11-Layer 2—LAN Switching Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath F1000[F5000][VFW] Firewalls Series Command Reference(V7)-6W60011-Layer 2—LAN Switching Command Reference
06-LLDP commands
06-LLDP commands 344.04 KB
LLDP commands
display lldp local-information
Use display lldp local-information to display local LLDP information.
context-admin
context-operator
global: Displays the global local LLDP information.
interface interface-type interface-number: Specifies a port by its type and number.
If you do not specify any keywords or arguments, the command displays all local LLDP information, which includes the following:
·     The global LLDP information.
·     The LLDP information about the LLDP-enabled ports in up state.
# Display all local LLDP information.
<Sysname> display lldp local-information
 Chassis ID          : 00e0-fc00-5600
 System name         : Sysname
 System description  :
   H3C Comware Platform Software, Software Version 7.1.064, Ess 9628P07
   H3C SecPath F5080
   Copyright (c) 2004-2020 New H3C Technologies Co., Ltd. All rights reserved.
 System capabilities supported  : Bridge, Router, Customer Bridge, Service Bridge
 System capabilities enabled    : Bridge, Router, Service Bridge
 MED information:
 Device class               : Connectivity device
 MED inventory information of master board:
 HardwareRev                : Ver.C
 FirmwareRev                : Basic Version:  1.04
Extend Version:  1.04
 SoftwareRev                : Version 7.10
 SerialNum                  : 210235A1Y03300000011
 Manufacturer name          : H3C
 Model name                 : SecPath F5080
 Asset tracking identifier  : Unknown
LLDP local-information of port 52[GigabitEthernet1/0/3]:
 Port ID type       : Interface name
 Port ID            : GigabitEthernet1/0/3
 Port description   : GigabitEthernet1/0/3 Interface
 LLDP agent nearest-bridge management address:
 Management address type           : IPv4
 Management address                : 192.168.80.60
 Management address interface ID   : Unknown
 Management address OID            : 0
 LLDP agent nearest-nontpmr management address:
 Management address                : 192.168.80.61
 LLDP agent nearest-customer management address:
 Management address                : 192.168.80.62
 Link aggregation enabled   : Yes
 Aggregation port ID        : 52
 Auto-negotiation enabled   : Yes
 OperMau                    : Speed(1000)/Duplex(Full)
 Power port class           : PD
 PSE power supported        : NO
 PSE power enabled          : NO
 PSE pairs control ability  : NO
 Power pairs                : Signal
 Port power classification  : Class 0
 Maximum frame size         : 9216
 Transmit Tw                : 0 us
 Receive Tw                 : 0 us
 Fallback Tw                : 0 us
 Echo Transmit Tw           : 0 us
 Echo Receive Tw            : 0 us
 PoE PSE power source       : Primary
 Port PSE priority          : Critical
 Port available power value : 0.0 w
Chassis ID
Bridge MAC address of the device.
Supported capabilities:
·     Bridge—Switching is supported.
·     Router—Routing is supported.
·     Telephone—The local device can act as a telephone.
·     Customer Bridge—The customer bridge feature is supported.
·     Service Bridge—The service bridge feature is supported.
Enabled capabilities:
·     Bridge—Switching is enabled.
·     Router—Routing is enabled.
·     Customer Bridge—The customer bridge feature is enabled.
·     Service Bridge—The service bridge feature is enabled.
Device class
MED device class:
·     Connectivity device—Network device.
·     Class I—Normal terminal device. It requires the basic LLDP discovery services.
·     Class II—Media terminal device. It supports media streams, and can also act as a normal terminal device.
·     Class III—Communication terminal device. It supports the IP communication systems of end users, and can also act as a normal terminal device or media terminal device.
MED inventory information about the MPU.
HardwareRev
Hardware version.
FirmwareRev
Firmware version.
SoftwareRev
Software version.
SerialNum
Serial number.
Manufacturer name
Device manufacturer.
Model name
Device model.
Port ID type
Port ID type:
·     MAC address.
·     Interface name.
Port ID
Port ID, the value of which depends on the port ID type.
Numbering type of the interface identified by the management address.
Index of the interface identified by the management address.
Management address object ID.
Indicates whether link aggregation is supported on the port.
Indicates whether link aggregation is enabled on the port.
Aggregation port ID
Member port ID, which is 0 when link aggregation is disabled.
Indicates whether autonegotiation is supported on the port.
Indicates whether autonegotiation is enabled on the port.
OperMau
Speed and duplex state of the port.
Power port class
PoE port class:
·     PSE—Power sourcing equipment.
·     PD—Powered device.
PSE power supported
Indicates whether the device can operate as a PSE.
PSE power enabled
Indicates whether the device is operating as a PSE.
Indicates whether the pair selection ability is available.
Power pairs
Power supply mode:
·     Signal—Uses data pairs to supply power.
·     Spare—Uses spare pairs to supply power.
Power class of the PD:
·     Class 0.
·     Class 1.
·     Class 2.
·     Class 3.
·     Class 4.
Power type
Power supply type:
·     Type 1 PD.
·     Type 2 PD.
·     Type 1 PSE.
·     Type 2 PSE.
Power source
Power source:
·     When the power supply type is PSE, options are:
¡     Unknown—Unknown power supply.
¡     Primary—Primary power supply.
¡     Backup—Backup power supply.
¡     Reserved.
·     When the power supply type is PD, options are:
¡     PSE—PSE power supply.
¡     Local—Local power supply.
¡     PSE and local—PSE and local power supplies.
Power priority
·     Unknown.
·     Critical.
·     High.
·     Low.
PD requested power value
2-pair single-signature PD requested power in watts.
PSE allocated power value
2-pair single-signature PSE allocated power in watts.
PD requested power value mode A
4-pair dual-signature PD requested power in mode A, in watts.
PD requested power value mode B
4-pair dual-signature PD requested power in mode B, in watts.
PSE allocated power value alternative A
4-pair PSE allocated power value in mode A, in watts.
PSE allocated power value alternative B
4-pair PSE allocated power value in mode B, in watts.
PSE powering status
PSE powering status:
·     Reserved—Unknown powering status.
