2-bgp-default] peer pe2-pe3 as-number 200
[PE2-bgp-default] peer pe2-pe3 connect-interface loopback 1
[PE2-bgp-default] peer 1.1.1.3 group pe2-pe3
[PE2-bgp-default-ipv4] peer pe2-pe1 enable
[PE2-bgp-default-ipv4] peer pe2-pe1 route-policy map2 export
[PE2-bgp-default-ipv4] peer pe2-pe1 label-route-capability
[PE2-bgp-default-ipv4] peer pe2-pe3 enable
[PE2-bgp-default-ipv4] peer pe2-pe3 route-policy map1 export
[PE2-bgp-default-ipv4] peer pe2-pe3 label-route-capability
[PE2-bgp-default-ipv4] import-route ospf 1
[PE2–bgp-default] quit
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1] area 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 1.1.1.2 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 11.11.11.11 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 10.10.1.0 0.0.0.255
[PE2-ospf-1] quit
3.     Configure PE 3:
<PE3> system-view
[PE3] router id 1.1.1.3
[PE3] multicast routing
[PE3-mrib] quit
[PE3] mpls lsr-id 1.1.1.3
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] interface gigabitethernet 2/0/1
[PE3-GigabitEthernet2/0/1] ip address 10.10.2.1 24
[PE3-GigabitEthernet2/0/1] pim sm
[PE3-GigabitEthernet2/0/1] mpls enable
[PE3-GigabitEthernet2/0/1] mpls ldp enable
[PE3-GigabitEthernet2/0/1] quit
[PE3] interface gigabitethernet 2/0/2
[PE3-GigabitEthernet2/0/2] ip address 192.168.1.2 24
[PE3-GigabitEthernet2/0/2] pim sm
[PE3-GigabitEthernet2/0/2] quit
[PE3] interface loopback 1
[PE3-LoopBack1] ip address 1.1.1.3 32
[PE3-LoopBack1] pim sm
[PE3-LoopBack1] quit
# Assign an IP address to Loopback 2, and enable PIM-SM on the interface.
[PE3] interface loopback 2
[PE3-LoopBack2] ip address 22.22.22.22 32
[PE3-LoopBack2] pim sm
[PE3-LoopBack2] quit
# Configure Loopback 2 as a C-BSR and a C-RP.
[PE3] pim
[PE3-pim] c-bsr 22.22.22.22
[PE3-pim] c-rp 22.22.22.22
[PE3-pim] quit
[PE3-GigabitEthernet2/0/2] pim bsr-boundary
[PE3] msdp
[PE3-msdp] encap-data-enable
[PE3-msdp] peer 1.1.1.2 connect-interface loopback 1
[PE3] ip route-static 1.1.1.2 32 gigabitethernet 2/0/2 192.168.1.1
# Configure BGP.
[PE3] bgp 200
[PE3-bgp-default] group pe3-pe4 internal
[PE3-bgp-default] peer pe3-pe4 connect-interface loopback 1
[PE3-bgp-default] peer 1.1.1.4 group pe3-pe4
[PE3-bgp-default] group pe3-pe2 external
[PE3-bgp-default] peer pe3-pe2 as-number 100
[PE3-bgp-default] peer pe3-pe2 connect-interface loopback 1
[PE3-bgp-default] peer 1.1.1.2 group pe3-pe2
[PE3-bgp-default-ipv4] peer pe3-pe4 enable
[PE3-bgp-default-ipv4] peer pe3-pe4 route-policy map2 export
[PE3-bgp-default-ipv4] peer pe3-pe4 label-route-capability
[PE3-bgp-default-ipv4] peer pe3-pe2 enable
[PE3-bgp-default-ipv4] peer pe3-pe2 route-policy map1 export
[PE3-bgp-default-ipv4] peer pe3-pe2 label-route-capability
[PE3-bgp-default-ipv4] import-route ospf 1
[PE3–bgp-default] quit
# Configure OSPF.
[PE3] ospf 1
[PE3-ospf-1] area 0.0.0.0
[PE3-ospf-1-area-0.0.0.0] network 1.1.1.3 0.0.0.0
[PE3-ospf-1-area-0.0.0.0] network 22.22.22.22 0.0.0.0
[PE3-ospf-1-area-0.0.0.0] network 10.10.2.0 0.0.0.255
[PE3-ospf-1] quit
4.     Configure PE 4:
<PE4> system-view
[PE4] router id 1.1.1.4
[PE4-mrib] quit
[PE4] mpls lsr-id 1.1.1.4
[PE4] mpls ldp
[PE4-ldp] quit
[PE4-mrib-a] quit
[PE4-mvpn-a-ipv4] default-group 239.1.1.1
[PE4-mvpn-a-ipv4] data-group 225.1.1.0 28
[PE4-mvpn-a] quit
[PE4-mrib-b] quit
# Specify the default group, MVPN source interface, and the data group range for VPN instance b.
[PE4-mvpn-b-ipv4] default-group 239.4.4.4
[PE4-mvpn-b-ipv4] data-group 225.4.4.0 28
[PE4-mvpn-b] quit
[PE4-GigabitEthernet2/0/1] ip address 10.10.2.2 24
[PE4-GigabitEthernet2/0/2] ip address 10.11.3.1 24
# Associate GigabitEthernet 2/0/3 with VPN instance b.
[PE4-GigabitEthernet2/0/3] ip address 10.11.4.1 24
[PE4-LoopBack1] ip address 1.1.1.4 32
# Configure BGP.
[PE4] bgp 200
[PE4-bgp-default] group pe4-pe3 internal
[PE4-bgp-default] peer pe4-pe3 connect-interface loopback 1
[PE4-bgp-default] peer 1.1.1.3 group pe4-pe3
[PE4-bgp-default] group pe4-pe1 external
[PE4-bgp-default] peer pe4-pe1 as-number 100
[PE4-bgp-default] peer pe4-pe1 ebgp-max-hop 255
[PE4-bgp-default] peer pe4-pe1 connect-interface loopback 1
[PE4-bgp-default] peer 1.1.1.1 group pe4-pe1
[PE4–bgp-default] address-family ipv4
[PE4-bgp-default-ipv4] peer pe4-pe3 enable
[PE4-bgp-default-ipv4] peer pe4-pe3 label-route-capability
[PE4-bgp-default-ipv4] quit
[PE4–bgp-default-vpnv4] peer pe4-pe1 enable
# Configure OSPF.
[PE4] ospf 1
[PE4-ospf-1-area-0.0.0.0] network 1.1.1.4 0.0.0.0
[PE4-ospf-1-area-0.0.0.0] network 10.10.2.0 0.0.0.255
[PE4-ospf-1] quit
[PE4-ospf-2] import-route bgp
[PE4-ospf-2-area-0.0.0.0] network 10.11.3.0 0.0.0.255
[PE4-ospf-2] quit
[PE4-ospf-3] import-route bgp
[PE4-ospf-3-area-0.0.0.0] network 10.11.4.0 0.0.0.255
[PE4-ospf-3] quit
5.     Configure CE a1:
# Enable IP multicast routing.
<CEa1> system-view
[CEa1] multicast routing
[CEa1-mrib] quit
# Assign an IP address to GigabitEthernet 2/0/1, and enable PIM-SM on the interface.
[CEa1] interface gigabitethernet 2/0/1
[CEa1-GigabitEthernet2/0/1] ip address 10.11.5.1 24
[CEa1-GigabitEthernet2/0/1] pim sm
[CEa1-GigabitEthernet2/0/1] quit
[CEa1] interface gigabitethernet 2/0/2
[CEa1-GigabitEthernet2/0/2] ip address 10.11.1.2 24
[CEa1-GigabitEthernet2/0/2] pim sm
[CEa1-GigabitEthernet2/0/2] quit
[CEa1] interface loopback 1
[CEa1-LoopBack1] ip address 2.2.2.2 32
[CEa1-LoopBack1] pim sm
[CEa1-LoopBack1] quit
# Configure Loopback 1 as a C-BSR and a C-RP.
[CEa1] pim
[CEa1-pim] c-bsr 2.2.2.2
[CEa1-pim] c-rp 2.2.2.2 1
[CEa1-pim] quit
# Configure OSPF.
[CEa1] ospf 1
[CEa1-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[CEa1-ospf-1-area-0.0.0.0] network 10.11.1.0 0.0.0.255
