11-Layer 2—LAN Switching Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath F1000[F5000][VFW] Firewalls Series Command Reference(V7)-6W60011-Layer 2—LAN Switching Command Reference
03-Ethernet link aggregation commands
03-Ethernet link aggregation commands 366.25 KB
vFW1000 and vFW2000 virtual firewalls do not support Layer 2 Ethernet interfaces or Layer 2 link aggregation.
bandwidth
Use bandwidth to set the expected bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
context-admin
# Set the expected bandwidth to 10000 kbps for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] bandwidth 10000
# Set the expected bandwidth to 10000 kbps for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] bandwidth 10000
default
Use default to restore the default settings for an aggregate interface.
default
context-admin
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you execute it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for Layer 2 aggregate interface 1.
[Sysname-Bridge-Aggregation1] default
# Restore the default settings for Layer 3 aggregate interface 1.
[Sysname-Route-Aggregation1] default
description
The description of an interface is interface-name Interface. For example, the default description of Bridge-Aggregation 1 is Bridge-Aggregation1 Interface.
context-admin
# Configure the description as connect to the lab for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] description connect to the lab
# Configure the description as connect to the lab for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] description connect to the lab
display interface
Use display interface to display aggregate interface information.
display interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ brief [ description | down ] ]
context-admin
context-operator
bridge-aggregation: Specifies Layer 2 aggregate interfaces.
route-aggregation: Specifies Layer 3 aggregate interfaces.
interface-number: Specifies an existing aggregate interface number.
down: Displays information about interfaces in down state and the causes for the down state. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an aggregate interface type, this command displays information about all interfaces except VA interfaces. For more information about VA interfaces, see PPP configuration in Layer 2—WAN Access Configuration Guide.
If you specify an aggregate interface type but do not specify an interface number, this command displays information about all aggregate interfaces of the specified type.
# Display detailed information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1
Bridge-Aggregation1
Current state: UP
IP packet frame type: Ethernet II, hardware address: 000f-e207-f2e0
Description: Bridge-Aggregation1 Interface
Bandwidth: 1000 kbps
2Gbps-speed mode, full-duplex mode
PVID: 1
Port link-type: Access
 Tagged VLANs:   None
 UnTagged VLANs: 1
  Last 300 seconds input:  6900 packets/sec 885160 bytes/sec    0%
  Last 300 seconds output:  3150 packets/sec 404430 bytes/sec    0%
  Input (total):  5364747 packets, 686688416 bytes
         2682273 unicasts, 1341137 broadcasts, 1341337 multicasts, 0 pauses
  Input (normal):  5364747 packets, 686688416 bytes
         - ignored, - parity errors
  Output (total): 1042508 packets, 133441832 bytes
         1042306 unicasts, 0 broadcasts, 202 multicasts, - pauses
  Output (normal): 1042508 packets, 133441832 bytes
         1042306 unicasts, 0 broadcasts, 202 multicasts, 0 pauses
         - lost carrier, - no carrier
# Display detailed information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1
Route-Aggregation1
Current state: UP
Line protocol state: UP
Description: Route-Aggregation1 Interface
IP packet frame type: Ethernet II, hardware address: 0000-0000-0000
IPv6 packet frame type: Ethernet II, hardware address: 0000-0000-0000
# Display brief information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1 brief
Speed: (a) – auto
BAGG1                UP   auto    A      A    1
# Display brief information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1 brief
Protocol: (s) - spoofing
RAGG1                UP   UP       --
Bridge-Aggregation1
Layer 2 aggregate interface name.
Route-Aggregation1
Layer 3 aggregate interface name.
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is both administratively and physically up.
IPv4 packet framing format.
Description of the interface.
Bandwidth
Expected bandwidth of the interface. This field is not displayed when the bandwidth is 0 kbps.
Port priority
Port priority of the interface.
The interface speed and duplex mode are unknown.
Port link-type
Port link type:
·     Access.
·     Trunk.
·     Hybrid.
Tagged VLANs
VLAN whose packets are sent out of this interface with a tag.
Untagged VLANs
VLAN whose packets are sent out of this interface without a tag.
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Last 300 seconds input/output rate
Average input or output rate over the last 300 seconds.
Input/Output (total)
Statistics of all packets received or sent on the interface.
Input/Output (normal)
Statistics of all normal packets received or sent on the interface.
Line protocol state
Data link layer state of the interface:
·     UP.
·     DOWN.
MTU of the interface.
The interface is not assigned an IP address and cannot process IP packets.
IP address of the interface and type of the address in parentheses.
Possible IP address types include:
·     Primary—Manually configured primary IP address.
·     Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed.
·     DHCP-Allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3IP Services Configuration Guide.
·     BOOTP-AllocatedBOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3IP Services Configuration Guide.
·     PPP-Negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2WAN Access Configuration Guide.
·     Unnumbered—IP address borrowed from another interface.
·     MAD—IP address assigned to an IRF member device for MAD on the interface. For more information, see IRF configuration in Virtual Technologies Configuration Guide.
Brief information about Layer 3 interfaces.
Brief information about Layer 2 interfaces.
Abbreviated interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state.
Speed
Speed of the interface, in bps.
This field displays the (a) flag next to the speed if the speed is automatically negotiated.
This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started.
Duplex
Duplex mode of the interface:
·     A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started.
·     F—Full duplex.
·     F(a)—Autonegotiated full duplex.
·     H—Half duplex.
·     H(a)—Autonegotiated half duplex.
Link type of the interface:
·     A—Access.
·     H—Hybrid.
·     T—Trunk.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Cause
Cause for the physical link state of an interface to be DOWN.
display lacp system-id
Use display lacp system-id to display the local system ID.
context-admin
context-operator
You can use the lacp system-priority command to change the LACP priority of the local system. The LACP priority value is specified in decimal format in the lacp system-priority command. However, it is displayed in hexadecimal format in the output from the display lacp system-id command.
# Display the local system ID.
<Sysname> display lacp system-id
Actor System ID: 0x8000, 0000-fc00-6504
Local system ID, which contains the system LACP priority (0x8000 in this sample output) and the system MAC address (0000-FC00-6504 in this sample output).
display link-aggregation load-sharing mode
Use display link-aggregation load-sharing mode to display global or group-specific link-aggregation load sharing modes.
display link-aggregation load-sharing mode [ interface [ { bridge-aggregation | route-aggregation } interface-number ] ]
context-admin
context-operator
If you do not specify the interface keyword, the command displays the global link-aggregation load sharing modes.