·     2-pair powering—2-pair powering mode.
·     4-pair powering single-signature PD—4-pair powering mode for a single-signature PD.
·     4-pair powering dual-signature PD—4-pair powering mode for a dual-signature PD.
PD powered status
PD powered status:
·     Reserved—Unknown powered status.
·     Powered single-signature PD—Powered status of a single-signature PD.
·     2-pair Powered dual-signature PD—Powered status of a dual-signature PD in 2-pair mode.
·     4-pair powered dual-signature PD—Powered status of a dual-signature PD in 4-pair mode.
PSE power pairs ext
PoE remote power supply mode:
·     Alternative A—PSE power supply in mode A.
·     Alternative B—PSE power supply in mode B.
·     Both Alternatives—PSE power supply in both mode A and mode B.
Dual-signature power class ext mode A
PSE power class for a dual-signature PD in mode A:
·     Reserved—Unknown power class.
·     Class 1.
·     Class 2.
·     Class 3.
·     Class 4.
·     Class 5.
·     Single-signature PD or 2-pair only PSE—A single-signature PD is connected or a 2-pair PSE power supply is used.
Dual-signature power class ext mode B
PSE power class for a dual-signature PD in mode B:
·     Class 1.
·     Class 2.
·     Class 3.
·     Class 4.
·     Class 5.
Power class ext
PSE power class when a single-signature PD is connected or a 2-pair PSE power supply is used. Options are:
·     Class 1.
·     Class 2.
·     Class 3.
·     Class 4.
·     Class 5.
·     Class 6.
·     Class 7.
·     Class 8.
·     Dual-signature PD—A dual-signature PD is connected.
Power type ext
Power supply type:
·     Type 3 PSE.
·     Type 4 PSE.
·     Type 3 single-signature PD.
·     Type 3 dual-signature PD.
·     Type 4 single-signature PD.
·     Type 4 dual-signature PD.
·     Reserved—Unknown power supply type.
PD load
Indicates whether a dual-signature PD is connected and isolation between mode A and mode B is required.
PSE maximum available power
PSE maximum output power.
Autoclass support
Indicates whether the PSE supports Autoclass.
Autoclass completed
Indicates whether the PSE has completed Autoclass.
Autoclass request
Indicates whether the PSE requests Autoclass.
PSE power source type:
·     Unknown—Unknown power supply.
·     Primary—Primary power supply.
·     Backup—Backup power supply.
PoE PD power source
PD power source type:
·     PSE—PSE power supply.
·     Local—Local power supply.
·     PSE and local—PSE and local power supplies.
Port PSE priority
PoE power supply priority of PSE ports:
·     Unknown.
·     Critical.
·     High.
·     Low.
Port PD priority
PoE power receiving priority of PD ports:
·     Unknown.
·     Critical.
·     High.
·     Low.
Available PoE power on PSE ports, or power needed on PD ports, in watts.
Transmit Tw
Sleep time of the local client, in μs.
Receive Tw
Sleep time of the peer client expected by the local client, in μs.
Fallback Tw
Candidate sleep time of the peer client expected by the local client, in μs.
Echo Transmit Tw
Sleep time of the peer client, in μs. This field displays zero when one of the following cases occurs:
·     The local client has not received the sleep time of the peer client.
·     The sleep time of the peer client is 0 μs.
Echo Receive Tw
Sleep time of the local client expected by the peer client, in μs. This field displays zero when one of the following cases occurs:
·     The local client has not received the expected sleep time from the peer client.
·     The sleep time of the local client expected by the peer client is 0 μs.
display lldp neighbor-information
Use display lldp neighbor-information to display the LLDP information received from the neighboring devices.
context-admin
context-operator
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify this option, the command displays the LLDP information that all ports receive from the neighboring devices.
agent: Specifies an agent type. If you do not specify an agent type, the command displays the LLDP information that all LLDP agents receive from the neighboring devices.
nearest-bridge: Specifies nearest bridge agents.
nearest-customer: Specifies nearest customer bridge agents.
nearest-nontpmr: Specifies nearest non-TPMR bridge agents.
verbose: Displays the detailed LLDP information that the local device receives from the neighboring devices. If you do not specify this keyword, the command displays the brief LLDP information that the local device receives from the neighboring devices.
list: Displays the LLDP information that the local device receives from the neighboring devices in the form of a list.
system-name system-name: Displays the LLDP information that the local device receives from a neighboring device specified by its system name. The system-name argument is a string of 1 to 255 characters. If you do not specify this option, the command displays the LLDP information that the local device receives from all neighboring devices in a list.
# Display detailed LLDP information that the nearest bridge agents on all ports received from the neighboring devices.
<Sysname> display lldp neighbor-information agent nearest-bridge verbose
LLDP neighbor-information of port 1[GigabitEthernet1/0/1]:
LLDP agent nearest-bridge:
 LLDP Neighbor index : 1
 Update time         : 0 days, 0 hours, 1 minutes, 1 seconds
 Chassis type        : MAC address
 Chassis ID          : 000f-0055-0002
 Port ID             : GigabitEthernet1/0/1
 Time to live        : 121
 Port description    : GigabitEthernet1/0/1 Interface
   H3C Comware Platform Software, Software Version 7.1.064, Alpha 7164
   H3C Simware32
 System capabilities enabled   : Bridge, Router, Customer Bridge
 Management address                : 192.168.1.55
 Port VLAN ID(PVID): 1
 Management VLAN ID  : 5
 PSE power supported        : Yes
 PSE power enabled          : Yes
 PSE pairs control ability  : Yes
 Maximum frame size         : 1500
 Transmit Tw                : 100 us
 Receive Tw                 : 90 us
 Fallback Tw                : 90 us
 Port PSE priority          : Low
 Port available power value : 2.2 w
# Display brief LLDP information that all LLDP agents received from all neighboring devices.
LLDP neighbor-information of port 52 [GigabitEthernet1/0/3]:
 LLDP neighbor index : 3
 ChassisID/subtype   : 0011-2233-4400/MAC address
 PortID/subtype      : 000c-29f5-c71f/MAC address
 Capabilities        : Bridge, Router, Customer Bridge
 LLDP neighbor index : 6
 PortID/subtype      : 000c-29f5-c715/MAC address
 Capabilities        : None
LLDP agent nearest-nontpmr:
 Capabilities        : None
# Display brief LLDP information that all LLDP agents received from the neighboring devices in a list.
Chassis ID : * -- --Nearest nontpmr bridge neighbor
             # -- --Nearest customer bridge neighbor
             Default -- -- Nearest bridge neighbor
Local Interface Chassis ID      Port ID                    System Name
GE1/0/1         000f-e25d-ee91  GigabitEthernet1/0/1       System1
LLDP information received through port 1.