[CEa1-ospf-1-area-0.0.0.0] network 10.11.5.0 0.0.0.255
[CEa1-ospf-1] quit
6.     Configure CE b1:
<CEb1> system-view
[CEb1] multicast routing
[CEb1-mrib] quit
[CEb1] interface gigabitethernet 2/0/1
[CEb1-GigabitEthernet2/0/1] ip address 10.11.6.1 24
[CEb1-GigabitEthernet2/0/1] pim sm
[CEb1-GigabitEthernet2/0/1] quit
[CEb1] interface gigabitethernet 2/0/2
[CEb1-GigabitEthernet2/0/2] ip address 10.11.2.2 24
[CEb1-GigabitEthernet2/0/2] pim sm
[CEb1-GigabitEthernet2/0/2] quit
# Configure OSPF.
[CEb1] ospf 1
[CEb1-ospf-1-area-0.0.0.0] network 10.11.2.0 0.0.0.255
[CEb1-ospf-1-area-0.0.0.0] network 10.11.6.0 0.0.0.255
[CEb1-ospf-1] quit
7.     Configure CE a2:
<CEa2> system-view
[CEa2] multicast routing
[CEa2-mrib] quit
# Assign an IP address to GigabitEthernet 2/0/1, and enable IGMP on the interface.
[CEa2] interface gigabitethernet 2/0/1
[CEa2-GigabitEthernet2/0/1] ip address 10.11.7.1 24
[CEa2-GigabitEthernet2/0/1] igmp enable
[CEa2-GigabitEthernet2/0/1] quit
[CEa2] interface gigabitethernet 2/0/2
[CEa2-GigabitEthernet2/0/2] ip address 10.11.3.2 24
[CEa2-GigabitEthernet2/0/2] pim sm
[CEa2-GigabitEthernet2/0/2] quit
# Configure OSPF.
[CEa2] ospf 1
[CEa2-ospf-1-area-0.0.0.0] network 10.11.3.0 0.0.0.255
[CEa2-ospf-1-area-0.0.0.0] network 10.11.7.0 0.0.0.255
[CEa2-ospf-1] quit
8.     Configure CE b2:
<CEb2> system-view
[CEb2] multicast routing
[CEb2-mrib] quit
[CEb2] interface gigabitethernet 2/0/1
[CEb2-GigabitEthernet2/0/1] ip address 10.11.8.1 24
[CEb2-GigabitEthernet2/0/1] igmp enable
[CEb2-GigabitEthernet2/0/1] quit
[CEb2] interface gigabitethernet 2/0/2
[CEb2-GigabitEthernet2/0/2] ip address 10.11.4.2 24
[CEb2-GigabitEthernet2/0/2] pim sm
[CEb2-GigabitEthernet2/0/2] quit
[CEb2] interface loopback 1
[CEb2-LoopBack1] ip address 3.3.3.3 32
[CEb2-LoopBack1] pim sm
[CEb2-LoopBack1] quit
[CEb2] pim
[CEb2-pim] c-bsr 3.3.3.3
[CEb2-pim] c-rp 3.3.3.3
[CEb2-pim] quit
# Configure OSPF.
[CEb2] ospf 1
[CEb2-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[CEb2-ospf-1-area-0.0.0.0] network 10.11.4.0 0.0.0.255
[CEb2-ospf-1-area-0.0.0.0] network 10.11.8.0 0.0.0.255
[CEb2-ospf-1] quit
# Display information about the local default group for IPv4 multicast transmission in each VPN instance on PE 1.
[PE1] display multicast-vpn default-group local
MVPN local default-group information:
 Group address    Source address   Interface     VPN instance
 239.1.1.1        1.1.1.1          MTunnel0      a
 239.4.4.4        1.1.1.1          MTunnel1      b
 239.1.1.1        1.1.1.4          MTunnel0      a
 239.4.4.4        1.1.1.4          MTunnel1      b
Example: Configuring inter-AS option A mLDP-based MVPN
As shown in Figure 27, configure inter-AS option A mLDP-based MVPN to meet the following requirements:
Item
·     PE 1: GigabitEthernet 2/0/2 belongs to VPN instance a. GigabitEthernet 2/0/3 belongs to VPN instance b. GigabitEthernet 2/0/1 and Loopback 1 belong to the public network.
·     PE 2: GigabitEthernet 2/0/1, and Loopback 1 belong to the public network. GigabitEthernet 2/0/2 belongs to VPN instance a. GigabitEthernet 2/0/3 belongs to VPN instance b.
·     PE 3: GigabitEthernet 2/0/1 and Loopback 1 belong to the public network. GigabitEthernet 2/0/2 belongs to VPN instance a. GigabitEthernet 2/0/3 belongs to VPN instance b.
·     PE 4: GigabitEthernet 2/0/2 belongs to VPN instance a. GigabitEthernet 2/0/3 belongs to VPN instance b. GigabitEthernet 2/0/1 and Loopback 1 belong to the public network.
·     Configure BGP IPv4 MVPN peer connections between PE 1, PE 2, PE 3, and PE 4 on their respective Loopback 1.
·     Enable MPLS on P 1 and P 2.
IGMP
·     Enable IGMPv3 on GigabitEthernet 2/0/1 of CE b2.
PIM
Enable PIM-SM for VPN instances a and b:
·     Enable PIM-SM on all private network interfaces of PE 1 and PE 4.
·     Configure GigabitEthernet 2/0/2 of CE a1 as a C-BSR and a C-RP for VPN instance a in AS 100 to provide services for all multicast groups.
·     Configure GigabitEthernet 2/0/2 of CE b1 as a C-BSR and a C-RP for VPN instance b in AS 200 to provide services for all multicast groups.
MSDP
Enable MSDP on CE a1, and specify GigabitEthernet 2/0/2 as the local MSDP connection interface.
Enable MSDP on CE a2, and specify GigabitEthernet 2/0/2 as the local MSDP connection interface.
Figure 27 Network diagram
Table 7 Interface and IP address assignment
Device
IP address
Device
IP address
S 1
12.1.1.100/24
R 1
12.4.1.100/24
S 2
12.2.1.100/24
R 2
12.3.1.100/24
PE 1
GE2/0/1
10.1.1.1/24
PE 3
GE2/0/1
10.4.1.1/24
PE 1
GE2/0/2
11.1.1.1/24
PE 3
GE2/0/2
10.3.1.2/24
PE 1
GE2/0/3
11.2.1.1/24
PE 3
GE2/0/3
10.6.1.2/24
PE 1
Loop1
1.1.1.1/32
PE 3
Loop1
3.3.3.3/32
PE 2
GE2/0/1
10.2.1.2/24
PE 4
GE2/0/1
10.5.1.2/24
PE 2
GE2/0/2
10.3.1.1/24
PE 4
GE2/0/2
11.3.1.1/24
PE 2
GE2/0/3
10.6.1.1/24
PE 4
GE2/0/3
11.4.1.1/24
PE 2
Loop1
2.2.2.2/32
PE 4
Loop1
4.4.4.4/24
P 1
GE2/0/1
10.1.1.2/24
P 2
GE2/0/1
10.5.1.1/24
P 1
GE2/0/2
10.2.1.1/24
P 2
GE2/0/2
10.4.1.2/24
P 1
Loop1
5.5.5.5/32
P 2
Loop1
6.6.6.6/32
CE a1
GE2/0/1
12.1.1.1/24
CE b1
GE2/0/1
12.2.1.1/24
CE a1
GE2/0/2
11.1.1.2/24
CE b1
GE2/0/2
11.2.1.2/24
CE a2
GE2/0/1
12.3.1.1/24
CE b2
GE2/0/1
12.4.1.1/24
CE a2
GE2/0/2
11.3.1.2/24
CE b2
GE2/0/2
11.4.1.2/24
1.     Configure PE 1:
# Configure a global router ID.
<PE1> system-view
[PE1] quit
# Configure an LSR ID, and enable LDP and mLDP P2MP globally.
[PE1] mpls ldp
[PE1-ldp] mldp p2mp
[PE1-ldp] quit
[PE1-mrib-a] quit
# Specify the MVPN source interface for VPN instance a.
# Enable dynamic inclusive tunnel creation, dynamic selective tunnel creation, and inter-AS auto-discovery for VPN instance a.