If you specify the interface keyword, but do not specify an interface, the command displays all group-specific load sharing modes.
The bridge-aggregation or route-aggregation keyword is available only when aggregate interfaces of the corresponding type exist on the device.
# Display the global link-aggregation load sharing mode. This example displays the default settings.
<Sysname> display link-aggregation load-sharing mode
Link-aggregation load-sharing mode:
Layer 2 traffic: packet type-based sharing
Layer 3 traffic: packet type-based sharing
# Display the global link-aggregation load sharing mode. This example displays user-configured settings.
destination-mac address, source-mac address
# Display the link-aggregation load sharing mode of Layer 2 aggregation group 1. This example displays the default settings.
<Sysname> display link-aggregation load-sharing mode interface bridge-aggregation 1
Bridge-Aggregation1 load-sharing mode:
# Display the link-aggregation load sharing mode of Layer 2 aggregation group 1. This example displays user-configured settings.
# Display the link-aggregation load sharing mode of Layer 3 aggregation group 1. This example displays the default settings.
<Sysname> display link-aggregation load-sharing mode interface route-aggregation 1
Route-Aggregation1 load-sharing mode:
# Display the link-aggregation load sharing mode of Layer 3 aggregation group 1. This example displays user-configured settings.
Global link-aggregation load sharing mode.
By default, this field displays the link-aggregation load sharing modes for Layer 2 and Layer 3 traffic.
If you have configured the global link-aggregation load sharing mode, this field displays the configured mode.
Link-aggregation load sharing mode of Layer 2 aggregation group 1.
By default, this field displays the global link-aggregation load sharing modes.
If you have configured a link-aggregation load sharing mode for this aggregation group, this field displays the configured mode.
Link-aggregation load sharing mode of Layer 3 aggregation group 1.
Route-Aggregation1 hardware-based forwarding load-sharing mode
Link-aggregation load sharing mode for hardware-based forwarding of Layer 3 aggregation group 1.
Route-Aggregation1 software-based forwarding load-sharing mode
Link-aggregation load sharing mode for software-based forwarding of Layer 3 aggregation group 1.
Layer 2 traffic: destination-mac address, source-mac address
Default link-aggregation load sharing mode for Layer 2 traffic. In this sample output, Layer 2 traffic is load shared based on source and destination MAC addresses.
Default link-aggregation load sharing mode for Layer 2 traffic. In this sample output, the system automatically selects a load sharing mode for Layer 2 traffic.
Layer 3 traffic: destination-ip address,  source-ip address
Default link-aggregation load sharing mode for Layer 3 traffic. In this sample output, Layer 3 traffic is load shared based on source and destination IP addresses.
Default link-aggregation load sharing mode for Layer 3 traffic. In this sample output, the system automatically selects a load sharing mode for Layer 3 traffic.
User-configured link-aggregation load sharing mode. In this sample output, traffic is load shared based on source and destination MAC addresses.
display link-aggregation load-sharing path
Use display link-aggregation load-sharing path to display forwarding information about the specified traffic flow.
display link-aggregation load-sharing path interface { bridge-aggregation | route-aggregation } interface-number ingress-port interface-type interface-number [ route ] { { destination-ip ip-address | destination-ipv6 ipv6-address } | { source-ip ip-address | source-ipv6 ipv6-address } | destination-mac mac-address | destination-port port-id | ethernet-type type-number | ip-protocol protocol-id | source-mac mac-address | source-port port-id | vlan vlan-id } * slot slot-number
context-admin
context-operator
interface-number: Specifies an existing aggregate interface by its number.
ingress-port interface-type interface-number: Specifies an ingress port by its type and number. The ingress port must be a physical port.
route: Displays forwarding information about Layer 3 traffic. If you do not specify this keyword, the command displays forwarding information about Layer 2 traffic.
destination-ip ip-address: Specifies a destination IPv4 address.
destination-ipv6 ipv6-address: Specifies a destination IPv6 address.
source-ip ip-address: Specifies a source IPv4 address.
source-ipv6 ipv6-address: Specifies a source IPv6 address.
destination-mac mac-address: Specifies a destination MAC address in H-H-H format.
destination-port port-id: Specifies a destination port number in the range of 1 to 65535.
ethernet-type type-number: Specifies an Ethernet type code in the range of 1 to 65535.
ip-protocol protocol-id: Specifies an IP protocol by its ID in the range of 0 to 255.
source-mac mac-address: Specifies a source MAC address in H-H-H format.
source-port port-id: Specifies a source port number in the range of 1 to 65535.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
slot slot-number: Specifies an IRF member device by its member ID.
A parameter specified in the command might not be used for selecting the egress port. The Load sharing parameters field displays the parameters that are used in egress port selection. For example, you can specify both the destination-mac mac-address and destination-ip ip-address options. If only the destination MAC address is used for selecting the egress port, the Load sharing parameters field does not display the destination-ip parameter.
If a parameter required for selecting the egress port is not specified, the default value of the parameter is used. If the parameter does not have any default values, the parameter is set to 0.
This command takes effect only on per-flow load sharing and automatic load sharing. As a best practice, do not use this command for per-packet load sharing.
# Display forwarding information about the specified traffic flow to be sent out of Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display link-aggregation load-sharing path interface bridge-aggregation 1 ingress-port gigabitethernet 1/0/1 destination-mac 0000-fc00-0001 source-mac 0000-fc00-0002 source-ip 10.100.0.2 destination-ip 10.100.0.1 slot 1
Load sharing mode: destination-mac, source-mac, source-ip, destination-ip
Unspecified parameters are set to 0.
Load-sharing parameters:
  Ingress port: GigabitEthernet1/0/1
  Destination MAC: 0000-fc00-0001
  Source MAC: 0000-fc00-0002
  Destination IP: 10.100.0.1
  Source IP: 10.100.0.2
Egress port: GigabitEthernet1/0/3
Load sharing mode:
Load sharing mode set for the aggregation group:
·     destination-mac—Traffic is load shared based on destination MAC addresses.
·     source-mac—Traffic is load shared based on source MAC addresses.
