- 28-WLAN Configuration Guide (FAT AP)
- 01-Compatibility of hardware and AP functionality
- 02-Radio management configuration
- 03-WLAN access configuration
- 04-WLAN security configuration
- 05-WLAN authentication configuration
- 06-WLAN QoS configuration
- 07-WLAN load balancing configuration
- 08-Band navigation configuration
- 09-WLAN multicast optimization configuration
| 02-Radio management configuration | 455.74 KB |
Restrictions: Hardware compatibility with radio management
Restrictions and guidelines: Radio management configuration
Radio management tasks at a glance
Enabling or disabling a radio interface
Enabling a radio to disable wireless services as scheduled
Configuring basic radio functions
Setting the maximum transmit power
Specifying a collision avoidance mode
Setting the fragmentation threshold
Setting the hardware retransmission limits
Setting the maximum number of clients that can associate with an AP
Configuring access services for 802.11b clients
Configuring 802.11g protection
Setting the maximum transmission distance
Enabling the continuous mode for a radio
Performing on-demand channel usage measurement
Configuring the A-MPDU aggregation method
Configuring the A-MSDU aggregation method
Configuring the client dot11n-only feature
Setting the 802.11n bandwidth mode
Configuring 802.11n protection
Configuring 802.11ac functions
Configuring the client dot11ac-only feature
Setting the 802.11ac bandwidth mode
Configuring the smart antenna feature
Configuring error packet ratio optimization and retransmission ratio optimization
Display and maintenance commands for radio management
Radio management configuration examples
Example: Configuring basic radio functions
Configuring radio management
About radio management
Radio frequency (RF) is a rate of electrical oscillation in the range of 300 KHz to 300 GHz. WLAN uses the 2.4 GHz band and 5 GHz band radio frequencies as the transmission media. The 2.4 GHz band includes radio frequencies from 2.4 GHz to 2.4835 GHz. The 5 GHz band includes radio frequencies from 5.150 GHz to 5.350 GHz and from 5.725 GHz to 5.850 GHz.
The term "radio frequency" or its abbreviation RF is also used as a synonym for "radio" in wireless communication.
Radio mode
NOTE: · 802.11g, 802.11n, and 802.11ac are backward compatible. · In this document, the term "802.11ac" refers to both 802.11ac and 802.11gac, unless otherwise specified. |
Table 1 provides a comparison of these radio modes.
Table 1 Comparison of 802.11 standards
IEEE standard |
Frequency band |
Maximum rate |
802.11a |
5 GHz |
54 Mbps |
802.11b |
2.4 GHz |
11 Mbps |
802.11g |
2.4 GHz |
54 Mbps |
802.11n |
2.4 GHz or 5 GHz |
600 Mbps |
802.11ac |
5 GHz |
6900 Mbps |
802.11gac |
2.4 GHz |
1600 Mbps |
802.11ax |
5 GHz |
9600 Mbps |
802.11gax |
2.4 GHz |
6900 Mbps |
Channel
A channel is a range of frequencies with a specific bandwidth.
The 2.4 GHz band has 14 channels. The bandwidth for each channel is 20 MHz and each two channels are spaced 5 MHz apart. Among the 14 channels, four groups of non-overlapping channels exist and the most commonly used one contains channels 1, 6, and 11.
The 5 GHz band can provide higher rates and is more immune to interference. There are 24 non-overlapping channels designated to the 5 GHz band. The channels are spaced 20 MHz apart with a bandwidth of 20 MHz. The available channels vary by country.
Transmit power
Transmit power reflects the signal strength of a wireless device. A higher transmit power enables a radio to cover a larger area but it brings more interference to adjacent devices. The signal strength decreases as the transmission distance increases.
Transmission rate
Transmission rate refers to the speed at which wireless devices transmit traffic. It varies by radio mode and spreading, coding, and modulation schemes. The following are rates supported by different types of radios:
· 802.11a—6 Mbps, 9 Mbps, 12 Mbps, 18 Mbps, 24 Mbps, 36 Mbps, 48 Mbps, and 54 Mbps.
· 802.11b—1 Mbps, 2 Mbps, 5.5 Mbps, and 11 Mbps.
· 802.11g—1 Mbps, 2 Mbps, 5.5 Mbps, 6 Mbps, 9 Mbps, 11 Mbps, 12 Mbps, 18 Mbps, 24 Mbps, 36 Mbps, 48 Mbps, and 54 Mbps.
· 802.11n—Rates for 802.11n radios vary by channel bandwidth. For more information, see "MCS."
· 802.11ac—Rates for 802.11ac radios vary by channel bandwidth and number of spatial streams (NSS). For more information, see "VHT-MCS."
MCS
Modulation and Coding Scheme (MCS) defined in IEEE 802.11n-2009 determines the modulation, coding, and number of spatial streams.
MCS types
802.11n MCSs are classified into the following types:
· Mandatory MCSs—Mandatory MCSs for an AP. To associate with an 802.11n AP, a client must support the mandatory MCSs for the AP.
· Supported MCSs—MCSs supported by an AP besides the mandatory MCSs. If a client supports both mandatory and supported MCSs, the client can use a supported rate to communicate with the AP.
· Multicast MCS—MCS for the rate at which an AP transmits multicast frames.
MCS parameters
An MCS is identified by an MCS index, which is represented by an integer in the range of 0 to 76. An MCS index is the mapping from MCS to a data rate.
Table 2 through Table 9 show sample MCS parameters for 20 MHz and 40 MHz.
When the bandwidth mode is 20 MHz, MCS indexes 0 through 15 are mandatory for APs, and MCS indexes 0 through 7 are mandatory for clients.
