03-HH3C-IFQOS2-MIB | 710.16 KB |
hh3cIfQoSAggregativeCarNextIndex
hh3cIfQoSHardwareQueueRunInfoTable
hh3cIfQoSHQueueTcpRunInfoTable
hh3cIfQoSAggregativeCarConfigTable
hh3cIfQoSAggregativeCarApplyTable
hh3cIfQoSAggregativeCarRunInfoTable
hh3cIfQoSTricolorCarConfigTable
hh3cIfQoSTricolorCarRunInfoTable
hh3cIfQoSWredGroupContentTable
hh3cIfQoSWredGroupApplyIfTable
hh3cIfQoSPortPirorityTrustTable
hh3cIfQoS8QueueResouceOverAlarm
hh3cIfQoS8QueueResouceOverRecover
hh3cIfQoS8QueueResoucePreAlarm
hh3cIfQoS8QueueResoucePreRecover
hh3cIfQoSModeChannelOverPortShapAlarm
hh3cIfQoSModeChannelOverPortShapRecover
hh3cIfQoSExclusiveBandApplyFailAlarm
hh3cIfQoSExclusiveBandApplyFailRecover
hh3cIfQoSExclusiveBandOverAlarm
hh3cIfQoSExclusiveBandOverRecover
hh3cIfQoSLRDiscardAlarmRecover
hh3cIfQoSCarDiscardAlarmRecover
hh3cIfQoSCoppDropPktAlarmRecover
hh3cIfQoSAclMemFullAlarmRecover
hh3cIfQoSQueBufferOverrunAlarm
hh3cIfQoSQueBufferOverrunRecover
hh3cIfQoSRcyPortPktsDropRecover
hh3cIfQoSUniPktsDiscardRecover
hh3cIfQoSIngressDiscardRecover
HH3C-IFQOS2-MIB
About this MIB
Use this MIB to configure or obtain settings for the following modules:
· Hardware queuing.
· Software queuing.
· Rate limit.
· CAR.
· GTS.
· WRED.
· Port priority and priority trust mode.
· Priority map.
CAR includes aggregate CAR and three-color CAR. WRED includes table-based WRED and interface WRED.
WRED
WRED avoids global TCP synchronization by randomly dropping packets before a queue is full. WRED sets an upper threshold and lower threshold for each queue, and processes the packets in a queue as follows:
· When the queue size is shorter than the lower threshold, no packet is dropped.
· When the queue size reaches the upper threshold, all subsequent packets are dropped.
· When the queue size is between the lower threshold and the upper threshold, the received packets are dropped at random. The drop probability in a queue increases along with the queue size under the maximum drop probability.
WRED can discard packets based on the IP precedence, DSCP, or MPLS EXP value and selectively discard low-priority packets.
Through combining WRED with WFQ, the flow-based WRED can be realized.
WRED has the following types:
· Port-based WRED: Applies WRED to all packets on a port.
· Queue-based WRED: Applies WRED to only packets on WRED-enabled queues.
· Drop level-based WRED: Applies different WRED parameters to packets with different WRED parameters.
· ACL-based WRED: Applies different WRED parameters to packets matching different ACLs.
· 802.1p-based WRED: Applies different WRED parameters to packets with different 802.1p priorities.
· EXP-based WRED: Applies different WRED parameters to packets with different EXP priorities.
· ATM CLP-based WRED: Applies different WRED parameters to packets with different CLP priorities.
· DSCP-based WRED: Applies different WRED parameters to packets with different DSCP values.
· IP precedence-based WRED: Applies different WRED parameters to packets with different IP precedences.
· FR DE-based WRED: Applies different WRED parameters to packets with different DE bit settings.
ComwareV500R002 supports two WRED configuration approaches:
· Interface configuration—Configure WRED parameters on an interface or PVC and enable WRED.
· WRED table configuration—Configure a WRED table in system view and then apply the WRED table to an interface. A maximum number of 64 WRED tables is supported.
Aggregate CAR
Some switch models support aggregate CAR.
An aggregate CAR action is created globally. It can be directly applied to interfaces or used in the traffic behaviors associated with different traffic classes to police multiple traffic flows as a whole. The total rate of the traffic flows must conform to the traffic policing specifications set in the aggregate CAR action.
MIB file name
hh3c-ifqos2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).huawei(2011).hh3c(10).hh3cCommon(2).hh3cQos2(65).hh3cIfQos2(1)
Scalar objects
hh3cIfQoSChassis
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSChassis (1.3.6.1.4.1.25506.2.65.1.15.1) |
accessible-for-notify |
Integer32 |
0..65534 |
Chassis number. |
hh3cIfQoSSlot
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSSlot (1.3.6.1.4.1.25506.2.65.1.15.2) |
Integer32 |
0..65534 |
Slot number. |
hh3cIfQoSCPU
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSCPU (1.3.6.1.4.1.25506.2.65.1.15.3) |
Integer32 |
0..65534 |
CPU number. |
hh3cIfQoSChip
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSChip (1.3.6.1.4.1.25506.2.65.1.15.4) |
Integer32 |
0..65534 |
Chip number. |
hh3cIfQoSIfName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSIfName (1.3.6.1.4.1.25506.2.65.1.15.5) |
OCTET STRING |
SIZE (1..47) |
Interface name. |
hh3cIfQoSDirection
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSDirection (1.3.6.1.4.1.25506.2.65.1.15.6) |
Direction |
Standard MIB values. |
Direction. |
hh3cIfQoSPassPacketRate
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSPassPacketRate (1.3.6.1.4.1.25506.2.65.1.15.7) |
read-only |
Unsigned32 |
Traffic rate. |
hh3cIfQoSCoppProtocol
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSCoppProtocol (1.3.6.1.4.1.25506.2.65.1.15.8) |
read-only |
OCTET STRING |
SIZE (1..31) |
Protocol type. |
hh3cIfQoSBandwidth
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSBandwidth (1.3.6.1.4.1.25506.2.65.1.15.9) |
read-only |
Unsigned32 |
Bandwidth. |
hh3cIfQoSServiceName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSServiceName (1.3.6.1.4.1.25506.2.65.1.15.10) |
read-only |
OCTET STRING |
SIZE (1..63) |
Service name. |
hh3cIfQoSApplyObject
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSApplyObject (1.3.6.1.4.1.25506.2.65.1.15.11) |
read-only |
OCTET STRING |
SIZE (1..127) |
Application object. |
hh3cIfQoSFailReason
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSFailReason (1.3.6.1.4.1.25506.2.65.1.15.12) |
read-only |
OCTET STRING |
SIZE (1..127) |
Failure causes. |
hh3cIfQoSBandwidthUnit
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSBandwidthUnit (1.3.6.1.4.1.25506.2.65.1.15.13) |
read-only |
INTEGER |
· unitUnavailable (0) · unitAbsolute (1) · unitAbsolutePPS (4) |
Bandwidth unit. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
1.3.6.1.4.1.25506.2.65.1.4.1.1 (hh3cIfQoSAggregativeCarNextIndex) |
read-only |
Integer32 |
1..65534 |
Aggregate CAR index. |
As per the MIB. |
hh3cIfQoSWredGroupNextIndex
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
1.3.6.1.4.1.25506.2.65.1.6.1.1 (hh3cIfQoSWredGroupNextIndex) |
read-only |
Integer32 |
0..256 |
WRED group index. |
Implementation varies by product. |
hh3cQoSTypeOfServiceMode
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
1.3.6.1.4.1.25506.2.65.1.12.7.1 (hh3cQoSTypeOfServiceMode) |
read-write |
Integer32 |
· disabled (1) · ipPrecedence (2) · dscp (3) · disabled (4) |
