11-Layer 2—LAN Switching Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath F1000[F5000][VFW] Firewalls Series Command Reference(V7)-6W60011-Layer 2—LAN Switching Command Reference
02-Layer 2 forwarding commands
02-Layer 2 forwarding commands 210.30 KB
Normal Layer 2 forwarding commands
display mac-forwarding statistics
Use display mac-forwarding statistics to display Layer 2 forwarding statistics.
display mac-forwarding statistics [ interface interface-type interface-number ]
context-admin
context-operator
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays Layer 2 forwarding statistics on all interfaces.
# Display Layer 2 forwarding statistics on all interfaces.
<Sysname> display mac-forwarding statistics
Input:
   Sum:               888        Unknown Unicast:   0
   Broadcast:         0          Multicast:         0
   Filtered:          0          STP discarded:     0
   Service dropped:   0          Source dropped:    0
   Unknown dropped: 0          Learning dropped:  0
   Blackhole dropped: 0          Suppress dropped:  0
   Source MAC dropped:0
Deliver:
   Sum:               111        L2 protocol:       11
   Local MAC address: 100
Output:
   Sum:               666        Filtered:          0
   Blackhole dropped: 0          STP discarded:     0
   Service dropped:   0          Dest MAC dropped:  0
# Display Layer 2 forwarding statistics on GigabitEthernet 1/0/1.
<Sysname> display mac-forwarding statistics interface gigabitethernet 1/0/1
GigabitEthernet1/0/1:
Input frames: 100    Output frames:100
Filtered:     0
Input
Inbound Ethernet frame statistics.
·     Sum—Total number of received Ethernet frames.
·     Filtered—Number of Ethernet frames filtered out by 802.1Q VLAN inbound filtering rules.
·     STP discarded—Number of inbound Ethernet frames dropped on the ports blocked by STP.
·     Service dropped—Number of Ethernet frames dropped by inbound service features.
·     Source dropped—Number of Ethernet frames dropped because their source MAC addresses are all-zeros, multicast, or broadcast MAC addresses.
·     Unknown dropped—Number of Ethernet frames dropped because the device is disabled from forwarding frames with unknown source MAC addresses.
·     Learning dropped—Number of Ethernet frames dropped because the device is disabled from forwarding unknown frames after the number of learned MAC addresses reaches the upper limit.
·     Suppress dropped—Number of Ethernet frames dropped by storm suppression.
·     Broadcast—Number of received broadcast Ethernet frames.
·     Multicast—Number of received multicast Ethernet frames.
·     Unknown unicast—Number of received unknown unicast Ethernet frames.
·     Blackhole dropped—Number of Ethernet frames dropped because they are sourced from blackhole MAC addresses.
·     Source MAC dropped—Number of Ethernet frames dropped by features based on the source MAC addresses.
Deliver
Statistics of Ethernet frames delivered to the CPU.
·     Sum—Total number of Ethernet frames delivered to the CPU.
·     L2 protocol—Number of Layer 2 protocol Ethernet frames delivered to the CPU.
·     Local MAC address—Number of Ethernet frames that use the MAC addresses of local Layer 3 VLAN interfaces as the destination MAC addresses.
Output
Outbound Ethernet frame statistics.
·     Sum—Total number of sent Ethernet frames.
·     Filtered—Number of Ethernet frames filtered out by 802.1Q VLAN outbound filtering rules.
·     Blackhole dropped—Number of Ethernet frames dropped because they are destined for blackhole MAC addresses.
·     STP discarded—Number of outbound Ethernet frames dropped on the ports blocked by STP.
·     Service dropped—Number of Ethernet frames dropped by outbound service features.
·     Dest MAC dropped—Number of Ethernet frames dropped by features based on the destination MAC addresses.
Layer 2 forwarding statistics on GigabitEthernet 1/0/1:
·     Input frames—Number of Ethernet frames received on the interface.
·     Output frames—Number of Ethernet frames sent out of the interface.