·     destination-ip—Traffic is load shared based on destination IP addresses.
·     source-ip—Traffic is load shared based on source IP addresses.
·     destination-port—Traffic is load shared based on destination ports.
·     source-port—Traffic is load shared based on source ports.
·     ip-protocol—Traffic is load shared based on IP protocol types.
·     ingress-port—Traffic is load shared based on ingress ports.
·     vlan—Traffic is load shared based on VLAN IDs.
·     packet type-based sharing—Traffic is load shared automatically based on packet types. If no load sharing mode is set, this field also displays packet type-based sharing.
Parameters that are used in egress port selection.
Egress port
Egress port of the specified traffic flow. If no egress port is found, this field displays N/A.
display link-aggregation member-port
Use display link-aggregation member-port to display detailed link aggregation information about the specified member ports.
display link-aggregation member-port [ interface-list | auto ]
context-admin
context-operator
interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-number2 argument must be equal to or greater than the value for the interface-number1 argument.
auto: Specifies all link aggregation member ports that are enabled with automatic assignment.
A member port in a static aggregation group cannot obtain information about the peer group. For such member ports, the command displays the port number, port priority, and operational key of only the local end.
# Display detailed information about GigabitEthernet 1/0/1, which is a member port of a static aggregation group.
<Sysname> display link-aggregation member-port gigabitethernet 1/0/1
       G -- Defaulted, H -- Expired
GigabitEthernet1/0/1:
Port Number: 1
Port Priority: 32768
Oper-Key: 1
# Display detailed information about GigabitEthernet 1/0/2, which is a member port of a dynamic aggregation group.
<Sysname> display link-aggregation member-port gigabitethernet 1/0/2
GigabitEthernet1/0/2:
Aggregate Interface: Bridge-Aggregation2
Local:
    Port Number: 2
    Oper-Key: 2
    Flag: {ACDEF}
Remote:
    Port Number: 26
    Oper-Key: 2
    Flag: {ACDEF}
Received LACP Packets: 5 packet(s)
Illegal: 0 packet(s)
Sent LACP Packets: 7 packet(s)
Table 5 Command output
Flags
LACP state flags. This field is one byte long, represented by ABCDEFGH from the least significant bit to the most significant bit. A letter appears when its bit is 1 and does not appear when its bit is 0.
·     A—Indicates whether LACP is active on the port. 1 indicates active. 0 indicates passive.
·     B—Indicates the LACP timeout interval. 1 indicates the short timeout interval. 0 indicates the long timeout interval.
·     C—Indicates whether the sending system considers that the link is aggregatable. 1 indicates yes. 0 indicates no.
·     D—Indicates whether the sending system considers that the link has been aggregated. 1 indicates yes. 0 indicates no.
·     E—Indicates whether the sending system considers that the link can collect frames. 1 indicates yes. 0 indicates no.
·     F—Indicates whether the sending system considers that the link can distribute frames. 1 indicates yes. 0 indicates no.
·     G—Indicates whether the RX state machine of the sending system is in default state. 1 indicates yes. 0 indicates no.
·     H—Indicates whether the RX state machine of the sending system is in expired state. 1 indicates yes. 0 indicates no.
Aggregate Interface
Aggregate interface to which the member port belongs.
Local
Information about the local end.
Oper-key
Operational key.
Flag
LACP protocol state flag.
Remote
Information about the peer end.
System ID
Peer system ID, containing the system LACP priority and the system MAC address.
Total number of LACP packets received.
Illegal
Total number of illegal packets.
Sent LACP Packets
Total number of LACP packets sent.
display link-aggregation summary
Use display link-aggregation summary to display brief information about all aggregation groups.
context-admin
context-operator
Static link aggregation groups cannot obtain information about the peer groups. As a result, the Partner ID field displays None or nothing for a static link aggregation group.
# Display brief information about all aggregation groups.
<Sysname> display link-aggregation summary
Aggregate Interface Type:
BAGG -- Bridge-Aggregation, BLAGG –- Blade-Aggregation, RAGG -- Route-Aggregation, SCH-B – Schannel-Bundle
Aggregation Mode: S -- Static, D -- Dynamic
Actor System ID: 0x8000, 000f-e267-6c6a
AGG        AGG   Partner ID              Selected  Unselected  Individual  Share
Interface  Mode                          Ports     Ports       Ports       Type
RAGG1      S     None                    1         0           0           NonS
BAGG2      D     0x8000,00e0-fcff-ff01   2         0           0           Shar
Table 6 Command output
Aggregate interface type:
·     BAGG—Layer 2.
·     RAGG—Layer 3.
·     BLAGG—Blade. This type is not supported in the current software version.
·     SCH-B—S-channel bundle. This type is not supported in the current software version.
Aggregation Mode
Aggregation group type:
·     S—Static.
·     D—Dynamic.
Loadsharing Type
Load sharing type:
·     Shar—Load-sharing.
·     NonS—Non-load-sharing.
Actor System ID
Local system ID, which contains the local system LACP priority and the local system MAC address.
AGG Interface
Type and number of the aggregate interface.
AGG Mode
Aggregation group type.
Partner ID
System ID of the peer system, which contains the peer system LACP priority and the peer system MAC address.
Selected Ports
Total number of Selected ports.
Unselected Ports
Total number of Unselected ports.
Individual Ports
Total number of Individual ports.
Share Type
Load sharing type.
display link-aggregation verbose
Use display link-aggregation verbose to display detailed information about the aggregation groups that correspond to the specified aggregate interfaces.
display link-aggregation verbose [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
context-admin
context-operator
If you do not specify an aggregate interface type, the command displays detailed information about all aggregation groups.
If you specify an aggregate interface type but do not specify an interface number, the command displays detailed information about all aggregation groups of the specified type.