[PE1-mvpn-a-ipv4] inclusive-tunnel dynamic
[PE1-mvpn-a-ipv4] selective-tunnel dynamic
[PE1-mvpn-a-ipv4] auto-discovery inter-as
[PE1-mvpn-a] quit
[PE1-mrib-b] quit
[PE1] multicast-vpn vpn-instance b mode mldp
# Specify the MVPN source interface for VPN instance b.
# Enable dynamic inclusive tunnel creation, dynamic selective tunnel creation, and inter-AS auto-discovery for VPN instance b.
[PE1-mvpn-b-ipv4] inclusive-tunnel dynamic
[PE1-mvpn-b-ipv4] selective-tunnel dynamic
[PE1-mvpn-b-ipv4] auto-discovery inter-as
[PE1-mvpn-b] quit
# Assign an IP address to Loopback 1.
# Configure BGP.
[PE1] bgp 100
[PE1-bgp-default] address-family ipv4 mvpn
[PE1-bgp-default-mvpn] peer 2.2.2.2 enable
[PE1–bgp-default-vpnv4] peer 2.2.2.2 next-hop-local
[PE1–bgp-default-vpnv4] mvpn-advertise-rt-import
[PE1-bgp-default-a] address-family ipv4
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1] quit
[PE1-ospf-2] quit
[PE1-ospf-3] quit
2.     Configure PE 2:
<PE2> system-view
[PE2] quit
[PE2] mpls ldp
[PE2-ldp] mldp p2mp
[PE2-ldp] quit
[PE2] ip vpn-instance a
[PE2-vpn-instance-a] route-distinguisher 100:1
[PE2-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE2-vpn-instance-a] vpn-target 100:1 import-extcommunity
[PE2-vpn-instance-a] quit
[PE2] multicast routing vpn-instance a
[PE2-mrib-a] quit
[PE2-mvpn-a] address-family ipv4
[PE2-mvpn-a-ipv4] source loopback 1
[PE2-mvpn-a-ipv4] quit
[PE2-mvpn-a] quit
[PE2] ip vpn-instance b
[PE2-vpn-instance-b] route-distinguisher 200:1
[PE2-vpn-instance-b] vpn-target 200:1 export-extcommunity
[PE2-vpn-instance-b] vpn-target 200:1 import-extcommunity
[PE2-vpn-instance-b] quit
[PE2] multicast routing vpn-instance b
[PE2-mrib-b] quit
[PE2-mvpn-b] address-family ipv4
[PE2-mvpn-b-ivp4] source loopback 1
[PE2-mvpn-b-ipv4] quit
[PE2-mvpn-b] quit
# Associate GigabitEthernet 2/0/2 with VPN instance a, and assign an IP address to the interface.
[PE2-GigabitEthernet2/0/2] ip binding vpn-instance a
# Enable PIM-SM on GigabitEthernet 2/0/2, and configure the interface as a PIM-SM domain border.
[PE2-GigabitEthernet2/0/3] ip binding vpn-instance b
[PE2-GigabitEthernet2/0/3] ip address 10.6.1.1 24
[PE2-GigabitEthernet2/0/3] pim sm
[PE2-GigabitEthernet2/0/3] quit
# Configure BGP.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.1 as-number 100
[PE2-bgp-default] peer 1.1.1.1 connect-interface loopback 1
[PE2-bgp-default] address-family ipv4 mvpn
[PE2-bgp-default-mvpn] peer 1.1.1.1 enable
[PE2-bgp-default-vpnv4] mvpn-advertise-rt-import
[PE2-bgp-default-vpnv4] peer 1.1.1.1 enable
[PE2-bgp-default-vpnv4] peer 1.1.1.1 next-hop-local
[PE2-bgp-default-vpnv4] quit
[PE2-bgp-default] ip vpn-instance a
[PE2-bgp-default-a] address-family ipv4 unicast
[PE2-bgp-default-ipv4-a] import-route direct
[PE2-bgp-default-ipv4-a] peer 10.3.1.2 enable
[PE2-bgp-default-ipv4-a] quit
[PE2-bgp-default-a] quit
[PE2-bgp-default]ip vpn-instance b
[PE2-bgp-default] peer 10.6.1.2 as-number 200
[PE2-bgp-default-b] address-family ipv4 unicast
[PE2-bgp-default-ipv4-b] import-route direct
[PE2-bgp-default-ipv4-b] peer 10.6.1.2 enable
[PE2-bgp-default-ipv4-b] quit
[PE2-bgp-default-b] quit
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1] quit
3.     Configure PE 3:
<PE3> system-view
[PE3] mpls ldp
[PE3-ldp] mldp p2mp
[PE3-ldp] quit
[PE3] ip vpn-instance a
[PE3-vpn-instance-a] route-distinguisher 300:1
[PE3-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE3-vpn-instance-a] vpn-target 100:1 import-extcommunity