·     Filtered—Number of Ethernet frames filtered out because they are from other VLANs.
reset mac-forwarding statistics
Use reset mac-forwarding statistics to clear Layer 2 forwarding statistics.
context-admin
context-operator
# Clear Layer 2 forwarding statistics.
<Sysname> reset mac-forwarding statistics
Fast Layer 2 forwarding commands
display mac-forwarding cache ip
Use display mac-forwarding cache ip to display IPv4 fast forwarding entries.
display mac-forwarding cache ip [ ip-address ] [ slot slot-number ]
context-admin
context-operator
ip-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command displays all IPv4 fast forwarding entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv4 fast forwarding entries for all member devices.
# Display all IPv4 fast forwarding entries.
<Sysname> display mac-forwarding cache ip
Total number of mac-forwarding entries: 2
SIP            SPort DIP             DPort Pro Input_If    Output_If   VLAN
1.1.1.2        99    1.1.1.1         2048  1   GE1/0/1     GE1/0/2     2
1.1.1.1        98    1.1.1.2         2012  1   GE1/0/2     GE1/0/1     2
Total number of IPv4 fast forwarding entries.
SIP
Source IPv4 address.
SPort
Source port number.
DIP
Destination IPv4 address.
DPort
Destination port number.
Pro
Protocol number.
Input_If
Input interface type and number.
If no input interface is involved in fast forwarding, this field displays N/A.
If no input interface is available, this field displays a hyphen (-).
Output_If
Output interface type and number.
If no output interface is involved in fast forwarding, this field displays N/A.
If no output interface is available, this field displays a hyphen (-).
VLAN
VLAN ID.
display mac-forwarding cache ip fragment
Use display mac-forwarding cache ip fragment to display IPv4 fast forwarding entries for fragments.
display mac-forwarding cache ip fragment [ ip-address ] [ slot slot-number ]
context-admin
context-operator
ip-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command displays IPv4 fast forwarding entries for all fragments.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv4 fast forwarding entries for fragments on all member devices.
# Display IPv4 fast forwarding entries for all fragments.
<Sysname> display mac-forwarding cache ip fragment
Total number of fragment mac-forwarding entries: 2
SIP             SPort DIP             DPort Pro Input_If    ID     VLAN
1.1.1.1         117   1.1.1.2         0     1   GE1/0/1     2828   1
1.1.1.2         110   1.1.1.1         67    17  GE1/0/2     2322   1
Total number of IPv4 fast forwarding entries for fragments.
SIP
SPort
Source port number.
DIP
DPort
Pro
Protocol number.
Input_If
ID
Fragment ID.
VLAN
VLAN ID.
display mac-forwarding cache ipv6
Use display mac-forwarding cache ipv6 to display IPv6 fast forwarding entries.
display mac-forwarding cache ipv6 [ ipv6-address ] [ slot slot-number ]
context-admin
context-operator
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays all IPv6 fast forwarding entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 fast forwarding entries for all member devices.
# Display all IPv6 fast forwarding entries.
<Sysname> display mac-forwarding cache ipv6
Total number of IPv6 mac-forwarding items: 1
Src IP: 2002::1                                        Src port: 129
Dst IP: 2001::1                                        Dst port: 65535
VLAN ID: 2
Protocol: 2
Input interface: GE1/0/2
Output interface: GE1/0/1
Total number of IPv6 fast forwarding entries.
Src IP
Source IPv6 address.
Src port
Source port number.
Dst IP
Destination IPv6 address.
Dst Port
Protocol
Protocol number.
Input interface
Output interface
mac fast-forwarding check-vlan-id
Use mac fast-forwarding check-vlan-id to enable VLAN ID check for fast Layer 2 forwarding.
Use undo mac fast-forwarding check-vlan-id to disable VLAN ID check for fast Layer 2 forwarding.