Update time
Time when LLDP information about a neighboring device was last updated.
LLDP mac type
Type of the neighbor MAC address:
·     Nearest bridge.
·     Nearest customer bridge.
·     Nearest non-TPMR bridge.
Chassis type
Chassis ID type:
·     Chassis component.
·     Interface alias.
·     Port component.
·     MAC address.
·     Network address (ipv4).
·     Interface name.
·     Locally assigned—Locally-defined chassis type other than those listed above.
Chassis ID
ID that identifies the LLDP sending device, which can be a MAC address, a network address, an interface, or some other value, depending on the chassis ID type of the neighboring device.
Port ID type
Port ID type:
·     Interface alias.
·     Port component.
·     MAC address.
·     Interface name.
·     Agent circuit ID.
·     Locally assigned—Locally-defined port ID type other than those listed above.
Port ID
Value of the type of the port ID.
System name
System name of the neighboring device.
System description
System description of the neighboring device.
Capabilities supported on the neighboring device:
Capabilities enabled on the neighboring device:
Indicates whether link aggregation is supported.
Indicates whether link aggregation is enabled.
Aggregation port ID
OperMau
Speed and duplex state on the port.
Power port class
PoE port class:
PSE power supported
PSE power enabled
Power pairs
Power supply mode:
·     Class 0.
·     Class 1.
·     Class 2.
·     Class 3.
·     Class 4.
Power type
Power supply type:
·     Type 1 PD.
·     Type 2 PD.
·     Type 1 PSE.
·     Type 2 PSE.
Power source
Power source:
¡     Reserved.
·     When the power supply type is PD, options are::
Power priority
·     Unknown.
·     Critical.
·     High.
·     Low.
2-pair single-signature PD allocated power in watts.
PSE powering status
PD powered status
PD powered status:
PSE power pairs ext
·     Class 1.
·     Class 2.
·     Class 3.
·     Class 4.
·     Class 5.
·     Class 1.
·     Class 2.
·     Class 3.
·     Class 4.
·     Class 5.
Power class ext
PSE power class when a single-signature PD is connected or 2-pair PSE power supply is used. Options are:
·     Class 1.
·     Class 2.
·     Class 3.
·     Class 4.
·     Class 5.
·     Class 6.
·     Class 7.
·     Class 8.
Power type ext
Power supply type:
·     Type 3 PSE.
·     Type 4 PSE.
PD load
Autoclass support
Autoclass completed
Autoclass request
PoE PD power source
Port PSE priority
·     Unknown.
·     Critical.
·     High.
·     Low.
Port PD priority
·     Unknown.
·     Critical.
·     High.
·     Low.
HardwareRev
Hardware version.
FirmwareRev
Firmware version.
SoftwareRev
Software version.
SerialNum
Serial number.
Manufacturer name
Model name
Device model.
TLV type
Unknown basic TLV type.
TLV information
Information contained in the unknown basic TLV type.
Unknown organizationally-defined TLV
Unknown organizationally specific TLV.
TLV OUI
OUI of the unknown organizationally specific TLV.
TLV subtype
Unknown organizationally specific TLV subtype.
Index
Unknown organization index.
Capabilities
·     None—The neighboring device does not advertise this TLV.
Local Interface
Local port that receives the LLDP information.
Chassis ID : * -- -- Nearest nontpmr bridge neighbor
                    #-- -- Nearest customer bridge neighbor
Chassis ID flag:
·     An asterisk (*) indicates the nearest non-TPMR bridge neighbor.
·     A pound sign (#) indicates the nearest customer bridge neighbor.
Transmit Tw
Receive Tw
Expected sleep time for the peer client of the local client, in μs.
Fallback Tw
Candidate expected sleep time for the peer client of the local client, in μs.
Echo Transmit Tw
Echo Receive Tw
Expected sleep time for the local client of the peer client, in μs. This field displays zero when one of the following cases occurs:
·     The local client has not received the expected sleep time of the peer client.
·     The expected sleep time of the peer client is 0 μs.
display lldp statistics
Use display lldp statistics to display the global LLDP statistics or the LLDP statistics of a port.
context-admin
context-operator
global: Displays the global LLDP statistics.
agent: Specifies an LLDP agent type. If you do not specify an agent type, the command displays the statistics for all LLDP agents.
If you do not specify any keywords or arguments, the command displays the global LLDP statistics and the LLDP statistics of all ports.
# Display the global LLDP statistics and the LLDP statistics of all ports.
LLDP statistics global information:
LLDP neighbor information last change time:0 days, 0 hours, 4 minutes, 40 seconds
The number of LLDP neighbor information deleted  : 1
The number of LLDP neighbor information dropped  : 0
LLDP statistics information of port 1 [GigabitEthernet1/0/1]:
The number of LLDP frames transmitted            : 0
The number of LLDP frames received               : 0
The number of LLDP frames discarded              : 0
The number of LLDP error frames                  : 0
The number of LLDP TLVs discarded                : 0
The number of LLDP TLVs unrecognized             : 0
The number of CDP frames transmitted             : 0
The number of CDP frames received                : 0
The number of CDP frames discarded               : 0
The number of CDP error frames                   : 0
LLDP agent nearest-customer:
# Display the LLDP statistics for the nearest customer bridge agents on GigabitEthernet 1/0/1.
<Sysname> display lldp statistics interface gigabitethernet 1/0/1 agent nearest-customer
Global LLDP statistics.
Time when the neighbor information was last updated.
Number of times neighbor information was added.
Number of times neighbor information was removed.