[PE3-vpn-instance-a] quit
[PE3] multicast routing vpn-instance a
[PE3-mrib-a] quit
[PE3-mvpn-a] address-family ipv4
[PE3-mvpn-a-ipv4] source loopback 1
[PE3-mvpn-a-ipv4] inclusive-tunnel dynamic
[PE3-mvpn-a-ipv4] selective-tunnel dynamic
[PE3-mvpn-a-ipv4] auto-discovery inter-as
[PE3-mvpn-a-ipv4] quit
[PE3-mvpn-a] quit
[PE3] ip vpn-instance b
[PE3-vpn-instance-b] route-distinguisher 400:1
[PE3-vpn-instance-b] vpn-target 200:1 export-extcommunity
[PE3-vpn-instance-b] vpn-target 200:1 import-extcommunity
[PE3-vpn-instance-b] quit
[PE3] multicast routing vpn-instance b
[PE3-mrib-b] quit
[PE3-mvpn-b] address-family ipv4
[PE3-mvpn-b-ivp4] source loopback 1
[PE3-mvpn-b-ipv4] inclusive-tunnel dynamic
[PE3-mvpn-b-ipv4] selective-tunnel dynamic
[PE3-mvpn-b-ipv4] auto-discovery inter-as
[PE3-mvpn-b-ipv4] quit
[PE3-mvpn-b] quit
[PE3-GigabitEthernet2/0/2] ip binding vpn-instance a
[PE3-GigabitEthernet2/0/3] pim sm
[PE3-GigabitEthernet2/0/3] quit
# Configure BGP.
[PE3] bgp 200
[PE3-bgp-default] address-family ipv4 mvpn
[PE3-bgp-default-mvpn] peer 4.4.4.4 enable
[PE3-bgp-default-mvpn] quit
[PE3-bgp-default] address-family vpnv4
[PE3-bgp-default-vpnv4] mvpn-advertise-rt-import
[PE3-bgp-default-vpnv4] peer 4.4.4.4 next-hop-local
[PE3-bgp-default-vpnv4] quit
[PE3-bgp-default]ip vpn-instance a
[PE3-bgp-default-a] peer 10.3.1.1 as-number 100
[PE3-bgp-default-a] address-family ipv4 unicast
[PE3-bgp-default-ipv4-a] import-route direct
[PE3-bgp-default-ipv4-a] peer 10.3.1.1 enable
[PE3-bgp-default-ipv4-a] quit
[PE3-bgp-default-a] quit
[PE3-bgp-default]ip vpn-instance b
[PE3-bgp-default-b] peer 10.6.1.1 as-number 100
[PE3-bgp-default-ipv4-b] import-route direct
[PE3-bgp-default-ipv4-b] peer 10.6.1.1 enable
[PE3-bgp-default-ipv4-b] quit
[PE3-bgp-default-b] quit
# Configure OSPF.
[PE3] ospf 1
[PE3-ospf-1] quit
4.     Configure PE 4:
<PE4> system-view
[PE4] mpls ldp
[PE4-ldp] mldp p2mp
[PE4-ldp] quit
[PE4-vpn-instance-a] route-distinguisher 300:1
[PE4-mrib-a] quit
[PE4] multicast-vpn vpn-instance a mode mldp
[PE4-mvpn-a] quit
[PE4-vpn-instance-b] route-distinguisher 400:1
[PE4-mrib-b] quit
# Create an mLDP-based MVPN for VPN instance b,.
[PE4] multicast-vpn vpn-instance b mode mldp
[PE4-mvpn-b] quit
# Configure BGP.
[PE4] bgp 200
[PE4-bgp-default] address-family ipv4 mvpn
[PE4–bgp-default-vpnv4] peer 3.3.3.3 next-hop-local
[PE4–bgp-default-vpnv4] mvpn-advertise-rt-import
[PE4–bgp-default -vpnv4] quit
[PE4–bgp] quit
# Configure OSPF.
[PE4] ospf 1
[PE4-ospf-1] quit
[PE4-ospf-2] import-route bgp 200
[PE4-ospf-2] quit
[PE4-ospf-3] import-route bgp 200
[PE4-ospf-3] quit
5.     Configure P 1:
[P1] mpls ldp
[P1-ldp] mldp p2mp
[P1-ldp] quit
[P1-LoopBack1] quit
# Configure OSPF.
[P1] ospf 1
6.     Configure P 2:
[P2] mpls ldp
[P2-ldp] mldp p2mp
[P2-ldp] quit
[P2-LoopBack1] quit
# Configure OSPF.
[P2] ospf 1
7.     Configure CE a1:
<CEa1> system-view
[CEa1-mrib] quit
[CEa1] pim
# Configure OSPF.
[CEa1] ospf 1
[CEa1-ospf-1] quit
# Configure MSDP.
[CEa1] msdp
[CEa1-msdp] peer 11.3.1.2 connect-interface gigabitethernet 2/0/2
[CEa1-msdp] quit
8.     Configure CE b1:
<CEb1> system-view
[CEb1-mrib] quit
# Configure OSPF.
[CEb1] ospf 1
[CEb1-ospf-1] quit
9.     Configure CE a2:
<CEa2> system-view
[CEa2-mrib] quit
[CEa2] pim
[CEa2-pim] c-bsr 11.3.1.2
[CEa2-pim] c-rp 11.3.1.2
[CEa2-pim] quit
# Configure OSPF.
[CEa2] ospf 1
[CEa2-ospf-1] quit
# Configure MSDP.
[CEa2] msdp
[CEa2-msdp] peer 11.1.1.2 connect-interface gigabitethernet 2/0/2
[CEa2-msdp] quit
<CEb2> system-view
[CEb2-mrib] quit
# Assign an IP address to GigabitEthernet 2/0/1, and enable IGMPv3 on the interface.
[CEb2-GigabitEthernet2/0/1] igmp version 3
# Configure OSPF.
[CEb2] ospf 1
[CEb2-ospf-1] quit
[PE1]display multicast-vpn vpn-instance a inclusive-tunnel local
Tunnel state: Up
Leafs:
  1: 2.2.2.2
[PE1] display multicast-vpn vpn-instance a selective-tunnel local
Tunnel state: Up
[PE1] display multicast-vpn vpn-instance a c-multicast routing-table
 Total 0 (*, G) entries; 1 (S, G) entries
 (12.1.1.100, 225.0.0.1)
   CreateTime: 02:54:43
Tunnel state: --
Root: 1.1.1.1
Leaf:
  1: 2.2.2.2(local)
Tunnel state: --
Root: 1.1.1.1
Leaf:
  1: 2.2.2.2 (local)
# Display PIM routing entries for VPN instance a on PE 2.
[PE2] display pim vpn-instance a routing-table
     RP: 11.1.1.2
     Protocol: pim-sm, Flag: SPT ACT SC
     UpTime: 00:56:25
     Upstream interface: LSPVIif0(1.1.1.1)
         Upstream neighbor: 1.1.1.1
         RPF prime neighbor: 1.1.1.1
     Downstream interface information:
         1: GigabitEthernet2/0/2
             Protocol: pim-sm, UpTime: 00:56:25, Expires: 00:03:17
# Display information about the mLDP inclusive tunnel for VPN instance a on PE 3.
[PE3]display multicast-vpn vpn-instance a inclusive-tunnel local
Tunnel state: Up
Root: 3.3.3.3 (local)
Leafs:
  1: 4.4.4.4
# Display information about mLDP selective tunnels for VPN instance a on PE 3.
[PE3]display multicast-vpn vpn-instance a selective-tunnel local
Tunnel state: Up
# Display C-multicast A-D route information for VPN instance a on PE 3.
[PE3] display multicast-vpn vpn-instance a c-multicast routing-table
# Display PIM routing entries for VPN instance a on PE 3.
[PE3] display pim vpn-instance a routing-table
     RP: 11.3.1.2
     Protocol: pim-sm, Flag: SPT ACT RC
     UpTime: 00:54:22
     Upstream interface: GigabitEthernet2/0/2
         Upstream neighbor: 10.3.1.1
         RPF prime neighbor: 10.3.1.1
         1: LSPVOif1
             Protocol: MD, UpTime: 00:54:18, Expires: -
# Display information about the mLDP inclusive tunnel for VPN instance b on PE 4.
[PE4] display multicast-vpn vpn-instance b inclusive-tunnel remote
Tunnel state: --
Root: 3.3.3.3
Leaf:
  1: 4.4.4.4 (local)
# Display information about mLDP selective tunnels for VPN instance a on PE 4.
[PE4] display multicast-vpn vpn-instance a selective-tunnel remote
Tunnel state: --
Root: 3.3.3.3
Leaf:
  1: 4.4.4.4 (local)
Example: Configuring inter-AS option B mLDP-based MVPN
As shown in Figure 28, configure inter-AS option B mLDP-based MVPN to meet the following requirements:
Item
·     PE 2: GigabitEthernet 2/0/1, GigabitEthernet 2/0/2, and Loopback 1 belong to the public network.
·     PE 3: GigabitEthernet 2/0/1, GigabitEthernet 2/0/2, and Loopback 1 belong to the public network.
·     Configure a static route on PE 2 and PE 3.
IGMP
PIM
·     Configure GigabitEthernet 2/0/2 of PE 1 as a C-BSR and a C-RP for VPN instance a to provide services for all multicast groups.
Figure 28 Network diagram
Table 8 Interface and IP address assignment
Device
IP address
Device
IP address
S 1
12.1.1.100/24
R 1
12.4.1.100/24
S 2
12.2.1.100/24
R 2
12.3.1.100/24
PE 1
GE2/0/1
10.1.1.1/24
PE 3
GE2/0/1
10.4.1.1/24
PE 1
GE2/0/2
11.1.1.1/24
PE 3
GE2/0/2
10.3.1.2/24
PE 1
GE2/0/3
11.2.1.1/24
PE 3
Loop1
3.3.3.3/32
PE 1
Loop1
1.1.1.1/32
PE 4
GE2/0/1
10.5.1.2/24
PE 2
GE2/0/1
10.2.1.2/24
PE 4
GE2/0/2
11.3.1.1/24
PE 2
GE2/0/2
10.3.1.1/24
PE 4
GE2/0/3
11.4.1.1/24
PE 2
Loop1
2.2.2.2/32
PE 4
Loop1
4.4.4.4/32
P 1
GE2/0/1
10.1.1.2/24
P 2
GE2/0/1
10.5.1.1/24
P 1
GE2/0/2
10.2.1.1/24
P 2
GE2/0/2
10.4.1.2/24
P 1
Loop1
5.5.5.5/32
P 2
Loop1
6.6.6.6/32
CE a1
GE2/0/1
12.1.1.1/24
CE b1
GE2/0/1
12.2.1.1/24
CE a1
GE2/0/2
11.1.1.2/24
CE b1
GE2/0/2
11.2.1.2/24
CE a2
GE2/0/1
12.3.1.1/24
CE b2
GE2/0/1
12.4.1.1/24
CE a2
GE2/0/2
11.3.1.2/24
CE b2
GE2/0/2
11.4.1.2/24
1.     Configure PE 1:
<PE1> system-view
[PE1] mpls ldp
[PE1-ldp] mldp p2mp
[PE1-ldp] quit
[PE1-mrib-a] quit
# Create an mLDP-based MVPN for VPN instance a.
[PE1] multicast-vpn vpn-instance a mode mldp
[PE1-mvpn-a] quit
[PE1-mrib-b] quit
# Create an mLDP-based MVPN for VPN instance b.
[PE1-mvpn-b] quit
# Assign an IP address to GigabitEthernet 2/0/1, and then enable MPLS and IPv4 LDP on the interface.
# Associate GigabitEthernet 2/0/2 with VPN instance a, assign an IP address to the interface, and then enable PIM-SM on the interface.
