- 17-BRAS Services Command Reference
- 01-AAA commands
- 02-ANCP commands
- 03-PPP commands
- 04-Value-added services commands
- 05-DHCP commands
- 06-DHCPv6 commands
- 07-User profile commands
- 08-Connection limit commands
- 09-L2TP commands
- 10-PPPoE commands
- 11-IPoE commands
- 12-802.1X commands
- 13-UCM commands
- 14-CP-UP connection management commands
- 15-UP backup commands
| 14-CP-UP connection management commands | 184.01 KB |
disconnection entry-aging (CUSP agent view)
echo-request (CUSP agent view)
keychain-authentication (CUSP agent view)
reset cusp agent statistics (UPs)
snmp-agent trap enable cusp-agent (UPs)
display protocol-tunnel packet statistics (UPs)
display protocol-tunnel verbose (UPs)
protocol-tunnel (CU agent view)
reset protocol-tunnel packet statistics (UPs)
snmp-agent trap enable protocol-tunnel
sub-interface inherit-main (UPs)
On a CUPS network, this device acts only as a UP. When executing operation commands in this chapter (except the display commands and the snmp-agent trap enable protocol-tunnel command), follow these restrictions and guidelines:
· If a command is tagged with (UPs), this command can be executed only on a UP. Before executing this command on a UP, make sure you are fully aware of the impact of this command on the current network and prevent configuration errors from causing network failures.
· If a command does not have any tag, this command can be executed only on a CP by default. To execute this command on a UP, do that under the guidance of professionals, make sure you are fully aware of the impact of this command on the current network, and prevent configuration errors from causing network failures.
Control channel commands
bfd enable (CUSP agent view)
Use bfd enable to enable BFD for CUSP on a CUSP agent.
Use undo bfd enable to disable BFD for CUPS on a CUSP agent.
bfd enable [ template template-name ]
undo bfd enable
BFD is disabled for CUSP.
CUSP agent view
template template-name: Specifies a BFD template by its name , a case-sensitive string of 1 to 63 characters. If you do not specify a BFD template, this command references the default BFD session parameters. To view the BFD session information, execute the display bfd session command.
With BFD enabled for CUPS on a CUSP agent, BFD sessions will be set up for new CUSP connections to fast detect CUSP connection faults. A BFD template is used for flexibly configuring BFD session parameters. For more information about BFD templates, see BFD in High Availability Configuration Guide.
# Enable BFD for CUPS on CUSP agent up1, and specify BFD template cusp-bfd. (UPs.)
[Sysname] cusp agent up1
[Sysname-cusp-agent-up1] bfd enable template cusp-bfd
controller address
Use controller address to specify the CUSP controller IP address for a CUSP agent.
Use undo controller address to delete the CUSP controller IP address for a CUSP agent.
controller address { ipv4-address | ipv6 ipv6-address }
undo controller address { ipv4-address | ipv6 ipv6-address }
No CUSP controller IP address is specified for a CUSP agent.
CUSP agent view
ipv4-address: Specifies a CUSP controller IPv4 address.
ipv6-address: Specifies a CUSP controller IPv6 address.
Make sure the IP address configured by using this command is the same as that configured by using the listening-ip command on the CUSP controller.
You can execute this command multiple times to specify multiple CUSP controller IP addresses for a CUSP agent.
# Remotely specify CUSP controller IP address 3.1.1.2 for CUSP agent up1. (UPs.)
[Sysname-cusp-agent-up1] controller address 3.1.1.2
cusp agent
Use cusp agent to create a CUSP agent and enter its view, or enter the view of an existing CUSP agent.
Use undo cusp agent to delete a CUSP agent.
cusp agent agent-name
undo cusp agent agent-name
No CUSP agent exists.
System view (UPs)
agent-name: Specifies a CUSP agent name, a case-sensitive string of 1 to 31 characters.
Only one CUSP agent can be created on a UP. To modify the name of a CUSP agent, first delete the CUSP agent.
# Create CUSP agent up1 and enter its view. (UPs.)
Use disconnection entry-aging to configure the CUSP entry aging time of a CUSP agent after the CUSP connection is disconnected.
Use undo disconnection entry-aging to restore the default.
disconnection entry-aging aging-time
The CUSP entries of a CUSP agent do not age out after the CUSP connection is disconnected.