VLAN ID check is enabled for fast Layer 2 forwarding.
context-admin
This feature allows the device to check whether the VLAN ID of a flow matches that of any fast forwarding entry. If no match is found, the flow does not match any fast forwarding entry.
The VLAN ID of a packet helps the device to determine the TCP session to which the packet belongs. On a hot backup system formed by two firewalls, you must disable VLAN ID check if the traffic incoming interfaces on the primary and secondary devices belong to different VLANs. If you enable VLAN ID check, traffic cannot match session entries correctly when asymmetric-path traffic exists.
# Enable VLAN ID check for fast Layer 2 forwarding.
[Sysname] mac fast-forwarding check-vlan-id
Cut-through Layer 2 forwarding commands
The following matrix shows the feature and hardware compatibility:
Series
Models
Cut-through Layer 2 forwarding compatibility
F50X0 series
F5010, F5020, F5020-GM, F5040, F5000-C, F5000-S
No
F5030, F5030-6GW, F5060, F5080, F5000-A, F5000-M
Yes
F5000-CN series
F5000-CN30, F5000-CN60
No
F5000-AI series
F5000-AI-15, F5000-AI-20, F5000-AI-40
Yes
F5000-V series
F5000-V30
Yes
F1000-AI series
F1000-AI-10, F1000-AI-15, F1000-AI-60, F1000-AI-65, F1000-AI-70, F1000-AI-75, F1000-AI-80, F1000-AI-90
No
F1000-AI-05, F1000-AI-20, F1000-AI-25, F1000-AI-30, F1000-AI-35, F1000-AI-50, F1000-AI-55
Yes
F1000-L series
F1003-L, F1005-L, F1010-L
Yes
F10X0 series
F1005, F1010, F1020, F1020-GM, F1030, F1030-GM, F1050, F1060, F1070, F1070-GM, F1070-GM-L, F1080
Yes
F1090
No
F1000-V series
F1000-V50, F1000-V70
Yes
F1000-V60, F1000-V90
No
F1000-SASE series
F1000-SASE100
Yes
F1000-SASE200
No
F1000-AK series
F1000-AK130, F1000-AK135, F1000-AK140, F1000-AK145, F1000-AK150, F1000-AK155, F1000-AK160, F1000-AK165, F1000-AK170, F1000-AK175, F1000-AK180, F1000-AK185, F1000-GM-AK370, F1000-GM-AK380, F1000-AK711, F1000-AK1010, F1000-AK1020, F1000-AK1030, F1000-AK1110, F1000-AK1120, F1000-AK1130, F1000-AK1140, F1000-AK1212, F1000-AK1222, F1000-AK1242, F1000-AK1252, F1000-AK1262, F1000-AK1272, F1000-AK1232, F1000-AK1312, F1000-AK1322, F1000-AK1332
Yes
F1000-AK108, F1000-AK109, F1000-AK110, F1000-AK115, F1000-AK120, F1000-AK125, F1000-AK710, F1000-AK1150, F1000-AK1160, F1000-AK1170, F1000-AK1180, F1000-AK1342, F1000-AK1352, F1000-AK1362, F1000-AK1414, F1000-AK1424, F1000-AK1434, F1000-AK1514, F1000-AK1524, F1000-AK1534, F1000-AK1614, F1000-AK9110, F1000-AK9210
No
Firewall modules
IM-NGFWX-IV, LSPM6FWD, LSPM6FWDB, LSQM1FWDSC0, LSQM2FWDSC0, LSU3FWCEA0, LSUM1FWCEAB0, LSUM1FWDEC0, LSWM1FWD0, LSX1FWCEA1, LSXM1FWDF1
No
vFW series
vFW1000, vFW2000
No
cut-through enable
Use cut-through enable to enable cut-through forwarding.
Use undo cut-through enable to disable cut-through forwarding.
cut-through enable
Cut-through forwarding is disabled.
context-admin
A cut-through forwarding-enabled device forwards a frame after it receives the first 64 bytes of the frame. This feature reduces the transmission time of a frame within the device and enhances forwarding performance.