Global service type. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
1.3.6.1.4.1.25506.2.65.1.13.1 (hh3cIfQoSProcessingStatus) |
read-only |
Integer32 |
· idle (1) · busy (2) |
QoS module processing status. |
Tabular objects
hh3cIfQoSQSModeTable
About this table
This table specifies the queuing mode. This table and hh3cIfQoSQSWeightTable together configure the queuing settings.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSQSMode (1.3.6.1.4.1.25506.2.65.1.1.1.1.1.1) |
read-write |
INTEGER |
· sp(1) · sp0(2) · sp1(3) · sp2(4) · wrr(5) · hwfq(6) · wrr-sp(7) · byteCountWrr(8)byteCountWfq(9) · gmb(10) |
Queuing mode. |
About this table
This table configures attributes for non-SP queues. This table and hh3cIfQoSQSModeTable together configure the queuing settings.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are ifIndex and hh3cIfQoSQueueID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSQueueID (1.3.6.1.4.1.25506.2.65.1.1.1.2.1.1) |
not-accessible |
Integer32 |
Queue ID. |
As per the MIB. |
hh3cIfQoSQueueGroupType (1.3.6.1.4.1.25506.2.65.1.1.1.2.1.2) |
read-write |
INTEGER |
· group0(1) · group1(2) · group2(3) · group3(4) · group4(5) |
WRR group. |
hh3cIfQoSQSType (1.3.6.1.4.1.25506.2.65.1.1.1.2.1.3) |
read-write |
INTEGER |
· weight(1) · byte-count(2) |
Queuing type. |
As per the MIB. |
hh3cIfQoSQSValue (1.3.6.1.4.1.25506.2.65.1.1.1.2.1.4) |
read-write |
Integer32 |
Scheduling weight. |
As per the MIB. |
hh3cIfQoSQSMaxDelay (1.3.6.1.4.1.25506.2.65.1.1.1.2.1.5) |
read-write |
Integer32 |
Maximum delay. |
Not supported. The value is fixed at 9. |
hh3cIfQoSQSMinBandwidth (1.3.6.1.4.1.25506.2.65.1.1.1.2.1.6) |
read-write |
Integer32 |
Minimum guaranteed bandwidth. |
hh3cIfQoSQSMinBandwidthPercent(1.3.6.1.4.1.25506.2.65.1.1.1.2.1.7) |
read-write |
Unsigned32 |
· 0..100 · 255 |
Percentage of the minimum guaranteed bandwidth to the available bandwidth. |
About this table
This table contains queue-based traffic statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSPassPackets (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.1) |
read-only |
Counter64 |
Number of forwarded packets. |
As per the MIB. |
hh3cIfQoSDropPackets (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.2) |
read-only |
Counter64 |
Number of dropped packets. |
As per the MIB. |
hh3cIfQoSPassBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.3) |
read-only |
Counter64 |
Number of forwarded bytes. |
As per the MIB. |
hh3cIfQoSPassPPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.4) |
read-only |
Unsigned32 |
Packet forwarding rate in packets per second. |
As per the MIB. |
hh3cIfQoSPassBPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.5) |
read-only |
Unsigned32 |
Packet forwarding rate in bytes per second. |
As per the MIB. |
hh3cIfQoSDropBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.6) |
read-only |
Counter64 |
Number of dropped bytes. |
As per the MIB. |
hh3cIfQoSQueueLengthInPkts (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.7) |
read-only |
Unsigned32 |
Maximum queue length in packets. |
As per the MIB. |
hh3cIfQoSQueueLengthInBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.8) |
read-only |
Unsigned32 |
Maximum queue length in bytes. |
Not supported |
hh3cIfQoSCurQueuePkts (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.9) |
read-only |
Unsigned32 |
Current queue length in packets. |
Not supported |
hh3cIfQoSCurQueueBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.10) |
read-only |
Unsigned32 |
Current queue length in bytes. |
Not supported |
hh3cIfQoSCurQueuePPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.11) |
read-only |
Unsigned32 |
Number of packets enqueued per second. |
Not supported |
hh3cIfQoSCurQueueBPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.12) |
read-only |
Unsigned32 |
Number of bytes enqueued per second. |
Not supported |
hh3cIfQoSTailDropPkts (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.13) |
read-only |
Counter64 |
Number of packets dropped by tail drop. |
Not supported |
hh3cIfQoSTailDropBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.14) |
read-only |
Counter64 |
Number of bytes dropped by tail drop. |
Not supported |
hh3cIfQoSTailDropPPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.15) |
read-only |
Unsigned32 |
Number of packets dropped per second by tail drop. |
Not supported |
hh3cIfQoSTailDropBPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.16) |
read-only |
Unsigned32 |
Number of bytes dropped per second by tail drop. |
Not supported |
hh3cIfQoSWredDropPkts (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.17) |
read-only |
Counter64 |
Number of packets dropped by WRED. |
Not supported |
hh3cIfQoSWredDropBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.18) |
read-only |
Counter64 |
Number of bytes dropped by WRED. |
Not supported |
hh3cIfQoSWredDropPPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.19) |
read-only |
Unsigned32 |
Number of packets dropped per second by WRED. |
Not supported |
hh3cIfQoSWredDropBPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.20) |
read-only |
Unsigned32 |
Number of bytes dropped per second by WRED. |
Not supported |
hh3cIfQoSPeakPassPPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.24) |
read-only |
Unsigned32 |
Peak number of packets forwarded. |
As per the MIB. |
hh3cIfQoSPeakPassBPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.25) |
read-only |
Unsigned32 |
Peak number of bytes forwarded. |
As per the MIB. |
About this table
This table contains queue-based traffic statistics on TCP packets and non-TCP packets.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSWredDropLPreNTcpPkts (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.1) |
read-only |
Counter64 |
Number of low-priority non-TCP packets dropped by WRED. |
As per the MIB. |
hh3cIfQoSWredDropLPreNTcpBytes (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.2) |
read-only |
Counter64 |
Number of low-priority non-TCP bytes dropped by WRED. |
As per the MIB. |
hh3cIfQoSWredDropLPreNTcpPPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.3) |
read-only |
Unsigned32 |
Number of low-priority non-TCP packets dropped by WRED per second. |
As per the MIB. |
hh3cIfQoSWredDropLPreNTcpBPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.4) |
read-only |
Unsigned32 |
Number of low-priority non-TCP bytes dropped by WRED per second. |
As per the MIB. |
hh3cIfQoSWredDropLPreTcpPkts (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.5) |
read-only |
Counter64 |
Number of low-priority TCP packets dropped by WRED. |
As per the MIB. |
hh3cIfQoSWredDropLPreTcpBytes (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.6) |
read-only |
Counter64 |
Number of low-priority TCP bytes dropped by WRED. |
As per the MIB. |
hh3cIfQoSWredDropLPreTcpPPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.7) |
read-only |
Unsigned32 |
Number of low-priority TCP packets dropped by WRED per second. |
As per the MIB. |
hh3cIfQoSWredDropLPreTcpBPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.8) |
read-only |
Unsigned32 |
Number of low-priority TCP bytes dropped by WRED per second. |
As per the MIB. |
hh3cIfQoSWredDropHPreNTcpPkts (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.9) |
read-only |
Counter64 |
Number of high-priority non-TCP packets dropped by WRED. |
As per the MIB. |
hh3cIfQoSWredDropHPreNTcpBytes (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.10) |
read-only |
Counter64 |
Number of high-priority non-TCP bytes dropped by WRED. |
As per the MIB. |
hh3cIfQoSWredDropHPreNTcpPPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.11) |
read-only |
Unsigned32 |
Number of high-priority non-TCP packets dropped by WRED per second. |
As per the MIB. |
hh3cIfQoSWredDropHPreNTcpBPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.12) |
read-only |
Unsigned32 |
Number of high-priority non-TCP bytes dropped by WRED per second. |
As per the MIB. |
hh3cIfQoSWredDropHPreTcpPkts (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.13) |
read-only |
Counter64 |
Number of high-priority TCP packets dropped by WRED. |
As per the MIB. |
hh3cIfQoSWredDropHPreTcpBytes (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.14) |
read-only |
Counter64 |
Number of high-priority TCP bytes dropped by WRED. |
As per the MIB. |
hh3cIfQoSWredDropHPreTcpPPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.15) |
read-only |
Unsigned32 |
Number of high-priority TCP packets dropped by WRED per second. |
As per the MIB. |
hh3cIfQoSWredDropHPreTcpBPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.16) |
read-only |
Unsigned32 |
Number of high-priority TCP bytes dropped by WRED per second. |
As per the MIB. |
hh3cIfQoSLRConfigTable
About this table
This table configures the inbound or outbound rate limit on an interface.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are ifIndex and hh3cIfQoSLRDirection.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSLRDirection (1.3.6.1.4.1.25506.2.65.1.3.1.1.1) |
not-accessible |
Direction |
Rate limit direction. |
hh3cIfQoSLRCir (1.3.6.1.4.1.25506.2.65.1.3.1.1.2) |
read-create |
Unsigned32 |
CIR. |
hh3cIfQoSLRCbs (1.3.6.1.4.1.25506.2.65.1.3.1.1.3) |
read-create |
Unsigned32 |
CBS. |
hh3cIfQoSLREbs (1.3.6.1.4.1.25506.2.65.1.3.1.1.4) |
read-create |
Unsigned32 |
EBS. |
hh3cIfQoSRowStatus (1.3.6.1.4.1.25506.2.65.1.3.1.1.5) |
read-create |
RowStatus |
Row status. |
· active(1) · createAndGo(4) · destroy(6) |
hh3cIfQoSLRPir (1.3.6.1.4.1.25506.2.65.1.3.1.1.6) |
read-create |
Unsigned32 |
PIR. |
hh3cIfQoSLRUnit (1.3.6.1.4.1.25506.2.65.1.3.1.1.7) |
read-create |
INTEGER |
· unitAbsolute(1) · unitPercent(2) |
Rate limit unit. |
hh3cIfQoSLRRunInfoTable
About this table
This table contains rate limit statistics on an interface.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSLRRunInfoPassedPackets (1.3.6.1.4.1.25506.2.65.1.3.2.1.1) |
read-only |
Counter64 |
As per the MIB. |
hh3cIfQoSLRRunInfoPassedBytes (1.3.6.1.4.1.25506.2.65.1.3.2.1.2) |
read-only |
Counter64 |
As per the MIB. |
hh3cIfQoSLRRunInfoDelayedPackets (1.3.6.1.4.1.25506.2.65.1.3.2.1.3) |
read-only |
Counter64 |
Number of delayed packets. |
As per the MIB. |
hh3cIfQoSLRRunInfoDelayedBytes (1.3.6.1.4.1.25506.2.65.1.3.2.1.4) |
read-only |
Counter64 |
Number of delayed bytes. |
As per the MIB. |
hh3cIfQoSLRRunInfoActiveShaping (1.3.6.1.4.1.25506.2.65.1.3.2.1.5) |
read-only |
INTEGER |
· active(1) · inactive(2) |
Rate limit configuration status. |
As per the MIB. |
About this table
This table contains aggregate CAR configuration, which can police the traffic on multiple ports. Routers do not support aggregate CAR. Some switch models support aggregate CAR.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cIfQoSAggregativeCarIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSAggregativeCarIndex (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.1) |
not-accessible |
Integer32 |
1..65534 |
As per the MIB. |
hh3cIfQoSAggregativeCarName (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.2) |
read-create |
OCTET STRING |
SIZE (1..31) |
Aggregate CAR name. |
As per the MIB. |
hh3cIfQoSAggregativeCarCir (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.3) |
read-create |
Unsigned32 |
CIR. |
As per the MIB. |
hh3cIfQoSAggregativeCarCbs (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.4) |
read-create |
Unsigned32 |
CBS. |
hh3cIfQoSAggregativeCarEbs (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.5) |
read-create |
Unsigned32 |
EBS. |
hh3cIfQoSAggregativeCarPir (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.6) |
read-create |
Unsigned32 |
PIR. |
hh3cIfQoSAggregativeCarGreenActionType (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.7) |
read-create |
Hh3cIfCarAction |
Action to take on green packets. |
hh3cIfQoSAggregativeCarGreenActionValue (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.8) |
read-create |
Integer32 |
· 0..63 · 255 |
Value to mark for green packets. |
hh3cIfQoSAggregativeCarYellowActionType (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.9) |
read-create |
Hh3cIfCarAction |
Action to take on yellow packets. |
hh3cIfQoSAggregativeCarYellowActionValue (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.10) |
read-create |
Integer32 |
· 0..63 · 255 |
Value to mark for yellow packets. |
hh3cIfQoSAggregativeCarRedActionType (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.11) |
read-create |
Hh3cIfCarAction |
Action to take on red packets. |
hh3cIfQoSAggregativeCarRedActionValue (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.12) |
read-create |
Integer |
· 0..63 · 255 |
Value to mark for red packets. |
hh3cIfQoSAggregativeCarType (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.13) |
read-create |
INTEGER |
· aggregative(1) · NotAggregative(2) · hierarchy(3) |
Aggregate CAR type. |
hh3cIfQoSAggregativeCarRowStatus (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.14) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
About this table
This table contains aggregate CAR application information for an interface.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are ifIndex, hh3cIfQoSAggregativeCarApplyDirection, hh3cIfQoSAggregativeCarApplyRuleType, and hh3cIfQoSAggregativeCarApplyRuleValue.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSAggregativeCarApplyDirection (1.3.6.1.4.1.25506.2.65.1.4.1.3.1.1) |
not-accessible |
Direction |
CAR direction. |
hh3cIfQoSAggregativeCarApplyRuleType (1.3.6.1.4.1.25506.2.65.1.4.1.3.1.2) |
not-accessible |
INTEGER |
· ipv4acl(1) · ipv6acl(2) · carl(3) · any(4) |
CAR type. |