# Display detailed information about Layer 2 aggregation group 1, which is a dynamic aggregation group.
<Sysname> display link-aggregation verbose bridge-aggregation 1
Port: A -- Auto port
Creation Mode: Manual
Aggregation Mode: Dynamic
Local:
  Port             Status  Priority Oper-Key  Flag
  GE1/0/1          S       32768    2         {ACDEF}
  GE1/0/2          S       32768    2         {ACDEF}
  GE1/0/3          S       32768    2         {ACDEF}
Remote:
  Actor            Partner Priority Oper-Key  SystemID               Flag
  GE1/0/1          1       32768    2         0x8000, 000f-e267-57ad {ACDEF}
  GE1/0/2          1       32768    2         0x8000, 000f-e267-57ad {ACDEF}
  GE1/0/3          1       32768    2         0x8000, 000f-e267-57ad {ACDEF}
# Display detailed information about Layer 3 aggregation group 1, which is a dynamic aggregation group.
<Sysname> display link-aggregation verbose route-aggregation 1
Local:
Remote:
# Display detailed information about Layer 2 aggregation group 2, which is a static aggregation group.
<Sysname> display link-aggregation verbose bridge-aggregation 2
Aggregation Mode: Static
  GE1/0/1          S       32768    1
  GE1/0/2          S       32768    1
  GE1/0/3          S       32768    1
# Display detailed information about Layer 3 aggregation group 2, which is a static aggregation group.
<Sysname> display link-aggregation verbose route-aggregation 2
Aggregate Interface: Route-Aggregation2
  GE1/0/1          S       32768    1
  GE1/0/2          S       32768    1
  GE1/0/3          S       32768    1
Table 7 Command output
Loadsharing Type
Load sharing type:
Port Status
Port state:
·     Selected.
·     Unselected.
·     Individual.
Port
Port type. Auto port indicates that the port is enabled with automatic assignment.
Flags
Aggregate Interface
Name of the aggregate interface.
Creation Mode
Creation mode of the dynamic aggregate interface:
·     Auto.
·     Manual.
Aggregation Mode
·     S—Static.
·     D—Dynamic.
System ID
Local system ID, containing the local system LACP priority and the local system MAC address.
Local
Information about the local end:
·     Port—Port type and number.
·     Status—Port state, which can be Selected, Unselected, or Individual.
·     Priority—Port priority.
·     Oper-Key—Operational key.
·     Flag—LACP state flag.
For static aggregation groups, the Flag field is not displayed.
Remote
Information about the peer end:
·     Actor—Type and number of the local port. This field displays the (R) flag next to the port if its peer port is the reference port.
·     Partner—Index of the peer port.
·     Priority—Priority of the peer port.
·     Oper-Key—Operational key of the peer port.
·     System ID—System ID of the peer end.
·     Flag—LACP state flag of the peer end.
Use interface bridge-aggregation to create a Layer 2 aggregate interface and enter its view, or enter the view of an existing Layer 2 aggregate interface.
Use undo interface bridge-aggregation to delete a Layer 2 aggregate interface.
undo interface bridge-aggregation interface-number
No Layer 2 aggregate interfaces exist.
context-admin
interface-number: Specifies a Layer 2 aggregate interface number.
The following compatibility matrix shows the value ranges for this argument:
Hardware series
Models
Value range
F50X0 series
F5010, F5020, F5020-GM, F5030, F5030-6GW, F5040, F5060, F5080, F5000-A, F5000-C, F5000-S, F5000-M
1 to 64
F5000-CN series
F5000-CN30, F5000-CN60
1 to 64
F5000-AI series
F5000-AI-15, F5000-AI-20, F5000-AI-40
1 to 64
F5000-V series
F5000-V30
1 to 64
F1000-AI series
F1000-AI-05, F1000-AI-10, F1000-AI-15, F1000-AI-20, F1000-AI-25, F1000-AI-30, F1000-AI-35, F1000-AI-50, F1000-AI-55, F1000-AI-60, F1000-AI-65, F1000-AI-70, F1000-AI-75, F1000-AI-80, F1000-AI-90
1 to 64
F1000-L series
F1003-L, F1005-L, F1010-L
1 to 64
F10X0 series
F1005, F1010, F1020, F1020-GM, F1030, F1030-GM, F1050, F1060, F1070, F1070-GM, F1070-GM-L, F1080, F1090
1 to 64
F1000-V series
F1000-V50, F1000-V60, F1000-V70, F1000-V90
1 to 64
F1000-SASE series
F1000-SASE100, F1000-SASE200
1 to 64
F1000-AK series
F1000-AK108, F1000-AK109, F1000-AK110, F1000-AK115, F1000-AK120, F1000-AK125, F1000-AK130, F1000-AK135, F1000-AK140, F1000-AK145, F1000-AK150, F1000-AK155, F1000-AK160, F1000-AK165, F1000-AK170, F1000-AK175, F1000-AK180, F1000-AK185, F1000-GM-AK370, F1000-GM-AK380, F1000-AK710, F1000-AK711, F1000-AK1010, F1000-AK1020, F1000-AK1030, F1000-AK1110, F1000-AK1120, F1000-AK1130, F1000-AK1140, F1000-AK1150, F1000-AK1160, F1000-AK1170, F1000-AK1180, F1000-AK1212, F1000-AK1222, F1000-AK1232, F1000-AK1242, F1000-AK1252, F1000-AK1262, F1000-AK1272, F1000-AK1312, F1000-AK1322, F1000-AK1332, F1000-AK1342, F1000-AK1352, F1000-AK1362, F1000-AK1414, F1000-AK1424, F1000-AK1434, F1000-AK1514, F1000-AK1524, F1000-AK1534, F1000-AK1614, F1000-AK9110, F1000-AK9210
1 to 64
Firewall modules
IM-NGFWX-IV, LSPM6FWD, LSPM6FWDB, LSQM1FWDSC0, LSQM2FWDSC0, LSU3FWCEA0, LSUM1FWCEAB0, LSUM1FWDEC0, LSWM1FWD0, LSX1FWCEA1, LSXM1FWDF1
1 to 64
vFW series
vFW1000, vFW2000
1 to 8
When you create a Layer 2 aggregate interface, the system automatically creates a Layer 2 aggregation group with the same number. The aggregation group operates in static aggregation mode by default.
Deleting a Layer 2 aggregate interface also deletes the Layer 2 aggregation group. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and enter its view.
Use interface route-aggregation to create a Layer 3 aggregate interface or subinterface and enter its view, or enter the view of an existing Layer 3 aggregate interface or subinterface.
Use undo interface route-aggregation to delete a Layer 3 aggregate interface or subinterface.
undo interface route-aggregation { interface-number | interface-number.subnumber }
No Layer 3 aggregate interfaces or subinterfaces exist.
context-admin
interface-number: Specifies a Layer 3 aggregate interface number.