Number of times neighbor information was dropped due to lack of available memory space.
display lldp status
Use display lldp status to display LLDP status.
context-admin
context-operator
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify this option, the command displays the global LLDP status and the LLDP status of all ports.
agent: Specifies an LLDP agent type. If you do not specify an agent type, the command displays the status information for all LLDP agents.
# Display the global LLDP status and the LLDP status of each port.
<Sysname> display lldp status
Global status of LLDP: Enable
The current number of LLDP neighbors: 5
Transmit interval              : 30s
Fast transmit interval         : 1s
Transmit max credit            : 5
Hold multiplier                : 4
Reinit delay                   : 2s
Trap interval                  : 5s
Fast start times               : 3
LLDP status information of port 1 [GigabitEthernet1/0/1]:
Port status of LLDP            : Enable
Admin status                   : TX_RX
Trap flag                      : No
MED trap flag                  : No
Polling interval               : 0s
Number of LLDP neighbors       : 5
Number of MED neighbors        : 2
Number of CDP neighbors        : 0
Number of sent optional TLV    : 12
Trap flag                      : No
MED trap flag                  : No
Trap flag                      : No
MED trap flag                  : No
Bridge mode of LLDP
LLDP bridge mode: service-bridge or customer-bridge.
Indicates whether LLDP is globally enabled.
Transmit interval
LLDP frame transmission interval.
Hold multiplier
TTL multiplier.
Reinit delay
LLDP reinitialization delay.
Transmit max credit
Token bucket size for sending LLDP frames.
Trap interval
Trap transmission interval.
Fast start times
Number of LLDP frames sent each time fast LLDP frame transmission is triggered.
Port 1
LLDP status of port 1.
Port status of LLDP
Indicates whether LLDP is enabled on the port.
Admin status
LLDP operating mode of the port:
·     TX_RX—The port can send and receive LLDP frames.
·     Rx_Only—The port can only receive LLDP frames.
·     Tx_Only—The port can only send LLDP frames.
·     Disable—The port cannot send or receive LLDP frames.
Trap Flag
Indicates whether trapping is enabled.
Polling interval
LLDP polling interval, which is 0 when LLDP polling is disabled.
Number of neighbors
Number of LLDP neighbors connecting to the port.
Number of MED neighbors connecting to the port.
Number of CDP neighbors connected to the port. This field is not supported in the current software version.
Number of optional TLVs contained in an LLDP frame sent through the port.
Number of unknown TLVs contained in a received LLDP frame.
display lldp tlv-config
Use display lldp tlv-config to display the types of advertisable optional LLDP TLVs of a port.
context-admin
context-operator
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify this option, the command displays the types of advertisable optional TLVs of all ports.
agent: Specifies an LLDP agent type. If you do not specify an agent type, the command displays the types of advertisable optional LLDP TLVs for all LLDP agents.
# Display the types of advertisable optional LLDP TLVs of GigabitEthernet 1/0/1.
<Sysname> display lldp tlv-config interface gigabitethernet 1/0/1
LLDP tlv-config of port 1[GigabitEthernet1/0/1]:
NAME                              STATUS    DEFAULT
Basic optional TLV:
 Port Description TLV             YES       YES
 System Name TLV                  YES       YES
 System Description TLV           YES       YES
 System Capabilities TLV          YES       YES
 Management Address TLV           YES       YES
IEEE 802.1 extend TLV:
 Port VLAN ID TLV                 NO        NO
 Port And Protocol VLAN ID TLV    NO        NO
 VLAN Name TLV                    NO        NO
 DCBX TLV                         NO        NO
 EVB TLV                          NO        NO
 Link Aggregation TLV             YES       YES
 Management VID TLV               NO        NO
IEEE 802.3 extend TLV:
 MAC-Physic TLV                   YES       YES
 Power via MDI TLV                YES       YES
 Maximum Frame Size TLV           YES       YES
LLDP-MED extend TLV:
 Network Policy TLV               NO        NO
 Location Identification TLV      NO        NO
 Extended Power via MDI TLV       YES       YES
 Inventory TLV                    YES       YES
NAME                              STATUS    DEFAULT
Basic optional TLV:
 Port Description TLV             NO        NO
 System Name TLV                  NO        NO
 System Description TLV           NO        NO
 System Capabilities TLV          NO        NO
 Management Address TLV           NO        NO
 VLAN Name TLV                    NO        NO
 DCBX TLV                         NO        NO
 EVB TLV                          NO        NO
 Link Aggregation TLV             NO        NO
 MAC-Physic TLV                   NO        NO
 Power via MDI TLV                NO        NO
 Maximum Frame Size TLV           NO        NO
 Extended Power via MDI TLV       NO        NO
 Inventory TLV                    NO        NO
NAME                              STATUS    DEFAULT
Basic optional TLV:
 VLAN Name TLV                    NO        NO
 DCBX TLV                         NO        NO
 EVB TLV                          NO        NO
 Inventory TLV                    NO        NO
Table 5 Command output
Advertisable optional TLVs of port 1.
NAME
TLV type.
STATUS
Indicates whether the type of TLV is sent through a port.
DEFAULT
Indicates whether the type of TLV is sent through a port by default.
Basic optional TLV
Basic optional TLVs:
·     Port Description TLV.
·     System Name TLV.
·     System Description TLV.
·     System Capabilities TLV.
·     Management Address TLV.
IEEE 802.1 extended TLV
IEEE 802.1 organizationally specific TLVs:
·     PVID TLV.
·     Port and protocol VLAN ID TLV.
·     VLAN name TLV.
·     DCBX TLV. DCBX TLVs are not supported in the current software version.
·     EVB TLV. EVB TLVs are not supported in the current software version.
·     Management VID TLV.
IEEE 802.3 extended TLV
IEEE 802.3 organizationally specific TLVs:
·     MAC-Physic TLV.
·     Power via MDI TLV.
·     Link aggregation TLV.
·     Maximum frame size TLV.
LLDP-MED extend TLV
LLDP-MED TLVs:
·     Capabilities TLV.
·     Network Policy TLV.
·     Extended Power-via-MDI TLV.
·     Location Identification TLV.
