- 28-WLAN Configuration Guide (FAT AP)
- 01-Compatibility of hardware and AP functionality
- 02-Radio management configuration
- 03-WLAN access configuration
- 04-WLAN security configuration
- 05-WLAN authentication configuration
- 06-WLAN QoS configuration
- 07-WLAN load balancing configuration
- 08-Band navigation configuration
- 09-WLAN multicast optimization configuration
| 03-WLAN access configuration | 337.42 KB |
Whitelist- and blacklist-based access control
Restrictions: Hardware compatibility with WLAN access
Configuring a service template
Configuring a description for a service template
Setting the maximum number of associated clients for a radio or a service template
Binding a service template to a radio interface
Specifying the method for APs to process traffic from unknown clients
Specifying the Web server to which client information is reported
Enabling generation of client logs in the specified format
Setting the idle period before client reauthentication
Configuring client maintenance
Setting the client idle timeout
Performing a wireless link quality test
Configuring client association ratio optimization
Enabling beacon frames and probe responses to carry the BSS load IE
Configuring client access control
Adding a client to the whitelist
Adding a client to the static blacklist
Configuring the dynamic blacklist
Configuring ACL-based access control
Enabling an AP to respond to specific broadcast probe requests
Enabling SNMP notifications for WLAN access
Display and maintenance commands for WLAN access
WLAN access configuration examples
Example: Configuring WLAN access
Example: Configuring whitelist-based access control
Example: Configuring static blacklist-based access control
Example: Configuring roaming enhancement
About WLAN access
Wireless access is provided by APs deployed at the edge of a wired network. The APs connect to the uplink through wired connections and provide wireless access services to downlink clients.
WLAN access process
A wireless client can access a WLAN only when it completes the scanning, link layer authentication, association, and WLAN authentication processes.
For more information about data link layer authentication, see "Configuring WLAN security." For more information about WLAN authentication, see "Configuring WLAN authentication."
Figure 1 WLAN access process
Scanning
Active scanning
A wireless client periodically scans surrounding wireless networks by sending probe requests. It obtains network information from received probe responses. Based on whether a probe request carries an SSID, active scanning can be divided into the following types:
· Active scanning of all wireless networks.
As shown in Figure 2, the client periodically sends a probe request on each of its supported channels to scan wireless networks. APs that receive the probe request send a probe response that carries the available wireless network information. The client associates with the optimal AP.
Figure 2 Scanning all wireless networks
· Active scanning of a specific wireless network.
As shown in Figure 3, the client periodically sends a probe request carrying the specified SSID or the SSID of the wireless network it has been associated with. When an AP that can provide wireless services with the specified SSID receives the probe request, it sends a probe response.
Figure 3 Scanning a specific wireless network
Passive scanning
As shown in Figure 4, the clients periodically listen for beacon frames sent by APs on their supported channels to get information about surrounding wireless networks. Then the clients select an AP for association. Passive scanning is used when clients want to save power.
Association
A client sends an association request to the associated AP after passing date link layer authentication. Upon receiving the request, the AP determines the capability supported by the wireless client and sends an association response to the client. Then the client is associated with the AP.
Client access control
The following client access control methods are available:
· Whitelist- and blacklist-based access control—Uses the whitelist and blacklists to control client access.
· ACL-based access control—Uses ACL rules bound to APs or service templates to control client access.
You can configure the whitelist or blacklists to filter frames from clients for client access control.
Whitelist-based access control
The whitelist contains the MAC addresses of all clients allowed to access the WLAN. Frames from clients not in the whitelist are discarded. This list is manually configured.
Blacklist-based access control
The following blacklists are available for access control:
· Static blacklist—Contains the MAC addresses of clients forbidden to access the WLAN. This list is manually configured.
· Dynamic blacklist—Contains the MAC addresses of clients forbidden to access the WLAN. An AP adds the MAC address of a client forbidden to access the WLAN to the list when WIPS is configured or when URL redirection is enabled for WLAN MAC authentication clients. The entries in the list are removed when the aging time expires.
Working mechanism
When the AP receives an association request, the AP performs the following operations to determine whether to permit the client:
1. Searches the whitelist:
¡ If the client MAC address does not match any entry in the whitelist, the client is rejected.
¡ If a match is found, the client is permitted.
2. Searches the static and dynamic blacklists if no whitelist entries exist:
¡ If the client MAC address matches an entry in either blacklist, the client is rejected.