CUSP agent view
aging-time: Specifies the aging time in the range of 5 to 1440 minutes.
After a CUSP connection is disconnected, if the connection is still disconnected when the CUSP entry aging time expires, the CUSP entries will be deleted. CUSP entries include user entries of UCM and route entries that the DHCP server deploys to the UPs through the control channel. For more information about UCM, see BRAS Services Configuration Guide.
When you configure this feature, follow these restrictions and guidelines:
· To prevent UP reboot from aging out and deleting CUSP entries, make sure the aging time set by using this command is longer than the sum of the UP reboot duration and the delay configured by using the first-connection-delay command.
· As a best practice, configure the same CUSP entry aging time on the CUSP controller and CUSP agent.
# Set the CUSP entry aging time to 120 minutes on the CUSP agent after the CUSP connection is disconnected. (UPs.)
[Sysname-cusp-agent-up1] disconnection entry-aging 120
display cusp agent (UPs)
Use display cusp agent to display the connection information of a CUSP agent.
display cusp agent [ controller address { ipv4-address | ipv6 ipv6-address } ]
controller address: Specifies a controller connected to a CUSP agent. If you do not specify a CUSP controller, this command displays information about all controllers connected to a CUSP agent.
This command is supported only on UPs.
# Display the connection information of a CUSP agent.
<Sysname> display cusp agent
Agent name : up1
Vendor ID : 25506
CUSP version : 2
Agent IP : 1.1.1.1
VPN instance : --
SSL policy : --
BFD state : Disable
BFD template : --
Echo interval : 30s
Echo timeout threshold : 4
Keychain name : --
Disconnection entry aging time : Not aging
First connection delay time : Not delayed
Controller information:
Vendor ID : 25506
Control tunnel state : Active
Controller IP : 2.2.2.2
Connection state : Established
Packets sent : 11137
Packets received : 7993
Agent name |
CUSP agent name. |
Vendor ID |
Vendor ID. |
CUSP version |
CUSP protocol version. |
Agent IP |
IPv4 or IPv6 address of a CUSP agent. To configure a CUSP agent IP address, use the local-address command. If no CUSP agent IP address is configured, this field displays two hyphens (--). |
VPN instance |
VPN instance where the CUSP agent resides. If no VPN instance is configured for the CUSP agent, this field displays two hyphens (--). |
SSL policy |
Name of the SSL client policy associated with the CUSP connection. If no SSL client policy is associated, this field displays two hyphens (--). |
BFD state |
State of BFD for CUSP: · Enable. · Disable. |
BFD template |
Name of the BFD templates associated with the CUSP connection. If no BFD template is associated, this field displays two hyphens (--). |
Echo interval |
Interval at which the CUSP agent sends heartbeat detection packets, in seconds. |
Echo timeout threshold |
Threshold for the CUSP agent heartbeat detection timeout occurrences. |
Keychain name |
Security authentication keychain name specified for the CUSP connection. This field displays two hyphens (--) if no keychain name is configured. |
Disconnection entry aging time |
CUSP entry aging time (in minutes) after the CUSP connection is disconnected. This field displays Not aging if the entries do not age out. |
First connection delay time |
Delay time (in minutes) after which the CUSP agent sets up the CUSP connection for the first time after the UP is rebooted. This field displays Not delayed if the first connection setup is not delayed. |
Controller information |
CUSP controller information. |
Control tunnel state |
State of the control channel between the CP where the CUSP controller resides and the UP where the CUSP agent resides. Possible values are: · Active. · Inactive. |
Controller IP |
CUSP controller IP address. |
Connection state |
State of the connection between the CUSP controller and the CUSP agent. Possible values are: · Idle—The connection is not set up. · Established. |
Packets sent |
Number of packets that the CUSP agent has sent to the CUSP controller. |
Packets received |
Number of packets that the CUSP agent has received from the CUSP controller. |
Use echo-request to configure the heartbeat detection parameters for a CUSP agent.
Use undo echo-request to restore the default.
echo-request { interval interval | threshold threshold }
undo echo-request { interval | threshold }
The heartbeat detection packet interval is 30 seconds, and the threshold for the heartbeat detection timeout occurrences is 4 on a CUSP agent.
CUSP agent view
interval: Specifies the interval at which the CUSP agent sends heartbeat detection packets, in the range of 0 to 120 seconds. The value 0 indicates no heartbeat detection packets are sent.
threshold: Specifies the threshold for the CUSP agent heartbeat detection timeout occurrences, in the range of 4 to 10.