·     Inventory TLV.
Inventory TLV
Inventory TLVs:
·     Hardware Revision TLV.
·     Firmware Revision TLV.
·     Software Revision TLV.
·     Serial Number TLV.
·     Manufacturer Name TLV.
·     Model name TLV.
·     Asset ID TLV.
lldp admin-status
Use lldp admin-status to set the LLDP operating mode.
Use undo lldp admin-status to restore the default.
In Layer 2 or Layer 3 Ethernet interface view:
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] admin-status
In Layer 2/Layer 3 aggregate interface view:
undo lldp agent { nearest-customer | nearest-nontpmr } admin-status
The nearest bridge agent operates in TxRx mode, and the nearest customer bridge agent and nearest non-TPMR bridge agent operate in Disable mode.
context-admin
agent: Specifies an LLDP agent type. If you do not specify an agent type in Ethernet interface view, the command sets the operating mode for nearest bridge agents.
disable: Specifies the Disable mode. A port in this mode cannot send or receive LLDP frames.
rx: Specifies the Rx mode. A port in this mode can only receive LLDP frames.
tx: Specifies the Tx mode. A port in this mode can only send LLDP frames.
txrx: Specifies the TxRx mode. A port in this mode can send and receive LLDP frames.
# Set the LLDP operating mode to Rx for the nearest customer bridge agents on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp agent nearest-customer admin-status rx
lldp check-change-interval
Use lldp check-change-interval to enable LLDP polling and set the polling interval.
Use undo lldp check-change-interval to disable LLDP polling.
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] check-change-interval
undo lldp agent { nearest-customer | nearest-nontpmr } check-change-interval
context-admin
agent: Specifies an LLDP agent type. If you do not specify an agent type in Ethernet interface view, the command enables LLDP polling and sets the polling interval for nearest bridge agents.
interval: Sets the LLDP polling interval in the range of 1 to 30 seconds.
# Enable LLDP polling and set the polling interval to 30 seconds for the nearest customer bridge agents on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp agent nearest-customer check-change-interval 30
lldp enable
Use lldp enable to enable LLDP on a port.
Use undo lldp enable to disable LLDP on a port.
lldp enable
undo lldp enable
LLDP is enabled on a port.
context-admin
LLDP takes effect on a port only when LLDP is enabled both globally and on the port.
# Disable LLDP on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] undo lldp enable
lldp global enable
lldp encapsulation snap
Use lldp encapsulation snap to set the encapsulation format for LLDP frames to SNAP.
Use undo lldp encapsulation to restore the default.
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] encapsulation
undo lldp agent { nearest-customer | nearest-nontpmr } encapsulation
The encapsulation format for LLDP frames is Ethernet II.
context-admin
agent: Specifies an LLDP agent type. If you do not specify an agent type in Ethernet interface view, the command sets the LLDP frame encapsulation format for nearest bridge agents.
LLDP-CDP packets use only SNAP encapsulation.
# Set the encapsulation format for LLDP frames to SNAP on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp encapsulation snap
lldp fast-count
Use lldp fast-count to set the number of LLDP frames sent each time fast LLDP frame transmission is triggered.
Use undo lldp fast-count to restore the default.
lldp fast-count count
Four LLDP frames are sent each time fast LLDP frame transmission is triggered.
context-admin
count: Sets the number of LLDP frames sent each time fast LLDP frame transmission is triggered. The value range is 1 to 8.
# Configure the device to send five LLDP frames each time fast LLDP frame transmission is triggered.
[Sysname] lldp fast-count 5
lldp global enable
Use lldp global enable to enable LLDP globally.
Use undo lldp global enable to disable LLDP globally.
lldp global enable
LLDP is disabled globally.
context-admin
# Disable LLDP globally.
[Sysname] undo lldp global enable
lldp enable
lldp hold-multiplier
Use lldp hold-multiplier to set the TTL multiplier.
Use undo lldp hold-multiplier to restore the default.
lldp hold-multiplier value
The TTL multiplier is 4.
context-admin
value: Sets the TTL multiplier in the range of 2 to 10.
The TTL TLV carried in an LLDPDU determines how long the device information carried in the LLDPDU can be saved on a recipient device.
By setting the TTL multiplier, you can set the TTL of locally sent LLDP frames. The TTL is expressed by using the following formula:
TTL = Min (65535, (TTL multiplier × LLDP frame transmission interval + 1))
As the expression shows, the TTL can be up to 65535 seconds.
# Set the TTL multiplier to 6.
lldp timer tx-interval
lldp ignore-pvid-inconsistency
Use lldp ignore-pvid-inconsistency to disable LLDP PVID inconsistency check.
Use undo lldp ignore-pvid-inconsistency to enable LLDP PVID inconsistency check.
LLDP PVID inconsistency check is enabled.
context-admin
By default, when the system receives an LLDP packet, it compares the PVID value contained in packet with the PVID configured on the receiving interface. If the two PVIDs do not match, a log message will be printed to notify the user.
You can disable PVID inconsistency check if different PVIDs are required on a link.
# Disable LLDP PVID inconsistency check.
[Sysname] lldp ignore-pvid-inconsistency
lldp management-address
Use lldp management-address to enable the device to generate an ARP or ND entry after receiving an LLDP frame that carries a management address TLV.
Use undo lldp management-address to restore the default.
lldp management-address { arp-learning | nd-learning } [ vlan vlan-id ]
undo lldp management-address { arp-learning | nd-learning }
The device does not generate an ARP or ND entry after receiving an LLDP frame that carries a management address TLV.
context-admin
arp-learning: Generates an ARP entry if the received management address TLV contains an IPv4 address.
nd-learning: Generates an ND entry if the received management address TLV contains an IPv6 address.
vlan vlan-id: Specifies the Layer 3 Ethernet subinterface that terminates the specified VLAN as the output interface. The VLAN ID is in the range of 1 to 4094. If you do not specify a VLAN ID, the Layer 3 Ethernet interface is recorded as the output interface.
This command must be used together with the lldp source-mac vlan command for the device to use the MAC address of a Layer 3 Ethernet subinterface as the source MAC address of LLDP frames. This ensures that the LLDP neighbor can learn correct ARP or ND entries.
