13-ACL and QoS
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 6715-6W10013-ACL and QoS
02-HH3C-CBQOS2-MIB
02-HH3C-CBQOS2-MIB 500.75 KB
HH3C-CBQOS2-MIB· 1
About this MIB· 1
MIB file name· 1
Root object 1
Scalar objects· 1
hh3cCBQoSClassifierIndexNext 1
hh3cCBQoSBehaviorIndexNext 1
hh3cCBQoSPolicyIndexNext 1
hh3cCBQoSApplyingStatus· 2
hh3cCBQoSChassis· 2
hh3cCBQoSSlot 2
hh3cCBQoSCPU· 2
hh3cCBQoSDirection· 2
hh3cCBQoSRedirectAlarmBehaviorName· 3
hh3cCBQoSRedirectAlarmProtoFamily· 3
hh3cCBQoSRedirectAlarmNextHop· 3
Tabular objects· 3
hh3cCBQoSClassifierCfgInfoTable· 3
hh3cCBQoSMatchRuleCfgInfoTable· 4
hh3cCBQoSMatchCpProtoCfgTable· 6
hh3cCBQoSMatchCpGroupCfgTable· 7
hh3cCBQoSBehaviorCfgInfoTable· 7
hh3cCBQoSCarCfgInfoTable· 8
hh3cCBQoSGtsCfgInfoTable· 9
hh3cCBQoSRemarkCfgInfoTable· 10
hh3cCBQoSQueueCfgInfoTable· 11
hh3cCBQoSFirewallCfgInfoTable· 12
hh3cCBQoSAccountCfgInfoTable· 12
hh3cCBQoSRedirectCfgInfoTable· 13
hh3cCBQoSMirrorCfgInfoTable· 14
hh3cCBQoSNestCfgInfoTable· 15
hh3cCBQoSNestPolicyCfgInfoTable· 15
hh3cCBQoSMirrorIfCfgInfoTable· 16
hh3cCBQoSColoredRemarkCfgTable· 16
hh3cCBQoSPrimapCfgInfoTable· 17
hh3cCBQoSColorMapDpCfgInfoTable· 18
hh3cCBQoSPolicyCfgInfoTable· 19
hh3cCBQoSPolicyClassCfgInfoTable· 20
hh3cCBQoSIfApplyPolicyTable· 21
hh3cCBQoSVlanApplyPolicyTable· 22
hh3cCBQoSGlobalApplyTable· 22
hh3cCBQoSCpApplyPolicyTable· 23
hh3cCBQoSApplyObjectTable· 24
hh3cCBQoSIntApplyObjectTable· 25
hh3cCBQoSVlanApplyObjectTable· 25
hh3cCBQoSNestPolicyApplyObjectTable· 26
hh3cCBQoSCpApplyObjectTable· 26
hh3cCBQoSCbqRunInfoTable· 27
hh3cCBQoSClassMatchRunInfoTable· 28
hh3cCBQoSCarRunInfoTable· 29
hh3cCBQoSRemarkRunInfoTable· 30
hh3cCBQoSQueueRunInfoTable· 30
hh3cCBQoSAccountingRunInfoTable· 31
hh3cCBQoSPolicyAccRunInfoTable· 32
Notifications· 32
hh3cCBQoSIfPolicyChanged· 32
hh3cCBQoSVlanPolicyChanged· 33
hh3cCBQoSGlobalAclNotSupport 34
hh3cCBQoSGlobalQPPBNotSupport 34
hh3cCBQoSRedirectInvalidAlarm·· 35
hh3cCBQoSRedirectInvalidAlarmRecover 36
hh3cCBQoSRdtNHLackResAlarm·· 37
hh3cCBQoSRdtNHLackResRecover 38
HH3C-CBQOS2-MIB
About this MIB
Use this MIB to configure class-based QoS (CBQoS).
CBQoS applies different service quality levels to different classes of packets, enabling multiple service support on the network.
MIB file name
hh3c-cbqos2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cQos2(65)
Scalar objects
Object (OID)
Access
Value range
Implementation
hh3cCBQoSClassifierIndexNext (1.3.6.1.4.1.25506.2.65.2.1.1.1)
read-only
Integer32
Standard MIB values.
Index of the next available traffic class.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSBehaviorIndexNext (1.3.6.1.4.1.25506.2.65.2.1.2.1)
read-only
Integer32
Index of the next available traffic behavior.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSPolicyIndexNext (1.3.6.1.4.1.25506.2.65.2.1.3.1)
read-only
Integer32
Index of the next available QoS policy.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSApplyingStatus (1.3.6.1.4.1.25506.2.65.2.1.6.1)
read-only
INTEGER
·     idle(1)
·     busy(2)
QoS policy application status.