¡ If no match is found, or no blacklist entries exist, the client is permitted.
Figure 5 Whitelist- and blacklist-based access control
This feature controls client access by using ACL rules bound to an AP or a service template.
Upon receiving an association request from a client, the device performs the following actions:
· Allows the client to access the WLAN if a match is found and the rule action is permit.
· Denies the client's access to the WLAN if no match is found or the matched rule has a deny statement.
For information about MSR routers that can offer WLAN services as fat APs, see "Compatibility of hardware and AP functionality."
WLAN access tasks at a glance
To configure WLAN access, perform the following tasks:
1. Configuring wireless services
¡ Configuring a service template
¡ (Optional.) Configuring a description for a service template
¡ (Optional.) Setting the maximum number of associated clients for a radio or a service template
¡ Binding a service template to a radio interface
2. (Optional.) Specifying the method for APs to process traffic from unknown clients
3. (Optional.) Configuring client management
¡ Specifying the Web server to which client information is reported
¡ Enabling generation of client logs in the specified format
¡ Setting the idle period before client reauthentication
4. (Optional.) Configuring client maintenance
¡ Setting the client idle timeout
¡ Configuring client keepalive
¡ Performing a wireless link quality test
¡ Configuring client association ratio optimization
5. (Optional.) Configuring client access control
¡ Adding a client to the whitelist
¡ Adding a client to the static blacklist
¡ Configuring the dynamic blacklist
¡ Configuring ACL-based access control
6. (Optional.) Enabling an AP to respond to specific broadcast probe requests
7. (Optional.) Enabling SNMP notifications for WLAN access
A service template defines a set of wireless service attributes, such as SSID and authentication method.
1. Enter system view.
2. Create a service template.
wlan service-template service-template-name
By default, no service template exists.
3. (Optional.) Assign clients coming online through the service template to the specified VLAN.
vlan vlan-id
By default, clients are assigned VLAN 1 after coming online through a service template.
2. Enter service template view.
3. Configure a description for the service template.
By default, no description is configured for a service template.
Setting an SSID
APs broadcast SSIDs in beacon frames for clients to discover them. When a BSS is unavailable or when you do not want clients to discover the BSS, you can enable SSID-hidden. With SSID-hidden enabled, the BSS hides its SSID in beacon frames and does not respond to broadcast probe requests. A client must send probe requests with the specified SSID to access the WLAN. This feature can protect the WLAN from being attacked.
When the number of clients associated with an AP reaches the upper limit, the AP automatically hides its SSIDs in beacon frames, and other clients cannot discover and associate with the AP. For these clients to discover the AP, you can configure the SSID broadcast feature. However, these clients still cannot associate with the AP.
3. Set an SSID for the service template.
ssid ssid-name
By default, no SSID is set for a service template.
4. (Optional.) Enable SSID-hidden in beacon frames.
beacon ssid-hide
By default, SSIDs are not hidden in beacon frames.
5. (Optional.) Enable SSID broadcast in beacon frames.
beacon ssid-advertise
By default, an AP hides SSIDs in beacon frames when the maximum number of associated clients is reached.
Perform this task to limit the associated client quantity to avoid overload. With this feature configured, new clients cannot access the WLAN and the SSID is hidden when the maximum number is reached.
3. Set the maximum number of associated clients for a radio or the service template.
client max-count max-number
By default, the number of associated clients for a radio or a service template is not limited.
Enabling a service template
3. Enable the service template.
service-template enable
By default, a service template is disabled.
You can bind a maximum of 16 service templates to a radio interface.
2. Enter WLAN-Radio interface view.
interface wlan-radio interface-number
3. Bind a service template to the radio interface.
By default, no service template is bound to a radio interface.
Perform this task to configure APs using the specified service template to drop data packets from unknown clients and deauthenticate these clients or to drop the packets only.
3. Specify the method for APs to process traffic from unknown clients.
unknown-client [ deauthenticate | drop ]
By default, APs drop packets from unknown clients and deauthenticate these clients.
Enabling quick association
Enabling band navigation might affect client association efficiency. For delay-sensitive services or in an environment where band navigation is not needed, you can enable quick association for a service template.
Quick association disables band navigation on clients associated with the service template. The device will not perform band navigation even if the feature is enabled in the WLAN.
3. Enable quick association.
quick-association enable
By default, quick association is disabled.