hh3cIfQoSAggregativeCarApplyRuleValue (1.3.6.1.4.1.25506.2.65.1.4.1.3.1.3) |
not-accessible |
Integer32 |
0..2147483647 |
CAR type value. |
.Implementation varies by product. |
hh3cIfQoSAggregativeCarApplyCarIndex (1.3.6.1.4.1.25506.2.65.1.4.1.3.1.4) |
read-create |
Integer32 |
1..65534 |
As per the MIB. |
hh3cIfQoSAggregativeCarApplyRowStatus (1.3.6.1.4.1.25506.2.65.1.4.1.3.1.5) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
About this table
This table contains aggregate CAR statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSAggregativeCarGreenPackets (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.1) |
read-only |
Counter64 |
Number of green packets. |
hh3cIfQoSAggregativeCarGreenBytes (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.2) |
read-only |
Counter64 |
Number of green bytes. |
hh3cIfQoSAggregativeCarYellowPackets (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.3) |
read-only |
Counter64 |
Number of yellow packets. |
hh3cIfQoSAggregativeCarYellowBytes (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.4) |
read-only |
Counter64 |
Number of yellow bytes. |
hh3cIfQoSAggregativeCarRedPackets (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.5) |
read-only |
Counter64 |
Number of red packets. |
hh3cIfQoSAggregativeCarRedBytes (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.6) |
read-only |
Counter64 |
Number of red bytes. |
About this table
This table contains three-color CAR configuration.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSTricolorCarDirection (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.1) |
not-accessible |
Direction |
hh3cIfQoSTricolorCarType (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.2) |
not-accessible |
INTEGER |
hh3cIfQoSTricolorCarValue (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.3) |
not-accessible |
Integer32 |
0..2147483647 |
CAR. |
hh3cIfQoSTricolorCarCir (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.4) |
read-create |
Unsigned32 |
CIR. |
hh3cIfQoSTricolorCarCbs (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.5) |
read-create |
Unsigned32 |
CBS. |
hh3cIfQoSTricolorCarEbs (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.6) |
read-create |
Unsigned32 |
EBS. |
hh3cIfQoSTricolorCarPir (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.7) |
read-create |
Unsigned32 |
PIR. |
hh3cIfQoSTricolorCarGreenActionType (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.8) |
read-create |
Hh3cIfCarAction |
hh3cIfQoSTricolorCarGreenActionValue (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.9) |
read-create |
Integer32 |
· 0..63 · 255 |
hh3cIfQoSTricolorCarYellowActionType (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.10) |
read-create |
Hh3cIfCarAction |
hh3cIfQoSTricolorCarYellowActionValue (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.11) |
read-create |
Integer32 |
· 0..63 · 255 |
hh3cIfQoSTricolorCarRedActionType (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.12) |
read-create |
Hh3cIfCarAction |
hh3cIfQoSTricolorCarRedActionValue (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.13) |
read-create |
Integer32 |
· 0..63 · 255 |
hh3cIfQoSTricolorCarRowStatus (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.14) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cIfQoSTricolorCarUnitType (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.15) |
read-create |
INTEGER |
Rate limit unit. |
About this table
This table contains three-color CAR statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ifIndex, hh3cIfQoSTricolorCarDirection, hh3cIfQoSTricolorCarType, and hh3cIfQoSTricolorCarValue.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSTricolorCarGreenPackets (1.3.6.1.4.1.25506.2.65.1.4.2.2.1.1) |
read-only |
Counter64 |
hh3cIfQoSTricolorCarGreenBytes (1.3.6.1.4.1.25506.2.65.1.4.2.2.1.2) |
read-only |
Counter64 |
hh3cIfQoSTricolorCarYellowPackets (1.3.6.1.4.1.25506.2.65.1.4.2.2.1.3) |
read-only |
Counter64 |
hh3cIfQoSTricolorCarYellowBytes (1.3.6.1.4.1.25506.2.65.1.4.2.2.1.4) |
read-only |
Counter64 |
hh3cIfQoSTricolorCarRedPackets (1.3.6.1.4.1.25506.2.65.1.4.2.2.1.5) |
read-only |
Counter64 |
hh3cIfQoSTricolorCarRedBytes (1.3.6.1.4.1.25506.2.65.1.4.2.2.1.6) |
read-only |
Counter64 |
hh3cIfQoSGTSConfigTable
About this table
This table contains GTS configuration information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are ifIndex, hh3cIfQoSGTSClassRuleType, and hh3cIfQoSGTSClassRuleValue.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSGTSClassRuleType (1.3.6.1.4.1.25506.2.65.1.5.1.1.1) |
not-accessible |
INTEGER |
· any(1) · ipv4acl(2) · ipv6acl(3) · queue(4) |
GTS type. |
Supports only queue(4). |
hh3cIfQoSGTSClassRuleValue (1.3.6.1.4.1.25506.2.65.1.5.1.1.2) |
not-accessible |
Integer32 |
0..2147483647 |
GTS type value. |
The value range is 0 to 7. |
hh3cIfQoSGTSCir (1.3.6.1.4.1.25506.2.65.1.5.1.1.3) |
read-create |
Unsigned32 |
CIR. |
· The value range is 300 to 1000000 for GE interfaces. · The value range is 300 to 10000000 for 10-GE interfaces. · The value range is 300 to 40000000 for 40-GE interfaces. · The value range is 300 to 100000000 for 100-GE interfaces. |
hh3cIfQoSGTSCbs (1.3.6.1.4.1.25506.2.65.1.5.1.1.4) |
read-create |
Unsigned32 |
CBS. |
· The value range is 4096 to 133169152 for GE interfaces. · The value range is 4096 to 133169152 for 10-GE interfaces. · The value range is 4096 to 535822336 for 40-GE interfaces. · The value range is 4096 to 1341128704 for 100-GE interfaces. |
hh3cIfQoSGTSEbs (1.3.6.1.4.1.25506.2.65.1.5.1.1.5) |
read-create |
Unsigned32 |
EBS in bytes. |
Not supported. |
hh3cIfQoSGTSQueueLength (1.3.6.1.4.1.25506.2.65.1.5.1.1.6) |
read-create |
Integer32 |
Queue length. |
Not supported. |
hh3cIfQoSGTSConfigRowStatus (1.3.6.1.4.1.25506.2.65.1.5.1.1.7) |
read-create |
RowStatus |
Row status. |
hh3cIfQoSGTSPir (1.3.6.1.4.1.25506.2.65.1.5.1.1.8) |
read-create |
Unsigned32 |
PIR. |
Not supported. |
hh3cIfQoSGTSUnitType (1.3.6.1.4.1.25506.2.65.1.5.1.1.9) |
read-create |
INTEGER |
· unitAbsolute (1) · unitPercent(2) |
GTS unit. |
Supports only unitAbsolute(1). |
hh3cIfQoSGTSRunInfoTable
About this table
This table contains GTS statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSGTSQueueSize (1.3.6.1.4.1.25506.2.65.1.5.2.1.1) |
read-only |
Integer32 |
Current number of packets in the queue. |
As per the MIB. |
hh3cIfQoSGTSPassedPackets (1.3.6.1.4.1.25506.2.65.1.5.2.1.2) |
read-only |
Counter64 |
As per the MIB. |
hh3cIfQoSGTSPassedBytes (1.3.6.1.4.1.25506.2.65.1.5.2.1.3) |
read-only |
Counter64 |
As per the MIB. |
hh3cIfQoSGTSDiscardPackets (1.3.6.1.4.1.25506.2.65.1.5.2.1.4) |
read-only |
Counter64 |
As per the MIB. |
hh3cIfQoSGTSDiscardBytes (1.3.6.1.4.1.25506.2.65.1.5.2.1.5) |
read-only |
Counter64 |
As per the MIB. |
hh3cIfQoSGTSDelayedPackets (1.3.6.1.4.1.25506.2.65.1.5.2.1.6) |