As per the MIB.
hh3cCBQoSChassis
Object (OID)
Access
Value range
Implementation
hh3cCBQoSChassis
(1.3.6.1.4.1.25506.2.65.2.1.8.1)
accessible-for-notify
Integer32
0..65534
Chassis number.
hh3cCBQoSSlot
Object (OID)
Access
Value range
Implementation
hh3cCBQoSSlot
(1.3.6.1.4.1.25506.2.65.2.1.8.2)
Integer32
0..65534
Slot number.
hh3cCBQoSCPU
Object (OID)
Access
Value range
Implementation
hh3cCBQoSCPU
(1.3.6.1.4.1.25506.2.65.2.1.8.3)
Integer32
0..65534
CPU number.
hh3cCBQoSDirection
Object (OID)
Access
Value range
Implementation
hh3cCBQoSDirection
(1.3.6.1.4.1.25506.2.65.2.1.8.4)
DirectionType
Standard MIB values
Direction.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.65.2.1.8.5)
OCTET STRING
SIZE (1..31)
Traffic behavior name.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSRedirectAlarmProtoFamily (1.3.6.1.4.1.25506.2.65.2.1.8.6)
InetAddressType
Standard MIB values
Protocol type.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSRedirectAlarmNextHop (1.3.6.1.4.1.25506.2.65.2.1.8.7)
InetAddress
Standard MIB values
Next-hop address.
Tabular objects
About this table
This table configures a traffic class.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cCBQoSClassifierIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSClassifierIndex (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.1)
not-accessible
Integer32
Traffic class index.
As per the MIB.
hh3cCBQoSClassifierName (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.2)
read-create
OCTET STRING
SIZE (1..31)
Traffic class name.
As per the MIB.
hh3cCBQoSClassifierRuleCount (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.3)
read-only
Integer32
Number of match criteria.
As per the MIB.
hh3cCBQoSClassifierOperator (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.4)
read-create
INTEGER
·     and(1)
·     or(2)
Relationship among match criteria.
As per the MIB.
hh3cCBQoSClassifierLayer (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.5)
read-create
INTEGER
·     unavailable(1)
·     l2(2)
·     l3(3)
·     both(4)
Protocol layer for the traffic class.
This object is not configurable and is fixed at unavailable(1).
hh3cCBQoSClassifierType (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.6)
read-only
INTEGER
·     systemDefined(1)
·     userDefined(2)
Traffic class type.
Implementation varies by product.
hh3cCBQosClassifierMatchRuleNextIndex (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.7)
read-only
Integer32
Index used to create a match criterion.
If the value is 2147483647, the a match criterion cannot be created.
hh3cCBQoSClassifierRowStatus (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.8)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table configures match criteria for a traffic class.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSClassifierIndex and hh3cCBQoSMatchRuleIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSMatchRuleIndex (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.1)
not-accessible
Integer32
Match criterion index.
As per the MIB.
hh3cCBQoSMatchRuleIfNot (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.2)
read-create
INTEGER
·     match(1)
·     notMatch (2)
Match attribute.
hh3cCBQoSMatchRuleType (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.3)
read-create
MatchRuleType
Match criterion type.
hh3cCBQoSMatchRuleStringValue (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.4)
read-create
OCTET STRING
SIZE (1..255)
Match criterion type string value. The corresponding match criterion types include:
·     IPv4acl
·     MACACL
·     UserACL
·     IPv6acl
·     Source-MAC
·     Destination-MAC
·     Classifier
·     Inbound-interface
·     VlanID
·     SourceIp
·     MplsLabel
·     SecondMplsLabel
As per the MIB.
hh3cCBQoSMatchRuleIntValue1 (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.5)
read-create
Unsigned32
Match criterion type integer value. The corresponding match criterion types include:
·     IPv4acl
·     MACACL
·     UserACL
·     IPv6acl
·     Software QoS
·     Hardware Qos
·     RtpPort
·     IpPrec
·     Dscp
·     Vlan8021p
·     Mplsexp
·     SourceIp
·     QosLocalID
·     AtmClp
·     FrDe
·     LocalPrecedence
·     DropPriority
·     ServiceDot1p
·     SecondMplsExp
·     PacketLength
·     ForwardingLayer
As per the MIB.
hh3cCBQoSMatchRuleIntValue2 (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.6)
read-create
Unsigned32
·     RTP-PORT
·     DSCP
·     PacketLength
As per the MIB.
hh3cCBQoSMatchIpAddressType (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.7)
read-create
InetAddressType
Match criterion type integer value. The corresponding match criterion type is SourceIP.
Not supported.
The value is fixed at unknown(0).
hh3cCBQoSMatchIpAddress (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.8)
read-create
InetAddress
Match criterion type integer value. The corresponding integer value is a source IP address.
Not supported.
The value is fixed at zero length.
hh3cCBQoSMatchRuleRowStatus (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.9)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
Use this MIB to configure a match criterion to match protocol traffic to a control plane.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSMatchCpProtoIfNot (1.3.6.1.4.1.25506.2.65.2.1.1.4.1.1)
read-create
INTEGER
·     match(1)
·     matchNot(2)
Match attribute.
hh3cCBQoSMatchCpProtoValue (1.3.6.1.4.1.25506.2.65.2.1.1.4.1.2)
read-create
OCTET STRING
SIZE (0..255)
Control plane protocol.
hh3cCBQoSMatchCpProtoRowStatus (1.3.6.1.4.1.25506.2.65.2.1.1.4.1.3)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
Use this MIB to configure a match criterion to match protocol group traffic to a control plane.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSMatchCpGroupIfNot (1.3.6.1.4.1.25506.2.65.2.1.1.5.1.1)
read-create
INTEGER
·     match(1)
·     matchNot(2)
Match attribute.
hh3cCBQoSMatchCpGroupValue (1.3.6.1.4.1.25506.2.65.2.1.1.5.1.2)
read-create
INTEGER
·     critical(1)
·     important(2)
·     management(3)
·     normal(4)
·     redirect(5)
·     monitor(6)
·     exception(7)
Control plane protocol group.
hh3cCBQoSMatchCpGroupRowStatus (1.3.6.1.4.1.25506.2.65.2.1.1.5.1.3)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table configures match criteria for a traffic behavior.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cCBQoSBehaviorIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSBehaviorIndex (1.3.6.1.4.1.25506.2.65.2.1.2.2.1.1)
not-accessible
Integer32
Traffic behavior index.