A frame is forwarded before its CRC field is received, and thus CRC-error frames are forwarded instead of being dropped.
# Enable cut-through forwarding on the device.
[Sysname] cut-through enable
Bridge forwarding commands
add interface
Use add interface to add an interface to a reflect-type, forward-type, or blackhole-type bridge instance.
Use undo add interface to remove an interface from a reflect-type, forward-type, or blackhole-type bridge instance.
add interface interface-type interface-number
undo add interface interface-type interface-number
No interfaces exist in a reflect-type, forward-type, or blackhole-type bridge instance.
Reflect-type bridge view
Forward-type bridge view
Blackhole-type bridge view
context-admin
You can add only Layer 2 physical interfaces, Layer 3 physical interfaces, or Layer 2 aggregate interfaces to reflect-type, forward-type, or blackhole-type bridge instances.
Only one interface can be added to a reflect-type or blackhole-type bridge instance.
Only two interfaces can be added to a manually created forward-type bridge instance. The two interfaces must be the same type.
Each interface can be added to only one bridge instance.
This command is not available for a forward-type bridge instance that is automatically created upon insertion of a hardware bypass subcard. An automatically created forward-type bridge instance uses the pair of interfaces on the bypass subcard by default and you cannot edit the interfaces in the instance.
If you execute this command multiple times in reflect-type or blackhole-type bridge view, the most recent configuration takes effect.
If you execute this command multiple times in forward-type bridge view, the most recent two configurations take effect.
# Add GigabitEthernet 1/0/1 to reflect-type bridge instance 1.
[Sysname] bridge 1 reflect
[Sysname-bridge1-reflect] add interface gigabitethernet 1/0/1
add vlan
Use add vlan to add a list of VLANs to an inter-VLAN bridge instance.
Use undo add vlan to remove VLANs from an inter-VLAN bridge instance.
add vlan vlan-id-list
undo add vlan [ vlan-id-list ]
No VLANs exist in an inter-VLAN bridge instance.
Inter-VLAN bridge view
context-admin
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each VLAN item specifies a VLAN ID or a range of VLAN IDs in the form of start-vlan-id to end-vlan-id. The end VLAN ID must be greater than the start VLAN ID. Valid VLAN IDs are from 1 to 4094.
You can add VLANs to a bridge instance before or after you create the VLANs.
You can add a VLAN to only one bridge instance.
If you execute the command multiple times, all configurations take effect.
If you do not specify the vlan-id-list argument, the undo add vlan command removes all VLANs from the inter-VLAN bridge instance.
# Add VLANs 2, 3, 5, and VLANs 50 through 70 to bridge instance 2.
[Sysname] bridge 2 inter-vlan
[Sysname-bridge2-inter-vlan] add vlan 2 3 5 50 to 70
bridge
Use bridge to create a specific type of bridge instance and enter its view, or enter the view of an existing bridge instance.
Use undo bridge to delete bridge instances.
bridge bridge-index [ blackhole | forward | inter-vlan | reflect ]
undo bridge { bridge-index | all }
No bridge instances exist.
context-admin
bridge-index: Specifies a bridge instance index. For an automatically created forward-type bridge instance, the system will assign an index in the range of 32768 to 1082400.