read-only |
Counter64 |
As per the MIB. |
hh3cIfQoSGTSDelayedBytes (1.3.6.1.4.1.25506.2.65.1.5.2.1.7) |
read-only |
Counter64 |
As per the MIB. |
hh3cIfQoSWredGroupTable
About this table
This table creates a WRED table.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cIfQoSWredGroupIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSWredGroupIndex (1.3.6.1.4.1.25506.2.65.1.6.1.2.1.1) |
not-accessible |
Integer32 |
0..256 |
WRED table index. |
hh3cIfQoSWredGroupName (1.3.6.1.4.1.25506.2.65.1.6.1.2.1.2) |
read-create |
OCTET STRING |
SIZE (1..32) |
WRED table name. |
As per the MIB. |
hh3cIfQoSWredGroupType (1.3.6.1.4.1.25506.2.65.1.6.1.2.1.3) |
read-create |
INTEGER |
· userdefined(0) · dot1p(1) · ippre(2) · dscp(3) · localpre(4) · atmclp(5) · frde(6) · exp(7) · queue(8) · dropLevel(9) |
WRED table type. |
hh3cIfQoSWredGroupWeightingConstant (1.3.6.1.4.1.25506.2.65.1.6.1.2.1.4) |
read-create |
Integer32 |
1..15 |
WRED exponent for average queue size calculation. |
The default value is 9. |
hh3cIfQoSWredGroupRowStatus (1.3.6.1.4.1.25506.2.65.1.6.1.2.1.6) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
About this table
This table configures a WRED table.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are hh3cIfQoSWredGroupIndex, hh3cIfQoSWredGroupContentIndex, and hh3cIfQoSWredGroupContentSubIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSWredGroupContentIndex (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.1) |
not-accessible |
Integer32 |
0..63 |
Second index. |
hh3cIfQoSWredGroupContentSubIndex (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.2) |
not-accessible |
Integer32 |
0..63 |
Third index. |
hh3cIfQoSWredLowLimit (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.3) |
read-create |
Integer32 |
Lower limit. |
hh3cIfQoSWredHighLimit (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.4) |
read-create |
Integer32 |
Higher limit. |
hh3cIfQoSWredDiscardProb (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.5) |
read-create |
Integer32 |
Drop probability. |
hh3cIfQoSWredGroupExponent (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.6) |
read-create |
Integer32 |
0..15 |
hh3cIfQoSWredRowStatus (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.7) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
About this table
This table contains WRED table application information for an interface.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSWredGroupApplyIndex (1.3.6.1.4.1.25506.2.65.1.6.1.4.1.1) |
read-create |
Integer32 |
0..256 |
WRED table index. |
As per the MIB. |
hh3cIfQoSWredGroupApplyName (1.3.6.1.4.1.25506.2.65.1.6.1.4.1.2) |
read-only |
OCTET STRING |
SIZE (1..32) |
WRED table name. |
As per the MIB. |
hh3cIfQoSWredGroupIfRowStatus (1.3.6.1.4.1.25506.2.65.1.6.1.4.1.3) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cIfQoSPortPriorityTable
About this table
This table contains the port priority. After the switch receives a packet, it performs priority mapping according to the configured priority trust mode. If no local precedence is successfully assigned or no packet priority is trusted, the switch uses the priority of the input interface as the local precedence or 802.1p priority for priority mapping. Routers do not support this table.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSPortPriorityValue (1.3.6.1.4.1.25506.2.65.1.7.1.1.1.1) |
read-write |
Integer32 |
0..7 |
Port priority. |
About this table
This table contains the priority trust mode.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSPortPriorityTrustTrustType (1.3.6.1.4.1.25506.2.65.1.7.1.2.1.1) |
read-write |
INTEGER |
· untrust(1) · dot1p(2) · dscp(3) · exp(4) · ipPrecedence (5) · dot11e(6) · auto(7) |
Priority trust mode. |
hh3cIfQoSPortPriorityTrustOvercastType (1.3.6.1.4.1.25506.2.65.1.7.1.2.1.2) |
read-write |
INTEGER |
· noOvercast(1) · overcastDSCP(2) · overcastCOS(3) · overcast(4) |
Overwrite mode. |
hh3cIfQoSPrePriMapTable
About this table
This table configures a priority map.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are hh3cIfQoSPrePriMapTableType, hh3cIfQoSPrePriMapTableColor, hh3cIfQoSPrePriMapTableDirection, and hh3cIfQoSPrePriMapTableImportValue.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSPrePriMapTableType (1.3.6.1.4.1.25506.2.65.1.9.1.4.1.1) |
not-accessible |
INTEGER |
· dot1pToLp(1) · dot1pToDp(2) · expToLp(3) · dscpToLp(4) · expToDp(5) · dscpToDp(6) · dscpToDot1p(7) · dot1pToDscp(8) · dscpToDscp(9) · dscpToExp(10) · expToDscp(11) · expToDot1p(12) · expToExp(13) · lpToDot1p(14) · dot1pToRpr(15) · dscpToRpr(16) · expToRpr(17) · ippreToRpr(18) · upToDot1p(19) · upToDscp(20) · upToExp(21) · upToDp(22) · upToLp(23) · upToRpr(24) · upToFc(25) · lpTodscp(26) · dot11eToLp(27) · lpToDot11e(28) · lpToLp(29) · dot1pToExp(30) · lpToExp(31) · lpToDp(32) · upToUp(33) · dot1pToDot1p(34) |
Priority map type. |
hh3cIfQoSPrePriMapTableColor (1.3.6.1.4.1.25506.2.65.1.9.1.4.1.2) |
not-accessible |
INTEGER |
· nocolor(1) · green(2) · yellow(3) · red(4) |
Priority map color. |
hh3cIfQoSPrePriMapTableDirection (1.3.6.1.4.1.25506.2.65.1.9.1.4.1.3) |
not-accessible |
INTEGER |
· nodirection(1) · inbound(2) · outbound(3) |
Priority map direction. |
hh3cIfQoSPrePriMapTableImportValue (1.3.6.1.4.1.25506.2.65.1.9.1.4.1.4) |
not-accessible |
Integer32 |
0..63 |
Input values of the priority map. |
As per the MIB. |
hh3cIfQoSPrePriMapTableExportValue (1.3.6.1.4.1.25506.2.65.1.9.1.4.1.5) |
read-write |
Integer32 |
0..63 |
Output values of the priority map. |
As per the MIB. |
hh3cQoSRemarkTcpPortPriTable
About this table
This table contains TCP port-based priority information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cQoSRemarkTcpPortStart.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cQoSRemarkTcpPortStart(1.3.6.1.4.1.25506.2.65.1.12.1.1.1) |
not-accessible |
Integer32 |
0..65535 |
Start port number of a TCP port range. |
As per the MIB. |
hh3cQoSRemarkTcpPortEnd (1.3.6.1.4.1.25506.2.65.1.12.1.1.2) |
read-create |
Integer32 |
0..65535 |
End port number of a TCP port range. |
As per the MIB. |
hh3cQoSRemarkTcpPortType (1.3.6.1.4.1.25506.2.65.1.12.1.1.3) |
read-create |
INTEGER |
· ipAll(1) · ipv4(2) · ipv6(3) |
IP type of matching packets. |
As per the MIB. |
hh3cQoSRemarkTcpPortDot1p (1.3.6.1.4.1.25506.2.65.1.12.1.1.4) |
read-create |
Unsigned32 |
· 0..7 · 255 |
802.1p priority value of matching packets. |
As per the MIB. |
hh3cQoSRemarkTcpPortDscp (1.3.6.1.4.1.25506.2.65.1.12.1.1.5) |
read-create |
Unsigned32 |
· 0..63 · 255 |
DSCP value of matching packets. |
As per the MIB. |
hh3cQoSRemarkTcpPortRowStatus (1.3.6.1.4.1.25506.2.65.1.12.1.1.6) |
read-create |
RowStatus |
Row status. |
hh3cQoSRemarkUdpPortPriTable
About this table