As per the MIB.
hh3cCBQoSBehaviorName (1.3.6.1.4.1.25506.2.65.2.1.2.2.1.2)
read-create
OCTET STRING
SIZE (1..31)
As per the MIB.
hh3cCBQoSBehaviorType (1.3.6.1.4.1.25506.2.65.2.1.2.2.1.3)
read-only
INTEGER
·     systemDefined(1)
·     userDefined(2)
Traffic behavior type.
hh3cCBQoSBehaviorRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.2.1.4)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table configures a CAR action for a traffic behavior.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSCarCir (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.1)
read-create
Unsigned32
CIR.
hh3cCBQoSCarCbs (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.2)
read-create
Unsigned32
CBS.
hh3cCBQoSCarEbs (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.3)
read-create
Unsigned32
EBS.
hh3cCBQoSCarPir (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.4)
read-create
Unsigned32
PIR.
hh3cCBQoSCarPbs (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.5)
read-create
Unsigned32
PBS.
Not supported.
The value is fixed at 4294967295.
hh3cCBQoSCarGreenAction (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.6)
read-create
CarAction
Action to take on green packets.
hh3cCBQoSCarGreenRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.7)
read-create
Integer32
·     0..63
·     255
Value to mark for green packets.
As per the MIB.
hh3cCBQoSCarYellowAction (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.8)
read-create
CarAction
Action to take on yellow packets.
hh3cCBQoSCarYellowRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.9)
read-create
Integer32
·     0..63
·     255
Value to mark for yellow packets.
As per the MIB.
hh3cCBQoSCarRedAction (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.10)
read-create
CarAction
·     For VRP: Action to take on packets exceeding the CIR.
·     For 10G: Action to take on packets exceeding the PIR.
hh3cCBQoSCarRedRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.11)
read-create
Integer32
·     0..63
·     255
Value to mark for red packets.
As per the MIB.
hh3cCBQoSCarPolicedPriorityMapType (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.12)
read-create
INTEGER
·     none (0)
·     policed-service-map (1)
·     local-precedence-dot1p-map (2)
·     drop-precedence-map (3)
Priority map type.
Not supported. The value is fixed at none(0).
hh3cCBQoSCarRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.13)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table contains GTS configuration information.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSGtsCir (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.1)
read-create
Unsigned32
CIR.
hh3cCBQoSGtsCbs (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.2)
read-create
Unsigned32
CBS.
hh3cCBQoSGtsEbs (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.3)
read-create
Unsigned32
EBS.
hh3cCBQoSGtsQueueLength (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.4)
read-create
Integer32
1..1024
Queue length.
As per the MIB.
hh3cCBQoSGtsRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.5)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSGtsPir (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.6)
read-create
Unsigned32
PIR.
About this table
This table contains marking configuration information.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSBehaviorIndex and hh3cCBQoSRemarkType.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSRemarkType (1.3.6.1.4.1.25506.2.65.2.1.2.6.1.1)
not-accessible
RemarkType
Marking type.
hh3cCBQoSRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.6.1.2)
read-create
Integer32
0..4095
As per the MIB.
hh3cCBQoSRemarkRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.6.1.3)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table contains queuing configuration information.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSQueueType (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.1)
read-create
QueueType
Queuing type.
hh3cCBQoSQueueDropType (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.2)
read-create
INTEGER
·     unavailable(0)
·     tail-drop(1)
·     wred(2)
Packet drop type.
Not supported.
hh3cCBQoSQueueLength (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.3)
read-create
Integer32
1..2147483647
Queue length.
hh3cCBQoSQueueBandwidthUnit (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.4)
read-create
QueueBandwidthUnit
Bandwidth unit.
hh3cCBQoSQueueBandwidthValue (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.5)
read-create
Integer32
·     1..100000000
·     2147483647
Bandwidth value.
hh3cCBQoSQueueCbs (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.6)
read-create
Integer32
·     32..1000000000
·     2147483647
CBS.
hh3cCBQoSQueueQueueNumber (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.7)
read-create
INTEGER
·     unavailable(0)
·     a16(16)
·     a32(32)
·     a64(64)
·     a128(128)
·     a256(256)
·     a512(512)
·     a1024(1024)
·     a2048(2048)
·     a4096(4096)
Maximum number of queues.
hh3cCBQoSQueueCbsRatio (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.8)
read-create
Integer32
·     25..500
·     2147483647
Allowed burst ratio.
hh3cCBQoSQueueRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.9)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table contains firewall configuration information.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSFirewallAction (1.3.6.1.4.1.25506.2.65.2.1.2.12.1.1)
read-create
INTEGER
·     permit(1)
·     deny(2)
Firewall behavior.