You can enable the device to generate both ARP entries and ND entries.
If you specify the vlan vlan-id option, the Layer 3 Ethernet subinterface that terminates the VLAN is recorded as the output interface in the generated ARP or ND entries. If the VLAN is not terminated by any Layer 3 Ethernet subinterface or the vlan vlan-id option is not specified, the Layer 3 Ethernet interface is recorded as the output interface. For more information about VLAN termination, see VLAN termination configuration in Layer 2—LAN Switching Configuration Guide.
# Configure GigabitEthernet 1/0/1 to generate an ARP entry after receiving an LLDP frame carrying an IPv4 management address TLV.
[Sysname-GigabitEthernet1/0/1] lldp management-address arp-learning
lldp management-address-format string
Use lldp management-address-format string to set the encoding format of the management address to string.
Use undo lldp management-address-format to restore the default.
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] management-address-format
undo lldp agent { nearest-customer | nearest-nontpmr } management-address-format
The encoding format of the management address is numeric.
context-admin
agent: Specifies an LLDP agent type. If you do not specify an agent type in Ethernet interface view, the command sets the encoding format of the management address for nearest bridge agents.
LLDP neighbors must use the same encoding format for the management address. If a neighbor encodes its management address in string format, set the encoding format of the management address to string on the connecting port. This guarantees normal communication with the neighbor.
# Set the encoding format of the management address to string for the nearest customer bridge agents on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp agent nearest-customer management-address-format string
lldp max-credit
Use lldp max-credit to set the token bucket size for sending LLDP frames.
Use undo lldp max-credit to restore the default.
lldp max-credit credit-value
The token bucket size for sending LLDP frames is 5.
context-admin
credit-value: Specifies the token bucket size for sending LLDP frames, in the range of 1 to 100.
# Set the token bucket size for sending LLDP frames to 10.
[Sysname] lldp max-credit 10
lldp mode
Use lldp mode to configure LLDP to operate in service bridge mode.
Use undo lldp mode to restore the default.
lldp mode service-bridge
undo lldp mode
LLDP operates in customer bridge mode.
context-admin
service-bridge: Specifies the service bridge mode.
The LLDP agent types supported by LLDP depend on the LLDP bridge mode:
·     Service bridge mode—LLDP supports nearest bridge agents and nearest non-TPMR bridge agents. LLDP processes the LLDP frames with destination MAC addresses for these agents and transparently transmits the LLDP frames with other destination MAC addresses in a VLAN.
·     Customer bridge mode—LLDP supports nearest bridge agents, nearest non-TPMR bridge agents, and nearest customer bridge agents. LLDP processes the LLDP frames with destination MAC addresses for these agents and transparently transmits the LLDP frames with other destination MAC addresses in a VLAN.
The bridge mode configuration takes effect only when LLDP is enabled globally. If LLDP is disabled globally, LLDP can only operate in customer bridge mode.
# Configure LLDP to operate in service bridge mode.
[Sysname] lldp mode service-bridge
lldp global enable
lldp notification med-topology-change enable
Use lldp notification med-topology-change enable to enable LLDP-MED trapping.
Use undo lldp notification med-topology-change enable to disable LLDP-MED trapping.
LLDP-MED trapping is disabled.
context-admin
# Enable LLDP-MED trapping on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp notification med-topology-change enable
lldp notification remote-change enable
Use lldp notification remote-change enable to enable LLDP trapping.
Use undo lldp notification remote-change enable to disable LLDP trapping.
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] notification remote-change enable
undo lldp agent { nearest-customer | nearest-nontpmr } notification remote-change enable
LLDP trapping is disabled.
context-admin
agent: Specifies an LLDP agent type. If you do not specify an agent type in Ethernet interface view, the command enables LLDP trapping for nearest bridge agents.
# Enable LLDP trapping for the nearest customer bridge agent on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp agent nearest-customer notification remote-change enable
Use lldp source-mac vlan to set the source MAC address of LLDP frames to the MAC address of a Layer 3 Ethernet subinterface.
Use undo lldp source-mac vlan to restore the default.
lldp source-mac vlan vlan-id
The source MAC address of LLDP frames is the MAC address of the egress interface.
context-admin
vlan vlan-id: Specifies the Layer 3 Ethernet subinterface that terminates the specified VLAN to provide the source MAC address for LLDP frames. The VLAN ID is in the range of 1 to 4094.
This command must be used together with the lldp management-address command for the device to use the MAC address of a Layer 3 Ethernet subinterface as the source MAC address of LLDP frames. This ensures that the LLDP neighbor can learn correct ARP or ND entries.
This command enables the device to use the MAC address of the Layer 3 Ethernet subinterface that terminates the specified VLAN as the source MAC address of outgoing LLDP frames. If the VLAN is not terminated by any Layer 3 Ethernet subinterface, the MAC address of the Layer 3 Ethernet interface is used as the source MAC address of outgoing LLDP frames. For more information about VLAN termination, see VLAN termination configuration in Layer 2—LAN Switching Configuration Guide.
# Set the source MAC address of LLDP frames to the MAC address of the Layer 3 Ethernet subinterface that terminates VLAN 4094.
[Sysname-GigabitEthernet1/0/1] lldp source-mac vlan 4094
lldp timer fast-interval
Use lldp timer fast-interval to set an interval for fast LLDP frame transmission.
Use undo lldp timer fast-interval to restore the default.
The interval for fast LLDP frame transmission is 1 second.
context-admin
interval: Sets an interval for fast LLDP frame transmission, in the range of 1 to 3600 seconds.
# Set the interval for fast LLDP frame transmission to 2 seconds.
[Sysname] lldp timer fast-interval 2
lldp timer notification-interval
Use lldp timer notification-interval to set the LLDP trap and LLDP-MED trap transmission interval.
Use undo lldp timer notification-interval to restore the default.
The LLDP trap and LLDP-MED trap transmission interval is 30 seconds.
context-admin
interval: Sets the LLDP trap and LLDP-MED trap transmission interval in the range of 5 to 3600 seconds.
