04-Virtual Technologies
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 6715-6W10004-Virtual Technologies
01-HH3C-LswMix-MIB
01-HH3C-LswMix-MIB 68.56 KB
HH3C-LswMix-MIB
About this MIB
Use this MIB to obtain information about slot roles in an IRF fabric, trigger an active/standby or master/subordinate switchover, and obtain information about switchover records.
MIB file name
hh3c-splat-mix.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswMix(17)
Scalar objects
hh3cLswLastSwitchDate
Object (OID)
Access
Value range
Implementation
hh3cLswLastSwitchDate (1.3.6.1.4.1.25506.8.35.17.1)
read-only
Integer32
Standard MIB values.
Date on which the last active/standby or master/subordinate switchover occurred.
The read operation is not supported on a non-default MDC.
hh3cLswLastSwitchTime
Object (OID)
Access
Value range
Implementation
hh3cLswLastSwitchTime (1.3.6.1.4.1.25506.8.35.17.2)
read-only
Integer32
Time when the last active/standby or master/subordinate switchover occurred.
hh3cLswMpuSwitchsNum
Object (OID)
Access
Value range
Implementation
hh3cLswMpuSwitchsNum (1.3.6.1.4.1.25506.8.35.17.3)
read-only
Integer32
Number of times active/standby or master/subordinate switchovers occurred.
hh3cLswMpuSwitch
Object (OID)
Access
Value range
Implementation
hh3cLswMpuSwitch (1.3.6.1.4.1.25506.8.35.17.4)
read-write
INTEGER
switch(1)
This object triggers an active/standby or master/subordinate switchover.
The read operation is not supported.
Tabular objects
hh3cLswXSlotTable
About this table
Use this table to obtain slot role information in an IRF fabric. For modular devices, a slot refers to an MPU or an interface module. For fix-port devices or expandable fixed-port devices, a slot refers to an IRF member device.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cLswFrameIndex and hh3cLswSlotIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswMainCardBoardStatus (1.3.6.1.4.1.25506.8.35.17.5.1.1)
read-only
INTEGER
master(1),
standby(2),
process(3)
Role of a slot in an IRF fabric.
As per the MIB.
hh3cLswCrossBarStatus (1.3.6.1.4.1.25506.8.35.17.5.1.2)
read-only
INTEGER
master(1),
standby(2)
Cross bar role of the slot.
Not supported.
Notifications
The following information describes the notifications included in the HH3C-LswMix-MIB module.
hh3cSlaveSwitchOver
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.8.35.17.10.1
An active/standby or master/subordinate switchover occurred.
Informational
Minor
N/A
ON
Notification triggers
(Centralized IRF devices.) This notification is generated when a master/subordinate switchover occurs in an IRF fabric.
(Distributed devices.) This notification is generated when an active/standby or master/subordinate switchover occurs.
System impact
No negative impact on services.
Status control
This notification cannot be disabled.
Objects
N/A
Recommended action
To resolve this issue:
1.     Identify whether the switchover is done administratively to determine the action to take:
¡     If the switchover was performed manually, no action is required.
¡     If the switchover occurred unexpectedly, examine the device operating conditions to troubleshoot the issue.
2.     If the issue persists, contact H3C Support.
