02-HH3C-MAD-MIB | 51.23 KB |
HH3C-MAD-MIB
About this MIB
Use this MIB to obtain IRF state data for management purposes.
MIB file name
hh3c-mad.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMad (253)
Notifications
This section contains the IRF MAD notifications.
hh3cMadConflictDetect
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.253.1.0.1 |
Multi-active collision occurred upon IRF split. |
Error |
Warning |
1.3.6.1.4.1.25506.2.253.1.0.2 (hh3cMadConflictResume) |
ON |
Notification triggers
This notification is generated when the MAD mechanism detects that the IRF fabric has split.
System impact
The IRF fabric splits into two or more IRF fabrics.
MAD disables all IRF fabrics except one from forwarding data traffic by shutting down all their network ports except those excluded manually or by default from the MAD shutdown action.
The down interfaces cannot provide services.
Status control
This notification cannot be disabled.
Objects
N/A
Recommended action
1. Execute the display irf topology command to identify the topology of the IRF fabric.
2. Check the physical connections of the IRF ports for miscabling.
Verify that the physical interfaces of IRF-port 1 on one member are connected to the physical interfaces of IRF-port 2 on the other.
3. Execute the display irf link and display interface commands to identify the failed interface and failure cause, respectively. Recover the link based on the provided failure cause.
4. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.253.1.0.2 |
IRF merge occurred or IRF fabric recovery occurred upon execution of the mad restore command. |
Recovery |
Warning |
N/A |
ON |
This notification is generated when IRF merge occurs or when the IRF fabric is recovered from the inactive state by using the mad restore command.
System impact
No negative impact on the system.
Status control
Objects
N/A
Recommended action
No action is required.