The following compatibility matrix shows the value ranges for the bridge-index argument for a manually created bridge instance:
Series
Models
Value range
F50X0 series
1 to 2048
1 to 128
F5000-CN series
1 to 128
F5000-AI series
1 to 128
F5000-V series
F5000-V30
1 to 128
F1000-AI series
F1000-AI-05, F1000-AI-10, F1000-AI-15, F1000-AI-20, F1000-AI-25, F1000-AI-30, F1000-AI-35, F1000-AI-50, F1000-AI-55, F1000-AI-60, F1000-AI-65, F1000-AI-70, F1000-AI-75, F1000-AI-80, F1000-AI-90
1 to 128
F1000-L series
1 to 128
F10X0 series
F1005, F1010, F1020, F1020-GM, F1030, F1030-GM, F1050, F1060, F1070, F1070-GM, F1070-GM-L, F1080, F1090
1 to 128
F1000-V series
F1000-V50, F1000-V60, F1000-V70, F1000-V90
1 to 128
F1000-SASE series
F1000-SASE100, F1000-SASE200
1 to 128
F1000-AK series
F1000-AK108, F1000-AK109, F1000-AK110, F1000-AK115, F1000-AK120, F1000-AK125, F1000-AK130, F1000-AK135, F1000-AK140, F1000-AK145, F1000-AK150, F1000-AK155, F1000-AK160, F1000-AK165, F1000-AK170, F1000-AK175, F1000-AK180, F1000-AK185, F1000-GM-AK370, F1000-GM-AK380, F1000-AK710, F1000-AK711, F1000-AK1010, F1000-AK1020, F1000-AK1030, F1000-AK1110, F1000-AK1120, F1000-AK1130, F1000-AK1140, F1000-AK1150, F1000-AK1160, F1000-AK1170, F1000-AK1180, F1000-AK1212, F1000-AK1222, F1000-AK1232, F1000-AK1242, F1000-AK1252, F1000-AK1262, F1000-AK1272, F1000-AK1312, F1000-AK1322, F1000-AK1332, F1000-AK1342, F1000-AK1352, F1000-AK1362, F1000-AK1414, F1000-AK1424, F1000-AK1434, F1000-AK1514, F1000-AK1524, F1000-AK1534, F1000-AK1614, F1000-AK9110, F1000-AK9210
1 to 128
Firewall modules
1 to 2048
vFW series
vFW1000, vFW2000
1 to 128
blackhole: Specifies a blackhole-type bridge instance.
forward: Specifies a forward-type bridge instance.
inter-vlan: Specifies an inter-VLAN bridge instance.
reflect: Specifies a reflect-type bridge instance.
all: Deletes all bridge instances.
Use this command to create a bridge instance. You can create reflect-type, forward-type, and blackhole-type bridge instances for inline forwarding.
When you create a bridge instance, you must specify its type. You can specify only one type for a bridge instance.
The device will automatically create a forward-type bridge instance upon insertion of a hardware bypass subcard. The automatically created forward-type bridge instance uses the pair of interfaces on the bypass subcard by default. You cannot edit the interfaces in the bridge instance or delete the bridge instance.
# Create blackhole-type bridge instance 1 and enter its view.
[Sysname] bridge 1 blackhole
[Sysname-bridge1-blackhole]
# Create forward-type bridge instance 2 and enter its view.
[Sysname] bridge 2 forward
[Sysname-bridge2-forward]
# Create inter-VLAN bridge instance 3 and enter its view.
[Sysname] bridge 3 inter-vlan
[Sysname-bridge3-inter-vlan]
# Create reflect-type bridge instance 4 and enter its view.
[Sysname] bridge 4 reflect
[Sysname-bridge4-reflect]
bridge mac-address timer aging
Use bridge mac-address timer aging to set the aging timer for dynamic MAC address entries in bridge instances.
Use undo bridge to restore the default.
bridge mac-address timer aging seconds
undo bridge mac-address timer aging
The aging timer for dynamic MAC address entries is 300 seconds.
context-admin
seconds: Specifies a MAC address aging timer, in seconds. The value range is 60 to 1440.
Follow these guidelines to set the aging timer appropriately:
·     A long aging interval causes the MAC address table to retain outdated entries and fail to accommodate the most recent network changes.
·     A short aging interval results in removal of valid entries. Then, unnecessary broadcast packets appear and affect device performance.
After you set an aging time for dynamic MAC address entries, the device automatically deletes the expired dynamic MAC address entries. Then, the device learns new MAC addresses to build new MAC address entries.