This table contains UDP port-based priority information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Columns
The table index is hh3cQoSRemarkUdpPortStart.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cQoSRemarkUdpPortStart (1.3.6.1.4.1.25506.2.65.1.12.2.1.1) |
not-accessible |
Integer32 |
0..65535 |
Start port number of a UDP port range. |
As per the MIB. |
hh3cQoSRemarkUdpPortEnd (1.3.6.1.4.1.25506.2.65.1.12.2.1.2) |
read-create |
Integer32 |
0..65535 |
End port number of the UDP port range. |
As per the MIB. |
hh3cQoSRemarkUdpPortType (1.3.6.1.4.1.25506.2.65.1.12.2.1.3) |
read-create |
INTEGER |
As per the MIB. |
hh3cQoSRemarkUdpPortDot1p (1.3.6.1.4.1.25506.2.65.1.12.2.1.4) |
read-create |
Unsigned32 |
· 0..7 · 255 |
As per the MIB. |
hh3cQoSRemarkUdpPortDscp (1.3.6.1.4.1.25506.2.65.1.12.2.1.5) |
read-create |
Unsigned32 |
· 0..63 · 255 |
As per the MIB. |
hh3cQoSRemarkUdpPortRowStatus(1.3.6.1.4.1.25506.2.65.1.12.2.1.6) |
read-create |
RowStatus |
Row status. |
hh3cQoSRemarkIPv4AddrPriTable
About this table
This table contains IPv4 address-based priority information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cQoSRemarkIPv4AddrValue.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cQoSRemarkIPv4AddrValue (1.3.6.1.4.1.25506.2.65.1.12.3.1.1) |
not-accessible |
IpAddress |
IPv4 address. |
As per the MIB. |
hh3cQoSRemarkIPv4AddrMask (1.3.6.1.4.1.25506.2.65.1.12.3.1.2) |
read-create |
IpAddress |
Mask for the IPv4 address. |
As per the MIB. |
hh3cQoSRemarkIPv4AddrMaskLength (1.3.6.1.4.1.25506.2.65.1.12.3.1.3) |
read-create |
Unsigned32 |
· 1..32 · 4294967295 |
Mask length for the IPv4 address |
As per the MIB. |
hh3cQoSRemarkIPv4AddrDot1p (1.3.6.1.4.1.25506.2.65.1.12.3.1.4) |
read-create |
Unsigned32 |
· 0..7 · 255 |
As per the MIB. |
hh3cQoSRemarkIPv4AddrDscp (1.3.6.1.4.1.25506.2.65.1.12.3.1.5) |
read-create |
Unsigned32 |
· 0..63 · 255 |
As per the MIB. |
hh3cQoSRemarkIPv4AddrRowStatus (1.3.6.1.4.1.25506.2.65.1.12.3.1.6) |
read-create |
RowStatus |
Row status. |
hh3cQoSRemarkIPv6AddrPriTable
About this table
This table contains IPv6 address-based priority information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cQoSRemarkIPv6AddrValue.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cQoSRemarkIPv6AddrValue (1.3.6.1.4.1.25506.2.65.1.12.4.1.1) |
not-accessible |
InetAddressIPv6 |
IPv6 address. |
As per the MIB. |
hh3cQoSRemarkIPv6AddrPrefixLength (1.3.6.1.4.1.25506.2.65.1.12.4.1.2) |
read-create |
InetAddressPrefixLength |
Prefix length for the IPv6 address. |
As per the MIB. |
hh3cQoSRemarkIPv6AddrDot1p (1.3.6.1.4.1.25506.2.65.1.12.4.1.3) |
read-create |
Unsigned32 |
· 0..7 · 255 |
As per the MIB. |
hh3cQoSRemarkIPv6AddrDscp (1.3.6.1.4.1.25506.2.65.1.12.4.1.4) |
read-create |
Unsigned32 |
· 0..63 · 255 |
As per the MIB. |
hh3cQoSRemarkIPv6AddrRowStatus (1.3.6.1.4.1.25506.2.65.1.12.4.1.5) |
read-create |
RowStatus |
Row status. |
hh3cQoSRemarkProtocolPriTable
About this table
This table contains Layer 3 protocol-based priority information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cQoSRemarkProtocolValue.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cQoSRemarkProtocolValue (1.3.6.1.4.1.25506.2.65.1.12.5.1.1) |
not-accessible |
Integer32 |
· ip(1) · ipx(2) · arp(3) · appletalk(4) · sna(5) · netbeui(6) |
Layer 3 protocol type. |
As per the MIB. |
hh3cQoSRemarkProtocolDot1p (1.3.6.1.4.1.25506.2.65.1.12.5.1.2) |
read-create |
Unsigned32 |
· 0..7 · 255 |
As per the MIB. |
hh3cQoSRemarkProtocolRowStatus (1.3.6.1.4.1.25506.2.65.1.12.5.1.3) |
read-create |
RowStatus |
Row status. |
hh3cQoSRemarkVlanPriTable
About this table
This table contains VLAN-based priority information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cQoSRemarkVlanStart.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cQoSRemarkVlanStart (1.3.6.1.4.1.25506.2.65.1.12.6.1.1) |
not-accessible |
Ingeter32 |
1..4094 |
Start VLAN of a VLAN range. |
As per the MIB. |
hh3cQoSRemarkVlanEnd (1.3.6.1.4.1.25506.2.65.1.12.6.1.2) |
read-create |
Ingeter32 |
1..4094 |
End VLAN of the VLAN range. |
As per the MIB. |
hh3cQoSRemarkVlanDot1p (1.3.6.1.4.1.25506.2.65.1.12.6.1.3) |
read-create |
Unsigned32 |
· 0..7 · 255 |
As per the MIB. |
hh3cQoSRemarkVlanDscp (1.3.6.1.4.1.25506.2.65.1.12.6.1.4) |
read-create |
Unsigned32 |
· 0..63 · 255 |
As per the MIB. |
hh3cQoSRemarkVlanRowStatus (1.3.6.1.4.1.25506.2.65.1.12.6.1.5) |
read-create |
RowStatus |
Row status. |
hh3cIfQoSCoppFlowStatTable
About this table
This table contains protocol traffic statistics for a control plane.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cIfQoSCoppFlowStatChassis, hh3cIfQoSCoppFlowStatSlot, and hh3cIfQoSCoppFlowStatProType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQoSCoppFlowStatChassis (1.3.6.1.4.1.25506.2.65.1.14.1.1.1) |
not-accessible |
Unsigned32 |
Chassis number for the control plane. |
As per the MIB. |
hh3cIfQoSCoppFlowStatSlot (1.3.6.1.4.1.25506.2.65.1.14.1.1.2) |
not-accessible |
Unsigned32 |
Slot number for the control plane. |
As per the MIB. |
hh3cIfQoSCoppFlowStatProType (1.3.6.1.4.1.25506.2.65.1.14.1.1.3) |
not-accessible |
Unsigned32 |
1..65 |
Protocol type. |
As per the MIB. |
hh3cIfQoSCoppFlowPassPackets (1.3.6.1.4.1.25506.2.65.1.14.1.1.4) |
read-only |
Counter64 |
As per the MIB. |
hh3cIfQoSCoppFlowPassBytes (1.3.6.1.4.1.25506.2.65.1.14.1.1.5) |
read-only |
Counter64 |
As per the MIB. |
hh3cIfQoSCoppFlowDropPackets (1.3.6.1.4.1.25506.2.65.1.14.1.1.6) |
read-only |
Counter64 |
As per the MIB. |
hh3cIfQoSCoppFlowDropBytes (1.3.6.1.4.1.25506.2.65.1.14.1.1.7) |
read-only |
Counter64 |
As per the MIB. |
Notifications
The following information describes the notifications included in the HH3C-IFQOS2-MIB module.
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.1 |
The downlink resources of an 8-queue scheduling profile are insufficient. |
Error |
Major |
hh3cIfQoS8QueueResouceOverRecover |
OFF |
Notification triggers
The notification is generated when the downlink (network side to user side) resources of an 8-queue scheduling profile are insufficient.
System impact
The qos user-queue command might not take effect.
Status control
ON
· CLI: Use the snmp-agent trap enable qos command.
OFF
· CLI: Use the undo snmp-agent trap enable qos command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
CPU number |
N/A |
Integer32 |
0 to 65534 |
Chip number |
N/A |
Integer32 |
0 to 65534 |
Direction |
N/A |
Direction |
As per the MIB |
Recommended action
To resolve the issue:
1. Delete or optimized related configuration.
2. If you cannot identify the configuration to be deleted or optimized, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.2 |
The resources of an 8-queue user-queue profile are sufficient. |
Recovery |
Major |
N/A |
OFF |
The notification is generated when the resources of an 8-queue user-queue profile are sufficient.