A CUSP agent sends an Echo Request (heartbeat detection packet) to the connected CUSP controller at the specified interval. If the CUSP agent continuously fails to receive replies from the controller for threshold times, the CUSP agent disconnects from the CUSP controller.
The CUSP connection keepalive timer is the minimum of the following two values:
· Keepalive timer of the TCP connection carrying the CUSP connection, which is fixed at 30 seconds.
· Heartbeat detection timeout timer of the CUSP connection (interval × threshold).
# Configure the threshold as 5 for the heartbeat detection timeout occurrences for CUSP agent up1. (UPs.)
[Sysname-cusp-agent-up1] echo-request threshold 5
Use first-connection-delay to configure the delay after which a CUSP agent sets up a CUSP connection for the first time after a UP is rebooted.
Use undo first-connection-delay to restore the default.
first-connection-delay delay-time
A CUSP agent immediately tries to set up a CUSP connection after a UP is rebooted.
CUSP agent view
aging-time: Specifies the first CUSP connection setup delay time in the range of 1 to 60 minutes.
After a UP is rebooted, if a CUSP connection is set up before the CGN module enters the normal state, service data might have errors. To resolve this issue, you can configure the CUSP agent to delay setting up the first CUSP connection. Make sure the delay is longer than the time taken by the CGN module to enter the normal state after device reboot. To view the module state, use the display device command.
# Configure CUSP agent up1 to set up the first CUSP connection 30 minutes of delay after the UP is rebooted. (UPs.)
[Sysname-cusp-agent-up1] first-connection-delay 30
Use keychain-authentication to specify a CUSP agent to use keychain authentication for setting up a CUSP connection.
Use undo keychain-authentication to restore the default.
keychain-authentication keychain-name
Keychain authentication is not used by a CUSP agent for setting up a CUSP connection.
CUSP agent view
keychain-name: Specifies a keychain name, a case-sensitive string of 1 to 63 characters.
You can configure keychain authentication to improve the CUSP connection security. For two ends to set up CUSP connections normally, configure keychain authentication on both the CUSP controller and CUSP agent, and make sure the keychains used by both ends meet the following conditions:
· The key ID used at a time must be the same. The key ID is specified by using the key command.
· Keys with the same ID use the same authentication algorithm and authentication key, which are configured by using the authentication-algorithm and key-string commands, respectively.
# Remotely specify keychain authentication with username abc for CUSP agent up1 to set up a CUSP connection. (UPs.)
[Sysname-cusp-agent-up1] keychain-authentication abc
authentication-algorithm (Security Command Reference)
key (Security Command Reference)
keychain (Security Command Reference)
key-string (Security Command Reference)
local-address
Use local-address to specify the local IP address for a CUSP agent.
Use undo local-address to delete the local IP address configuration from a CUSP agent.
local-address { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
undo local-address
No local IP address is specified for a CUSP agent.
CUSP agent view
ipv4-address: Specifies an IPv4 address as the local IP address.
ipv6-address: Specifies an IPv6 address as the local IP address.
vpn-instance vpn-instance-name: Specifies the VPN instance to which a CUSP agent belongs. The vpn-instance-name argument specifies an MPLS L3VPN name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the CUSP agent belongs to the public network.
# Configure the local IP address as 3.1.1.1 for CUSP agent up1. (UPs.)
[Sysname-cusp-agent-up1] local-address 3.1.1.1
Use reset cusp agent statistics to clear the packet statistics of a CUSP agent.
reset cusp agent statistics [ controller address { ipv4-address | ipv6 ipv6-address } ]
If you do not specify an IP address, this command clears packet statistics of all CUSP connections of a CUSP agent.
# Clear the packet statistics of a CUSP agent.
<Sysname> reset cusp agent statistics
Use snmp-agent trap enable cusp-agent to enable SNMP notifications for the CUSP agent module.
Use undo snmp-agent trap enable cusp-agent to disable SNMP notifications for the CUSP agent module.
snmp-agent trap enable cusp-agent [ connect-state ]
undo snmp-agent trap enable cusp-agent [ connect-state ]
SNMP notifications are enabled for a CUSP agent.
connect-state: Enables SNMP notifications for the CUSP connection state changes. If you do not specify this option, this command enables all types of SNMP notifications for the CUSP agent module.