Perform this task to enable the device to report client information, such as client MAC address, associated AP, and association time, to the specified Web server through HTTP. The Web server accepts client information only when the server's host name, port number, and path are specified.
2. Specify the host name and port number of the Web server.
wlan web-server host host-name port port-number
By default, the host name and port number of the Web server are not specified.
3. Specify the path of the Web server.
wlan web-server api-path path
By default, the path of the Web server is not specified.
4. (Optional.) Set the maximum number of client entries that can be reported at a time.
wlan web-server max-client-entry number
By default, a maximum of ten client entries can be reported at a time.
The device supports client logs in the following formats:
· H3C—Logs AP name, radio ID, client MAC address, SSID, BSSID, and client online status. By default, the device generates client logs only in H3C format.
· Normal—Logs AP MAC address, AP name, client IP address, client MAC address, SSID, and BSSID.
· Sangfor—Logs AP MAC address, client IP address, and client MAC address.
This feature enables the device to generate client logs in normal or sangfor format and send the logs to the information center. Log destinations are determined by the information center settings. For more information about the information center, see Network Management and Monitoring Configuration Guide.
This feature does not affect generation of client logs in the H3C format.
2. Enable the device to generate client logs in the specified format.
customlog format wlan { normal | sangfor }
By default, the device generates client logs only in the H3C format.
When URL redirection for WLAN MAC authentication is enabled, an AP redirects clients whose information is not recorded on the RADIUS server to the specified URL for Web authentication. Clients passing Web authentication are logged off and must perform MAC reauthentication to come online. However, MAC reauthentication fails if the IP addresses assigned to the clients have not expired.
Perform this task to add these clients to the dynamic blacklist for the specified idle period after they pass Web authentication to reduce reauthentication failures.
2. Set the idle period before client reauthentication.
wlan client reauthentication-period [ period-value ]
By default, the idle period is 10 seconds.
If an online client does not send any frames to the associated AP before the client idle timeout timer expires, the AP logs off the client.
2. Set the client idle timeout.
wlan client idle-timeout timeout
By default, the client idle timeout is 3600 seconds.
This feature enables an AP to send keepalive packets to clients at the specified interval to determine whether the clients are online. If the AP does not receive any replies from a client within three keepalive intervals, it logs off the client.
2. Enable client keepalive.
wlan client keep-alive enable
By default, client keepalive is disabled.
3. Set the client keepalive interval.
wlan client keep-alive interval interval
By default, the client keepalive interval is 300 seconds.
This feature enables an AP to test the quality of the link to a wireless client. The AP sends empty data frames to the client at each supported rate. Then it calculates link quality information such as RSSI, packet retransmissions, and RTT based on the responses from the client.
The timeout for a wireless link quality test is 10 seconds. If the wireless link test is not completed before the timeout expires, test results cannot be obtained.
To perform a wireless link quality test, execute the wlan link-test mac-address command in user view.
Setting the NAS ID
A network access server identifier (NAS ID) or network access server port identifier (NAS port ID) identifies the network access server of a client and differentiates the source of client traffic.
If you specify a NAS ID when binding a service template to a radio, the radio uses the NAS ID specified for the service template.
2. Set the format of NAS port IDs for wireless clients.
wlan nas-port-id format { 2 | 4 }
By default, clients use format 2 to generate NAS port IDs.
3. Enter global configuration view.
wlan global-configuration
4. Set the NAS ID.
nas-id nas-id
By default, no NAS ID is set.
Setting the NAS port type
RADIUS requests carry the NAS port type attribute to indicate type of the access port for 802.1X and MAC authentication clients.
Make sure the service template is disabled before you perform this task.
3. Set the NAS port type.
nas-port-type value
By default, the NAS port type is WLAN-IEEE 802.11 with a code value of 19.
This feature enables the device to recalculate the client association success ratio, association congestion ratio, and abnormal disassociation ratio by using the specified index to get smaller ratio values.
The client association success ratio is the number of successful client associations divided by the total number of client association attempts. The client association congestion ratio is the number of failed client associations caused by AP overloading divided by the total number of client association attempts. The client abnormal disassociation ratio is the number of abnormal disassociations divided by the sum of successful associations and online clients.
2. Enter global configuration view.
wlan association optimization value
By default, the index is 0. The device does not optimize client association ratios.
About BSS load IE in beacon frames and probe responses
A BSS load IE contains information about the number of online clients in the BSS, channel usage, and remaining media time.