# Associate GigabitEthernet 2/0/3 with VPN instance b, assign an IP address to the interface, and then enable PIM-SM on the interface.
[PE1] pim vpn-instance a
[PE1-pim-a] c-bsr 11.1.1.1
[PE1-pim-a] c-rp 11.1.1.1
[PE1-pim-a] quit
# Configure BGP.
[PE1] bgp 100
[PE1-bgp-default-mvpn] quit
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1] quit
[PE1-ospf-2] quit
[PE1-ospf-3] quit
2.     Configure PE 2:
<PE2> system-view
[PE2] mpls ldp
[PE2-ldp] mldp p2mp
[PE2-ldp] quit
# Assign an IP address to GigabitEthernet 2/0/1, and enable MPLS and IPv4 LDP on the interface.
# Assign an IP address to GigabitEthernet 2/0/2, and enable MPLS and IPv4 LDP on the interface.
[PE2-GigabitEthernet2/0/2] mpls ldp enable
# Configure BGP.
[PE2] bgp 100
[PE2-bgp-default] peer 10.3.1.2 connect-interface gigabitethernet 2/0/2
[PE2–bgp-default-vpnv4] mvpn-advertise-rt-import
[PE2-bgp-default-mvpn] undo policy vpn-target
[PE2-bgp-default-mvpn] peer 10.3.1.2 enable
[PE2-bgp-default-mvpn] quit
[PE2]ip route-static 3.3.3.3 32 gigabitethernet 2/0/2 10.3.1.2
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1] quit
3.     Configure PE 3:
<PE3> system-view
# Configure an LSR ID, and enable LDP, mLDP P2MP, and mLDP recursive FEC globally.
[PE3] mpls ldp
[PE3-ldp] mldp p2mp
[PE3-ldp] mldp recursive-fec
[PE3-ldp] quit
[PE3-GigabitEthernet2/0/2] mpls ldp enable
# Configure BGP.
[PE3] bgp 200
[PE3-bgp-default] peer 10.3.1.1 connect-interface gigabitethernet 2/0/2
[PE3-bgp-default-mvpn] undo policy vpn-target
[PE3-bgp-default-mvpn] peer 10.3.1.1 enable
[PE3]ip route-static 2.2.2.2 32 gigabitethernet 2/0/2 10.3.1.1
# Configure OSPF.
[PE3] ospf 1
[PE3-ospf-1] quit
4.     Configure PE 4:
<PE4> system-view
[PE4] mpls ldp
[PE4-ldp] mldp p2mp
[PE4-ldp] mldp recursive-fec
[PE4-ldp] quit
[PE4-mrib-a] quit
[PE4-mvpn-a] quit
[PE4-mrib-b] quit
[PE4-mvpn-b] quit
# Associate GigabitEthernet 2/0/2 with VPN instance a, assign an IP address to the interface, and enable PIM-SM on the interface.
# Associate GigabitEthernet 2/0/3 with VPN instance b, assign an IP address to the interface, and enable PIM-SM on the interface.
# Configure BGP.
[PE4] bgp 200
[PE4-bgp-default-mvpn] peer 3.3.3.3 enable
[PE4-bgp-default-mvpn] quit
# Configure OSPF.
[PE4] ospf 1
[PE4-ospf-1] quit
[PE4-ospf-2] quit
[PE4-ospf-3] quit
5.     Configure P 1:
[P1] mpls ldp
[P1-ldp] mldp p2mp
[P1-ldp] quit
[P1-LoopBack1] quit
# Configure OSPF.
[P1] ospf 1
6.     Configure P 2:
[P2] mpls ldp
[P2-ldp] mldp p2mp
[P2-ldp] quit
[P2-LoopBack1] quit
# Configure OSPF.
[P2] ospf 1
7.     Configure CE a1:
<CEa1> system-view
[CEa1-mrib] quit
# Configure OSPF.
[CEa1] ospf 1
[CEa1-ospf-1] quit
8.     Configure CE b1:
<CEb1> system-view
[CEb1-mrib] quit
# Configure OSPF.
[CEb1] ospf 1
[CEb1-ospf-1] quit
9.     Configure CE a2:
<CEa2> system-view
[CEa2-mrib] quit
# Configure OSPF.
[CEa2] ospf 1
[CEa2-ospf-1] quit
<CEb2> system-view
[CEb2-mrib] quit
# Configure OSPF.
[CEb2] ospf 1
[CEb2-ospf-1] quit
# Display information about the mLDP inclusive tunnel for VPN instance a on PE 1.
Tunnel interface: LSPVOif0
Tunnel identifier: mLDP P2MP <0xe4000000>
Tunnel state: Up
Opaque value: 0x010004e4000000
Root: 1.1.1.1 (local)
Leafs:
  1: 4.4.4.4
# Display information about mLDP selective tunnels for VPN instance a on PE 1.
[PE1]display multicast-vpn vpn-instance a selective-tunnel local
Total 1 selective tunnel in using
Total 0 selective tunnel in creating
Tunnel interface: LSPVOif2
Tunnel identifier: mLDP P2MP <0xe4000002>
Tunnel state: Up
Opaque value: 0x010004e4000002
# Display C-multicast A-D route information for VPN instance a on PE 1.
   Tunnel Information: LSPVOif2
# Display PIM routing entries for VPN instance a on PE 1.
[PE1]display pim vpn-instance a routing-table
     RP: 11.1.1.1 (local)
     Protocol: pim-sm, Flag: SPT 2MSDP ACT RC SRC-ACT 2MVPN
     UpTime: 00:00:43
         Upstream neighbor: 11.1.1.2
         RPF prime neighbor: 11.1.1.2
         1: LSPVOif2
             Protocol: MD, UpTime: 00:00:30, Expires: -
# Display information about the mLDP inclusive tunnel for VPN instance b on PE 1.
[PE1]display multicast-vpn vpn-instance b inclusive-tunnel local
Tunnel interface: LSPVOif1
Tunnel identifier: mLDP P2MP <0xe4000001>
Tunnel state: up
Opaque value: 0x010004e4000001
Leafs:
  1: 4.4.4.4
# Display information about mLDP selective tunnels for VPN instance b on PE 1.
[PE1]display multicast-vpn vpn-instance b selective-tunnel local
Tunnel interface: LSPVOif3
Tunnel identifier: mLDP P2MP <0xe4000003>
Tunnel state: Up
Opaque value: 0x010004e4000003
# Display PIM routing entries for VPN instance b on PE 1.
[PE1]display pim vpn-instance b  routing-table
 (12.2.1.100, 232.0.0.0)