Hardware series
Models
Value range
F50X0 series
1 to 64
F5000-CN series
1 to 64
F5000-AI series
1 to 64
F5000-V series
F5000-V30
1 to 64
F1000-AI series
1 to 64
F1000-L series
1 to 64
F10X0 series
1 to 64
F1000-V series
1 to 64
F1000-SASE series
1 to 64
F1000-AK series
1 to 64
Firewall modules
IM-NGFWX-IV, LSPM6FWD, LSPM6FWDB , LSQM1FWDSC0, LSQM2FWDSC0, LSU3FWCEA0, LSUM1FWCEAB0, LSUM1FWDEC0, LSWM1FWD0, LSX1FWCEA1, LSXM1FWDF1
1 to 64
vFW series
vFW1000, vFW2000
1 to 8
interface-number.subnumber: Specifies a subinterface of a Layer 3 aggregate interface. The interface-number argument specifies the main interface number. The subnumber argument specifies the subinterface number and is separated from the main interface number by a dot (.). The value range for the interface-number argument is 1 to 4094.
When you create a Layer 3 aggregate interface, the system automatically creates a Layer 3 aggregation group with the same number. The Layer 3 aggregation group operates in static aggregation mode by default.
Deleting a Layer 3 aggregate interface also deletes the Layer 3 aggregation group and all its aggregate subinterfaces. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
Deleting a Layer 3 aggregate subinterface does not affect the state of the main interface and the corresponding aggregation group.
# Create Layer 3 aggregate interface Route-Aggregation 1 and enter its view.
# Create Layer 3 aggregate subinterface Route-Aggregation 1.1 and enter its view.
[Sysname] interface route-aggregation 1.1
[Sysname-Route-Aggregation1.1]
jumboframe enable
Use jumboframe enable to allow the jumbo frames on an interface to pass through.
Use undo jumboframe enable to deny jumbo frames on an interface.
Use undo jumboframe enable size to restore the default.
jumboframe enable [ size ]
The following compatibility matrix shows the default maximum jumbo frame length on each hardware model:
Series
Hardware
F50X0 series
9216 bytes
F5000-AI series
9216 bytes
F5000-V series
F5000-V30
9216 bytes
F1000-AI series
F1000-AI-05
1524 bytes
9216 bytes
F1000-L series
1524 bytes
F10X0 series
F1005, F1010
1524 bytes
9216 bytes
F1000-V series
9216 bytes
F1000-AK series
F1000-AK108, F1000-AK109, F1000-AK110, F1000-AK115, F1000-AK120, F1000-AK125, F1000-AK1010, F1000-AK1020, F1000-AK1030, F1000-AK1110, F1000-AK1120, F1000-AK1130, F1000-AK9110, F1000-AK9210
1524 bytes
F1000-AK130, F1000-AK135, F1000-AK140, F1000-AK145, F1000-AK150, F1000-AK155, F1000-AK160, F1000-AK165, F1000-AK170, F1000-AK175, F1000-AK180, F1000-AK185, F1000-GM-AK370, F1000-GM-AK380, F1000-AK710, F1000-AK711, F1000-AK1140, F1000-AK1150, F1000-AK1160, F1000-AK1170, F1000-AK1180, F1000-AK1212, F1000-AK1222, F1000-AK1232, F1000-AK1242, F1000-AK1252, F1000-AK1262, F1000-AK1272, F1000-AK1312, F1000-AK1322, F1000-AK1332, F1000-AK1342, F1000-AK1352, F1000-AK1362, F1000-AK1414, F1000-AK1424, F1000-AK1434, F1000-AK1514, F1000-AK1524, F1000-AK1534, F1000-AK1614
9216 bytes
Firewall modules
IM-NGFWX-IV, LSPM6FWD, LSQM1FWDSC0, LSQM2FWDSC0, LSU3FWCEA0, LSUM1FWCEAB0, LSUM1FWDEC0, LSWM1FWD0, LSX1FWCEA1, LSXM1FWDF1
9216 bytes
vFW series
vFW1000, vFW2000
16384 bytes
context-admin
size: Specifies the maximum length of jumbo frames, in bytes.
Series
Models
Value range
F50X0 series
Fixed at 9216 bytes
F5000-CN series
Fixed at 9216 bytes
F5000-AI series
Fixed at 9216 bytes
F5000-V series
F5000-V30
Fixed at 9216 bytes
F1000-AI series
F1000-AI-05
Fixed at 1524 bytes
Fixed at 9216 bytes
F1000-L series
Fixed at 1524 bytes
F10X0 series
F1005, F1010
Fixed at 1524 bytes
Fixed at 9216 bytes
F1000-V series
F1000-V50, F1000-V70, F1000-V60, F1000-V90
Fixed at 9216 bytes
F1000-SASE series
F1000-SASE100
Fixed at 1524 bytes
F1000-SASE200
Fixed at 9216 bytes
F1000-AK series
F1000-AK108, F1000-AK109, F1000-AK110, F1000-AK115, F1000-AK120, F1000-AK125, F1000-AK710, F1000-AK1010, F1000-AK1020, F1000-AK1030, F1000-AK1110, F1000-AK1120, F1000-AK1130, F1000-AK1140, F1000-AK9110, F1000-AK9210
Fixed at 1524 bytes
F1000-AK130, F1000-AK135, F1000-AK140, F1000-AK145, F1000-AK150, F1000-AK155, F1000-AK160, F1000-AK165, F1000-AK170, F1000-AK175, F1000-AK180, F1000-AK185, F1000-GM-AK370, F1000-GM-AK380, F1000-AK711, F1000-AK1150, F1000-AK1160, F1000-AK1170, F1000-AK1180, F1000-AK1212, F1000-AK1222, F1000-AK1232, F1000-AK1242, F1000-AK1252, F1000-AK1262, F1000-AK1272, F1000-AK1312, F1000-AK1322, F1000-AK1332, F1000-AK1342, F1000-AK1352, F1000-AK1362, F1000-AK1414, F1000-AK1424, F1000-AK1434, F1000-AK1514, F1000-AK1524, F1000-AK1534, F1000-AK1614
Fixed at 9216 bytes
Firewall modules
Fixed at 9216 bytes
vFW series
vFW1000, vFW2000
1536 to 16384 bytes
# Allow jumbo frames to pass through on Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> System-view
[Sysname-Bridge-Aggregation1] jumboframe enable
# Allow jumbo frames to pass through on Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] jumboframe enable
lacp default-selected-port disable
Use lacp default-selected-port disable to disable the default port selection action for dynamic aggregation groups.