As per the MIB.
hh3cCBQoSFirewallRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.12.1.2)
read-create
RowStatus
Row status.
As per the MIB.
About this table
This table contains accounting configuration information.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSAccounting (1.3.6.1.4.1.25506.2.65.2.1.2.14.1.1)
read-create
INTEGER
·     true(1)
·     false(2)
Accounting.
Not supported. The value is fixed at true(1).
hh3cCBQoSAccountRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.14.1.2)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSAccountingMode (1.3.6.1.4.1.25506.2.65.2.1.2.14.1.3)
read-create
INTEGER
·     auto(1)
·     packet(2)
·     byte(3)
·     both(4)
Accounting mode.
About this table
This table configures a redirecting action for a traffic behavior.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSRedirectType (1.3.6.1.4.1.25506.2.65.2.1.2.15.1.1)
read-create
INTEGER
·     cpu(1)
·     interface(2)
·     nextHop(3)
Redirecting destination.
hh3cCBQoSRedirectIfIndex (1.3.6.1.4.1.25506.2.65.2.1.2.15.1.2)
read-create
Integer32
Interface index.
As per the MIB.
hh3cCBQoSRedirectIpAddressType
read-create
InetAddressType
Next-hop address type.
Not supported. The value is fixed at unknown(0).
hh3cCBQoSRedirectIpAddress1
read-create
InetAddress
First next-hop address.
Not supported. The value is fixed at zero-length.
hh3cCBQoSRedirectIpAddress2
read-create
InetAddress
Second next-hop address.
hh3cCBQoSRedirectRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.15.1.6)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSRedirectIpv6Interface1
read-create
Integer32
Outgoing interface for the first next-hop IPv6 address.
Not supported. The value is fixed at 0.
hh3cCBQoSRedirectIpv6Interface2
read-create
Integer32
Outgoing interface for the second next-hop IPv6 address.
hh3cCBQoSRedirectIfVlanID (1.3.6.1.4.1.25506.2.65.2.1.2.15.1.9)
read-create
Integer32
0..4094|65535
VLAN ID.
About this table
This table contains flow mirroring configuration information.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSMirrorType (1.3.6.1.4.1.25506.2.65.2.1.2.17.1.1)
read-create
INTEGER
·     interface(1)
·     cpu(2)
·     vlan(3)
Mirroring destination.
hh3cCBQoSMirrorIfIndex (1.3.6.1.4.1.25506.2.65.2.1.2.17.1.2)
read-create
OCTET STRING
SIZE (1..255)
Destination interface index.
hh3cCBQoSMirrorVlanID (1.3.6.1.4.1.25506.2.65.2.1.2.17.1.3)
read-create
Integer32
0..4094
Destination VLAN ID.
hh3cCBQoSMirrorRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.17.1.4)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table configures nesting for VLAN mapping.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSNestServiceVlanID (1.3.6.1.4.1.25506.2.65.2.1.2.18.1.1)
read-create
Integer32
·     1..4094
·     65535
Service provider VLAN ID.
As per the MIB.
hh3cCBQoSNestServiceDot1pValue (1.3.6.1.4.1.25506.2.65.2.1.2.18.1.2)
read-create
Integer32
·     0..7
·     65535
Outer 802.1p priority value.
hh3cCBQoSNestCustomerVlanID
read-create
Integer32
·     1..4094
·     65535
Customer VLAN ID.
Not supported. The value is fixed at 65535.
hh3cCBQoSNestCustomerDot1pValue
read-create
Integer32
·     0..7
·     65535
Inner 802.1p priority value.
hh3cCBQoSNestRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.18.1.5)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table nests a QoS policy.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSNestPolicyName (1.3.6.1.4.1.25506.2.65.2.1.2.19.1.1)
read-create
OCTET STRING
SIZE (1..31)
Nested policy name.
As per the MIB.
hh3cCBQoSNestPolicyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.19.1.2)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table contains information about flow mirroring to an interface.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSMirrorIfMainIfIndex (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.1)
not-accessible
Integer32
As per the MIB.
hh3cCBQoSMirrorIfMainIfStatus (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.2)
read-only
INTEGER
·     inactive(1)
·     active(2)
Destination interface status.
As per the MIB.
hh3cCBQoSMirrorIfBackupIfIndex (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.3)
read-create
Integer32
Backup destination interface index.
hh3cCBQoSMirrorIfBackupIfStatus (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.4)
read-only
INTEGER
·     inactive(1)
·     active(2)
Backup destination interface status.
As per the MIB.
hh3cCBQoSMirrorIfRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.5)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSBehaviorIndex, hh3cCBQoSColoredRemarkType, and hh3cCBQoSColoredRemarkColor.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.65.2.1.2.21.1.1)
not-accessible
RemarkType
Marking type.
hh3cCBQoSColoredRemarkColor (1.3.6.1.4.1.25506.2.65.2.1.2.21.1.2)
not-accessible
INTEGER
·     green(1)
·     yellow(2)
·     red(3)
Marking color.
hh3cCBQoSColoredRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.21.1.3)
read-create
Integer32
0..4095
Value to mark for packets.