# Set the aging timer to 500 seconds for dynamic MAC address entries.
[Sysname] bridge mac-address timer aging 500
bridge tunnel-encapsulation skip
Use bridge tunnel-encapsulation skip to configure the device to ignore the tunnel encapsulation when forwarding tunneled packets in inline mode.
Use undo bridge tunnel-encapsulation skip to restore the default.
In inline forwarding mode, tunneled packets are forwarded based on information in the tunnel encapsulation.
context-admin
This command takes effect only for inline forwarding.
In inline forwarding mode, tunneled packets are forwarded based on information in the tunnel encapsulation by default.
Use this command to enable the device to ignore the tunnel encapsulation and forward tunneled packets based on the original packet header information.
# Configure the device to ignore the tunnel encapsulation when forwarding tunneled packets in inline mode.
[Sysname] bridge tunnel-encapsulation skip
bypass enable
Use bypass enable to enable internal security service bypass.
Use undo bypass enable to disable security service bypass.
bypass enable
undo bypass enable
Security service bypass is disabled.
Blockhole-type bridge view
context-admin
This feature enables the device to bypass the security service and to directly process received packets according to the configured bridge forwarding mode.
If you configure the bypass enable command and the bypass enable external command multiple times, the most recent configuration takes effect.
# Enable internal security service bypass.
[Sysname] bridge 1 forward
[Sysname-bridge-1-forward] bypass enable
Use bypass enable external to enable external security service bypass.
bypass enable external [ auto [ check-interval interval ] ]
undo bypass enable
The following compatibility matrix shows the support of hardware platforms for this command:
Series
Models
Command compatibility
F50X0 series
Yes
No
F5000-CN series
No
F5000-AI series
No
F5000-V series
F5000-V30
No
F1000-AI series
No
F1000-L series
No
F10X0 series
No
F1000-V series
No
F1000-SASE series
No
F1000-AK series
No
Firewall modules
No
vFW series
vFW1000, vFW2000
No
context-admin
auto: Enables automatic external bypass.
check-interval interval: Specifies the interface status check interval in seconds. The value range is 0 to 3600 and the default is 15. The value 0 indicates that the interface status check feature is disabled.
If you configure this command multiple times, the most recent configuration takes effect.
With external bypass enabled, user traffic will bypass the security device and be forwarded directly by the PFC.
You can specify the auto keyword to enable dynamic external bypass or omit this keyword to enable static external bypass:
·     Static external bypass—External bypass takes effect immediately when configured and must be manually disabled.
·     Dynamic external bypass—External bypass is enabled or disabled automatically based on the status of the links between the security device and the PFC. The security device polls the link status periodically and enables external bypass if one or both links go down. External bypass is disabled automatically if the failed links come up.
You can specify the auto keyword to enable automatic external bypass, and specify the interval argument as 0 to disable the interface status check. In this case, external bypass is enabled automatically based on the status of the links between the security device and the PFC. The security device enables external bypass if one or both links go down. However, user traffic will still be forwarded directly by the PFC when the failed links come up.
External bypass is not supported in multi-chassis IRF systems.
External bypass is available only in the default context. The following guidelines apply when you configure this feature in the default context that contains a Layer 2 Ethernet interface assigned to it in shared-mode:
·     If external bypass takes effect, user traffic will be forwarded by the PFC. On the Layer 2 Ethernet interface, settings of a non-default context that conflict with the external bypass feature do not take effect.
·     If external bypass does not take effect, user traffic will not be forwarded by the PFC. On the Layer 2 Ethernet interface, settings of a non-default context that conflict with the external bypass feature take effect, and user traffic will be forwarded accordingly.
For a forward-type bridge instance that is automatically created upon insertion of a hardware bypass subcard, you can enable only internal bypass for the instance.
You can enable external bypass only for one manually created forward-type bridge instance. The interfaces added to the forward-type bridge instance must reside on the same slot.
The external security service bypass and the interface collaboration feature cannot be used at the same time. For more information about the interface collaboration feature, see High Availability Configuration Guide.
