13-ACL and QoS
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 6715-6W10013-ACL and QoS
05-HH3C-TRNG2-MIB
05-HH3C-TRNG2-MIB 67.89 KB
HH3C-TRNG2-MIB
About this MIB
Use this MIB to configure a time range.
MIB file name
hh3c-trng2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cTRNG2(121)
Tabular objects
hh3cTrangeCreateTimerangeTable
About this table
This table creates a time range.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is h3cTrangeIndex.
Object (OID)
Access
Value range
Implementation
hh3cTrangeIndex (1.3.6.1.4.1.25506.2.121.1.1.1.1)
not-accessible
Integer32
0..2147483647
Time range index.
The value range is 1 to 1024.
hh3cTrangeName (1.3.6.1.4.1.25506.2.121.1.1.1.2)
read-create
OCTET STRING
1..32
Time range name.
As per the MIB.
hh3cTrangeValidFlag (1.3.6.1.4.1.25506.2.121.1.1.1.3)
read-only
TruthValue
Standard MIB values.
Validity flag.
As per the MIB.
hh3cTrangeCreateRowStatus (1.3.6.1.4.1.25506.2.121.1.1.1.4)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cTrangeAbsoluteTable
About this table
This table configures an absolute time range.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are h3cTrangeAbsoluteNameIndex and h3cTrangeAbsoluteSubIndex.
Object (OID)
Access
Value range
Implementation
hh3cTrangeAbsoluteNameIndex (1.3.6.1.4.1.25506.2.121.1.2.1.1)
not-accessible
Integer32
0..2147483647
Time range index.
hh3cTrangeAbsoluteSubIndex (1.3.6.1.4.1.25506.2.121.1.2.1.2)
not-accessible
Integer32
1..12
Subitem index.
The value range is 1 to 12.
hh3cTrangeAbsoluteStartTime (1.3.6.1.4.1.25506.2.121.1.2.1.3)
read-create
DateAndTime
Start date and time of the time range, in the format YYYY-MM-DD,hh:mm:0,0.
As per the MIB.
hh3cTrangeAbsoluteEndTime (1.3.6.1.4.1.25506.2.121.1.2.1.4)
read-create
DateAndTime
End date and time of the time range, in the format YYYY-MM-DD,hh:mm:0,0.
As per the MIB.
hh3cTrangeAbsolueRowStatus (1.3.6.1.4.1.25506.2.121.1.2.1.5)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·      destroy(6)
hh3cTrangePeriodicTable
About this table
This table configures a periodic time range.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are h3cTrangePeriodicNameIndex and h3cTrangePeriodicSubIndex.
Object (OID)
Access
Value range
Implementation
hh3cTrangePeriodicNameIndex (1.3.6.1.4.1.25506.2.121.1.3.1.1)
not-accessible
Integer32
0..2147483647
Time range index.
hh3cTrangePeriodicSubIndex (1.3.6.1.4.1.25506.2.121.1.3.1.2)
not-accessible
Integer32
1..32
Subitem index.
The value range is 1 to 32.
hh3cTrangePeriodicDayOfWeek (1.3.6.1.4.1.25506.2.121.1.3.1.3)
read-create
BITS
·     sunday(0)
·     monday(1)
·     tuesday(2)
·     wednesday(3)
·     thursday(4)
·     friday(5)
·     saturday(6)
Day of the week.
As per the MIB.
hh3cTrangePeriodicStartTime (1.3.6.1.4.1.25506.2.121.1.3.1.4)
read-create
DateAndTime
Start date and time of the time range, in the format hh:mm:0,0.
As per the MIB.
hh3cTrangePeriodicEndTime (1.3.6.1.4.1.25506.2.121.1.3.1.5)
read-create
DateAndTime
End date and time of the time range, in the format hh:mm:0,0.
As per the MIB.
hh3cTrangePeriodicRowStatus (1.3.6.1.4.1.25506.2.121.1.3.1.6)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