As per the MIB.
hh3cCBQoSColoredRemarkRowStatus
(1.3.6.1.4.1.25506.2.65.2.1.2.21.1.4)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table contains information about predefined priority maps. The system modifies the priority of matching packets according to the predefined priority map.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSPrimapColorType (1.3.6.1.4.1.25506.2.65.2.1.2.22.1.1)
not-accessible
INTEGER
·     noColorMap(1)
·     colorMap(2)
Predefined priority map color attribute.
hh3cCBQoSPrePriMapTableType(1.3.6.1.4.1.25506.2.65.2.1.2.22.1.2)
not-accessible
INTEGER
·     invalid(0)
·     dot1pToLp(1)
·     dot1pToDp(2)
·     expToLp(3)
·     dscpToLp(4)
·     expToDp(5)
·     dscpToDp(6)
·     dscpToDot1p(7)
·     dot1pToDscp(8)
·     dscpToDscp(9)
·     dscpToExp(10)
·     expToDscp(11)
·     expToDot1p(12)
·     expToExp(13)
·     lpToDot1p(14)
·     dot1pToRpr(15)
·     dscpToRpr(16)
·     expToRpr(17)
·     ippreToRpr(18)
·     upToDot1p(19)
·     upToDscp(20)
·     upToExp(21)
·     upToDp(22)
·     upToLp(23)
·     upToRpr(24)
·     upToFc(25)
·     lpTodscp(26)
·     dot11eToLp(27)
·     lpToDot11e(28)
·     lpToLp(29)
·     dot1pToExp(30)
·     lpToExp(31)
·     lpToDp(32)
·     upToUp(33)
·     dot1pToDot1p(34)
Predefined priority map type.
hh3cCBQoSPrimapRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.22.1.3)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table contains information about packet color-to-drop priority mappings. The system assigns drop priority to packets according to the packet color.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSColorMapDpEnable (1.3.6.1.4.1.25506.2.65.2.1.2.23.1.1)
read-create
INTEGER
·     true(1)
·     false(2)
Color-to-drop priority mapping enable status.
As per the MIB.
hh3cCBQoSColorMapDpRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.23.1.2)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table configures a QoS policy.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSPolicyIndex (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.1)
not-accessible
Integer32
Policy index.
As per the MIB.
hh3cCBQoSPolicyName (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.2)
read-create
OCTET STRING
SIZE (1..31)
Policy name.
As per the MIB.
hh3cCBQoSPolicyClassCount (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.3)
read-only
Integer32
Number of traffic classes in the QoS policy.
As per the MIB.
hh3cCBQoSPolicyConfigMode (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.4)
read-create
INTEGER
·     unavailable(0)
·     config(1)
·     auto(2)
Policy mode.
Not supported. The value is fixed at unavailable(0).
hh3cCBQoSPolicyType (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.5)
read-only
INTEGER
·     systemDefined(1)
·     userDefined(2)
Policy type.
hh3cCBQoSPolicyClassNextIndex (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.6)
read-only
Integer32
Traffic class index used to create a traffic class.
If the value is 2147483647, no traffic class can be created for hh3cCBQoSPolicyClassCfgInfoTable.
hh3cCBQoSPolicyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.7)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table describes CB association information for a QoS policy.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSPolicyIndex and hh3cCBQoSPolicyClassIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSPolicyClassIndex (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.1)
not-accessible
Integer32
As per the MIB.
hh3cCBQoSPolicyClassClassifierIndex (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.2)
read-create
Integer32
As per the MIB.
hh3cCBQoSPolicyClassClassifierName (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.3)
read-only
OCTET STRING
SIZE (1..31)
Traffic class name.
As per the MIB.
hh3cCBQoSPolicyClassBehaviorIndex (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.4)
read-create
Integer32
As per the MIB.
hh3cCBQoSPolicyClassBehaviorName (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.5)
read-only
OCTET STRING
SIZE (1..31)
As per the MIB.
hh3cCBQoSPolicyClassPrecedence (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.6)
read-create
Integer32
·     0..16383
·     2147483647
Traffic class priority.
Not supported. The value is fixed at 2147483647.
hh3cCBQoSPolicyClassRowStatus (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.7)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSPolicyClassMode (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.8)
read-create
INTEGER
·     modeNo(1)
·     modeDot1q(2)
·     modeQppb(3)
·     modeIpSourceGuard(4)
·     modeVoiceVlan(5)
·     modeDcbx(6)
CB association mode.
hh3cCBQoSPolicyClassCfgOrder (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.9)
read-only
Integer32
CB association configuration order.
Not supported
About this table
.This table applies a QoS policy to an interface.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSIfApplyPolicyIfIndex and hh3cCBQoSIfApplyPolicyDirection.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSIfApplyPolicyIfIndex (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.1)
Integer32
Index of the interface to which a QoS policy is applied.
As per the MIB.
hh3cCBQoSIfApplyPolicyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.2)
DirectionType
Application direction.
As per the MIB.
hh3cCBQoSIfApplyPolicyName (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.3)
read-create
OCTET STRING
SIZE (1..31)
Policy name.