With SNMP notifications enabled for the CUSP agent module, this module can generate alarms to report important events of this module. The generated alarms are sent to the SNMP module of the device. You can specify how the alarms are output through setting the alarm output parameters in SNMP. For more information about alarms, see SNMP configuration in Network Management and Monitoring Guide.
# Enable SNMP notifications for the CUSP agent module.
[Sysname] snmp-agent trap enable cusp-agent
ssl-client-policy
Use ssl-client-policy to specify the SSL client policy for a CUSP agent to set up a CUSP connection.
Use undo ssl-client-policy to restore the default.
ssl-client-policy policy-name
No SSL client policy is specified for a CUSP agent to set up a CUSP connection.
CUSP agent view
policy-name: Specifies an SSL client policy by its name, a case-insensitive string of 1 to 31 characters.
With this feature configured on a CUSP agent, the CUSP agent uses the SSL parameters in the SSL client policy for setting up a CUSP connection to secure the connection. For more information about SSL client policies, see SSL configuration in Security Configuration Guide.
# Specify SSL client policy cusp-policy for CUSP agent up1 to set up a CUSP connection. (UPs.)
[Sysname-cusp-agent-up1] ssl-client-policy cusp-policy
ssl client-policy (Security Command Reference)
Protocol channel commands
cp-management (UPs)
The cp-management command configuration on an interface indicates that the interface is remotely managed by a CP.
cp-management
No interface on a UP is remotely managed by a CP.
Interface view
In a CUPS network, a CP can remotely manage interfaces on UPs. When a remote interface is created on the CP, the cp-management command configuration is automatically generated on the UP interface managed by the remote interface.
The cp-management command configuration is automatically generated on the UP interface managed by the remote interface, and cannot be manually executed.
After the control channel to a UP is disconnected, you can execute the reset cp configuration command on the UP. Then, these UP interfaces are not remotely managed by the CP.
When a remote interface on the CP is mapped to a UP interface, you cannot execute the reset cp configuration command on the UP.
If the cp-management command configuration exists on the UP interface managed by the remote interface, you cannot perform the following tasks on the UP interface. To perform these tasks on the interface, first disconnect the control channel between the CP and UP and execute the reset cp configuration command on the UP.
· Deleting an interface
· Switching the interface mode between bridge and route
· Splitting an interface
· Switching the interface type by using the port-type command
· Assigning an interface to an aggregation group
· Assigning an interface to a redundancy group
cu-agent
Use cu-agent to create a CU agent and enter its view.
Use undo cu-agent to delete a CU agent and all configuration in the view of the CU agent.
cu-agent
undo cu-agent
A CU agent does not exist.
System view (UPs)
This command is supported only when the device is operating in standard mode. For more information about the system operating mode, see device management configuration in Fundamentals Configuration Guide.
In CU agent view on a CP in the CUPS scenario, you can execute the commands available in CU agent view on a UP and deploy these commands to the UP.
When you execute the undo cu-agent command, the CU agent view and configuration in the view are deleted on the CP, as well as the configuration in CU agent view on the UP.
# Create a CU agent and enter its view. (UPs.)
[Sysname] cu-agent
[Sysname-cu-agent]
Use display protocol-tunnel packet statistics to display the packet statistics of protocol channels.
display protocol-tunnel packet statistics [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays entries for the active MPU.
In the CUPS scenario, the CP and a UP needs to set up a protocol channel to exchange protocol packets. During the protocol packet exchange between the CP and UP, the device will record the protocol packet statistics in the memory, which facilitates troubleshooting when a failure occurs. To view statistics of protocol packets between the CP and the UP, use this command.