System impact
No negative impact on the system.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
CPU number |
N/A |
Integer32 |
0 to 65534 |
Chip number |
N/A |
Integer32 |
0 to 65534 |
Direction |
N/A |
Direction |
As per the MIB |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.3 |
The resource usage of an 8-queue scheduling profile exceeds 90%. |
Error |
Minor |
hh3cIfQoS8QueueResoucePreRecover |
OFF |
The notification is generated when the resource usage of an 8-queue scheduling profile exceeds 90%.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
CPU number |
N/A |
Integer32 |
0 to 65534 |
Chip number |
N/A |
Integer32 |
0 to 65534 |
Direction |
N/A |
Direction |
As per the MIB |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.4 |
The resource usage of an 8-queue scheduling profile fell below 90%. |
Recovery |
Minor |
N/A |
OFF |
The notification is generated when the resource usage of an 8-queue scheduling profile falls below 90%.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
CPU number |
N/A |
Integer32 |
0 to 65534 |
Chip number |
N/A |
Integer32 |
0 to 65534 |
Direction |
N/A |
Direction |
As per the MIB |
Recommended action
hh3cIfQoSBufferOverAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.5 |
Queue buffer usage alarm. |
Error |
Minor |
hh3cIfQoSBufferOverRecover |
OFF |
An alarm is generated when the queue buffer usage reaches or exceeds 90%.
System impact
Packet loss occurs on high-priority queues.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
CPU number |
N/A |
Integer32 |
0 to 65534 |
Chip number |
N/A |
Integer32 |
0 to 65534 |
Direction |
N/A |
Direction |
As per the MIB |
Recommended action
1. Reduce deployed services.
2. If the issue persists, collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.6 |
Queue buffer usage alarm recovery. |
Recovery |
Minor |
N/A |
OFF |
The notification is generated when the queue buffer usage alarm recovers.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
CPU number |
N/A |
Integer32 |
0 to 65534 |
Chip number |
N/A |
Integer32 |
0 to 65534 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.7 |
The channelized bandwidth exceeds the interface rate limit. |
Error |
Major |
hh3cIfQoSModeChannelOverPortShapRecover |
OFF |
The notification is generated when the channelized bandwidth exceeds the interface rate limit.
System impact
The channelized bandwidth does not take effect.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
CPU number |
N/A |
Integer32 |
0 to 65534 |
Interface name |
N/A |
OCTET STRING |
SIZE (1 to 47) |
Recommended action
1. Use the mode channel-bandwidth command to set a smaller channelized bandwidth.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.8 |
The channelized bandwidth is smaller than the interface rate limit. |
Recovery |
Major |
N/A |
OFF |
The notification is generated when the channelized bandwidth is smaller than the interface rate limit.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
CPU number |
N/A |
Integer32 |
0 to 65534 |
Interface name |
N/A |
OCTET STRING |
SIZE (1 to 47) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.9 |
Exclusive bandwidth application failure alarm. |
Error |
Major |
hh3cIfQoSExclusiveBandApplyFailRecover |
OFF |
The notification is generated when the exclusive bandwidth fails to be applied.
System impact
The exclusive bandwidth does not take effect.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
CPU number |
N/A |
Integer32 |
0 to 65534 |
Interface name |
N/A |
OCTET STRING |
SIZE (1 to 47) |
Recommended action
Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.10 |
Exclusive bandwidth application failure alarm recovery. |
Recovery |
Major |
N/A |
OFF |
The notification is generated when the exclusive bandwidth application failure alarm recovers.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
CPU number |
N/A |
Integer32 |
0 to 65534 |
Interface name |
N/A |
OCTET STRING |
SIZE (1 to 47) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.11 |
Exclusive bandwidth exceeding maximum interface bandwidth. |
Error |
Major |
hh3cIfQoSExclusiveBandOverRecover |
OFF |
The notification is generated when the exclusive bandwidth value exceeds the maximum interface bandwidth. The configuration will also become ineffective.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
CPU number |
N/A |
Integer32 |
0 to 65534 |
Interface name |
N/A |
OCTET STRING |
SIZE (1 to 47) |
Recommended action
Configure an exclusive bandwidth value that is smaller than the maximum interface bandwidth.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.12 |
Exclusive bandwidth exceeding maximum interface bandwidth alarm recovery. |
Recovery |
Major |
N/A |
OFF |
The notification is generated when the alarm that the configured exclusive bandwidth value exceeds the maximum interface bandwidth recovers.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
CPU number |
N/A |
Integer32 |
0 to 65534 |
Interface name |
N/A |
OCTET STRING |
SIZE (1 to 47) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.13 |
The outgoing traffic of an interface exceeds the configured CIR |
Error |
Major |
hh3cIfQoSLRDiscardAlarmRecover |
OFF |
The notification is generated when the outgoing traffic of an interface exceeds the configured CIR.
System impact
The outgoing traffic of an interface might be dropped.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface name |
N/A |
OCTET STRING |
SIZE (1 to 47) |
CIR |
N/A |
Unsigned32 |
Outgoing traffic rate of the interface |
N/A |
Unsigned32 |
Recommended action
Increase the CIR on the interface.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.14 |
The outgoing traffic rate of an interface drops below the configured CIR |
Recovery |
Major |
N/A |
OFF |
The notification is generated when the outgoing traffic rate of an interface drops below the configured CIR.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface name |
N/A |
OCTET STRING |
SIZE (1 to 47) |
CIR |
N/A |
Unsigned32 |
N/A |
Unsigned32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.15 |
Packets are dropped by CAR on an interface |
Error |
Major |
hh3cIfQoSCarDiscardAlarmRecover |
OFF |
The notification is generated when packets are dropped by CAR on an interface.
System impact
Traffic might be dropped.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
Interface name |
N/A |
OCTET STRING |
SIZE (1 to 47) |
Direction |
N/A |
Direction |
Recommended action
Cancel the CAR settings or increase the CIR.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.16 |
Packets dropped by CAR on an interface have been recovered |
Recovery |
Major |
N/A |
OFF |
The notification is generated when packets dropped by CAR on an interface have been recovered.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
Interface name |
N/A |
OCTET STRING |
SIZE (1 to 47) |
Direction |
N/A |
Direction |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.17 |
Packets are dropped by CAR on the control plane |
Error |
Major |
hh3cIfQoSCoppDropPktAlarmRecover |
OFF |
The notification is generated when packets are dropped by CAR on the control plane.
System impact
Packets are dropped by CAR on the control plane, and services or internal control information might not be able to be processed.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
Protocol type |
N/A |
OCTET STRING |
SIZE (1 to 31) |
Bandwidth |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.65.1.15.13 (hh3cIfQoSBandwidthUnit) |
Bandwidth unit |
N/A |
INTEGER |
Recommended action
Cancel the CAR settings for the control plane.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.18 |
Packets dropped by CAR on the control plane have been recovered |
Recovery |
Major |
N/A |
OFF |
The notification is generated when packets dropped by CAR on the control plane have been recovered.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
Protocol type |
N/A |
OCTET STRING |
SIZE (1 to 31) |
Bandwidth |
N/A |
Unsigned32 |
Bandwidth unit |
N/A |
INTEGER |
Recommended action
hh3cIfQoSQueExcpAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.19 |
Packets fail to be forwarded due to queue exceptions. |
Error |
Major |
hh3cIfQoSQueExcpAlarmRecover |
OFF |
The notification is generated when packets fail to be forwarded due to queue exceptions.
System impact
Packets cannot be forwarded.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
Protocol type |
N/A |
OCTET STRING |
SIZE (1 to 31) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.20 |
Packets failing to be forwarded due to queue exceptions have been recovered. |
Recovery |
Major |
N/A |
OFF |
The notification is generated when packets failing to be forwarded due to queue exceptions have been recovered.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
Protocol type |
N/A |
OCTET STRING |
SIZE (1 to 31) |
Recommended action
hh3cIfQoSBoardL3AclResLack
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.21 |
Layer 3 ACL resources are insufficient. |
Error |
Major |
N/A |
OFF |
The notification is generated when Layer 3 ACL resources are insufficient.