     Protocol: pim-ssm, Flag: RC
     UpTime: 00:26:06
     Upstream interface: GigabitEthernet2/0/3
         Upstream neighbor: 11.2.1.2
         RPF prime neighbor: 11.2.1.2
         1: LSPVOif3
             Protocol: MD, UpTime: 00:25:56, Expires: -
# Display information about the mLDP inclusive tunnel for VPN instance a on PE 4.
[PE4] display multicast-vpn vpn-instance a inclusive-tunnel remote
Tunnel interface: --
Tunnel state: --
Root: 1.1.1.1
Leaf:
  1: 4.4.4.4 (local)
Tunnel state: --
Root: 1.1.1.1
Leaf:
  1: 4.4.4.4 (local)
Tunnel state: --
Root: 1.1.1.1
Leaf:
  1: 4.4.4.4 (local)
# Display information about mLDP selective tunnels for VPN instance b on PE 4.
[PE4] display multicast-vpn vpn-instance b selective-tunnel remote
Tunnel state: --
Root: 1.1.1.1
Leaf:
  1: 4.4.4.4 (local)
Example: Configuring inter-AS option C mLDP-based MVPN
As shown in Figure 29, configure inter-AS option C mLDP-based MVPN to meet the following requirements:
Item
IGMP
PIM
Figure 29 Network diagram
Table 9 Interface and IP address assignment
Device
IP address
Device
IP address
S 1
12.1.1.100/24
R 1
12.4.1.100/24
S 2
12.2.1.100/24
R 2
12.3.1.100/24
PE 1
GE2/0/1
10.1.1.1/24
PE 3
GE2/0/1
10.4.1.1/24
PE 1
GE2/0/2
11.1.1.1/24
PE 3
GE2/0/2
10.3.1.2/24
PE 1
GE2/0/3
11.2.1.1/24
PE 3
Loop1
3.3.3.3/32
PE 1
Loop1
1.1.1.1/32
PE 4
GE2/0/1
10.5.1.2/24
PE 2
GE2/0/1
10.2.1.2/24
PE 4
GE2/0/2
11.3.1.1/24
PE 2
GE2/0/2
10.3.1.1/24
PE 4
GE2/0/3
11.4.1.1/24
PE 2
Loop1
2.2.2.2/32
PE 4
Loop1
4.4.4.4/24
P 1
GE2/0/1
10.1.1.2/24
P 2
GE2/0/1
10.5.1.1/24
P 1
GE2/0/2
10.2.1.1/24
P 2
GE2/0/2
10.4.1.2/24
P 1
Loop1
5.5.5.5/32
P 2
Loop1
6.6.6.6/32
CE a1
GE2/0/1
12.1.1.1/24
CE b1
GE2/0/1
12.2.1.1/24
CE a1
GE2/0/2
11.1.1.2/24
CE b1
GE2/0/2
11.2.1.2/24
CE a2
GE2/0/1
12.3.1.1/24
CE b2
GE2/0/1
12.4.1.1/24
CE a2
GE2/0/2
11.3.1.2/24
CE b2
GE2/0/2
11.4.1.2/24
1.     Configure PE 1:
<PE1> system-view
[PE1] mpls ldp
[PE1-ldp] mldp p2mp
[PE1-ldp] quit
# Create a VPN instance named a, and configure the RD and route targets for the VPN instance.
[PE1-mrib-a] quit
[PE1-mvpn-a] quit
# Create a VPN instance named b, and configure the RD and route targets for the VPN instance.
[PE1-mrib-b] quit
[PE1-mvpn-b] quit
[PE1-pim-a] quit
# Configure BGP.
[PE1] bgp 100
[PE1-bgp-default] peer 4.4.4.4 as-number 200
[PE1-bgp-default] peer 4.4.4.4 connect-interface loopback 1
[PE1-bgp-default] peer 4.4.4.4 ebgp-max-hop 10
[PE1-bgp-default-ipv4] peer 2.2.2.2 enable
[PE1-bgp-default-ipv4] peer 2.2.2.2 label-route-capability
[PE1-bgp-default-ipv4] quit
[PE1-bgp-default-mvpn] peer 4.4.4.4 enable
[PE1–bgp-default-vpnv4] peer 4.4.4.4 enable
[PE1-bgp-default] quit
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1] quit
[PE1-ospf-2] quit
[PE1-ospf-3] quit
2.     Configure PE 2:
<PE2> system-view
[PE2] mpls ldp
[PE2-ldp] mldp p2mp
[PE2-ldp] quit
# Configure routing polices.
[PE2] route-policy map1 permit node 1
[PE2-route-policy-map1-1] apply mpls-label
[PE2-route-policy-map1-1] quit
[PE2] route-policy map2 permit node 1
[PE2-route-policy-map2-1] apply mpls-label
[PE2-route-policy-map2-1] if-match mpls-label
[PE2-route-policy-map2-1] quit
# Configure BGP.
[PE2] bgp 100
[PE2-bgp-default-ipv4] peer 1.1.1.1 enable
[PE2-bgp-default-ipv4] peer 1.1.1.1 route-policy map2 export
[PE2-bgp-default-ipv4] peer 1.1.1.1 label-route-capability
[PE2-bgp-default-ipv4] peer 10.3.1.2 enable
[PE2-bgp-default-ipv4] peer 10.3.1.2 route-policy map1 export
[PE2-bgp-default-ipv4] peer 10.3.1.2 label-route-capability
[PE2-bgp-default-ipv4] quit
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1] quit
3.     Configure PE 3:
<PE3> system-view
[PE3] mpls ldp
[PE3-ldp] mldp p2mp
[PE3-ldp] quit
# Configure routing policies.
[PE3] route-policy map1 permit node 1
[PE3-route-policy-map1-1] apply mpls-label
[PE3-route-policy-map1-1] quit
[PE3] route-policy map2 permit node 1
[PE3-route-policy-map2-1] apply mpls-label
[PE3-route-policy-map2-1] if-match mpls-label
[PE3-route-policy-map2-1] quit
# Configure BGP.
[PE3] bgp 200
[PE3-bgp-default-ipv4] peer 4.4.4.4 enable
[PE3-bgp-default-ipv4] peer 4.4.4.4 route-policy map2 export
[PE3-bgp-default-ipv4] peer 4.4.4.4 label-route-capability
[PE3-bgp-default-ipv4] peer 10.3.1.1 enable
[PE3-bgp-default-ipv4] peer 10.3.1.1 route-policy map1 export
[PE3-bgp-default-ipv4] quit
# Configure OSPF.
[PE3] ospf 1
[PE3-ospf-1] quit
4.     Configure PE 4:
<PE4> system-view
[PE4] mpls ldp
[PE4-ldp] mldp p2mp
[PE4-ldp] quit
[PE4-mrib-a] quit
[PE4-mvpn-a] quit
[PE4-mrib-b] quit
[PE4-mvpn-b] quit
# Configure BGP.
[PE4] bgp 200
[PE4-bgp-default] peer 1.1.1.1 as-number 100
[PE4-bgp-default] peer 1.1.1.1 ebgp-max-hop 10
[PE4-bgp-default] peer 1.1.1.1 connect-interface loopback 1
[PE4-bgp-default-ipv4] peer 3.3.3.3 enable
[PE4-bgp-default-ipv4] peer 3.3.3.3 label-route-capability
[PE4–bgp-default] address-family ipv4 mvpn
[PE4–bgp-default-mvpn] peer 1.1.1.1 enable
[PE4–bgp-default-mvpn] quit
[PE4–bgp-default-vpnv4]mvpn-advertise-rt-import
[PE4–bgp-default-vpnv4] peer 1.1.1.1 enable
# Configure OSPF.
[PE4] ospf 1
[PE4-ospf-1] quit
[PE4-ospf-2] quit
[PE4-ospf-3] quit
5.     Configure P 1:
[P1] mpls ldp
[P1-ldp] mldp p2mp
[P1-ldp] quit
[P1-LoopBack1] quit
# Configure OSPF.
[P1] ospf 1
6.     Configure P 2:
[P2] mpls ldp
[P2-ldp] mldp p2mp
[P2-ldp] mldp recursive-fec
[P2-ldp] quit
[P2-LoopBack1] quit
# Configure OSPF.
[P2] ospf 1
7.     Configure CE a1:
<CEa1> system-view
[CEa1-mrib] quit
# Configure OSPF.
[CEa1] ospf 1
[CEa1-ospf-1] quit
8.     Configure CE b1:
<CEb1> system-view
[CEb1-mrib] quit
# Configure OSPF.
[CEb1] ospf 1
[CEb1-ospf-1] quit
9.     Configure CE a2:
<CEa2> system-view
