- 17-High Availability Configuration Guide
- 01-Ethernet OAM configuration
- 02-CFD configuration
- 03-DLDP configuration
- 04-S-Trunk configuration
- 05-VRRP configuration
- 06-VSRP configuration
- 07-BFD configuration
- 08-Track configuration
- 09-Process placement configuration
- 10-Interface backup configuration
- 11-Interface collaboration configuration
- 12-Error code detection configuration
| 00-Preface | 110.22 KB |
Preface
This configuration guide describes high availability technologies and features available on the device for failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