As a best practice, enable this feature in Hotspot 2.0 networks or networks configured with WLAN roaming to help clients identify the optimal WLAN.
2. Enable beacon frames and probe responses to carry the BSS load IE.
wlan client bss-load-ie enable [ update-interval interval ]
By default, beacon frames and probe responses do not carry the BSS load IE.
When you add the first client to the whitelist, the system asks you whether to disconnect all online clients. Enter Y at the prompt to configure the whitelist.
2. Add a client to the whitelist.
wlan whitelist mac-address mac-address
You cannot add a client to both the whitelist and the static blacklist.
If the whitelist and blacklists are configured, only the whitelist takes effect.
2. Add a client to the static blacklist.
wlan static-blacklist mac-address mac-address
The AP adds the MAC address of a client forbidden to access the WLAN to the list when WIPS is configured or when URL redirection is enabled for WLAN MAC authentication clients.
Entries in the dynamic blacklist are removed when the aging timer expires.
The configured aging timer takes effect only on entries newly added to the dynamic blacklist.
2. Set the aging timer for dynamic blacklist entries.
wlan dynamic-blacklist lifetime lifetime
By default, the aging timer is 300 seconds.
The aging timer for dynamic blacklist entries takes effect only on rogue client entries.
The ACL-based access control configuration takes precedence over the whitelist and blacklist configuration. As a best practice, do not configure both ACL-based access control and whitelist- and blacklist-based access control on the same device.
If the specified ACL contains a deny statement, configure a permit statement for the ACL to permit all clients. If you do not do so, no clients can come online.
This feature supports only Layer 2 ACLs and can only use source MAC address as the match criterion. If you specify an ACL of another type, the configuration does not take effect.
3. Specify an ACL.
access-control acl acl-number
By default, no ACL is specified.
Broadcast probe requests do not carry any SSIDs. Upon receiving a broadcast probe request, an AP responds with a probe response that carries service information for the AP.
By default, an AP responds to all broadcast probe requests, which might threat network security and decrease AP performance. However, disabling responding to broadcast probe requests might forbid clients from roaming to the optimal AP in time, affecting client access.
You can perform this task to enable an AP to respond to broadcast requests from a specific frequency band with strong signal strength.
2. Enable the AP to respond to specific broadcast probe requests.
wlan broadcast-probe reply [ rssi-threshold rssi-value ] [ frequency-band { 2.4 | 5 } ]
By default, the AP responds to broadcast probe requests from clients operating at any frequency band.
To report critical WLAN access events to an NMS, enable SNMP notifications for WLAN access. For WLAN access event notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
2. Choose the options to configure as needed:
¡ Enable SNMP notifications for client access.
snmp-agent trap enable wlan client
¡ Enable SNMP notifications for client audit.
snmp-agent trap enable wlan client-audit
By default, SNMP notifications are disabled.
Enabling smart client access
About smart client access
This feature enables H3C wireless clients to access the WLAN automatically when the AKM mode is set to PSK or when the radio is bound to an empty service template.
3. Enable smart client access.
client smart-access enable
By default, smart client access is disabled.
Task |
Command |
Display WLAN radio interface information. |
display interface wlan-radio [ interface-number ] [ brief ] |
Display the number of online clients at the 2.4 GHz band and the 5 GHz band. |
display wlan ap all client-number |
Display the number of online clients and channel information for each radio. |
display wlan ap all radio client-number |
Display blacklist entries. |
display wlan blacklist { dynamic | static } |
Display basic service set (BSS) information. |
display wlan bss { all | bssid bssid } [ verbose ] |
Display client information. |
display wlan client [ interface wlan-radio interface-number | mac-address mac-address | service-template service-template-name | vlan vlan-id ] [ verbose ] |
Display information about client IPv6 addresses. |
display wlan client ipv6 |
Display client online duration. |
display wlan client online-duration [ verbose ] |
Display client status information. |
display wlan client status [ mac-address mac-address ] [ verbose ] |
Display statistics about received and transmitted packets in client mode. |
display wlan client-mode packet-statistics radio radio-id |
Display information about BSSs detected in client mode. |
display wlan client-mode roam-enhance bss |
Display roaming state changes of the AP in client mode. |
display wlan client-mode roaming-state |
Display service template information. |
display wlan service-template [ service-template-name ] [ verbose ] |
Display client statistics. |
display wlan statistics client [ mac-address mac-address ] |
Display client connection history. |
display wlan statistics connect-history service-template service-template-name |
Display service template statistics. |
display wlan statistics service-template service-template-name |
Display whitelist entries. |
display wlan whitelist |
Log off the specified client or all clients. |
reset wlan client { all | mac-address mac-address } |
Remove the specified client or all clients from the dynamic blacklist. |
reset wlan dynamic-blacklist [ mac-address mac-address ] |
Clear client statistics. |
reset wlan statistics client { all | mac-address mac-address } |
Clear service template statistics. |
reset wlan statistics service-template service-template-name |
As shown in Figure 6, the switch acts as the DHCP server to assign IP addresses to the AP and the client. The AP provides wireless services with SSID trade-off.