Table 2 MCS parameters (20 MHz, NSS=1)
MCS index |
Number of spatial streams |
Modulation |
Data rate (Mbps) |
800ns GI |
400ns GI |
0 |
1 |
BPSK |
6.5 |
7.2 |
1 |
1 |
QPSK |
13.0 |
14.4 |
2 |
1 |
QPSK |
19.5 |
21.7 |
3 |
1 |
16-QAM |
26.0 |
28.9 |
4 |
1 |
16-QAM |
39.0 |
43.3 |
5 |
1 |
64-QAM |
52.0 |
57.8 |
6 |
1 |
64-QAM |
58.5 |
65.0 |
7 |
1 |
64-QAM |
65.0 |
72.2 |
Table 3 MCS parameters (20 MHz, NSS=2)
MCS index |
Modulation |
Data rate (Mbps) |
800ns GI |
400ns GI |
8 |
2 |
BPSK |
13.0 |
14.4 |
9 |
2 |
QPSK |
26.0 |
28.9 |
10 |
2 |
QPSK |
39.0 |
43.3 |
11 |
2 |
16-QAM |
52.0 |
57.8 |
12 |
2 |
16-QAM |
78.0 |
86.7 |
13 |
2 |
64-QAM |
104.0 |
115.6 |
14 |
2 |
64-QAM |
117.0 |
130.0 |
15 |
2 |
64-QAM |
130.0 |
144.4 |
Table 4 MCS parameters (20 MHz, NSS=3)
MCS index |
Modulation |
Data rate (Mbps) |
800ns GI |
400ns GI |
16 |
3 |
BPSK |
19.5 |
21.7 |
17 |
3 |
QPSK |
39.0 |
43.3 |
18 |
3 |
QPSK |
58.5 |
65.0 |
19 |
3 |
16-QAM |
78.0 |
86.7 |
20 |
3 |
16-QAM |
117.0 |
130.0 |
21 |
3 |
64-QAM |
156.0 |
173.3 |
22 |
3 |
64-QAM |
175.5 |
195.0 |
23 |
3 |
64-QAM |
195.0 |
216.7 |
Table 5 MCS parameters (20 MHz, NSS=4)
MCS index |
Modulation |
Data rate (Mbps) |
800ns GI |
400ns GI |
24 |
4 |
BPSK |
26.0 |
28.9 |
25 |
4 |
QPSK |
52.0 |
57.8 |
26 |
4 |
QPSK |
78.0 |
86.7 |
27 |
4 |
16-QAM |
104.0 |
115.6 |
28 |
4 |
16-QAM |
156.0 |
173.3 |
29 |
4 |
64-QAM |
208.0 |
231.1 |
30 |
4 |
64-QAM |
234.0 |
260.0 |
31 |
4 |
64-QAM |
260.0 |
288.9 |
Table 6 MCS parameters (40 MHz, NSS=1)
MCS index |
Modulation |
Data rate (Mbps) |
800ns GI |
400ns GI |
0 |
1 |
BPSK |
13.5 |
15.0 |
1 |
1 |
QPSK |
27.0 |
30.0 |
2 |
1 |
QPSK |
40.5 |
45.0 |
3 |
1 |
16-QAM |
54.0 |
60.0 |
4 |
1 |
16-QAM |
81.0 |
90.0 |
5 |
1 |
64-QAM |
108.0 |
120.0 |
6 |
1 |
64-QAM |
121.5 |
135.0 |
7 |
1 |
64-QAM |
135.0 |
150.0 |
Table 7 MCS parameters (40 MHz, NSS=2)
MCS index |
Modulation |
Data rate (Mbps) |
800ns GI |
400ns GI |
8 |
2 |
BPSK |
27.0 |
30.0 |
9 |
2 |
QPSK |
54.0 |
60.0 |
10 |
2 |
QPSK |
81.0 |
90.0 |
11 |
2 |
16-QAM |
108.0 |
120.0 |
12 |
2 |
16-QAM |
162.0 |
180.0 |
13 |
2 |
64-QAM |
216.0 |
240.0 |
14 |
2 |
64-QAM |
243.0 |
270.0 |
15 |
2 |
64-QAM |
270.0 |
300.0 |
Table 8 MCS parameters (40 MHz, NSS=3)
MCS index |
Modulation |
Data rate (Mbps) |
800ns GI |
400ns GI |
16 |
3 |
BPSK |
40.5 |
45.0 |
17 |
3 |
QPSK |
81.0 |
90.0 |
18 |
3 |
QPSK |
121.5 |
135.0 |
19 |
3 |
16-QAM |
162.0 |
180.0 |
20 |
3 |
16-QAM |
243.0 |
270.0 |
21 |
3 |
64-QAM |
324.0 |
360.0 |
22 |
3 |
64-QAM |
364.5 |
405.0 |
23 |
3 |
64-QAM |
405.0 |
450.0 |
Table 9 MCS parameters (40 MHz, NSS=4)
MCS index |
Modulation |
Data rate (Mbps) |
800ns GI |
400ns GI |
24 |
4 |
BPSK |
54.0 |
60.0 |
25 |
4 |
QPSK |
108.0 |
120.0 |
26 |
4 |
QPSK |
162.0 |
180.0 |
27 |
4 |
16-QAM |
216.0 |
240.0 |
28 |
4 |
16-QAM |
324.0 |
360.0 |
29 |
4 |
64-QAM |
432.0 |
480.0 |
30 |
4 |
64-QAM |
486.0 |
540.0 |
31 |
4 |
64-QAM |
540.0 |
600.0 |
NOTE: · For all the MCS data rate tables, see IEEE 802.11n-2009. · Support for MCS indexes depends on the device model. |
VHT-MCS
Very High Throughput Modulation and Coding Scheme (VHT-MCS) defined in IEEE 802.11ac determines the wireless data rates.
VHT-MCS types
802.11ac VHT-MCSs are classified into the following types:
· Mandatory VHT-MCSs—Mandatory VHT-MCSs for an AP. To associate with an 802.11ac AP, a client must support the mandatory VHT-MCSs for the AP.
· Supported VHT-MCSs—VHT-MCSs supported by an AP besides the mandatory VHT-MCSs. If a client supports both mandatory and supported VHT-MCSs, the client can use a supported rate to communicate with the AP.
· Multicast VHT-MCS—VHT-MCS for the rate at which an AP transmits multicast frames.
VHT-MCS parameters
A VHT-MCS is identified by a VHT-MCS index, which is represented by an integer in the range of 0 to 9. A VHT-MCS index is the mapping from VHT-MCS to a data rate.
802.11ac supports the 20 MHz, 40 MHz, 80 MHz, and 160 MHz bandwidth modes, and supports a maximum of eight spatial streams. 802.11gac supports the 20 MHz and 40 MHz bandwidth modes.
Table 10 through Table 21 show VHT-MCS parameters that are supported by an AP.