[CEa2-mrib] quit
# Configure OSPF.
[CEa2] ospf 1
[CEa2-ospf-1] quit
<CEb2> system-view
[CEb2-mrib] quit
# Configure OSPF.
[CEb2] ospf 1
[CEb2-ospf-1] quit
Tunnel state: Up
Leafs:
  1: 4.4.4.4
Tunnel state: Up
     UpTime: 00:00:43
         1: LSPVOif2
# Display information about the mLDP inclusive tunnel for VPN instance b on PE 2.
Tunnel state: up
Leafs:
  1: 4.4.4.4
# Display information about mLDP selective tunnels for VPN instance b on PE 2.
Tunnel state: Up
# Display PIM routing entries for VPN instance b on PE 2.
     UpTime: 00:26:06
         1: LSPVOif3
Tunnel state: --
Root: 1.1.1.1
Leaf:
  1: 4.4.4.4 (local)
Tunnel state: --
Root: 1.1.1.1
Leaf:
1: 4.4.4.4 (local)
Tunnel state: --
Root: 1.1.1.1
Leaf:
  1: 4.4.4.4 (local)
Tunnel state: --
Root: 1.1.1.1
Leaf:
  1: 4.4.4.4(local)
Example: Configuring receiver-PE-based MVPN extranet
As shown in Figure 30, configure MVPN extranet to meet the following requirements:
Item
·     In VPN instance a, S 1 is a multicast source.
·     In VPN instance b, R 1 is a receiver.
·     For VPN instance a, the default group is 239.1.1.1, and the data group range is 225.2.2.0 to 225.2.2.15.
·     PE 1: GigabitEthernet2/0/1 belongs to VPN instance a. GigabitEthernet2/0/2 and Loopback 0 belong to the public network instance.
·     PE 2: GigabitEthernet2/0/2 belongs to VPN instance b. GigabitEthernet2/0/1 and Loopback 0 belong to the public network instance.
·     Configure OSPF on the public network and configure RIP between PEs and CEs.
·     Establish BGP peer connections between PE 1 and PE 2 on their respective Loopback 0.
·     Configure MPLS on the public network.
·     Enable IP multicast routing on the P device.
·     Enable IP multicast routing for the public network on PE 1 and PE 2.
·     Enable IP multicast routing for VPN instance a on PE 1.
·     Enable IP multicast routing for VPN instance b on PE 2.
·     Enable IP multicast routing on CE 1 and CE 2.
IGMPv2
Enable IGMPv2 on GigabitEthernet2/0/2 of CE 2.
PIM-SM
·     Enable PIM-SM on all interfaces of the P device.
·     Enable PIM-SM on all public and private network interfaces of PE 1 and PE 2.
·     Enable PIM-SM on all interfaces that do not have attached receiver hosts on CE 1 and CE 2.
·     Configure Loopback 0 of the P device as a C-BSR and a C-RP for the public network to provide services for all multicast groups.
·     Configure Loopback 1 of CE 1 as a C-BSR and a C-RP for VPN instance a to provide services for all multicast groups.
·     Configure Loopback 1 of PE 2 as a C-BSR and a C-RP for VPN instance b to provide services for all multicast groups.
Figure 30 Network diagram
Table 10 Interface and IP address assignment
Device
IP address
Device
IP address
S 1
10.110.7.2/24
PE 2
GE2/0/1
192.168.7.1/24
R 1
10.110.11.2/24
PE 2
GE2/0/2
10.110.3.2/24
P
GE2/0/1
192.168.6.1/24
PE 2
Loop0
1.1.1.2/32
P
GE2/0/2
192.168.7.2/24
PE 2
Loop1
20.20.20.20/32
P
Loop0
2.2.2.2/32
PE 2
Loop2
100.100.100.100/32
PE 1
GE2/0/1
10.110.2.1/24
CE 1
GE2/0/1
10.110.7.1/24
PE 1
GE2/0/2
192.168.6.2/24
CE 1
GE2/0/2
10.110.2.2/24
PE 1
Loop0
1.1.1.1/32
CE 1
Loop1
11.11.11.11/32
CE 2
GE2/0/1
10.110.3.1/24
CE 2
GE2/0/2
10.110.11.1/24
1.     Configure PE 1:
<PE1> system-view
[PE1-mrib] quit
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-mrib-a] quit
# Create an MDT-based MVPN for VPN instance a.
[PE1-mvpn-a-ipv4] source loopback 0
[PE1-mvpn-a-ipv4] data-group 225.2.2.0 28
[PE1-mvpn-a] quit
# Assign an IP address to GigabitEthernet 2/0/2, and enable PIM-SM, MPLS, and IPv4 LDP on the interface.
[PE1-GigabitEthernet2/0/2] ip address 192.168.6.2 24
[PE1-GigabitEthernet2/0/2] mpls enable
[PE1-GigabitEthernet2/0/2] mpls ldp enable
# Associate GigabitEthernet 2/0/1 with VPN instance a, assign an IP address to the interface and enable PIM-SM on the interface.
[PE1-GigabitEthernet2/0/1] ip binding vpn-instance a
[PE1-GigabitEthernet2/0/1] ip address 10.110.2.1 24
# Assign an IP address to Loopback 0, and enable PIM-SM on the interface.
[PE1] interface loopback 0
[PE1-LoopBack0] pim sm
[PE1-LoopBack0] quit
# Configure BGP.
[PE1] bgp 100
[PE1-bgp-default] group vpn-g internal
[PE1-bgp-default] peer vpn-g connect-interface loopback 0
[PE1-bgp-default] peer 1.1.1.2 group vpn-g
[PE1-bgp-default-ipv4-a] import-route rip 2
[PE1–bgp-default-vpnv4] peer vpn-g enable
[PE2–bgp-default-vpnv4] quit
[PE1–bgp-default] address-family ipv4 mdt
[PE1–bgp-default-mdt] peer vpn-g enable
[PE1–bgp-default-mdt] quit
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1-area-0.0.0.0] network 192.168.6.0 0.0.0.255
[PE1-ospf-1] quit
# Configure RIP.
[PE1] rip 2 vpn-instance a
[PE1-rip-2] network 10.110.2.0 0.0.0.255
[PE1-rip-2] import-route bgp
[PE1-rip-2] quit
2.     Configure PE 2:
<PE2> system-view
[PE2-mrib] quit
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-mrib-a] quit
[PE2] multicast-vpn vpn-instance a mode mdt
[PE2-mvpn-a-ipv4] default-group 239.1.1.1
[PE2-mvpn-a-ipv4] source loopback 0
[PE2-mvpn-a-ipv4] data-group 225.2.2.0 28
[PE2-mvpn-a] quit
# Create a VPN instance named b.
# Configure IPv4 MVPN extranet RPF selection policies.
[PE2-mrib-b] multicast extranet select-rpf vpn-instance a source 10.110.7.2 32 group 226.1.1.0 24
[PE2-mrib-b] multicast extranet select-rpf vpn-instance a source 20.20.20.20 32 group 226.1.1.0 24
[PE2-mrib-b] quit
# Assign an IP address to GigabitEthernet 2/0/1, and enable PIM-SM, MPLS, and IPv4 LDP on the interface.
[PE2-GigabitEthernet2/0/1] ip address 192.168.7.1 24
# Associate GigabitEthernet 2/0/2 with VPN instance b, assign an IP address to the interface, and enable PIM-SM on the interface.