# View the packet statistics of the protocol channel between slot 3 of the UP and the CP.
<Sysname> display protocol-tunnel packet statistics slot 3
Input packet statistics:
Total: 2000
PPPoE PADI and PADO: 1000
Other PPPoE: 1000
DHCP DISCOVER and OFFER: 0
Other DHCP: 0
DHCPv6: 0
ND: 0
L2TP: 0
ARP: 0
IPv4 data miss: 0
IPv6 data miss: 0
Ethernet: 0
IPv4: 0
IPv6: 0
Drop: 0
Output packet statistics:
Total: 2000
PPPoE PADI and PADO: 0
Other PPPoE: 2000
Other DHCP: 0
DHCPv6: 0
ND: 0
L2TP: 0
ARP: 0
IPv4 data miss: 0
IPv6 data miss: 0
Ethernet: 0
IPv4: 0
IPv6: 0
Drop: 0
Input packet statistics |
Inbound protocol packet statistics of a protocol tunnel. |
Output packet statistics |
Outbound protocol packet statistics of a protocol tunnel. |
Total |
Total number of packets. |
PPPoE PADI and PADO |
PPPoE PADI and PADO packets. |
Other PPPoE |
Protocol packets except PADI and PADO packets, including PADR, PADS, and PADT packets. |
DHCP DISCOVER and OFFER |
DHCP Discover and Offer packets. |
Other DHCP |
DHCPv4 protocol packets except DHCP Discover and Offer packets. |
DHCPv6 |
DHCPv6 protocol packets. |
ND |
IPv6 ND protocol packets. |
L2TP |
L2TP protocol packets. |
ARP |
ARP protocol packets that the device sends to users. |
IPv4 data miss |
ARP and other IPv4 packets that the users send to the device for triggering user access. |
IPv6 data miss |
Other IPv6 packets that the users send to the device for triggering user access. |
Ethernet |
Others packets that the device sends to users. |
IPv4 |
IPv4 packets in the protocol channel. |
IPv6 |
IPv6 packets in the protocol channel. |
Drop |
Dropped packets. |
Use display protocol-tunnel verbose to display detailed information about the protocol channel between a UP and a CP on the UP.
# Display detailed information about the protocol channel between the UP and a CP on the UP.
<Sysname> display protocol-tunnel verbose
Protocol tunnel:
VXLAN ID: 100
Source IPv4/IPv6 address: 1.1.1.1
Destination IPv4/IPv6 address: 10.1.2.3
VPN instance: abc
State: UP
Active: Yes
Protocol tunnel:
VXLAN ID: 200
Destination IPv4/IPv6 address: 10.1.2.4
State: UP
Active: Yes
Protocol tunnel |
Protocol channel information. |
VXLAN ID |
VXLAN ID of the protocol channel. |
Source IPv4/IPv6 address |
Source IPv4/IPv6 address of the protocol channel. |
Destination IPv4/IPv6 address |
Destination IPv4/IPv6 address of the protocol channel. |
VPN instance |
VPN instance associated with the protocol channel. This field is not displayed when the VPN instance is not configured. |
State |
Protocol channel connection status: · DOWN. · UP. |
Active |
Protocol channel activation status: · No—The protocol channel is not activated. · Yes—The protocol channel is activated. |
Use protocol-tunnel to configure the parameters for the protocol channel between a CP and a UP.
Use undo protocol-tunnel to delete the protocol channel between a CP and a UP.
protocol-tunnel vxlan vxlan-id source { ipv4-address | ipv6 ipv6-address } destination { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
undo protocol-tunnel vxlan vxlan-id source { ipv4-address | ipv6 ipv6-address } destination { ipv4-address | ipv6 ipv6-address }
No protocol channel exists between a CP and a UP.
CU agent view
vxlan vxlan-id: Specifies the VXLAN ID that a UP uses to set up a protocol channel to a CP. The value range for the vxlan-id argument is 1 to 16777215.
source: Specifies the source IP address used by a UP for setting up a protocol channel to a CP.
destination: Specifies the destination IP address used by a UP for setting up a protocol channel to a CP.
ipv4-address: Specifies an IPv4 UP IP address. This address cannot be an all-zeros, all-ones, class-D, class-E, or loopback address.
ipv6 ipv6-address: Specifies an IPv6 UP IP address. This address must be a unicast address and cannot be a loopback or link-local address. If you do not specify this option, an IPv4 UP IP address is specified.
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. The VPN instance is associated with the interface connecting a UP to a CP. If you do not specify this option, the interface connecting a UP to a CP belongs to the public network.
A VXLAN tunnel is set up between a UP and a CP and used as the protocol channel for exchanging protocol packets, such as ARP, IP, and DHCP protocol packets.
When you execute this command, make sure the source IP specified is the destination IP of the protocol channel on the CP, and the destination IP specified is the source IP of the protocol channel on the CP.
The VXLAN tunnels on a CP and UP pair must have the same VXLAN ID.
A CP can be configured with up to two protocol channels, which are typically used in the CPDR scenario.