Table 10 VHT-MCS parameters (20 MHz, NSS=1)
VHT-MCS index |
Modulation |
Data rate (Mbps) |
800ns GI |
400ns GI |
0 |
BPSK |
6.5 |
7.2 |
1 |
QPSK |
13.0 |
14.4 |
2 |
QPSK |
19.5 |
21.7 |
3 |
16-QAM |
26.0 |
28.9 |
4 |
16-QAM |
39.0 |
43.3 |
5 |
64-QAM |
52.0 |
57.8 |
6 |
64-QAM |
58.5 |
65.0 |
7 |
64-QAM |
65.0 |
72.2 |
8 |
256-QAM |
78.0 |
86.7 |
9 |
Not valid |
Table 11 VHT-MCS parameters (20 MHz, NSS=2)
VHT-MCS index |
Modulation |
Data rate (Mbps) |
800ns GI |
400ns GI |
0 |
BPSK |
13.0 |
14.4 |
1 |
QPSK |
26.0 |
28.9 |
2 |
QPSK |
39.0 |
43.3 |
3 |
16-QAM |
52.0 |
57.8 |
4 |
16-QAM |
78.0 |
86.7 |
5 |
64-QAM |
104.0 |
115.6 |
6 |
64-QAM |
117.0 |
130.0 |
7 |
64-QAM |
130.0 |
144.4 |
8 |
256-QAM |
156.0 |
173.3 |
9 |
Not valid |
Table 12 VHT-MCS parameters (20 MHz, NSS=3)
VHT-MCS index |
Modulation |
Data rate (Mbps) |
800ns GI |
400ns GI |
0 |
BPSK |
19.5 |
21.7 |
1 |
QPSK |
39.0 |
43.3 |
2 |
QPSK |
58.5 |
65.0 |
3 |
16-QAM |
78.0 |
86.7 |
4 |
16-QAM |
117.0 |
130.0 |
5 |
64-QAM |
156.0 |
173.3 |
6 |
64-QAM |
175.5 |
195.0 |
7 |
64-QAM |
195.0 |
216.7 |
8 |
256-QAM |
234.0 |
260.0 |
9 |
256-QAM |
260.0 |
288.9 |
Table 13 VHT-MCS parameters (20 MHz, NSS=4)
VHT-MCS index |
Modulation |
Data rate (Mbps) |
800ns GI |
400ns GI |
0 |
BPSK |
26.0 |
28.9 |
1 |
QPSK |
52.0 |
57.8 |
2 |
QPSK |
78.0 |
86.7 |
3 |
16-QAM |
104.0 |
115.6 |
4 |
16-QAM |
156.0 |
173.3 |
5 |
64-QAM |
208.0 |
231.1 |
6 |
64-QAM |
234.0 |
260.0 |
7 |
64-QAM |
260.0 |
288.9 |
8 |
256-QAM |
312.0 |
346.7 |
9 |
Not valid |
Table 14 VHT-MCS parameters (40 MHz, NSS=1)
VHT-MCS index |
Modulation |
Data rate (Mbps) |
800ns GI |
400ns GI |
0 |
BPSK |
13.5 |
15.0 |
1 |
QPSK |
27.0 |
30.0 |
2 |
QPSK |
40.5 |
45.0 |
3 |
16-QAM |
54.0 |
60.0 |
4 |
16-QAM |
81.0 |
90.0 |
5 |
64-QAM |
108.0 |
120.0 |
6 |
64-QAM |
121.5 |
135.0 |
7 |
64-QAM |
135.0 |
150.0 |
8 |
256-QAM |
162.0 |
180.0 |
9 |
256-QAM |
180.0 |
200.0 |
Table 15 VHT-MCS parameters (40 MHz, NSS=2)
VHT-MCS index |
Modulation |
Data rate (Mbps) |
800ns GI |
400ns GI |
0 |
BPSK |
27.0 |
30.0 |
1 |
QPSK |
54.0 |
60.0 |
2 |
QPSK |
81.0 |
90.0 |
3 |
16-QAM |
108.0 |
120.0 |
4 |
16-QAM |
162.0 |
180.0 |
5 |
64-QAM |
216.0 |
240.0 |
6 |
64-QAM |
243.0 |
270.0 |
7 |
64-QAM |
270.0 |
300.0 |
8 |
256-QAM |
324.0 |
360.0 |
9 |
256-QAM |
360.0 |
400.0 |
Table 16 VHT-MCS parameters (40 MHz, NSS=3)
VHT-MCS index |
Modulation |
Data rate (Mbps) |
800ns GI |
400ns GI |
0 |
BPSK |
40.5 |
45.0 |
1 |
QPSK |
81.0 |
90.0 |
2 |
QPSK |
121.5 |
135.0 |
3 |
16-QAM |
162.0 |
180.0 |
4 |
16-QAM |
243.0 |
270.0 |
5 |
64-QAM |
324.0 |
360.0 |
6 |
64-QAM |
364.5 |
405.0 |
7 |
64-QAM |
405.0 |
450.0 |
8 |
256-QAM |
486.0 |
540.0 |
9 |
256-QAM |
540.0 |
600.0 |
Table 17 VHT-MCS parameters(40 MHz, NSS=4)
VHT-MCS index |
Modulation |
Data rate (Mbps) |
800ns GI |
400ns GI |
0 |
BPSK |
54.0 |
60.0 |
1 |
QPSK |
108.0 |
120.0 |
2 |
QPSK |
162.0 |
180.0 |
3 |
16-QAM |
216.0 |
240.0 |
4 |
16-QAM |
324.0 |
360.0 |
5 |
64-QAM |
432.0 |
480.0 |
6 |
64-QAM |
486.0 |
540.0 |
7 |
64-QAM |
540.0 |
600.0 |
8 |
256-QAM |
648.0 |
720.0 |
9 |
256-QAM |
720.0 |
800.0 |
Table 18 VHT-MCS parameters (80 MHz, NSS=1)
VHT-MCS index |
Modulation |
Data rate (Mbps) |
800ns GI |
400ns GI |
0 |
BPSK |
29.3 |
32.5 |
1 |
QPSK |
58.5 |
65.0 |
2 |
QPSK |
87.8 |
97.5 |
3 |
16-QAM |
117.0 |
130.0 |
4 |
16-QAM |
175.5 |
195.0 |
5 |
64-QAM |
234.0 |
260.0 |
6 |
64-QAM |
263.0 |
292.5 |
7 |
64-QAM |
292.5 |
325.0 |
8 |
256-QAM |
351.0 |
390.0 |
9 |
256-QAM |
390.0 |
433.3 |
Table 19 VHT-MCS parameters (80 MHz, NSS=2)
VHT-MCS index |
Modulation |
Data rate (Mbps) |
800ns GI |
400ns GI |
0 |
BPSK |
58.5 |
65.0 |
1 |
QPSK |
117.0 |
130.0 |
2 |
QPSK |
175.5 |
195.0 |
3 |
16-QAM |
234.0 |
260.0 |
4 |
16-QAM |
351.0 |
390.0 |
5 |
64-QAM |
468.0 |
520.0 |
6 |
64-QAM |
526.5 |
585.0 |
7 |
64-QAM |
585.0 |
650.0 |
8 |
256-QAM |
702.0 |
780.0 |
9 |
256-QAM |
780.0 |
866.7 |
Table 20 VHT-MCS parameters (80 MHz, NSS=3)
VHT-MCS index |
Modulation |
Data rate (Mbps) |
800ns GI |
400ns GI |
0 |
BPSK |
87.8 |
97.5 |
1 |
QPSK |
175.5 |
195.0 |
2 |
QPSK |
263.3 |
292.5 |
3 |
16-QAM |
351.0 |
390.0 |
4 |
16-QAM |
526.5 |
585.0 |
5 |
64-QAM |
702.0 |
780.0 |
6 |
Not valid |
7 |
64-QAM |
877.5 |
975.0 |
8 |
256-QAM |
1053.0 |
1170.0 |
9 |
256-QAM |
1170.0 |
1300.0 |
Table 21 VHT-MCS parameters (80 MHz, NSS=4)
VHT-MCS index |
Modulation |
Data rate (Mbps) |
800ns GI |
400ns GI |
0 |
BPSK |
117.0 |
130.0 |
1 |
QPSK |
234.0 |
260.0 |
2 |
QPSK |
351.0 |
390.0 |
3 |
16-QAM |
468.0 |
520.0 |
4 |
16-QAM |
702.0 |
780.0 |
5 |
64-QAM |
936.0 |
1040.0 |
6 |
64-QAM |
1053.0 |
1170.0 |
7 |
64-QAM |