System impact
ACL rules do not take effect or fail to be matched.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
Service name |
N/A |
OCTET STRING |
SIZE (1 to 63) |
Failure reason |
N/A |
OCTET STRING |
SIZE (1 to 127) |
Recommended action
hh3cIfQoSAclResAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.22 |
Error |
Major |
hh3cIfQoSAclResAlarmRecover |
OFF |
The notification is generated when ACL resources are insufficient.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
Service name |
N/A |
OCTET STRING |
SIZE (1 to 63) |
Application object |
N/A |
OCTET STRING |
SIZE (1 to 127) |
Direction |
N/A |
Direction |
Failure reason |
N/A |
OCTET STRING |
SIZE (1 to 127) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
The ACL resource alarm is cleared. |
Recovery |
Major |
N/A |
OFF |
The notification is generated when the ACL resource alarm is cleared.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
Service name |
N/A |
OCTET STRING |
SIZE (1 to 63) |
N/A |
OCTET STRING |
SIZE (1 to 127) |
Direction |
N/A |
Direction |
Failure reason |
N/A |
OCTET STRING |
SIZE (1 to 127) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.24 |
The ACL forwarding engine memory is exhausted. |
Error |
Major |
hh3cIfQoSAclMemFullAlarmRecover |
OFF |
The notification is generated when the ACL forwarding engine memory is exhausted.
System impact
ACL rules fail to be matched.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.25 |
The ACL forwarding engine memory is recovered. |
Recovery |
Major |
N/A |
OFF |
The notification is generated when the ACL forwarding engine memory is recovered.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0 to 65534 |
Slot number |
N/A |
Integer32 |
0 to 65534 |
Recommended action
hh3cIfQoSBufferAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.26 |
QoS buffer alarm. |
Error |
Major |
hh3cIfQoSBufferAlarmRecover |
OFF |
The notification is generated when buffer resources are insufficient.
System impact
QoS forwarding services are affected.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.65.1.15.2 (hh3cIfQoSSlot) |
Slot number |
N/A |
Integer32 |
0..65534 |
1.3.6.1.4.1.25506.2.65.1.15.4 (hh3cIfQoSChip) |
Chip number |
N/A |
Integer32 |
0..65534 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.27 |
QoS buffer recovery. |
Recovery |
Major |
N/A |
OFF |
The notification is generated when buffer resources are sufficient.
System impact
QoS forwarding services are normal.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Slot number |
N/A |
Integer32 |
0..65534 |
Chip number |
N/A |
Integer32 |
0..65534 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.28 |
The buffer usage of a queue reaches the threshold. |
Error |
Major |
hh3cIfQoSQueBufferOverrunRecover |
OFF |
The notification is generated when the buffer usage of a queue reaches the threshold.
System impact
Packet loss occurs in the outbound direction.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.65.1.15.14 (hh3cIfQoSQueBufferQueID) |
Queue ID. |
N/A |
Integer32 |
0..65535 |
1.3.6.1.4.1.25506.2.65.1.15.5 (hh3cIfQoSIfName) |
Interface name. |
N/A |
OCTET STRING |
SIZE (1..47) |
1.3.6.1.4.1.25506.2.65.1.15.19 (hh3cIfQoSSlot) |
Slot number. |
N/A |
Integer32 |
0..65534 |
1.3.6.1.4.1.25506.2.65.1.15.15 (hh3cIfQoSQueBufferUsedCell) |
Buffer used during congestion. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.65.1.15.16 (hh3cIfQoSQueBufferUsedLength) |
Queue length during congestion. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.65.1.15.17 (hh3cIfQoSQueBufferDiscard) |
Packets dropped. |
N/A |
Counter64 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.29 |
The buffer usage of a queue falls below the threshold. |
Recovery |
Major |
N/A |
OFF |
The notification is generated when the buffer usage of a queue falls below the threshold.
System impact
No packets are dropped in the outbound direction.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Queue ID. |
N/A |
Integer32 |
0..65535 |
Interface name. |
N/A |
OCTET STRING |
SIZE (1..47) |
Slot number. |
N/A |
Integer32 |
0..65534 |
N/A |
Unsigned32 |
N/A |
Unsigned32 |
Packets dropped. |
N/A |
Counter64 |
Recommended action
hh3cIfQoSFCoEPriorityAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.30 |
Priority mapping alarm. |
Error |
Major |
hh3cIfQoSFCoEPriorityRecover |
OFF |
The notification is generated when the PHB-to-802.1p priority mapping is disabled in the outbound direction of an interface.
System impact
FCoE packets might be dropped because the priority of FCoE packets is incorrect.
Status control
ON
OFF
Objects
None.
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.31 |
Priority mapping recovery. |
Recovery |
Major |
N/A |
OFF |
The notification is generated when the PHB-to-802.1p priority mapping is enabled in the outbound direction of an interface.
System impact
No FCoE packets are dropped due to low priority.
Status control
ON
OFF
Objects
None.
Recommended action
hh3cIfQoSRcyPortPktsDropAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.32 |
Packets are dropped on a loopback interface. |
Error |
Major |
hh3cIfQoSRcyPortPktsDropRecover |
OFF |
The notification is generated when packets are dropped on a loopback interface.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.65.1.15.18 (hh3cIfQoSPortID) |
Interface ID. |
N/A |
Integer32 |
0..65535 |
Slot number. |
N/A |
Integer32 |
0..65534 |
Chip number. |
N/A |
Integer32 |
0..65534 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.33 |
Packets are no longer dropped on a loopback interface. |
Recovery |
Major |
N/A |
OFF |
The notification is generated when packets are no longer dropped on a loopback interface.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface ID. |
N/A |
Integer32 |
0..65535 |
Slot number. |
N/A |
Integer32 |
0..65534 |
Chip number. |
N/A |
Integer32 |
0..65534 |
Recommended action
hh3cIfQoSStormSuppressAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.34 |
QoS storm suppression alarm. |
Error |
Major |
hh3cIfQoSStormSuppressRecover |
OFF |
The notification is generated when the QoS storm suppression feature is abnormal.
System impact
The QoS storm suppression feature is abnormal.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Slot number. |
N/A |
Integer32 |
0..65534 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.35 |
Recovery |
Major |
N/A |
OFF |
The notification is generated when the QoS storm suppression feature is normal.
System impact
The QoS storm suppression feature is normal.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Slot number. |
N/A |
Integer32 |
0..65534 |
Recommended action
hh3cIfQoSUniPktsDiscardAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.36 |
Unicast packets are dropped. |
Error |
Major |
hh3cIfQoSUniPktsDiscardRecover |
OFF |
The notification is generated when unicast packets are dropped.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Slot number. |
N/A |
Integer32 |
0..65534 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.37 |
Unicast packets are no longer dropped. |
Recovery |
Major |
N/A |
OFF |
The notification is generated when unicast packets are no longer dropped.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Slot number. |
N/A |
Integer32 |
0..65534 |
Recommended action
hh3cIfQoSIngressDiscardAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.38 |
Packet scheduling in the inbound direction fails. |
Error |
Major |
hh3cIfQoSIngressDiscardRecover |
OFF |
The notification is generated when packet scheduling in the inbound direction fails.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Slot number. |
N/A |
Integer32 |
0..65534 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.1.16.0.39 |
Packet scheduling in the inbound direction succeeds. |
Recovery |
Major |
N/A |
OFF |
The notification is generated when packet scheduling in the inbound direction succeeds.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Slot number. |
N/A |
Integer32 |
0..65534 |
Recommended action