# Enable external security service bypass for forward-type bridge instance 1.
[Sysname-bridge-1-forward] bypass enable external
display bridge bypass status
Use display bridge bypass status to display the status of the security service bypass feature.
display bridge bridge-index bypass status
Series
Models
F50X0 series
Yes
No
F5000-CN series
No
F5000-AI series
No
F5000-V series
F5000-V30
No
F1000-AI series
No
F1000-L series
No
F10X0 series
No
F1000-V series
No
F1000-SASE series
No
F1000-AK series
No
Firewall modules
No
vFW series
vFW1000, vFW2000
No
context-admin
context-operator
bridge-index: Specifies a bridge instance by its index.
This command is supported in the default context.
# Display the status of the security service bypass feature in bridge instance Bridge 1.
<Sysname> display bridge 1 bypass status
   Current external bypass status: Disable
   The bypass device is faulty.
Table 5 Command output
Status of the external security service bypass feature:
·     Enable.
·     Disable.
The bypass device (PFC) is faulty.
display bridge mac-address
Use display bridge mac-address to display MAC address entries in bridge instances.
display bridge mac-address [ bridge-index [ vlan vlan-id ] ] [ count ] [ slot slot-number ]
context-admin
context-operator
vlan vlan-id: Specifies a VLAN by its ID.
count: Displays only the total number of MAC address entries that match all entry attributes you specify in this command. In this case, the detailed information about MAC address entries is not displayed. For example, you can use the display bridge mac-address 2 vlan 20 count command to display the total number of entries for VLAN 20 in bridge instance 2. If you do not specify this keyword, this command displays detailed information about specified MAC address entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays MAC address entries for the master device.
If you do not specify any parameters, this command displays MAC address entries for all bridge instances.
This command displays dynamic MAC address entries because the MAC address entries in a bridge instance are all learned MAC addresses.
# Display MAC address entries for bridge instance 100.
<Sysname> display bridge mac-address 100
MAC Address      BRIDGE ID  State        VLAN ID  Port            Aging
0033-0033-0033   100        Learned      44       GE1/0/1         Y
0000-0000-0002   100        Learned      66       GE1/0/2         Y
# Display the number of MAC address entries in bridge instance 100.
<Sysname> display bridge mac-address 100 count
1 mac address(es) found.
Table 6 Command output
BRIDGE ID
Index of the bridge instance to which the MAC address entry belongs.
MAC address entry state: Learned.
VLAN ID
VLAN of the outgoing interface.
Port
Outgoing interface.
Aging
Whether the entry can age out:
·     Y—The entry can age out.
·     N—The entry never ages out.
Number of matching MAC address entries.
mac-address max-mac-count
Use mac-address max-mac-count to set the MAC learning limit on an inter-VLAN bridge instance.
Use undo mac-address max-mac-count to restore the default.
The MAC learning limit is 4096 on an inter-VLAN bridge instance.
context-admin
count: Sets the maximum number of MAC addresses that can be learned on an inter-VLAN bridge instance. The value range for this argument is 0 to 4096. To prevent an inter-VLAN bridge instance from learning any MAC addresses, set the limit to 0 for the bridge instance.
The command sets the size of the inter-VLAN bridge forwarding MAC address table. When the number of MAC address entries learned by an inter-VLAN bridge instance reaches the limit, the bridge instance stops learning MAC address entries.
# Configure inter-VLAN bridge instance 2 to learn a maximum of 10 MAC address entries.
[Sysname-bridge2-inter-vlan] mac-address max-mac-count 10
Fast bridge forwarding commands
bridge fast-forwarding check-vlan-id
Use bridge fast-forwarding check-vlan-id to enable VLAN ID check for fast bridge forwarding.
Use undo bridge fast-forwarding check-vlan-id to disable VLAN ID check for fast bridge forwarding.