1170.0 |
1300.0 |
8 |
256-QAM |
1404.0 |
1560.0 |
9 |
256-QAM |
1560.0 |
1733.3 |
NOTE: · For all the VHT-MCS data rate tables, see IEEE 802.11ac-2013. · Support for VHT-MCS indexes depends on the AP model. |
For information about MSR routers that can offer WLAN services as fat APs, see "Compatibility of hardware and AP functionality."
You can configure radios by using the following methods:
· Configure radios one by one in radio view.
· Assign APs to an AP group and configure the radios of the AP group in an AP group's radio view.
· Configure all radios in global configuration view.
For a radio, the settings made in these views for the same parameter take effect in descending order of radio view, an AP group's radio view, and global configuration view.
In a large-sized network, configure AP groups instead of any single AP as a best practice.
To configure radio management, perform the following tasks:
· Enabling or disabling a radio interface
· Enabling a radio to disable wireless services as scheduled
· Configuring basic radio functions
· (Optional.) Configuring 802.11n functions
· (Optional.) Configuring 802.11ac functions
· (Optional.) Configuring the smart antenna feature
· (Optional.) Configuring error packet ratio optimization and retransmission ratio optimization
· (Optional.) Disabling radar avoidance
1. Enter system view.
2. Enter radio interface view.
interface wlan-radio interface-number
3. Enable or disable the radio interface.
¡ Enable
the radio interface:
undo
shutdown
¡ Disable the radio interface:
shutdown
By default, a radio interface is enabled.
5. Enter AP view.
wlan ap ap-name
6. Enter radio view.
radio radio-id
7. Enable the radio to disable wireless services as scheduled.
radio scheduled-shutdown time-range range-name
By default, this feature is not configured.
Specifying a radio mode
Available radio functions vary by radio mode:
· For 802.11a, 802.11b, and 802.11g radios, you can configure basic radio functions.
· For 802.11an and 802.11gn radios, you can configure basic radio functions and 802.11n functions.
· For 802.11ac and 802.11gac radios, you can configure basic radio functions, 802.11n functions, and 802.11ac functions.
Support for channels and transmit powers depends on the radio mode. When you change the mode of a radio, the system automatically adjusts the channel and power parameters for the radio.
3. Specify a radio mode.
type { dot11a | dot11ac | dot11an | dot11ax | dot11b | dot11g | dot11gac | dot11gax | dot11gn }
The default setting for this command varies by AP model.
Specifying a working channel
Perform this task to reduce interference from both wireless and non-wireless devices. You can manually specify a channel or configure the system to automatically select a channel for a radio.
When radar signals are detected on the working channel of a radio, one of the following events occurs:
· If the channel is automatically assigned, the radio changes its channel.
· If the channel is manually specified, the radio changes its channel, and switches back to the specified channel after 30 minutes and then starts the quiet timer. If no radar signals are detected within the quiet time, the radio starts to use the channel. If radar signals are detected within the quiet time, the radio changes it channel again.
3. Specify a working channel.
channel { channel-number | auto }
The default setting for this command varies by device model.
Setting the antenna type
You can perform this task to specify the antenna type of an H3C antenna or a third-party antenna.
· When an H3C antenna is used, make sure the antenna type is consistent with the actual type of the antenna used on the AP.
· When a third-party antenna is used, make sure the antenna gain is the actual gain of the third-party antenna.
3. Set the antenna type.
antenna type { antenna-type | custom gain custom-gain }
The default antenna type for an AP varies by device model.
The transmit power range supported by a radio varies by region code, channel, AP model, radio mode, antenna type, and bandwidth mode. If you change these attributes for a radio after you set the maximum transmit power, the configured maximum transmit power might be out of the supported transmit power range. If this happens, the system automatically adjusts the maximum transmit power to a valid value.
If you enable power lock, the locked power becomes the maximum transmit power. For more information about power lock, see "Configuring power lock."
3. Set the maximum transmit power.
max-power radio-power
By default, a radio interface uses the supported maximum transmit power.