Use undo lacp default-selected-port disable to enable the default port selection action for dynamic aggregation groups.
The default port selection action is enabled for dynamic aggregation groups.
context-admin
The default port selection action applies to dynamic aggregation groups.
This action automatically chooses the port with the lowest ID from among all up member ports as a Selected port if none of them has received LACPDUs before the LACP timeout interval expires.
After this action is disabled, a dynamic aggregation group will not have any Selected ports to forward traffic if it has not received LACPDUs before the LACP timeout interval expires.
# Disable the default port selection action.
[Sysname] lacp default-selected-port disable
lacp edge-port
Use lacp edge-port to configure an aggregate interface as an edge aggregate interface.
Use undo lacp edge-port to restore the default.
lacp edge-port
undo lacp edge-port
An aggregate interface does not operate as an edge aggregate interface.
context-admin
Use this command on the aggregate interface that connects the device to a server if dynamic link aggregation is configured only on the device. This feature improves link reliability by enabling all member ports of the aggregation group to forward packets.
This command takes effect only on an aggregate interface corresponding to a dynamic aggregation group.
Link-aggregation traffic redirection cannot operate correctly on an edge aggregate interface.
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as an edge aggregate interface.
[Sysname-Bridge-Aggregation1] lacp edge-port
# Configure Layer 3 aggregate interface Route-Aggregation 1 as an edge aggregate interface.
[Sysname-Route-Aggregation1] lacp edge-port
lacp mode
Use lacp mode passive to configure LACP to operate in passive mode on a port.
Use undo lacp mode to restore the default.
lacp mode passive
undo lacp mode
LACP operates in active mode on a port.
context-admin
This command takes effect only on member ports of dynamic aggregation groups.
When LACP is operating in passive mode on a local member port and its peer port, both ports cannot send LACPDUs. When LACP is operating in active mode on either end of a link, both ports can send LACPDUs.
# Configure LACP to operate in passive mode on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lacp mode passive
lacp period short
Use lacp period short to enable the short LACP timeout interval (3 seconds) on an interface.
Use undo lacp period to restore the default.
lacp period short
undo lacp period
The LACP timeout interval is the long timeout interval (90 seconds) on an interface.
context-admin
To avoid traffic interruption during an ISSU, do not enable the short LACP timeout interval before performing the ISSU. For more information about ISSU, see Fundamentals Configuration Guide.
# Enable the short LACP timeout interval (3 seconds) on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lacp period short
Use lacp system-priority to set the system LACP priority.
Use undo lacp system-priority to restore the default.
lacp system-priority priority
The system LACP priority is 32768.
context-admin
priority: Specifies the system LACP priority in the range of 0 to 65535. The smaller the value, the higher the system LACP priority.
# Set the system LACP priority to 64.
[Sysname] lacp system-priority 64
link-aggregation port-priority
link-aggregation forwarding-acceleration enable
Use link-aggregation forwarding-acceleration enable to enable forwarding acceleration on an aggregate interface.
Use undo link-aggregation forwarding-acceleration enable to disable forwarding acceleration on an aggregate interface.
The following matrix shows the hardware and command compatibility:
Hardware series
Models
Command compatibility
F50X0 series
Yes
F5000-CN series
Yes
F5000-AI series
Yes
F5000-V series
F5000-V30
Yes
F1000-AI series
Yes
F1000-L series
Yes
F10X0 series
Yes
F1000-V series
Yes
F1000-SASE series
Yes
F1000-AK series
Yes
Firewall modules
No
vFW series
vFW1000, vFW2000
Yes
Forwarding acceleration is enabled on aggregate interfaces.
context-admin
Forwarding acceleration takes effect on an aggregate interface only when it is enabled both globally and on the aggregate interface.
This feature accelerates traffic forwarding on an aggregate interface whose member ports are located on multiple slots.
# Enable forwarding acceleration on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] link-aggregation forwarding-acceleration enable
# Enable forwarding acceleration on Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-aggregation forwarding-acceleration enable
link-aggregation global forwarding-acceleration enable
Use link-aggregation global forwarding-acceleration enable to enable forwarding acceleration globally.
undo link-aggregation global forwarding-acceleration enable to disable forwarding acceleration globally.
Hardware series
Models
F50X0 series
Yes
F5000-CN series
Yes
F5000-AI series
Yes
F5000-V series
F5000-V30
Yes
F1000-AI series
Yes
F1000-L series
Yes
F10X0 series
Yes
F1000-V series
Yes
F1000-SASE series
Yes
F1000-AK series
Yes
Firewall modules
No
vFW series
vFW1000, vFW2000
Yes
Forwarding acceleration is disabled globally.
context-admin
# Enable forwarding acceleration globally.
[Sysname] link-aggregation global forwarding-acceleration enable
link-aggregation global load-sharing mode
Use link-aggregation global load-sharing mode to set the global link-aggregation load sharing mode.
Use undo link-aggregation global load-sharing mode to restore the default.
link-aggregation global load-sharing mode { destination-ip | destination-mac | destination-port | ingress-port | source-ip | source-mac | source-port } *
The system automatically chooses a load sharing mode depending on the packet type.
context-admin
destination-ip: Distributes traffic based on destination IP addresses.
destination-mac: Distributes traffic based on destination MAC addresses.
destination-port: Distributes traffic based on destination ports.
ingress-port: Distributes traffic based on ingress ports.
source-ip: Distributes traffic based on source IP addresses.
source-mac: Distributes traffic based on source MAC addresses.
source-port: Distributes traffic based on source ports.
If an unsupported load sharing mode is set, the device displays an error message.
# Set the global load sharing mode to load share packets based on destination MAC addresses.
[Sysname] link-aggregation global load-sharing mode destination-mac
bandwidth
link-aggregation ignore vlan
Use link-aggregation ignore vlan to configure a Layer 2 aggregate interface to ignore the specified VLANs.