# Set both the LLDP trap and LLDP-MED trap transmission interval to 8 seconds.
lldp timer reinit-delay
Use lldp timer reinit-delay to set the LLDP reinitialization delay.
Use undo lldp timer reinit-delay to restore the default.
lldp timer reinit-delay delay
The LLDP reinitialization delay is 2 seconds.
context-admin
delay: Sets the LLDP reinitialization delay in the range of 1 to 10 seconds.
# Set the LLDP reinitialization delay to 4 seconds.
lldp timer rx-timeout
Use lldp timer rx-timeout to set the timeout for receiving LLDP frames and enable the device to report no LLDP neighbor events.
Use undo lldp timer rx-timeout to restore the default.
lldp timer rx-timeout timeout
No timeout is set for receiving LLDP frames, and the device does not report no LLDP neighbor events.
context-admin
timeout: Sets the timeout for receiving LLDP frames, in the range of 30 to 32768 seconds.
This command can detect only directly connected LLDP neighbors.
When you use this command, make sure the following requirements are met:
·     LLDP is enabled.
·     Interfaces are physically up.
·     Nearest bridge agents operate in Rx or TxRx mode.
After this command is executed, the device restarts the timeout timer for receiving LLDP frames on an interface in one of the following situations:
·     When LLDP is enabled, the interface state changes from down to up.
·     When the interface is physically up, LLDP is enabled.
·     When LLDP is enabled and the interface is physically up, the mode of nearest bridge agents is changed from disabled to Rx or TxRx.
If an interface has not received any LLDP frames when the timeout timer expires, the device reports a no LLDP neighbor event to the NETCONF module.
To avoid misdetection, make sure the timeout for receiving LLDP frames is greater than the LLDP frame transmission interval.
# Set the timeout for receiving LLDP frames to 30 seconds.
[Sysname] lldp timer rx-timeout 30
Use lldp timer tx-interval to set the LLDP frame transmission interval.
Use undo lldp timer tx-interval to restore the default.
The LLDP frame transmission interval is 30 seconds.
context-admin
interval: Sets the LLDP frame transmission interval in the range of 5 to 32768 seconds.
# Set the LLDP frame transmission interval to 20 seconds.
lldp tlv-enable
Use lldp tlv-enable to configure the types of advertisable TLVs on a port.
Use undo lldp tlv-enable to disable the advertising of the specified types of TLVs on a port.
In Layer 2 Ethernet interface view:
·     For nearest bridge agents:
lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation | protocol-vlan-id [ vlan-id ] | vlan-name [ vlan-id ] | management-vid [ mvlan-id ] } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | network-policy [ vlan-id ] | power-over-ethernet | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } } }
undo lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation | protocol-vlan-id | vlan-name | management-vid } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | network-policy [ vlan-id ] | power-over-ethernet | location-id } }
·     For nearest non-TPMR bridge agents:
lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation } }
undo lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation } }
undo lldp tlv-enable dot1-tlv { protocol-vlan-id | vlan-name | management-vid }
·     For nearest customer bridge agents:
lldp agent nearest-customer tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation } }
undo lldp agent nearest-customer tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation } }
In Layer 3 Ethernet interface view:
lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address | interface loopback interface-number ] } | dot1-tlv { all | link-aggregation } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | power-over-ethernet | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } } }
lldp agent { nearest-nontpmr | nearest-customer } tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | link-aggregation } }
undo lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address | interface loopback interface-number ] } | dot1-tlv { all | link-aggregation } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | power-over-ethernet | location-id } }
undo lldp agent { nearest-nontpmr | nearest-customer } tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | link-aggregation } }
In Layer 2 aggregate interface view:
lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | management-address-tlv [ ipv6 ] [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id } }
undo lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | management-address-tlv [ ipv6 ] [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id } }
undo lldp agent nearest-customer tlv-enable { basic-tlv { all | management-address-tlv [ ipv6 ] [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id } }
In Layer 3 aggregate interface view:
lldp agent { nearest-customer | nearest-nontpmr } tlv-enable basic-tlv { all | management-address-tlv [ ipv6 ] [ ip-address ] | port-description | system-capability | system-description | system-name }
undo lldp agent { nearest-customer | nearest-nontpmr } tlv-enable basic-tlv { all | management-address-tlv [ ipv6 ] [ ip-address ] | port-description | system-capability | system-description | system-name }
On Layer 2 Ethernet interfaces:
·     Nearest bridge agents can advertise all types of LLDP TLVs except the following types:
¡     Location identification TLVs.
¡     Port and protocol VLAN ID TLVs.
¡     VLAN name TLVs.
¡     Management VLAN ID TLVs.
·     Nearest customer bridge agents can advertise basic TLVs and IEEE 802.1 organizationally specific TLVs.
On Layer 3 Ethernet interfaces:
·     Nearest bridge agents can advertise all types of LLDP TLVs except network policy TLVs. Among all the 802.1 organizationally specific TLVs, only the link aggregation TLV is supported.
·     Nearest non-TPMR bridge agents do not advertise TLVs.
·     Nearest customer bridge agents can advertise basic TLVs and IEEE 802.1 organizationally specific TLVs (only link aggregation TLV is supported).
On Layer 2 aggregate interfaces:
·     Nearest non-TPMR bridge agents do not advertise any TLVs.
·     Nearest customer bridge agents can advertise basic TLVs and IEEE 802.1 organizationally specific TLVs. Among the IEEE 802.1 organizationally specific TLVs, only port and protocol VLAN ID TLVs, VLAN name TLVs, and management VLAN ID TLVs are supported.
On Layer 3 aggregate interfaces:
·     Nearest customer bridge agents can advertise only basic TLVs.
context-admin
agent: Specifies an LLDP agent type. If you do not specify an agent type in Ethernet interface view, the command configures the types of advertisable TLVs for nearest bridge agents.
all: Advertises all TLVs of the specified type. This keyword enables the interface to advertise following TLVs:
·     All basic LLDP TLVs if the all keyword is specified for basic-tlv.
·     All IEEE 802.1 organizationally specific LLDP TLVs if the all keyword is specified for dot1-tlv.