[PE2-GigabitEthernet2/0/2] ip binding vpn-instance b
[PE2-GigabitEthernet2/0/2] ip address 10.110.3.2 24
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 1.1.1.2 32
[PE2-LoopBack0] pim sm
[PE2-LoopBack0] quit
# Associate Loopback 1 with VPN instance b, assign an IP address to the interface, and enable PIM-SM on the interface.
[PE2-LoopBack1] ip binding vpn-instance b
[PE2-LoopBack1] ip address 20.20.20.20 32
# Configure Loopback 1 as a C-BSR and a C-RP for VPN instance b.
[PE2] pim vpn-instance b
[PE2-pim-b] c-bsr 20.20.20.20
[PE2-pim-b] c-rp 20.20.20.20
[PE2-pim-b] quit
# Associate Loopback 2 with VPN instance a, assign an IP address to the interface, and enable PIM-SM on the interface.
[PE2-LoopBack2] ip binding vpn-instance a
[PE2-LoopBack2] ip address 100.100.100.100 32
# Configure BGP.
[PE2] bgp 100
[PE2-bgp-default] group vpn-g internal
[PE2-bgp-default] peer vpn-g connect-interface loopback 0
[PE2-bgp-default] peer 1.1.1.1 group vpn-g
[PE2–bgp-default] ip vpn-instance a
[PE2–bgp-default] address-family vpnv4
[PE2–bgp-default-vpnv4] peer vpn-g enable
[PE2–bgp-default] address-family ipv4 mdt
[PE2–bgp-default-mdt] peer vpn-g enable
[PE2–bgp-default-mdt] quit
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1-area-0.0.0.0] network 192.168.7.0 0.0.0.255
[PE2-ospf-1] quit
# Configure RIP.
[PE2] rip 3 vpn-instance b
[PE2-rip-3] network 10.110.3.0 0.0.0.255
[PE2-rip-3] network 20.20.20.20 0.0.0.0
[PE2-rip-3] import-route bgp
[PE2-rip-3] quit
3.     Configure the P device:
# Enable IP multicast routing on the public network.
<P> system-view
[P] multicast routing
[P-mrib] quit
[P] mpls lsr-id 2.2.2.2
[P] mpls ldp
[P-ldp] quit
[P] interface gigabitethernet 2/0/1
[P-GigabitEthernet2/0/1] ip address 192.168.6.1 24
[P-GigabitEthernet2/0/1] pim sm
[P-GigabitEthernet2/0/1] mpls enable
[P-GigabitEthernet2/0/1] mpls ldp enable
[P-GigabitEthernet2/0/1] quit
[P] interface gigabitethernet 2/0/2
[P-GigabitEthernet2/0/2] ip address 192.168.7.2 24
[P-GigabitEthernet2/0/2] pim sm
[P-GigabitEthernet2/0/2] mpls enable
[P-GigabitEthernet2/0/2] mpls ldp enable
[P-GigabitEthernet2/0/2] quit
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.2 32
[P-LoopBack0] pim sm
[P-LoopBack0] quit
# Configure Loopback 0 as a C-BSR and a C-RP for the public network.
[P] pim
[P-pim] c-bsr 2.2.2.2
[P-pim] c-rp 2.2.2.2
[P-pim] quit
# Configure OSPF.
[P] ospf 1
[P-ospf-1] area 0.0.0.0
[P-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[P-ospf-1-area-0.0.0.0] network 192.168.6.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 192.168.7.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] quit
4.     Configure CE 1:
<CE1> system-view
[CE1] multicast routing
[CE1-mrib] quit
[CE1] interface gigabitethernet 2/0/1
[CE1-GigabitEthernet2/0/1] ip address 10.110.7.1 24
[CE1-GigabitEthernet2/0/1] pim sm
[CE1-GigabitEthernet2/0/1] quit
[CE1] interface gigabitethernet 2/0/2
[CE1-GigabitEthernet2/0/2] ip address 10.110.2.2 24
[CE1-GigabitEthernet2/0/2] pim sm
[CE1-GigabitEthernet2/0/2] quit
[CE1] interface loopback 1
[CE1-LoopBack1] ip address 11.11.11.11 32
[CE1-LoopBack1] pim sm
[CE1-LoopBack1] quit
# Configure Loopback 1 as a C-BSR and a C-RP for VPN instance a.
[CE1] pim
[CE1-pim] c-bsr 11.11.11.11
[CE1-pim] c-rp 11.11.11.11
[CE1-pim] quit
# Configure RIP.
[CE1] rip 2
[CE1-rip-2] network 10.110.2.0 0.0.0.255
[CE1-rip-2] network 10.110.7.0 0.0.0.255
[CE1-rip-2] network 11.11.11.11 0.0.0.0
[CE1-rip-2] quit
5.     Configure CE 2:
<CE2> system-view
[CE2] multicast routing
[CE2-mrib] quit
[CE2] interface gigabitethernet 2/0/1
[CE2-GigabitEthernet2/0/1] ip address 10.110.3.1 24
[CE2-GigabitEthernet2/0/1] pim sm
[CE2-GigabitEthernet2/0/1] quit
[CE2] interface gigabitethernet 2/0/2
[CE2-GigabitEthernet2/0/2] ip address 10.110.11.1 24
[CE2-GigabitEthernet2/0/2] igmp enable
[CE2-GigabitEthernet2/0/2] quit
# Configure RIP.
[CE2] rip 3
[CE2-rip-3] network 10.110.3.0 0.0.0.255
[CE2-rip-3] network 10.110.11.0 0.0.0.255
[CE2-rip-3] quit
# Display information about the local default group for IPv4 multicast transmission in each VPN instance on PE 2.
[PE2] display multicast-vpn default-group local
 239.1.1.1         1.1.1.2           MTunnel0      a
# Display PIM routing entries for MVPN extranet of VPN instance a on PE 2.
 Total 1 (*, G) entries; 1 (S, G) entries
 (*, 226.1.1.1)
     RP: 11.11.11.11
     Protocol: pim-sm, Flag: WC
     UpTime: 07:06:11
     Upstream interface: MTunnel0
         1: Extranet (VPN: b)
             Protocol: MD, UpTime: 01:12:52, Expires: -
(10.110.7.2, 226.1.1.1)
     RP: 11.11.11.11
     Protocol: pim-sm, Flag: SPT ACT RQ
     UpTime: 07:06:10
# Display PIM routing entries for MVPN extranet of VPN instance b on PE 2.
[PE2] display pim vpn-instance b routing-table
 (*, 226.1.1.1)
     RP: 20.20.20.20
     UpTime: 07:06:11
     Upstream interface: Extranet (VPN: a)
         Upstream neighbor: 127.0.0.1
         RPF prime neighbor: 127.0.0.1
             Protocol: igmp, UpTime: 01:12:52, Expires: -
     RP: 20.20.20.20
     Protocol: pim-sm, Flag: SPT ACT 2MVPN
     UpTime: 07:06:10
         1:
Troubleshooting MVPN
A default MDT cannot be established
Symptom
The default MDT cannot be established. PIM neighboring relationship cannot be established between PE devices' interfaces that are in the same VPN instance.
Solution
To resolve the problem:
1.     Use the display interface command to examine the MTI interface state and address encapsulation on the MTI.
2.     Use the display multicast-vpn default-group command to verify that the same default group address has been configured for the same VPN instance on different PE devices.
3.     Use the display pim interface command to verify the following:
¡     PIM is enabled on a minimum of one interface of the same VPN on different PE devices.
¡     The same PIM mode is running on all the interfaces of the same VPN instance on different PE devices and on all the interfaces of the P router.
4.     Use the display ip routing-table command to verify that a unicast route exists from the VPN instance on the local PE device to the same VPN instance on each remote PE device.
5.     Use the display bgp peer command to verify that the BGP peer connections have been correctly configured.
6.     If the problem persists, contact H3C Support.
An MVRF cannot be created
Symptom
A VPN instance cannot create an MVRF correctly.
Solution
1.     Use the display pim bsr-info command to verify that the BSR information exists on the public network and VPN instance. If it does not, verify that a unicast route exists to the BSR.
2.     Use the display pim rp-info command to examine the RP information. If no RP information is available, verify that a unicast route exists to the RP. Use the display pim neighbor command to verify that the PIM adjacencies have been correctly established on the public network and the VPN.
3.     Use the ping command to examine the connectivity between the VPN DR and the VPN RP.
4.     If the problem persists, contact H3C Support.