If you enable power lock, the current power is locked and becomes the maximum transmit power. The locked power still takes effect after the AC restarts.
If you enable power lock, the current power is locked and becomes the maximum transmit power. The locked power still takes effect after the AP restarts.
If a radio enabled with power lock switches to a new channel that provides lower power than the locked power, the maximum power supported by the new channel takes effect.
3. Configure power lock.
power-lock { disable | enable }
By default, power lock is disabled.
Setting transmission rates
Transmission rates are classified into the following types:
· Prohibited rates—Rates that cannot be used by an AP.
· Mandatory rates—Rates that the clients must support to associate with an AP.
· Supported rates—Rates that an AP supports. After a client associates with an AP, the client can select a higher rate from the supported rates to communicate with the AP. The AP automatically decreases or increases the transmission rate as interference signals, retransmission packets, or dropped packets increase or decrease.
· Multicast rate—Rate at which an AP transmits multicasts and broadcasts. The multicast rate must be selected from the mandatory rates.
3. Set the transmission rates for the radio.
rate { multicast { auto | rate-value } | { disabled | mandatory | supported } rate-value }
The default settings are as follows:
¡ 802.11a/802.11an/802.11ac/802.11ax radios:
- Prohibited rates—None.
- Mandatory rates—6, 12, and 24.
- Multicast rate—Selected from the mandatory rates.
- Supported rates—9, 18, 36, 48, and 54.
¡ 802.11b radios:
- Mandatory rates—1 and 2.
- Supported rates—5.5, and 11.
¡ 802.11g/802.11gn/802.11gac/802.11gax radios:
- Mandatory rates—1, 2, 5.5, and 11.
- Supported rates—6, 9, 12, 18, 24, 36, 48, and 54.
Setting the beacon interval
Perform this task to enable an AP to broadcast beacon frames at the specified interval. A short beacon interval enables clients to easily detect the AP but consumes more system resources.
3. Set the beacon interval.
beacon-interval interval
By default, the beacon interval is 100 TU.
Setting the DTIM interval
An AP periodically broadcasts a beacon compliant with the Delivery Traffic Indication Map (DTIM). After the AP broadcasts the beacon, it sends buffered broadcast and multicast frames based on the value of the DTIM interval. For example, if you set the DTIM interval to 5, the AP sends buffered broadcast and multicast frames every five beacon frames.
3. Set the DTIM interval.
dtim counter
By default, the DTIM interval is 1.
Wireless devices operate in half duplex mode and cannot send and receive data simultaneously. To avoid collision, 802.11 allows wireless devices to send Request to Send (RTS) or Clear to Send (CTS) packets before they transmit data.
You can specify either of the following collision avoidance modes for an AP:
· RTS/CTS—An AP sends an RTS packet to a client before sending data to the client. After receiving the RTS packet, the client sends a CTS packet to the AP. The AP begins to send data after receiving the CTS packet, and other devices that detect the RTS or CTS packet do not send data within a specific time period.
· CTS-to-self—An AP sends a CTS packet with its own MAC address as the destination MAC address before sending data to a client. After receiving the CTS-to-self packet, the AP begins to send data, and other devices that detect the CTS-to-self packet do not send data within a specific time period. The CTS-to-self mode reduces the transmission time but might result in hidden node problems.
To ensure wireless resource efficiency, collision avoidance takes effect only when the following conditions are met:
· The size of the packets to be sent is larger than the RTS threshold 2346 bytes.
· 802.11g or 802.11n protection is enabled. For more information about 802.11g or 802.11n protection, see "Configuring 802.11g protection" and "Configuring 802.11n protection."
3. Specify a collision avoidance mode.
protection-mode { cts-to-self | rts-cts }
By default, the CTS-to-self mode is used.
Setting the RTS threshold
802.11 allows wireless devices to send Request to Send (RTS) or Clear to Send (CTS) packets to avoid collision. However, excessive RTS and CTS packets consume system resources and reduce transmission efficiency. You can set an RTS threshold to resolve this problem. The system performs collision avoidance only for packets larger than the RTS threshold.
In a low-density WLAN, increase the RTS threshold to improve the network throughput and efficiency. In a high-density WLAN, decrease the RTS threshold to reduce collisions in the network.
3. Set the RTS threshold.
protection-threshold size
By default, the RTS threshold is 2346 bytes.
Frames larger than the fragmentation threshold are fragmented before transmission. Frames smaller than the fragmentation threshold are transmitted without fragmentation.
When a fragment is not received, only this fragment rather than the whole frame is retransmitted.
In a WLAN with great interference, decrease the fragmentation threshold and set the MTU (ip mtu command) of packets sent over the radio to be lower than the fragmentation threshold. This improves the network throughput and efficiency.
3. Set the fragmentation threshold.
fragment-threshold size
By default, the fragmentation threshold is 2346 bytes.
In wireless networks, unicast packets require acknowledgements. If a radio fails to receive the acknowledgement for a packet, it retransmits the packet.
You can set hardware retransmission limits for both large frames and small frames. Transmitting large frames requires a large buffer size and a long time because the system performs collision avoidance for large frames before transmission. Therefore, you can set a small hardware retransmission limit for large frames to save system buffer and transmission time.
3. Set the hardware retransmission limit for small frames.
short-retry threshold count
By default, the hardware retransmission limit is 7 for small frames.
4. Set the hardware retransmission limit for large frames.
long-retry threshold count
By default, the hardware retransmission limit is 4 for large frames.
When the maximum number of clients is reached on an AP, the AP stops accepting new clients and the SSID will be automatically hidden. This prevents the AP from being overloaded.
3. Set the maximum number of clients that can associate with the AP.
client max-count max-number
By default, no limit is set for the number of clients that can associate with an AP.
To prevent low-speed 802.11b clients from decreasing wireless data transmission performance, you can enable an 802.11g, 802.11gac, or 802.11gn radio to disable access services for 802.11b clients.
3. Configure access services for 802.11b clients.
client dot11b-forbidden { disable | enable }
By default, the AP accepts 802.11b clients.
When both 802.11b and 802.11g clients exist in a WLAN, transmission collision might occur because they use different modulation modes. 802.11g protection can avoid such collision. It enables 802.11g, 802.11n, 802.11ac, or 802.11ax devices to send RTS/CTS or CTS-to-self packets to inform 802.11b clients to defer access to the medium. For more information about RTS/CTS or CTS-to-self, see "Specifying a collision avoidance mode."