·     All IEEE 802.3 organizationally specific LLDP TLVs if the all keyword is specified for dot3-tlv.
·     All LLDP-MED TLVs except location identification TLVs if the all keyword is specified for med-tlv.
basic-tlv: Advertises basic LLDP TLVs.
management-address-tlv [ ipv6 ] [ ip-address | interface loopback interface-number ]: Advertises management address TLVs. The ipv6 keyword indicates that the management address to be advertised is in IPv6 format. The ip-address argument specifies the management address to be advertised. The interface loopback interface-number option specifies the management address as the IP address of a loopback interface specified by its number. By default, the following rules apply:
·     When you execute the lldp tlv-enable command:
¡     For a Layer 2 Ethernet or aggregate interface, the IPv4 or IPv6 address of the VLAN interface that meets the following requirements will be advertised as the management address:
-     In up state.
-     The corresponding VLAN ID is the lowest among the VLANs permitted on the interface.
If you specify the ipv6 keyword, the IPv6 address of the VLAN interface will be advertised. If you do not specify the ipv6 keyword, the IPv4 address of the VLAN interface will be advertised.
If none of the VLAN interfaces of the permitted VLANs is assigned an IPv4 or IPv6 address or all VLAN interfaces are down, the MAC address of the interface will be advertised.
¡     For a Layer 3 Ethernet interface, the IPv4 or IPv6 address of the interface will be advertised when the following conditions exist:
-     The ip-address argument is not configured.
-     The specified loopback interface does not have an IPv4 or IPv6 address, or the specified loopback interface does not exist.
If you specify the ipv6 keyword, the IPv6 address of the interface will be advertised. If you do not specify the ipv6 keyword, the IPv4 address of the interface will be advertised.
If the interface does not have an IPv4 or IPv6 address, the MAC address of the interface will be advertised.
¡     For a Layer 3 aggregate interface, the IPv4 or IPv6 address of the interface will be advertised when the ip-address argument is not configured.
·     When you execute the undo lldp tlv-enable command:
¡     For a Layer 2/Layer 3 Ethernet interface or Layer 2/Layer 3 aggregate interface:
-     If you do not specify ip-address, ipv6, or interface loopback interface-number, the interface does not advertise any management address TLVs.
-     If you specify ip-address, ipv6, or interface loopback interface-number, the interface advertises the default management address TLVs.
port-description: Advertises port description TLVs.
system-capability: Advertises system capabilities TLVs.
system-description: Advertises system description TLVs.
system-name: Advertises system name TLVs.
dot1-tlv: Advertises IEEE 802.1 organizationally specific LLDP TLVs.
port-vlan-id: Advertises port VLAN ID TLVs.
protocol-vlan-id [ vlan-id ]: Advertises port and protocol VLAN ID TLVs. The vlan-id argument specifies a VLAN ID in the TLVs to be advertised. The VLAN ID is in the range of 1 to 4094, and the default is the lowest VLAN ID on the port.
vlan-name [ vlan-id ]: Advertises VLAN name TLVs. The vlan-id argument specifies a VLAN ID in the TLVs to be advertised. The VLAN ID is in the range of 1 to 4094, and the default is the lowest VLAN ID on the port. If you do not specify a VLAN ID and the port is not assigned to any VLAN, the PVID of the port is advertised.
management-vid [ mvlan-id ]: Advertises management VLAN ID TLVs. The mvlan-id argument specifies a management VLAN ID in the TLVs to be advertised. The management VLAN ID is in the range of 1 to 4094. If you do not specify this option, the value 0 is advertised, which means that the LLDP agent is not configured with a management VLAN ID.
link-aggregation: Advertises link aggregation TLVs.
dot3-tlv: Advertises IEEE 802.3 organizationally specific LLDP TLVs.
mac-physic: Advertises MAC/PHY configuration/status TLVs.
max-frame-size: Advertises maximum frame size TLVs.
power: Advertises power in MDI TLVs and power stateful control TLVs.
med-tlv: Advertises LLDP-MED TLVs.
capability: Advertises LLDP-MED capabilities TLVs.
inventory: Advertises the following TLVs: hardware revision, firmware revision, software revision, serial number, manufacturer name, model name, and asset ID.
location-id: Advertises location identification TLVs.
civic-address: Inserts the typical address information about the network device in location identification TLVs .
device-type: Sets a device type value in the range of 0 to 2:
·     Value 0 specifies a DHCP server.
·     Value 1 specifies a network device.
·     Value 2 specifies an LLDP-MED endpoint.
country-code: Sets a country code defined in ISO 3166.
{ ca-type ca-value }&<1-10>: Configures address information. ca-type represents the address information type in the range of 0 to 255. ca-value represents address information, a string of 1 to 250 characters. &<1-10> indicates that you can specify up to 10 ca-type ca-value pairs.
elin-address: Inserts telephone numbers for emergencies in location identification TLVs.
tel-number: Sets the telephone number for emergencies, a string of 10 to 25 characters.
network-policy [ vlan-id ]: Advertises network policy TLVs. The vlan-id argument specifies the voice VLAN ID to be advertised, in the range of 1 to 4094.
power-over-ethernet: Advertises extended power-via-MDI TLVs.
Nearest bridge agents are not supported on aggregate interfaces.
You can enable the device to advertise multiple types of TLVs by using this command without the all keyword specified.
If the MAC/PHY configuration/status TLV is not advertisable, none of the LLDP-MED TLVs will be advertised whether or not they are advertisable. If the LLDP-MED capabilities TLV is not advertisable, the other LLDP-MED TLVs will not be advertised regardless of whether or not they are advertisable.
The port and protocol VLAN ID, VLAN name, and management VLAN ID TLVs in IEEE 802.1 organizationally specific LLDP TLVs can be configured only for nearest bridge agents. The configuration can be inherited by nearest customer bridge agents and nearest non-TPMR bridge agents.
# Enable the nearest customer bridge agents on GigabitEthernet 1/0/1 to advertise link aggregation TLVs of the IEEE 802.1 organizationally specific TLVs.
[Sysname-GigabitEthernet1/0/1] lldp agent nearest-customer tlv-enable dot1-tlv link-aggregation