As per the MIB.
hh3cCBQoSIfApplyPolicyEnableDynamic (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.4)
read-create
INTEGER
·     unavailable(1)
·     true(2)
·     false(3)
Dynamic QoS
Not supported. The value is fixed at unavailable(1).
hh3cCBQoSIfApplyPolicyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.5)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSIfApplyPolicyStatus (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.6)
read-only
INTEGER
·     processing (0)
·     success (1)
·     partialItemFailed (2)
Application status.
As per the MIB.
About this table
This table applies a QoS policy to a VLAN interface.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSVlanApplyPolicyVlanid and hh3cCBQoSVlanApplyPolicyDirection.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSVlanApplyPolicyVlanid (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.1)
Integer32
VLAN ID.
As per the MIB.
hh3cCBQoSVlanApplyPolicyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.2)
DirectionType
As per the MIB.
hh3cCBQoSVlanApplyPolicyName (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.3)
read-create
OCTET STRING
SIZE (0..31)
Policy name.
As per the MIB.
hh3cCBQoSVlanApplyPriority (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.4)
read-create
Integer32
0..4095
Policy priority.
hh3cCBQoSVlanApplyPolicyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.5)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSVlanApplyPolicyStatus (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.6)
read-only
INTEGER
·     processing (1)
·     success (2)
·     partialItemFailed (3)
Application status.
As per the MIB.
About this table
This table applies a QoS policy globally.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cCBQoSGlobalApplyDirection.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSGlobalApplyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.6.1.1)
not-accessible
DirectionType
As per the MIB.
hh3cCBQoSGlobalApplyName (1.3.6.1.4.1.25506.2.65.2.1.4.6.1.2)
read-create
OCTET STRING
SIZE (1..31)
Policy name.
As per the MIB.
hh3cCBQoSGlobalApplyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.4.6.1.3)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSGlobalApplyStatus (1.3.6.1.4.1.25506.2.65.2.1.4.6.1.4)
read-only
INTEGER
·     processing (1)
·     success (2)
Application status.
As per the MIB.
About this table
This table describes application information for a QoS policy applied to a control plane.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSCpApplyPolicyChassis, hh3cCBQoSCpApplyPolicySlot, and hh3cCBQoSCpApplyPolicyDirection.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSCpApplyPolicyChassis (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.1)
not-accessible
Unsigned32
Chassis number for the control plane.
As per the MIB.
(1.3.6.1.4.1.25506.2.65.2.1.4.7.1.2)
not-accessible
Unsigned32
Slot number for the control plane.
As per the MIB.
hh3cCBQoSCpApplyPolicyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.3)
not-accessible
DirectionType
As per the MIB.
hh3cCBQoSCpApplyPolicyName (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.4)
read-create
OCTET STRING
SIZE (1..31)
Policy name.
As per the MIB.
hh3cCBQoSCpApplyPolicyStatus
(1.3.6.1.4.1.25506.2.65.2.1.4.7.1.5)
read-only
INTEGER
·     processing (0)
·     success (1)
Application status.
As per the MIB.
hh3cCBQoSCpApplyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.6)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table obtains the application entity information for a QoS policy.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cCBQoSApplyObjectIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.1)
not-accessible
Unsigned32
Application entity index.
As per the MIB.
hh3cCBQoSApplyObjectType (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.2)
read-only
ApplyObjectType
Application entity type.
·     interface(1)
·     vlan(2)
·     controlPlane(5)
hh3cCBQoSApplyObjectDirection (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.3)
read-only
DirectionType
Application entity direction.
As per the MIB.
hh3cCBQoSApplyObjectMainSite (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.4)
read-only
Unsigned32
Main index of the application entity.
As per the MIB.
hh3cCBQoSApplyObjectSubChannel (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.5)
read-only
Unsigned32
Subchannel ID of the application entity.
As per the MIB.
hh3cCBQoSApplyObjectSubClass (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.6)
read-only
Unsigned32
Level-1 subclass number for level-2 nesting.
As per the MIB.
hh3cCBQoSApplyObjectSubClassSec (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.7)
read-only
Unsigned32
Level-2 subclass number for level-3 nesting.
As per the MIB.
About this table
This table obtains the application entity index for a QoS policy applied to an interface.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSIntApplyObjectIfIndex and hh3cCBQoSApplyObjectDirection.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSIntApplyObjectIfIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.2.1.1)
not-accessible
Unsigned32
As per the MIB.
hh3cCBQoSIntApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.2.1.2)
read-only
Unsigned32
As per the MIB.
About this table
This table obtains the application entity index for a QoS policy applied to a VLAN or globally.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cCBQoSVlanApplyObjectVlanID and hh3cCBQoSApplyObjectDirection.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSVlanApplyObjectVlanID (1.3.6.1.4.1.25506.2.65.2.1.5.5.3.1.1)
not-accessible
Unsigned32
0..4094
ID of the VLAN to which a QoS policy is applied.
When the value is 0, the QoS policy is applied globally.
hh3cCBQoSVlanApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.3.1.2)
read-only
Unsigned32
As per the MIB.
About this table
This table obtains the application entity index for a child QoS policy.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cCBQoSApplyObjectIndex and hh3cCBQoSNestPolicyClassIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSNestPolicyClassIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.5.1.1)
not-accessible
Unsigned32
Policy class index.