Use undo link-aggregation ignore vlan to remove the specified ignored VLANs for a Layer 2 aggregate interface.
link-aggregation ignore vlan vlan-id-list
undo link-aggregation ignore vlan vlan-id-list
A Layer 2 aggregate interface does not ignore any VLANs.
context-admin
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
This command takes effect only when the link type of the Layer 2 aggregate interface is hybrid or trunk.
With this command configured, a Layer 2 aggregate interface ignores the permitted VLAN and VLAN tagging mode configuration of the specified VLANs when choosing Selected ports.
# Configure Layer 2 aggregate interface bridge-aggregation 1 to ignore VLAN 50.
[Sysname-Bridge-Aggregation1] link-aggregation ignore vlan 50
link-aggregation lacp traffic-redirect-notification enable
Use link-aggregation lacp traffic-redirect-notification enable to enable link-aggregation traffic redirection.
Use undo link-aggregation lacp traffic-redirect-notification enable to disable link-aggregation traffic redirection.
Link-aggregation traffic redirection is disabled.
context-admin
This feature redirects traffic on a Selected port to the remaining available Selected ports of an aggregation group if the port is shut down by using the shutdown command or the slot that hosts the port reboots.
The device does not redirect traffic to member ports that become Selected during the traffic redirection process.
This feature ensures zero packet loss for known unicast traffic, but does not protect unknown unicast traffic.
This feature applies only to dynamic link aggregation groups.
To prevent traffic interruption, enable link-aggregation traffic redirection on devices at both ends of the aggregate link.
To prevent packet loss that might occur when a slot reboots, do not enable spanning tree together with link-aggregation traffic redirection.
# Enable link-aggregation traffic redirection.
[Sysname] link-aggregation lacp traffic-redirect-notification enable
Use link-aggregation load-sharing mode to set the link-aggregation load sharing mode for an aggregation group.
Use undo link-aggregation load-sharing mode to restore the default.
link-aggregation load-sharing mode { destination-ip | destination-mac | destination-port | source-ip | source-mac | source-port } *
An aggregation group uses the global link-aggregation load sharing mode.
context-admin
# Configure Layer 2 aggregation group 1 to load share packets based on destination MAC addresses.
[Sysname-Bridge-Aggregation1] link-aggregation load-sharing mode destination-mac
# Configure Layer 3 aggregation group 1 to load share packets based on destination MAC addresses.
[Sysname-Route-Aggregation1] link-aggregation load-sharing mode destination-mac
bandwidth
link-aggregation load-sharing mode local-first
Use link-aggregation load-sharing mode local-first to enable local-first load sharing for link aggregation globally.
Use undo link-aggregation load-sharing mode local-first to disable local-first load sharing for link aggregation globally.
Local-first load sharing is enabled for link aggregation globally.
context-admin
Use local-first load sharing in a multichassis link aggregation scenario to distribute traffic preferentially across member ports on the ingress device.
If you disable local-first load sharing, packets of an aggregate interface are load shared among all Selected ports on IRF member devices.
You can configure local-first load sharing for link aggregation only globally. The global setting takes effect on all aggregation groups.
# Disable local-first load sharing for link aggregation globally.
[Sysname] undo link-aggregation load-sharing mode local-first
link-aggregation group load-sharing mode local-first
link-aggregation mode
Use link-aggregation mode dynamic to configure an aggregation group to operate in dynamic aggregation mode and enable LACP.
Use undo link-aggregation mode to restore the default.
An aggregation group operates in static aggregation mode.
context-admin
Aggregation mode change might cause Selected member ports to become Unselected.
When you change the aggregation mode, make sure you understand the impact of the change on services.
# Configure Layer 2 aggregation group 1 to operate in dynamic aggregation mode.
# Configure Layer 3 aggregation group 1 to operate in dynamic aggregation mode.
[Sysname-Route-Aggregation1] link-aggregation mode dynamic
Use link-aggregation port-priority to set the port priority of an interface.
Use undo link-aggregation port-priority to restore the default.
The port priority of an interface is 32768.
context-admin
priority: Specifies the port priority in the range of 0 to 65535. The smaller the value, the higher the port priority.
# Set the port priority to 64 for Layer 2 Ethernet interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] link-aggregation port-priority 64
# Set the port priority to 64 for Layer 3 Ethernet interface GigabitEthernet 1/0/2.
[Sysname-GigabitEthernet1/0/2] link-aggregation port-priority 64
link-aggregation selected-port maximum
Use link-aggregation selected-port maximum to set the maximum number of Selected ports allowed in an aggregation group.
Use undo link-aggregation selected-port maximum to restore the default.
link-aggregation selected-port maximum max-number
The maximum number of Selected ports allowed in an aggregation group depends on hardware limitation.
context-admin
max-number: Specifies the maximum number of Selected ports allowed in an aggregation group. The value range for this argument is 1 to 16.
Executing this command might cause some of the Selected ports in an aggregation group to become Unselected ports.
The maximum number of Selected ports allowed in the aggregation groups must be the same for the local and peer ends.
For an aggregation group, the maximum number of Selected ports must be equal to or higher than the minimum number of Selected ports.
The maximum number of Selected ports allowed in an aggregation group is limited by one of the following values, whichever value is smaller:
·     Maximum number set by using the link-aggregation selected-port maximum command.
·     Maximum number of Selected ports allowed by the link aggregation capability.
You can implement backup between two ports by performing the following tasks:
·     Assigning two ports to an aggregation group.
·     Setting the maximum number of Selected ports to 1 for the aggregation group.
Then, only one Selected port is allowed in the aggregation group at any point in time, while the Unselected port acts as a backup port.
# Set the maximum number of Selected ports to 5 for Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port maximum 5
# Set the maximum number of Selected ports to 5 for Layer 3 aggregation group 1.
[Sysname-Route-Aggregation1] link-aggregation selected-port maximum 5
link-aggregation selected-port minimum
Use link-aggregation selected-port minimum to set the minimum number of Selected ports in an aggregation group.
Use undo link-aggregation selected-port minimum to restore the default.
The minimum number of Selected ports in an aggregation group is not specified.
context-admin
min-number: Specifies the minimum number of Selected ports in an aggregation group required to bring up the aggregate interface. The value range for this argument is 1 to 16.
Executing this command might cause all member ports in the aggregation group to become Unselected ports.