802.11g, 802.11n, or 802.11ac devices send RTS/CTS or CTS-to-self packets before sending data only when 802.11b signals are detected on the channel.
802.11g protection automatically takes effect when 802.11b clients associate with an 802.11g, 802.11n (2.4 GHz), 802.11gac, or 802.11gax AP.
This feature is applicable only to 802.11g, 802.11n (2.4 GHz), 802.11gac, and 802.11gax radios.
3. Configure 802.11g protection.
dot11g protection { disable | enable }
By default, 802.11g protection is disabled.
Configuring ANI
Adaptive Noise Immunity (ANI) enables the device to adjust the anti-noise level as required by the environment to reduce interference.
3. Configure ANI.
ani { disable | enable }
By default, ANI is enabled.
Setting the preamble type
A preamble is a set of bits in a packet header to synchronize transmission signals between sender and receiver. A short preamble improves network performance and a long preamble ensures compatibility with wireless devices using long preambles.
This feature is applicable only to 802.11b, 802.11g, and 802.11gn radios.
3. Set the preamble type.
preamble { long | short }
By default, a short preamble is used.
The strength of wireless signals gradually degrades as the transmission distance increases. The maximum transmission distance of wireless signals depends on the surrounding environment and on whether an external antenna is used.
· Without an external antenna—About 300 meters (984.25 ft).
· With an external antenna—30 km (18.64 miles) to 50 km (31.07 miles).
· In an area with obstacles—35 m (114.83 ft) to 50 m (164.04 ft).
3. Set the maximum transmission distance.
distance distance
By default, the maximum transmission distance is 1 km (0.62 miles).
This feature is used for network testing only. Do not use it under any other circumstances.
The feature enables continuous data packet sending at the specified rate. When the feature is enabled, do not perform any other operations except for changing the transmit rate.
For an 802.11a, 802.11b, or 802.11g radio, set the transmit rate. For an 802.11n radio, set the transmit rate or MCS index. For an 802.11ac or 802.11gac radio, set the transmit rate, MCS index, or VHT-MCS index.
3. Enable the continuous mode for the radio interface.
continuous-mode { mcs mcs-index | nss nss-index vht-mcs vhtmcs-index | rate rate-value }
By default, the continuous mode is disabled.
This feature enables an AP to scan supported channels and display the channel usage after scanning. It takes about one second to scan a channel.
3. Perform on-demand channel usage measurement.
channel-usage measure
NOTE: · Support for 802.11n functions depends on the device model. · 802.11n functions are applicable only to 802.11an, 802.11gn, 802.11ac, and 802.11gac radios. |
A MAC Protocol Data Unit (MPDU) is a data frame in 802.11 format. MPDU aggregation aggregates multiple MPDUs into one aggregate MPDU (A-MPDU) to reduce additional information, ACK frames, and Physical Layer Convergence Procedure (PLCP) header overhead. This improves network throughput and channel efficiency.
All MPDUs in an A-MPDU must have the same QoS priority, source address, and destination address.
3. Configure the A-MPDU aggregation method.
a-mpdu { disable | enable }
By default, the A-MPDU aggregation method is enabled.
MSDU aggregation aggregates multiple MSDUs into one aggregate MSDU (A-MSDU) to reduce PLCP preamble, PLCP header, and MAC header overheads. This improves network throughput and frame forwarding efficiency.
All MSDUs in an A-MSDU must have the same QoS priority, source address, and destination address. When a device receives an A-MSDU, it restores the A-MSDU to multiple MSDUs for processing.
3. Configure the A-MSDU aggregation method.
a-msdu { disable | enable }
By default, the A-MSDU aggregation method is enabled.
Configuring short GI
802.11 OFDM fragments frames to data blocks for transmission. It uses GI to ensure that the data block transmissions do not interfere with each other and are immune to transmission delays.
The GI used by 802.11a/g and 802.11ax is 800 ns. 802.11n supports a short GI of 400 ns, which provides a 10% increase in data rate.
Both the 20 MHz and 40 MHz bandwidth modes support short GI.
3. Configure short GI.
short-gi { disable | enable }
By default, short GI is enabled.
Configuring LDPC
802.11n introduces the Low-Density Parity Check (LDPC) mechanism to increase the signal-to-noise ratio and enhance transmission quality. LDPC takes effect only when both ends support LDPC.
3. Configure LDPC.
ldpc { disable | enable }
By default, LDPC is enabled.
Configuring STBC
The Space-Time Block Coding (STBC) mechanism enhances the reliability of data transmission and does not require clients to have high transmission rates.
3. Configure STBC.
stbc { disable | enable }
By default, STBC is enabled.
Setting MCS indexes
802.11n clients use the rate corresponding to the MCS index to send unicast frames. 802.11a/b/g clients use the 802.11a/b/g rate to send unicast frames.
If you do not set a multicast MCS index, 802.11n clients and the AP use the 802.11a/b/g multicast rate to send multicast frames. If you set a multicast MCS index, one of following events occurs:
· The AP and clients use the rate corresponding to the multicast MCS index to send multicast frames if only 802.11n and 802.11ac clients exist.
· The AP and clients use the 802.11a/b/g multicast rate to send multicast frames if any 802.11a/b/g clients exist.
When you set the maximum mandatory or supported MCS index, you are specifying a range. For example, if you set the maximum mandatory MCS index to 5, rates corresponding to MCS indexes 0 through 5 are configured as 802.11n mandatory rates.
The multicast MCS index cannot be greater than the maximum mandatory MCS index.
The maximum supported MCS index cannot be smaller than the maximum mandatory MCS index.
3. Set the maximum mandatory MCS index.
dot11n mandatory maximum-mcs index
By default, no maximum mandatory MCS index is set.
4. Set the maximum supported MCS index.
dot11n support maximum-mcs index
By default, the maximum supported MCS index is 76.
5. Set the multicast MCS index.
dot11n multicast-mcs index
By default, no multicast MCS index is set.
To prevent low-speed 802.11a/b/g clients from decreasing wireless data transmission performance, you can enable the client dot11n-only feature for an AP to accept only 802.11n and 802.11ac clients.
