| 01-About the Router | 1.10 MB |
1 About the router
Unless otherwise stated, routing and forwarding units (RFUs) and HMIC interface modules are collectively referred to as "modules" in this document.
Chassis views
The figures in this section are for illustration only.
Figure1-1 Front panel
(1) HMIC interface module slot 2 |
(2) HMIC interface module slot 4 |
(3) HMIC interface module slot 3 |
(4) HMIC interface module slot 5 |
(5) RFU slot 0 |
(6) RFU slot 1 |
(7) Power supply slot PWR3 |
(8) Power supply slot PWR2 |
(9) Power supply slot PWR1 |
(10) Power supply slot PWR0 |
(11) HMIC interface module slot 7 |
(12) HMIC interface module slot 9 |
(13) HMIC interface module slot 6 |
(14) HMIC interface module slot 8 |
Figure1-2 Rear panel
(1) Fan tray slot 0 |
(2) Fan tray slot 1 |
(3) Grounding screw |
Slot arrangement and interface numbering
Slot arrangement
Table1-1 Slot arrangement on the router
Model |
Slot arrangement |
SR6608-M |
Interface numbering
Conventions
The interfaces (except the management Ethernet interface) on the router are numbered in the interface-type X/Y/Z format. The management Ethernet interface number is M-GigabitEthernet 0/0/0.
· interface-type—Type of the interface such as GigabitEthernet and Ten-GigabitEthernet.
· X—Number of the slot where the module resides on the router, as shown in Table1-1.
· Y—Subslot number, which is fixed at 0.
· Z—Number of the interface on the module, starting from 0.
An HMIC-XP4 interface module is installed in slot 6 of the router. Fixed SFP+ fiber ports on the interface module are numbered Ten-GigabitEthernet 6/0/0 through Ten-GigabitEthernet 6/0/3, respectively.
An RFU-560-G is installed in slot 0 of the router. The fixed SFP+ fiber port on the RFU-560-G is numbered Ten-GigabitEthernet 0/0/0.
Technical specifications
Table1-2 SR6608-M technical specifications
Item |
Specification |
Dimensions (H × W × D) (excluding rubber feet and mounting brackets) |
175 × 440 × 330 mm (6.89 × 17.32 × 12.99 in) |
Chassis weight (including mounting brackets and filler panels) |
11.5 kg (25.35 lb) |
Device weight |
Weights of the chassis (including mounting brackets and filler panels), modules, power supplies, fan trays, and other removable components |
System power consumption |
Total power consumption of all modules and fan trays |
Heat dissipation |
Heat dissipation of the router per hour is 0.9 × (total power consumption of all modules and fan trays)/0.9 × 3.4121 |
RFU slots |
2 |
HMIC interface module slots |
8 |
Fan tray slots |
2 |
Power supply slots |
4 |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
Operating humidity |
5% RH to 95% RH, noncondensing |
NOTE: Heat dissipation is measured in BTU/h. 1 W equals 3.4121 BTU/h. |