# Create service template service1, set the SSID to trade-off, and enable the service template.
<AP> system-view
[AP] wlan service-template service1
[AP-wlan-st-service1] ssid trade-off
[AP-wlan-st-service1] service-template enable
[AP-wlan-st-service1] quit
# Bind service template service1 to WLAN-Radio 0/0.
[AP] interface wlan-radio 0/0
[AP-WLAN-Radio0/0] undo shutdown
[AP-WLAN-Radio0/0] service-template service1
[AP-WLAN-Radio0/0] quit
# Verify that the SSID is trade-off, and the service template is enabled.
[AP] display wlan service-template verbose
Service template name : service1
Description : Not configured
SSID : trade-off
SSID-hide : Disabled
User-isolation : Disabled
Service template status : Enabled
Maximum clients per BSS : Not configured
Frame format : Dot3
Seamless roam status : Disabled
Seamless roam RSSI threshold : 50
Seamless roam RSSI gap : 20
VLAN ID : 3
AKM mode : Not configured
Security IE : Not configured
Cipher suite : Not configured
TKIP countermeasure time : 0 sec
PTK life time : 43200 sec
PTK rekey : Enabled
GTK rekey : Enabled
GTK rekey method : Time-based
GTK rekey time : 86400 sec
GTK rekey client-offline : Disabled
WPA3 status : Disabled
PPSK : Disabled
PPSK Fail Permit : Disabled
Enhance-open status : Enabled
Enhanced-open transition-mode service-template : N/A
User authentication mode : Bypass
Intrusion protection : Disabled
Intrusion protection mode : Temporary-block
Temporary block time : 180 sec
Temporary service stop time : 20 sec
Fail VLAN ID : Not configured
Critical VLAN ID : Not configured
802.1X handshake : Disabled
802.1X handshake secure : Disabled
802.1X domain : my-domain
MAC-auth domain : Not configured
Max 802.1X users per BSS : 4096
Max MAC-auth users per BSS : 4096
802.1X re-authenticate : Disabled
Authorization fail mode : Online
Accounting fail mode : Online
Authorization : Permitted
Key derivation : SHA1
PMF status : Disabled
Hotspot policy number : Not configured
Forwarding policy status : Disabled
Forwarding policy name : Not configured
Forwarder : AP
FT status : Disabled
QoS trust : Port
QoS priority : 0
# Associate the client with the fat AP. (Details not shown.)
# Verify that the client can access the WLAN.
[AP] display wlan client service-template service1
Total number of clients: 1
MAC address Username RID IP address IPv6 address VLAN
0023-8933-223b N/A 1 3.0.0.3 3
As shown in Figure 7, configure the whitelist to permit only the client whose MAC address is 0000-000f-1211 to access the WLAN.
# Add MAC address 0000-000f-1211 to the whitelist.
<AP> system-view
[AP] wlan whitelist mac-address 0000-000f-1211
# Verify that MAC address 0000-000f-1211 is in the whitelist.
<AP> display wlan whitelist
MAC addresses:
0000-000f-1211
As shown in Figure 8, configure the static blacklist to forbid the client whose MAC address is 0000-000f-1211 to access the WLAN.
# Add MAC address 0000-000f-1211 to the static blacklist.
<AP> system-view
[AP] wlan static-blacklist mac-address 0000-000f-1211
# Verify that MAC address 0000-000f-1211 is in the static blacklist.
<AP> display wlan blacklist static
MAC addresses:
0000-000f-1211
As shown in Figure 9, AP 1 and AP 2 are fit APs associated with the AC to provide wireless access service for client-mode fat APs. AP 3 operates in client mode to provide wireless access for devices that do not have a wireless NIC on the vehicle. Configure radio 1 (5 GHz) on AP 3 to access SSID agv and enable radio enhancement on radio 2 (2.4 GHz) on AP 3.