3. Configure the client dot11n-only feature.
client dot11n-only { disable | enable }
By default, the client dot11n-only feature is disabled.
802.11n uses the channel structure of 802.11a/b/g, but it increases the number of data subchannels in each 20 MHz channel to 52. This improves data transmission rate.
802.11n binds two adjacent 20 MHz channels to form a 40 MHz channel (one primary channel and one secondary channel). This provides a simple way to double the data rate.
If the current channel of a radio does not support the specified bandwidth mode, the radio clears the channel configuration and selects another channel.
If the bandwidth mode is set to 40 MHz, the radio uses the 40 MHz bandwidth if two adjacent channels that can be bound together exist. If there are no adjacent channels that can be bound together, the radio uses the 20 MHz bandwidth.
3. Set the 802.11n bandwidth mode.
channel band-width { 20 | 40 [ auto-switch ] }
By default, the bandwidth mode is 40 MHz for 802.11an radios and 20 MHz for 802.11gn radios.
Only 802.11gn radios support the auto-switch keyword.
Specifying a MIMO mode
NOTE: The number of spatial streams supported by a radio varies by AP model. |
Multiple-input and multiple-output (MIMO) enables a radio to send and receive wireless signals through multiple spatial streams. This improves system capacity and spectrum usage without requiring higher bandwidth.
A radio can operate in one of the following MIMO modes:
· 1x1—Sends and receives wireless signals through one spatial stream.
· 2x2—Sends and receives wireless signals through two spatial streams.
· 3x3—Sends and receives wireless signals through three spatial streams.
· 4x4—Sends and receives wireless signals through four spatial streams.
· 5x5—Sends and receives wireless signals through five spatial streams.
· 6x6—Sends and receives wireless signals through six spatial streams.
· 7x7—Sends and receives wireless signals through seven spatial streams.
· 8x8—Sends and receives wireless signals through eight spatial streams.
3. Specify a MIMO mode.
mimo { 1x1 | 2x2 | 3x3 | 4x4 | 5x5 | 6x6 | 7x7 | 8x8 }
The default MIMO mode for a radio varies by device model.
Configuring energy saving
After you enable the energy-saving feature, the MIMO mode of a radio automatically changes to 1x1 if no clients associate with the radio and the radio is not enabled with WIPS.
3. Configure energy saving.
green-energy-management { disable | enable }
By default, energy saving is disabled.
When both 802.11n and non-802.11n clients exist in a WLAN, transmission collision might occur because they use different modulation modes.
802.11n devices send RTS/CTS or CTS-to-self packets before sending data only when non-802.11n signals are detected on the channel.
802.11n protection automatically takes effect when non-802.11n clients associate with an 802.11n, 802.11ac, or 802.11ax AP.
NOTE: 802.11n devices refer to 802.11n, 802.11ac, and 802.11ax devices. |
3. Configure 802.11n protection.
dot11n protection { disable | enable }
By default, 802.11n protection is disabled.
NOTE: · Support for 802.11ac depends on the device model. · 802.11ac functions are applicable only to 802.11ac and 802.11gac radios. |
Setting NSSs
If the AP supports an NSS, it supports all VHT-MCS indexes for the NSS. 802.11ac clients use the rate corresponding to the VHT-MCS index for the NSS to send unicast frames. Non-802.11ac clients use the 802.11a/b/g/n rate to send unicast frames.
If you do not set a multicast NSS, 802.11ac clients and the AP use the 802.11a/b/g/n multicast rate to send multicast frames. If you set a multicast NSS and specify a VHT-MCS index, the following situations occur:
· The AP and clients use the rate corresponding to the VHT-MCS index to send multicast frames if all clients are 802.11ac clients.
· The AP and clients use the 802.11a/b/g/n multicast rate to send multicast frames if any non-802.11ac clients exist.
The maximum mandatory NSS or supported NSS determines a range of 802.11 rates. For example, if the maximum mandatory NSS is 5, rates corresponding to VHT-MCS indexes for NSSs 1 through 5 will be 802.11ac mandatory rates.
The maximum supported NSS cannot be smaller than the maximum mandatory NSS and the multicast NSS cannot be greater than the maximum mandatory NSS.
3. Set the maximum mandatory NSS.
dot11ac mandatory maximum-nss nss-number
By default, no maximum mandatory NSS is set.
4. Set the maximum supported NSS.
dot11ac support maximum-nss nss-number
By default, the maximum supported NSS is 8.
5. Set the multicast NSS and specify a VHT-MCS index.
dot11ac multicast-nss nss-number vht-mcs index
By default, no multicast NSS is set.
To prevent low-speed 802.11a/b/g/n clients from decreasing wireless data transmission performance, you can enable the client dot11ac-only feature for an AP to accept only 802.11ac and 802.11ax clients.
3. Configure the client dot11ac-only feature.
client dot11ac-only { disable | enable }
By default, the client dot11ac-only feature is disabled.
802.11ac uses the channel structure of 802.11n and increases the maximum bandwidth from 40 MHz to 160 MHz. 802.11ac can bind two adjacent 20/40/80 MHz channels to form a 40/80/160 MHz channel.
The radio uses the specified 40/80/160 MHz bandwidth if adjacent channels can be bound to form a 40/80/160 channel. If adjacent channels cannot form a 40/80/160 channel, the radio uses the next available bandwidth less than the specified one.
For example, the bandwidth mode is set to 80 MHz. The radio uses the 80 MHz bandwidth if adjacent channels that can be bound together exist. If adjacent channels that can be bound to an 80 MHz channel do not exist, but two adjacent channels that can be bound to a 40 MHz channel exist, the 40 MHz bandwidth is used. If no adjacent channels that can be bound together exist, the radio uses the 20 MHz bandwidth.
When the bandwidth mode is set to 80+80 MHz, the radio uses the 160 MHz bandwidth if two adjacent 80 MHz channels that can be bound together exist. If a 160 MHz channel cannot be formed but two non-adjacent 80 MHz channels are available, the radio uses the two 80 MHz channels to achieve the 160 MHz bandwidth.
If the working channel is specified, you can specify the secondary 80 MHz channel for the 160 MHz or 80+80 MHz bandwidth mode. If no working channel is specified, the device automatically selects a secondary channel. The working channel forwards all packets and the secondary channel forwards only data packets.