As per the MIB.
hh3cCBQoSNestPolicyApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.5.1.2)
read-only
Unsigned32
As per the MIB.
About this table
This table obtains QoS policy application information for a control plane.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cCBQoSCpApplyObjectChassis, hh3cCBQoSCpApplyObjectSlot, and hh3cCBQoSApplyObjectDirection.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSCpApplyObjectChassis (1.3.6.1.4.1.25506.2.65.2.1.5.5.6.1.1)
not-accessible
Unsigned32
As per the MIB.
hh3cCBQoSCpApplyObjectSlot (1.3.6.1.4.1.25506.2.65.2.1.5.5.6.1.2)
not-accessible
Unsigned32
As per the MIB.
hh3cCBQoSCpApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.6.1.3)
read-only
Unsigned32
As per the MIB.
About this table
This table obtains CBQ queue statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSCbqQueueSize (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.1)
read-only
Integer32
Current CBQ queue size.
As per the MIB.
hh3cCBQoSCbqDiscard (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.2)
read-only
Counter64
Number of packets dropped by the CBQ queue.
As per the MIB.
hh3cCBQoSCbqEfQueueSize (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.3)
read-only
Integer32
EF queue size.
As per the MIB.
hh3cCBQoSCbqAfQueueSize (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.4)
read-only
Integer32
AF queue size.
As per the MIB.
hh3cCBQoSCbqBeQueueSize (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.5)
read-only
Integer32
BE queue size.
As per the MIB.
hh3cCBQoSCbqBeActiveQueueNum (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.6)
read-only
Integer32
Number of active BE queues.
As per the MIB.
hh3cCBQoSCbqBeMaxActiveQueueNum (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.7)
read-only
Integer32
Maximum number of active BE queues that have existed.
As per the MIB.
hh3cCBQoSCbqBeTotalQueueNum (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.8)
read-only
Integer32
Total number of BE queues.
As per the MIB.
hh3cCBQoSCbqAfAllocatedQueueNum (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.9)
read-only
Integer32
Number of AF queues that have been allocated.
As per the MIB.
About this table
This table obtains matching statistics about a traffic class.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cCBQoSApplyObjectIndex and hh3cCBQoSPolicyClassIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSClassMatchedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.1)
read-only
Counter64
Number of matching packets.
As per the MIB.
hh3cCBQoSClassMatchedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.2)
read-only
Counter64
Number of matching bytes.
As per the MIB.
hh3cCBQoSClassFwdPktpps (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.3)
read-only
Unsigned32
Number of packets sent per second during the last collection interval.
Not supported
hh3cCBQoSClassFwdPktbps (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.4)
read-only
Unsigned32
Number of bits sent per second during the last collection interval.
Not supported
hh3cCBQoSClassDropPktpps (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.5)
read-only
Unsigned32
Number of packets dropped per second during the last collection interval.
Not supported
hh3cCBQoSClassDropPktbps (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.6)
read-only
Unsigned32
Number of bits dropped per second during the last collection interval.
Not supported
hh3cCBQoSClassFlowStatInterval (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.7)
read-only
Unsigned32
Statistics collection interval.
Not supported
hh3cCBQoSClassBehaviorStatus (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.8)
read-only
INTEGER
·     success(1)
·     failure(2)
·     partialSuccess(3)
CB association application status.
As per the MIB.
About this table
This table obtains CAR statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSCarGreenPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.1)
read-only
Counter64
Number of packets matching the CAR configuration
As per the MIB.
hh3cCBQoSCarGreenBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.2)
read-only
Counter64
Number of bytes matching the CAR configuration
As per the MIB.
hh3cCBQoSCarRedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.3)
read-only
Counter64
Number of red packets.
As per the MIB.
hh3cCBQoSCarRedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.4)
read-only
Counter64
Number of red bytes.
As per the MIB.
hh3cCBQoSCarYellowPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.5)
read-only
Counter64
Number of yellow packets.
As per the MIB.
hh3cCBQoSCarYellowBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.6)
read-only
Counter64
Number of yellow bytes.
As per the MIB.
hh3cCBQoSCarClassName (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.7)
read-only
OCTET STRING
SIZE (1..31)
Traffic class name.
As per the MIB.
About this table
This table obtains marking statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSRemarkedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.5.1.1)
read-only
Counter64
Number of packets marked.
As per the MIB.
About this table
.This table obtains queue-related traffic statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSQueueMatchedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.1)
read-only
Counter64
Number of packets matching a queue.
As per the MIB.
hh3cCBQoSQueueMatchedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.2)
read-only
Counter64
Number of bytes matching the queue.
As per the MIB.
hh3cCBQoSQueueEnqueuedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.3)
read-only
Counter64
Number of packets enqueued.
As per the MIB.
hh3cCBQoSQueueEnqueuedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.4)
read-only
Counter64
Number of bytes enqueued.
As per the MIB.
hh3cCBQoSQueueDiscardedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.5)
read-only
Counter64
Number of packets dropped by the queue.
As per the MIB.
hh3cCBQoSQueueDiscardedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.6)
read-only
Counter64
Number of bytes dropped by the queue.
As per the MIB.
About this table
This table obtains traffic statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSAccountingPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1.1)
read-only
Counter64
Number of packets.