The minimum number of Selected ports allowed in the aggregation groups must be the same for the local and peer ends.
For an aggregation group, the minimum number of Selected ports must be equal to or lower than the maximum number of Selected ports.
# Set the minimum number of Selected ports to 3 for Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port minimum 3
# Set the minimum number of Selected ports to 3 for Layer 3 aggregation group 1.
[Sysname-Route-Aggregation1] link-aggregation selected-port minimum 3
link-delay
Use link-delay to set the physical state change suppression interval on an aggregate interface.
Use undo link-delay to restore the default.
link-delay [ msec ] delay-time [ mode { up | updown } ]
undo link-delay [ msec ] delay-time [ mode { up | updown } ]
Each time the physical link of an aggregate interface goes up or comes down, the system immediately reports the change to the CPU.
context-admin
msec: Sets the physical state change suppression interval in milliseconds. If you do not specify this keyword, the suppression interval is in seconds.
delay-time: Sets the physical state change suppression interval. To report a physical state change immediately to the CPU, set the interval to 0.
·     If you do not specify the msec keyword, the value range is 0 to 30 seconds.
·     If you specify the msec keyword, the value range is 0 to 10000 milliseconds, and the value must be a multiple of 100.
mode up: Suppresses link-up events.
mode updown: Suppresses both link-up and link-down events.
You can configure this feature to suppress only link-down events, only link-up events, or both. If an event of the specified type persists when the suppression interval expires, the system reports the event.
When you configure this feature, follow these guidelines:
·     To suppress only link-down events, use the link-delay [ msec ] delay-time command.
·     To suppress only link-up events, use the link-delay [ msec ] delay-time mode up command.
·     To suppress both link-down and link-up events, use the link-delay [ msec ] delay-time mode updown command.
On an interface, you can configure different suppression intervals for link-up and link-down events. If you execute the link-delay command multiple times for link-up or link-down events, the most recent configuration takes effect.
# Set the link-down event suppression interval to 8 seconds on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] link-delay down 8
# Set the link-down event suppression interval to 8 seconds on Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-delay 8
mtu
Use mtu to set the MTU of a Layer 3 aggregate interface or subinterface.
mtu size
undo mtu
The MTU of Layer 3 aggregate interfaces and subinterfaces is 1500 bytes.
context-admin
size: Specifies an MTU in bytes. The value range for this argument is 46 to 1560..
# Set the MTU of interface Route-Aggregation 1 to 1430 bytes.
[Sysname-Route-Aggregation1] mtu 1430
display interface
port link-aggregation group
Use port link-aggregation group to assign an interface to an aggregation group.
Use undo port link-aggregation group to remove an interface from the aggregation group to which it belongs.
An interface does not belong to any aggregation group.
context-admin
group-id: Specifies an aggregation group by its aggregate interface number. The value range for the number argument is 1 to 64.
You can assign a Layer 2 or Layer 3 Ethernet interface only to a Layer 2 or Layer 3 aggregation group, respectively.
An interface can belong to only one aggregation group.
By default, the following restrictions exist:
·     You cannot assign both Ethernet interfaces and Ethernet subinterfaces to an aggregation group.
·     You cannot create subinterfaces on an Ethernet interface that is in an aggregation group.
·     You cannot assign an Ethernet interface that has subinterfaces to an aggregation group.
You cannot create aggregate subinterfaces on an aggregate interface if its aggregation group contains Ethernet subinterfaces. You cannot assign Ethernet subinterfaces to an aggregation group if its aggregate interface has aggregate subinterfaces.
Before you assign an Ethernet subinterface to an aggregation group, verify that the following requirements are met:
·     VLAN termination has been configured on the Ethernet subinterface. You cannot modify VLAN termination configuration on the Ethernet subinterfaces in an aggregation group. To configure VLAN termination, use the following commands:
¡     vlan-type dot1q default.
¡     vlan-type dot1q untagged.
¡     vlan-type dot1q vid.
·     By default, the Ethernet subinterfaces to be assigned to an aggregation group terminate the same VLAN.
·     If you execute the vlan-type dot1q vid vlan-id-list command on an Ethernet subinterface to be assigned to a dynamic aggregation group, specify only one VLAN ID.
You cannot assign the following interfaces to an aggregation group:
·     Member interfaces of redundant Ethernet interfaces.
·     Member interfaces of redundancy group nodes.
For more information about redundant Ethernet interfaces and redundancy group nodes, see Virtual Technologies Configuration Guide.
# Assign Layer 2 Ethernet interface GigabitEthernet 1/0/1 to Layer 2 aggregation group 1.
[Sysname-GigabitEthernet1/0/1] port link-aggregation group 1
# Assign Layer 3 Ethernet interface GigabitEthernet 1/0/2 to Layer 3 aggregation group 2.
[Sysname-GigabitEthernet1/0/2] port link-aggregation group 2
vlan-type dot1q vid
Use reset counters interface to clear statistics about the specified aggregate interfaces.
reset counters interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
context-admin
Use this command to clear history statistics before you collect traffic statistics for a time period.
If you do not specify an aggregate interface type, the command clears statistics about all interfaces in the system.
If you specify only an aggregate interface type, the command clears statistics about all aggregate interfaces of the specified type.
# Clear the statistics about interface Bridge-Aggregation 1.
<Sysname> reset counters interface bridge-aggregation 1
reset lacp statistics
Use reset lacp statistics to clear LACP statistics about the specified link aggregation member ports.
context-admin
interface interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-number1 argument must be equal to or greater than the value for the interface-number2 argument. If you do not specify any member ports, the command clears LACP statistics about all member ports.
# Clear LACP statistics about all link aggregation member ports.
<Sysname> reset lacp statistics
shutdown
Use shutdown to shut down an aggregate interface or subinterface.
Use undo shutdown to bring up an aggregate interface or subinterface.
shutdown
An interface is not manually shut down.
context-admin
CAUTION
CAUTION:
The shutdown command will disconnect all links established on an interface. Make sure you are fully aware of the impacts of this command when you use it on a live network.
Shutting down or bringing up a Layer 3 aggregate interface shuts down or brings up its subinterfaces. Shutting down or bringing up a Layer 3 aggregate subinterface does not affect its main interface.
# Bring up Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] undo shutdown
# Bring up Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] undo shutdown