Figure 1 802.11ac bandwidth modes
802.11gac supports only the 20 MHz and 40 MHz bandwidth modes.
3. Set the 802.11ac bandwidth mode:
channel band-width { 20 | 40 | 80 | 160 }
Execute this command in the view of a 5 GHz radio interface.
By default, the bandwidth mode is 80 MHz for 802.11ac radios.
4. Set the 802.11gac bandwidth mode:
Execute this command in the view of a 2.4 GHz radio interface.
By default, the bandwidth mode is 20 MHz for 802.11gac radios.
Configuring TxBF
NOTE: Support for this feature depends on the AP model. |
Transmit beamforming (TxBF) enables an AP to adjust transmitting parameters based on the channel information to focus RF signals on intended clients. This feature improves the RF signal quality. TxBF includes single-user TxBF and multi-user TxBF.
· Single-user TxBF—Single-user TxBF enables an AP to improve the signal to one intended client. Single-user TxBF is applicable to WLANs that have widely spread clients, poor network quality, and serious signal attenuation.
· Multi-user TxBF—Multi-user TxBF is part of 802.11ac Wave2. Multi-user TxBF enables an AP to focus different RF signals on their intended clients to reduce interference and transmission delay. This improves traffic throughput and bandwidth usage. Multi-user TxBF is applicable to WLANs that have a large number of clients and require high bandwidth usage and low transmission delay.
3. Configure single-user TxBF.
su-txbf { disable | enable }
By default, single-user TxBF is disabled.
4. Configure multi-user TxBF.
mu-txbf { disable | enable }
By default, multi-user TxBF is disabled.
Multi-user TxBF takes effect only when single-user TxBF is enabled.
NOTE: Support for this feature depends on the device model. |
This feature is applicable only to 802.11n and 802.11ac radios.
The smart antenna feature enables an AP to automatically adjust the antenna parameters based on the client location and channel information to improve signal quality and stability.
You can configure a radio to operate in one of the following smart antenna modes:
· Auto—Uses the high availability mode for audio and video packets, and uses the high throughput mode for other packets.
· High-availability—Applicable to WLANs that require stable bandwidth, this mode reduces noise and interference impacts, and provides guaranteed bandwidth for clients.
· High-throughput—Applicable to WLANs that require high performance, this mode enhances signal strength and association capability.
3. Configure the smart antenna feature.
Smart-antenna { disable | enable }
By default, the smart antenna feature is enabled.
4. Specify a smart antenna mode.
smart-antenna policy { auto | high-availability | high-throughput }
By default, the auto mode is used.
This feature enables the device to recalculate the error packet ratio and retransmission ratio by using the specified indexes to get smaller ratio values.
2. Set the index for optimizing the error packet ratio.
wlan error-frame optimization value
By default, the index for optimizing the error packet ratio is not set.
3. Set the index for optimizing the retransmission ratio.
wlan retransmit-frame optimization value
By default, the index for optimizing the retransmission ratio is not set.
Radar avoidance enables a radio to change its working channel or keep silent when radar signals are detected on the working channel, avoiding interference on radars. After 30 minutes, the radio switches back to the previous working channel or restarts transmission. If radar signals can still be detected, the radio changes its working channel or keeps silent again.
With radar avoidance disabled, radios continue to transmit or receive traffic on the working channels even if radar signals are detected on the channels.
Disable radar avoidance only when you perform device debugging.
3. Disable radar avoidance.
radar-detect disable
By default, radar avoidance is enabled.
Task |
Command |
Display client information. |
display wlan client [ interface interface-type interface-number | mac-address mac-address | service-template service-template-name ] [ verbose ] |
Display radio information. |
display wlan radio radio-id |
The parameters configured in this example are for reference only. To achieve the best performance, configure the parameters based on your actual network requirements.
As shown in Figure 2, set the radio mode, working channel, and maximum transmit power to 802.11b, channel 36, and 19 dBm, respectively.
# Enter radio interface view.
<AP> system-view
[AP] interface wlan-radio 1/0/1
# Set the radio mode to dot11b.
[AP-WLAN-Radio1/0/1] type dot11b
# Configure the radio to work on channel 36.
[AP-WLAN-Radio1/0/1] channel 36
# Set the maximum transmit power to 19 dBm.
[AP-WLAN-Radio1/0/1] max-power 19
# Verify that the online clients are 802.11b clients.
[AP-WLAN-Radio1/0/1] display wlan client verbose
Total number of clients: 1
MAC address : 000f-e265-6400
IPv4 address : 10.1.1.114
IPv6 address : 2001::1234:5678:0102:0304
Username : N/A
AID : 1
AP ID : 1
AP name : ap1
Radio ID : 1
SSID : office
BSSID : 0026-3e08-1150
VLAN ID : 1
Power save mode : Active
Wireless mode : 802.11b
Supported rates : 1, 2 Mbps
QoS mode : WMM
Listen interval : 10
RSSI : 62
Rx/Tx rate : 130/11
Authentication method : Open system
Security mode : PRE-RSNA
AKM mode : N/A
Cipher suite : N/A
User authentication mode : Bypass
Authorization ACL ID : 3001(Not effective)
Authorization user profile : N/A
Authorization CAR : N/A
Roam status : N/A
Key derivation : SHA1
PMF status : Enabled
Forward policy : N/A
Online time : 0hr 1min 13sec
FT status : Inactive
Example: Configuring 802.11n
As shown in Figure 3, specify the radio as an 802.11an radio, and enable the A-MSDU and A-MPDU aggregation methods on the radio.
<AP> system-view
# Set the radio mode to dot11an.
[AP-WLAN-Radio1/0/1] type dot11an
# Enable the A-MSDU and A-MPDU aggregation methods.
[AP-WLAN-Radio1/0/1] a-mpdu enable
[AP-WLAN-Radio1/0/1] a-msdu enable
# Enable the radio.
[AP-WLAN-Radio1/0/1] undo shutdown
# Display client information.
Username : N/A
AID : 1
AP ID : 1
AP name : ap1
Radio ID : 1
SSID : office
VLAN ID : 1
Wireless mode : 802.11an
QoS mode : WMM
RSSI : 62
Rx/Tx rate : 130/11
AKM mode : N/A
Cipher suite : N/A
Roam status : N/A