As per the MIB.
hh3cCBQoSAccountingBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1.2)
read-only
Counter64
Number of bytes.
As per the MIB.
hh3cCBQoSAccountingPktpps (1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1.3)
read-only
Counter64
Traffic rate in pps.
As per the MIB.
hh3cCBQoSAccountingPktbps (1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1.4)
read-only
Counter64
Traffic rate in bps.
As per the MIB.
About this table
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSPolicyAccPackets
read-only
Counter64
Number of packets.
As per the MIB.
hh3cCBQoSPolicyAccBytes
read-only
Counter64
Number of bytes.
As per the MIB.
Notifications
The following information describes the notifications included in the HH3C-CBQOS2-MIB module.
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.65.2.1.7.0.1
The application status of a QoS policy on an interface changed.
Informational
Warning
N/A
OFF
Notification triggers
The notification is generated when the application status of a QoS policy on an interface changes.
System impact
The QoS policy applied take effect on the interface.
Status control
ON
·     CLI: Use the snmp-agent trap enable qos command.
OFF
·     CLI: Use the undo snmp-agent trap enable qos command.
Objects
OID (object name)
Index nodes
Value range
Interface index
N/A
Integer32
N/A
DirectionType
Recommended action
No action is required.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.2.1.7.0.2
Informational
Warning
N/A
OFF
The notification is generated when the application status of a QoS policy on a VLAN interface changes.
System impact
The QoS policy applied take effect on the VLAN interface.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
VLAN ID
N/A
Integer32
N/A
DirectionType
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.2.1.7.0.3
The global ACL is not supported.
Informational
Warning
N/A
OFF
This notification is generated when you apply a QoS policy globally and a card does not support the ACL used in the QoS policy.
System impact
The QoS policy applied globally does not take effect on the card.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
hh3cCBQoSChassis
Chassis number
N/A
Integer32
0..65534
hh3cCBQoSSlot
Slot number
N/A
Integer32
0..65534
hh3cCBQoSCPU
CPU number
N/A
Integer32
0..65534
hh3cCBQoSDirection
N/A
DirectionTyp
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.2.1.7.0.4
QPPB is not supported.
Informational
Warning
N/A
OFF
This notification is generated when you apply a QoS policy globally in QPPB mode and a card does not support QPPB.
System impact
The QoS policy applied globally in QPPB mode does not take effect on the card.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
hh3cCBQoSChassis
Chassis number
N/A
Integer32
0..65534
hh3cCBQoSSlot
Slot number
N/A
Integer32
0..65534
hh3cCBQoSCPU
CPU number
N/A
Integer32
0..65534
hh3cCBQoSDirection
N/A
DirectionTyp
Recommended action
Apply a QoS policy in QPPB mode to the interfaces on the card that support the QPPB mode.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.2.1.7.0.5
The redirection next hop is unreachable.
Error
Major
OFF
This notification is generated when the redirection next hop is unreachable.
System impact
The QoS policy containing the redirection action does not take effect.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.65.2.1.8.5 (hh3cCBQoSRedirectAlarmBehaviorName)
N/A
OCTET STRING
SIZE (1..31)
1.3.6.1.4.1.25506.2.65.2.1.8.6 (hh3cCBQoSRedirectAlarmProtoFamily)
Protocol family of the next-hop address
N/A
InetAddressType
1.3.6.1.4.1.25506.2.65.2.1.8.7 (hh3cCBQoSRedirectAlarmNextHop)
Next-hop address
N/A
InetAddress
Recommended action
To resolve the issue, identify whether the next hop exists in the routing table. If the next hop does not exist in the routing table, configure a routing protocol for the next hop to be learned to the routing table.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.2.1.7.0.6
The redirection next hop is reachable.
Recovery
Major
N/A
OFF
This notification is generated when the redirection next hop is reachable.
System impact
No negative impact on the system.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET STRING
SIZE (1..31)
N/A
InetAddressType
Next-hop address
N/A
InetAddress
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.2.1.7.0.7
The resources for redirection next hop are insufficient.
Error
Major
OFF
The notification is generated when the resources for redirection next hop are insufficient.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET STRING
SIZE (1..31)
1.3.6.1.4.1.25506.2.65.2.1.8.2 (hh3cCBQoSSlot)
Slot number
N/A
Integer32
0..65534
N/A
InetAddressType
Next-hop address
N/A
InetAddress
1.3.6.1.4.1.25506.2.65.2.1.8.4 hh3cCBQoSDirection)
N/A
DirectionType
1.3.6.1.4.1.25506.2.65.2.1.8.8 (hh3cCBQoSApplyObject)
Application object
N/A
OCTET STRING
SIZE (1..127)
Recommended action
To resolve the issue:
1.     Reduce deployed services.
2.     If the issue persists, collect alarm information, log messages, and configuration data, and then contact Technical Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.2.1.7.0.8
The resources for redirection next hop become sufficient.
Recovery
Major
N/A
OFF
The notification is generated when the resources for redirection next hop become sufficient.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET STRING
SIZE (1..31)
Slot number
N/A
Integer32
0..65534
N/A
InetAddressType
Next-hop address
N/A
InetAddress
N/A
DirectionType
Application object
N/A
OCTET STRING
SIZE (1..127)
Recommended action