1. Configure the AC:
# Create service template agv and set the SSID to agv. This service template is used for the wireless access of AP 3.
<AC> system-view
[AC] wlan service-template agv
[AC-wlan-st-agv] ssid agv
[AC-wlan-st-agv] service-template enable
[AC-wlan-st-agv] quit
# Create service template service and set the SSID to service. This service template is used for roaming enhancement and the wireless access of devices other than AP 3, for example, phones and iPads.
[AC] wlan service-template service
[AC-wlan-st-service] ssid service
[AC-wlan-st-service] service-template enable
[AC-wlan-st-service] quit
# Create AP ap1 and specify its serial ID.
[AC] wlan ap ap1 model WA6320
[AC-wlan-ap-ap1] serial-id 219801A28N819CE00021T
# Configure radio 1 of AP ap1 to operate in channel 36, and bind service template agv to the radio.
[AC-wlan-ap-ap1] radio 1
[AC-wlan-ap-ap1-radio-1] channel 36
[AC-wlan-ap-ap1-radio-1] service-template agv
[AC-wlan-ap-ap1-radio-1] quit
# Configure radio 2 of AP ap1 to operate in channel 1, enable roaming enhancement, and bind service template service to the radio.
[AC-wlan-ap-ap1] radio 2
[AC-wlan-ap-ap1-radio-2] channel 1
[AC-wlan-ap-ap1-radio-2] service-template service
[AC-wlan-ap-ap1-radio-2] roam-enhance ssid agv
[AC-wlan-ap-ap1-radio-2] radio enable
[AC-wlan-ap-ap1-radio-2] quit
[AC-wlan-ap-ap1] quit
# Create AP ap2 and specify its serial ID.
[AC] wlan ap ap2 model WA6320
[AC-wlan-ap-ap2] serial-id 219801A28N819CE0002T
# Configure radio 1 of AP ap2 to operate in channel 40, and bind service template agv to the radio.
[AC-wlan-ap-ap2] radio 1
[AC-wlan-ap-ap2-radio-1] channel 40
[AC-wlan-ap-ap2-radio-1] service-template agv
[AC-wlan-ap-ap2-radio-1] radio enable
[AC-wlan-ap-ap2-radio-1] quit
# Configure radio 2 of AP ap2 to operate in channel 6, enable roaming enhancement, and bind service template service to the radio.
[AC-wlan-ap-ap2] radio 2
[AC-wlan-ap-ap2-radio-2] channel 6
[AC-wlan-ap-ap2-radio-2] service-template service
[AC-wlan-ap-ap2-radio-2] roam-enhance ssid agv
[AC-wlan-ap-ap2-radio-2] radio enable
[AC-wlan-ap-ap2-radio-2] quit
[AC-wlan-ap-ap2] quit
2. Configure AP 3.
# Enter view of radio interface WLAN-Radio 1/0/1.
[AP3] interface wlan-radio 1/0/1
# Enable client mode.
[AP3-WLAN-Radio1/0/1] client-mode enable
# Specify SSID agv for the radio.
[AP3-WLAN-Radio1/0/1] client-mode ssid agv
[AP3-WLAN-Radio1/0/1] quit
# Enter view of radio interface WLAN-Radio 1/0/2.
[AP3] interface wlan-radio 1/0/2
# Add channels 1, 6, and 11 to the channel scanning whitelist.
[AP3-WLAN-Radio1/0/2] scan channel whitelist 1 6 11
# Enable roaming enhancement and set the roaming mode to quick.
[AP3-WLAN-Radio1/0/2] client-mode roam-enhance quick
[AP3-WLAN-Radio1/0/2] quit
# Verify that you can view information about detected BSSs on AP 3.
<AP3> display wlan client-mode roam-enhance bss
Total number of BSSs: 2
BSSID Time MSec RSSI AVER CHL AGE SSID
84d9-3100-4b00 16:51:09 0244 37 36 36 5 agv
16:51:08 0834 37
16:51:08 0732 36
16:51:08 0642 37
16:51:09 0253 36
50da-00df-33e0 16:51:08 0802 45 45 40 5 agv
16:51:08 0699 44
16:51:08 0597 46
16:51:08 0261 46
16:51:09 0251 45