VLAN ID check is enabled for fast bridge forwarding.
context-admin
On a hot backup system formed by two firewalls, inter-VLAN fast bridge forwarding enables a packet to match the same session after being transmitted between the primary and secondary devices. Because the device does not check VLAN IDs for inter-VLAN fast bridge forwarding. That is, this command does not take effect on inter-VLAN fast bridge forwarding.
# Enable VLAN ID check for fast bridge forwarding.
[Sysname] bridge fast-forwarding check-vlan-id
display bridge cache ip
Use display bridge cache ip to display IPv4 fast bridge forwarding entries.
display bridge cache ip { inline | inter-vlan } [ ip-address ] [ slot slot-number ]
context-admin
context-operator
inline: Displays IPv4 inline forwarding entries.
inter-vlan: Displays IPv4 inter-VLAN forwarding entries.
ip-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command displays all IPv4 fast bridge forwarding entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv4 fast bridge forwarding entries for all member devices.
# Display IPv4 inline fast bridge forwarding entries.
<Sysname> display bridge cache ip inline
Total number of bridge-forwarding entries: 2
SIP             SPort DIP             DPort Pro InVLAN OutVLAN Output_If
1.1.1.3         470   1.1.1.2         0     1   3      2       GE1/0/1
1.1.1.2         470   1.1.1.3         2048  1   2      3       GE1/0/2
Table 7 Command output
Total number of IPv4 fast bridge forwarding entries.
SIP
SPort
Source port number.
DIP
DPort
Pro
Protocol number.
InVLAN
Input VLAN.
OutVLAN
Output VLAN.
Output_If
Output interface.
display bridge cache ip fragment
Use display bridge cache ip fragment to display IPv4 fast bridge forwarding entries for fragments.
display bridge cache ip fragment { inline | inter-vlan } [ ip-address ] [ slot slot-number ]
context-admin
context-operator
inline: Displays IPv4 inline forwarding entries for fragments.
inter-vlan: Displays IPv4 inter-VLAN forwarding entries for fragments.
ip-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command displays IPv4 fast bridge forwarding entries for all fragments.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv4 fast bridge forwarding entries for fragments on all member devices.
# Display IPv4 inline fast bridge forwarding entries for fragments.
<Sysname> display bridge cache ip fragment inline
Total number of fragment bridge-forwarding entries: 2
SIP             SPort DIP             DPort Pro InVLAN ID
2.1.1.2         2320  2.1.1.1         2048  1   2      7298
2.1.1.1         2048  2.1.1.2         2320  1   3      6826
Table 8 Command output
Total number of IPv4 fast bridge forwarding entries for fragments.
SIP
SPort
Source port number.
DIP
DPort
Pro
Protocol number.
InVLAN
Input VLAN.
ID
Fragment ID.
display bridge cache ipv6
Use display bridge cache ipv6 to display IPv6 fast bridge forwarding entries.
display bridge cache ipv6 { inline | inter-vlan } [ ipv6-address ] [ slot slot-number ]
context-admin
context-operator
inline: Displays IPv6 inline forwarding entries.
inter-vlan: Displays IPv6 inter-VLAN forwarding entries.
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays all IPv6 fast bridge forwarding entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 fast bridge forwarding entries for all member devices.
# Display IPv6 inline fast bridge forwarding entries.
<Sysname> display bridge cache ipv6 inline
Total number of IPv6 bridge-forwarding items: 1
Src IP: 10::12                                         Src Port: 427
Dst IP: 10::11                                         Dst Port: 32768
InVLAN: 2                                              OutVLAN: 3
Protocol: 58
Context ID: 257
Bridge ID: 10
Table 9 Command output
Total number of IPv6 fast bridge forwarding entries.
Src IP
Src port
Source port number.
Dst IP
Dst Port
InVLAN
Input VLAN.
OutVLAN
Output VLAN.
Protocol
Protocol number.
Context ID
Context ID.
Output interface
If no output interface is involved in fast forwarding, this field displays N/A. If no output interface is available, this field displays a hyphen (-).