If you execute this command multiple times with the same VXLAN ID, source IP address, and destination IP address, the most recent configuration takes effect.
Different UPs correspond to different VXLAN tunnels. The source IP address and destination IP address of each VXLAN tunnel must be unique. That is, a source IP address and destination IP address pair corresponds to a unique VXLAN ID.
# In CU agent view, configure parameters for the protocol channel between a UP and a CP, with VXLAN ID 10, source IP 1.1.1.1, and destination IP 2.2.2.2. (UPs.)
[Sysname] cu-agent
[Sysname-cu-agent] protocol-tunnel vxlan 10 source 1.1.1.1 destination 2.2.2.2
reset cp configuration (UPs)
Use reset cp configuration to clear all configuration that a CP deploys to a UP.
CAUTION: When the connection between a CP and a UP is normal, executing this command will clear the cp-management and protocol-tunnel configuration deployed by the CP to the UP and disconnect the CP and UP. As a result, users cannot come online. |
When a UP is permanently disconnected from its CP and not managed by the CP any more, use this command to clear all configuration that the CP has deployed to the UP. After executing this command, manually disconnect the NETCONF session between the CP and UP. Otherwise, when the CP reconnects to the UP, the NETCONF session between the CP and UP cannot be re-connected. As a result, the CP cannot deploy configuration to the UP, and the CP cannot manage the UP.
When a CP and a UP are properly connected, to clear all configuration that the CP deploys to the UP, you must first delete all remote interfaces on the CP.
# Clear all configuration that a CP deploys to a UP.
<Sysname> reset cp configuration
Use reset protocol-tunnel packet statistics to clear the packet statistics of protocol channels.
reset protocol-tunnel packet statistics [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears entries for the active MPU.
In the CUPS scenario, during protocol packet exchange between a CP and a UP, the device will record the protocol packet statistics in the memory, which facilitates troubleshooting when a failure occurs. To prevent the history packet statistics from affecting troubleshooting, first use this command on the UP to clear the packet statistics of protocol channels, and then use the display protocol-tunnel packet statistics to display the new packet statistics of protocol channels.
A CP and a UP collect packet statistics separately. Using this command on the UP to clear the packet statistics protocol channel between the CP and the UP does not affect the packet statistics of protocol channels on the CP.
# Clear the packet statistics of all protocol channels.
<Sysname> reset protocol-tunnel packet statistics
Use snmp-agent trap enable protocol-tunnel to enable SNMP notifications for CP-UP protocol tunnels.
Use undo snmp-agent trap enable protocol-tunnel to disable SNMP notifications for CP-UP protocol tunnels.
SNMP notifications are disabled for CP-UP protocol tunnels.
With this feature enabled on a device, alarms are generated when the protocol tunnel states change. The generated alarms are sent to the SNMP module of the device. You can specify how the alarms are output through setting the alarm output parameters in SNMP.
# Enable SNMP notifications for CP-UP protocol tunnels.
[Sysname] snmp-agent trap enable protocol-tunnel
Use sub-interface inherit-main to configure subinterfaces managed by a main interface on the CP not to report state information
Use undo sub-interface inherit-main to restore the default.
Subinterfaces managed by a main interface on the CP report state information.
By default, the state of a remote subinterface is reported by a UP to the CP through CUSP channels. On CPs of some vendors, the state of remote subinterfaces is inherited from their main interfaces, the CPs do not receive subinterface state information reported by UPs, and UPs do not report subinterface state information. When you interoperate with CPs of these vendors, for compatibility with the subinterface state information processing method, execute this command on the UP to disable the UP from reporting remote subinterface state information.
Execute this command on both a CP and its UPs. If you execute this command on a CP, you must also execute this command on its UPs, and vice versa. Asymmetric configuration of this command might cause the subinterface state information reported by UPs to be lost. As a result, the remote subinterface state on the CP is incorrect.
After you execute this command, as a best practice, do not modify the subinterface state information on a UP. Otherwise, the subinterface resources might be inconsistent on the CP and its UPs.
If this feature is also configured on a CP, when you execute the undo sub-interface inherit-main command, first execute this command on the CP, and then execute this command on the UP. Otherwise, the subinterface resources might be inconsistent on the CP and its UPs.
# Disable subinterfaces managed by a CP from reporting state information.
[Sysname] sub-interface inherit-main
